H3C G6 Servers HDM2 System Log Messages Reference-6W107
HomeSupportDiagnose & MaintainAlarms ReferencesH3C G6 Servers HDM2 System Log Messages Reference-6W107
Download Book
  • Released At: 05-06-2025
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
H3C G6 Servers HDM2
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
Introduction· 1
Use cases· 1
Obtaining system log messages· 1
System log severity level 1
Using this document 2
Applicable products· 2
Event log messages· 4
Temperature· 4
Dropped below the lower minor threshold· 4
Dropped below the lower major threshold· 4
Dropped below the lower critical threshold· 5
Exceeded the upper minor threshold· 5
Exceeded the upper major threshold· 6
Exceeded the upper critical threshold· 7
Voltage· 8
Dropped below the lower minor threshold· 8
Dropped below the lower major threshold· 8
Dropped below the lower major threshold· 9
Dropped below the lower critical threshold· 9
Exceeded the upper minor threshold· 10
Exceeded the upper major threshold· 10
Exceeded the upper major threshold· 11
Exceeded the upper critical threshold· 11
Transition to Non-Critical from OK· 12
Transition to Non-recoverable from less severe· 12
Transition to Non-recoverable from less severe· 13
Transition to Non-recoverable from less severe· 14
Transition to Non-recoverable from less severe· 15
Transition to Non-recoverable from less severe· 16
Transition to Non-recoverable from less severe· 17
Transition to Non-recoverable from less severe· 18
Transition to Non-recoverable from less severe· 19
Transition to Non-recoverable from less severe· 20
Transition to Non-recoverable from less severe· 21
Transition to Non-recoverable from less severe· 22
Transition to Non-recoverable from less severe· 23
Transition to Non-recoverable from less severe· 24
Transition to Non-recoverable from less severe· 25
Transition to Non-recoverable from less severe· 26
Transition to Non-recoverable from less severe· 27
Transition to Non-recoverable from less severe· 28
Transition to Non-recoverable from less severe· 29
Transition to Non-recoverable from less severe· 30
Transition to Non-recoverable from less severe· 31
Transition to Non-recoverable from less severe· 32
Transition to Non-recoverable from less severe· 33
Transition to Non-recoverable from less severe· 34
Transition to Non-recoverable from less severe· 35
Transition to Non-recoverable from less severe· 36
Transition to Non-recoverable from less severe· 37
Transition to Non-recoverable from less severe· 38
Transition to Non-recoverable from less severe· 39
Transition to Non-recoverable from less severe· 40
Transition to Non-recoverable from less severe· 41
Transition to Non-recoverable from less severe· 42
Transition to Non-recoverable from less severe· 43
Transition to Non-recoverable from less severe· 44
Transition to Non-recoverable from less severe· 45
Transition to Non-recoverable from less severe· 46
Transition to Non-recoverable from less severe· 47
Transition to Non-recoverable from less severe· 48
Transition to Non-recoverable from less severe· 49
Transition to Non-recoverable from less severe· 50
Transition to Non-recoverable from less severe· 51
Transition to Non-recoverable from less severe· 52
Transition to Non-recoverable from less severe· 53
Transition to Non-recoverable from less severe· 54
Transition to Non-recoverable from less severe· 55
Transition to Non-recoverable from less severe· 56
Transition to Non-recoverable from less severe· 57
Transition to Non-recoverable from less severe· 58
Transition to Non-recoverable from less severe· 59
Transition to Non-recoverable from less severe· 60
Transition to Non-recoverable from less severe· 61
Transition to Non-recoverable from less severe· 62
Transition to Non-recoverable from less severe· 63
Transition to Non-recoverable from less severe· 64
Transition to Non-recoverable from less severe· 65
Transition to Non-recoverable from less severe· 66
Transition to Non-recoverable from less severe· 67
Transition to Non-recoverable from less severe· 68
Transition to Non-recoverable from less severe· 69
Current 70
Transition to Critical from less severe· 70
Exceeded the upper minor threshold· 70
Exceeded the upper major threshold· 71
Exceeded the upper critical threshold· 72
Fan· 72
Predictive Failure deasserted· 72
Predictive Failure asserted· 73
Transition to Running· 73
Transition to Off Line· 74
Transition to Degraded· 74
Fully Redundant 75
Non-redundant:Sufficient Resources from Redundant 75
Non-redundant:Insufficient Resources· 76
Physical Security· 76
General Chassis Intrusion· 76
LAN Leash Lost 77
Processor 77
IERR· 77
MCERR· 78
Thermal Trip· 78
FRB1/BIST failure· 79
FRB2/Hang in POST failure· 79
FRB3/Processor Startup/Initialization failure· 80
Configuration Error 80
Processor Presence detected· 81
Processor Automatically Throttled· 81
Processor Automatically Throttled· 82
Machine Check Exception· 83
Triggered a uncorrectable error 84
Machine Check Exception· 84
Machine Check Exception· 85
Triggered a correctable error 85
Correctable Machine Check Error 86
Correctable Machine Check Error 87
CPU OEM ERR1· 88
Power Supply· 88
Presence detected· 88
Power Supply Failure detected· 89
Power Supply Predictive Failure· 89
Power Supply input lost (AC/DC) 90
Power Supply input lost or out-of-range· 90
Power Supply input out-of-range - but present 91
Configuration error ---Vendor mismatch· 91
Configuration error---Power Supply rating mismatch· 92
Configuration error---Power supply rating mismatch· 92
Power Supply Inactive/standby state· 93
PSU failure detected by CPLD·· 93
Redundancy Lost 94
Power Unit 94
Power limit is exceeded over correction time limit 94
Cooling Device· 95
Transition to OK· 95
Transition to Non-recoverable---Liquid leakage occurred· 95
Transition to Non-recoverable from less severe· 96
Transition to Non-Critical from OK--- Liquid leakage detection cable is disconnected· 96
Other Units-based Sensor 97
Exceeded the upper minor threshold· 97
Memory· 97
Correctable ECC or other correctable memory error 97
Correctable ECC or other correctable memory error 98
Correctable ECC or other correctable memory error 99
CPU triggered a correctable error 99
Correctable ECC or other correctable memory error 100
Uncorrectable ECC or other uncorrectable memory error 100
Uncorrectable ECC or other uncorrectable memory error 101
Uncorrectable ECC or other uncorrectable memory error 102
Uncorrectable ECC or other uncorrectable memory error 103
Triggered an uncorrectable error 103
Parity· 104
Parity· 104
Parity· 105
Parity---An uncorrectable error occurs during the memory test phase· 105
Parity---The memory interleaving configuration cannot meet the requirements of the server 106
Parity---The memory interleaving configuration cannot meet the requirements of the server 107
Parity---CMD eye width is too small 107
Parity---CmdPiGroup: No Eye width· 108
Parity---The command is not in the FNv table· 108
Parity---Memory read DqDqs training failed· 109
Parity---Memory Receive Enable Training Error 109
Parity---Memory write DqDqs training failed· 110
Parity---An error occurs during memory test, and the rank is disabled· 110
Parity---LRDIMM RCVEN training failed· 111
Parity---Read delay training failed· 111
Parity---Write delay training failed· 112
Parity---Mapped out because failed critical mask test at cold boot 112
Parity---Invalid SPD contents· 113
Parity---The DCPMM memory modules of the unexpected model are installed· 113
Parity---Delay exceeded· 114
Parity---Timing error occurred during signal line adjustment for memory write leveling training· 114
Parity---CS is not consistent with clock in timing, and the channel is isolated· 115
Parity---CA is not consistent with clock in timing, and the channel is isolated· 115
Parity---LRDIMM external coarse training failed· 116
Parity---LRDIMM external fine training failed· 116
Parity---LRDIMM internal coarse training failed· 117
Parity---LRDIMM internal fine training failed· 117
Memory Device Disabled· 118
Memory Device Disabled---The Rank is disabled· 119
Memory Device Disabled---The DIMM is disabled· 120
Memory Device Disabled· 121
Memory Device Disabled---The DIMM is disabled because of inconsistency with POR restrictions· 121
Memory Device Disabled---Buck Regulator Output Over or Under Voltage Lockout 122
Correctable ECC or other correctable memory error logging limit reached· 123
Correctable ECC or other memory error limit reached· 124
Presence detected· 124
Memory patrol scrub CE occurred· 125
Memory patrol scrub UCE occurred and degraded to CE· 126
Memory patrol scrub CE occured· 126
Configuration error---RDIMMs are installed on the server that supports only UDIMMs· 127
Configuration error---UDIMMs are installed on the server that supports only RDIMMs· 127
Configuration error---SODIMMs are installed on the server that supports only RDIMMs· 128
Configuration error---The number of ranks per channel can be only 1, 2, or 4· 128
Configuration error---Columns, rows, or banks of the DIMM cannot meet the JEDEC standards, and LRDIMMs are not supported· 129
Configuration error---The number of ranks in the channel exceeds 8· 130
Configuration error---Support for ECC on the DIMMs is not consistent with support for ECC on the server 130
Configuration error---The voltage for a DDR4 DIMM must be 12V, and the voltage for a DDR5 DIMM must be 11V  131
Configuration error---The CPU is not compatible with 3DS DIMMs· 131
Configuration error---NVDIMMs with stepping lower than 0x10 are not supported· 132
Configuration error---The CPU is not compatible with the DIMMs· 132
Configuration error---The frequency of the DIMM is not supported on the server 133
Configuration error---24Gb or higher Capacity DRAMs not supported with this CPU· 134
Configuration error---The CPU is not compatible with LRDIMMs· 134
Configuration error--- DCPMM + HBM config is not supported. Disable DCPMM populated channel 135
Configuration Error---DIMM speed is less than the minimum POR DIMM speed· 135
Configuration error--- Failed to enable the lockstep mode The memory RAS mode has degraded to independent 136
Configuration error---Failed to enable the full mirror mode· 136
Configuration error---Failed to enable the partial mirror mode The memory RAS mode degraded to independent 137
Configuration error---The memory interleaving configuration cannot meet the requirements of the server 138
Configuration error---Failed to enable the rank sparing mode The memory RAS mode has degraded to independent 139
Configuration error---Failed to enable patrol scrubbing· 140
Configuration Error---The white slot has more ranks than the black slot in a channel or the black slot is used but the white slot in the channel is empty· 141
Configuration error---DIMM population error Two DDR-T memory modules cannot be installed in a channel 142
Configuration error---The DDR-T memory module is installed in the white slot 143
Configuration error---ODT configuration errorThe channel is isolated· 143
Configuration error---REQ is not consistent with clock in timing· 144
Configuration error---Failed to enable ADDDC· 144
Configuration error---NVMCTRL_MEDIA_NOTREADY· 145
Drive Slot 145
Drive Presence· 145
Drive Fault 146
Drive Fault 146
Drive Fault---The disk is present, but its details cannot be obtained· 147
Drive Fault 148
Predictive Failure· 148
Predictive Failure· 149
In Critical Array· 150
In Failed Array· 151
Rebuild/Remap in progress· 151
The disk triggered an media error 152
The disk triggered an uncorrectable error 152
The disk is missing· 153
System Firmware Progress· 153
System Firmware Error (POST Error)---Run sense AMP HW FSM failed· 153
System Firmware Error (POST Error)--- Memory population enforcement mismatch, Please check the DIMM symmetry on the socket 154
System Firmware Error (POST Error)---No Dimm on socket$1· 154
System Firmware Error (POST Error)---No memory found· 155
System Firmware Error (POST Error)---No DIMM is available for memory-mapping operation· 155
System Firmware Error (POST Error)---DIMM population error 156
System Firmware Error (POST Error)---Some CPU links failed to train. UPI topology changed across reset 156
System Firmware Error (POST Error)---CPU stepping mismatch detected· 157
System Firmware Error (POST Error)---KTI Topology Change Logged· 157
System Firmware Error (POST Error)---CPU matching failure---CPU stepping is detected· 158
System Firmware Error (POST Error)---CPU matching failure---CPU frequency is detected· 158
System Firmware Error (POST Error)---CPU matching failure---CPU Microcode is detected· 159
System Firmware Error (POST Error)---CPU matching failure---UPI Topology is detected· 159
System Firmware Error (POST Error)---CPU matching failure· 160
System Firmware Error(POST Error)---Unrecoverable video controller failure· 160
System Firmware Hang· 161
System Firmware Hang---C2C initialization failed· 161
System Firmware Hang---C2C initialization cannot obtain parameter table· 162
System software triggered an uncorrectable error 162
System software triggered a correctable error 163
System Firmware Progress---Secondary processor(s) initialization---Detection unsuccessful 163
System Firmware Progress---PCI resource configuration---PCIe controller initialization failed· 164
System Firmware Progress---PCI resource configuration---PCIe controller initialization cannot find parameter table  164
System Firmware Progress---Video initialization---Detection unsuccessful 165
Event Logging Disabled· 165
Log Area Reset/Cleared· 165
SEL Full 166
SEL Almost Full 166
System Event 167
System Reconfigured---BIOS load default. CMOS cleared· 167
Oem system boot event---LPC Reset occurred· 167
Limit Exceeded---CPU usage exceeds the threshold· 168
Limit Exceeded---Mem usage exceeds the threshold· 168
Limit Exceeded---Network usage exceeds the threshold· 169
Limit Exceeded---Hard disk usage exceeds the threshold· 169
Timestamp clock synch· 170
Timestamp clock synch---BMC Time SYNC succeed· 170
Critical Interrupt 171
Transition to Non-Critical from OK· 171
PCI PERR· 172
PCI SERR· 173
Bus Correctable Error 174
GPU Device Correctable Error 174
GPU PCIe Bus Correctable Error 175
GPU Vedio Memory Correctable Error 175
Bus Correctable Error 176
Bus Uncorrectable Error 177
GPU Device Uncorrectable Error 178
GPU PCIe Bus Uncorrectable Error 178
GPU Vedio Memory Uncorrectable Error 179
Bus Uncorrectable Error 179
Bus Fatal Error 180
Bus Degraded· 181
$1 triggered an uncorrectable error 182
$1 triggered a correctable error 183
Button / Switch· 184
Power Button pressed---Physical button---Button pressed· 184
Reset Button pressed· 184
Module / Board· 185
Transition to Non-Critical from OK($1) 185
Transition to Critical from less severe· 185
Transition to Non- Recoverable from less severe· 186
Transition to Non-Critical from OK---System is operating in KTI Link Slow Speed Mode· 186
Transition to Non-Critical from OK---Requested Link Speed is not supported. Defaulting to 18GT· 187
Transition to Non-Critical from OK---One or more per Link option mismatch detected. Forcing to common setting  187
Transition to Non-Critical from OK---Some CPU has more than one link connecting to other CPU. Disable one of the Dual-Link· 188
Transition to Non-Critical from OK---KTI Adaptation is in progress, or High Speed adaptation is failed  188
System board triggered a correctable error 189
System board triggered an uncorrectable error 189
Add-in Card· 190
Transition to OK· 190
Transition to Critical from less severe· 191
Transition to Critical from less severe· 192
Transition to Non-recoverable  from less severe· 193
ChipSet 193
Transition to Critical from less severe· 193
Cable/Interconnect 194
Configuration Error - Incorrect cable connected / Incorrect interconnection· 194
Configuration Error - Incorrect cable connected / Incorrect interconnection· 195
System Boot / Restart Initiated· 196
Initiated by power up· 196
Initiated by hard reset 196
Initiated by warm reset 197
System restart 197
Boot Error 198
No bootable media· 198
OS_BOOT· 198
C: boot completed· 198
Boot completed - boot device not specified· 199
OS Stop / Shutdown· 199
Run-time Critical Stop· 199
OS Graceful Stop· 200
OS Graceful Shutdown· 200
Slot / Connector 201
Device Disabled: PCIe module information not obtained· 201
Fault Status asserted· 201
Transition to Non-Critical from OK· 202
System ACPI Power State· 202
S0 / G0 "working" 202
S0 / G0 "working" 203
S5 / G2 "soft-off" 203
S5 / G2 "soft-off" 204
S4 / S5 soft-off, particular S4 / S5 state cannot be determined· 205
LPC Reset occurred· 205
Watchdog2· 206
Watchdog overflowAction:Timer expired· 206
Watchdog overflowAction:Hard Reset 207
Watchdog overflowAction:Power Down· 208
Watchdog overflowAction:Power Cycle· 209
Entity Presence· 210
Entity Present---License is about to expire· 210
Entity Disabled---License has expired· 210
Management Subsystem Health· 211
Controller access degraded or unavailable· 211
Battery· 212
Battery low (predictive failure) 212
Battery failed· 213
Battery presence detected· 213
Version Change· 214
Hardware incompatibility detected with associated Entity---Memory is not certified· 214
Introduction
This document describes HDM2 log messages generated to notify the occurrence and removal of system exceptions detected by sensors in the server. You can use this document to obtain message details and recommended actions for server maintenance.
HDM2 is an upgraded version of HDM. For convenience purposes, the term "HDM" refers to HDM2 in this document.
Use cases
When the device experiences a failure or certain reasons lead to an abnormal working state of the system, the system is able to generate alarms based on the faults occurring in different modules, as well as generate event log information. After obtaining the log information, users can search for the corresponding log information in this document using the relevant fields in the log information. This will allow them to understand the detailed content of the log information and receive recommended solutions for handling, thus facilitating the maintenance of the server's normal operation.
You can obtain system log messages through the following methods:
·     HDM Web interface—Access the HDM Web interface and click Remote O&M > Log > Log Download. On the Log Download tab, select to download the entire log or log entries for a period.
·     Alert emails—Complete alert email settings to obtain log messages.
·     Third-party platform—Complete SNMP, SMTP, and SYSLOG settings to connect HDM to a third-party management platform, and obtain log messages from the platform.
·     Redfish event subscription—If a remote subscription server is configured, Redfish uploads received log messages to the remote subscription server.
·     IPMI commands—Use IPMItool commands to access the IPMI interface for BMC and enter commands to obtain event log messages.
Table 1 System log message severity levels
Severity
Critical
The following conditions are present: severe decreases in the processing power of the system processing unit, significant reduction in available system resources, severe decreases in service processing capabilities, widespread interruptions in service modules, or unavailability of storage devices. This may lead to or cause server failure, system crashes, service data loss or other similar situations. Immediate action is required.
Major
Such events have had a significant impact on the system and there is a possibility of interrupting the normal operation of system or service modules (computing, storage, communication, and user data security), which may lead to service interruption.
Minor
Such events have not had a significant impact on the system, but there may be some risks and potential hazards. It is advisable to observe the relevant events and take necessary measures when needed to prevent further escalation of faults.
Info
Event logs generated during the normal operation of the server. Such events do not affect the normal operation of the server and do not require any action.
Using this document
This document explains messages in tables. Table 2 describes information provided in these tables.
Table 2 Message explanation table contents
Item
Example
Event code
A hexadecimal code that uniquely represents a log message.
The parity of the last character in the event code represents the alarm type:
·     Even—An alarm was generated.
·     Odd—An alarm was removed.
0x02900002
Message text
Presents the message description. The same message description might be reported by different types of sensors.
Exceeded the upper major threshold.---Current reading:$1---Threshold reading:$2
Variable fields
Briefly describes the variable fields in the order that they appear in the message text.
The variable fields are numbered in the "$Number" form to help you identify their location in the message text.
·     $1: Current reading of the voltage sensor.
·     $2: Major overvoltage threshold of the voltage sensor.
Severity level
Provides the severity level of the message.
Major
Example
Log example.
Exceeded the upper major threshold.---Current reading:2.58---Threshold reading:2.56
Impact
Explains the impact of the alarm event on the system
Performance degradation and unstable operation might occur on the device components if the voltage is too high.
Cause
Explains the reason for the log generation
Abnormal board voltage.
Recommended action
Provides recommended actions. If the issue persists after the recommended actions have been taken, contact the technical support.
1.     Verify that the external power supply is operating correctly.
2.     Access the HDM Web interface and verify that the power supply is operating correctly.
3.     If the issue persists, contact Technical Support.
Applicable products
This document is available for the following product models:
·     H3C UniServer E3300 G6
·     H3C UniServer R3950 G6
·     H3C UniServer R4300 G6
·     H3C UniServer R4500 G6
·     H3C UniServer R4700 G6
·     H3C UniServer R4700LE G6
·     H3C UniServer R4900 G6
·     H3C UniServer R4900 G6 Ultra
·     H3C UniServer R4900LE G6 Ultra
·     H3C UniServer R4950 G6
·     H3C UniServer R5300 G6
·     H3C UniServer R5350 G6
·     H3C UniServer R5500 G6
·     H3C UniServer B5700 G6
·     H3C UniServer R6700 G6
·     H3C UniServer R6900 G6
Event log messages
Temperature
Event code
0x01000002
Variable fields
$1: Current reading of the temperature sensor
$2: Threshold (in Celsius) for triggering a minor low-temperature notification.
Severity level
Minor
Example
Dropped below the lower minor threshold---Current reading:8--Threshold reading:10
Impact
Performance degradation and unstable operation might occur on the device components if the temperature is too low.
If the temperature does not rise and the alarm persists, it may result in further temperature reduction and produce alarms of the major level. Therefore, it is important to detect potential issues that may lead to low temperature alarms as early as possible to avoid escalation of the problem.
Cause
The temperature is too low.
Recommended action
1.     ‍Adjust the temperature of the equipment room.
2.     If the issue persists, contact Technical Support.
Event code
0x01200002
Message text
Dropped below the lower major threshold---Current reading:$1---Threshold reading:$2
Variable fields
$2: Threshold (in Celsius) for triggering a major low-temperature notification.
Severity level
Major
Example
Dropped below the lower major threshold---Current reading:4--Threshold reading:5
Impact
If the temperature does not rise and the alarm persists, it may result in further temperature reduction and generate alarms of the critical level. Therefore, it is important to detect potential issues that may lead to low temperature alarms as early as possible in order to avoid problem escalation.
Cause
Recommended action
Event code
0x01400002
Message text
Dropped below the lower critical threshold---Current reading:$1---Threshold reading:$2
Variable fields
$2: Threshold (in Celsius) for triggering a critical low-temperature notification.
Severity level
Critical
Example
Dropped below the lower critical threshold---Current reading:0--Threshold reading:1
Impact
Operating devices in ultra-low temperature environments can reduce device performance, impact device lifespan, disrupt business operations, and lead to system downtime.
Cause
Recommended action
Event code
0x01700002
Message text
Exceeded the upper minor threshold---Current reading:$1---Threshold reading:$2
Variable fields
$2: Threshold (in Celsius) for triggering a minor high-temperature notification.
Severity level
Minor
Example
Exceeded the upper minor threshold---Current reading:85---Threshold reading:80
Impact
Performance degradation and unstable operation might occur on the device components if the temperature is too high.
If the temperature does not decrease and the alarm persists, it may result in further temperature rise and generate major-level alarms. Therefore, it is important to detect potential issues that may lead to high temperature alarms as early as possible in order to avoid problem escalation.
Cause
High ambient temperature, blockage of air intake or exhaust, and low fan speed.
Recommended action
2.     Verify that the air inlet and outlet are not blocked.
3.     Log in to HDM, and verify that the fans are running correctly. If abnormal fans exist, replace them.
4.     Log in to HDM, access the fan management page, and verify that the fan speed is appropriate.
5.     If the issue persists, contact Technical Support.
Event code
0x01900002
Message text
Exceeded the upper major threshold---Current reading:$1---Threshold reading:$2
Variable fields
$2: Threshold (in Celsius) for triggering a major high-temperature notification.
Severity level
Major
Example
Exceeded the upper major threshold---Current reading:90---Threshold reading:88
Impact
If the temperature does not decrease and the alarm persists, it may result in further temperature rise and generate critical-level alarms. Therefore, it is important to detect potential issues that may lead to high temperature alarms as early as possible in order to avoid problem escalation.
Cause
High ambient temperature, clogged air intake or exhaust, and low fan speed.
Recommended action
Event code
0x01b00002
Message text
Exceeded the upper critical threshold---Current reading:$1---Threshold reading:$2
Variable fields
$2: Threshold (in Celsius) for triggering a critical high-temperature notification.
Severity level
Critical
Example
Exceeded the upper critical threshold---Current reading:95---Threshold reading:90
Impact
Operating devices in high-temperature environments can reduce device performance, impact device lifespan, increase energy consumption, disrupt business operations, and cause system crashes.
Cause
Recommended action
Voltage
Event code
0x02000002
Message text
Dropped below the lower minor threshold---Current reading:$1---Threshold reading:$2
Variable fields
$2: Threshold for triggering a minor low-voltage notification.
Severity level
Minor
Example
Impact
Performance degradation and unstable operation might occur on the device components if the voltage is too low.
Cause
Recommended action
1.     ‍Verify whether the log was generated during device power-on or power-off. If it was, no action is required.
2.     If device was running correctly when the log was generated, replace the system board.
Event code
0x02200002
Message text
Variable fields
$2: Threshold for triggering a major low-voltage notification.
Severity level
Major
Example
Impact
Cause
Recommended action
Event code
0x02220002
Message text
Variable fields
Severity level
Major
Example
Dropped below the lower major threshold---Current reading:10---Threshold reading:2
Impact
Memory and system performance degradation might occur.
Cause
This alarm is generated when the PMIC voltage reading of the memory is lower than the low voltage major alarm threshold.
Recommended action
2.     If device was running correctly when the log was generated, replace the DIMM.
Event code
0x02400002
Message text
Variable fields
$2: Threshold for triggering a critical low-voltage notification.
Severity level
Critical
Example
Impact
The device is running in an ultra-low voltage environment, which affects the system's power supply, or causes one board to power off, leading to a system crash.
Cause
Recommended action
Event code
0x02700002
Message text
Variable fields
$2: Threshold for triggering a minor high-voltage notification.
Severity level
Minor
Example
Impact
Cause
Recommended action
Event code
0x02900002
Message text
Variable fields
$2: Threshold for triggering a major high-voltage notification.
Severity level
Major
Example
Impact
Cause
Recommended action
Event code
0x02920002
Message text
Variable fields
Severity level
Major
Example
Exceeded the upper major threshold---Current reading:10---Threshold reading:1
Impact
Cause
This alarm is generated when the PMIC voltage of the memory is higher than the current major voltage alarm threshold.
Recommended action
Event code
0x02b00002
Message text
Variable fields
$2: Threshold for triggering a critical high-voltage notification.
Severity level
Critical
Example
Impact
The device is operating in an ultra-high voltage environment, which affects the system's power supply, or causes a board to power off, resulting in a system crash.
Cause
Recommended action
Event code
0x0218d00e
Message text
Transition to Non- Critical from OK($1)
Variable fields
$1: VGA_REAR, USB_REAR_UP, USB_REAR_DOWN,  EAR_VGA2, EAR_LCD, L_EAR_USB, INNER_USB, R_EAR_USB, L_EAR_VGA, L_EAR_TYPEC
Severity level
Minor
Example
Transition to Non-Critical from OK(VGA_REAR)
Impact
The system will be powered off.
Cause
In-board voltage error.
Recommended action
1.     ‍Verify that the power supply is correct and stable.
2.     Verify if the alarm interface is connected to a device. If connected, disconnect it to prevent overcurrent caused by device short-circuit.
3.     Power off and restart the server.
4.     If the issue persists, replace the system board.
Event code
0x1530200e
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
HDD Bay does not operate correctly, which impacts the reliability of the system.
Cause
The HDD Bay voltage is abnormal.
Recommended action
1.     ‍Reconnect the HDD Bay node. Make sure the node is completely powered off from the AC power source before powering on the node.
2.     If the issue persists, replace the HDD Bay component.
Event code
0x1530300e
Message text
Transition to Non-recoverable from less severe($1)
Variable fields
$1: Faulty power supply position on the GPU riser card.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(P3V3_A)
Impact
The system is powered off.
Cause
A power supply error occurred on the GPU riser card.
Recommended action
1.     Gently press the physical power button to power off the server. Then, press the physical power button again to power on the server.
2.     If the server fails to power on, reconnect all power cords, and then power on the server.
3.     If the issue persists, replace the GPU riser card.
4.     If the issue persists, contact Technical Support.
Event code
0x1530400e
Message text
Variable fields
Severity level
Critical
Example
Transition to Non-recoverable from less severe(P12V_0)
Impact
Cause
Recommended action
4.     If the issue persists, reconnect or replace the power cord of the GPU power adapter board.
Event code
0x0230000e
Message text
Transition to Non-recoverable from less severe---System detected a power supply failure($1)
Variable fields
$1: BMC_network_PHY_P1V0, BMC_network_PHY_P1V8.
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(BMC_network_PHY_P1V0)
Impact
Cause
An alarm occurs on the PHY power supply for the BMC dedicated network port.
Recommended action
1.     ‍Identify whether the host is AC powered off.
¡     If the host is AC powered off, reconnect the power cords and verify that the host can be powered on successfully.
¡     If the host is not AC powered off and the other power supply is operating correctly, replace the system board.
Event code
0x0230010e
Message text
Variable fields
$1: P1V8_PCH_STBY, P1V05_PCH_STBY, PVNN_PCH_STBY, PVCCIN_CPU0_VR_HOT, PVCCD_HV_CPU0_VR_HOT, PVCCINFAON_CPU0_VR_HOT.
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P1V8_PCH_STBY)
Impact
Cause
The current or voltage on the system board is abnormal.
Recommended action
1.     ‍Gently press the physical power button to power off the host, and then press the power button to power on the host again.
2.     If the host fails to be powered on again, reconnect all power cords to ensure that the host is powered on after it is completely powered off.
3.     If the issue persists, replace the system board.
Event code
0x0230a00e
Message text
Transition to Non-recoverable from less severe---System detected a power supply failure ($1)
Variable fields
$1: AC lost
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure (AC lost)
Impact
The AC power supply is removed from the device.
Cause
CPLD detected ACFAIL signal from all PSUs.
Recommended action
1.     ‍Examine whether any abnormalities exist in the power supply network of the device, such as power grid fluctuations, PDU abnormality, or poor contact of the national standard power cord.
2.     Examine the PSUs for errors. If problems are detected, replace the PSUs.
Event code
0x0230c00e
Message text
Variable fields
$1: RISER1, RISER2, RISER3, RISER4, RISER5
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(RISER1)
Impact
Cause
·     A power error occurs on RISER P3V3.
·     Overcurrent is detected on RISER INA3221.
Recommended action
1.     Gently press the physical power button to power off the host, and then press the power button to power on the host again.
3.     If the issue persists, replace the faulty riser card.
Event code
0x0230d00e
Message text
Variable fields
$1: Mezz1, Mezz2, Mezz3, NIC_MEZZ.
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(NIC_MEZZ)
Impact
Cause
The Mezz card power supply is abnormal.
Recommended action
1.     ‍Reconnect the power cords. Verify that the server can be powered on correctly. If the server cannot be powered on, replace the corresponding MEZZ module.
Event code
0x0230d10e
Message text
Variable fields
$1: Mezz1.
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(Mezz1)
Impact
Cause
Recommended action
Event code
0x0231110e
Message text
Variable fields
$1: CPU1_DIMM_AB_PMIC_ERROR.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(CPU1_DIMM_AB_PMIC_ERROR)
Impact
Cause
The power supply is abnormal.
Recommended action
1.     ‍Memory power failure occurred in channel 1 and channel 2 for processor 1, re-install the memory module in the alarming channels.
2.     Replace the memory modules in the alarming channels.
3.     Remove the corresponding processor and verify that the processor socket does not have bent pins or foreign objects.
4.     Re-install the processor and make sure it is properly secured.
Event code
0x0231120e
Message text
Variable fields
$1: CPU1_DIMM_CD_PMIC_ERROR.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(CPU1_DIMM_CD_PMIC_ERROR)
Impact
Cause
Recommended action
1.     ‍Memory power failure occurred in channel 3 and channel 4 for processor 1, re-install the memory module in the alarming channels.
Event code
0x0231130e
Message text
Variable fields
$1: CPU1_DIMM_EF_PMIC_ERROR.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(CPU1_DIMM_EF_PMIC_ERROR)
Impact
Cause
Recommended action
1.     ‍Memory power failure occurred in channel 5 and channel 6 for processor 1, re-install the memory module in the alarming channels.
Event code
0x0231140e
Message text
Variable fields
$1: CPU1_DIMM_GH_PMIC_ERROR.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(CPU1_DIMM_GH_PMIC_ERROR)
Impact
Cause
Recommended action
1.     ‍Memory power failure occurred in channel 7 and channel 8 for processor 1, re-install the memory module in the alarming channels.
Event code
0x0231150e
Message text
Variable fields
$1: CPU2_DIMM_AB_PMIC_ERROR.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(CPU2_DIMM_AB_PMIC_ERROR)
Impact
Cause
Recommended action
1.     ‍Memory power failure occurred in channel 1 and channel 2 for processor 2, re-install the memory module in the alarming channels.
Event code
0x0231160e
Message text
Variable fields
$1: CPU2_DIMM_CD_PMIC_ERROR.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(CPU2_DIMM_CD_PMIC_ERROR)
Impact
Cause
Recommended action
1.     ‍Memory power failure occurred in channel 3 and channel 4 for processor 2, re-install the memory module in the alarming channels.
Event code
0x0231170e
Message text
Variable fields
$1: CPU2_DIMM_EF_PMIC_ERROR.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(CPU2_DIMM_EF_PMIC_ERROR)
Impact
Cause
Recommended action
1.     ‍Memory power failure occurred in channel 5 and channel 6 for processor 2, re-install the memory module in the alarming channels.
Event code
0x0231180e
Message text
Variable fields
$1: CPU2_DIMM_GH_PMIC_ERROR.
Severity level
Critical
Example
Transition to Non-recoverable from less severe(CPU2_DIMM_GH_PMIC_ERROR)
Impact
Cause
Recommended action
1.     ‍Memory power failure occurred in channel 7 and channel 8 for processor 2, re-install the memory module in the alarming channels.
Event code
0x0230200e
Message text
Transition to Non-recoverable from less severe---System detected a power supply failure on $1
Variable fields
$1: CPU power supply failure type. Options include PVCCD_HV_CPU3, PVPP_HBM_CPU3, PVCCFA_EHV_CPU3, PVCCFA_EHV_FIVRA_CPU3, PVCCINFAON_CPU3, PVNN_MAIN_CPU3, PVCCIN_CPU3, PVCCD_HV_CPU4, PVPP_HBM_CPU4, PVCCFA_EHV_CPU4, PVCCFA_EHV_FIVRA_CPU4, PVCCINFAON_CPU4, PVNN_MAIN_CPU4, and PVCCIN_CPU4.
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure (PVCCD_HV_CPU3)
Impact
The device is immediately shut down and enters power failure state.
The LEDs on the chassis ear are rapidly flashing (the power LED flashes red, the UID LED flashes blue, the NIC LED flashes green, and the health LED flashes red), and the status is no longer controllable. The LED status recovers after the issue is resolved and the device is re-powered on.
Cause
The internal power supply of the CPU experiences faults such as overcurrent, overvoltage, or undervoltage in the VR chip on the processor mezzanine board that corresponds to the CPU power supply.
Recommended action
1.     ‍Identify whether the server is powered off. If the server is powered off, re-connect the power cord and identify whether the server can be powered on properly.
2.     If the server is not powered off, replace the processor mezzanine board.
3.     If the issue persists, replace the CPU.
Event code
0x0230300e
Message text
Transition to Non-recoverable from less severe---System detected a power supply failure on the backplane($1)
Variable fields
$1: REAR_BACKPLANE, REAR_BACKPLANE1, REAR_BACKPLANE2, REAR_BACKPLANE3, FRONT_BACKPLANE1, FRONT_BACKPLANE2, FRONT_BACKPLANE3, MID_BACKPLANE1, MID_BACKPLANE2.
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure on the backplane(FRONT_BACKPLANE1)
Impact
Cause
The board voltage is abnormal.
Recommended action
1.     ‍Verify that the drive backplane is operating correctly.
2.     Reconnect the power cord to verify that the server can be powered on correctly. If the server cannot be powered on correctly, replace the drive backplane.
Event code
0x0231d00e
Message text
Variable fields
$1: RAID card
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure on RAID card
Impact
The device immediately shuts down and enters power failure state.
Cause
CPLD detects PGD signal of RAID controller.
Recommended action
1.     ‍Reconnect the power cords. Verify that the server can be powered on correctly. If the server cannot be powered on, replace the corresponding RAID controller.
Event code
0x0231190e
Message text
Variable fields
$1: CPU1_DIMM_PMIC_ERROR_1-6, P1_DIMM_AF_PMIC_ERROR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_DIMM_PMIC_ERROR_1-6)
Impact
Cause
Recommended action
1.     ‍Re-install the memory modules in slots 1 through 6 under CPU1.
2.     Examine whether the CPU is securely fastened.
3.     Examine the CPU socket for bent pins or foreign objects.
Event code
0x02311a0e
Message text
Variable fields
$1: CPU1_DIMM_PMIC_ERROR_7-12, P1_DIMM_GL_PMIC_ERROR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_DIMM_PMIC_ERROR_7-12)
Impact
Cause
Recommended action
1.     ‍Re-install the memory modules in slots 7 through 12 under CPU1.
Event code
0x02311b0e
Message text
Variable fields
$1: CPU2_DIMM_PMIC_ERROR_1-6, P2_DIMM_AF_PMIC_ERROR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_DIMM_PMIC_ERROR_1-6)
Impact
Cause
Recommended action
1.     ‍Re-install the memory modules in slots 1 through 6 under CPU2.
Event code
0x02311c0e
Message text
Variable fields
$1: CPU2_DIMM_PMIC_ERROR_7-12, P2_DIMM_GL_PMIC_ERROR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_DIMM_PMIC_ERROR_7-12)
Impact
Cause
Recommended action
1.     ‍Re-install the memory modules in slots 7 through 12 under CPU2.
Event code
0x0231400e
Message text
Variable fields
$1: M.2 adapter card
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(M.2 adapter card)
Impact
Cause
The power supply of the M.2 adapter card has failed.
Recommended action
2.     If the server is not powered off, replace the corresponding M.2 adapter card.
Event code
0x0231500e
Message text
Variable fields
$1: OCP1 network card, OCP2 network card, or OCP3 network card
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(OCP1 network card)
Impact
Cause
The power supply of the OCP network adapter is abnormal.
Recommended action
2.     If the server is not powered off, replace the OCP network adapter.
3.     If the issue persists, replace the adapter.
Event code
0x0232200e
Message text
Variable fields
$1: Mezzanine storage controller
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(Mezzanine storage controller)
Impact
Cause
The power supply of the Mezzanine storage controller has failed.
Recommended action
2.     If the server is not powered off, replace the corresponding Mezzanine storage controller.
Event code
0x0239000e
Message text
Transition to Non-recoverable from less severe---System detected GPU power supply failure($1)
Variable fields
$1: P12V_SLOT_1_2, P12V_SLOT_3_4, P12V_SLOT_5_6, P12V_SLOT_7_8.
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected GPU power supply failure(P12V_SLOT_1_2)
Impact
The system might be powered off.
Cause
The power supply to the system board is abnormal.
Recommended action
1.     Identify whether the server is powered off. If the server is powered off, re-connect the power cord and identify whether the server can be powered on properly.
2.     If the server is not powered off, remove the GPU from the corresponding slot and then power on the server. If the server is powered on, contact Technical Support. If the server cannot be powered on, proceed to the next step.
Event code
0x0233000e
Message text
Variable fields
Severity level
Critical
Example
Impact
Cause
The power supply of the BMC card is abnormal.
Recommended action
2.     If the server is not powered off, replace the BMC card.
Event code
0x0233500e
Message text
Transition to Non-recoverable from less severe---System detected a power supply failure on GPUSWITCH($1)
Variable fields
$1: P3V3_A, P3V3_B, P3V3_C, P3V3_D, P12V_0, P12V_1, P1V8, P1V8_A, P1V8_B, P0V9_2_3, P0V9_0_1, P12V_SLOT1, P12V_SLOT3, P12V2, or P12V3.
Severity level
Critical
Example
Transition to Non-recoverable from less severe--- System detected a power supply failure on GPUSWITCH(P1V8)
Impact
Cause
·     The power cables of the GPUSWITCH board are either not properly assembled or not fully connected.
·     The AUX cable from the GPUSWITCH board to the system board is not properly assembled.
·     The power of the GPUSWITCH board is abnormal.
Recommended action
2.     If the server cannot be poweredon, verify if the cables of the GPUSWITCH board are connected correctly.
3.     If the issue persists, replace the GPUSWITCH board.
Event code
0x0233a00e
Message text
Variable fields
$1: DSD card
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(DSD card)
Impact
Cause
Abnormal DSD card voltage.
Recommended action
2.     If the server is not powered off, replace the DSD card.
Event code
0x0233d00e
Message text
Variable fields
$1: P12V
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V)
Impact
Cause
Abnormal P12V voltage.
Recommended action
2.     Sequentially check the PSU, fans, RISER, drive backplane, and system board.
3.     Replace the faulty component.
Event code
0x0233e00e
Message text
Variable fields
$1: P5V
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P5V)
Impact
Cause
Abnormal P5V voltage.
Recommended action
2.     If the server is not powered off, replace the system board.
3.     If the issue persists, replace the BMC card.
4.     If the issue persists, replace the rear backplane.
Event code
0x0233f00e
Message text
Variable fields
$1: P5V_STBY
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P5V_STBY)
Impact
Cause
Recommended action
Event code
0x0234000e
Message text
Variable fields
$1: P12V_STBY
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_STBY)
Impact
Cause
Recommended action
3.     If the issue persists, replace the OCP3 module.
4.     If the issue persists, replace the fan module.
Event code
0x0234100e
Message text
Variable fields
$1: P12V Overcurrent
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V Overcurrent)
Impact
Cause
Abnormal P12V signal current.
Recommended action
3.     If the issue persists, replace the fan module.
4.     If the issue persists, replace the memory module.
Event code
0x0234200e
Message text
Variable fields
$1: PVCCD_HV_CPU1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCD_HV_CPU1)
Impact
Cause
Recommended action
Event code
0x0234300e
Message text
Variable fields
$1: PVPP_HBM_CPU1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVPP_HBM_CPU1)
Impact
Cause
Recommended action
Event code
0x0234400e
Message text
Variable fields
$1: PVCCFA_EHV_CPU1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCFA_EHV_CPU1)
Impact
Cause
Recommended action
Event code
0x0234500e
Message text
Variable fields
$1: PVCCFA_EHV_FIVRA_CPU1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCFA_EHV_FIVRA_CPU1)
Impact
Cause
Recommended action
Event code
0x0234600e
Message text
Variable fields
$1: PVCCINFAON_CPU1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCINFAON_CPU1)
Impact
Cause
Recommended action
Event code
0x0234700e
Message text
Variable fields
$1: PVNN_MAIN_CPU1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVNN_MAIN_CPU1)
Impact
Cause
Recommended action
Event code
0x0234800e
Message text
Variable fields
$1: PVCCIN_CPU1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCIN_CPU1)
Impact
Cause
Recommended action
Event code
0x0234900e
Message text
Variable fields
$1: PVCCD_HV_CPU2
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCD_HV_CPU2)
Impact
Cause
Recommended action
Event code
0x0234a00e
Message text
Variable fields
$1: PVPP_HBM_CPU2
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVPP_HBM_CPU2)
Impact
Cause
Recommended action
Event code
0x0234b00e
Message text
Variable fields
$1: PVCCFA_EHV_CPU2
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCFA_EHV_CPU2)
Impact
Cause
Recommended action
Event code
0x0234c00e
Message text
Variable fields
$1: PVCCFA_EHV_FIVRA_CPU2
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCFA_EHV_FIVRA_CPU2)
Impact
Cause
Recommended action
Event code
0x0234d00e
Message text
Variable fields
$1: PVCCINFAON_CPU2
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCINFAON_CPU2)
Impact
Cause
Recommended action
Event code
0x0234e00e
Message text
Variable fields
$1: PVNN_MAIN_CPU2
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVNN_MAIN_CPU2)
Impact
Cause
Recommended action
Event code
0x0234f00e
Message text
Variable fields
$1: PVCCIN_CPU2
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PVCCIN_CPU2)
Impact
Cause
Recommended action
Event code
0x0235000e
Message text
Variable fields
$1: P3V3_STBY_A, P3V3
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P3V3_STBY_A)
Impact
Cause
Recommended action
Event code
0x0235100e
Message text
Variable fields
$1: P5V_STBY
Severity level
Critical
Example
Impact
Cause
Recommended action
Event code
0x0235200e
Message text
Variable fields
$1: P12V_STBY
Severity level
Critical
Example
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the PSUs.
Event code
0x0235300e
Message text
Variable fields
$1: P12V
Severity level
Critical
Example
Impact
Cause
Recommended action
Event code
0x0235400e
Message text
Variable fields
$1: CPU1_1V8_STBY
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_1V8_STBY)
Impact
Cause
Recommended action
3.     If the issue persists, replace CPU1.
Event code
0x0235500e
Message text
Variable fields
$1: CPU1_3V3_STBY
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_3V3_STBY)
Impact
Cause
Recommended action
Event code
0x0235600e
Message text
Variable fields
$1: CPU2_1V8_STBY
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_1V8_STBY)
Impact
Cause
Recommended action
3.     If the issue persists, replace CPU2.
Event code
0x0235700e
Message text
Variable fields
$1: CPU2_3V3_STBY
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_3V3_STBY)
Impact
Cause
Recommended action
Event code
0x0235800e
Message text
Variable fields
$1: CPU1_VDDCR1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_VDDCR1)
Impact
Cause
Recommended action
Event code
0x0235900e
Message text
Variable fields
$1: CPU1_VDDCR0
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_VDDCR0)
Impact
Cause
Recommended action
Event code
0x0235a00e
Message text
Variable fields
$1: CPU1_VDDCR_SOC
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_VDDCR_SOC)
Impact
Cause
Recommended action
Event code
0x0235b00e
Message text
Variable fields
$1: CPU1_VDDIO
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_VDDIO)
Impact
Cause
Recommended action
Event code
0x0235c00e
Message text
Variable fields
$1: CPU1_1V1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_1V1)
Impact
Cause
Recommended action
Event code
0x0235d00e
Message text
Variable fields
$1: CPU2_VDDCR1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_VDDCR1)
Impact
Cause
Recommended action
Event code
0x0235e00e
Message text
Variable fields
$1: CPU2_VDDCR0
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_VDDCR0)
Impact
Cause
Recommended action
Event code
0x0235f00e
Message text
Variable fields
$1: CPU2_VDDCR_SOC
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_VDDCR_SOC)
Impact
Cause
Recommended action
Event code
0x0236000e
Message text
Variable fields
$1: CPU2_VDDIO
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_VDDIO)
Impact
Cause
Recommended action
Event code
0x0236100e
Message text
Variable fields
$1: CPU2_1V1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_1V1)
Impact
Cause
Recommended action
Event code
0x0236200e
Message text
Variable fields
$1: OCP1 card
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(OCP1 card)
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the OCP1 card.
Event code
0x0236300e
Message text
Variable fields
$1: OCP2 card
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(OCP2 card)
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the OCP2 card.
Event code
0x0236400e
Message text
Variable fields
$1: OCP3 card
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(OCP3 card)
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the OCP3 card.
3.     If the issue persists, replace the adapter board if available.
Event code
0x0236500e
Message text
Variable fields
$1: AC lost
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(AC lost)
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the power supply.
Event code
0x0236600e
Message text
Variable fields
$1: P12V_STBY
Severity level
Critical
Example
Impact
Cause
Recommended action
2.     Power off and restart the server.
3.     If the issue persists,replace the system board.
Event code
0x0236700e
Message text
Variable fields
$1: P12V
Severity level
Critical
Example
Impact
Cause
Recommended action
Event code
0x0236900e
Message text
Variable fields
$1: RISER_P12V_OCP
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(RISER_P12V_OCP)
Impact
Cause
Recommended action
3.     Re-install the riser card or replace the riser card and make sure the riser card provides power correctly.
Event code
0x0236a00e
Message text
Variable fields
$1: CPU_DIMM_P12V_OCP
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU_DIMM_P12V_OCP)
Impact
Cause
Recommended action
2.     If power supply is not removed from the server, verify if any DIMM, processor, or system board alarms are present. If a corresponding component is faulty, replace the component.
3.     If no component alarms are present, replace the DIMM.
4.     If the issue persists, replace the CPU.
5.     If the issue persists, replace the system board.
6.     If the issue persists, contact Technical Support.
Event code
0x0236b00e
Message text
Variable fields
$1: P12V_BP_FRONT
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_BP_FRONT)
Impact
Cause
Recommended action
3.     If the issue persists, replace the front backplane.
Event code
0x0236c00e
Message text
Variable fields
$1: P12V_BP_REAR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_BP_REAR)
Impact
Cause
Recommended action
3.     If the issue persists, replace the rear backplane.
Event code
0x0236d00e
Message text
Variable fields
$1: P5V_BP, P3V3_STBY_BP
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P5V_BP)
Impact
Cause
Recommended action
3.     Reconnect the backplane power supply or replace the backplane. Make sure the backplane has correct power supply.
Event code
0x0236e00e
Message text
Variable fields
Severity level
Critical
Example
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the fan.
Event code
0x0237100e
Message text
Variable fields
$1: P12V
Severity level
Critical
Example
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the riser card.
3.     If the issue persists, replace the backplane.
Event code
0x0237200e
Message text
Variable fields
$1: CPU1_THERMTRIP, CPU2_THERMTRIP
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_THERMTRIP)
Impact
The device gets stuck before this message is generated. Then, the device is powered off and enters the standby mode.
Cause
The CPU actively lower its frequency when its actual temperature exceeds the upper limit. If the CPU continues to overheat even after the frequency is lowered, the Thermtrip signal will be triggered and the CPU will stop running.
Recommended action
2.     If the server is not powered off, replace the CPU and CPU heatsink.
Event code
0x0237300e
Message text
Variable fields
$1: REAR_4SFF_EFUSE, P12V_BP_REAR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(REAR_4SFF_EFUSE)
Impact
Cause
Recommended action
3.     If the issue persists, replace the 4SFF backplane.
Event code
0x0237400e
Message text
Variable fields
$1: RISER2_GPU_EFUSE, P12V_SLOT_2_3
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(RISER2_GPU_EFUSE)
Impact
Cause
Recommended action
3.     If the issue persists, replace the riser card 2.
Event code
0x0237500e
Message text
Variable fields
$1: RISER1_GPU_EFUSE, P12V_SLOT_0_1
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(RISER1_GPU_EFUSE)
Impact
Cause
·     The EFUSE chip is faulty on the expander module.
·     The P12V_EB_F power supply provided by the expander module for the riser card and GPU is abnormal.
·     Riser card 1 or the GPU P12V power supply is abnormal.
Recommended action
2.     If the server is not powered off, replace the expander module.
3.     If the issue persists, replace Riser card 1.
Event code
0x0237600e
Message text
Transition to Non-recoverable from less severe---System detected a power supply failure($1) ---SW CpldReg 0x30:$2, 0x31:$3
Variable fields
$1: SW
$2: Value of register 0x30 in SW.
$3: Value of register 0x31 in SW.
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(SW) ---SW CpldReg 0x30:0x01, 0x31:0x40
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the switch card.
Event code
0x0237900e
Message text
Variable fields
$1: UART_ERROR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(UART_ERROR)
Impact
Cause
Recommended action
Event code
0x0237c00e
Message text
Variable fields
$1: SWCPLD_ERROR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(SWCPLD_ERROR)
Impact
Cause
Recommended action
Event code
0x0237d00e
Message text
Variable fields
$1: P5V
Severity level
Critical
Example
Impact
Cause
Recommended action
Event code
0x0237a00e
Message text
Variable fields
$1: P12V_STBY
Severity level
Critical
Example
Impact
Cause
Recommended action
2.     If the issue persists, replace the power supply.
Event code
0x0237b00e
Message text
Transition to Non-recoverable from less severe---System detected a failure on the BMC board($1)
Variable fields
$1: BMCCPLD_ERROR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a failure on the BMC board(BMCCPLD_ERROR)
Impact
Cause
Recommended action
Event code
0x0237e00e
Message text
Variable fields
$1: RISER_P12V_PWR
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(RISER_P12V_PWR)
Impact
Cause
Recommended action
3.     If the issue persists, replace the riser card.
Event code
0x0237f00e
Message text
Variable fields
$1: PVCCD_HV_CPU1, PVPP_HBM_CPU1, PVCCFA_EHV_CPU1, PVCCFA_EHV_FIVRA_CPU1, PVCCINFAON_CPU1, PVNN_MAIN_CPU1, PVCCIN_CPU1
Severity level
Critical
Example
Impact
Cause
Recommended action
3.     If the issue persists, replace the CPU1.
Event code
0x0238000e
Message text
Variable fields
$1: PVCCD_HV_CPU2, PVPP_HBM_CPU2, PVCCFA_EHV_CPU2, PVCCFA_EHV_FIVRA_CPU2, PVCCINFAON_CPU2, PVNN_MAIN_CPU2, PVCCIN_CPU2
Severity level
Critical
Example
Impact
Cause
Recommended action
3.     If the issue persists, replace the CPU2.
Event code
0x0238100e
Message text
Variable fields
$1: P12V
Severity level
Critical
Example
Impact
Cause
Recommended action
Event code
0x0238400e
Message text
Variable fields
$1: FAN_P12V, P12V_FAN_VIN_1, P12V_FAN_VIN_2
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(FAN_P12V)
Impact
The system will be powered off immediately.
Cause
Recommended action
2.     If the server is not powered off, replace the fan board.
3.     If the issue persists, replace the power board.
4.     If the issue persists, replace the fan.
Event code
0x0238500e
Message text
Variable fields
$1: USB_HUB_P1V2_STBY
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(USB_HUB_P1V2_STBY)
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the upper and lower USB ports of the BMC card.
3.     If the issue persists, replace the iFIST module.
5.     If the issue persists, replace the internal USB.
Event code
0x0238600e
Message text
Variable fields
$1: DIMM_P12V
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(DIMM_P12V)
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the DIMM.
Event code
0x0238700e
Message text
Variable fields
$1: CPU_P12V
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU_P12V)
Impact
Cause
Recommended action
2.     If the issue persists, replace the CPU.
Event code
0x0238800e
Message text
Variable fields
$1: P12V_BP_REAR_GPU
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_BP_REAR_GPU)
Impact
Cause
Recommended action
2.     If the server is not powered off, replace the power board.
3.     If the issue persists, replace the rear GPU.
Event code
0x0238900e
Message text
Variable fields
$1: CEB_P1V8_STBY, CEB_P5V_STBY, CEB_P1V0_STBY, CEB_P5V
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CEB_P1V8_STBY)
Impact
Cause
Recommended action
3.     If the issue persists, replace the expander module.
Event code
0x0238910e
Message text
Variable fields
$1: TORSwitchModule
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(TORSwitchModule)
Impact
Cause
Recommended action
Event code
0x0238a00e
Message text
Variable fields
$1: CPU1_3V3_STBY, CPU2_3V3_STBY, CPU1_1V8_STBY, CPU2_1V8_STBY, CPU1_VDDCR_SOC_S5, CPU2_VDDCR_SOC_S5, CPU1_VDDIO_DDR_S3_1V1, CPU2_VDDIO_DDR_S3_1V1,
Severity level
Critical
Example
Impact
Cause
Recommended action
Event code
0x0238b00e
Message text
Variable fields
$1: CPU1_3V3_S0, CPU1_1V8_S0, CPU1_VDDH_PHY_1V8, CPU1_VDD_CLDO, CPU1_VDDP_PHY_0V9, CPU1_VDDCR1, CPU1_VDDCR0, CPU1_VDDCR_SOC
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU1_3V3_S0)
Impact
Cause
Recommended action
Event code
0x0238c00e
Message text
Variable fields
$1: CPU2_3V3_S0, CPU2_1V8_S0, CPU2_VDDH_PHY_1V8, CPU2_VDD_CLDO, CPU2_VDDCR1, CPU2_VDDCR0, CPU2_VDDCR_SOC, CPU2_VDDP_PHY_0V9
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(CPU2_3V3_S0)
Impact
Cause
Recommended action
Event code
0x023a500e
Message text
Variable fields
$1: P12V_P2_DIMM_VIN
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_P2_DIMM_VIN)
Impact
Cause
Recommended action
Event code
0x023a600e
Message text
Variable fields
$1: P12V_P1_DIMM_VIN
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_P1_DIMM_VIN)
Impact
Cause
Recommended action
Event code
0x023a700e
Message text
Variable fields
$1: P12V_CPU2_VIN
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_CPU2_VIN)
Impact
Cause
Recommended action
Event code
0x023a800e
Message text
Variable fields
$1: P12V_CPU1_VIN
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_CPU1_VIN)
Impact
Cause
Recommended action
Event code
0x023ad00e
Message text
Variable fields
$1: P12V_SLOT_1_2_3_4, P12V_SLOT_5_6_7_8, P12V_ NIC
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(P12V_SLOT_1_2_3_4)
Impact
Cause
The voltage on the power board is abnormal.
Recommended action
1.     ‍Gently press the physical power button to power off the server. Then, press the physical power button again to power on the server.
Event code
0x023ae00e
Message text
Variable fields
$1: PAL_GPU_MAIN
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(PAL_GPU_MAIN)
Impact
Cause
Recommended action
Event code
0x023b300e
Message text
Variable fields
$1: RAID_RISER
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(RAID_RISER)
Impact
Cause
Recommended action
3.     If the issue persists, replace the RAID riser adapter board.
Event code
0x023b400e
Message text
Variable fields
$1: OCP_RISER
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(OCP_RISER)
Impact
Cause
Recommended action
3.     If the issue persists, replace the OCP riser card.
Event code
0x023b500e
Message text
Variable fields
$1: REDRIVER1_BOARD, REDRIVER2_BOARD
Severity level
Critical
Example
Transition to Non-recoverable from less severe---System detected a power supply failure(REDRIVER1_BOARD)
Impact
Cause
Recommended action
3.     If the issue persists, replace the Redriver board.
Current
Event code
0x0320000e
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Powering off a module affects system operations.
Cause
The current of the corresponding component is abnormal.
Recommended action
1.     ‍Check for any abnormal alarms on the power supply and the system board through the HDM Web alarm page.
2.     Make sure the power supply system is functioning properly and the voltage is stable.
Event code
0x03700002
Message text
Variable fields
$1: Current reading of the current sensor.
$2: Threshold for triggering a minor current notification.
Severity level
Minor
Example
Impact
Performance degradation and unstable operation might occur on the device components if the current is too high.
Cause
Recommended action
1.     ‍Replace the component.
Event code
0x03900002
Message text
Variable fields
$2: Threshold for triggering a major current notification.
Severity level
Major
Example
Impact
Cause
Abnormal board current.
Recommended action
Event code
0x03920002
Message text
Variable fields
Severity level
Major
Example
Exceeded the upper major threshold---Current reading:0.50---Threshold reading:0.20
Impact
Cause
This alarm is triggered when the current reading of the PMIC for the memory exceeds the major alarm threshold.
Recommended action
1.     ‍Replace the DIMM.
Event code
0x03b00002
Message text
Variable fields
$2: Threshold for triggering a critical current notification.
Severity level
Critical
Example
Impact
This could potentially cause component damage, leading to a system crash.
Cause
Recommended action
Fan
Predictive Failure deasserted
Event code
0x04100008
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
The status of the power fan has returned to normal.
Recommended action
No action is required.
Predictive Failure asserted
Event code
0x04000008
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
Predictive failure.
Cause
The state of the power supply fan is abnormal.
Recommended action
1.     ‍If the power supply fan stops due to foreign objects in the power supply, remove the foreign objects.
2.     If the issue persists, Re-install the power supplies,
3.     If the issue persists, replace the faulty power supply.
Transition to Running
Event code
0x04000014
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
The fan is operating correctly.
Recommended action
Transition to Off Line
Event code
0x04400014
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
This affects system heat dissipation and reduces the performance of the system board components.
Cause
The fan module has been unplugged or the fan module and the system board have poor contact.
Recommended action
1.     ‍If the fan has been removed, reinstall the fan as a best practice.
2.     Check if the pins of the fan and system board connector are normal. If an abnormality is present, replace the component. Otherwise, reinsert or reattach the fan to ensure proper contact.
3.     Replace the fan.
Transition to Degraded
Event code
0x04600014
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
The fan speed is abnormal.
Recommended action
1.     ‍Use the HDM Web page to check the fan speed and confirm the cause of the fan failure. If the speed is too low, it may be due to fan aging. If the speed is close to zero, it may be due to the fan being blocked by foreign objects or a fan failure.
2.     Verify that the fan is not blocked.
3.     Replace the fan.
Fully Redundant
Event code
0x04000016
Message text
Fully Redundant
Variable fields
N/A
Severity level
Info
Example
Fully Redundant
Impact
No negative impact.
Cause
All fan slots are equipped with fans.
Recommended action
Non-redundant:Sufficient Resources from Redundant
Event code
0x04300016
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
This issue does not affect system heat dissipation.
Cause
The fan is invalid or is absent.
Recommended action
2.     Reinsert or reattach the fan to ensure proper contact.
3.     If the fan status sensor reports a malfunction, it means that the fan has failed. Replace the fan.
Non-redundant:Insufficient Resources
Event code
0x04500016
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
This affects system heat dissipation, causing the system to overheat and automatically shut down.
Cause
Recommended action
Physical Security
General Chassis Intrusion
Event code
0x050000de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
No negative impact.
Cause
The chassis access panel is removed.
Recommended action
1.     ‍Check if the access panel was removed manually.
2.     Check if the access panel is installed properly. If necessary, open the access panel and then close it to see if the error log is cleared.
3.     Check if the connection between the access-open alarm module and the chassis ear is normal.
LAN Leash Lost
Event code
0x054000de
Message text
LAN Leash Lost
Variable fields
N/A
Severity level
Info
Example
LAN Leash Lost
Impact
No negative impact.
Cause
BMC's NCSI channel detects a physical disconnection in the network.
Recommended action
1.     ‍Check if the network adapter is disabled in the operating system. If it is disabled, no action is required.
2.     If the system reports this log during the power on/off phase, it can be ignored.
3.     Check if the shared network port cable is properly connected.
4.     If the shared network port is not needed, disable it.
Processor
IERR
Event code
0x070000de
Message text
$1 IERR err---Socket $2
Variable fields
$1: Signal type. Options include MSMI and CATERR.
$2: Faulty CPU.
Severity level
Critical
Example
CATERR IERR err---Socket 1
Impact
It can cause system crash. Then, the system will automatically restart by default.
Cause
A CPU internal error was detected. For example, if the Package Control Unit (PCU) encounters an unrecoverable error, this alarm will be triggered.
Recommended action
1.     ‍Upgrade the BIOS and HDM firmware to the up-to-date version.
2.     Process it in conjunction with the specific component event logs reported at the same time as this log.
MCERR
Event code
0x070010de
Message text
$1 MCERR err---Socket $2
Variable fields
$2: Faulty CPU number.
Severity level
Critical
Example
CATERR MCERR err---Socket 1
Impact
Cause
A CPU internal error was detected. For example, if an uncorrectable error occurs on the memory, this alarm will be triggered.
Recommended action
2.     CPU detects internal error and generates this log. Further check hardware information and sensor pages for errors or disabled components based on the description information.
3.     Check for memory, PCIe, and UPI failures using the contextual logs, and perform troubleshooting steps based on the corresponding recommended actions.
Thermal Trip
Event code
0x071000de
Message text
Thermal Trip
Variable fields
N/A
Severity level
Critical
Example
Thermal Trip
Impact
It can cause host power-off.
Cause
When the CPU overheats, this event is triggered, which may result in shutdown and poweroff.
Recommended action
1.     ‍Log in to HDM, and verify that the fan is in normal state.
2.     Re-install or replace the fan module with a speed alarm.
3.     Identify whether the ambient temperature is too high. Keep the server operating within its normal temperature range.
4.     Check for any blockages at the air inlet/outlet and remove any obstructions.
5.     Power off the server, check for poor contact of the CPU heatsink, reapply the thermal grease, reinstall the heatsink, and power on the server again.
6.     For a liquid-cooled server model, identify whether liquid-cooled component-related alarms have occurred.
7.     If the issue persists, contact Technical Support.
FRB1/BIST failure
Event code
0x072000de
Message text
FRB1/BIST failure.
Variable fields
N/A
Severity level
Minor
Example
FRB1/BIST failure
Impact
The operating system might fail to start up and hardware downsizing applies.
Cause
This alarm is generated when the CPU self-check detects an error during system startup.
Recommended action
1.     ‍Power cycle the device.
FRB2/Hang in POST failure
Event code
0x073000de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
The operating system might fail to start up.
Cause
The BIOS startup timed out.
Recommended action
1.     ‍Upgrade the BIOS.
FRB3/Processor Startup/Initialization failure
Event code
0x074000de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
Recommended action
Configuration Error
Event code
0x075000de
Message text
Configuration Error---$1, ErrorType: $2,Severity: $3, Component: $4, IIO Stack: $5, Location: Socket: $6 or Configuration Error--- ErrorType: $2,Severity: $3, Failed Core: $7, Location: Socket: $6
Variable fields
$1: Time at which the error occurred. It can beCurrent Boot Error or Last Boot Error.
$2: Fault type. It can be IIO Internal Error or Spare core Error.
$3: Fault severity.
$4: Faulty component.
$5: I/O number.
$6: CPU number.
$7: core number.
Severity level
Minor
Example
Configuration Error---Current Boot Error, ErrorType: IIO Internal Error,Severity:Correctable, Component:VTD, IIO Stack: 1, Location: Socket: 1
Impact
Cause
The main system CPU detected internal correctable error information during operation.
Recommended action
This log is generated when correctable internal errors are detected during server operation, such as IIO internal errors or CPU core errors. No action is required for correctable internal errors.
Processor Presence detected
Event code
0x077000df
Message text
Variable fields
N/A
Severity level
Info/Critical
Example
Impact
If the primary CPU is not in place, it may result in system startup failure.
Cause
This event log is triggered when the primary CPU is not in place or installed incorrectly.
Recommended action
1.     ‍Verify that the primary CPU is installed correctly.
2.     If the primary CPU fails, replace the CPU.
Processor Automatically Throttled
Event code
0x07a000de
Message text
Processor Automatically Throttled---$1
Variable fields
$1: CPU throttling reasons, possible values include: due to sensor reading exceeds the threshold, due to insufficient fan redundancy, due to sensor reading exceeds the threshold and insufficient fan redundancy.
Severity level
Minor
Example
Processor Automatically Throttled---due to sensor reading exceeds the threshold
Impact
System performance decreases due to CPU throttling.
Cause
The CPU throttles due to fan failure.
Recommended action
1.     ‍Verify that the fan speed mode matches the current service model.
2.     Identify whether the ambient temperature is too high or whether air inlet and air outlet are blocked.
3.     Identify whether the fan is blocked by any foreign objects or whether the fan is faulty.
4.     Identify the fan status. If the fan is faulty, replace the faulty fan.
Event code
0x07a010de
Message text
Processor Automatically Throttled---prochot
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
CPU throttling might occur due to CPU overheating.
Recommended action
Event code
0x07a020de
Message text
Processor Automatically Throttled---memhot
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
CPU throttling may occur due to memory overheating.
Recommended action
5.     For a liquid-cooled server model, identify whether liquid-cooled component-related alarms have occurred.
Machine Check Exception
Event code
0x07b000de
Message text
Machine Check Exception---$1---$2---Location: Socket:$3
Variable fields
$1: Fault type.
$2: Specifies if the error occurred during the current boot or the previous boot.
$3: Faulty CPU.
Severity level
Critical
Example
Machine Check Exception---PIE---Last Boot Error---Location: Socket:1
Impact
The system might stop responding.
Cause
Only in AMD models, when the CPU generates an uncorrectable error, this event will be triggered.
Recommended action
1.     ‍Check if any corresponding faults exist in the operating system.
2.     Check the CPU microcode to identify whether to upgrade the microcode.
3.     Upgrade the BIOS and BMC to the latest versions.
Event code
0x07b050de
Message text
Explanation
An uncorrectable error occurred on a CPU.
$1: Uncorrectable error type, including fatal and non-fatal.
$2: CPU error type, including Cache Error, TLB Error, Bus Error, and Micro-architectural Error.
$3: CPU number.
Severity
Critical
Example
Machine Check Exception---fatal---Cache Error---Location: Socket:1
System impact
It might cause the system to stop responding.
Possible reasons
This event is generated when an uncorrectable error occurs on a CPU.
Recommended action
1.     ‍Check if a corresponding fault exists in the OS, and resolve the software issues.
2.     Check the CPU microcode and evaluate whether to upgrade the microcode.
3.     Update the BIOS and HDM to the latest version.
Triggered a uncorrectable error
Event code
0x07b201de
Message text
CPU $1 triggered a uncorrectable error.
Variable fields
$1: CPU number.
Severity level
Critical
Example
CPU 1 triggered a uncorrectable error.
Impact
Cause
Triggering IERR or MCERR errors, the diagnosis result of HDM is CPU uncorrectable error.
Recommended action
2.     Safely power off the server and replace the CPU to identify whether the alarm disappears.
3.     If the issue persists, contact Technical Support.
Event code
0x07b100de
Message text
Machine Check Exception---HBM error---Location: Socket:$1
Variable fields
$1: CPU number.
Severity level
Critical
Example
Machine Check Exception---HBM error---Location: Socket:1
Impact
Cause
HBM failed.
Recommended action
1.     ‍Check if there are any corresponding faults in the operating system.
2.     Check the CPU microcode and upgrade the BIOS and BMC to the latest versions.
3.     Safely power off the server and replace the CPU to identify whether the alarm disappears.
Event code
0x07b001de
Message text
Machine Check Exception---$1, Bank: $2,Severity:$3, Error Info:$4, Location: Socket: $5
Variable fields
$1: Specifies if the error occurred during the current boot or the previous boot.
$2: Fault bank.
$3: Fault severity.
$4: Fault information.
$5: CPU number.
Severity level
Critical
Example
Machine Check Exception---Current Boot Error, Bank: IFU,Severity:FATAL, Error Info:Cache, Location: Socket: 1
Impact
Cause
This event occurs when there is an internal fault in the CPU.
Recommended action
1.     ‍Check if there are any corresponding faults present in the operating system.
2.     Check the CPU microcode and upgrade the BIOS and HDM to the latest versions.
3.     If the issue persists, preliminarily determine the range of the fault based on the bank location and check if any other warning logs have been generated.
4.     Power off the server safely and replace the CPU or peripheral with a known working one to see if the warning disappears.
5.     Replace the system board.
Triggered a correctable error
Event code
0x07c201de
Message text
CPU $1 triggered a correctable error.
Variable fields
$1: CPU number.
Severity level
Minor
Example
CPU 1 triggered a correctable error.
Impact
No negative impact.
Cause
Triggering IERR or MCERR errors, the diagnosis result of HDM is CPU correctable error.
Recommended action
Correctable Machine Check Error
Event code
0x07c000de
Message text
Correctable Machine Check Error---$1---$2---Location: Socket:$3
Variable fields
$1: Fault type.
$3: Faulty CPU.
Severity level
Minor
Example
Correctable Machine Check Error---PIE---Current Boot Error---Location: Socket:1
Impact
No negative impact.
Cause
This alarm is generated only in AMD models when correctable errors such as TWIX, WAFL, or SMU occur.
Recommended action
Event code
0x07c050de
Message text
Correctable Machine Check Error---$1---Location: Socket:$2
Explanation
A correctable error occurred on a CPU.
$1: CPU error type, including Cache Error, TLB Error, Bus Error, and Micro-architectural Error.
$2: CPU number.
Severity
Minor
Example
Correctable Machine Check Error---Cache Error---Location: Socket:1
System impact
No negative impact on the system.
Possible reasons
This event is generated when a correctable error occurs on a CPU.
Recommended action
Event code
0x07c100de
Message text
Correctable Machine Check Error---HBM error---Location: Socket:$1
Variable fields
$1: CPU number.
Severity level
Minor
Example
Correctable Machine Check Error---HBM error---Location: Socket:1
Impact
No negative impact.
Cause
An correctable error was detected on HBM.
Recommended action
Event code
0x07c001de
Message text
Correctable Machine Check Error---$1, Bank: $2,Severity:$3, Error Info:$4, Location: Socket: $5
Variable fields
$2: Fault bank.
$3: Fault severity.
$5: CPU number.
Severity level
Minor
Example
Correctable Machine Check Error---Current Boot Error, Bank: IFU,Severity:Corrected, Error Info:Cache, Location: Socket: 1
Impact
No negative impact.
Cause
An internal correctable error occurred in the CPU.
Recommended action
CPU OEM ERR1
Event code
0x07d000de
Message text
CPU OEM ERR1---$1 Fault---Socket:$2
Variable fields
$1: Error type.
$2: Socket number of the CPU that generated the error.
Severity level
Major
Example
CPU OEM ERR1---SMN Fault---Socket:1
Impact
Cause
A severe alarm is present on a CPU in an AMD server.
Recommended action
1.     ‍Restart the server.
2.     Safely power off the server, and replace the faulty CPU with a well-functioning CPU.
Power Supply
Presence detected
Event code
0x080000de
Message text
Presence detected
Variable fields
N/A
Severity level
Info
Example
Presence detected
Impact
No negative impact.
Cause
When the power supply is detected as being inserted, this event is triggered, indicating a transition from the power supply not being in place to being in place.
When the power supply is detected as being removed, this event is cleared, indicating a transition from the power supply being in place to not being in place.
Recommended action
If the power supply is removed, install the power supply again.
Power Supply Failure detected
Event code
0x081000de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
It affects system power supply and may result in abnormal system power-off.
Cause
A power supply fault was detected.
Recommended action
1.     ‍Re-install the power supply.
Power Supply Predictive Failure
Event code
0x082000de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
The power supply may have malfunctions that affect system power supply.
Cause
Recommended action
1.     ‍Identify whether any foreign objects have obstructed and stop the power supply fan. If yes, remove the foreign objects.
2.     If the issue persists, re-install the power supply.
3.     If the issue persists, replace the power supply.
Power Supply input lost (AC/DC)
Event code
0x083000de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
It may cause the server to power off abnormally.
Cause
The AC power cable of the power supply is unplugged or there is an abnormal AC input.
Recommended action
1.     ‍Verify that the power input is normal.
2.     Verify that all power cables are undamaged and properly connected.
3.     Verify that all power supplies are correctly installed.
Power Supply input lost or out-of-range
Event code
0x084000de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
This may cause the server to power off abnormally.
Cause
The input voltage of the power supply exceeded the rated range.
Recommended action
Power Supply input out-of-range - but present
Event code
0x085000de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Abnormal power input beyond the supported range may cause the server to power off.
Cause
The input voltage of the power supply is too high.
Recommended action
1.     ‍Check if the input voltage of the power supply is normal.
2.     Verify that the power cables and power supplies are installed correctly.
3.     Unplug and re-plug the power supply to ensure a good power connection.
4.     Check if the fans of the power supply are spinning.
5.     If the issue persists, contact Technical Support.
Configuration error ---Vendor mismatch
Event code
0x086000de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
An unknown risk exists due to non-original certified components.
Cause
Non-original certified power supplies are installed.
Recommended action
Install original certified power supplies.
Configuration error---Power Supply rating mismatch
Event code
0x086030de
Message text
Configuration error --- Power Supply rating mismatch
Variable fields
N/A
Severity level
Minor
Example
Impact
This may result in unstable power supply and abnormal system shutdown.
Cause
Original certified power supplies are installed, but the models of the two power supplies do not match.
Recommended action
1.     ‍Make sure all the power supplies are of the same model.
2.     If the issue persists, contact Technical Support.
Configuration error---Power supply rating mismatch
Event code
0x086200de
Message text
Configuration error---Power supply rating mismatch:PSU$1,POUT:$2W
Variable fields
$1: PSU ID, which can be 1 or 2.
$2: Output power of the power supply.
Severity level
Minor
Example
Configuration error---Power supply rating mismatch:PSU1,POUT:2000W
Impact
Cause
The rated power of the installed power supplies may be inconsistent.
Recommended action
Power Supply Inactive/standby state
Event code
0x087000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
The power supply exits cold standby mode. When the function of standby power supply is enabled, if the current device is running at a high power, the standby power supply will automatically exit cold backup mode and provide power to the device.
Recommended action
PSU failure detected by CPLD
Event code
0x088000de
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
Cause
The server has experienced an AC power failure.
Recommended action
1.     ‍Check for environmental issues such as high temperature or abnormal power supply fan.
2.     Replug the power supply and check if the alarm disappears.
Redundancy Lost
Event code
0x08100016
Message text
Redundancy Lost
Variable fields
N/A
Severity level
Major
Example
Redundancy Lost
Impact
Power redundancy failure reduces the reliability of device power supply.
Cause
Power redundancy got lost.
Recommended action
1.     ‍Check if the power supply environment is normal.
2.     Check if any power supply has been removed.
3.     Check for poor contact between power supplies and power cables.
4.     Check for power-related fault alarm logs to determine if it is a power failure.
Power Unit
Power limit is exceeded over correction time limit
Event code
0x095010de
Message text
Power limit is exceeded over correction time limit---$1 Current Power: $2W.
Variable fields
$1: GPU/Not available for chassis power consumption
$2: Current power value.
Severity level
Minor
Example
GPU: Power limit is exceeded over correction time limit---GPU Current Power: 2000W
Chassis: Power limit is exceeded over correction time limit---Current Power: 2000W
Impact
Power capping failed and the corresponding policy will be executed.
Cause
Power capping triggers this alarm after a certain amount of time elapsed when the power output exceeds the limit.
Recommended action
1.     ‍Adjust the power capping threshold or adjust the GPU workload.
Cooling Device
Transition to OK
Event code
0x0a00000e
Message text
Transition to OK
Variable fields
N/A
Severity level
Info
Example
Transition to OK
Impact
No negative impact.
Cause
The liquid-cooled module is in place and free of faults.
Recommended action
Transition to Non-recoverable---Liquid leakage occurred
Event code
0x0a60000e
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
For the server model that supports only processor liquid-cooled module, processor heal dissipation is affected. For the server model that supports processor liquid-cooled module and GPU liquid-cooled module, processor or GPU heat dissipation is affected.
Cause
This message is generated when liquid leakage occurs.
Recommended action
1.     ‍Check if the liquid cooling device is functioning properly or if there is any liquid leakage.
2.     Replace the liquid-cooled module.
Event code
0x0a30000e
Message text
Transition to Non-recoverable from less severe--- Liquid Cooler not present
Variable fields
N/A
Severity level
Minor
Example
Impact
Heat dissipation of the components in the liquid-cooled device on which the alarm is present is affected.
Cause
In a server that supports multiple liquid-cooled devices, one liquid-cooled device is not present (or the corresponding liquid leakage detection cable is not plugged in).
Recommended action
1.     ‍Examine if the liquid leakage detection cable of the liquid-cooled device is loose. If it is loose, remove the AC power and reconnect the liquid leakage detection cable.
Transition to Non-Critical from OK--- Liquid leakage detection cable is disconnected
Event code
0x0a10000e
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Unable to detect coolant leakage.
Cause
Liquid leakage sensor cannot be detected.
Recommended action
1.     ‍Check if the liquid cooling device is present.
2.     Check if the liquid leakage sensor is installed correctly.
3.     Replace the liquid-cooled module.
Other Units-based Sensor
Exceeded the upper minor threshold
Event code
0x0b700002
Message text
Exceeded the upper minor threshold---Current reading:$1---Threshold reading:$2
Variable fields
$1: Current power value.
$2: Threshold for triggering a minor power notification.
Severity level
Minor
Example
Exceeded the upper minor threshold---Current reading:20---Threshold reading:18
Impact
Exceeding the maximum power limit will cause the system to shut down.
Cause
The power exceeds the limit.
Recommended action
1.     ‍Log in to HDM, and verify that the threshold value is appropriate.
2.     Check if the total power consumption of the server is too high through the HDM web page.
3.     Check if the total power consumption of the power supply meets the service requirements.
4.     If the issue persists, contact Technical Support.
Memory
Correctable ECC or other correctable memory error
Event code
0x0c0000de
Message text
Correctable ECC or other correctable memory error--$1-Location:CPU:$2 CH:$3 DIMM:$4 $5
Variable fields
$1: Time at which the error occurred, Current Boot Error or Last Boot Error.
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Minor
Example
Correctable ECC or other correctable memory error---Current Boot Error-Location:CPU:1 CH:1 DIMM:0 A1
Impact
No negative impact.
Cause
Correctable memory errors.
Recommended action
Event code
0x0c0020de
Message text
Correctable ECC or other correctable memory error---$1---Location:CPU:$2 CH:$3 DIMM:$4 $5
Variable fields
$1: Fault type, which can be ECC, Parity, CRC, or Other
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Minor
Example
Correctable ECC or other correctable memory error---CRC---Location:CPU:1 CH:1 DIMM:0 A0
Impact
No negative impact.
Cause
A correctable error occurred on the memory.
Recommended action
Event code
0x0c0050de
Message text
Explanation
A correctable error occurs on memory.
$1: Memory error type, including Unknown, No error, Single-bit ECC, Multi-bit ECC, Single-symbol ChipKill ECC, Multi-symbol ChipKill ECC, Master abort, Target abort, Watchdog timeout, Invalid address, Mirror Broken, Memory Sparing, and Physical Memory Map-out event.
$2: CPU number.
$3: Channel number.
$4: Memory number.
Severity
Minor
Example
Correctable ECC or other correctable memory error---Unknown---Location:CPU:1 CH:1 DIMM:0
System impact
Possible reasons
Recommended action
Event code
0x0c0600de
Message text
Correctable ECC or other correctable memory error---$1---$2---Location:CPU$3 CH:$4 DIMM:$5 $6
Variable fields
$1: Fault type, which can be ECC, Parity, or CRC.
$2: Specifies if the error occurred during the current boot or the previous boot. It can be Current Boot Error or Last Boot Error.
$3: CPU number.
$4: Channel number.
$5: DIMM number.
$6: DIMM mark.
Severity level
Minor
Example
Correctable ECC or other correctable memory error---ECC---Current Boot Error---Location:CPU1 CH:8 DIMM:0 A0
Impact
No negative impact.
Cause
Recommended action
CPU triggered a correctable error
Event code
0x0c0500de
Message text
CPU $1 $2 triggered a correctable error
Variable fields
$1: CPU number.
$2: DIMM mark.
Severity level
Minor
Example
CPU 1 A0 triggered a correctable error
Impact
No negative impact.
Cause
Triggering IERR or MCERR errors, the HDM diagnostic result shows correctable errors in memory.
Recommended action
Event code
0x0c0c00de
Message text
Variable fields
$1: ADDDC type.
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Minor
Example
Correctable ECC or other correctable memory error---ECC---Memory ADDDC Bank VIS---Location:CPU:1 CH:1 DIMM:0 A0
Impact
No negative impact.
Cause
Recommended action
1.     ‍A correctable memory error occurred but the system can still operate normally.
2.     No action is required.
Uncorrectable ECC or other uncorrectable memory error
Event code
0x0c1000de
Message text
Uncorrectable ECC or other uncorrectable memory error--$1-Location:CPU:$2 CH:$3 DIMM:$4 $5
Variable fields
$1: Specifies if the error occurred during the current boot or the previous boot. It can be Current Boot Error or Last Boot Error.
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Major
Example
Uncorrectable ECC or other uncorrectable memory error---Current Boot Error-Location:CPU:1 MEM CTRL:1 CH:1 DIMM:0 A1
Impact
It can cause the system to stop sending responses, unless the memory is in certain RAS modes, such as mirror or MCA recovery.
Cause
A non-correctable (multiple bit flip) ECC error has occurred.
Recommended action
1.     ‍Verify that the temperature and humidity are appropriate.
2.     Clean the memory slots and memory contacts, ensuring that there are no foreign objects in the memory slots and the contacts are not contaminated. Then, reinstall the corresponding DIMM.
3.     Replace the DIMM.
Event code
0x0c1020de
Message text
Variable fields
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Major
Example
Uncorrectable ECC or other uncorrectable memory error---Current Boot Error-Location:CPU:1 MEM CTRL:1 CH:1 DIMM:0 A0
Impact
It can cause the system to stop sending responses.
Cause
An uncorrectable (multiple bit flip) ECC error has occurred.
Recommended action
Event code
0x0c1050de
Message text
Uncorrectable ECC or other uncorrectable memory error---$1---$2---Location:CPU:$3 CH:$4 DIMM:$5
Variable fields
$2: Memory error type, including Unknown, No error, Single-bit ECC, Multi-bit ECC, Single-symbol ChipKill ECC, Multi-symbol ChipKill ECC, Master abort, Target abort, Watchdog timeout, Invalid address, Mirror Broken, Memory Sparing, and Physical Memory Map-out event.
$3: CPU number.
$4: Channel number.
$5: Memory number.
Severity level
Major
Example
Uncorrectable ECC or other uncorrectable memory error---fatal---Single-bit ECC---Location: CPU:1 CH:1 DIMM:0
Impact
Cause
This message is generated when an uncorrectable error occurs on memory.
Recommended action
1.     ‍Verify that the ambient temperature or humidity is within the normal range.
2.     Clean the slot and the gold contacts of the memory module. Make sure no foreign objects exist in the slots and the contacts are not contaminated. Then, reinstall the corresponding memory module.
3.     If the issue persists, replace the memory module.
Event code
0x0c1600de
Message text
Uncorrectable ECC or other uncorrectable memory error---$1---$2---Location:CPU$3 CH:$4 DIMM:$5 $6
Variable fields
$2: Startup time upon error occurrence. It can be Current Boot Error or Last Boot Error.
$3: CPU number.
$4: Channel number.
$5: DIMM number.
$6: DIMM mark.
Severity level
Major
Example
Uncorrectable ECC or other uncorrectable memory error---ECC---Last Boot Error---Location:CPU1 CH:8 DIMM:0 A0
Impact
The system might restart or stop responding.
Cause
Uncorrectable ECC or other uncorrectable errors occur.
Recommended action
3.     If the issue persists, replace the DIMM.
Triggered an uncorrectable error
Event code
0x0c1500de
Message text
CPU$1 $2 triggered an uncorrectable error
Variable fields
$1: CPU number.
$2: DIMM mark.
Severity level
Major
Example
CPU1 A0 triggered an uncorrectable error
Impact
Cause
Triggering IERR or MCERR errors, the HDM diagnostic result shows uncorrectable errors in memory.
Recommended action
Parity
Event code
0x0c2000de
Message text
Parity ---$1---Location: Location:CPU:$2 CH:$3 DIMM:$4 $5
Variable fields
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Minor
Example
Parity---Current Boot Error-Location:CPU:1 CH:1 DIMM:0 A0
Impact
No negative impact.
Cause
This error message is generated when there is a failure in data parity on the command/address lines while reading the memory cell data, resulting in abnormal data access to the memory.
Recommended action
Parity
Event code
0x0c2020de
Message text
Parity---Location:CPU:$1 CH:$2 DIMM:$3 $4
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
Severity level
Minor
Example
Parity---Location:CPU:1 CH:1 DIMM:0 A0
Impact
No negative impact.
Cause
This message is generated when there is a failure in data parity on the command/address lines while reading the memory cell data, resulting in abnormal data access to the memory. The SEL records the command/address parity error and logs the accessed DIMM.
Recommended action
Parity
Event code
0x0c2050de
Message text
Parity---Location: CPU:$1 CH:$2 DIMM:$3
Explanation
Memory data parity check fails.
Variable fields
$1: CPU number.
$2: Channel number.
$3: Memory number.
Severity
Minor
Example
Parity---Location: CPU:1 CH:1 DIMM:0
Impact
Cause
Data parity check fails when the system reads memory unit data, causing memory data access error. The SEL log records the command/address parity check error and records the target DIMM.
Recommended action
Parity---An uncorrectable error occurs during the memory test phase
Event code
0x0c20b1c4
Message text
Parity---An uncorrectable error occurs during the memory test phase---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---An uncorrectable error occurs during the memory test phase---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
System performance degradation might occur.
Cause
An UCE occurred in the memtest phase.
Recommended action
Parity---The memory interleaving configuration cannot meet the requirements of the server
Event code
0x0c20e014
Message text
Parity---The memory interleaving configuration cannot meet the requirements of the server---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---The memory interleaving configuration cannot meet the requirements of the server---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Configuration error. Memory interleave configuration does not meet the requirements of the server.
Recommended action
Contact Technical Support.
Event code
0x0c20e024
Message text
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Impact
Cause
Recommended action
Event code
0x0c20e0e4
Message text
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Impact
System performance degradation or system startup failure might occur.
Cause
Recommended action
Parity---CMD eye width is too small
Event code
0x0c226014
Message text
Parity---CMD eye width is too small---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---CMD eye width is too small---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Memory parity error. CMD eye width is too small.
Recommended action
1.     ‍Confirm the memory slot according to the alarm information.
2.     Check if there are foreign objects on the memory gold finger and memory slot and clean them.
Parity---CmdPiGroup: No Eye width
Event code
0x0c226024
Message text
Parity---CmdPiGroup: No Eye width---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---CmdPiGroup: No Eye width---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
CMD eye width does not exist.
Recommended action
Parity---The command is not in the FNv table
Event code
0x0c228004
Message text
Parity---The command is not in the FNv table---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---The command is not in the FNv table---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
The command sent is not in the FNv table.
Recommended action
Parity---Memory read DqDqs training failed
Event code
0x0c231134
Message text
Parity---Memory read DqDqs training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Memory read DqDqs training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Memory read Dq or Dqs training failed.
Recommended action
Parity---Memory Receive Enable Training Error
Event code
0x0c231144
Message text
Parity---Memory receive enable training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Memory receive enable training failed---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Memory Faulty Parts Tracking failure. The Receive Enable signal of the memory fails to train to the corresponding timing.
Recommended action
Parity---Memory write DqDqs training failed
Event code
0x0c231164
Message text
Parity---Memory write DqDqs training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Memory write DqDqs training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Recommended action
Parity---An error occurs during memory test, and the rank is disabled
Event code
0x0c2311c4
Message text
Parity---An error occurs during memory test, and the rank is disabled---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---An error occurs during memory test, and the rank is disabled---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
An error occurred during memory testing, and that rank has been disabled.
Recommended action
Parity---LRDIMM RCVEN training failed
Event code
0x0c231264
Message text
Parity---LRDIMM RCVEN training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$4: Rank number.
Severity level
Minor
Example
Parity---LRDIMM RCVEN training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
LRDIMM RCVEN training failed.
Recommended action
Parity---Read delay training failed
Event code
0x0c231284
Message text
Parity---Read delay training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Read delay training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Read delay training has failed.
Recommended action
Parity---Write delay training failed
Event code
0x0c2312b4
Message text
Parity---Write delay training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Write delay training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Write delay training failed.
Recommended action
Parity---Mapped out because failed critical mask test at cold boot
Event code
0x0c28c024
Message text
Parity---Mapped out because failed critical mask test at cold boot---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Mapped out because failed critical mask test at cold boot---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
The DIMM failed in key mask test and mapped out as a failed area during cold boot.
Recommended action
Parity---Invalid SPD contents
Event code
0x0c2ed094
Message text
Parity---Invalid SPD contents---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Invalid SPD contents---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Invalid SPD content.
Recommended action
Parity---The DCPMM memory modules of the unexpected model are installed
Event code
0x0c2ed0c4
Message text
Parity---The DCPMM memory modules of the unexpected model are installed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---The DCPMM memory modules of the unexpected model are installed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Unsupported CDPMMs are inserted.
Recommended action
1.     ‍Based on the alarm type, confirm the specifications of the DCPMM and replace the DCPMM memory.
Parity---Delay exceeded
Event code
0x0c214024
Message text
Parity---Delay exceeded---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Delay exceeded---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The program execution timed out.
Recommended action
Parity---Timing error occurred during signal line adjustment for memory write leveling training
Event code
0x0c215014
Message text
Parity---Timing error occurred during signal line adjustment for memory write leveling training---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---Timing error occurred during signal line adjustment for memory write leveling training---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Timing abnormality occurs to write leveling adjustment signal line.
Recommended action
Parity---CS is not consistent with clock in timing, and the channel is isolated
Event code
0x0c229044
Message text
Parity---CS is not consistent with clock in timing, and the channel is isolated---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---CS is not consistent with clock in timing, and the channel is isolated---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
A timing mismatch occurred between CS and clock.
Recommended action
Parity---CA is not consistent with clock in timing, and the channel is isolated
Event code
0x0c229054
Message text
Parity---CA is not consistent with clock in timing, and the channel is isolated---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---CA is not consistent with clock in timing, and the channel is isolated---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
A timing mismatch might occur between CA and clock.
Recommended action
Parity---LRDIMM external coarse training failed
Event code
0x0c231204
Message text
Parity---LRDIMM external coarse training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---LRDIMM external coarse training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
LRDIMM external fine training failed.
Recommended action
Parity---LRDIMM external fine training failed
Event code
0x0c231214
Message text
Parity---LRDIMM external fine training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---LRDIMM external fine training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Recommended action
Parity---LRDIMM internal coarse training failed
Event code
0x0c231224
Message text
Parity---LRDIMM internal coarse training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---LRDIMM internal coarse training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
LRDIMM internal coarse training failed.
Recommended action
Parity---LRDIMM internal fine training failed
Event code
0x0c231234
Message text
Parity---LRDIMM internal fine training failed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Parity---LRDIMM internal fine training failed---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
LRDIMM internal fine training failed.
Recommended action
Memory Device Disabled
Event code
0x0c4000de
Message text
Memory Device Disabled--$1---Location:CPU:$2 CH:$3 DIMM:$4 $5
Variable fields
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Major
Example
Memory Device Disabled---Current Boot Error---Location:CPU:1 CH:1 DIMM:0 A1
Impact
The DIMM is disabled. System performance degradation might occur.
Cause
A memory fault is detected during the system startup process.
Recommended action
2.     If multiple DIMMs in the channels for a CPU are disabled at the same time except the DIMMs disabled due to POR rules, insert the CPU to another slot. If the issue occurs on this CPU again, replace this CPU.
3.     If the multiple DIMMs are disabled for two CPUs at the same time except the DIMMs disabled due to POR rules, replace the system board.
Memory Device Disabled---The Rank is disabled
Event code
0x0c40a034
Message text
Memory Device Disabled---The rank is disabled---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Major
Example
Memory Device Disabled---The rank is disabled---Location:CPU:2 CH:1 DIMM:0 A0 Rank:1
Impact
System performance degradation might occur. This does not affect normal use of the system.
Cause
One rank of the memory is disabled, but it does not affect the use of the remaining ranks.
Recommended action
Memory Device Disabled---The DIMM is disabled
Event code
0x0c40a044
Message text
Memory Device Disabled---The DIMM is disabled---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Major
Example
Memory Device Disabled---The DIMM is disabled---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Recommended action
Event code
0x0c4020de
Message text
Memory Device Disabled---Location:CPU:$1 CH:$2 DIMM:$3 $4
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
Severity level
Major
Example
Memory Device Disabled ---Location:CPU:1 CH:1 DIMM:0 A0
Impact
Cause
Recommended action
2.     If multiple DIMMs in the channels for a CPU are disabled at the same time, insert the CPU to another slot. If the issue occurs on this CPU again, replace this CPU.
3.     If the multiple DIMMs are disabled for two CPUs at the same time, replace the system board.
Memory Device Disabled---The DIMM is disabled because of inconsistency with POR restrictions
Event code
0x0c417504
Message text
Memory Device Disabled---The DIMM is disabled because of inconsistency with POR restrictions---Location:CPU:$1 CH:$2 DIMM:$3
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM mark.
Severity level
Major
Example
Memory Device Disabled--- The DIMM is disabled because of inconsistency with POR restrictions---Location:CPU:1 CH:1 DIMM: A0
Impact
The system performance might degrade.
Cause
The DIMM is disabled due to incorrect DIMM installation.
Recommended action
1.     ‍Re-install DIMMs based on the DIMM population guidelines in the user guide for the server.
Memory Device Disabled---Buck Regulator Output Over or Under Voltage Lockout
Event code
0x0c446fb4
Message text
Memory Device Disabled---Buck Regulator Output Over or Under Voltage Lockout---Location:CPU:$1 CH:$2 DIMM:$3 $4
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
Severity level
Major
Example
Memory Device Disabled---Buck Regulator Output Over or Under Voltage Lockout---Location:CPU:1 CH:3 DIMM:0 C0
Impact
Cause
A memory fault is detected.
Recommended action
Correctable ECC or other correctable memory error logging limit reached
Event code
0x0c5000de
Message text
Correctable ECC or other correctable memory error logging limit reached--$1---Location:CPU:$2 CH:$3 DIMM:$4 $5 $6
Variable fields
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
$6: Description, ---Predictive Failure assert, which is not displayed when the CE limit is normally reported.
Severity level
Minor
Example
Correctable ECC or other correctable memory error logging limit reached---Current Boot Error---Location:CPU:1 CH:1 DIMM:0 A1---Predictive Failure assert
Impact
Cause
The memory may not be installed correctly or there could be an internal memory failure. The correctable errors in the memory have reached the set threshold, and when the corresponding Memory RAS mode is enabled, the corresponding RAS features will be executed without causing a system crash. Even in the memory repair mode, the errors still exceed the threshold.
Recommended action
1.     ‍Reinstall the corresponding DIMM to ensure correct installation, clean the gold fingers, make sure no foreign objects exist in the memory slot, and that the temperature and humidity in the environment are normal.
2.     Check the memory funnel threshold in the BIOS. If it is too low, adjust the funnel threshold value in the BIOS.
Correctable ECC or other memory error limit reached
Event code
0x0c5020de
Message text
Correctable ECC or other correctable memory error logging limit reached---$1 $2:$3---Location:CPU:$4 CH:$5 DIMM:$6 $7 $8
Variable fields
$1: MCA/UMC(Available in case of CE Count Overflow)
$2: CE Count Overflow/Memory CE Storm Threshold/Memory CE Accumulation Threshold
$3: Threshold.
$4: CPU number.
$5: Channel number.
$6: DIMM number.
$7: DIMM mark.
$8: Description, ---Predictive Failure assert, which is not displayed when the CE limit is normally reported.
Severity level
Minor
Example
Correctable ECC or other correctable memory error logging limit reached---MCA CE Count Overflow:8769---Location:CPU:1 CH:5 DIMM:0 A0---Predictive Failure assert
Impact
Cause
The memory may not be installed correctly or there could be an internal memory failure. The correctable errors in the memory have reached the set threshold and will not cause a system crash. Even in the memory repair mode, the errors still exceed the threshold.
Recommended action
1.     ‍Reinstall the corresponding DIMM. Make sure it is installed correctly, the gold contacts are not contaminated, no foreign objects exist in the memory slot, and the environmental temperature and humidity are normal.
2.     Check whether the memory funnel threshold in the BIOS is too low. If so, adjust the funnel threshold value in the BIOS.
Presence detected
Event code
0x0c6000de
Message text
Presence detected
Variable fields
N/A
Severity level
Info
Example
Presence detected
Impact
No negative impact.
Cause
A DIMM is detected present.
Recommended action
Memory patrol scrub CE occurred
Event code
0x0c3010de
Message text
Memory patrol scrub CE occurred---$1---Location: Location:CPU:$2 CH:$3 DIMM:$4 $5
Variable fields
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Minor
Example
Memory patrol scrub CE occurred---Current Boot Error---Location:CPU:1 CH:1 DIMM:0 A0
Impact
Check failed for reading memory data. No negative impact.
Cause
CE Inspection.
This error message indicates that there was a data parity error during the read operation of a memory cell. The error occurred on the command/address lines, resulting in abnormal data retrieval from the memory. The error is recorded in the SEL, along with the DIMM that was accessed during the error.
Recommended action
Memory patrol scrub UCE occurred and degraded to CE
Event code
0x0c3020de
Message text
Memory patrol scrub UCE occurred and degraded to CE---$1---Location: Location:CPU:$2 CH:$3 DIMM:$4 $5
Variable fields
$2: CPU number.
$3: Channel number.
$4: DIMM number.
$5: DIMM mark.
Severity level
Minor
Example
Memory patrol scrub UCE occurred and degraded to CE---Current Boot Error---Location:CPU:1 CH:1 DIMM:0 A0
Impact
Cause
UCE Inspection: Degraded CE.
Recommended action
Memory patrol scrub CE occured
Event code
0x0c3050de
Message text
Memory scrub Failed---$1---Location: CPU:$2 CH:$3 DIMM:$4
Explanation
A correctable error detected during memory patrol.
Variable fields
$1: Memory error type, including Scrub corrected error.
$2: CPU number.
$3: Channel number.
$4: Memory number.
Severity
Minor
Example
Memory scrub Failed ---Scrub corrected error---Location: CPU:1 CH:1 DIMM:0
Impact
Cause
A memory correctable error was detected during memory patrol.
Recommended action
Configuration error---RDIMMs are installed on the server that supports only UDIMMs
Event code
0x0c701014
Message text
Configuration error---RDIMMs are installed on the server that supports only UDIMMs---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---RDIMMs are installed on the server that supports only UDIMMs-Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
An RDIMM was inserted into a CPU platform that only supports UDIMM.
Recommended action
Configuration error---UDIMMs are installed on the server that supports only RDIMMs
Event code
0x0c702014
Message text
Configuration error---UDIMMs are installed on the server that supports only RDIMMs---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---UDIMMs are installed on the server that supports only RDIMMs---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
An UDIMM was inserted into a CPU platform that only supports RDIMM.
Recommended action
Configuration error---SODIMMs are installed on the server that supports only RDIMMs
Event code
0x0c703014
Message text
Configuration error---SODIMMs are installed on the server that supports only RDIMMs-Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---SODIMMs are installed on the server that supports only RDIMMs-Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
An SODIMM was inserted into a platform that only supports RDIMM.
Recommended action
Configuration error---The number of ranks per channel can be only 1, 2, or 4
Event code
0x0c707024
Message text
Configuration error---The number of ranks per channel can be only 1, 2, or 4---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The number of ranks per channel can be only 1, 2, or 4---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The number of ranks in the memory does not meet the requirements of the CPU platform. The current CPU platform supports a maximum of 4 ranks of memory.
Recommended action
Configuration error---Columns, rows, or banks of the DIMM cannot meet the JEDEC standards, and LRDIMMs are not supported
Event code
0x0c707044
Message text
Configuration error---Columns, rows, or banks of the DIMM cannot meet the JEDEC standards, and LRDIMMs are not supported---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---Columns, rows, or banks of the DIMM cannot meet the JEDEC standards, and LRDIMMs are not supported---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Unsupported memory type:
·     The memory design (COL, Row, Bank) does not comply with JEDEC standard design.
·     The LRDIMM is not on the server's supported list.
Recommended action
Configuration error---The number of ranks in the channel exceeds 8
Event code
0x0c707054
Message text
Configuration error---The number of ranks in the channel exceeds 8---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The number of ranks in the channel exceeds 8---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The total number of ranks of all memory in the channel exceeds the maximum supported number of ranks (8).
Recommended action
Configuration error---Support for ECC on the DIMMs is not consistent with support for ECC on the server
Event code
0x0c707094
Message text
Configuration error---Support for ECC on the DIMMs is not consistent with support for ECC on the server---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---Support for ECC on the DIMMs is not consistent with support for ECC on the server---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The ECC support for the server's memory is inconsistent.
Recommended action
Configuration error---The voltage for a DDR4 DIMM must be 12V, and the voltage for a DDR5 DIMM must be 11V
Event code
0x0c7070a4
Message text
Configuration error---The voltage for a DDR4 DIMM must be 12V, and the voltage for a DDR5 DIMM must be 11V---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The voltage for a DDR4 DIMM must be 12V, and the voltage for a DDR5 DIMM must be 11V---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The current voltage does not meet the supported voltage of the memory.
·     DDR4 memory supports a voltage of 12V.
·     DDR5 memory supports a voltage of 11V.
Recommended action
Configuration error---The CPU is not compatible with 3DS DIMMs
Event code
0x0c707104
Message text
Configuration error---The CPU is not compatible with 3DS DIMMs---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The CPU is not compatible with 3DS DIMMs-Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The current CPU does not support memory with 3DS packaging.
Recommended action
Configuration error---NVDIMMs with stepping lower than 0x10 are not supported
Event code
0x0c707114
Message text
Configuration error---NVDIMMs with stepping lower than 0x10 are not supported---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---NVDIMMs with stepping lower than 0x10 are not supported---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Configuration error. NVDIMMs with a step value lower than 16 are not supported.
Recommended action
Configuration error---The CPU is not compatible with the DIMMs
Event code
0x0c707144
Message text
Configuration error---The CPU is not compatible with the DIMMs---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The CPU is not compatible with the DIMMs---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Configuration error: CPU and DIMM are not compatible.
Recommended action
Configuration error---The frequency of the DIMM is not supported on the server
Event code
0x0c707154
Message text
Configuration error---The frequency of the DIMM is not supported on the server---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The frequency of the DIMM is not supported on the server---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The current platform configuration does not support the frequency of the memory module.
Recommended action
1.     ‍The current configuration does not support the memory frequency settings. Confirm whether the Enforce Population POR/Enforce DDR Memory Frequency POR option in the Setup menu is enabled and whether the supported frequency of the memory module is within the supported range.
Configuration error---24Gb or higher Capacity DRAMs not supported with this CPU
Event code
0x0c7071f4
Message text
Configuration error---24Gb or higher Capacity DRAMs not supported with this CPU---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---24Gb or higher Capacity DRAMs not supported with this CPU---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The CPU does not support memory modules with a capacity of 24GB or above.
Recommended action
1.     ‍The current CPU does not support memory modules with a capacity of 24GB or above. Check the error message for the corresponding DIMM and replace the DIMM with a supported capacity.
Configuration error---The CPU is not compatible with LRDIMMs
Event code
0x0c707214
Message text
Configuration error---The CPU is not compatible with LRDIMMs---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The CPU is not compatible with LRDIMMs---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The CPU does not support LRDIMMs.
Recommended action
1.     ‍Replace the DIMM.
Configuration error--- DCPMM + HBM config is not supported. Disable DCPMM populated channel
Event code
0x0c707224
Message text
Configuration error--- DCPMM + HBM config is not supported. Disable DCPMM populated channel---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error--- DCPMM + HBM config is not supported. Disable DCPMM populated channel---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
DCPMM and HBM cannot coexist. The channel for DCPMM detected by memory installation check must be disabled.
Recommended action
1.     ‍Remove the DCPMM.
Configuration Error---DIMM speed is less than the minimum POR DIMM speed
Event code
0x0c707274
Message text
Configuration Error---DIMM speed is less than the minimum POR DIMM speed---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration Error---DIMM speed is less than the minimum POR DIMM speed---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
DIMM speed is less than the minimum POR DIMM speed.
Recommended action
1.     ‍See the user guide on the official website to select the matching memory or CPUs.
Configuration error--- Failed to enable the lockstep mode The memory RAS mode has degraded to independent
Event code
0x0c709014
Message text
Configuration error--- Failed to enable the lockstep mode The memory RAS mode has degraded to independent ---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---Failed to enable the lockstep mode The memory RAS mode has degraded to independent---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The memory configuration cannot enable Lockstep mode. It will be downgraded to independent mode.
Recommended action
1.     ‍Lockstep configuration has been downgraded. Check if the memory installation satisfies Lockstep mode.
Configuration error---Failed to enable the full mirror mode
Event code
0x0c70c014
Message text
Configuration error---Failed to enable the full mirror mode---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---Failed to enable the full mirror mode---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Enabling Full Mirror RAS mode for memory has failed. The Mirror configuration will be downgraded.
Recommended action
1.     ‍Mirror configuration has been downgraded. Check if the memory installation satisfies mirror mode.
Configuration error---Failed to enable the partial mirror mode The memory RAS mode degraded to independent
Event code
0x0c70d014
Message text
Configuration error--- Failed to enable the partial mirror mode The memory RAS mode degraded to independent---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error--- Failed to enable the partial mirror mode The memory RAS mode degraded to independent---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Unable to start partial mirror mode. The system is switched to Independent channel mode.
Recommended action
1.     ‍Partial mirror configuration has been downgraded. Check if the memory installation satisfies Partial mirror mode.
Configuration error---The memory interleaving configuration cannot meet the requirements of the server
Event code
0x0c70e034
Message text
Configuration error---The memory interleaving configuration cannot meet the requirements of the server---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The memory interleaving configuration cannot meet the requirements of the server---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Memory configuration error. The memory interleaving configuration does not meet the requirements of the server.
Recommended action
1.     ‍Check the memory interleaving configuration in the setup (NUMA and interleaving).
Configuration error---Failed to enable the rank sparing mode The memory RAS mode has degraded to independent
Event code
0x0c710014
Message text
Configuration error---Failed to enable the rank sparing mode The memory RAS mode has degraded to independent---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---Failed to enable the rank sparing mode The memory RAS mode has degraded to independent---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Rank Sparing mode cannot be enabled. The memory RAS mode has been downgraded to independent mode.
Recommended action
1.     ‍The Sparing configuration has been downgraded. Check if the memory installation satisfies the Sparing mode.
Configuration error---Failed to enable patrol scrubbing
Event code
0x0c711004
Message text
Configuration error---Failed to enable patrol scrubbing---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---Failed to enable patrol scrubbing---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Memory patrol/scrubbing cannot be enabled.
Recommended action
1.     ‍Enabling patrol scrub has failed. Check the RAS (Reliability, Availability, Serviceability) features supported by the CPU specifications.
Configuration Error---The white slot has more ranks than the black slot in a channel or the black slot is used but the white slot in the channel is empty
Event code
0x0c717014
Message text
Configuration Error---The white slot has more ranks than the black slot in a channel or the black slot is used but the white slot in the channel is empty---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration Error---The white slot has more ranks than the black slot in a channel or the black slot is used but the white slot in the channel is empty---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
·     ‍The principle of having larger rank memory in front (white slot) is not met under the channel configuration.
·     The principle of white slot preferred with memory is not met.
Recommended action
1.     ‍The memory installation is incorrect. Refer to the Intel PDG for DDR5/DCPMM and other relevant resources for proper memory installation guidelines.
Configuration error---DIMM population error Two DDR-T memory modules cannot be installed in a channel
Event code
0x0c717034
Message text
Configuration error---DIMM population error Two DDR-T memory modules cannot be installed in a channel---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---DIMM population error Two DDR-T memory modules cannot be installed in a channel---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
Two DCPMMs are installed in a channel, which does not meet DIMM installation requirements.
Recommended action
1.     ‍The DIMMs are installed incorrectly. For more information, see DDR5/DCPMM related information from Intel PDG.
Configuration error---The DDR-T memory module is installed in the white slot
Event code
0x0c717054
Message text
Configuration error---The DDR-T memory module is installed in the white slot---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---The DDR-T memory module is installed in the white slot---Location:CPU:1 CH:1 DIMM:0 A0 Rank:0
Impact
Cause
The DCPMM is installed in a white slot, which does not meet DIMM installation requirements.
Recommended action
Configuration error---ODT configuration errorThe channel is isolated
Event code
0x0c729034
Message text
Configuration error---ODT configuration error The channel is isolated---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---ODT configuration errorThe channel is isolated---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Memory ODT is configured incorrectly, and the channel is isolated.
Recommended action
Configuration error---REQ is not consistent with clock in timing
Event code
0x0c729064
Message text
Configuration error---REQ is not consistent with clock in timing---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---REQ is not consistent with clock in timing---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
REQ and the clock input have inconsistent timing.
Recommended action
Configuration error---Failed to enable ADDDC
Event code
0x0c73a014
Message text
Configuration error---Failed to enable ADDDC---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---Failed to enable ADDDC---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
Failed to enable ADDDC due to incorrect memory configuration.
Recommended action
1.     ‍Verify that the memory configuration meets the ADDDC requirements.
Configuration error---NVMCTRL_MEDIA_NOTREADY
Event code
0x0c784024
Message text
Configuration error---NVMCTRL_MEDIA_NOTREADY---Location:CPU:$1 CH:$2 DIMM:$3 $4 Rank:$5
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
$4: DIMM mark.
$5: Rank number.
Severity level
Minor
Example
Configuration error---NVMCTRL_MEDIA_NOTREADY---Location:CPU:1 CH:2 DIMM:0 A0 Rank:0
Impact
Cause
The DCPMM firmware medium is not ready.
Recommended action
1.     ‍Access the BIOS setup utility to identify the DCPMM status and update the DCPMM firmware.
2.     Replace the DIMM.
3.     If the issue persists, contact Technical Support.
Drive Slot
Drive Presence
Event code
0x0d0000de
Message text
Drive Presence
Variable fields
N/A
Severity level
Info
Example
Drive Presence
Impact
The drive presence changed.
Cause
Recommended action
Drive Fault
Event code
0x0d1000de
Message text
Drive Fault
HDDBay upper drive: Drive Fault --- Bay Slot: $1, HDD Slot: $2
Variable fields
$1: Bay slot number.
$2: HDD slot number.
Severity level
Major
Example
Drive Fault
HDDBay upper drive: Drive Fault --- Bay Slot: 1, HDD Slot: 2
Impact
The drive is faulty, which might cause data loss.
Cause
The drive is faulty.
Recommended action
1.     ‍Verify that the status of the drive is Unconfigured Good.
2.     Verify that drive LEDs are normal, and the drive can be identified and is accessible in the OS. If a drive LED is orange, the drive is faulty. Replace the faulty components, if any.
3.     Verify that the storage controller is in normal state.
Drive Fault
Event code
0x0d1050de
Message text
Drive Fault---Percentage drive life used is $1%---Exceed the major threshold $2% $3.
Variable fields
$1: Used life percentage of the drive.
$2: Major threshold.
$3: PCIe mark for the AIC card.
Severity level
Major
Example
·     Non-NVMe AIC card: Drive Fault---Percentage drive life used is 100%---Exceed the major threshold 95%.
·     NVMe AIC card: Drive Fault---Percentage drive life used is 100%---Exceed the major threshold 95% ---PCIe slot 7.
Impact
The remaining drive life is significantly lower than expected, which might cause data loss.
Cause
The used SSD life reaches the major alarm threshold.
Recommended action
1.     ‍If the used drive life reaches the major alarm threshold, replace the drive as soon as possible.
Drive Fault---The disk is present, but its details cannot be obtained
Event code
0x0d1500de
Message text
HDDBay drive: Drive Fault---The disk is present but its details cannot be obtained
Variable fields
N/A
Severity level
Major
Example
Impact
The storage system stability of the system is impacted.
Cause
A drive cannot be identified by the storage system, because the drive is faulty or the cables are connected incorrectly.
Recommended action
1.     Log in to HDM, and verify that the drive can be identified successfully.
2.     If the issue persists, verify that the drive data, power, and signal cable are connected correctly.
3.     If the issue persists, replace the drive.
Event code
0x0d1520de
Message text
HDDBay drive: Drive Fault---The disk is present but its details cannot be obtained---Bay slot:$1---HDD slot:$2
Variable fields
Severity level
Major
Example
HDDBay drive: Drive Fault---The disk is present but its details cannot be obtained---Bay slot:10---HDD slot:34
Impact
Cause
Recommended action
Drive Fault
Event code
0x0d1900de
Message text
Drive Fault--- $1---$2
Variable fields
$1: Fault description.
$2: PCIe silk screen for ACI card. This field is available only when an ACI card is connected.
Severity level
Major
Example
Drive Fault---The NVM subsystem reliability has been degraded---PCIe Slot 2
Impact
The drive health status is abnormal, which might cause data loss.
Cause
The SMART status of drives is abnormal.
Recommended action
1.     ‍Run a full SMART test on drives to check the drive health status.
2.     If the issue persists, back up drive data in time and replace the faulty drive.
Predictive Failure
Event code
0x0d2000de
Message text
Predictive Failure
Variable fields
N/A
Severity level
Minor
Example
Predictive Failure
Impact
The drive reliability decreases, which might impact the OS storage performance and service operation.
Cause
The RAID controller or NVMe SSD reports a predictive failure, which can be a storage medium reserved block alarm, drive lifetime alarm, Prefail alarm, or bad sector alarm.
Recommended action
1.     ‍Replace the drive.
Predictive Failure
Event code
0x0d2050de
Message text
Predictive Failure---Percentage drive life used is $1%---Exceed the minor threshold $2% $3.
Variable fields
$2: Minor threshold.
Severity level
Minor
Example
Non-NVMe AIC card: Predictive Failure---Percentage drive life used is 93%---Exceed the minor threshold 90%.
NVMe AIC card: Predictive Failure---Percentage drive life used is 93%---Exceed the minor threshold 90%---PCIe slot 7.
Impact
The remaining drive life is significantly lower than expected. The probability of drive damage is increasing, which affects data security.
Cause
The used SSD life reaches the minor alarm threshold.
Recommended action
1.     ‍If the used drive life reaches the minor alarm threshold, replace the drive as soon as possible.
Predictive Failure
Event code
0x0d2900de
Message text
Predictive Failure--- $1 $2
Variable fields
Severity level
Minor
Example
Predictive Failure --- The available spare capacity has fallen below the threshold---PCIe Slot 2
Impact
Cause
Recommended action
In Critical Array
Event code
0x0d5000de
Message text
In Critical Array---PCIe slot:$1---LDDevno:$2
Variable fields
$1: PCIe slot where the logical drive resides.
$2: Logical drive number.
Severity level
Major
Example
In Critical Array---PCIe slot:1---LDDevno:1
Impact
The logical drive degraded, which might impact data reliability.
Cause
A drive in a logical drive was removed or failed and the logical drive degraded.
Recommended action
1.     ‍Verify that no drive is removed. If a drive is removed, re-install the drive and recreate the RAID array.
2.     Log in to HDM, view drive information from the storage page, and verify that all drives in the logical drive are identified correctly. If a drive cannot be identified, re-install the drive. If the drive cannot be identified after re-installation, replace the drive.
3.     Log in to HDM, view drive information, and verify that the status of the drive is Unconfigured Good.
4.     After the drive is identified correctly, recreate the RAID array.
In Failed Array
Event code
0x0d6000de
Message text
In Failed Array---PCIe slot:$1---LDDevno:$2
Variable fields
Severity level
Major
Example
In Failed Array---PCIe slot:1---LDDevno:1
Impact
The RAID array becomes invalid, causing data loss offline.
Cause
A drive in a logical drive was removed or failed and the logical drive was totally corrupted.
Recommended action
1.     ‍Verify that no drive is removed. If a drive is removed, re-install the drive.
2.     If the drive is installed correctly, log in to HDM. View drive information from the storage page, and verify that the drive can be identified correctly. If the drive cannot be identified, re-install the drive. If the drive cannot be identified after re-installation, replace the drive.
3.     If the drive is installed correctly, log in to HDM, view drive information from the storage page, and verify that the status of the drive is Unconfigured Good.
4.     After the drive is identified correctly, verify that the RAID array is normal. If the RAID array is faulty, recreate the RAID array.
5.     If the issue persists, contact Technical Support.
Rebuild/Remap in progress
Event code
0x0d7000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
This message is generated during RAID rebuilding after a drive is installed.
Recommended action
The disk triggered an media error
Event code
0x0da000de
Message text
The disk triggered an media error--$1
Variable fields
$1: Drive location.
Severity level
Info
Example
The disk triggered an media error--Front 1
Impact
A media error on the storage media might cause data loss.
Cause
The number of media errors exceeded the threshold.
Recommended action
1.     ‍Update the drive firmware.
2.     Replace the drive.
The disk triggered an uncorrectable error
Event code
0x0db000de
Message text
The disk triggered an uncorrectable error--$1
Variable fields
$1: Drive location.
Severity level
Minor
Example
The disk triggered an uncorrectable error--Front 1
Impact
An uncorrectable error on the storage media might cause data loss.
Cause
The number of uncorrectable errors exceeded the threshold.
Recommended action
The disk is missing
Event code
0x0dc000de
Message text
The disk is missing
Variable fields
N/A
Severity level
Major
Example
The disk is missing
Impact
The drive is removed or not installed correctly, which impacts the storage system stability of the system.
Cause
The drive cannot be identified by the storage controller or drive cables are connected incorrectly.
Recommended action
1.     ‍Log in to HDM, and verify that the drive can be identified successfully.
2.     Verify that the drive data cables, power cords, and signal cables are connected correctly.
3.     Re-install the drive.
4.     Replace the drive.
System Firmware Progress
System Firmware Error (POST Error)---Run sense AMP HW FSM failed
Event code
0x0f0fe044
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
System startup failure might occur.
Cause
A memory configuration error occurred.
Recommended action
1.     ‍Update the BIOS firmware.
2.     Verify that the CPUs and DIMMs are installed correctly.
3.     Reduce interleaving configuration (memory interleaving and NUMA).
System Firmware Error (POST Error)--- Memory population enforcement mismatch, Please check the DIMM symmetry on the socket
Event code
0x0f017134
Message text
System Firmware Error (POST Error)--- Memory population enforcement mismatch, Please check the DIMM population rules--- Location: cpu $1
Variable fields
$1: CPU number.
Severity level
Major
Example
System Firmware Error (POST Error)--- Memory population enforcement mismatch, Please check the DIMM population rules--- Location: cpu 1
Impact
Cause
The DIMM population is incorrect.
Recommended action
See the DIMM population schemes in the user guide for the corresponding product.
System Firmware Error (POST Error)---No Dimm on socket$1
Event code
0x0f017184
Message text
Variable fields
$1: CPU number.
Severity level
Major
Example
System Firmware Error (POST Error)---No Dimm on socket1
Impact
If no DIMMs are installed for CPU 1, the system cannot start up. If no DIMMs are not installed for other CPUs, system performance degradation might occur.
Cause
No DIMMs are installed for the CPU.
Recommended action
1.     ‍Verify that the DIMMs are installed correctly as required in the user guide for the server. Re-install all DIMMs if needed.
2.     Re-install the DIMM. Verify that the gold contacts on the DIMM are not contaminated and the DIMM slot does not contain any foreign objects.
3.     Replace the DIMM, and then power on the server.
System Firmware Error (POST Error)---No memory found
Event code
0x0f0e8014
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
The system cannot start up correctly.
Cause
No DIMMs are available.
Recommended action
Verify that the DIMMs are available in the system.
System Firmware Error (POST Error)---No DIMM is available for memory-mapping operation
Event code
0x0f0e8024
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
No DIMMs is available for memory mapping.
Recommended action
1.     ‍Log in to HDM, access the memory page, and verify that available DIMMs exist.
2.     If the issue persists, contact Technical Support.
System Firmware Error (POST Error)---DIMM population error
Event code
0x0f0ed024
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
A DIMM compatibility error occurred.
Recommended action
See the HDM maintenance guide for the server.
System Firmware Error (POST Error)---Some CPU links failed to train. UPI topology changed across reset
Event code
0x0f003ff4
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
A CPU error occurred.
Recommended action
Verify that CPUs are installed correctly.
System Firmware Error (POST Error)---CPU stepping mismatch detected
Event code
0x0f010ff4
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
The CPUs were installed incorrectly and CPU stepping mismatch occurred.
Recommended action
Verify that the CPU stepping is consistent between the installed CPUs.
System Firmware Error (POST Error)---KTI Topology Change Logged
Event code
0x0f0ffff4
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
Recommended action
Verify that the CPUs are installed correctly.
System Firmware Error (POST Error)---CPU matching failure---CPU stepping is detected
Event code
0x0f0d00de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
System startup failure occurs.
Cause
A CPU stepping mismatch error occurred at POST.
Recommended action
1.     ‍Verify that the CPU has the same model as the primary CPU.
2.     Verify that CPU stepping of the CPU matches the primary CPU.
System Firmware Error (POST Error)---CPU matching failure---CPU frequency is detected
Event code
0x0f0d10de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
A CPU frequency mismatch error occurred at POST.
Recommended action
System Firmware Error (POST Error)---CPU matching failure---CPU Microcode is detected
Event code
0x0f0d20de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
A CPU microcode mismatch error occurred at POST.
Recommended action
System Firmware Error (POST Error)---CPU matching failure---UPI Topology is detected
Event code
0x0f0d30de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
A CPU UPI mismatch error occurred at POST.
Recommended action
Event code
0x0f0d40de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
The CPU model mismatch error occurred at POST.
Recommended action
System Firmware Error(POST Error)---Unrecoverable video controller failure
Event code
0x0f0090de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
KVM video display is abnormal.
Cause
Two VGA screen captures are the same during the host startup process.
Recommended action
1.     ‍Replace the BMC card.
System Firmware Hang
Event code
0x0f1000de
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
System operation failure might occur.
Cause
The BIOS hangs during startup.
Recommended action
1.     ‍Resolve the issue based on other event logs reported simultaneously for the component.
System Firmware Hang---C2C initialization failed
Event code
0x0f1800de
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
The system fails to start up properly.
Cause
The processor interconnect link C2C failed to be initialized.
Recommended action
1.     ‍Restart the server.
2.     Update the BIOS firmware.
3.     If the issue persists, replace the processor.
4.     If the issue persists, replace the system board.
System Firmware Hang---C2C initialization cannot obtain parameter table
Event code
0x0f1801de
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
The system cannot operate correctly.
Cause
The initialization of the processor interconnect link C2C failed to continue due to failure to obtain the parameter table.
Recommended action
System software triggered an uncorrectable error
Event code
0x0f1a00de
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
An IERR or MCERR error is triggered, which may cause service unavailability.
Cause
An IERR or MCERR error is triggered, and the HDM diagnosis result shows that a system software uncorrectable error occurred.
Recommended action
Usually an IERR or MCERR error is triggered by an abnormality in the system or system software. Contact Technical Support.
System software triggered a correctable error
Event code
0x0f0a00de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
An IERR or MCERR error is triggered, and the HDM diagnosis result shows that a system software correctable error occurred.
Recommended action
System Firmware Progress---Secondary processor(s) initialization---Detection unsuccessful
Event code
0x0f2030de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
No negative impact.
Cause
The TPM/TCM self-test signal is lost or a device access failure occurs.
Recommended action
System Firmware Progress---PCI resource configuration---PCIe controller initialization failed
Event code
0x0f2070de
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
Cause
The PCIe controller fails to be initialized and gets stuck during the startup.
Recommended action
1.     ‍Check the BIOS settings on the server. Make sure the related PCIe controller settings are configured correctly and not disabled.
2.     Restart the server.
3.     Update the BIOS firmware.
4.     If the issue persists, replace the CPU or system board where the PCIe controller resides.
System Firmware Progress---PCI resource configuration---PCIe controller initialization cannot find parameter table
Event code
0x0f2071de
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
Cause
The PCIe controller fails to be initialized due to failure to find the parameter table.
Recommended action
System Firmware Progress---Video initialization---Detection unsuccessful
Event code
0x0f2090de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
No negative impact.
Cause
A video controller check failed.
Recommended action
Event Logging Disabled
Log Area Reset/Cleared
Event code
0x102000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
This message is generated when all event log entries are cleared.
Recommended action
No action is required.
SEL Full
Event code
0x104000de
Message text
SEL Full
Variable fields
N/A
Severity level
Minor
Example
SEL Full
Impact
The system stops logging new events.
Cause
This message is generated when one of the following occurs:
·     If the event log reaches its maximum size, the system stops logging new events.
·     A user disables event logging.
Recommended action
Log in to HDM, enter the Event Log page, and clear all event logs.
SEL Almost Full
Event code
0x105000de
Message text
SEL Almost Full
Variable fields
N/A
Severity level
Minor
Example
SEL Almost Full
Impact
No negative impact.
Cause
The log file is reaching its maximum size when the logging policy is configured to stop login at full storage.
Recommended action
System Event
System Reconfigured---BIOS load default. CMOS cleared
Event code
0x120000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
The BIOS loads the default settings and the user-configured settings get lost.
Cause
The system board battery is abnormal.
Recommended action
1.     ‍Verify that the BIOS boot mode meets the requirements of secure boot. If not, change the boot mode to UEFI.
2.     Verify that the BIOS firmware is upgraded successfully.
3.     Upgrade the BIOS with the factory defaults (if any) or default settings of the BIOS restored.
4.     If the issue persists, contact Technical Support.
Oem system boot event---LPC Reset occurred
Event code
0x121000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
The host system reboots or powers off.
Cause
·     A command to reboot or power off the host system was executed.
·     The host system has an anomaly.
Recommended action
Limit Exceeded---CPU usage exceeds the threshold
Event code
0x1210100a
Message text
Limit Exceeded---CPU usage exceeds the threshold---Current usage $1, Threshold $2
Variable fields
$1: Current CPU usage.
$2: CPU usage threshold.
Severity level
Info
Example
Limit Exceeded---Cpu usage exceeds the threshold---Current usage 82%, Threshold 80%
Impact
Cause
The CPU usage exceeds the threshold.
Recommended action
Limit Exceeded---Mem usage exceeds the threshold
Event code
0x1210200a
Message text
Limit Exceeded---Mem usage exceeds the threshold---Current usage $1, Threshold $2
Variable fields
$1: Current memory usage.
$2: Memory usage threshold.
Severity level
Info
Example
Limit Exceeded---Mem usage exceeds the threshold---Current usage 81%, Threshold 80%
Impact
Cause
The memory usage exceeds the threshold.
Recommended action
Limit Exceeded---Network usage exceeds the threshold
Event code
0x1210300a
Message text
Limit Exceeded---Network usage exceeds the threshold---Current usage $1, Threshold $2
Variable fields
$1: Current network usage.
$2: Network usage threshold.
Severity level
Info
Example
Limit Exceeded---Network usage exceeds the threshold---Current usage 81%, Threshold 80%
Impact
The network might get lost.
Cause
The network usage exceeds the threshold.
Recommended action
This message is triggered by FIST SMS according to the system resource usage.
Limit Exceeded---Hard disk usage exceeds the threshold
Event code
0x1210400a
Message text
Limit Exceeded---Hard disk usage exceeds the threshold---OS:Linux/Unix,See disk details about Logical disk name,Current usage $1, Threshold $2
Variable fields
$1: Current drive usage.
$2: Drive usage threshold.
Severity level
Info
Example
Limit Exceeded---Hard disk usage exceeds the threshold---OS:Linux/Unix,See disk details about Logical disk name,Current usage 81%, Threshold 80%
Impact
The drive reliability decreases, which might impact the storage performance and service operation of the OS.
Cause
The drive usage exceeds the threshold.
Recommended action
Timestamp clock synch
Event code
0x125000de
Message text
Timestamp Clock Synch---event is $1 of pair---SEL Timestamp Clock updated
Variable fields
$1: In the format of first/second, where first represents the event before time synchronization and second represents the event after time synchronization.
Severity level
Info
Example
Timestamp Clock Synch---event is first of pair---SEL Timestamp Clock updated
Impact
No negative impact.
Cause
HDM synchronizes time with the server when the server is powered on. The first event is triggered before time synchronization and the second event is triggered after time synchronization.
Recommended action
Timestamp clock synch---BMC Time SYNC succeed
Event code
0x125800de
Message text
Timestamp Clock Synch---BMC Time SYNC succeed.
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
BMC synchronized ME clock successfully.
Recommended action
Critical Interrupt
Transition to Non-Critical from OK
Event code
0x1310000e
Message text
Transition to Non-Critical from OK--- Single-bit ECC error---PCIe slot:$1
Variable fields
$1: Slot number.
Severity level
Major
Example
Transition to Non-Critical from OK--- Single-bit ECC error---PCIe slot: 2
Impact
An error occurred during the access to a PCIe module. This has no negative impact on the system operation.
Cause
The PCIe module in the slot is faulty.
Recommended action
This message is generated when an error is detected by PCIe hardware check. Review the related event log messages and replace the faulty PCIe module or contact Technical Support.
PCI PERR
Event code
0x134000de
Message text
PCI PERR ---Slot $1---PCIE Name:$2
Variable fields
$1: Slot number.
$2: PCIe name.
Severity level
Major
Example
PCI PERR ---Slot 3---PCIE Name: RAID-LSI-9361-8i
Impact
An error occurred on the PCIe module, which might lead to the system-level failure if the error is severe enough.
Cause
An internal parity error occurs on the PCIe module. This message is generated when the PERR signal (parity check) on the PCIe module is abnormal.
Recommended action
1.     ‍If the message is reported serval times during a period of time, ensure that the riser card is securely connected to the system board.
2.     Reboot the server.
3.     Locate the PCIe module based on the slot number.
4.     If the PCIe module is a removable component, perform the following operations:
a.     ‍Verify that the PCIe module is installed correctly.
b.     Verify that the golden plating on the PCIe module is not contaminated.
c.     Install the PCIe module to another slot to identify whether the error is present on the PCIe module or the slot.
d.     Update all firmware and drivers, including non-Intel components.
e.     If the error occurs on the PCIe slot, verify that the slot is normal and the gold plating on the riser card is not contaminated.
f.     Replace the PCIe module.
5.     If the PCIe module is embedded on the system board, perform the following operations:
a.     ‍Update the BIOS, firmware, and drivers.
b.     Replace the system board.
PCI SERR
Event code
0x135000de
Message text
PCI SERR---Slot $1---PCIE Name:$2
Variable fields
$1: Slot number.
$2: PCIe name.
Severity level
Major
Example
PCI SERR---Slot 3---PCIE Name: RAID-LSI-9361-8i
Impact
Cause
An internal system error occurred on the PCIe module. This message is generated when the SERR signal on the PCIe module is abnormal. A system error includes an address parity error, data parity error within a period, and other fatal errors.
Recommended action
Bus Correctable Error
Event code
0x137000de
Message text
Bus Correctable Error ---Slot $1---PCIE Name:$2
Variable fields
$1: PCIe slot number.
$2: PCIe module name, IEH.
Severity level
Minor
Example
·     Bus Correctable Error---Slot 3---PCIE Name: RAID-LSI-9361-8i
·     Bus Correctable Error---PCIE Name: IEH
Impact
If this message is generated occasionally, no negative impact occurs on the system. If this message is generated frequently, the PCIe module performance might be affected.
Cause
An internal correctable error occurred on the PCIe module.
Recommended action
1.     ‍When you access PCIe devices, this alarm can generally be ignored.
2.     If the alarm is generated continuously, determine the faulty PCIe device based on the error information.
3.     Restart the server and verify if the logs still report the issue.
4.     Update the BIOS, PCIe device firmware, and drivers.
5.     If an IEH error occurred, replace the system board or CPUs.
6.     If a module error occurred, verify that the module is installed correctly or replace the module slot to identify the fault reason.
7.     If the issue persists, replace with the spare part.
GPU Device Correctable Error
Event code
0x137100de
Message text
GPU Device Correctable Error---Slot:$1
Variable fields
$1: Slot number of the faulty PCIe module.
Severity level
Minor
Example
GPU Device Correctable Error---Slot:9
Impact
The GPU can operate correctly and does not impact the system operation.
Cause
The onboard sensor, temperature sensor, or power consumption sensor for the Enflame S60 GPU is faulty.
Recommended action
GPU PCIe Bus Correctable Error
Event code
0x137200de
Message text
GPU PCIe Bus Correctable Error---Slot:$1
Variable fields
Severity level
Minor
Example
GPU PCIe Bus Correctable Error---Slot:9
Impact
Cause
The PCIe bus for the S60 GPU is faulty.
Recommended action
GPU Vedio Memory Correctable Error
Event code
0x137300de
Message text
GPU Vedio Memory Correctable Error---Slot:$1
Variable fields
Severity level
Minor
Example
GPU Vedio Memory Correctable Error---Slot:9
Impact
Cause
The S60 GPU video memory is faulty.
Recommended action
Event code
0x137800de
Message text
Variable fields
$2: PCIe module name.
Severity level
Minor
Example
Impact
Cause
An internal correctable error occurred on the PCIe module on an AMD model.
Recommended action
1.     ‍Ignore this message if it is generated during access to the PCIe module, ignore it.
2.     If the same message is generated repeatedly, use the slot number to locate the faulty PCIe module.
3.     If the PCIe module is removable, verify that the PCIe module is installed correctly or install the PCIe module to another slot to identify the cause.
4.     Replace the PCIe module.
Bus Uncorrectable Error
Event code
0x138000de
Message text
Bus Uncorrectable Error ---Slot $1---PCIE Name:$2
Variable fields
Severity level
Major
Example
·     Bus Uncorrectable Error---Slot 3---PCIE Name: RAID-LSI-9361-8i
·     Bus Uncorrectable Error---PCIE Name: IEH
Impact
Cause
An uncorrectable error occurred on the device or link when the specified PCIe device interacted with CPUs.
Recommended action
1.     Restart the server to identify whether the log message is still generated.
2.     Update the firmware of the BIOS, PCIe device, and drivers.
3.     If this log message is generated due to an IEH error, replace the system board or CPU.
4.     If this log message is generated due to a non-IEH error, perform the following steps:
a.     Verify that the PCIe device is installed securely and the gold contacts on the device are not contaminated.
b.     Install the PCIe device to a new slot. If the faulty slot changes, replace the PCIe device. If the fault occurs on the fixed slot, replace the card where the PCIe device resides.
c.     If this log message is generated on devices integrated on the system board, replace the system board.
5.     If multiple similar errors occur in the same time period, check the connection status of the riser cards and other link components or system board. If no anomalies are detected, replace link components such as the switch board system board.
6.     If the issue persists, contact Technical Support.
GPU Device Uncorrectable Error
Event code
0x138100de
Message text
GPU Device Uncorrectable Error---Slot:$1
Variable fields
Severity level
Major
Example
GPU Device Unorrectable Error---Slot:9
Impact
The GPU is being reset, which interrupts services.
Cause
Recommended action
1.     ‍Wait for the GPU reset to finish.
2.     If the issue persists, restart the server.
3.     If the issue persists, re-install the GPU.
4.     If the issue persists, replace the GPU.
GPU PCIe Bus Uncorrectable Error
Event code
0x138200de
Message text
GPU PCIe Bus Uncorrectable Error---Slot:$1
Variable fields
Severity level
Major
Example
Impact
Cause
Recommended action
GPU Vedio Memory Uncorrectable Error
Event code
0x138300de
Message text
GPU Vedio Memory Uncorrectable Error---Slot:$1
Variable fields
Severity level
Major
Example
GPU Vedio Memory Unorrectable Error---Slot:9
Impact
Cause
Recommended action
Event code
0x138800de
Message text
Variable fields
Severity level
Major
Example
Impact
Cause
An internal uncorrectable error identified by SHD occurred on the PCIe module on an AMD model.
Recommended action
1.     ‍Locate the PCIe module based on the slot number.
2.     If the PCIe module is a removable component, perform the following operations:
b.     Install the PCIe module is another slot.
c.     Update the firmware and driver of the PCIe module.
3.     If the PCIe module is embedded on the system board, perform the following operations:
a.     ‍Update the BIOS, firmware, and driver.
Bus Fatal Error
Event code
0x13a000de
Message text
Bus Fatal Error ------Slot $1---PCIE Name: $2
Variable fields
Severity level
Major
Example
·     Bus Fatal Error---Slot 3---PCIE Name: RAID-LSI-9361-8i
·     Bus Fatal Error---PCIE Name: IEH
Impact
An error occurred on the PCIe module. The server might fail to be powered due to the error.
Cause
Due to uncorrectable errors in the PCIe link or device, and the inability of the software layer to perform fault tolerance, irreversible effects are caused on the system.
Recommended action
a.     ‍Verify that the PCIe device is installed securely and the gold contacts on the device are not contaminated.
Bus Degraded
Event code
0x13b000de
Message text
Bus Degraded ------Slot $1---PCIE Name: $2
Variable fields
Severity level
Major
Example
Bus Degraded ---Slot 3---PCIE Name: RAID-LSI-9361-8i
Impact
Cause
The speed and bandwidth of the PCIe module decreased.
Recommended action
2.     Reboot the server and verify that the message is not generated again.
$1 triggered an uncorrectable error
Event code
0x138400de
Message text
Variable fields
$1: PCIe module type.
Severity level
Major
Example
NIC triggered an uncorrectable error
Impact
Cause
An IERR or MCERR error occurred, which is identified as a PCIe uncorrectable error by HDM.
Recommended action
b.     Install the PCIe module to another slot to identify whether the error is present on the PCIe module or the slot.
c.     Update all firmware and drivers, including non-Intel components.
$1 triggered a correctable error
Event code
0x137400de
Message text
Variable fields
Severity level
Minor
Example
NIC triggered a correctable error
Impact
Cause
An IERR or MCERR error occurred, which is identified as a PCIe correctable error by HDM.
Recommended action
1.     ‍If this alarm occurs occasionally, you can ignore it.
2.     If the alarm persists, locate the faulty PCIe module based on the slot number.
3.     If the PCIe module is a removable component, perform the following operations:
4.     If the PCIe module is embedded on the system board, perform the following operations:
Button / Switch
Power Button pressed---Physical button---Button pressed
Event code
0x140000de
Message text
Power Button pressed---$1---$2
Variable fields
N/A
Severity level
$1: Button type, including Physical button and Virtual button.
$2: Action, including Power off command, Power on command, and Soft off command.
Example
Power Button pressed---Physical button---Power off command
Impact
No negative impact.
Cause
This message is generated in the following conditions:
·     The physical power button on the front panel of the server is pressed.
·     Commands are executed to forcedly power off the server, gracefully power off the server, and power cycle the server.
Recommended action
Reset Button pressed
Event code
0x142000de
Message text
Reset Button pressed---Virtual button---reset command
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
This message is generated when one of the following conditions exists:
·     The reset command is executed.
·     An IERR event occurs.
Recommended action
Module / Board
Transition to Non-Critical from OK($1)
Event code
0x1510000e
Message text
Variable fields
$1: Types of alarms, such as VGA_REAR, USB_REAR_UP,USB_REAR_DOW, EAR_VGA2, EAR_LCD, L_EAR_USB, INNER_USB, R_EAR_USB.
Severity level
Minor
Example
Transition to Non-Critical from OK(VGA_REAR)
Impact
No negative impact if this message is generated occasionally.
Cause
An internal correctable error occurred on the motherboard.
Recommended action
1.     ‍Verify that the power supply for the system is normal.
Transition to Critical from less severe
Event code
0x1520000e
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
An error occurred on the PCIe BUS0 device, which might lead to the system-level failure if the error is severe enough.
Cause
An internal uncorrectable error occurred on the PCIe BUS0 device.
Recommended action
2.     Verify that all components are operating correctly.
Transition to Non- Recoverable from less severe
Event code
0x1530000e
Message text
Transition to Non-Recoverable from less severe--System detected a power supply failure on Motherboard($1)
Variable fields
$1: P5V, P5V_STBY, P12V_SHORTOUT, P1V0_STBY, P1V8_STBY, P1V05_PCH_STBY, PVNN_PCH_STBY, P1V8_PCH_STBY.
Severity level
Critical
Example
Transition to Non- Recoverable from less severe---System detected a power supply failure on Motherboard(P5V)
Impact
The system will be powered off.
Cause
The voltage for the system board is abnormal.
Recommended action
1.     ‍Ignore this message if it is triggered by a system power-on or power-off event.
2.     Reconnect power cords and identify whether the server can be powered on correctly.
¡     If the server can be powered on, the message might be generated because the detection signals were interfered. No action is required.
¡     If the server cannot be powered on, replace the system board.
3.     If the issue persists, replace the I/O expander module if any.
Transition to Non-Critical from OK---System is operating in KTI Link Slow Speed Mode
Event code
0x15101ff4
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
The system is operating in Keizer Technology Interconnect (KTI) low speed mode.
Recommended action
Verify that the signal quality and hardware parameters are correct.
Transition to Non-Critical from OK---Requested Link Speed is not supported. Defaulting to 18GT
Event code
0x15102ff4
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
The link speed is not supported.
Recommended action
Verify that hardware parameters are correct.
Transition to Non-Critical from OK---One or more per Link option mismatch detected. Forcing to common setting
Event code
0x15104ff4
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
Some CPU links are faulty.
Recommended action
Verify that the UPI configuration is correct on the BIOS setup utility.
Transition to Non-Critical from OK---Some CPU has more than one link connecting to other CPU. Disable one of the Dual-Link
Event code
0x15105ff4
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
A UPI link error occurred.
Recommended action
Verify that the UPI link is connected as required.
Transition to Non-Critical from OK---KTI Adaptation is in progress, or High Speed adaptation is failed
Event code
0x15106ff4
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
Cause
KTI adaption is in progress.
Recommended action
System board triggered a correctable error
Event code
0x1511000e
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
An IERR or MCERR error occurred in the system, which causes services to become unavailable.
Cause
An IERR or MCERR error was triggered. The error was identified as an uncorrectable error on the system board (including backplanes) by HDM.
Recommended action
System board triggered an uncorrectable error
Event code
0x1521000e
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
Recommended action
Add-in Card
Transition to OK
Event code
0x1700000e
Message text
Transition to OK---PCIe slot: $1---LDDevno:$2
Variable fields
Severity level
Info
Example
Transition to OK---PCIe slot:1---LDDevno:0
Impact
No negative impact.
Cause
This message is generated if the logical drive managed by the storage controller changes from abnormal to normal.
Recommended action
Event code
0x1720000e
Message text
Variable fields
N/A
Severity level
Major
Example
Impact
Cause
The backplane power supply is faulty.
Recommended action
1.     ‍Log in to HDM to identify whether the logical drive is degraded or faulty.
2.     If the logical drive is degraded, perform the following operations:
a.     ‍Verify that all member drives in the logical drive are operating correctly.
b.     Re-install member drives to identify whether the drives can be correctly identified.
c.     Access the BIOS to identify whether all member drives have been configured correctly.
d.     Check the error logs for the drives.
e.     Replace the faulty drive.
f.     If the issue persists, contact Technical Support.
3.     If the logical drive is faulty, perform the following operations:
a.     ‍Verify that the drive has not been uninstalled.
b.     Re-install the member drives and rebuild the RAID.
c.     Replace the faulty drive, and then reboot the server.
d.     If the issue persists, contact Technical Support.
Event code
0x172a000e
Event code
Transition to Critical from less severe---PCIe slot:$1---LDDevno::$2
Message text
The logical drive degraded.
Variable fields
Major
Severity level
Transition to Critical from less severe---PCIe slot: 1---LDDevno:0
Example
Impact
This message is generated when the logical drive managed by the storage controller is degraded or faulty.
Cause
Transition to Non-recoverable  from less severe
Event code
0x1730000e
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
Cause
The backplane power supply or the riser power supply is faulty.
Recommended action
¡     If the server cannot be powered on, review the SDS logs to locate the fault and replace the faulty component.
3.     If the issue persists, replace the faulty component.
ChipSet
Event code
0x1920000e
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
System performance degradation might occur.
Cause
The PCH status was abnormal.
Recommended action
1.     ‍If this message is generated during the host restart process, ignore this message.
2.     If this message is repeatedly generated during the operation, replace the system board.
Cable/Interconnect
Configuration Error - Incorrect cable connected / Incorrect interconnection
Event code
0x1b1000de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
The network is abnormal, which might cause network disconnectivity in the system.
Cause
Incorrect cable configuration.
Recommended action
1.     ‍Verify that the cables are connected to the correct interfaces.
2.     Verify that the cables connected properly for power connection.
Event code
0x1b1200de
Message text
Configuration Error - Incorrect cable connected / Incorrect interconnection---Slot$1 support S5 power supply, $2
Variable fields
$1: PCIe slot with S5 power supply enabled.
$2: Description of the reason.
Severity level
Minor
Example
Configuration Error-Incorrect cable connected / Incorrect interconnection---Slot5 support S5 power supply, but Card not support this feature
Impact
No negative impact on the system.
Cause
The slot with S5 power supply enabled either does not have a smart network adapter or the smart network adapter is not properly inserted.
Recommended action
1.     Disable the S5 function for the current slot.
2.     Insert the smart network adapter into the slot again.
Event code
0x1b1800de
Message text
Configuration Error - Incorrect cable connected / Incorrect interconnection---$1
Variable fields
$1: Incorrect cable configuration.
Severity level
Minor
Example
Configuration Error - Incorrect cable connected / Incorrect interconnection---Incorrect SATA cable connection to the backplane
Impact
A communication exception might occur on the backplane.
Cause
Recommended action
Event code
0x1b1400de
Message text
Configuration Error - Incorrect cable connected / Incorrect interconnection ($1)
Variable fields
$1: Cable connection location.
Severity level
Minor
Example
Configuration Error-Incorrect cable connected / Incorrect interconnection(FrontBackplane1)
Impact
Cause
Recommended action
System Boot / Restart Initiated
Initiated by power up
Event code
0x1d0000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
This event is triggered by a system power-on.
Recommended action
Initiated by hard reset
Event code
0x1d1000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
This event is triggered by a system restart.
Recommended action
Initiated by warm reset
Event code
0x1d2000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
This event is triggered by a system warm restart.
Recommended action
System restart
Event code
0x1d7000de
Message text
System Restart---$1:$2
Variable fields
$1: Reboot cause.
$2: Power mode. Options include power off, power reset, and power cycle. This option may be empty.
Severity level
Info
Example
System Restart---due to power button pressed:power off
Impact
No negative impact.
Cause
The system restarts.
Recommended action
Boot Error
No bootable media
Event code
0x1e0000de
Message text
No bootable media
Variable fields
N/A
Severity level
Info
Example
No bootable media
Impact
No negative impact.
Cause
Status description to indicate no bootable media, which typically has no negative impact.
Recommended action
1.     ‍Specify an available boot device.
OS_BOOT
C: boot completed
Event code
0x1f1000de
Message text
C: boot completed
Variable fields
N/A
Severity level
Info
Example
C: boot completed
Impact
No negative impact.
Cause
The operating system booted from a hard drive. This event happens for most Windows OSs.
Recommended action
Boot completed - boot device not specified
Event code
0x1f6000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
This message is generated when the server exits the BIOS boot phase.
Recommended action
OS Stop / Shutdown
Run-time Critical Stop
Event code
0x201000de
Message text
Variable fields
N/A
Severity level
Critical
Example
Impact
The system crashes.
Cause
A critical error occurred during operating system operation.
Recommended action
1.     ‍Verify that the installed system, drivers, firmware, and software do not have bugs and are compatible with the server.
2.     Update the versions if bugs or compatibility issues exist.
3.     Verify that the installed hardware options are compatible with the server. For more information about component and server compatibility, access the component compatibility query tool at the official website.
OS Graceful Stop
Event code
0x202000de
Message text
OS Graceful Stop
Variable fields
N/A
Severity level
Info
Example
OS Graceful Stop
Impact
The system shut down.
Cause
The Windows OS was forcedly stopped.
Recommended action
OS Graceful Shutdown
Event code
0x203000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
Cause
The Windows OS was shut down gracefully.
Recommended action
Slot / Connector
Device Disabled: PCIe module information not obtained
Event code
0x21000012
Message text
Device Disabled: PCIe module information not obtained---Slot $1
Variable fields
Severity level
Major
Example
Device Disabled: PCIe module information not obtained---Slot 1
Impact
The PCIe module cannot be identified, which decrease the system performance.
Cause
The PCIe module is faulty.
Recommended action
1.     ‍Verify that the server starts up with the minimum configuration. For more information, see the troubleshooting guide for the server.
2.     Verify that port is disabled in the BIOS.
3.     Verify that the PCIe module is compatible with the server.
4.     Verify that the PCIe module is installed correctly.
5.     Install the PCIe module into another slot to verify that the PCIe module is not faulty.
Fault Status asserted
Event code
0x210000de
Message text
Fault Status asserted:---fan error in slot $1
Variable fields
$1: Slot number.
Severity level
Major
Example
Fault Status asserted:---fan error in slot 15
Impact
The system might crash due to a PCIe module error.
Cause
This message is generated when the OCP fan is absent or blocked.
Recommended action
1.     ‍Re-install the OCP fan.
2.     If the issue persists, replace the OCP fan.
Event code
0x2110000e
Message text
Transition to Non-Critical from OK---slot $1----PCIe Name:$2
Variable fields
Severity level
Major
Example
Transition to Non-Critical from OK---slot 15----PCIe Name:NIC-620F-B2-25Gb-2P-1-X
Impact
Cause
This message is generated when the system fails to obtain information about network adapter connection.
Recommended action
1.     ‍Verify that the network adapter is no faulty.
2.     Verify that the related links are operating correctly, for example, I2C or MCTP.
System ACPI Power State
S0 / G0 "working"
Event code
0x220000de
Message text
S0 / G0 "working"
Variable fields
N/A
Severity level
Info
Example
S0 / G0 "working"
Impact
No negative impact.
Cause
S0/G0 indicate that the system is operating correctly, where G(0-2) indicate the global states (G-States) and S(0-5) indicate the sleep states (S-States).
G0 operating status: In this state, you can run the applications.
S0 sleep state: Normal operating status.
Recommended action
S0 / G0 "working"
Event code
0x220800de
Message text
S0 / G0 "working"---$1
Variable fields
$1: Reason for a power-on operation, including:
·     due to virtual power button pressed
·     due to physical power button pressed
·     due to ipmi cmd
·     due to redfish cmd
·     due to AC lost
·     due to kvm button pressed
·     due to snmp cmd
Severity level
Info
Example
S0 / G0 "working"--- due to virtual power button pressed
Impact
No negative impact.
Cause
The system is powered on.
Recommended action
S5 / G2 "soft-off"
Event code
0x225000de
Message text
S5 / G2 "soft-off"
Variable fields
N/A
Severity level
Info
Example
S5 / G2 "soft-off"
Impact
No negative impact.
Cause
S5 / G2 indicates the software shutdown state. You cannot run applications or the operating system in this state. Software shutdown shuts down the entire operating system except the main power supply unit. Almost no power is consumed during software shutdown. The waking time will be longer to reboot the system after a soft shutdown.
Recommended action
S5 / G2 "soft-off"
Event code
0x225800de
Message text
S5 / G2 "soft-off"---$1
Variable fields
$1: Reason for a power-off operation, including:
·     due to ipmi cmd
·     due to AC lost
·     due to snmp cmd
·     due to pef expiration
Severity level
Info
Example
S5 / G2 "soft-off"--- due to virtual power button pressed
Impact
No negative impact.
Cause
Recommended action
S4 / S5 soft-off, particular S4 / S5 state cannot be determined
Event code
0x226000de
Message text
Variable fields
N/A
Severity level
Info
Example
Impact
No negative impact.
Cause
S4/S5 indicates the software shutdown state, but you cannot identify whether the current state is S4 or S5.
S4 state:
·     All components are closed including ARM.
·     Only the platform settings are retained, while other settings are saved in a special location on the drive.
·     After a successful switch to S4, the system will shut down.
·     Due to the cessation of almost all programs and configurations, the power consumption is less than 3W.
·     Upon wake-up, the system needs to enter BIOS Boot Sequence again.
·     No system restart is required. The system will continue with the S5 shutdown state.
Recommended action
LPC Reset occurred
Event code
0x22d000de
Message text
LPC Reset occurred
Variable fields
N/A
Severity level
Info
Example
LPC Reset occurred
Impact
No negative impact.
Cause
The server was reset.
This message is available only for servers that use Intel processors.
Recommended action
Watchdog2
Watchdog overflowAction:Timer expired
Event code
0x230000de
Message text
Watchdog overflow.Action:Timer expired - status only (no action and no interrupt)---interrupt type:$1---timer use at expiration:$2
Variable fields
$1: Interrupt type. Options include none, SMI, NMI, Messaging Interrupt, and unspecified.
$2: Watchdog. Options include reserved, BIOS FRB2, BIOS POST, OS Load, SMS OS, OEM, and unspecified.
Severity level
Info
Example
Watchdog overflow.Action:Timer expired - status only (no action and no interrupt)---interrupt type:none---timer use at expiration:BIOS FRB2
Impact
Cause
This message is generated when the following conditions are met:
·     The watchdog is enabled in the BIOS.
·     The watchdog timer expires.
·     The timeout action is set to no action.
Recommended action
1.     ‍For a BIOS POST watchdog timeout, review the event logs to identify hardware errors or BIOS startup errors, and troubleshoot the errors as instructed in the logs.
2.     For an OS Load watchdog timeout, verify that no error is present in the system startup environment. If no error is present, proceed to step 5.
3.     For an OS Running watchdog timeout, review the OS logs to identify whether software exceptions occurred and troubleshoot the exceptions as instructed in the logs.
4.     Identify whether data storms have occurred. If yes, troubleshoot network errors.
Watchdog overflowAction:Hard Reset
Event code
0x231000de
Message text
Watchdog overflow.Action:Hard Reset---interrupt type:$1---timer use at expiration:$2
Variable fields
Severity level
Major
Example
Watchdog overflow.Action:Hard Reset---interrupt type:none---timer use at expiration:BIOS FRB2
Impact
Cause
·     The watchdog timer expires during the BIOS POST, OS Load, or SMS/OS phase (indicated by the watchdog timer type).
·     The timeout action is set to hard reset.
Recommended action
Watchdog overflowAction:Power Down
Event code
0x232000de
Message text
Watchdog overflow.Action:Power Down---interrupt type:$1---timer use at expiration:$2
Variable fields
Severity level
Major
Example
Watchdog overflow.Action:Power Down---interrupt type:none---timer use at expiration:BIOS FRB2
Impact
Cause
·     The timeout action is set to power down.
The watchdog powered off the system forcibly. Services are interrupted and the data that has not been saved will get lost.
Recommended action
Watchdog overflowAction:Power Cycle
Event code
0x233000de
Message text
Watchdog overflow.Action:Power Cycle---interrupt type:$1---timer use at expiration:$2
Variable fields
Severity level
Major
Example
Watchdog overflow.Action:Power Cycle---interrupt type:none---timer use at expiration:BIOS FRB2
Impact
Cause
·     The timeout action is set to power cycle.
Recommended action
Entity Presence
Entity Present---License is about to expire
Event code
0x250000de
Message text
Variable fields
N/A
Severity level
Minor
Example
Impact
No negative impact.
Cause
This message is generated when the remaining validity period of the license is less than 10 days.
Recommended action
The temporary license is about to expire. Please purchase the formal license.
Entity Disabled---License has expired
Event code
0x252000de
Message text
Entity Disabled---$1
Variable fields
$1: Certificate state:
·     License has expired.
·     License is unavailable.
Severity level
Minor
Example
Impact
No negative impact.
Cause
The certificate has expired or is not available.
Recommended action
1.     ‍If the temporary license has expired, purchase and activate the formal license.
2.     If the license is not available, re-install and activate the existing license or contact Technical Support.
Management Subsystem Health
Controller access degraded or unavailable
Event code
0x281000de
Message text
Controller access degraded or unavailable---$1
Variable fields
$1: Possible options include Failed to access the SD card and SD card partitions are missing.
Severity level
Major
Example
Controller access degraded or unavailable---Failed to access the SD card.
Impact
No negative impact.
Cause
SD card reading failed or the SD card was missing.
Recommended action
1.     ‍Restart HDM.
2.     Reset the SD module for BMC.
Event code
0x282000de
Message text
Management controller off-line ---$1
Variable fields
$1: BMC reboot cause.
Severity level
Info
Example
Management controller off-line---BMC reset
Impact
No negative impact.
Cause
BMC was restarted.
Recommended action
Battery
Battery low (predictive failure)
Event code
0x290000de
Message text
Battery low (predictive failure)---PCIe slot:$1
Variable fields
$1: PCIe slot number of the storage controller.
Severity level
Minor
Example
Battery low (predictive failure)---PCIe slot:1
Impact
The reliability of the RAID controller will degrade, which might cause system performance degradation.
Cause
The supercapacitor of the storage controller has a low charge, overtemperature, overvoltage, or overcurrent condition.
Recommended action
1.     ‍Power on the server to charge the supercapacitor. Log in to HDM, and verify that the supercapacitor of the RAID controller is in normal state and identify whether the alarm is cleared.
2.     Verify that the power fail safeguard module is installed correctly.
3.     Replace the corresponding components, including the battery, supercapacitor, or flash card (if any), and then restart the server.
Battery failed
Event code
0x291000de
Message text
Battery failed---PCIe slot:$1
Variable fields
Severity level
Minor
Example
Battery failed---PCIe slot:1
Impact
Cause
An internal error occurred on the power fail safeguard module of the storage controller.
Possible reasons include:
·     The supercapacitor is exhausted or has expired.
·     The power fail safeguard module failed to be initialized.
·     The power fail safeguard module subsystem failed.
·     The supercapacitor failed to be charged.
·     The battery or supercapacitor fails.
Recommended action
1.     ‍Log in to HDM, and verify that the supercapacitor of the RAID controller is in normal state.
Battery presence detected
Event code
0x292000de
Message text
Battery presence detected---PCIe slot:$1
Variable fields
Severity level
Info
Example
Battery presence detected---PCIe slot:1
Impact
Cause
The battery or supercapacitor of the RAID controller is absent.
Recommended action
2.     Verify that the supercapacitor is installed correctly and the supercapacitor cable is connected correctly.
Version Change
Hardware incompatibility detected with associated Entity---Memory is not certified
Event code
0x2b2000de
Message text
Hardware incompatibility detected with associated Entity---Memory is not certified---Location:CPU:$1 CH:$2 DIMM:$3
Variable fields
$1: CPU number.
$2: Channel number.
$3: DIMM number.
Severity level
Minor
Example
Hardware incompatibility detected with associated Entity---Memory is not certified---Location:CPU:1 CH:1 DIMM:0
Impact
No negative impact.
Cause
This message is generated when the DIMM is not certified.
Recommended action
1.     ‍Install DIMMs certified by the server vendor.
