- Released At: 30-08-2024
- Page Views:
- Downloads:
H3C SecPath NS-C300-CGQ2TG16A1 interface module
1 Identifier
The module identifier NS-C300-CGQ2TG16A1 is in the upper right corner of the front panel.
2 Specifications
The NS-C300-CGQ2TG16A1 interface module provides sixteen 10-GE fiber ports and two 100-GE fiber ports.
Figure 1 Front panel
(1) 100-GE fiber port |
(2) Ejector lever |
(3) 10-GE fiber ports |
(4) 10-GE fiber port LEDs |
(5) 100-GE fiber port LEDs |
Table 1 Module specifications
Item |
Specification |
Dimensions (H × W × D) |
44 × 191 × 365.3 mm (1.73 × 7.52 × 14.38 in) |
Power consumption |
7 W to 38 W |
Net weight |
1.52 kg (3.35 lb) |
Hot swapping |
Not supported |
Ports |
· 2 × 100GBASE-R QSFP28 fiber ports · 16 ×10GBASE-R SFP+ fiber ports |
Connector type |
LC/MPO |
Available transceiver modules |
Compatible interface switch modules and slots |
· NSQM5MBSHA1 interface switch module (slots 1 and 2) · NSQM7MBSHA0 interface switch module (slots 1 and 2) · NSQM7MBSHB0 interface switch module (slots 1 and 2) |
The 10G fiber ports support SFP transceiver modules and cables described in Table 2 and SFP+ transceiver modules described in Table 3.
Table 2 SFP transceiver modules and cables available for the 10-GE fiber ports
Transceiver module or cable |
Central wavelength (nm) |
Connector type |
Cable specifications (µm) |
Maximum transmission distance |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, multi-mode optical fiber (MMF) |
550 m (1804.46 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
50/125, MMF |
SFP-GE-LX-SM1310-A |
1310 |
LC |
9/125, single-mode optical fiber (SMF) |
10 km (6.21 miles) |
SFP-GE-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
SFP-GE-LH40-SM1310 |
1310 |
LC |
9/125, SMF |
40 km (24.86 miles) |
SFP-GE-LH40-SM1310-D |
1310 |
LC |
9/125, SMF |
SFP-GE-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
SFP-GE-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
80 km (49.71 miles) |
SFP-GE-LH80-SM1550-D |
1550 |
LC |
9/125, SMF |
SFP-GE-LH100-SM1550 |
1550 |
LC |
9/125, SMF |
100 km (62.14 miles) |
SFP-GE-T |
N/A |
RJ-45 |
Category-5 twisted pair cable |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
100 m (328.08 ft) |
NOTE: All 10-GE fiber ports on the NS-C300-CGQ2TG16A1 interface module support 1000 Mbps autosensing. |
Table 3 SFP+ transceiver modules available for the 10-GE fiber ports
Module |
Connector type |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
300 m (984.25 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
300 m (984.25 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
300 m (984.25 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
SFP-XG-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
SFP-XG-LX-SM1310-E |
1310 |
LC |
9/125, SMF |
SFP-XG-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
SFP-XG-LH40-SM1550-D |
1550 |
LC |
9/125 µm, SMF |
SFP-XG-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
SFP-XG-LH80-SM1550-D |
1550 |
LC |
9/125, SMF |
The 100-GE fiber ports support QSFP+ transceiver modules described in Table 4 and QSFP28 transceiver modules described in Table 5.
Table 4 QSFP+ transceiver modules available for the 100GBASE-R QSFP28 fiber ports
Module |
Connector type |
Modal bandwidth (MHz × km) |
QSFP-40G-SR4-MM850 |
850 |
MPO |
50/125, MMF |
2000 |
100 m (328.08 ft) |
QSFP-40G-LR4-WDM1300 |
1310 |
LC |
9/125, SMF |
N/A |
QSFP-40G-CSR4-MM850 |
850 |
MPO |
50/125, MMF |
2000 |
300 m (984.25 ft) |
QSFP-40G-LR4L-WDM1300 |
1310 |
LC |
9/125, SMF |
N/A |
2 km (1.24 miles) |
QSFP-40G-BIDI-SR-MM850 |
850 |
LC |
50/125, MMF |
2000 |
100 m (328.08 ft) |
QSFP-40G-ER4-WDM1300 |
1310nm |
LC |
9/125, SMF |
40 km (24.84 miles) |
QSFP-40G-BIDI-WDM850 |
850nm |
LC |
50/125, MMF |
2000 |
300 m (984.25 ft) |
NOTE: All 100-GE fiber ports on the NS-C300-CGQ2TG16A1 interface module support 40 Gbps autosensing. |
The 100GBASE-R QSFP28 fiber ports support QSFP28 transceiver modules described in Table 5.
Table 5 QSFP28 transceiver modules available for the 100GBASE-R-QSFP28 fiber ports
Module |
Connector type |
QSFP-100G-SR4-MM850 |
850 |
MPO |
50/125, MMF |
100 m (328.08 ft) |
QSFP-100G-LR4-WDM1300 |
1310 |
LC |
50/125, SMF |
QSFP-100G-LR4L-WDM1300 |
1310 |
LC |
9/125, SMF |
2 km (1.24 miles) |
QSFP-100G-ER4-WDM1300 |
1300 |
LC |
9/125, SMF |
QSFP-100G-SWDM4-MM850 |
850 |
LC |
50/125, SMF |
100 m (328.08 ft) |
3 LEDs
The module provides a LED for each 10-GE fiber port and 100-GE fiber port to indicate their operating status.
Table 6 10-GE fiber port LED description
Status |
Flashing |
The port is sending or receiving data. |
Steady on |
A link is present on the port. |
Off |
No link is present on the port. |
Table 7 100-GE fiber port LED description
Status |
Flashing |
Steady on |
Off |
4 Related documentation
For information about installing the module on a device, see the installation guide for the device.
Copyright © 2024 New H3C Technologies Co., Ltd.
