H3C G6 Servers HDM2 IPMI Technology White Paper-6W101
HomeSupportTechnology LiteratureTechnology White PapersH3C G6 Servers HDM2 IPMI Technology White Paper-6W101
Download Book
  • Released At: 05-06-2025
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
H3C G6 Servers HDM2
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Overview
About IPMI
The Intelligent Platform Management Interface (IPMI) is a standard applied to the design of server management systems and was jointly proposed by Intel, HP, Dell, and NEC in 1998. The main highlight of IPMI is its independence from processors, the BIOS, and the operating system. Using this standard can help implement system management on different types of server hardware, realizing centralized management of different platforms.
The IPMI system communicates through the Baseboard Management Controller (BMC), the core controller of the IPMI platform that connects to the main processor and onboard components, to monitor and manage physical components.
The independence of the BMC system enables IPMI to provide enterprise-level HA, which allows the IPMI platform to remain available even when the system is powered off. You can obtain platform status information and perform recovery operations even if both the system management software and normal inband management mechanism are not available. Through independent monitoring, logging, and other functions, IPMI provides a built-in manageable platform for server hardware.
IPMI defines a set of standard APIs to provide out-of-band management and monitoring capabilities. The main IPMI features include the following:
·     Asset management.
·     Fault monitoring.
·     Logging.
·     Recovery mechanism.
Protocol
IPMI interfaces
IPMI uses message-based interfaces to connect management subsystems (such as IPMB and LAN) of the platform. All IPMI messages share the same fields in the message payload, regardless of interfaces through which messages are transferred. The payload of IPMI messages is available for each interface specified by IPMI, but is encapsulated in different ways based on the transmission demands. This allows the management software on an interface to use another interface by changing the basic driver for a specific transmission.
The system interface connects to a system bus that can be driven by the primary processors. The current IPMI system interfaces can be I/O or memory mapped. IPMI can use any timing specification-compliant system bus that allows the primary processors to access the specified I/O or memory locations. For example, an IPMI system interface can connect to the network, PCI, LPC, or a proprietary bus of the baseboard chip set.
IPMI messaging
IPMI messaging uses a request/response protocol. IPMI request messages are typically referred to as commands. Using a request/response protocol can promote the transfer of IPMI messages over different transports, and supports multi-master operations on buses such as Intelligent Platform Management Bus (IPMB). It also allows messages to be interleaved and multiple management controllers to intercommunicate directly on the bus.
IPMI commands are functionally grouped into command sets depending on a field called the network function code. These command sets contain sensor and event commands, chassis commands, and other commands. This function-based grouping facilitates organizing and managing command value assignment.
All IPMI request messages have a network function, command and optional data fields. All IPMII response messages carry network function, command, optional data, and a completion code field.
Message format
The core of the IPMI protocol is to standardize the definition of message data formats such as sensors, event messages, and SDRs in the platform management architecture. Table 1 shows the components of an IPMI message specified in the protocol.
Table 1 IPMI message format
Network function (NetFn)
Identifies the function class of the message. The network function groups IPMI commands into different sets.
Request/Response identifier
Differentiates request messages from response messages. In the IPMI protocol, this identifier merges with the NetFn code, where an even NetFn code presents a request message, and an odd code presents a response message.
Requester ID
Identifies the request source. The information of this field must be complete for the response to return to the target requester. For example, for the IPMB requester ID contains the subordinate address and LUN of the requester device. For a multi-stream system interface, the requester ID is the stream ID for the stream through which the request was sent.
Responder ID
Identifies the responder to the request. In a request message, this field transfers the request to the desired responder. In a response message, this field helps the requester matching the response with a given request.
Indicates the one-byte command field in the messages specified in this document. A command is unique within a specific network function. Command values lies in the range of from 00h to FDh. Code FEh is reserved for the future extensions of the specification, and code FFh is reserved for message interface level errors reported on future interfaces.
Data
Carries other parameters, if any, in a request or a response.
Network function code
Table 2 lists NetFn codes, which can group commands into functional command sets.
Table 2 NetFn codes
Values (hexadecimal)
Name
00,01
Chassis
Identifies a message for typical chassis functions, such as a power-on or power-off operation.
02,03
Bridge
Identifies a message that contains bridging data. This code is available only on a bridge device.
04,05
Sensor/Event
Used for event messages and system sensors.
.06,07
Application
Identifies an application-related message. The format of application messages vary by device model.
08,09
Firmware
Identifies a firmware-related message, such as a message for online upgrade.
0A,0B
Storage
Identifies a message for access to non-volatile storage, such as EEPROM.
0C,0D
Transport
Identifies a message for access interfaces, such as configuration of serial and LAN interfaces.
2C,2D
Group extension
Used for other protocol communication, where the first data byte represents the protocol type.
2E,2F
OEM extension
Used for IANA. The first three data bytes must be IANA enterprise numbers.
30-3F
Custom
Reserved for vendor-customized commands.
Completion codes
All response messages contain a completion code as the first byte in the data field of the response. A management controller must return an error completion code for an invalid request.
Completion code values are divided into generic and feature-specific (including OEM) types. All commands can return generic completion codes. Commands that are executed successfully will return the 00h execution success code.
Table 3 IPMI completion codes
Code (hexadecimal)
Definition
00
Execution success.
C0
Busy target.
C1
Invalid command.
C2
The target LUN does not support the command.
C3
Timeout error.
C4
Out of range.
C5
Reservation canceled or invalid reservation ID.
C6
Incomplete request data.
C7
Invalid data length.
C8
Request data out of range.
C9
Parameter out of range.
CA
Cannot return the number of requested data.
CB
Requested sensor, data, or record not present.
CC
Invalid data in the request message.
CD
Illegal for the specified sensor or record.
CE
Cannot respond to the request.
CF
Duplicate request.
D0
Cannot respond to the command for the SDR repository is being upgraded.
D1
Cannot respond to the command for the firmware is being upgraded.
D2
Cannot respond to the command because of BMC initialization in progress.
D3
Invalid destination.
D4
Insufficient permissions or security level.
D5
Command execution not supported by the current configuration.
D6
Parameter error for the destination subsystem.
01-7E
Device-specific completion codes
80-BE
Reserved for command-specific codes.
Others
Reserved.
Channel model
IPMI v2.0 contains a common communication infrastructure that is referred to as the channel model.
Channels provide a mechanism for directing the transmission of IPMI messages between different media connected to BMC. A channel number can identify a specific connection. Channels can support multiple IPMB, LAN, or serial connections to BMC.
Channels primary IPMB (0h) and system interface (Fh) have a fixed channel ID. The channel ID of other channels can be customized.
Table 4 Channel definitions in HDM
Channel ID
Type/Protocol
0
Primary IPMB
Channel 0 is assigned to the primary IPMB.
1-Bh
Implementation specific
Assigned channel numbers, such as LAN1 (1h), LAN2 (8h), and ICMB(3h).
Ch-Dh
N/A
Reserved.
Eh
Current channel
Identifies the current channel. For example, if the software wants to obtain the channel attributes of the current interaction, but do not know the channel ID, it can identify the ID by executing the Get Channel Info command.
Fh
System interface
Channel F is assigned to the system interface.
IPMI sessions
The authenticated IPMI communication with BMC is realized by session establishment. After a session is established, a session ID identifies the session. You can consider the session ID as a handle for a connection between a given remote user and BMC. The IPMI specification supports establishing multiple sessions with BMC.
Session-less connections
A session-less connection is not authenticated, and no user login is required for IPMI messaging. The system interface and IPMI on the IPMB are connection-less sessions.
Session timeout
BMC automatically terminates a session if the session does not receive any valid messages in the specified interval after receiving the most recent valid message. Once terminated, a session must be re-authenticated for session activation.
BMC message bridging
BMC message bridging is used for IPMI messages between different media. Bridging only transmits messages between different channels. That is, it is not used for message transmission on the same channel.
In IPMI 1.0, bridging was used only for access between SMS and IPMB. In IPMI 1.5, bridging supports sessions of any media connected to the BMC.
Messages to SMS always receive the Receive Message Queue, so the Send Message command is not used for sending messages to SMS. Messages to SMS are transferred through BMC SMS LUN 10b. BMC always automatically converts messages to SMS into the LUN 10b format for SMS to obtain through the Get Message command.
KCS interface
Keyboard Controller Style (KCS) is a transfer protocol for BMC and SMS, and was used for transferring keyboard stroke data in earlier days, and its speed and efficiency is not high. The KCS interface supports polling, and an interrupt operation by the OBF flag is optional.
BMC LUN
A logical unit number (LUN) is two bits in length. In the IPMB protocol, LUN is a sub-address for delivering messages to different logical units on the physical device.
LUN 00b is typically used for sending all messages to BMC through the KCS interface. LUN 10b is reserved for the Receive Message Queue and cannot be used for sending commands to BMC.
KCS interface-BMC request message format
Request messages are sent to BMC from the system software through the KCS interface. The message bytes are organized as shown in Figure 1.
Figure 1 KCS interface-BMC request message format
Table 5 Request message byte description
Byte name
LUN
Sub-address of different LUNs behind the same physical interface, 2 bits in length.
NetFn
Network function code, which occupies the most significant six bits in the first message byte. An even NetFn code value is used for requests to BMC, and an odd NetFn code value resides in the responses from BMC.
Cmd
Message byte that specifies the operation to execute under the specified network function.
Data
Zero or more bytes of data required by a given command. The convention is typically to first pass data LS-byte. However, the implementation varies by command specification.
BMC-KCS interface response message format
Response messages are data from BMC to the system software through the KCS interface. BMC returns responses through the KCS interface only when data needs to be returned. The message bytes are organized as shown in Figure 2.
Figure 2 BMC-KCS interface response message format
Table 6 Response message format description
Byte name
LUN
LUN that was passed in the request message.
NetFn
NetFn code. An odd NetFn value is returned.
Cmd
Cmd code that was passed in the request message.
Completion code
Indicates whether the request message is completed successfully.
Data
Zero or more bytes of data. BMC always returns a response to acknowledge the request, no matter whether it returns data.
LAN interface
The LAN interface specifications define how to transmit IPMI messages to BMC encapsulated in Remote Management Control Protocol (RMCP) packet datagrams, which is also referred to as IPMI over LAN. IPMI also defines related LAN-specific configuration interfaces for setting other option settings such as IP addresses, and commands for discovering IPMI-based systems.
Figure 3 IPMI LAN interface architecture
The Distributed Management Task Force (DMTF) specifies the RMCP format. This packet format is used for publication through the DMTF's Alert Standard Forum (ASF) specification. The use of the RMCP packet format enables standardized operations between management applications.
IPMI v2.0 defines extended packet formats and functions, which are collectively referred to as RMCP+. RMCP+ is defined in the IPMI-specific part of an RMCP packet. The authentication algorithms used by RMCP+ are more closely to the mechanisms of the ASF 2.0 specification. In addition, RMCP+ provides data confidentiality (encryption) and the payload capability
For LAN transmission, IPMI messages are a special data format encapsulated in IPMI session packets. IPMI session packets are encapsulated in RMCP packets, and RCMP packets are encapsulated in UDP datagrams, as shown in Figure 4.
In RMCP/ASF network transmission, the order with the most-significant byte first is applied. The IPMI specification defines that the order with the least-significant byte first is used for transmitting multi-byte numeric fields. Unless otherwise specified, the order with the least-significant byte first is applied to transmit data in the IPMI session header and IPMI message fields.
Figure 4 RMCP+ packet encapsulation
BT interface protocol
Block Transfer (BT) is a transmission protocol used for BMC and SMS. The BT interface defines messages for SMS or OEM, but does not define information transmission for BMC and SMI.
Due to the existence of a message data block buffering mechanism, when the trigger conditions are met, the controller is notified to retrieve the data characteristics, which is named the BT interface. Compared to the KCS interface, which is a byte-oriented communication method, the BT interface can obtain information about the buffer size and other details for subsequent information transmission through the "Get BT interface capabilities" command.
The BT interface on the host side is designed in either interrupt or polling mode. It can be used for event triggering (B2H_ATN) from BMC to the host side or for triggering interrupts (SMS_ATN) from system management software. Through interrupt operations, the host side can achieve efficient information transmission (H2B_ATN).
BT interface-BMC request format
When sending a request from system software to BMC through the BT interface, encapsulate the request data according to the format as shown in Figure 5. The specific data format and its meanings are described in Table 7.
Figure 5 Request data format
Table 7 Field description
Length
As part of the BT interface frame, this value records the length of the request content. The minimum length of the request is 3 bytes, which can at least include the NetFn/LUN, Seq, and Cmd byte content.
LUN
Subaddress of different LUNs after the same physical interface. The field length is 2 bits.
NetFn
Network function code. The NetFn field occupies the highest six bits of the first byte of the message.
·     Even NetFn values: Requests to BMC.
·     Odd NetFn values: Responses from BMC.
Seq
Sequence number of the BT interface command, which can be used to match responses with request messages, enabling the interaction process to support asynchronous responses. When combined with the NetFn and Cmd fields, it can determine a unique request.
Cmd
Used to specify the operation performed under the specified network function.
Data
Zero or more bytes of data, determined by the requirements of the given command. It is generally agreed to first transmit the low byte of the data, but the specific command specifications should be reviewed for confirmation.
BMC-BT interface response format
Response messages are data transmitted from BMC to system software via the BT interface. In general, the BMC always responds to the requests transmitted through the BT interface. Use the format as shown in Figure 6 to encapsulate the response data. The specific data format and its meanings are described in Table 8.
Figure 6 Reponses data format
Table 8 Field description
Length
As part of the BT interface frame, this value records the length of the response content. It can cover at least 4 bytes of content, including the NetFn/LUN, Seq, Cmd, and completion code fields.
LUN
LUN in the transmitted request message.
NetFn
Network function code, an odd value.
Seq
Sequence number of the BT interface command, which can be used to match responses with request messages, enabling support for asynchronous responses. When combined with the NetFn and Cmd values, it can determine a unique request command.
Cmd
Cmd code in the transmitted request message.
Completion code
Indicates whether the request has been successfully completed.
Data
Zero or more bytes of data. The BMC always returns a response to acknowledge the request, regardless of whether data is returned.
IPMItool
IPMItool is a system command line tool compatible with IPMI 1.5 and IPMI 2.0 standards. The KCS/BT-based IPMItool must operate in the OS of the server, and the LAN-based IPMItool can remotely manage the server.
The IPMItool third-party tool supports Windows and Linux.
Command format
An IPMI command uses the ipmitool -I connect_type -H hostname -U username -P password <command> format, where:
·     -I connect_typeSpecifies the connection method used to access the device to be managed. The connect_type argument is fixed to lanplus, which indicates that the device to be managed will be accessed as required in the IPMI 2.0 specification.
·     -H hostnameSpecifies the IP address of the device to be managed.
·     -U usernameSpecifies the HDM username of the device to be managed.
·     -P passwordSpecifies the HDM password of the device to be managed.
·     <command>—Specifies the action to be taken. This argument can be a string (chassis status for example) or a hexadecimal raw code (raw 0x00 0x01). For more information about this argument, see H3C HDM2 IPMI Basics Command Reference.
·     -LSpecifies the user role. The default user role is Administrator.
Features
Table 9 lists the features provided by IPMItool.
Table 9 IPMItool features
Keyword
raw
Send a RAW IPMI request and print response.
i2c
Send an I2C Master Write-Read command and print response.
spd
Print SPD info from remote I2C device.
lan
Configure LAN channels.
chassis
Get chassis status and set power status.
power
Shortcut to chassis power commands.
event
Send predefined events to MC.
mc
Management Controller status and global enables.
sdr
Print Sensor Data Repository entries and readings.
sensor
Print detailed sensor information.
fru
Print built-in FRU and scan SDR for FRU locators.
gendev
Read/Write Device associated with Generic Device locators sdr.
sel
Print system event log (SEL).
pef
Configure platform event filtering (PEF).
sol
Configure and connect IPMI v2.0 Serial-over-LAN.
tsol
Configure and connect with Tyan IPMI v1.5 Serial-over-LAN.
isol
Configure IPMI v1.5 Serial-over-LAN.
user
Configure Management Controller users.
channel
Configure Management Controller channels.
session
Print session information.
dcmi
Data Center Management Interface
firewall
Configure firmware firewall.
exec
Run list of commands from file.
set
Set runtime variable for shell and exec.
ekanalyzer
Run FRU-Ekeying analyzer using FRU files.
IPMItool examples
Example 1: Out-of-band method
# Obtain the value and health status of each sensor on the server through the out-of-band LAN channel.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sdr
Inlet_Temp       | 20 degrees C      | ok
CPU1_Status      | 0x00              | ok
CPU2_Status      | 0x00              | ok
CPU1_Temp        | 39 degrees C      | ok
CPU2_Temp        | 39 degrees C      | ok
CPU1_DTS         | -53 degrees C     | ok
CPU2_DTS         | -53 degrees C     | ok
CPU1_VR_Temp     | 41 degrees C      | ok
CPU2_VR_Temp     | 42 degrees C      | ok
PCH_Temp         | 40 degrees C      | ok
Power_Button     | 0x00              | ok
UID_Button       | 0x00              | ok
Watchdog2        | 0x00              | ok
Sys_Restart      | 0x00              | ok
Boards           | 0x00              | ok
Sys_FW_Progress  | 0x00              | ok
ACPI_State       | 0x00              | ok
BMC_Boot_Up      | 0x00              | ok
SEL_Status       | 0x00              | ok
SYS_12V          | 12.16 Volts       | ok
SYS_12V_Standby  | 12.10 Volts       | ok
SYS_5V           | 4.96 Volts        | ok
SYS_3V3_Standby  | 3.28 Volts        | ok
SYS_3V_BAT       | 2.92 Volts        | ok
Example 2: Inband method
# Obtain FRU information of the server through the inband LPC channel.
[root@localhost~]# ipmitool  fru
FRU Device Description : Builtin FRU Device (ID 0)
 Chassis Type          : Rack Mount Chassis
 Chassis Part Number   : 0200A00R
 Chassis Serial        : 750124
 Chassis Extra         : User Defined
 Chassis Extra         : 307BACC120AA
 Chassis Extra         : 6
 Chassis Extra         : FC9612PW11
 Board Mfg Date        : Fri Dec  8 00:00:00 2017
 Board Mfg             : H3C
 Board Product         : RS33M2C3S
 Board Serial          : 02A3TWH17C000085
 Board Part Number     : 0302A3TW
 Board Extra           : 210235A2CVH17C000003
 Product Manufacturer  : Unis Huashan Technologies Co., Ltd.
 Product Name          : 750124
 Product Part Number   : 0200A00R
 Product Version       : VERA
 Product Serial        : 638889
 Product Asset Tag     : h3c123456789
FRU Device Description : BackPlane1 (ID 2)
 Board Mfg Date        : Thu Sep 14 00:00:00 2017
 Board Mfg             : H3C
 Board Product         : RS33B04LA
 Board Serial          : 02A3GPH179000133
 Board Part Number     : 0302A3GP
 Board Extra           : 02A3GPH179000133
FRU Device Description : MB BIOS (ID 22)
 Product Manufacturer  : H3C
 Product Name          : BIOS
 Product Part Number   : C35
 Product Version       : 2.00.32P04
FRU Device Description : MB BMC (ID 21)
 Product Name          : BMC
 Product Part Number   : HDM
 Product Version       : 2.13.00
FRU Device Description : Riser1 (ID 16)
 Board Mfg Date        : Sun Aug 13 08:00:00 2017
 Board Mfg             : H3C
 Board Product         : RS33RGPX16
 Board Serial          : 02A3H9H178000022
 Board Part Number     : 0302A3H9
 Board Extra           : 02A3H9H178000022
FRU Device Description : mLOM (ID 3)
 Board Mfg Date        : Tue Dec  5 00:00:00 2017
 Board Mfg             : H3C
 Board Product         : RS33NGT4M
 Board Serial          : 02A3GKH17B000267
 Board Part Number     : 0302A3GK
 Board Extra           : 02A3GKH17B000267
HDM IPMI implementation
H3C BMC management software, HDM, is compatible with IPMI 1.5 and IPMI 2.0 standards. It can effectively manage a server by using a third-party tool, such as IPMItool, through the LPC- or eSPI-based KCS/BT or LAN-based UDP or IP.
·     If LPC-based KCS is used, the third-party tool must operate in the OS of the server.
·     If LAN-based UDP or IP is used, the third-party tool can remotely manage the server.
HDM supports using the AES-CBC-128 algorithm for encryption and using the HMAC-SHA1 or HMAC-SHA256 algorithm for authentication and integrity checking.
IPMI standard commands
Table 12 lists standard IPMI Spec commands.
Table 10 HDM IPMI Spec standard commands
NetFn
CMD
Command description
HDM support
App
01h
Get Device ID
Yes
App
01h
Broadcast 'Get Device ID'
Yes
App
02h
Cold Reset
Yes
App
03h
Warm Reset
Yes
App
04h
Get Self Test Results
Yes
App
05h
Manufacturing Test On
Yes
App
06h
Set ACPI Power State
Yes
App
07h
Get ACPI Power State
Yes
App
08h
Get Device GUID
Yes
App
09h
Get NetFn Support
Yes
App
0Ah
Get Command Support
Yes
App
0Bh
Get Command Sub-function Support
Yes
App
0Ch
Get Configurable Commands
Yes
App
0Dh
Get Configurable Command Sub-functions
Yes
App
22h
Reset Watchdog Timer
Yes
App
24h
Set Watchdog Timer
Yes
App
25h
Get Watchdog Timer
Yes
App
2Eh
Set BMC Global Enables
Yes
App
2Fh
Get BMC Global Enables
Yes
App
30h
Clear Message Flags
Yes
App
31h
Get Message Flags
Yes
App
32h
Enable Message Channel Receive
Yes
App
33h
Get Message
Yes
App
34h
Send Message
Yes
App
35h
Read Event Message Buffer
Yes
App
36h
Get BT Interface Capabilities
Yes
App
37h
Get System GUID
Yes
App
38h
Get Channel Authentication Capabilities
Yes
App
39h
Get Session Challenge
Yes
App
3Ah
Activate Session
Yes
App
3Bh
Set Session Privilege Level
Yes
App
3Ch
Close Session
Yes
App
3Dh
Get Session Info
Yes
App
3Fh
Get AuthCode
No
App
40h
Set Channel Access
Yes
App
41h
Get Channel Access
Yes
App
42h
Get Channel Info Command
Yes
App
43h
Set User Access Command
Yes
App
44h
Get User Access Command
Yes
App
45h
Set User Name
Yes
App
46h
Get User Name Command
Yes
App
47h
Set User Password Command
Yes
App
48h
Activate Payload
Yes
App
49h
Deactivate Payload
Yes
App
4Ah
Get Payload Activation Status
Yes
App
4Bh
Get Payload Instance Info
Yes
App
4Ch
Set User Payload Access
Yes
App
4Dh
Get User Payload Access
Yes
App
4Eh
Get Channel Payload Support
Yes
App
4Fh
Get Channel Payload Version
Yes
App
50h
Get Channel OEM Payload Info
Yes
App
52h
Master Write-Read
Yes
App
54h
Get Channel Cipher Suites
Yes
App
55h
Suspend/Resume Payload Encryption
No
App
56h
Set Channel Security Keys
Yes
App
57h
Get System Interface Capabilities
Yes
App
58h
Set System Info Parameters
Yes
App
59h
Get System Info Parameters
Yes
App
60h
Set Command Enables
Yes
App
61h
Get Command Enables
Yes
App
62h
Set Command Sub-function Enables
Yes
App
63h
Get Command Sub-function Enables
Yes
App
64h
Get OEM NetFn IANA Support
Yes
Chassis
00h
Get Chassis Capabilities
Yes
Chassis
01h
Get Chassis Status
Yes
Chassis
02h
Chassis Control
Yes
Chassis
03h
Chassis Reset
No
Chassis
04h
Chassis Identify
Yes
Chassis
05h
Set Chassis Capabilities
Yes
Chassis
06h
Set Power Restore Policy
Yes
Chassis
07h
Get System Restart Cause
Yes
Chassis
08h
Set System Boot Options
Yes
Chassis
09h
Get System Boot Options
Yes
Chassis
0Ah
Set Front Panel Button Enables
Yes
Chassis
0Bh
Set Power Cycle Interval
Yes
Chassis
0Fh
Get POH Counter
Yes
S/E
00h
Set Event Receiver
Yes
S/E
01h
Get Event Receiver
Yes
S/E
02h
Platform Event (a.k.a. “Event Message”)
Yes
S/E
10h
Get PEF Capabilities
Yes
S/E
11h
Arm PEF Postpone Timer
Yes
S/E
12h
Set PEF Configuration Parameters
Yes
S/E
13h
Get PEF Configuration Parameters
Yes
S/E
14h
Set Last Processed Event ID
Yes
S/E
15h
Get Last Processed Event ID
Yes
S/E
16h
Alert Immediate
Yes
S/E
17h
PET Acknowledge
Yes
S/E
20h
Get Device SDR Info
Yes
S/E
21h
Get Device SDR
Yes
S/E
22h
Reserve Device SDR Repository
Yes
S/E
23h
Get Sensor Reading Factors
Yes
S/E
24h
Set Sensor Hysteresis
Yes
S/E
25h
Get Sensor Hysteresis
Yes
S/E
26h
Set Sensor Threshold
Yes
S/E
27h
Get Sensor Threshold
Yes
S/E
28h
Set Sensor Event Enable
Yes
S/E
29h
Get Sensor Event Enable
Yes
S/E
2Ah
Re-arm Sensor Events
Yes
S/E
2Bh
Get Sensor Event Status
Yes
S/E
2Dh
Get Sensor Reading
Yes
S/E
2Eh
Set Sensor Type
Yes
S/E
2Fh
Get Sensor Type
Yes
S/E
30h
Set Sensor Reading And Event Status
No
Storage
10h
Get FRU Inventory Area Info
Yes
Storage
11h
Read FRU Data
Yes
Storage
12h
Write FRU Data
Yes
Storage
20h
Get SDR Repository Info
Yes
Storage
21h
Get SDR Repository Allocation Info
Yes
Storage
22h
Reserve SDR Repository
Yes
Storage
23h
Get SDR
Yes
Storage
24h
Add SDR
No
Storage
25h
Partial Add SDR
No
Storage
26h
Delete SDR
No
Storage
27h
Clear SDR Repository
No
Storage
28h
Get SDR Repository Time
Yes
Storage
29h
Set SDR Repository Time
No
Storage
2Ah
Enter SDR Repository Update Mode
No
Storage
2Bh
Exit SDR Repository Update Mode
No
Storage
2Ch
Run Initialization Agent
Yes
Storage
40h
Get SEL Info
Yes
Storage
41h
Get SEL Allocation Info
Yes
Storage
42h
Reserve SEL
Yes
Storage
43h
Get SEL Entry
Yes
Storage
44h
Add SEL Entry
Yes
Storage
45h
Partial Add SEL Entry
Yes
Storage
46h
Delete SEL Entry
Yes
Storage
47h
Clear SEL
Yes
Storage
48h
Get SEL Time
Yes
Storage
49h
Set SEL Time
Yes
Storage
5Ah
Get Auxiliary Log Status
No
Storage
5Bh
Set Auxiliary Log Status
No
Storage
5Ch
Get SEL Time UTC Offset
Yes
Storage
5Dh
Set SEL Time UTC Offset
Yes
Transport
01h
Set LAN Configuration Parameters
Yes
Transport
02h
Get LAN Configuration Parameters
Yes
Transport
03h
Suspend BMC ARPs
Yes
Transport
04h
Get IP/UDP/RMCP Statistics
No
Transport
10h
Set Serial/Modem Configuration
Yes
Transport
11h
Get Serial/Modem Configuration
Yes
Transport
12h
Set Serial/Modem Mux
Yes
Transport
13h
Get TAP Response Codes
No
Transport
14h
Set PPP UDP Proxy Transmit Data
No
Transport
15h
Get PPP UDP Proxy Transmit Data
No
Transport
16h
Send PPP UDP Proxy Packet
No
Transport
17h
Get PPP UDP Proxy Receive Data
No
Transport
18h
Serial/Modem Connection Active
No
Transport
19h
Callback
No
Transport
1Ah
Set User Callback Options
No
Transport
1Bh
Get User Callback Options
No
Transport
1Ch
Set Serial Routing Mux
No
Transport
20h
SOL Activating
No
Transport
21h
Set SOL Configuration Parameters
Yes
Transport
22h
Get SOL Configuration Parameters
Yes
Transport
30h
Forwarded Command
No
Transport
31h
Set Forwarded Commands
No
Transport
32h
Get Forwarded Commands
No
Transport
33h
Enable Forwarded Commands
No
Bridge
00h
Get Bridge State
No
Bridge
01h
Set Bridge State
No
Bridge
02h
Get ICMB Address
No
Bridge
03h
Set ICMB Address
No
Bridge
04h
Set Bridge ProxyAddress
No
Bridge
05h
Get Bridge Statistics
No
Bridge
06h
Get ICMB Capabilities
No
Bridge
08h
Clear Bridge Statistics
No
Bridge
09h
Get Bridge Proxy Address
No
Bridge
0Ah
Get ICMB Connector Info
No
Bridge
0Bh
Get ICMB Connection ID
No
Bridge
0Ch
Send ICMB Connection ID
No
Bridge
10h
PrepareForDiscovery
No
Bridge
11h
GetAddresses
No
Bridge
12h
SetDiscovered
No
Bridge
13h
GetChassisDeviceId
No
Bridge
14h
SetChassisDeviceId
No
Bridge
20h
BridgeRequest
No
Bridge
21h
BridgeMessage
No
Bridge
30h
GetEventCount
No
Bridge
31h
SetEventDestination
No
Bridge
32h
SetEventReceptionState
No
Bridge
33h
SendICMBEventMessage
No
Bridge
34h
GetEventDestination (optional)
No
Bridge
35h
GetEventReceptionState (optional)
No
Table 11 lists standard IPMI NetFn values.
Table 11 IPMI NetFn values
NetFn
Value
App
0x06
Chassis
0x00
S/E
0x04
Storage
0x0A
Transport
0x0C
Bridge
0x02
For more information about the command details, see the IPMI2.0 specification.
IPMI extended commands
In addition to standard IPMI commands, HDM also supports IPMI extended command set by using commands in raw format to meet the increasing requirements of data center users.
Table 12 lists the main IPMI features. For more information about IPMI extended commands, see H3C HDM2 IPMI Basics Command Reference.
Table 12 HDM IPMI extended features
Feature
Hardware
Obtains hardware information about CPUs, memory, and PCIe modules.
Storage management
Manages storage controllers, physical drives, and logical drives.
BIOS
Manages part of BIOS configuration items through commands.
DNS
Configures DNS settings and obtains DNS information.
Firewall
Configures firewall settings and obtains firewall information.
Network port
Manages network ports, including bond mode configuration and network port status configuration.
Directory service
Configures LDAP and AD settings.
SNMP
Configures SNMP settings and obtains SNMP information.
NTP
Configures NTP settings and obtains NTP information.
HDM maintenance
Manages firmware and HDM configuration.
Maintainability
Configures syslog and SMTP services, obtains syslog and SMTP information, and manages SEL settings.
Fan
Manages fans.
PSU
Manages power supplies.
KVM
Configures KVM encryption settings.
Interface privileges
HDM assigns a permitted module for each IPMI interface. When an interface is used, HDM will identify the privileges according to the configuration of the module to which the interface belongs and the user role group configuration. Thus, this improves the security of the interface.
Table 13 Privileges of HDM modules
Module
User accounts
Includes local user management, LDAP user configuration, AD user configuration, OTP authentication, certificate authentication, SSH key management, license management, secure erasure, configuration import and export, and HDM unified control.
Basic configuration
Includes asset tag setting, network configuration, LLDP configuration, wireless management, NTP configuration, SNMP configuration, alarm configuration (SMTP, Trap, and Syslog), event log policy configuration, operation log clearance, video playback, and security bezel configuration.
Security configuration
Includes service configuration, firewall, SSL certificate, PFR firmware protection, and login security information configuration.
Remote control
Includes storage information management, system resource monitoring settings, BIOS settings, KVM (excluding power control and image mounting), H5 KVM (excluding power control and image mounting), VNC password management, system boot options, UID LED control, SOL serial port settings, and MCA policy configuration.
Remote media
Includes virtual media configuration, KVM image mounting, and H5 KVM image mounting.
Power control
Includes power supply management, NMI control, physical power control, fan management, and intelligent power saving configuration.
Maintenance
Includes event log clearance, package management, firmware update, firmware library management, scheduled task management, HDM configuration restoration, HDM restart, CPLD restart, and service USB disk settings.
System audit
Includes viewing and saving event logs and operation logs, and downloading SDS logs through one click.
Password modification
Includes configuration of the current user's password (available only for local users).
Information query
Includes viewing primary information of HDM, excluding viewing event logs and operation logs and downloading SDS logs through one click. The permission to view other user information is only applicable to users with the administrator privileges.
Acronyms
Acronym
Full name
IPMI
HDM
Hardware Device Management
BMC
MC
IPMB
DMTF
KVM
Keyboard, Video, and Mouse
SMS
System Management Software
LUN
Logical Unit Number
LPC
Low Pin Count
KCS
ASF
Apache Software Foundation
DCMI
Data Centers Manageability Interface
BT
Block Transfer
