H3C S9825 & S9855 Switch Series Transceiver Module Compatibility Matrix-6W100
HomeSupportInstall & UpgradeTransceiver ModulesH3C S9825 & S9855 Switch Series Transceiver Module Compatibility Matrix-6W100
H3C S9825[S9855] Switch Series
Document version: 6W100-20250227
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Switches and transceiver modules compatibility matrix
The S9825 switch series and S9855 switch series support a wide range of transceiver modules and cables. See Table 1 for the transceiver modules and cables supported by different ports on the switches and cards. For more information about transceiver modules and cables, see H3C Transceiver Modules User Guide.
You cannot use the speed command to change the speed of a split interface on a module.
You can only use QSFP+ to SFP+ cables for 10GE interfaces split from a 100GE interface.
Table 1 Switches and transceiver modules compatibility matrix
Hardware
Port
Available transceiver modules
Device software version and remarks
S9825-128B
1 to 128
QSFP56-200G-2QSFP56-100G-AOC-10m
R9131 and later
QSFP56-200G-2QSFP56-100G-AOC-20m
R9131 and later
QSFP56-200G-2QSFP56-100G-AOC-30m
R9131 and later
QSFP56-200G-2QSFP56-100G-AOC-50m
R9131 and later
QSFP56-200G-2QSFP56-100G-AOC-5m
R9131 and later
QSFP56-200G-2QSFP56-100G-AOC-7m
R9131 and later
QSFP56-200G-D-AOC-10m
R9131 and later
QSFP56-200G-D-AOC-20m
R9131 and later
QSFP56-200G-D-AOC-5m
R9131 and later
QSFP56-200G-D-AOC-7m
R9131 and later
QSFP56-200G-D-DAC-1m
R9131 and later
QSFP56-200G-D-DAC-2m
R9131 and later
QSFP56-200G-D-DAC-3m
R9131 and later
QSFP56-200G-FR4-WDM1300
R9131 and later
QSFP56-200G-SR4-MM850
R9131 and later
S9825-64D
1 to 64
CAB-400G-QSFP-DD-2m
R9126P03
OSFP112-RHS-QDD-400G-AOC-20m
R9130 and later
OSFP112-RHS-QDD-400G-AOC-50m
R9130 and later
QSFP-100G-CWDM4-SM1300-A
R9126P03 and later
QSFP-100G-D-AOC-10M
R9126P03 and later
QSFP-100G-D-AOC-20M
R9126P03 and later
QSFP-100G-D-AOC-20M-H
R9126P03 and later
QSFP-100G-D-AOC-7M
R9126P03 and later
QSFP-100G-D-AOC-7M-H
R9126P03 and later
QSFP-100G-D-CAB-1M
R9126P03 and later
QSFP-100G-D-CAB-1M-Z
R9126P03 and later
QSFP-100G-D-CAB-3M
R9126P03 and later
QSFP-100G-D-CAB-3M-Z
R9126P03 and later
QSFP-100G-D-CAB-5M
R9126P03 and later
QSFP-100G-D-CAB-5M-Z
R9126P03 and later
QSFP-100G-DR1-SM1310
R9130 and later
QSFP-100G-ER4L-WDM1300
R9126P03 and later
QSFP-100G-eSR4-MM850
R9126P03 and later
QSFP-100G-FR1-SM1310
R9130 and later
QSFP-100G-LR1-SM1310-DC
R9130 and later
QSFP-100G-LR4L-WDM1300
R9126P03 and later
QSFP-100G-LR4-WDM1300
R9126P03 and later
QSFP-100G-LR4-WDM1300-A
R9126P03 and later
QSFP-100G-PSM4-SM1310
R9126P03 and later
QSFP-100G-SR4-MM850
R9126P03 and later
QSFP-100G-SR4-MM850-A
R9126P03 and later
QSFP-100G-SR4-MM850-H
R9126P03 and later
QSFP-100G-SWDM4-MM850
R9126P03 and later
R9126P03
R9126P03
R9126P03
R9126P03
R9126P03
QSFPDD-400G-2QSFP56-200G-AOC-10m
R9126P03
QSFPDD-400G-2QSFP56-200G-AOC-20m
R9126P03
QSFPDD-400G-2QSFP56-200G-AOC-30m
R9126P03
QSFPDD-400G-2QSFP56-200G-AOC-50m
R9126P03
QSFPDD-400G-2QSFP56-200G-AOC-5m
R9126P03
QSFPDD-400G-2QSFP56-200G-AOC-7m
R9126P03
QSFPDD-400G-D-AOC-10m
R9126P03 and later
QSFPDD-400G-D-AOC-20m
R9126P03 and later
QSFPDD-400G-D-AOC-30m
R9126P03 and later
QSFPDD-400G-D-AOC-50m
R9126P03 and later
QSFPDD-400G-D-AOC-5m
R9126P03 and later
QSFPDD-400G-D-AOC-7m
R9126P03 and later
QSFPDD-400G-D-CAB-2M-Z
R9126P03
QSFPDD-400G-DR4-SM1310
R9216H03
QSFPDD-400G-FR4-WDM1300
R9126P03
QSFPDD-400G-FR4-WDM1300-Z
QSFPDD-400G-LR4-WDM1300-DC
R9126P03
QSFPDD-400G-LR8-WDM1300
R9126P03
QSFPDD-400G-SR4-MM850
QSFPDD-400G-SR8-MM850
R9126P03
QSFPDD-400G-SR8-MM850-Z
R9126P03
QSFPDD-400G-ZR-A
The 16 ports in the top row (ports 1, 5, 9, 13, 17, 21, 25, 29, 33, 37, 41, 45, 49, 53, 57, and 61) can be used simultaneously.
QSFPDD-400G-ZR-B
S9855-24B8D
1 to 24
40GBASE-SR4-QSFP+
E9128 and later
LSWM1QSTK0
E9128 and later
LSWM1QSTK1
E9128 and later
LSWM1QSTK2
E9128 and later
LSWM1QSTK3
E9128 and later
LSWM1QSTK4
E9128 and later
LSWM1QSTK5
E9128 and later
QSFP-100G-4SFP-25G-CAB-1M
E9128 and later
QSFP-100G-4SFP-25G-CAB-1M-Z
E9128 and later
QSFP-100G-4SFP-25G-CAB-3M
E9128 and later
QSFP-100G-4SFP-25G-CAB-3M-Z
E9128 and later
QSFP-100G-4SFP-25G-CAB-5M
E9128 and later
QSFP-100G-4SFP-25G-CAB-5M-Z
E9128 and later
E9128 and later
QSFP-100G-D-AOC-10M
E9128 and later
QSFP-100G-D-AOC-20M
E9128 and later
QSFP-100G-D-AOC-7M
E9128 and later
QSFP-100G-D-CAB-1M
E9128 and later
E9128 and later
QSFP-100G-D-CAB-3M
E9128 and later
E9128 and later
QSFP-100G-D-CAB-5M
E9128 and later
E9128 and later
R9130 and later
E9128 and later
E9128 and later
R9130 and later
R9130 and later
E9128 and later
E9128 and later
E9128 and later
QSFP-100G-SR4-MM850
E9128 and later
E9128 and later
E9128 and later
QSFP-40G-4SFP-10G-CAB-1M-Z
E9128 and later
QSFP-40G-4SFP-10G-CAB-3M-Z
E9128 and later
QSFP-40G-4SFP-10G-CAB-5M-Z
E9128 and later
QSFP-40G-BIDI-SR-MM850
E9128 and later
QSFP-40G-CSR4-MM850
E9128 and later
QSFP-40G-D-AOC-10M
E9128 and later
QSFP-40G-D-AOC-20M
E9128 and later
QSFP-40G-D-AOC-7M
E9128 and later
QSFP-40G-D-CAB-1M-Z
E9128 and later
QSFP-40G-D-CAB-3M-Z
E9128 and later
QSFP-40G-D-CAB-5M-Z
E9128 and later
QSFP-40G-ER4-WDM1300
E9128 and later
QSFP-40G-LR4L-WDM1300
E9128 and later
QSFP-40G-LR4-WDM1300
E9128 and later
QSFP-40G-SR4-MM850
E9128 and later
QSFP56-200G-2QSFP56-100G-DAC-1m
R9129P01
QSFP56-200G-2QSFP56-100G-DAC-2m
R9129P01
QSFP56-200G-2QSFP56-100G-DAC-3m
R9129P01
F9126P02
F9126P02
F9126P02
F9126P02
E9128
25 to 32
40GBASE-SR4-QSFP+
E9128 and later
CAB-400G-QSFP-DD-2m
LSWM1QSTK0
E9128 and later
LSWM1QSTK1
E9128 and later
LSWM1QSTK2
E9128 and later
R9130 and later
R9130 and later
E9128 and later
E9128 and later
E9128 and later
E9128 and later
E9128 and later
E9128 and later
E9128 and later
QSFP-100G-D-AOC-10M
E9128 and later
QSFP-100G-D-AOC-20M
E9128 and later
QSFP-100G-D-AOC-7M
E9128 and later
QSFP-100G-D-CAB-1M
E9128 and later
E9128 and later
QSFP-100G-D-CAB-3M
E9128 and later
E9128 and later
QSFP-100G-D-CAB-5M
E9128 and later
E9128 and later
R9130 and later
E9128 and later
E9128 and later
R9130 and later
R9130 and later
E9128 and later
E9128 and later
E9128 and later
QSFP-100G-SR4-MM850
E9128 and later
E9128 and later
E9128 and later
E9128 and later
QSFP-40G-CSR4-MM850
E9128 and later
QSFP-40G-D-AOC-10M
E9128 and later
QSFP-40G-D-AOC-20M
E9128 and later
QSFP-40G-D-AOC-7M
E9128 and later
QSFP-40G-D-CAB-1M-Z
E9128 and later
QSFP-40G-D-CAB-3M-Z
E9128 and later
QSFP-40G-D-CAB-5M-Z
E9128 and later
E9128 and later
E9128 and later
E9128 and later
QSFP-40G-SR4-MM850
E9128 and later
F9126P02
F9126P02
F9126P02
F9126P02
E9128
F9126P02
F9126P02
F9126P02
F9126P02
F9126P02
F9126P02
F9126P02
E912901
F9126P02
F9126P02
F9126P02
F9126P02
F9126P02
QSFPDD-400G-ZR-A
F9126P02
QSFPDD-400G-ZR-B
F9126P02
S9855-32D
1 to 32
CAB-400G-QSFP-DD-2m
LSWM1QSTK0
R9127 and later
LSWM1QSTK1
R9127 and later
LSWM1QSTK2
R9127 and later
QSFP-100G-D-AOC-20M
QSFP-100G-D-AOC-7M
QSFP-100G-D-CAB-1M
QSFP-100G-D-CAB-3M
QSFP-100G-D-CAB-5M
QSFP-100G-SR4-MM850
QSFP-40G-D-CAB-1M-Z
R9127 and later
QSFP-40G-D-CAB-3M-Z
R9127 and later
QSFP-40G-D-CAB-5M-Z
R9127 and later
E912901
E912901
E912901
R9127
E9129P01
E9129P01
E9129P01
E9129P01
E9129P01
E9129P01
E9129P01 and later
E9129P01 and later
33 and 34
BD-SFP-XG-SX-MM850-A1-F
LSTM1STK
R9127 and later
LSWM1STK
R9127 and later
LSWM2STK
LSWM2STK
R9127 and later
LSWM3STK
R9127 and later
S5500-10GSTK
R9127 and later
SFP-10G-D-CAB-1M-Z
R9127 and later
SFP-10G-D-CAB-3M-Z
R9127 and later
SFP-10G-D-CAB-5M-S
R9127 and later
SFP-10G-D-CAB-5M-Z
R9127 and later
SFP-GE-LH100-SM1550
R9127 and later
SFP-GE-LH40-SM1310
SFP-GE-LH40-SM1310-D
SFP-GE-LH40-SM1310-S
SFP-GE-LH40-SM1550
SFP-GE-LH80-SM1550
SFP-GE-LH80-SM1550-D
SFP-GE-LX-SM1310-A
SFP-GE-LX-SM1310-D
SFP-GE-LX-SM1310-S
SFP-GE-SX-MM850-A
SFP-GE-SX-MM850-A-H-Z
SFP-GE-SX-MM850-A-Z
SFP-GE-SX-MM850-D
SFP-GE-SX-MM850-S
SFP-GE-T
SFP-GE-T-D
SFP-GE-T-S
SFP-XG-D-AOC-10M
SFP-XG-D-AOC-10M-H
SFP-XG-D-AOC-20M
SFP-XG-D-AOC-20M-H
SFP-XG-D-AOC-7M
SFP-XG-D-AOC-7M-H
SFP-XG-LH40-SM1270-BIDI
SFP-XG-LH40-SM1330-BIDI
SFP-XG-LH80-SM1550
SFP-XG-LH80-SM1550-D
SFP-XG-LX-SM1270-BIDI
SFP-XG-LX-SM1270-BIDI-S
SFP-XG-LX-SM1310
SFP-XG-LX-SM1310-D
SFP-XG-LX-SM1310-E
SFP-XG-LX-SM1310-H
SFP-XG-LX-SM1310-S
SFP-XG-LX-SM1330-BIDI
SFP-XG-LX-SM1330-BIDI-S
SFP-XG-SX-MM850-A
SFP-XG-SX-MM850-D
SFP-XG-SX-MM850-E
SFP-XG-SX-MM850-H
SFP-XG-SX-MM850-S
UIS-SFP-XG-SX-MM850
UN-SFP-XG-SX-MM850-A1
UN-SFP-XG-SX-MM850-A1-X
S9855-40B
1 to 40
100GBASE-LR4-QSFP28
E9305 and later
100GBASE-SR4-QSFP28
E9305 and later
40GBASE-SR4-QSFP+
E9305 and later
LSWM1QSTK0
E9305 and later
LSWM1QSTK1
E9305 and later
LSWM1QSTK2
E9305 and later
QSFP-100G-BIDI-MM850
E9305 and later
QSFP-100G-BIDI-MM850-Z
E9305 and later
E9305 and later
QSFP-100G-D-AOC-10M
E9305 and later
QSFP-100G-D-AOC-10M-H
E9305 and later
QSFP-100G-D-AOC-10M-Z
E9305 and later
QSFP-100G-D-AOC-20M
E9305 and later
E9305 and later
QSFP-100G-D-AOC-7M
E9305 and later
E9305 and later
QSFP-100G-D-CAB-1M
E9305 and later
E9305 and later
QSFP-100G-D-CAB-3M
E9305 and later
E9305 and later
QSFP-100G-D-CAB-5M
E9305 and later
E9305 and later
E9305 and later
E9305 and later
QSFP-100G-ER4L-WDM1300-Z
E9305 and later
QSFP-100G-ER4-WDM1300
E9305 and later
E9305 and later
E9305 and later
E9305 and later
E9305 and later
QSFP-100G-LR4L-WDM1300-Z
E9305 and later
E9305 and later
E9305 and later
QSFP-100G-LR4-WDM1300-Z
E9305 and later
QSFP-100G-SR4-MM850
E9305 and later
E9305 and later
QSFP-100G-SR4-MM850-Z
E9305 and later
E9305 and later
QSFP-100G-SWDM4-MM850-Z
E9305 and later
QSFP-100G-ZR4-WDM1300
E9305 and later
E9305 and later
QSFP-40G-BIDI-SR-MM850-Z
E9305 and later
QSFP-40G-BIDI-WDM1310
E9305 and later
QSFP-40G-BIDI-WDM850
E9305 and later
QSFP-40G-CSR4-MM850
E9305 and later
QSFP-40G-CSR4-MM850-H
E9305 and later
QSFP-40G-CSR4-MM850-NDDM
E9305 and later
QSFP-40G-CSR4-MM850-Z
E9305 and later
QSFP-40G-D-AOC-10M
E9305 and later
QSFP-40G-D-AOC-10M-H
E9305 and later
QSFP-40G-D-AOC-3M
E9305 and later
QSFP-40G-D-AOC-7M
E9305 and later
QSFP-40G-D-AOC-7M-H
E9305 and later
QSFP-40G-D-CAB-1M-Z
E9305 and later
QSFP-40G-D-CAB-3M-Z
E9305 and later
QSFP-40G-D-CAB-5M-Z
E9305 and later
E9305 and later
QSFP-40G-ER4-WDM1300-Z
E9305 and later
E9305 and later
QSFP-40G-LR4L-WDM1300-Z
E9305 and later
E9305 and later
QSFP-40G-LR4-WDM1300-Z
E9305 and later
QSFP-40G-LX4-WDM1300
E9305 and later
QSFP-40G-LX4-WDM1300-Z
E9305 and later
QSFP-40G-SR4-MM850
E9305 and later
QSFP-40G-SR4-MM850-E
E9305 and later
QSFP-40G-SR4-MM850-H
E9305 and later
QSFP-40G-SR4-MM850-NDDM
E9305 and later
QSFP-40G-SR4-MM850-Z
E9305 and later
E9305 and later
E9305 and later
E9305 and later
E9305 and later
E9305 and later
E9305 and later
E9305 and later
E9305 and later
S9855-48CD8D
1 to 48
E9125 and later
LSTM1STK
E9125 and later
LSWM1STK
E9125 and later
LSWM2STK
E9125 and later
LSWM3STK
E9125 and later
S5500-10GSTK
E9125 and later
SFP-10G-D-CAB-1M-Z
E9125 and later
SFP-10G-D-CAB-3M-Z
E9125 and later
SFP-10G-D-CAB-5M-S
E9125 and later
SFP-10G-D-CAB-5M-Z
E9125 and later
SFP-25G-D-AOC-10M
E9125 and later
SFP-25G-D-AOC-20M
E9125 and later
SFP-25G-D-AOC-3M
E9125 and later
SFP-25G-D-AOC-5M
E9125 and later
SFP-25G-D-AOC-7M
E9125 and later
SFP-25G-D-CAB-1M
E9125 and later
SFP-25G-D-CAB-3M
E9125 and later
SFP-25G-D-CAB-5M
E9125 and later
SFP-25G-D-CAB-5M-Z
E9125 and later
SFP-25G-LR-SM1310
E9125 and later
SFP-25G-SR-MM850
E9125 and later
E9125 and later
E9125 and later
SFP-XG-LH40-SM1550
E9125 and later
SFP-XG-LH40-SM1550-D
E9125 and later
SFP-XG-LH40-SM1550-S
E9125 and later
SFP-XG-LH80-SM1490-BIDI
E9125 and later
SFP-XG-LH80-SM1550
E9125 and later
SFP-XG-LH80-SM1550-BIDI
E9125 and later
E9125 and later
E9125 and later
E9125 and later
SFP-XG-LX-SM1310
E9125 and later
SFP-XG-LX-SM1310-D
E9125 and later
SFP-XG-LX-SM1310-E
E9125 and later
SFP-XG-LX-SM1310-E-H-Z
E9125 and later
SFP-XG-LX-SM1310-E-Z
E9125 and later
SFP-XG-LX-SM1310-S
E9125 and later
E9125 and later
E9125 and later
SFP-XG-SX-MM850-A
E9125 and later
SFP-XG-SX-MM850-D
E9125 and later
SFP-XG-SX-MM850-D-H-Z
E9125 and later
SFP-XG-SX-MM850-D-Z
E9125 and later
SFP-XG-SX-MM850-E
E9125 and later
SFP-XG-SX-MM850-S
E9125 and later
UIS-SFP-XG-SX-MM850
E9125 and later
E9125 and later
E9125 and later
49 to 56
CAB-400G-QSFP-DD-2m
R9216
E9125 and later
QSFP-100G-D-AOC-10M
E9125 and later
QSFP-100G-D-AOC-20M
E9125 and later
QSFP-100G-D-AOC-7M
E9125 and later
QSFP-100G-D-CAB-1M
E9125 and later
E9125 and later
QSFP-100G-D-CAB-3M
E9125 and later
E9125 and later
QSFP-100G-D-CAB-5M
E9125 and later
E9125 and later
R9130 and later
E9125 and later
R9130 and later
R9130 and later
E9125 and later
E9125 and later
E9125 and later
QSFP-100G-SR4-MM850
E9125 and later
E9125 and later
E9125 and later
F9126P02
F9126P02
F9126P02
F9126P02
E9128
F9126P02
F9126P02
F9126P02
F9126P02
F9126P02
F9126P02
A9127 and later
A9127 and later
A9127 and later
A9127 and later
A9127 and later
A9127 and later
R9216
A9127
F9126P02
F9126P02
F9126P02
E9124
E9124
