Title | Size | Downloads |
H3C SecPath NSQM1ISPAXA1&NSQM1ISPAXB1 Installation Guide-5W100-book.pdf | 2.13 MB |
book | 2.13 MB |
H3C SecPath NSQM1ISPAXA1&NSQM1ISPAXB1 |
Intelligent Service Platform Modules Installation Guide |
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Compatibility of the modules with firewalls
NSQM1ISPAXA1 intelligent service platform module
NSQM1ISPAXB1 intelligent service platform module
Mapping relations between ports on the modules and network cards
Internal inline port interconnecting the module and device
Installing the NSQM1ISPAXA1 intelligent service platform module
Installing the NSQM1ISPAXB1 intelligent service platform module
Removing an NSQM1ISPAXA1 intelligent service platform module
Removing an NSQM1ISPAXB1 intelligent service platform module
Starting the module for the first time
Setting up the configuration environment
Configuration for the first access
Configuring the IP address and gateway for the intelligent service platform
Appendix B Basic Linux commands
Configuring a temporary IP address
Configuration terminal display problems
Overview
The intelligent service platform modules are applicable to multiple firewalls. The following table describes the compatibility of the intelligent service platform modules with firewalls.
Table 1 Compatibility of the intelligent service platform modules with firewalls
Module model |
Applicable firewall models |
Applicable slots |
Application software versions |
NSQM1ISPAXA1 |
· F1020, F1030, F1050, F1060, F1070, F1080 · F100-A-G2, F100-A-EI, F100-E-G2, F100-A-SI, F100-E-EI · F1020-GM, F1030-GM, F1070-GM, F1070-GM-L · F1000-AK130, F1000-AK135, F1000-AK140, F1000-AK145, F1000-AK150, F1000-AK155, F1000-AK160, F1000-AK165, F1000-AK170, F1000-AK175, F1000-AK1212, F1000-AK1222, F1000-AK1232, F1000-AK1312, F1000-AK1322, F1000-AK1332, F1000-AK180, F1000-AK185, F1000-AK711, F1000-GM-AK370, F1000-GM-AK370 · F1000-AI-20, F1000-AI-30, F1000-AI-50 · F1000-920-AI, F1000-930-AI, F1000-950-AI, F1000-960-AI, F1000-970-AI, F1000-980-AI, F1000-990-AI · F1000-E-VG, F1000-V70 · F1000-C-G2, F1000-C-EI, F1000-E-G2, F1000-S-G2, F1000-A-G2 · F100-A-G3, F100-E-G3, F100-A80-WiNet · F1000-C-HI, F1000-C-EI |
Slot 1 |
R9360P19 or later |
· F1090, F1000-AI-60, F1000-AI-90, F1000-AI-80, F1000-AI-70 · F1000-V90, F1000-V60, F1000-V50 · F1000-S-G3, F1000-A-G3, F1000-E-G3, F1000-C-G3 · F1000-E-G5, F1000-H-G5 · F1000-C8395 · F1000-AK1414, F1000-AK1424, F1000-AK1434, F1000-AK1514, F1000-AK1524, F1000-AK1534, F1000-AK1614 · F1000-AK1235, F1000-AK1242, F1000-AK1252, F1000-AK1262, F1000-AK1272, F1000-AK9160, F1000-AK9180 · F1000-AI-25, F1000-AI-35, F1000-AI-55, F1000-AI-75 · F100-E-G5, F1000-C-G5, F1000-C-G5-LI · F1000-9350-AI, F1000-9360-AI · F1000-740-HI, F1000-750-HI · F100-A91-WiNet · F1000-E-XI · F1000-T1000-E |
Slot 1 |
R8660P18 or later |
NSQM1ISPAXB1 |
· F5030, F5060, F5080, F5030-6GW · F5000-M, F5000-A · F5000-AI-20, F5000-AI-40 · F5000-V30 |
Slot 1 and Slot 2 |
F9660 or later |
F5030-D, F5060-D, F5080-D |
Slot 2/1 and Slot 2/2 |
F9660 or later |
F5000-AK515, F5000-AK525 |
Slot 1 and Slot 2 |
R9660P28 or later |
Hardware information
Figure 1 NSQM1ISPAXA1 intelligent service platform module
(1) 10/100/1000BASE-T Ethernet copper port |
(2) 1000BASE-X Ethernet fiber port |
(3) USB port |
(4) Console port (CONSOLE) |
(5) Handle |
(6) Power button |
(7) 1000BASE-X Ethernet fiber port |
(8) 10/100/1000BASE-T Ethernet copper port (management Ethernet port) |
Figure 2 NSQM1ISPAXB1 intelligent service platform module
(1) USB port |
(2) Console port (CONSOLE) |
(3) 10/100/1000BASE-T Ethernet copper port |
(4) 1000BASE-X Ethernet fiber port |
(5) 1000BASE-X Ethernet fiber port |
(6) Ejector lever |
(7) 10/100/1000BASE-T Ethernet copper port (management Ethernet port) |
(8) Power button |
The following table describes the mapping relations between ports on the intelligent service platform modules and network cards.
Table 2 Mapping relations between ports on the NSQM1ISPAXA1 intelligent service platform modules and network cards
Network card name |
enp11s0f0 |
Port 0 on the faceplate (10/100/1000BASE-T Ethernet copper port) |
enp11s0f1 |
Port 1 on the faceplate (10/100/1000BASE-T Ethernet copper port) |
enp11s0f2 |
Port 2 on the faceplate (1000BASE-X Ethernet fiber port) |
enp11s0f3 |
Port 3 on the faceplate (1000BASE-X Ethernet fiber port) |
enp1s0f0 |
enp1s0f1 |
enp3s0f0 |
Internal inline port |
enp3s0f1 |
Table 3 Mapping relations between ports on the NSQM1ISPAXB1 intelligent service platform modules and network cards
Network card name |
enp11s0f0 |
enp11s0f1 |
enp11s0f2 |
enp11s0f3 |
enp1s0f0 |
enp1s0f1 |
enp3s0f0 |
enp3s0f1 |
When an intelligent service platform module is installed on a device, it connects to the device through an internal inline port. The name of the inline port depends on the device model. For example, if you install an NSQM1ISPAXA1 module on an F1080 firewall, the inline port is named as enp3s0f0 on the module side and as GE1/1/0 on the device side, as shown in the following table.
Table 4 Internal inline port interconnecting the module and device
Module name |
Internal inline port name on the module side |
Internal inline port name on the device side |
NSQM1ISPAXA1 |
enp3s0f0 |
GE1/1/0 |
NSQM1ISPAXB1 |
enp1s0f0 |
XGE1/1/0 or XGE1/2/0 |
Technical specifications
The following table describes the technical specifications for the intelligent service platform module. For the technical specifications of the ports, see "Appendix A Ports and LEDs."
Table 5 Technical specifications
Item |
Specification |
Processor |
Intel C3558, 2.2 GHz |
DDR |
8 GB DDR4 |
Storage |
480 GB SSD |
Operating system |
Linux |
Hot swapping |
Not supported |
External ports |
· 2 × GE copper ports (including one management Ethernet port) · 1 × Console port · 2 × USB ports (USB 2.0) · 2 × GE fiber ports |
Dimensions (H × W × D) |
· NSQM1ISPAXA1: 40.1 × 150 × 243.6 mm (1.58 × 5.91 × 9.59 in) · NSQM1ISPAXB1: 40.1 × 189 × 212.4 mm (1.58 × 7.44 × 8.36 in) |
Weight |
1 kg (2.20 lb) |
Power consumption (static) |
18 W |
Power consumption (fully loaded) |
· NSQM1ISPAXA1: 28 W · NSQM1ISPAXB1: 29 W |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Operating relative humidity (noncondensing) |
5% to 95% |
The power button LED on the module indicates the operating status of the module. To start up or put the module in standby mode, press and hold the power button for 2 seconds.
Table 6 Description for the power button LED
LED status |
Steady green |
Power is present on the module. |
Steady red |
The module is in a standby state. |
Installing the module
Follow these restrictions and guidelines when installing the module:
· Wear an ESD wrist strap during the installation process. Make sure the strap makes good skin contact and is reliably grounded.
· To prevent device damages, do not use excessive force during installation.
· An intelligent service platform module uses two interface module slots on a device. After you install an intelligent service platform module on a device that has only two interface module slots, you cannot install other interface modules on the device.
1. Face the rear panel of the device.
2. The NSQM1ISPAXA1 intelligent service platform module uses two interface module slots on the device. Use a Phillips screwdriver to remove the screws on the filler panels and remove the filler panels. Keep the removed filler panels secure.
Figure 3 Removing filler panels
3. Take out the module from its packaging materials and slowly push it along the guide rails into the interface module slots until it has a firm contact with the device.
4. Use a Phillips screwdriver to fasten the captive screws on the module.
Figure 4 Installing an NSQM1ISPAXA1 intelligent service platform module
NOTE: After installation, part of the module is left outside the device, increasing the overall depth of the device by 72 mm (2.83 in). |
2. The NSQM1ISPAXB1 intelligent service platform module uses two interface module slots on the device. Use a Phillips screwdriver to remove the screws on the filler panels and remove the filler panels. Keep the removed filler panels secure.
Figure 5 Removing filler panels
3. Open the two ejector levers of the module, and then push the module slowly into the slot along the guide rails.
4. Push inward the two ejector levers to ensure that the interface module is firmly seated in the slot.
5. Use a Phillips screwdriver to fasten the captive screws on the module.
Figure 6 Installing the NSQM1ISPAXB1 intelligent service platform module
Remove the module
Follow these restrictions and guidelines when removing an intelligent service platform module:
· To avoid cable damage, remove cables from the module before removing the module.
· Wear an ESD wrist strap during the removal process. Make sure the strap makes good skin contact and is reliably grounded.
· To avoid damage to the device and its components, do not use excessive force during the removal process.
· If you are not to install a new module, install filler panels in the slots in time to ensure adequate heat dissipation and prevent dust from entering the device.
· Replace the removed module on an antistatic mat.
1. Use a Phillips screwdriver to loosen the screws on the module.
2. Pull the handle to disengage the module from the device's connector terminal.
3. Use both hands to remove the module from the device slowly and horizontally.
4. Place the removed on an antistatic mat or in an antistatic bag with its PCB side facing up.
Figure 7 Removing an NSQM1ISPAXA1 intelligent service platform module
5. If you are not to install a new module, install filler panels in the slots in time. To install a new module, see "Installing the NSQM1ISPAXA1 intelligent service platform module."
1. Use a Phillips screwdriver to loosen the captive screws on the interface module.
2. Hold and rotate outward the two ejector levers of the module. Pull the module a small part way out of the slot along the guide rails, and then support the module bottom with one hand and pull out the module completely out of the slot with the other slowly.
3. Place the removed module on an antistatic mat or in an antistatic bag with its PCB side facing up.
Figure 8 Removing an NSQM1ISPAXB1 intelligent service platform module
4. If you are not to install a new module, install filler panels in the slots in time. To install a new module, see "Installing the NSQM1ISPAXB1 intelligent service platform module."
Verifying the installation
Execute the display interface brief command on the device to verify that the physical connection state and data link layer protocol state of the internal inline port are up.
If the physical connection state and data link layer protocol state of the internal inline port are not up, perform the following steps:
1. Follow the instructions in this document to reinstall the module.
2. If the issue persists, contact H3C Support.
The module provides a console port on the front panel from which you can log in to the device for the first time. Figure 9 shows a typical network diagram for intelligent service platform modules, using the NSQM1ISPAXB1 module as an example.
Figure 9 Typical network diagram of the module
To perform initial configuration for the module, use a console cable to connect a PC to the console port on the module.
The module communicates with the device via an internal inline port. The internal inline port is identified as enp1s0f0 on the module side and recognized as a 10GE port (such as XGE1/1/0) on the device side. To remotely manage and upgrade the module, you can use the management Ethernet port enp11s0f0.
Connecting the console cable
Console cable
A console cable is an 8-core shielded cable, with a crimped RJ-45 connector at one end for connection to the console port on the module, and a DB-9 female connector at the other end for connection to the serial port on a configuration terminal (for example, a PC). The console cable is as shown in the following figure.
CAUTION: · Pay attention to the port labels and ensure that you connect the cable to the correct port. · When connecting the module and a PC, first connect the DB-9 connector of the cable to the PC, and then connect the RJ-45 connector at the other end of the cable to the module. To disconnect the cable, remove the RJ-45 connector before removing the DB-9 connector. |
To connect a configuration terminal to the module:
1. Plug the DB-9 female connector of the console cable to the serial port on the configuration terminal (for example, a PC).
2. Connect the RJ-45 connector of the console cable to the console port on the module.
Setting terminal parameters
To configure and manage the module from the console port, you must run a terminal emulator program, such as TeraTermPro, on your configuration terminal. For more information about the terminal emulator programs, see the user guides for these programs.
Configure the terminal emulation program parameters as follows:
· Baud rate—115200.
· Data bit—8.
· Stop bit—1.
· Parity check—None.
· Flow control—None.
WARNING! To ensure system security, use the passwd command to edit the login password if you access the intelligent service platform module for the first time as a root user. For more information about the command, see “passwd command.” |
As shown in Figure 11, after the intelligent service platform module software starts up, the terminal emulator program displays the user login interface when you access the module through the console port.
Figure 11 User login interface
When you access the intelligent service platform module for the first time, you access as a super (root) user. The username and default password are root and 123456, respectively. Press Enter to access the CLI.
Figure 12 CLI for the root user
This section describes how to configure an IP address and the gateway for NIC enp11s0f0 of the intelligent service platform system.
For the Linux operating system, the IP address of a NIC can be dynamically obtained through DHCP or manually configured. To ensure service continuity, manually configure a fixed IP address for a NIC.
To configure a fixed IP address for a NIC, you must edit the configuration file for the NIC. The configuration file resides in the /etc/sysconfig/network-scripts directory and its name is in the ifcfg-+NIC_name format. For example, the name of the configuration file for NIC enp11s0f0 is ifcfg-enp11s0f0.
To configure an IP address and the gateway for NIC enp11s0f0:
1. Open the configuration file of NIC enp11s0f0 by using the vi editor.
NOTE: For information about how to use the vi editor, see "vi editor." |
[root@H3LINUX100 ~]# vi /etc/sysconfig/network-scripts/ifcfg-enp11s0f0
The configuration file content is as follows:
TYPE=Ethernet
PROXY_METHOD=none
BROWSER_ONLY=no
BOOTPROTO=dhcp
DEFROUTE=yes
IPV4_FAILURE_FATAL=no
IPV6INIT=yes
IPV6_AUTOCONF=yes
IPV6_DEFROUTE=yes
IPV6_FAILURE_FATAL=no
IPV6_ADDR_GEN_MODE=stable-privacy
NAME=quy
UUID=db19dc60-6676-43d8-aa8d-ba6df2cfe6da
DEVICE=enp11s0f0
ONBOOT=no
2. Edit the configuration file.
¡ Change BOOTPROTO=dhcp to BOOTPROTO=static to manually configure an IP address for the NIC.
¡ Change ONBOOT=no to ONBOOT=yes to enable automatic startup of the NIC when the system starts up.
¡ Add the IPADDR, NETMASK, and GATEWAY items to configure the IP address, mask, and gateway address for the NIC, respectively. As shown in the example, configure the IP address as 1.1.1.1, mask as 255.255.255.0, and gateway address as 1.1.1.3. Enable automatic startup of the NIC when the system starts up.
The edited configuration file content is as follows:
TYPE=Ethernet
PROXY_METHOD=none
BROWSER_ONLY=no
BOOTPROTO=static
DEFROUTE=yes
IPV6INIT=yes
IPV6_AUTOCONF=yes
IPV6_DEFROUTE=yes
NAME=quy
DEVICE=enp11s0f0
ONBOOT=yes
IPADDR=1.1.1.1
NETMASK=255.255.255.0
GATEWAY=1.1.1.3
3. Restart the network.service service.
[root@H3LINUX100 ~]# systemctl restart network.service
4. Verify that NIC enp11s0f0 has obtained an IP address.
[root@H3LINUX100 ~]# ifconfig enp11s0f0
The following output shows that the NIC is configured with IP address 1.1.1.1.
enp11s0f0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 1.1.1.1 netmask 255.255.255.0 broadcast 1.1.1.255
inet6 fe80::2a0:c9ff:fe00:0 prefixlen 64 scopeid 0x20<link>
ether 00:a0:c9:00:00:00 txqueuelen 1000 (Ethernet)
RX packets 1248 bytes 95322 (93.0 KiB)
RX errors 0 dropped 196 overruns 0 frame 0
TX packets 67 bytes 9122 (8.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0x81760000-8177ffff
5. Verify that NIC enp11s0f0 is configured with a gateway address.
[root@H3LINUX100 ~]# ip route
The following output shows that the NIC is configured with gateway address 1.1.1.2.
default via 1.1.1.2 dev enp11s0f0 proto static metric 100
1.1.1.0/24 dev enp11s0f0 proto kernel scope link src 1.1.1.1 metric 100
Configuring the SSH service
By default, the intelligent service platform is enabled with the SSH service. You can configure or upgrade the intelligent service platform through SSH remote access.
Viewing the SSH service status
To view the SSH service status, execute the following command:
[root@H3LINUX100 ~]# systemctl status sshd.service
Figure 13 shows that the SSH service is enabled.
Figure 13 Viewing the SSH service status
SSH remote access
IMPORTANT: · When you access the intelligent service platform through SSH, make sure NIC enp11s0f0 has been configured with the IP address, mask, and gateway address. · Make sure your PC and NIC enp11s0f0 can reach each other. · Before accessing the intelligent service platform, make sure your PC is enabled with the SSH client feature. |
You can remotely access the intelligent service platform through SSH as a root user or a non-root user.
· Root user—Installs or upgrades the intelligent service platform.
· Non-root user—Manages the intelligent service platform, such as configuring routes and uploading software versions of the intelligent service platform.
The methods of accessing the intelligent service platform are different for a root user and a non-root user.
· Access the intelligent service platform as a root user.
You can access the intelligent service platform as a root user by using either of the following methods:
¡ Execute the [root@H3LINUX100 ~]# ssh [email protected] command.
Figure 14 Accessing the intelligent service platform as a root user through SSH (1)
¡ Execute the [root@H3LINUX100 ~]# ssh 1.1.1.1 command.
Figure 15 Accessing the intelligent service platform as a root user through SSH (2)
As shown in Figure 14, when you access the intelligent service platform as a root user for the first time, the system asks if you want to save the public key fingerprint of the target host. Please enter yes.
As shown in Figure 15, when you access the intelligent service platform as a root user again, the system does not ask again.
· Access the intelligent service platform as a non-root user.
a. If no non-root users are created, access the intelligent service platform as a root user first. Execute the useradd and passwd commands to create a non-root user and configure the login password, respectively.
For example, execute the following commands to create non-root user user and configure the login password as 123456.
[root@H3LINUX100 ~]# useradd user
[root@H3LINUX100 ~]# passwd 123456
Figure 16 shows that non-root user user is created and authenticated.
Figure 16 Creating a non-root user
b. Execute the following command to access the intelligent service platform through SSH as a non-root user:
Figure 17 Accessing the intelligent service platform as a non-root user through SSH (1)
Figure 18 Accessing the intelligent service platform as a non-root user through SSH (2)
As shown in Figure 17, when you access the intelligent service platform as a non-root user for the first time, the system asks if you want to save the public key fingerprint of the target host. Please enter yes.
As shown in Figure 18, when you access the intelligent service platform as a non-root user again, the system does not ask again.
Console port
Table 7 Console port specifications
Item |
Specification |
Connector |
RJ-45 |
Standard compliant |
EIA/TIA-232 |
Baud rate |
115200 bps |
Transmission medium and max transmission distance |
≤ 15 m (49.21 ft) over asynchronous serial cables |
Services |
· Provides connection to an ASCII terminal · Provides connection to a serial port of a local terminal (for example a PC) running a terminal emulator program |
GE copper port
Table 8 GE copper port specifications
Item |
Specification |
Connector |
RJ-45 |
Interface speed and duplex mode |
1000 Mbps, full duplex |
Cable type |
Category 5 or above twisted pair cable |
Max transmission distance |
100 m (328.08 ft) |
IEEE 802.3i, 802.3u, 802.3ab |
Functions and services |
Connects to a computer or remote network management work station for upgrading and managing applications |
GE fiber port
Table 9 GE fiber port specifications
Item |
Specification |
Connector |
LC |
Transceiver module type |
SFP |
Standard compliance |
1000BASE-X |
Interface speed |
1000 Mbps |
Duplex mode |
Full duplex |
USB port
Table 10 USB port specifications
Item |
Specification |
Interface type |
USB2.0 |
xHCI |
Accesses the file system on the flash of the intelligent service platform module, for example, to upload or download application and configuration files |
Port LEDs
Table 11 Port LED description
Status |
Steady green |
A 1000 Mbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 1000 Mbps. |
Off |
No link is present on the port. |
vi editor
The vi editor supports the following working modes:
· Command mode—To enter this mode, execute the vi filename command to open a file. In this mode, you can perform the following tasks:
¡ Use the arrow keys to move the cursor.
¡ Delete characters or lines in the file.
¡ Copy and paste file data.
· Insert mode—To enter this mode, press i, I, o, O, a, A, r, or R. In this mode, you can edit the content. To return to the command mode, press Esc.
· Last-line mode—To enter this mode, press :, /, or ?. Then, the cursor moves to the bottom line. In this mode, you can search for keywords, read files, save files, replace characters in bulk, exit files, or view line numbers. To return to the command mode, press Esc.
The following example edits the configuration file of NIC enp11s0f0 to describe how to use the vi editor.
1. Open the ifcfg-enp11s0f0 file.
Figure 19 shows the configuration file content. The vi editor enters the command mode.
Figure 19 Configuration file content of NIC enp11s0f0
Move the cursor to the end of the fourth line, and then press a. The vi editor enters the insert mode and the cursor moves to the position after the last p in the line. You can edit the ifcfg-enp11s0f0 configuration file as required.
After editing the configuration file, press Esc to return to the command mode. However, the configuration file content is not actually edited.
Figure 20 Editing the configuration file
3. Save the configuration file.
In the current mode, press : to enter the last-line mode. In this mode, you can execute the following commands:
¡ w—Write the file.
¡ q—Exit the file.
¡ wq—Write and save the file.
¡ wq!—Write and forcibly save the file.
¡ q! —Forcibly exit the file without saving it.
As shown in Figure 21, execute the wq command in the last line to save the configuration file. Press Enter to return to the CLI.
Figure 21 Saving the configuration file
The temporary IP address of a NIC loses effect after the module restarts up. Configure temporary IP addresses for NICs as required.
To configure a temporary IP address for NIC enp11s0f0:
1. Configure the IP address as 1.1.1.1 and mask as 24 for NIC enp11s0f0.
[root@H3LINUX100 ~]# ifconfig enp11s0f0 1.1.1.1/24
2. View the IP address of NIC enp11s0f0.
Figure 22 Configuring a temporary IP address
The output shows that a temporary IP address has been configured for NIC enp11s0f0.
passwd command
Use the passwd or passwd username command to edit or configure the login password for a Linux user. When you access the intelligent service platform module for the first time or create a non-root user, you must edit or configure the login password.
· To edit the login password for a root user who accesses the module for the first time, execute the passwd command at the CLI.
As shown in Figure 23, after you execute the passwd command, the system prompts you to enter the new password twice. Make sure you enter the same new password.
Figure 23 Editing the login password for a root user
· To configure a login password for a non-root user, first access the CLI as a root user. Execute the useradd command to create a non-root user, and then execute the passwd username command to configure a login password for the non-root user.
[root@H3LINUX100 ~]# passwd user
As shown in Figure 24, configure a password for non-root user user as prompted.
Figure 24 Creating a non-root user and configuring the login password
cd command
Use the cd [absolute path/relative path/special character] command to change the working directory for a login user.
The following shows examples about how to change the working directory for a login user.
· Switch the working directory from the root directory to the /opt/EScan directory.
[root@H3LINUX100 ~]# cd /opt/EScan
[root@H3LINUX100 EScan]#
· Switch the working directory from the /opt/EScan directory to the /opt/Adaptec directory.
[root@H3LINUX100 EScan]# cd ../Adaptec
· Switch the working directory from the /opt/EScan directory to the root directory.
[root@H3LINUX100 EScan]# cd ~
· Switch the working directory from the /opt/EScan directory to the /opt directory.
cat command
Use the cat filename command to view the file content.
For example, execute the following command to view the scanner version:
[root@H3LINUX100 ~]# cat /opt/EScan/conf/configsVersion
tar command
Use the tar options filename command to compress folders to a file or decompress files.
For example, execute the following command to compress the EScan folder to the EScan.tar.gz file:
[root@H3LINUX100 EScan]# tar -czvf EScan EScan.tar.gz
Execute the following command to decompress the EScan.tar.gz file:
[root@H3LINUX100 EScan]# tar -xzvf EScan.tar.gz
cp command
Use the cp source destination command to copy files.
For example, execute the following command to copy the EScan.tar.gz file in the /opt directory to the /h3Linux directory:
[root@H3LINUX100 ~]# cp /opt/EScan.tar.gz /h3Linux
mkdir command
Use the mdkir directory command to create directories.
For example, execute the following command to create the /USB directory:
[root@H3LINUX100 /]# mkdir USB
Troubleshooting
NIC failure
Symptom
The ifconfig command does not display information about NIC enp3s0f1.
Solution
To resolve the issue:
1. Execute the reboot command to restart the intelligent service platform module.
2. Execute the following commands to reload the NIC driver.
modprobe –r igb
modprobe –r ixgbe
modprobe igb
modprobe ixgbe
Symptom
The configuration terminal displays nothing or garbled text when the module is powered on.
Solution
· Verify that the power supply system is operating correctly.
· Verify that the console cable is connected correctly to the serial port specified on the configuration terminal.
· Verify that the configuration terminal parameters are configured correctly.
¡ Baud rate—115200.
¡ Data bits—8.
¡ Parity—None.
¡ Stop bits—1.
¡ Flow control—None.
¡ Terminal emulation—VT100.
· Verify that the console cable is in good condition.
