H3C G7 Servers HDM3 IPMI Basics Command Reference-6W100
HomeSupportDeveloper DocumentsAPI ReferencesH3C G7 Servers HDM3 IPMI Basics Command Reference-6W100
Download Book
  • Released At: 14-07-2025
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
H3C G7 Servers HDM3
New H3C Technologies Co., Ltd.
http://www.h3c.com
Software version: HDM3-1.25 and later, HDM3-2.04 and later
Document version: V2.02
Copyright © 2025, New H3C Technologies Co., Ltd. and its licensors
All rights reserved
Trademarks
Notice
The information in this document is subject to change without notice. All contents in this document, including statements, information, and recommendations, are believed to be accurate, but they are presented without warranty of any kind, express or implied. H3C shall not be liable for technical or editorial errors or omissions contained herein.
Revision records
Version
Revised date
HDM version
Interface name
Interface modification content
Obtain information about the specified storage controller
Added the Present option for powerfail safeguard status in the Data[269:300] field.
Revised the change history.
Obtain information about the specified logical drive
Added the 0xFF option for 3SINC storage controllers to indicate that the feature is not available in Data[87].
Added description about LSI controllers and 3SINC storage controllers in Data[91], Data[93], and Data[94].
Added support information about 3SINC storage controllers in Data[99].
Obtain information about the specified physical drive for a storage controller
Added description about physical drive status for 3SINC storage controllers in Data[12:44].
V1.0
2024.2.8
HDM3-1.06
All interfaces
First revision, based on H3C HDM2 IPMI Basics Command Reference_V1.10.
V1.1
2024.5.17
HDM3-1.09
The version number represents the most recent HDM version when the document was released. For more information about versions supporting a specific interface, see the change history for the interface.
Configure NTP settings
Changed the description of the Data[7] and Data[8-N] fields.
Obtain the number of supported CPUs and DIMMs
Supplemented the application scope of Data[4] to indicate that the field has been discarded for new products.
Obtain server power status and UID LED status
Added support description for G7 products.
Obtain CPU information
Supplemented description for the Data[127-128] TDP field.
Added the Data[129-144] CHIP ID field.
Changed the reserved field to Data[145].
V1.2
2024.7.3
HDM3-1.13
Set the alarm threshold for a sensor
Revised the description for lnr, lcr, and lnc.
Revised the description of the Data[4] field for parameter selectors.
Obtain the fan speed mode
Added the description for this interface, which already exists in earlier versions.
V1.3
2024.8.9
HDM3-1.14
Set the location of an SNMP trap node
Set the SNMP trap contact information
Configure an SNMP community
Changed the maximum length of the community name to 31 bytes. The community name must end with \0.
Obtain the next boot mode
Set the next boot mode
Added the remarks to indicate that the Phytium platform does not support Legacy mode.
Added use of reserved field Data[101].
Obtain the MCA policy information
Added the command in HDM3.
Configure MCA policy settings
Obtain the SEL storage mode
Revised the response fields.
Obtain SMTP alert email configuration
Revised the email ID parameter for Data[7].
V1.4
2024.9.4
HDM3-1.15
Obtain idle slot list information
Added the command.
Obtain information about an idle slot
Added the command.
Obtain information about idle slots under a storage controller
Added the command.
Obtain information about an idle slot under a storage controller
Added the command.
Obtain SNMP trap general settings
Changed the response fields to the same as HDM3.
V1.5
2024.9.11
HDM3-1.18
Added description about physical drive status for 3SINC storage controllers in Data[12:43].
Create a logical drive
Added the length description for 3SINC storage controllers in Data[12:43].
Added the stripe size description for 3SINC storage controllers in Data[45].
Added the capacity description for 3SINC storage controllers in Data[46:49].
Added support description about 3SINC storage controllers in Data[51].
Added description about initialization modes for 3SINC storage controllers in Data[52].
Added description about the physical drive cache policy for 3SINC storage controllers in Data[56].
Added description about the  read policy and write policy for 3SINC storage controllers in Data[57] and Data[58], respectively.
Added description about 3SINC storage controllers in Data[67].
V1.6
2024.10.17
HDM3-1.19
Added the Data[145-146] field
to display the actual number of threads.
Obtain KVM modes
HDM3-1.18: Revised the description for Data[5] and Data[7].
Set KVM modes
HDM3-1.18: Revised the description for Data[8] and Data[10].
Obtain remote virtual media (VM)
Added the command.
Deploy remote virtual media (VM) settings
Added the command.
Start or stop image mounting (VM)
Added the command.
Obtain image information (VM)
Added the command.
Configure image settings (VM)
Added the command.
Manually take snapshots
Added the command.
Delete snapshots
Added the command.
Added the field for specifying a file type.
V1.7
2024.11.05
HDM3-1.20
Updated the version number
V1.8
2024.11.28
HDM3-1.21
HDM3-2.01
Revised the command and examples.
Set a BIOS option
Added support for G7 AMD products and added the option description for G7 AMD products.
Obtain a BIOS option
Set the SEL storage mode
Revised response fields and examples.
V1.9
2024.12.24
HDM3-1.23
HDM3-2.02
Obtain the firmware revision of a power supply
Revised the command title.
Corrected errors in the example.
Set a BIOS option
Revised the data[7] value from 0x07 to 0x14 in the BIOS AMD field BootOrder1.
V2.01
2025.1.14
HDM3-1.24
HDM3-2.03
Obtain HDM network service information
Deleted Telnet service information.
Configure HDM network service settings
Revised response fields.
Added the idle slot numbering description for Data[12:13].
Added the idle slot numbering description for Data[11:12].
Added the idle slot numbering description for Data[13:14].
Added service ID.
Added service ID.
Configure SMTP settings
Added the description for the sender username.
Added the description for the username.
Configure SNMP version settings
Added the description for SNMP read/write community.
V2.02
2025.2.19
HDM3-1.25
HDM3-2.04
Added the description for the value.
Revised the description for Data[12:13].
Revised the description for Data[11:12].
Revised the description for Data[13:14].
Obtain information about the specified PCIe module
Added the command.
Added a restriction remark for the SMTP anonymous field.
V2.0x
2025.3.14
HDM3-1.2x
HDM3-2.0x
IPMI command conventions· 1
About IPMI 1
About IPMItool 1
Command format 1
Request and response· 2
Applicable products and versions· 3
Permissions· 3
Port description· 3
Standard IPMI commands· 5
Chassis management 5
Obtain current chassis status· 5
Obtain the reason for the most recent restart 5
Obtain total power-on time of a chassis· 6
Obtain the chassis self-test result 6
Chassis power management 6
Obtain the current chassis power status· 6
Power on a chassis· 7
Power off a chassis· 7
Restart a chassis· 7
Trigger NMI diagnosis· 8
Set the power-on policy for a chassis· 8
Obtain the supported power-on policies of a chassis· 9
Server information obtaining· 9
Obtain server version information· 9
Obtain server GUID information· 10
Obtain the current status of all sensors· 11
Obtain sensor type information· 14
Obtain the list of supported sensors in a chassis· 15
Obtain fan status information· 18
Obtain fan speed information· 18
Perform a server self-test on HDM·· 19
Reset HDM·· 19
Obtain the reading of a sensor 20
Set the alarm threshold for a sensor 20
Obtain SEL information· 22
Obtain FRU information· 22
Obtain current session information· 24
Obtain server power status and UID LED status· 25
Set server UID LED status· 26
Obtain FRU information· 27
User management 28
Obtain information about all HDM users· 28
Obtain brief HDM user information· 28
Add an HDM user 28
Set the password for an HDM user 29
Verify an HDM user password· 30
Disable HDM access· 31
Enable HDM access· 31
Delete an HDM access· 32
Specify the HDM user role· 32
HDM IPv4 management 33
Obtain the IP address obtaining method for a network port 33
Obtain the IP address of a network port 34
Obtain the MAC address of a network port 35
Obtain the subnet mask of a network port 36
Obtain the gateway address· 37
Set the IP address obtaining method for a network port 38
Specify a static IP address for a network port 39
Specify the subnet mask for a network port 40
Specify the gateway address for a network port 41
HDM IPv6 management 42
Obtain the IPv6 address of a network port 42
Specify a static IPv6 address for a network port 43
Specify the prefix length for a network port 44
Obtain the prefix length of a network port 44
Obtain the IPv6 address obtaining method for a network port 45
Set the IPv6 address obtaining method for a network port 46
Specify the IPv6 gateway address for a network port 47
System boot 48
Set the one-time next boot option· 48
Remove the configured one-time next boot option· 49
Configure the server to enter the BIOS setup utility after startup· 49
Device extended commands· 50
Hardware information· 50
Obtain the number of present PCIe modules· 50
Obtain PCIe module information· 50
Obtain information about the specified PCIe module· 53
Obtain port information on an Ethernet adapter 55
Obtain the number of supported CPUs and DIMMs· 55
Obtain CPU information· 56
Obtain memory information· 59
Obtain product generation· 63
Obtain expander information· 64
Obtain server health status· 65
Obtain OCP network adapter status· 68
Host 69
Obtain security bezel LED configuration· 69
Set security bezel LEDs· 71
Obtain MCA policy information· 72
Configure MCA policy settings· 73
Storage· 74
Obtain storage controller list information· 74
Obtain information about the specified storage controller 76
Obtain the logical drive list for the specified storage controller 79
Obtain information about the specified logical drive· 80
Obtain the physical drive list for a storage controller 85
Obtain information about the specified physical drive for a storage controller 87
Obtain the physical drive list 93
Obtain information about the specified physical drive· 95
Obtain idle slot list information· 101
Obtain information about an idle slot 103
Obtain information about idle slots under a storage controller 105
Obtain information about an idle slot under a storage controller 107
Set the mode of a storage controller 109
Set the attributes of the specified storage controller 110
Clear configuration of the specified storage controller 112
Create a logical drive· 113
Delete a logical drive· 118
Modify the attributes of the specified logical drive· 119
Add/Remove the specified hot spare drive· 120
Modify the status of the specified physical drive· 123
Locate the specified physical drive· 125
Obtain the drive alarm thresholds· 126
Set the drive alarm thresholds· 128
Obtain the total drive usage· 130
Specify the drive usage· 131
BMC and BIOS interaction· 132
Obtain the next boot option· 132
Set the next boot option· 133
Obtain the next boot mode· 134
Set the next boot mode· 135
Obtain the power-on delay time· 136
Set the power-on delay time· 137
Obtain Postcode information· 138
Set a BIOS option· 140
Obtain a BIOS option· 142
DNS· 144
Obtain host name setting· 144
Security· 145
Obtain the state of weak password dictionary validation· 145
Set the state of weak password dictionary validation· 146
Obtain ICMP outbound rules of the firmware· 146
Configure ICMP outbound rules on the firmware· 147
Network-related settings· 149
Obtain HDM network service information· 149
Configure HDM network service settings· 150
Obtain permissions of all user roles· 152
Set permissions for a custom user role· 153
Trigger an immediate network restart 154
Delete all network firewall rules· 155
Set NCSI information· 156
Obtain NCSI information· 157
Set the BMC network mode· 158
Obtain the status setting of a network port 159
Set the network port status· 160
Obtain network port in use in active/standby mode· 161
Obtain the name of a network port 161
Obtain the link status of dedicated and shared network ports· 162
SNMP· 163
Obtain SNMP version information· 163
Configure SNMP version settings· 164
Set the enabling status of SNMP traps· 165
Set the SNMP trap version· 166
Set the location of an SNMP trap node· 167
Set the SNMP trap contact information· 168
Configure an SNMP community· 169
Specify the severity levels of SNMP traps to be reported· 170
Configure an SNMP trap server 170
Set the SNMP trap mode· 172
Obtain SNMP trap general settings· 173
Send a SNMP trap test command· 174
Set user SNMP v3 information· 175
NTP· 176
Obtain the NTP configuration information· 176
Configure NTP settings· 178
Set the time zone· 180
Set the NTP refresh interval 180
Obtain the IP address of the tertiary NTP server 181
Obtain the NTP synchronization interval 182
HDM maintenance· 183
Obtain HDM firmware information· 183
Obtain BIOS firmware information· 184
Restore factory HDM settings· 186
Obtain CPLD firmware information· 186
Obtain FPCPLD firmware information· 188
Obtain service USB device configuration· 189
Set service USB device configuration· 190
Obtain Wi-Fi service enabling status· 190
Set Wi-Fi service enabling status· 191
Obtain the number of taskservice tasks and the current task ID·· 192
Obtain taskservice task details· 193
Set the enabling status of the dedicated management interface· 194
View the enabling status of the dedicated management interface· 195
System maintenance· 196
Obtain the SEL storage mode· 196
Set the SEL storage mode· 197
Obtain overall information about SEL logs· 198
Obtain information about an SEL log· 199
Obtain information about a packet transmitted for an SEL entry· 200
Obtain information about the serial port connected to the SOL· 202
Obtain information about the serial port connected to a panel 203
Obtain SMTP configuration information· 204
Configure SMTP settings· 206
Obtain SMTP alert email configuration· 208
Configure SMTP alert email settings· 209
Obtain rsyslog configuration information· 210
Obtain information about rsyslog single-channel server configuration· 211
Set rsyslog message configuration· 214
Configure rsyslog single-channel server settings· 215
Test rsyslog single-channel server settings· 217
Configure event log association with the health center 218
Fans· 219
Set the fan speed mode· 219
Obtain the fan speed mode· 220
Reload the configuration file for fans· 221
Power supplies· 222
Obtain the maximum number of supported power supplies· 222
Check whether the installed power supply are as required· 222
Obtain the presence, AC input, and DC input status of a power supply· 223
Obtain the cold backup state of a power supply· 224
Configure a power supply to enter in cold backup· 225
Configure a power supply to exit from cold backup· 226
Obtain the manufacturer information of a power supply· 227
Obtain the model of a power supply· 227
Obtain the maximum output power of a power supply· 228
Obtain power supply information displayed on the Web interface· 229
Obtain the current output power of a power supply· 230
Obtain the range of the power cap value· 231
Obtain the power information of a power supply· 231
Obtain the firmware revision of a power supply· 232
Obtain GPU power capping information· 233
Configure GPU power capping· 234
Obtain power information of the past day or week· 235
KVM and virtual media· 237
Obtain KVM modes· 237
Set KVM modes· 238
Obtain remote virtual media (VM) 239
Deploy remote virtual media (VM) settings· 241
Start or stop image mounting (VM) 242
Obtain image information (VM) 244
Configure image settings (VM) 247
Manually take snapshots· 248
Delete snapshots· 249
Examples· 251
Using IPMItool to obtain chassis status· 251
Network configuration· 251
Using IPMItool software· 251
Using IPMItool to obtain chassis information· 252
About IPMI
Intelligent Platform Management Interface (IPMI) is an industry standard for managing peripheral devices in server systems. You can use IPMI to monitor the physical health status of servers from different vendors, such as temperature, voltage, fan modules, power supplies to achieve unified management of servers from different vendors.
About IPMItool
IPMItool is an open source IPMI client tool that supports both Linux and Windows operating systems and is the most commonly used IPMI client tool. IPMItool accesses the IPMI interface of a server through commands. As shown in Figure 1, open the Windows cmd and access the IPMItool directory to execute IPMI commands.
Figure 1 Windows Command Prompt
Command format
An IPMI command uses the ipmitool -I connect_type -H hostname -U username -P password <command> format, where:
·     -I connect_type—Specifies the connection method used to access the device to be managed. The connect_type argument is fixed to lanplus, which indicates that the device to be managed will be accessed as required in the IPMI 2.0 specification. The value lan is not supported by default. You need to enable RMCP in the Service Configuration.
·     -H hostnameSpecifies the IP address of the device to be managed.
·     -U username -P passwordSpecifies the HDM username and password of the device to be managed.
·     <command>—Specifies the action to be taken. This argument can be a string (chassis status for example) or a hexadecimal raw code (raw 0x00 0x01). For more information about this argument, see the specific command.
·     -L—Specifies the session privilege, which is Administrator by default. You can use this keyword to specify user privileges when establishing a session for access. The specified privileges and command privileges cannot be higher than the current user's privileges. When -L oem keyword is specified, the session privileges are consistent with the privileges of the current user.
User privileges
Available -L privileges
Administrator
Administrator, Operator, User, oem
Operator
Operator, User, oem
User
User, oem
CustomRole1-5
oem
·     The length of the raw code (raw 0x00 0x01) in a command cannot exceed 255 bytes.
·     In an OS environment with the BT channel enabled, if the ipmitool tool is used for a request and the returned content exceeds 250 bytes (excluding Completion Code), the command return is not supported or the excess part of the command will be truncated due to the limitations of the Linux system kernel driver. Be careful about data validity.
For some commands, the request and response will be displayed as a hexadecimal raw string. Table 1 and Table 2 display the example data fields in such a request and a response, respectively.
Table 1 Example data fields in a request
Data[1]
Specifies a single-byte field. The byte is displayed as 2-digit hexadecimal numbers. For more information, see the parameters of the specific command.
Data[1:3]
Specifies a multi-byte field. This field contains three bytes: Data[1], Data[2], and Data[3]. Each byte is displayed as 2-digit hexadecimal numbers. For more information, see the parameters of the specific command.
Table 2 Example data fields in a response
Data[1]
Specifies the first returned byte. For more information, see the response of the specific command.
Data[9:16]
Specifies the 9th to 16th returned bytes. For more information, see the response of the specific command.
Bits[7:1]
Specifies the seven highest bits of a byte. In a response, each byte contains eight bits: 7, 6, 5, 4, 3, 2, 1, and 0, where 7 represents the highest bit and 0 represents the second lowest bit.
Bits[5:4]
Specifies the fifth and fourth lowest bits of a byte. In a response, each byte contains eight bits: 7, 6, 5, 4, 3, 2, 1, and 0, where 7 represents the highest bit and 0 represents the second lowest bit.
HDM, HDM2, and HDM3 are the first-generation, second-generation, and third-generation management software for the H3C server baseboard controller, respectively. HDM is applicable to H3C G3 and G5 server products. Both HDM2 and HDM3 are compatible with H3C G6 servers. HDM3 is applicable to H3C G7 servers.
In this document, some commands may be compatible with G3, G5, and G6 products that use HDM and HDM2, so you might see explanations revision records that include compatibility and supported version information for products of earlier generations. Any revision records outlined in the Change history for HDM-1.xx/HDM-2.xx/HDM-3.xx/HDM2-x.xx are supported on HDM3-compatible products. The revision version numbers that apply to HDM3 will be named as HDM3-x.xx.
For the interface content of HDM and HDM2 products, see the manual applicable to the corresponding software version.
Interfaces described in this document are applicable to H3C G7 servers and H3C G6 servers that use HDM3.
Support for interface functions depends on the product specifications.
Permissions
Port description
Permission module
User accounts
Includes:
·     User management
·     Advanced password configuration
·     Directory management
·     Import or export
·     Unified management
Basic configuration
Includes:
·     Network configuration (network ports, NTP, SNMP, LLDP, DNS)
·     Alarm settings
·     Asset tag configurations.
Remote control,
Includes:
·     RAID
·     BIOS options
·     Boot items
·     UID
·     SOL
·     MCA policies
·     System resource monitoring threshold configuration
Remote media
Includes remote image mounting.
Security
Includes:
·     KVM configuration
·     VNC configuration
·     SSL
·     Firewall
·     Service configuration
Power control
Includes:
·     Power supply
·     Fans
·     Energy-saving control
·     NMI
Maintenance
Includes:
·     Log management
·     Video screenshots
·     Firmware management
·     Firmware restart
Password modification
Includes user self-password configuration.
System audit
Includes:
·     Event logs
·     Operation logs
·     One-click log downloading and exporting
Information query
Typically, GET interfaces have query permissions.
Chassis management
Use chassis status to obtain the current status of a chassis.
ipmitool -I connect_type -H hostname -U username -P password chassis status
Required permission
Information query
# Obtain the current chassis status.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ chassis status
System Power         : on
Power Overload       : false
Power Interlock      : inactive
Main Power Fault     : false
Power Control Fault  : false
Power Restore Policy : previous
Last Power Event     : command
Chassis Intrusion    : inactive
Front-Panel Lockout  : inactive
Drive Fault          : false
Cooling/Fan Fault    : false
Sleep Button Disable : allowed
Diag Button Disable  : allowed
Reset Button Disable : allowed
Power Button Disable : allowed
Sleep Button Disabled: true
Diag Button Disabled : true
Reset Button Disabled: true
Power Button Disabled: true
Use chassis restart_cause to obtain the reason for the most recent restart.
ipmitool -I connect_type -H hostname -U username -P password chassis restart_cause
Required permission
Information query
# Obtain the reason for the most recent restart.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_  chassis restart_cause
System restart cause: chassis power control command
Use chassis poh to obtain the total power-on time of a chassis.
ipmitool -I connect_type -H hostname -U username -P password chassis poh
Required permission
Information query
# Obtain the total power-on time of a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ chassis poh
POH Counter  : 8 days, 13 hours
Use chassis selftest to obtain the self-test result of a chassis.
When the BMC starts up, it performs a self-test on the FRUs. If no FRU information is detected, the test is considered failed.
ipmitool -I connect_type -H hostname -U username -P password chassis selftest
Required permission
Information query
# Obtain the self-test result of a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ chassis selftest
Self Test Results    : passed
Use power status to obtain the current power status of a chassis.
ipmitool -I connect_type -H hostname -U username -P password power status
Required permission
Information query
# Obtain the current power status of a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ power status
Chassis Power is on
Power on a chassis
Use power on to power on a chassis.
ipmitool -I connect_type -H hostname -U username -P password power { up | on }
Required permission
Power control
The up and on keyword function the same. You can use either keyword to power on the chassis.
# Power on a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ power on
Chassis Power Control: Up/On
Power off a chassis
Use power off to power off a chassis.
ipmitool -I connect_type -H hostname -U username -P password power { down | off }
Required permission
Power control
The down and off keyword function the same. You can use either keyword to power off the chassis.
# Power off a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ power off
Chassis Power Control: Down/Off
Restart a chassis
Use power reset to restart a chassis. This operation disconnects the server power.
ipmitool -I connect_type -H hostname -U username -P password power reset
Required permission
Power control
# Restart a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ power reset
Chassis Power Control: Reset
Use this command to trigger NMI diagnosis.
ipmitool -I connect_type -H hostname -U username -P password power diag
Required permission
Power control
# Trigger NMI diagnosis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ power diag
Chassis Power Control: Diag
Change history
Version
Change description
HDM-2.0.07
Added this command.
Use chassis policy to set the power-on policy that takes effect when the server is connected to the power source.
ipmitool -I connect_type -H hostname -U username -P password chassis policy power_policy
Table 3 Request field description
power_policy
Specify the power-on policy. Supported options:
·     always-on—Enables the server to power on automatically.
·     previous—Enables the server to return to the power state on the previous power-off.
·     always-off—Enables the server to stay off.
The power-on policy is previous. The server returns to the power state on the previous power-off.
Required permission
Power control
# Set the power-on policy for a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ chassis policy always-on
Set chassis power restore policy to always-on
Use chassis policy list to obtain the supported power-on policies of a chassis.
ipmitool -I connect_type -H hostname -U username -P password chassis policy list
Required permission
Information query
# Obtain the supported power-on policies of a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ chassis policy list
Supported chassis power policy:  always-off always-on previous
Use mc info to obtain server version information.
ipmitool -I connect_type -H hostname -U username -P password mc info
Required permission
Information query
# Obtain server version information from HDM 1.11.9.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ mc info
Device ID                 : 32
Device Revision           : 1
Firmware Revision         : 1.11
IPMI Version              : 2.0
Manufacturer ID           : 25506
Manufacturer Name         : Unknown (0x63A2)
Product ID                : 27 (0x001b)
Product Name              : Unknown (0x1B)
Device Available          : yes
Provides Device SDRs      : no
Additional Device Support :
    Sensor Device
    SDR Repository Device
    SEL Device
    FRU Inventory Device
    IPMB Event Receiver
    IPMB Event Generator
    Chassis Device
Aux Firmware Rev Info     :
    0x09
    0x00
    0x00
0x00
# Obtain server version information from HDM3 1.04.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin –P Password@_ mc info
DeviceID                  : 32
DeviceRevision            : 3
FirmwareRevision          : 1.04
IPMIVersion               : 2.0
ManufacturerName          : Unknown (0x63A2)
ProductID                 : 1 (0x0001)
ProductName               : Unknown (0x1)
DeviceAvailable           : yes
Provides Device SDRs      : yes
    Sensor Device
    SEL Device
    IPMB Event Receiver
    Chassis Device
    0x00
    0x00
    0x00
0x00
Change history
Version
Change description
HDM3-1.05
Added an example of HDM3.
Use mc guid to obtain the globally unique identifier (GUID) information of the server.
ipmitool -I connect_type -H hostname -U username -P password mc guid
Required permission
Information query
# Obtain server GUID information.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ mc guid
System GUID  : 65e3328a-1019-04b0-e611-0edc168afafa
Timestamp    : 03/02/2024 22:07:06
Use sdr to obtain the current status of sensors in a chassis.
ipmitool -I connect_type -H hostname -U username -P password sdr
ipmitool -I connect_type -H hostname -U username -P password sdr list
Required permission
Information query
This command returns the readings and status of all sensors in the chassis. The server is in healthy state only when all sensors are in heathy state.
# Obtain the current status and readings of all sensors in a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sdr
18-P/S 1 Zone    | 39 degrees C      | ok
19-P/S 2 Zone    | 36 degrees C      | ok
24-BMC Zone      | 44 degrees C      | ok
32-Outlet_Temp 1 | 45 degrees C      | ok
33-Outlet_Temp 2 | 41 degrees C      | ok
16-P/S 1         | 36 degrees C      | ok
17-P/S 2         | 36 degrees C      | ok
02-CPU 1         | 52 degrees C      | ok
03-CPU 2         | 51 degrees C      | ok
04-CPU 1 DTS     | -40 degrees C     | ok
05-CPU 2 DTS     | -41 degrees C     | ok
06-P1 DIMM Ch1-3 | 36 degrees C      | ok
07-P1 DIMM Ch4-6 | 38 degrees C      | ok
08-P2 DIMM Ch1-3 | 39 degrees C      | ok
25-PCI 1         | 61 degrees C      | ok
26-PCI 2         | no reading        | ns
28-PCI 1 Zone    | 44 degrees C      | ok
29-PCI 2 Zone    | no reading        | ns
10-Front HD Max  | 35 degrees C      | ok
12-Rear HD Max   | no reading        | ns
22-HD Controller | 38 degrees C      | ok
31-LOM Card      | 43 degrees C      | ok
01-Inlet Temp    | 28 degrees C      | ok
23-Expander Card | no reading        | ns
13-Rear HD Zone  | no reading        | ns
09-P2 DIMM Ch4-6 | 37 degrees C      | ok
15-PCH           | 55 degrees C      | ok
20-VR P1         | 43 degrees C      | ok
21-VR P2         | 45 degrees C      | ok
14-M.2 Zone      | no reading        | ns
FAN5_F_Speed     | 5000 RPM          | ok
FAN4_R_Speed     | no reading        | ns
FAN5_R_Speed     | 5300 RPM          | ok
FAN7_F_Speed     | 5000 RPM          | ok
FAN2_F_Speed     | 4900 RPM          | ok
FAN4_F_Speed     | no reading        | ns
FAN7_R_Speed     | 5200 RPM          | ok
FAN3_R_Speed     | 5200 RPM          | ok
FAN6_R_Speed     | 5300 RPM          | ok
FAN1_R_Speed     | 5300 RPM          | ok
FAN6_F_Speed     | 5000 RPM          | ok
FAN2_R_Speed     | 5300 RPM          | ok
FAN3_F_Speed     | 5000 RPM          | ok
FAN1_F_Speed     | 5000 RPM          | ok
CPU1_Status      | 0x80              | ok
CPU2_Status      | 0x80              | ok
PSU1_PIN         | 95 Watts          | ok
PSU2_PIN         | 85 Watts          | ok
PSU1_Status      | 0x01              | ok
PSU2_Status      | 0x01              | ok
FAN1_F_Status    | 0x01              | ok
FAN2_F_Status    | 0x01              | ok
FAN3_F_Status    | 0x01              | ok
FAN4_F_Status    | Not Readable      | ns
FAN5_F_Status    | 0x01              | ok
FAN6_F_Status    | 0x01              | ok
FAN7_F_Status    | 0x01              | ok
FAN1_R_Status    | 0x01              | ok
FAN2_R_Status    | 0x01              | ok
FAN3_R_Status    | 0x01              | ok
FAN4_R_Status    | Not Readable      | ns
FAN5_R_Status    | 0x01              | ok
FAN6_R_Status    | 0x01              | ok
FAN7_R_Status    | 0x01              | ok
27-PCI 3         | no reading        | ns
30-PCI 3 Zone    | no reading        | ns
SEL_sensor       | 0x00              | ok
Watchdog2        | 0x00              | ok
OverCurrent      | 0x01              | ok
11-Front NVMe    | no reading        | ns
AreaIntrusion    | 0x00              | ok
CPU1_DDR_VPP1    | 2.58 Volts        | ok
CPU1_DDR_VDDQ1   | 1.22 Volts        | ok
CPU1_Vcore       | 1.78 Volts        | ok
CPU2_DDR_VPP2    | 2.58 Volts        | ok
CPU2_DDR_VPP1    | 2.58 Volts        | ok
CPU2_DDR_VDDQ2   | 1.22 Volts        | ok
CPU2_DDR_VDDQ1   | 1.22 Volts        | ok
CPU1_DDR_VPP2    | 2.58 Volts        | ok
CPU1_DDR_VDDQ2   | 1.22 Volts        | ok
CPU2_Vcore       | 1.78 Volts        | ok
PSU1_VIN         | 231.60 Volts      | ok
PSU2_VIN         | 232.80 Volts      | ok
SYS_3V3          | 3.28 Volts        | ok
SYS_5V           | 5.12 Volts        | ok
SYS_3V_BAT       | 3.28 Volts        | ok
SYS_12V          | 12 Volts          | ok
HDD_BP3_12V      | no reading        | ns
HDD_BP2_12V      | no reading        | ns
HDD_BP1_12V      | no reading        | ns
PSU2_VOUT        | 12 Volts          | ok
PSU1_VOUT        | 11.88 Volts       | ok
CPU2_VDDQ1_PG    | 0x01              | ok
CPU1_VDDQ2_PG    | 0x01              | ok
CPU2_DDR_VPP2_PG | 0x01              | ok
CPU2_VDDQ2_PG    | 0x01              | ok
SYS_5V_STBY_PG   | 0x01              | ok
BP_1_PG          | 0x01              | ok
BP_2_PG          | 0x01              | ok
CPU1_DDR_VPP2_PG | 0x01              | ok
BP_3_PG          | 0x01              | ok
CPU1_DDR_VPP1_PG | 0x01              | ok
CPU2_DDR_VPP1_PG | 0x01              | ok
CPU1_VDDQ1_PG    | 0x01              | ok
CPU2_DIMM_B1     | Not Readable      | ns
CPU1_DIMM_A6     | 0x40              | ok
CPU2_DIMM_B5     | Not Readable      | ns
CPU2_DIMM_B2     | 0x40              | ok
CPU1_DIMM_A1     | Not Readable      | ns
CPU2_DIMM_B4     | Not Readable      | ns
CPU1_DIMM_A4     | Not Readable      | ns
CPU1_DIMM_A7     | Not Readable      | ns
CPU2_DIMM_B3     | Not Readable      | ns
CPU2_DIMM_B7     | Not Readable      | ns
CPU2_DIMM_B8     | Not Readable      | ns
CPU1_DIMM_A8     | Not Readable      | ns
CPU2_DIMM_B6     | 0x40              | ok
CPU1_DIMM_A5     | Not Readable      | ns
CPU1_DIMM_A2     | Not Readable      | ns
CPU1_DIMM_A3     | 0x40              | ok
Use this command to obtain information about a sensor type in a chassis.
ipmitool -I connect_type -H hostname -U username -P password sdr type
ipmitool -I connect_type -H hostname -U username -P password sdr type sdr_type
Table 4 Request field description
sdr_type
Specify a sensor type.
Required permission
Information query
·     Obtain the list of supported sensor types in a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sdr type
Sensor Types:
        Temperature                 Voltage
        Current                     Fan
        Physical Security           Platform Security
        Processor                   Power Supply
        Power Unit                  Cooling Device
        Other                       Memory
        Drive Slot / Bay            POST Memory Resize
        System Firmwares            Event Logging Disabled
        Watchdog                    System Event
        Critical Interrupt          Button
        Module / Board              Microcontroller
        Add-in Card                 Chassis
        Chip Set                    Other FRU
        Cable / Interconnect        Terminator
        System Boot Initiated       Boot Error
        OS Boot                     OS Critical Stop
        Slot / Connector            System ACPI Power State
        Watchdog                    Platform Alert
        Entity Presence             Monitor ASIC
        LAN                         Management Subsystem Health
·     Obtain information about power supply sensors in a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sdr type "Power Supply"
PWR_On_TMOUT     | 97h | ok   |  7.3   |     Presence detected
PSU1_Status             | C4h | ok  | 10.1 |      Presence detected
PSU2_Status             | C5h | ok  | 10.2 |      Presence detected
PSU_Redundant       | C6h | ok  | 10.127 |   Fully Redundant
PSU_Mismatch         | C7h | ok  | 10.126 |
Use sensor list to obtain the list of supported sensors in a chassis.
ipmitool -I connect_type -H hostname -U username -P password sensor list
Required permission
Information query
# Obtain the list of supported sensors in a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sensor list
Sensor Name    | Reading    | Unit       | Status| Crit low  | Major low | Minor low | Minor high| Major high| Crit high
18-P/S 1 Zone    | 39.000     | degrees C  | ok    | na        | na        | na        | 95.000    | 100.000   | na
19-P/S 2 Zone    | 36.000     | degrees C  | ok    | na        | na        | na        | 95.000    | 100.000   | na
24-BMC Zone      | 44.000     | degrees C  | ok    | na        | na        | na        | 95.000    | 100.000   | na
32-Outlet_Temp 1 | 45.000     | degrees C  | ok    | na        | na        | na        | 95.000    | 100.000   | na
33-Outlet_Temp 2 | 41.000     | degrees C  | ok    | na        | na        | na        | 95.000    | 100.000   | na
16-P/S 1         | 36.000     | degrees C  | ok    | na        | na        | na        | 60.000    | 62.000    | na
17-P/S 2         | 36.000     | degrees C  | ok    | na        | na        | na        | 60.000    | 62.000    | na
02-CPU 1         | 52.000     | degrees C  | ok    | na        | na        | na        | na        | na        | na
03-CPU 2         | 51.000     | degrees C  | ok    | na        | na        | na        | na        | na        | na
04-CPU 1 DTS     | -40.000    | degrees C  | ok    | na        | na        | na        | -1.000    | na        | na
05-CPU 2 DTS     | -41.000    | degrees C  | ok    | na        | na        | na        | -1.000    | na        | na
06-P1 DIMM Ch1-3 | 36.000     | degrees C  | ok    | na        | na        | na        | 89.000    | 95.000    | na
07-P1 DIMM Ch4-6 | 38.000     | degrees C  | ok    | na        | na        | na        | 89.000    | 95.000    | na
08-P2 DIMM Ch1-3 | 39.000     | degrees C  | ok    | na        | na        | na        | 89.000    | 95.000    | na
25-PCI 1         | 60.000     | degrees C  | ok    | na        | na        | na        | 90.000    | 100.000   | na
26-PCI 2         | na         | degrees C  | na    | na        | na        | na        | 90.000    | 100.000   | na
28-PCI 1 Zone    | 44.000     | degrees C  | ok    | na        | na        | na        | 95.000    | 100.000   | na
29-PCI 2 Zone    | na         | degrees C  | na    | na        | na        | na        | 95.000    | 100.000   | na
10-Front HD Max  | 35.000     | degrees C  | ok    | na        | na        | na        | 60.000    | na        | na
12-Rear HD Max   | na         | degrees C  | na    | na        | na        | na        | 60.000    | na        | na
22-HD Controller | 38.000     | degrees C  | ok    | na        | na        | na        | 90.000    | 99.000    | 102.000
31-LOM Card      | 43.000     | degrees C  | ok    | na        | na        | na        | 90.000    | 100.000   | na
01-Inlet Temp    | 28.000     | degrees C  | ok    | na        | na        | na        | 50.000    | 52.000    | 54.000
23-Expander Card | na         | degrees C  | na    | na        | na        | na        | 100.000   | 120.000   | 125.000
13-Rear HD Zone  | na         | degrees C  | na    | na        | na        | na        | 95.000    | 100.000   | na
09-P2 DIMM Ch4-6 | 37.000     | degrees C  | ok    | na        | na        | na        | 89.000    | 95.000    | na
15-PCH           | 54.000     | degrees C  | ok    | na        | na        | na        | 92.000    | 102.000   | na
20-VR P1         | 43.000     | degrees C  | ok    | na        | na        | na        | 110.000   | 112.000   | na
21-VR P2         | 45.000     | degrees C  | ok    | na        | na        | na        | 110.000   | 112.000   | na
14-M.2 Zone      | na         | degrees C  | na    | na        | na        | na        | 95.000    | 100.000   | na
FAN5_F_Speed     | 5000.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN4_R_Speed     | na         | RPM        | na    | na        | na        | na        | na        | na        | na
FAN5_R_Speed     | 5300.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN7_F_Speed     | 5000.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN2_F_Speed     | 5000.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN4_F_Speed     | na         | RPM        | na    | na        | na        | na        | na        | na        | na
FAN7_R_Speed     | 5200.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN3_R_Speed     | 5200.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN6_R_Speed     | 5300.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN1_R_Speed     | 5300.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN6_F_Speed     | 5000.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN2_R_Speed     | 5300.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN3_F_Speed     | 5000.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
FAN1_F_Speed     | 5000.000   | RPM        | ok    | na        | na        | na        | na        | na        | na
CPU1_Status      | 0x0        | discrete   | 0x8080| na        | na        | na        | na        | na        | na
CPU2_Status      | 0x0        | discrete   | 0x8080| na        | na        | na        | na        | na        | na
PSU1_PIN         | 95.000     | Watts      | ok    | na        | na        | na        | na        | na        | na
PSU2_PIN         | 85.000     | Watts      | ok    | na        | na        | na        | na        | na        | na
PSU1_Status      | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
PSU2_Status      | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN1_F_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN2_F_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN3_F_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN4_F_Status    | na         | discrete   | na    | na        | na        | na        | na        | na        | na
FAN5_F_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN6_F_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN7_F_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN1_R_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN2_R_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN3_R_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN4_R_Status    | na         | discrete   | na    | na        | na        | na        | na        | na        | na
FAN5_R_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN6_R_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
FAN7_R_Status    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
27-PCI 3         | na         | degrees C  | na    | na        | na        | na        | 90.000    | 100.000   | na
30-PCI 3 Zone    | na         | degrees C  | na    | na        | na        | na        | 95.000    | 100.000   | na
SEL_sensor       | 0x0        | discrete   | 0x0080| na        | na        | na        | na        | na        | na
Watchdog2        | 0x0        | discrete   | 0x0080| na        | na        | na        | na        | na        | na
OverCurrent      | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
11-Front NVMe    | na         | degrees C  | na    | na        | na        | na        | 70.000    | na        | na
AreaIntrusion    | 0x0        | discrete   | 0x0080| na        | na        | na        | na        | na        | na
CPU1_DDR_VPP1    | 2.580      | Volts      | ok    | na        | 2.340     | na        | na        | 2.760     | na
CPU1_DDR_VDDQ1   | 1.220      | Volts      | ok    | na        | 1.080     | na        | na        | 1.320     | na
CPU1_Vcore       | 1.780      | Volts      | ok    | na        | 1.330     | na        | na        | 1.880     | na
CPU2_DDR_VPP2    | 2.580      | Volts      | ok    | na        | 2.340     | na        | na        | 2.760     | na
CPU2_DDR_VPP1    | 2.580      | Volts      | ok    | na        | 2.340     | na        | na        | 2.760     | na
CPU2_DDR_VDDQ2   | 1.220      | Volts      | ok    | na        | 1.080     | na        | na        | 1.320     | na
CPU2_DDR_VDDQ1   | 1.220      | Volts      | ok    | na        | 1.080     | na        | na        | 1.320     | na
CPU1_DDR_VPP2    | 2.580      | Volts      | ok    | na        | 2.340     | na        | na        | 2.760     | na
CPU1_DDR_VDDQ2   | 1.220      | Volts      | ok    | na        | 1.080     | na        | na        | 1.320     | na
CPU2_Vcore       | 1.780      | Volts      | ok    | na        | 1.330     | na        | na        | 1.880     | na
PSU1_VIN         | 232.800    | Volts      | ok    | na        | na        | na        | na        | na        | na
PSU2_VIN         | 235.200    | Volts      | ok    | na        | na        | na        | na        | na        | na
SYS_3V3          | 3.280      | Volts      | ok    | na        | 2.960     | na        | na        | 3.600     | na
SYS_5V           | 5.120      | Volts      | ok    | na        | 4.480     | na        | na        | 5.520     | na
SYS_3V_BAT       | 3.280      | Volts      | ok    | na        | 2.000     | na        | na        | 3.680     | na
SYS_12V          | 12.000     | Volts      | ok    | na        | 10.800    | na        | na        | 13.200    | na
HDD_BP3_12V      | na         | Volts      | na    | na        | na        | na        | na        | na        | na
HDD_BP2_12V      | na         | Volts      | na    | na        | na        | na        | na        | na        | na
HDD_BP1_12V      | na         | Volts      | na    | na        | na        | na        | na        | na        | na
PSU2_VOUT        | 12.000     | Volts      | ok    | na        | na        | na        | na        | na        | na
PSU1_VOUT        | 11.880     | Volts      | ok    | na        | na        | na        | na        | na        | na
CPU2_VDDQ1_PG    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
CPU1_VDDQ2_PG    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
CPU2_DDR_VPP2_PG | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
CPU2_VDDQ2_PG    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
SYS_5V_STBY_PG   | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
BP_1_PG          | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
BP_2_PG          | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
CPU1_DDR_VPP2_PG | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
BP_3_PG          | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
CPU1_DDR_VPP1_PG | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
CPU2_DDR_VPP1_PG | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
CPU1_VDDQ1_PG    | 0x0        | discrete   | 0x0180| na        | na        | na        | na        | na        | na
CPU2_DIMM_B1     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU1_DIMM_A6     | 0x0        | discrete   | 0x4080| na        | na        | na        | na        | na        | na
CPU2_DIMM_B5     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU2_DIMM_B2     | 0x0        | discrete   | 0x4080| na        | na        | na        | na        | na        | na
CPU1_DIMM_A1     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU2_DIMM_B4     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU1_DIMM_A4     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU1_DIMM_A7     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU2_DIMM_B3     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU2_DIMM_B7     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU2_DIMM_B8     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU1_DIMM_A8     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU2_DIMM_B6     | 0x0        | discrete   | 0x4080| na        | na        | na        | na        | na        | na
CPU1_DIMM_A5     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU1_DIMM_A2     | na         | discrete   | na    | na        | na        | na        | na        | na        | na
CPU1_DIMM_A3     | 0x0        | discrete   | 0x4080| na        | na        | na        | na        | na        | na
Table 5 Response field description
Status
Sensor status. Supported options:
·     na—A sensor is absent.
·     ok—A sensor is operating correctly.
·     nc—A minor error occurs on a sensor.
·     cr—A major error occurs on a sensor.
·     nr—A critical error occurs on a sensor. The error is not recoverable.
Use sensor get to obtain status information of a fan in a chassis.
ipmitool -I connect_type -H hostname -U username -P password sensor get FAN_Status
Table 6 Request field description
FAN_Status
Specify the name of a fan status sensor, for example, FAN1_Status and FAN2_Status.
Required permission
Information query
Make sure the specified sensor name is correct. To obtain the names of supported sensors, execute the sensor list command.
# Obtain status information of a fan in a chassis.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sensor get FAN1_Status
Locating sensor record...
Sensor ID              : FAN1_Status (0x60)
 Entity ID             : 30.0
 Sensor Type (Discrete): Fan
 States Asserted       : Availability State
                         [Transition to Running]
sensor list
Use sensor get to obtain the rotation speed information of a fan.
ipmitool -I connect_type -H hostname -U username -P password sensor get FAN_Speed
Table 7 Request field description
FAN_Speed
Specify the name of a fan speed sensor, for example, FAN1_Speed and FAN2_Speed.
Required permission
Information query
# Obtain the rotation speed information of a fan.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sensor get FAN1_Speed
Sensor ID              : FAN1_Speed (0x70)
 Entity ID             : 29.0
 Sensor Type (Analog)  : Fan
 Sensor Reading        : 3400 (+/- 0) RPM
 Status                : ok
 Lower Non-Recoverable : na
 Lower Critical        : na
 Lower Non-Critical    : na
 Upper Non-Critical    : na
 Upper Critical        : na
 Upper Non-Recoverable : na
 Assertion Events      :
 Assertions Enabled    :
sensor list
Use mc selftest to perform a server self-test on HDM.
ipmitool -I connect_type -H hostname -U username -P password mc selftest
Required permission
Information query
# Perform a server self-test on HDM.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ mc selftest
Selftest: passed
Reset HDM
Use mc reset to reset HDM.
ipmitool -I connect_type -H hostname -U username -P password mc reset warm
Table 8 Request field description
warm
Specify warm reset. This operation resets HDM without disconnecting the system power.
Required permission
Maintenance
# Reset HDM.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ mc reset warm
Sent warm reset command to MC
Use sensor reading to obtain the reading of a sensor.
ipmitool -I connect_type -H hostname -U username -P password sensor reading sensor_id
Table 9 Request field description
sensor_id
Specify the sensor name.
Required permission
Information query
You can use this command to obtain only readings of continuous sensors, such as temperature, voltage, current, power, and speed sensors.
# Obtain the reading of a sensor.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sensor reading FAN5_F_Speed
FAN5_F_Speed     | 5000
sensor list
Use sensor thresh to set the alarm threshold for a sensor.
ipmitool -I connect_type -H hostname -U username -P password sensor thresh sensor_id threshold value
Table 10 Request field description
sensor_id
threshold
Specify the threshold type. Table 11 displays the available threshold types.
value
Specify the threshold value.
Table 11 Available threshold types
unr
Upper critical alarm threshold.
ucr
Upper major alarm threshold.
unc
Upper minor alarm threshold.
lnr
Lower critical alarm threshold.
lcr
Lower major alarm threshold.
lnc
Lower minor alarm threshold.
lower
Specifies all lower alarm thresholds in the following order: lower minor, lower major, and lower critical.
upper
Specifies all upper alarm thresholds in the following order: upper minor, upper major, and upper critical.
Required permission
Maintenance
CAUTION
CAUTION:
As a best practice, perform this task under professional guidance.
# Set the upper minor, upper major, and upper critical thresholds of the HDM temperature sensor to 70°C (158°F), 80°C (176°F), and 90°C (194°F), respectively.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sensor thresh "24-BMC Zone" upper  70 80 90
Locating sensor record '24-BMC Zone'...
Setting sensor "24-BMC Zone" Upper Non-Critical threshold to 70.000
Setting sensor "24-BMC Zone" Upper Critical threshold to 80.000
Setting sensor "24-BMC Zone" Upper Non-Recoverable threshold to 90.000
sensor list
Change history
Version
Change description
HDM3-1.13
Use sel to obtain SEL information.
ipmitool -I connect_type -H hostname -U username -P password sel
Required permission
Information query
# Obtain SEL information.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ sel
SEL Information
Version          : 1.5 (v1.5, v2 compliant)
Entries          : 175
Free Space       : 62352 bytes
Percent Used     : 4%
Last Add Time    : 01/01/2018 08:00:27
Last Del Time    : Not Available
Overflow         : false
Supported Cmds   : 'Delete' 'Partial Add' 'Reserve' 'Get Alloc Info'
# of Alloc Units : 1500
Alloc Unit Size  : 18
# Free Units     : 3464
Largest Free Blk : 3464
Max Record Size  : 13
Use fru to obtain FRU information.
ipmitool -I connect_type -H hostname -U username -P password fru
Required permission
Information query
# Obtain FRU information.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ fru
FRU Device Description : Builtin FRU Device (ID 0)
 Chassis Type           : Rack Mount Chassis
 Chassis Part Number    : 0200A00T
 Chassis Serial         : 210200A00TH177000016
 Chassis Extra          : User Defined
 Chassis Extra          : 74EACB5A5D7C
 Chassis Extra          : 6
 Chassis Extra          : FC9612PW11
 Board Mfg Date        : Fri Jul 14 00:00:00 2017
 Board Mfg             : ABC
 Board Product         : RS23M2C3S
 Board Serial          : 02A3U0H176000003
 Board Part Number     : 0302A3U0
 Board Extra           : 210235A2DBH177000014
 Product Manufacturer  : Unis Huashan Technologies Co., Ltd.
 Product Name          : UniServer R2700 G3
 Product Part Number   : 0200A00T
 Product Serial        : 210200A00TH177000016
 Product Asset Tag     : @!!
FRU Device Description : Expander (ID 1)
 Device not present (Requested sensor, data, or record not found)
FRU Device Description : BackPanel1 (ID 2)
 Board Mfg Date        : Thu Apr 20 08:00:00 2017
 Board Mfg             : ABC
 Board Product         : RS33B08SA
 Board Serial          : 02A3GNH174000023
 Board Part Number     : 0302A3GN
 Board Extra           : 02A3GNH174000023
FRU Device Description : HBA_Raid (ID 12)
 Board Mfg Date        : Sat Jun 17 08:00:00 2017
 Board Mfg             : ABC
 Board Product         : RS33H2P8SA
 Board Serial          : 02A3H0H176000047
 Board Part Number     : 0302A3H0
 Board Extra           : 02A3H0H176000047
FRU Device Description : BackPanel2 (ID 13)
FRU Device Description : mLOM (ID 3)
 Unknown FRU header version 0xff
FRU Device Description : PcieCard1 (ID 5)
FRU Device Description : PcieCard2 (ID 8)
FRU Device Description : BackPanel3 (ID 14)
FRU Device Description : Riser1 (ID 16)
 Board Mfg Date        : Thu Jun  8 08:00:00 2017
 Board Mfg             : ABC
 Board Product         : RS33RGPX16
 Board Serial          : 02A3H9H176000059
 Board Part Number     : 0302A3H9
 Board Extra           : 02A3H9H176000059
FRU Device Description : Riser2 (ID 17)
FRU Device Description : M.2 (ID 15)
FRU Device Description : Mezzine (ID 19)
FRU Device Description : LP_Card (ID 20)
FRU Device Description : MB BMC (ID 21)
 Product Manufacturer  : ABC
 Product Name          : BMC
 Product Part Number   : HDM
 Product Version       : 1.11.09
FRU Device Description : MB BIOS (ID 22)
 Product Name          : BIOS
 Product Part Number   : C35
 Product Version       : 1.01.04
Use session info to obtain information about the current HDM sessions.
ipmitool -I connect_type -H hostname -U username -P password session info { active | all | id id | handle handle }
Table 12 Request field description
active
Specify active sessions.
all
Specify all sessions.
id id
Specify the ID of a user, in the 0xnnnnnnnn format.
handle handle
Specify a session handle, in the 0xnn format.
Required permission
Information query
# Obtain information about active sessions.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ session info active
session handle                : 13
slot count                    : 36
active sessions               : 1
user id                       : 2
privilege level               : ADMINISTRATOR
session type                  : IPMIv2/RMCP+
channel number                : 0x01
console ip                    : 192.16.1.196
console mac                   : 2c:41:38:9f:9b:ab
console port                  : 2043
Use this command to obtain server power status and UID LED status.
ipmitool -I connect_type -H hostname -U username -P password raw 0x00 0x01
Required permission
Information query
# Obtain server power status and UID LED status.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x00 0x01
 41 01 40 f0
Table 13 Response field description
Data[1]
Bits[7:1]: N/A
Bit[0]: Current power status. Supported options:
·     1b—Power-on.
·     0b—Power-off.
Data[2]
N/A
Data[3]
Bit[7]: Reserved.
Bit[6]: Indicates whether UID LED is supported. Supported options:
·     1b—Supported.
·     0b—Not supported.
Bits[5:4]: UID LED status.
·     Supported options for G3:
¡     00bOff.
¡     01b—Steady on.
¡     10b—Flashing.
¡     11b—Reserved.
·     Supported options for G5/G6/G7:
¡     00bOff.
¡     01b—Flashing.
¡     10b—Steady on.
¡     11bReserved.
For G3/G5, bits[3:0]: N/A
For G6/G7, bits [3:1]: N/A
For G6/G7, [0] – Whether chassis intrusion detection is supported, where 1b indicates that chassis intrusion detection is supported, and 0b indicates that chassis intrusion detection is not supported.
Data[4]
N/A
Change history
Version
Change description
HDM3-1.09
HDM2-1.57
Added support for identifying whether chassis intrusion detection is supported.
HDM-2.0.04
Changed the UID LED status for G5 servers to the standard.
Use this command to set server UID LED status.
ipmitool -I connect_type -H hostname -U username -P password raw 0x00 0x04 sec uid_state ac_uid
Table 14 Request field description
Request field
sec
Specify the state duration, where 0 indicates a permanent state.
uid_state
Specify the status of the UID LED. Supported options:
·     0x00: On.
·     0x01: Off.
ac_uid
Not specified/0-0xff
Table 15 UID LED action
Value of sec
Value of uid_state
Value of ac_uid
LED action
Not specified
Not specified
Not specified
Flash for 15 seconds
0-0xff
Not specified
Not specified
Flash for the specified seconds. If sec is 0, the command turns off the LED.
0-0xff
0x01
Not specified//0-0xff
Steady on for the specified seconds. A sec value of 0 represents permanently on.
·     If the value for ac_uid is not specified, the UID LED is steady on for the specified seconds.
·     If the value for ac_uid is not specified, a sec value of 0 represents permanently on.
·     If you specify a value for ac_uid and a sec value of 0 represents permanently on:
¡     An ac_uid value of non-zero represents that the LED is off after an AC or BMC restart.
¡     An ac_uid value of 0 represents that the UID LED status does not change after an AC or BMC restart.
0-0xff
0x00
·     If sec is 0, the command turns off the UID LED.
·     If sec is not 0, the UID LED flashes for the specified seconds. After the flashing ends, the UID LED will be off.
·     No ac_uid value can take effect.
Required permission
Remote control
# Configure the server UID LED to flash for 15 seconds.
COMMAND> ipmitool-I lanplus-H 127.0.0.1 –U admin –P Password@_ raw 0x00 0x04
# Configure the server UID LED to flash for 2 seconds.
COMMAND>ipmitool –I lanplus –H 127.0.0.1 –U admin –P Password@_raw 0x00 0x04 0x2
# Configure the server UID LED to be steady on.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x00 0x04 0x00 0x01
# Turn off the server UID LED.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x00 0x04 0x00 0x00
# Configure the server UID LED to be steady on after an AC or BMC restart.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x00 0x04 0x00 0x01 0x01
Change history
Version
Change description
HDM2-1.53
Added the field for setting the UID LED status after an AC or BMC restart.
Use this command to obtain FRU information and saves the information to the fru.bin file in the current directory.
ipmitool -I connect_type -H hostname -U username -P password fru read ID  directory/xxx.bin
Required permission
Information query
# Obtain system board FRU information and save the information to the current directory.
COMMAND>ipmitool -I lanplus -H 192.168.30.41 -U admin -P Password@_ fru read 0 ./fru.bin
Fru Size         : 992 bytes
Done
Change history
Version
Change description
HDM-2.0.07
Added this command.
User management
Use user list to obtain information about all HDM users.
ipmitool -I connect_type -H hostname -U username -P password user list
Required permission
Information query
# Obtain information about all HDM users.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ user list
ID  Name             Callin  Link Auth  IPMI Msg   Channel Priv Limit
1                    false   false      true       ADMINISTRATOR
2   admin            false   false      true       ADMINISTRATOR
Use user summary to obtain brief HDM user information.
ipmitool -I connect_type -H hostname -U username -P password user summary
Required permission
Information query
# Obtain brief HDM user information.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ user summary
Maximum IDs         : 16
Enabled User Count  : 2
Fixed Name Count    : 2
Add an HDM user
Use user set name to add an HDM user.
ipmitool -I connect_type -H hostname -U username -P password user set name user_id username
Table 16 Request field description
user_id
Specify a user ID. Make sure the user ID is no larger than the value of the Maximum IDs field in the output from the user summary command.
username
Specify a username, a case-sensitive string of 1 to 16 characters. Only letters, digits, dots (.), hyphens (-), underscores (_), and at signs (@) are allowed.
The administrator users exist and the usernames are admin and anonymous.
Required permission
User accounts
If the specified user ID already exists with a different username, the command changes the existing username of the user.
To add a user, you must also specify the password, enable HDM access, and specify the HDM user role for the user.
# Add an HDM user, set the user ID to 9, and specify the username as test.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ user set name 9 test
# View information about all HDM users.
9   test             true    false      false      NO ACCESS
user set password
user enable
user priv
Change history
Version
Change description
HDM2-1.20
Added a default administrator user and support for at signs (@).
Use user set password to set the password for an HDM user.
ipmitool -I connect_type -H hostname -U username -P password user set password user_id password
Table 17 Request field description
user_id
Specify a user ID. Make sure the user ID already exists.
password
Specify the password string, a case-sensitive string. The password can contain 16 characters. Only letters, digits, spaces, and the following special characters are allowed: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
When password complexity check is disabled, the password must contain 2 to 20 characters.
When password complexity check is enabled, all passwords must meet the following requirements:
·     The password must contain 8 to 20 characters and is case-sensitive.
·     Only letters, digits, spaces, and the following special characters are allowed: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
·     The password must contain characters from a minimum of two categories: uppercase letters, lowercase letters, and digits.
·     The password must contain a minimum of one space or special character.
·     The password cannot be the same as the username or the reversed username.
·     The password must comply with Password history count requirements.
Password history count: Specifies the number of most recent history passwords that cannot be reused.
No password is set for an HDM user.
Required permission
User accounts/Password modification
To add a user, you must specify a password for the user.
# Specify a password for the user whose ID is 9.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ user set password 9 123
user set name
user enable
user priv
Change history
HDM2
Added password complexity description. You can configure this feature from the Web interface.
Use user test to verify an HDM user password.
ipmitool -I connect_type -H hostname -U username -P password user test user_id password_max_len_type password
Table 18 Request field description
user_id
Specify the user ID. Make sure the specified user ID already exists.
Specify the password length. Options include 16 and 20.
password
Specify the password.
Required permission
# Verify the password of the HDM user whose user ID is 9.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ user test 9 16 123
Success
// The system returns success for a valid password.
Disable HDM access
Use user disable to disable HDM access for a user.
ipmitool -I connect_type -H hostname -U username -P password user disable user_id
Table 19 Request field description
user_id
HDM access is enabled for the default user admin and disabled for manually added users.
Required permission
# Disable HDM access for the user whose user ID is 9.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ user disable 9
Enable HDM access
Use user enable to enable HDM access for a user.
Table 20 Request field description
user_id
Required permission
For a manually added user to access HDM, you must enable HDM access for the user.
# Enable HDM access for the user whose user ID is 9.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ user enable 9
user set name
user set password
user priv
Use this command to delete an HDM user.
ipmitool -I connect_type -H hostname -U username -P password raw 0x06 0x45 user_id 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff
Table 21 Request field description
user_id
Required permission
User accounts
# Delete the HDM user whose user ID is 9.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x06 0x45 0x09 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff
Use user priv to specify the HDM user role for a user.
ipmitool -I connect_type -H hostname -U username -P password user priv user_id privilege_level
The HDM user role of the default user admin is administrator and the HDM user role of a manually added user is none.
Table 22 Request field description
user_id
privilege_level
Specify the HDM user role. Supported options:
·     2—Specifies the user role. The user has read-only permission.
·     3—Specifies the operator role. The user has read permission to all features and has write permission to some features.
·     4Specifies the administrator role. The user has read and write permissions to all features.
·     6 to 10—Custom 1 to 5.
·     15—None. The user does not have network access permissions.
Required permission
User accounts
For a manually added user to access HDM, you must use this command to specify non-none HDM user role for the user.
Some ipmitool tools verify user permissions and support only one OEM permission (privilege_level=0x05). The ipmitool-1.8.8 supports configuring the privilege level in the range of 6 to 10.
# Specify the administrator role for the user whose ID is 9.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ user priv 9 4
user set name
user set password
user enable
user priv
Change history
Version
HDM-2.0.04
Added user roles custom 1 to 5.
HDM IPv4 management
Use this command to obtain the IP address obtaining method for a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x02 Data[1] 0x04 0x00 0x00
Table 23 Request field description
Data[1]
G3:
·     0x01—Specifies the shared network port.
·     0x08Specifies the dedicated network port.
G5/G6:
·     0x01—Specifies the dedicated network port.
·     0x08Specifies the shared network port.
Required permission
Information query
# Obtain the IP address obtaining method for the shared network port.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x02 0x01 0x04 0x00 0x00
 11 01
Table 24 Response field description
Data[1]
This field is fixed to 0x11.
Data[2]
IP address obtaining method. Supported options:
·     01Static IP.
·     02DHCP.
Change history
Version
Change description
HDM-2.0.03
The HDM user role was changed as follows:
G3:
G5:
·     0x08—Specifies the shared network port.
Use user priv to obtain the IP address of a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x02 Data[1] 0x03 0x00 0x00
Table 25 Request field description
Data[1]
G3:
G5/G6:
Required permission
Information query
# Use a in-band system command to obtain the IP address the shared network port.
COMMAND>ipmitool raw 0x0c 0x02 0x01 0x03 0x00 0x00
 11 c0 a8 32 a6
Table 26 Response field description
Data[1]
Data[2:5]
IP address of the network port, in hexadecimal notation.
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Use this command to obtain the MAC address of a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x02 Data[1] 0x05 0x00 0x00
Table 27 Request field description
Data[1]
G3:
G5/G6:
Required permission
Information query
# Obtain the MAC address of the shared network port.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x02 0x01 0x05 0x00 0x00
 11 30 7b ac 76 0f 65
Table 28 Response field description
Data[1]
Data[2:7]
MAC address of the network port.
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Use this command to obtain the subnet mask of a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x02 Data[1] 0x06 0x00 0x00
Table 29 Request field description
Data[1]
G3:
G5/G6:
Required permission
Information query
# Obtain the subnet mask of the shared network port.
Table 30 Response field description
Data[1]
Data[2:5]
Subnet mask of the network port.
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Use this command to obtain the gateway address.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x02 Data[1] 0x0c 0x00 0x00
Table 31 Request field description
Data[1]
G3:
G5/G6:
Required permission
Information query
# Obtain the gateway address of the shared network port.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x02 0x01 0x0c 0x00 0x00
 11 c0 a8 32 01
Table 32 Response field description
Data[1]
Data[2:5]
IP address of the gateway, in hexadecimal notation.
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Use this command to set the IP address obtaining method for a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x01 Data[1] 0x04 Data[2]
Table 33 Request field description
Data[1]
G3:
G5/G6:
Data[2]
Specify IP obtaining method. Supported options:
·     01—Static IP.
·     02—DHCP.
Required permission
Basic configuration
# Set the IP obtaining method of the shared network port to DHCP.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x01 0x01 0x04 0x02
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Use this command to specify a static IP address for a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x01 Data[1] 0x03 Data[2:5]
Table 34 Request field description
Data[1]
G3:
G5/G6:
Data[2:5]
Specify an IP address, in hexadecimal notation.
No IP address is specified for a network port.
Required permission
Basic configuration
This command is available only when the IP obtaining method is static for the network port.
# Specify a static IP address for the shared network port.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x01 0x01 0x03 0xc0 0x10 0x01 0x4e
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Use this command to specify a subnet mask for a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x01 Data[1] 0x06 Data[2:5]
Table 35 Request field description
Data[1]
G3:
G5/G6:
Data[2:5]
Specify a subnet mask, in hexadecimal notation.
No subnet mask is specified for a network port.
Required permission
Basic configuration
# Specify a subnet mask for the shared network port.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x01 0x01 0x06 0xff 0x00 0x00 0x00
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Specify the gateway address for a network port
Use this command to specify a gateway address for a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x01 Data[1] 0x0c Data[2:5]
Table 36 Request field description
Data[1]
G3:
G5/G6:
Data[2:5]
Specify a gateway address, in hexadecimal notation.
No gateway address is specified for a network port.
Required permission
Basic configuration
Make sure the gateway address is in the same network segment as the IP address of the network port.
# Specify a gateway address for the shared network port.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x01 0x01 0x0c 0xc0 0xa8 0x32 0x01
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
HDM IPv6 management
Obtain the IPv6 address of a network port
Use this command to obtain the IPv6 address of a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x02 Data[1] 0xcf 0x00 0x00
Table 37 Request field description
Data[1]
G3:
G5/G6:
Required permission
Information query
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x02 0x08 0x0cf 0x00 0x00
 11 fe 80 00 00 00 00 00 00 ee d6 8a ff fe 3c 0d 2f
Table 38 Response field description
Data[1]
Data[2:17]
IPv6 address of the network port, in hexadecimal notation.
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Specify a static IPv6 address for a network port
Use this command to specify a static IP address for a network port. Make sure the IP address set by this command is not in the same network segment as other IPv6 addresses (except for the gateway).
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x01 Data[1] 0x38 0x00 0x80 Data[2:17] Data[18] 0x00
Table 39 Request field description
Data[1]
G3:
G5/G6:
Data[2:17]
Specify an IPv6 address, in hexadecimal notation.
Data[18]
Specify the IPv6 prefix, in hexadecimal notation.
A port obtains an IPv6 address through DHCP.
Required permission
Basic configuration
In bonding mode, the specified IPv6 address also applies to the bond port (bond0).
# Specify a static IPv6 address for the shared network port.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x01 0x01 0x38 0x00 0x80 0x20 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x40 0x00
Change history
Version
Change description
HDM2-1.60
Added the static routing function and the following usage guideline:
HDM-2.0.03
G3:
G5:
Specify the prefix length for a network port
Use this command to specify a prefix length for a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x01 Data[1] 0xc6 Data[2] Data[3]
Table 40 Request field description
Data[1]
G3:
G5/G6:
Data[2]
Specify the position of the IPv6 prefix. This field is fixed to 0.
Data[3]
Specify the prefix length.
A port obtains a prefix length address through DHCP.
Required permission
Basic configuration
This command is available only when a static IPv6 address has been specified for the network port.
# Set the prefix length to 72 for the shared network port.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x01 0x01 0xc6 0x00 0x48
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Obtain the prefix length of a network port
Use this command to obtain the prefix length of a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x02 Data[1] 0xc6 0x00 0x00
Table 41 Request field description
Data[1]
G3:
G5/G6:
Required permission
Information query
# Obtain the prefix length of the shared network port.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x02 0x08 0xc6 0x00 0x00
 11 40
Table 42 Response field description
Data[1]
Data[2]
Prefix length, in hexadecimal notation.
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Obtain the IPv6 address obtaining method for a network port
Use this command to obtain the IPv6 address obtaining method for a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x02 Data[1] 0xc4 0x00 0x00
Table 43 Request field description
Data[1]
G3:
G5/G6:
Required permission
Information query
# Obtain the IPv6 address obtaining method for the shared network port.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x02 0x01 0xc4 0x00 0x00
 11 01
Table 44 Response field description
Data[1]
Data[2]
IPv6 address obtaining method. Supported options:
·     01Static IP.
·     02DHCP.
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
Set the IPv6 address obtaining method for a network port
Use this command to set the IPv6 address obtaining method for a network port.
After setting the IPv6 address obtaining method, you must also change the DNS obtaining method (DNSDHCP) also needs to be changed accordingly.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x01 Data[1] 0xc4 Data[2]
Table 45 Request field description
Data[1]
G3:
G5/G6:
Data[2]
Specify the IPv6 obtaining method. Supported options:
·     01Static IP.
·     02—DHCP.
Required permission
Basic configuration
# Change the IPv6 address obtaining method from static to DHCP for the shared network port.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x01 0x01 0xc4 0x02
Change history
Version
Change description
HDM2-1.57
Removed the usage guidelines.
HDM-2.0.03
G3:
G5:
Specify the IPv6 gateway address for a network port
Use this command to specify the IPv6 gateway address for a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0c 0x01 Data[1] 0xc7 Data[2:17]
Table 46 Request field description
Data[1]
G3:
G5/G6:
Data[2:17]
Specify an IPv6 gateway address, in hexadecimal notation.
No IPv6 gateway address is specified for a network port.
Required permission
Basic configuration
This command is available only when the IPv6 obtaining method is static for the network port.
Make sure the IPv6 gateway address is in the same network segment as the IPv6 address of the network port.
# Specify an IPv6 gateway address for the shared network port.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0c 0x01 0x01 0xc7 0x3f 0xfe 0x05 0x01 0xee 0xee 0x00 0x02 0x3a 0x91 0xd5 0xff 0xfe 0xec 0x60 0xd3
Change history
Version
Change description
HDM-2.0.03
G3:
G5:
System boot
Set the one-time next boot option
Use chassis bootdev to set the one-time next boot option.
ipmitool -I connect_type -H hostname -U username -P password chassis bootdev boot_mode boot_mode
Table 47 Request field description
boot_mode
Specify the boot option. Options include drive, cdrom, and pxe.
The server starts from the boot option configured in the BIOS.
Required permission
Remote control
# Set the one-time next boot option to cdrom.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ chassis bootdev cdrom
Set Boot Device to cdrom
Remove the configured one-time next boot option
Use chassis bootdev none to remove the configured one-time next boot option and enable the server to start from the boot option configured in the BIOS.
ipmitool -I connect_type -H hostname -U username -P password chassis bootdev none
Required permission
Remote control
# Remove the configured one-time next boot option.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ chassis bootdev none
Configure the server to enter the BIOS setup utility after startup
Use chassis bootdev bios to configure the server to enter the BIOS setup utility after startup.
ipmitool -I connect_type -H hostname -U username -P password chassis bootdev bios
The server starts up as configured in the BIOS.
Required permission
Remote control
# Configure the server to enter the BIOS setup utility after startup.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ chassis bootdev bios
Set Boot Device to bios
Device extended commands
Hardware information
Obtain the number of present PCIe modules
Use this command to obtain the number of present PCIe modules, including storage controllers and AIC NVMe drives.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x1f
Required permission
Information query
# Obtain the number of present PCIe modules.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x1f
 a2 63 00 03
Table 48 Response field description
Data[1:3]
Manufacturer ID. This field is fixed to a2 63 00.
Data[4]
Number of present PCIe modules.
Obtain PCIe module information
Use this command to obtain information about PCIe modules, including storage controllers, GPUs, NICs, and U.2 NVMe drives.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x20 pcie_index
Table 49 Request field description
pcie_index
Specify the index of the PCIe module, starting from 0. The value range varies by device model.
Required permission
Information query
# Obtain information about the PCIe module with index 2.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x20 0x02
a2 63 00 03 00 86 80 d1 37 86 80 00 00 3d 3d 01
01 19 01 4e 49 43 2d 47 45 2d 34 50 2d 33 36 30
54 2d 4c 33 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 01 00 31 2e
31 37 36 37 2e 30 00 00 00 00 00 00 00 00 00 00
00 00 01 00 30 32 41 33 47 4b 48 31 37 42 30 30
30 32 36 37 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 30 33 30 32 41 33 47 4b 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00
00 00 00 04 00 00 00 00 00 00 00 00 00 00 00  19
00 00 00 00 00 00 00 00 01 ff 00 00 00
Table 50 Response field description
Data[1:3]
Data[4:5]
Slot number.
Data[6:7]
Vendor ID.
Data[8:9]
Device ID.
Data[10:11]
Sub vendor ID.
Data[12:13]
Sub device ID.
Data[14:15]
Bus number. The lower bytes come first.
Data[16]
Current speed.
·     1—2.5GT/s.
·     2—5.0GT/s.
·     3—8.0GT/s.
·     4—16.0GT/s.
·     532.0GT/s.
Data[17]
Current bandwidth.
·     1x1.
·     2x2.
·     4x4.
·     8x8.
·     16x16.
Data[18]
Max speed.
·     25—2.5GT/s.
·     50—5.0GT/s.
·     80—8.0GT/s.
·     96—16.0GT/s.
·     160—16.0GT/s.
·     255—Invalid. See Data[172-173].
Data[19]
PCIe generation.
Data[20:59]
Product name.
Data[60]
PCIe status. Supported options:
·     0—Normal.
·     1—Abnormal.
·     2—Absent.
Data[61]
Page display. Supported options:
·     0—No.
·     1—Yes.
Data[62]
Alarm status. Options:
·     0—Normal.
·     1—Alarm triggered.
Data[63:70]
Reserved. This field is 0 by default.
Data[63:82]
Firmware version.
Data[83:84]
Network adapter port speed.
Data[85-116]
Serial number. The serial number has 32 characters and ends with \0.
Data[117-141]
Part number. The part number has 25 characters and ends with \0.
Data[142]
Specify the network port type. Supported options:
·     0x00Not adapted to any network adapters or is not a network adapter.
·     0x01Fiber port.
·     0x02Copper port.
Data[143]
PciBaseClassCode.
Data[144]
PciSubClassCode.
Data[145]
PCIe bus range.
Data[146]
Device ID.
Data[147]
Function ID.
Data[148]
Network adapter ports.
Data[149]
CPU bus.
Data[150
CPU device.
Data[151]
CPU function.
Data[152]
CPU ID. 0xff represents invalid values.
Data[153-168]
Slot description.
Data[169]
PCIe device type.
·     0Not present.
·     1Ethernet.
·     2—GPU.
·     3—FC HBA.
·     4—IB.
·     5—RAID/HBA.
·     6—M.2 NVMe.
·     7—AIC NVMe.
·     8—Retimer.
·     9—Switch.
·     10—M.2.
·     11U2 NVME (not supported).
·     12—REDRIVER.
·     13QAT.
·     14Clock card.
·     15MOC card.
·     18PCIeAux card.
Data[170]
Card bandwidth. Maximum number of PCIe lanes supported.
Data[171]
Segment
Data[172-173]
Max speed extension, which has the same function with Data[18]. Pay attention to this field for speeds equal to or greater than 32.0GT/s. This field is displayed in little-endian format.
·     25—2.5GT/s.
·     50—5.0GT/s.
·     80—8.0GT/s.
·     96—16.0GT/s.
·     160—16.0GT/s.
·     320—32.0GT/s.
Change history
Version
Change description
HDM2-2.04
Added a value of 18 to Data[169].
HDM2-1.18
·     Added a value of 5 (32.0GT/s) to Data[16].
·     Added a value of 255 for indicating invalidity to Data[18]. If 255 is returned, pay attention to Data[172-173].
·     Added Data[172-173] (MaxSpeedExt).
HDM2-1.12
Added the segment field.
HDM2
Added the NicPortType field.
Obtain information about the specified PCIe module
Use this command to obtain information about PCIe modules, including storage controllers, GPUs, network adapters, and U.2 NVMe drives.
Table 51 Request field description
pcie_index
Required permission
Information query
# Obtain information about the PCIe module with index 1.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0xc5 0x01
a2 63 00 02 00 b3 15 1b 10 b3 15 07 00 02 00 00
00 00 00 01 02 00 00 49 42 2d 4d 43 58 36 35 33
31 30 35 41 2d 48 44 41 54 2d 32 30 30 47 62 2d
31 50 00 00 00 00 00 00 00 00 00 00 00 00 00 4d
54 32 32 34 32 34 30 31 32 45 30 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4d
43 58 36 35 33 31 30 35 41 2d 48 44 41 54 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Table 52 Response field description
Data[1:3]
Data[4:5]
Slot number.
Data[6:7]
Vendor ID.
Data[8:9]
Device ID.
Data[10:11]
Sub vendor ID.
Data[12:13]
Sub device ID.
Data[14:15]
Data[16]
Device ID.
Data[17]
Function ID.
Data[18]
Segment.
Data[19]
CpuBus.
Data[20]
CpuDevice.
Data[21]
CpuFunction.
Data[22]
CpuSegment.
Data[23]
Data[24:63]
Product name.
Data[64:95]
Data[96:120]
Data[121:250]
Reserved.
Change history
Version
Change description
HDM3-2.04
Added the command.
Obtain port information on an Ethernet adapter
Use this command to obtain information about ports on an Ethernet adapter.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x16 pcie_slot
Table 53 Request field description
pcie_slot
Specify the number of the PCIe slot in which the network adapter resides.
Required permission
Information query
# Obtain information about ports on the Ethernet adapter in slot 9.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x16 0x09
 a2 63 00 04 01 09 74 ea cb 5a 5d 7e 02 09 74 ea
 cb 5a 5d 7f 03 09 74 ea cb 5a 5d 80 04 09 74 ea
 cb 5a 5d 81 00 00 00 00 00 00 00 00 00 00 00 00
Table 54 Response field description
Data[1:3]
Data[4]
Number of ports on the Ethernet adapter.
Data[5:132]
Detailed port information, including port number (1 byte), slot number (1 byte), and MAC address (6 bytes). Information about each port occupies eight bytes and a maximum of 16 ports are supported. If a port is absent, 0x00 is displayed in the output.
Obtain the number of supported CPUs and DIMMs
Use this command to obtain the number of supported CPUs and DIMMs.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x0b
Required permission
Information query
# Obtain the number of supported CPUs and DIMMs.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x0b
 a2 63 00 ff 02 18 0c 00 00 00 00 00 00
Table 55 Response field description
Data[1:3]
Data[4]
Base board type. Supported options:
·     20h—V5R1.
·     00h—UIS.
·     28h—CR16K.
·     ffh—Unknown.
This field is available only for G2 servers. For G3 or new products, this field is ignored.
Data[5]
Maximum number of CPUs, in hexadecimal notation.
Data[6]
Maximum number of DIMMs, in hexadecimal notation.
Data[7]
Maximum number of DIMMs supported by each CPU, in hexadecimal notation.
Data[8:13]
Change history
Version
Change description
HDM3-1.09
Supplemented the application scope of Data[4] to indicate that the field has been discarded for new products.
Obtain CPU information
Use this command to obtain the presence status and parameters of a CPU.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x07 cpu_id
Table 56 Request field description
cpu_id
Specify the ID of a CPU, starting from 0. The value range varies by device model.
Required permission
Information query
# Obtain CPU information (non-Phytium platform).
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x07 0x00
a2 63 00 00 01 00 00 41 4d 44 20 45 50 59 43 20
39 35 35 35 20 36 34 2d 43 6f 72 65 20 50 72 6f
63 65 73 73 6f 72 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 01 08 fc 00 80 0c 02 00 20
00 80 00 40 20 80 01 17 8b fb ff 00 b0 0f 21 03
80 f2 71 2a 05 b7 02 03 80 f2 71 2a 05 b7 02 30
11 00 0a 00 00 00 80 00 00 00 00 02 00 00 00 00
20 00 00
# Obtain CPU information (Phytium platform).
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x07 0x01
a2 63 00 01 01 00 00 53 35 30 30 30 43 2d 36 34
00 00 00 00 00 00 00 01 02 ec 00 34 08 04 00 20
00 20 00 40 40 40 01 00 00 00 00 70 0f 86 20 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 34
08 00 10 00 00 00 80 00 00 00 80 00 00 00 00 00
4b 50 41 35 36 34 31 35 30 33 31 31 30 30 30 00
20 00 00
Table 57 Response field description
Data[1:3]
Data[4]
CPU number.
Data[5]
Presence status of the CPU. Supported options:
·     0hAbsent.
·     1hPresent.
Data[6]
Data source. Supported options:
·     00hBIOS.
·     01hAgent.
·     OthersReserved.
Data[7]
Version field. This field is reserved and is 0 by default.
Data[8:71]
CPU model. The model ends with \0.
Data[72]
CPU status. Supported options:
·     00hUnavailable.
·     01hGood.
Data[73]
Number of memory controller (MC).
Data[74:75]
Features supported by processors:
·     BIT0Reserved.
·     BIT1Unknown.
·     BIT264-bit capable.
·     BIT3Multi-core.
·     BIT4Hardware thread.
·     BIT5Execute protection.
·     BIT6Enhanced virtualization.
·     BIT7Power/Performance control.
·     BIT8-15Reserved.
Data[76:77]
Base frequency, in MHz.
Data[78:79]
L1 cache, in little endian format, in MB. Keep the original value.
If the original value is not a multiple of 1024, truncation will occur during unit conversion. To obtain the accurate value, use Data[114-117].
Data[80:81]
L2 cache, in little endian format, in MB.
Data[82:83]
L3 cache, in little endian format, in MB.
Data[84]
Total number of cores.
Data[85]
Number of available cores.
Data[86]
Number of threads.(lower byte).
Data[87]
Cache units for each level in Data[78:83]:
·     0—KB.
·     1—MB.
·     2—GB.
Data[88:95]
CPU ID, in little endian format.
This field is not supported by the Phytium platform. For the Phytium platform, the field value is fixed to 00.
Data[96:103]
Reserved.
Data[104:111]
CPU PPIN, in little endian format.
Data[112:113]
Maximum CPU frequency, in MHz and in little endian format.
Data[114:117]
L1 cache, in KB.
Data[118:121]
L2 cache, in KB.
Data[122:125]
L3 cache, in KB.
Data[126]
Number of threads (higher byte).
Data[127:128]
TDP value.
Data[129-144]
Processor CHIP ID, in little endian format.
This field is supported only by the Phytium platform. For other platforms, the field value is fixed to 00.
Data[145-146]
Actual number of threads (lower byte).
Data[147]
Reserved.
Change history
Version
Change description
HDM3-1.19
Added the Data[145-146] field to display the actual number of threads. If the field displays only 00 00, the BIOS does not obtaining the actual number of threads.
HDM3-1.09
Supplemented description for the Data[127-128] TDP field.
Added the Data[129-144] CHIP ID field.
Changed the reserved field to Data[145].
HDM2-1.62
Changed the description for Data[96-103] to Reserved because the returned content of this field is incomplete.
HDM2-1.53
Revised the description for Data[74-75] to describe processor features based on bits.
HDM2-1.18
Revised cache description for Data[78-83] to indicate the possibility of truncation.
HDM2-1.14
Added Data[126] to specify the number of threads (higher byte), and revised the number of threads (lower byte) in Data[86].
HDM2
Added Data[114:125] to specify the cache unit for each level.
HDM-1.30.13
Added the maximum CPU frequency field.
HDM-1.30.08
Added the CPU SN and CPU PPIN fields.
Obtain memory information
Use this command to obtain memory information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x08 Memory_Index
Table 58 Request field description
Memory_Index
Specify the index of a DIMM.
Required permission
Information query
# Obtain memory information for DIMM 8 in a G6 product.
COMMAND>ipmitool -I lanplus -H 192.168.38.88 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x08 0x08
a2 63 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 08 01 00 00 04 00 02 01 4d
33 32 31 52 34 47 41 33 42 42 30 2d 43 51 4b 56
45 00 00 22 00 02 52 44 49 4d 4d 00 00 00 00 00
00 00 00 00 00 00 00 ce 00 80 00 00 c0 12 c0 12
00 30 31 41 35 39 32 44 44 00 00 00 00 00 00 00
00
Table 59 Response field description
Data[1:3]
Data[4-55]
G3 memory information. For more information, see Table 60.
Data[56-177]
G5/G6/G7 memory information. For more information, see Table 61.
Table 60 G3 memory information
Data[4]
Channel number.
Data[5]
Presence status. Supported options:
·     00hAbsent.
·     01hPresent.
Data[6]
·     00h—BIOS.
·     01hAgent.
·     OthersReserved.
Data[7]
CPU number. Supported options:
·     00hCPU 1.
·     01hCPU 2.
Data[8]
Channel number.
Data[9]
DIMM number in the channel.
Data[10]
DIMM authentication status. Supported options:
·     02hGenuine.
·     03hPiracy.
·     OthersReserved.
Data[11]
DIMM status. Supported options:
·     0—Unavailable or disabled.
·     1Available.
·     2Abnormal.
·     3Not initialized.
Data[12:31]
Part number.
Data[32]
DIMM type. Supported options:
·     18hDDR3.
·     1ah—DDR4.
·     1bh—LPDDR.
·     1ch—LPDDR2.
·     1dh—LPDDR3.
·     1eh—LPDDR4.
·     Others—N/A.
Data[33]
Operating voltage. Supported options:
·     00h—1.1 V.
·     01h—1.35 V.
·     03h—1.2 V.
Data[34]
Bits[7:4]: Reserved.
Bits[3:0]: DIMM ranks.
Data[35]
Memory technology. Supported options:
·     00h—RDIMM.
·     01h—UDIMM.
·     02h—SODIMM.
·     09h—LRDIMM.
·     Others—N/A.
Data[36:37]
Vendor number.
Data[38:41]
DIMM capacity, in MB.
Data[42:43]
Current frequency, in MT/s.
Data[44:45]
Maximum frequency, in MT/s.
Data[46]
Support for ECC. Supported options:
·     00h—Not supported.
·     01h—Supported.
Data[47:54]
Memory serial number.
Data[55]
Reserved. This field can be extended and is 0 by default.
Table 61 G5/G6/G7 memory information
Data[56]
DIMM ID.
Data[57]
·     00hAbsent.
·     01hPresent.
Data[58]
·     00h—BIOS.
·     01hAgent.
·     OthersReserved.
Data[59]
·     00hCPU 1.
·     01hCPU 2.
Data[60]
Channel number.
Data[61]
Data[62]
·     02hGenuine.
·     03hPiracy.
·     OthersReserved.
Data[63]
·     1Available.
·     2Abnormal.
·     3—Not initialized.
Data[64:83]
Part number
Data[84]
·     18hDDR3.
·     1ah—DDR4.
·     1bh—LPDDR.
·     1ch—LPDDR2.
·     1dh—LPDDR3.
·     1eh—LPDDR4.
·     22hLPDDR5.
·     Others—N/A.
Data[85]
·     00h1.1V.
·     01h—1.35 V.
·     03h—1.2 V.
Data[86]
Data[87:102]
·     00h—RDIMM.
·     01h—UDIMM.
·     02h—SODIMM.
·     09h—LRDIMM.
Data[103:104]
Vendor number.
Data[105:108]
Data[109:110]
Data[111:112]
Data[113]
·     01h—Supported.
Data[114:145]
Data[146]
Memory UCE fault count (supported only by G6/G7 products)
Data[147]
Memory total bit width (supported only by G6/G7 products)
Data[148]
Memory data bit width (supported only by G6/G7 products)
Data[149:177]
Change history
Version
Change description
HDM2
Added LPDDR5 support, added the memory total bit width and memory data bit width fields, and changed the frequency unit to MT/s.
HDM-2.0.05
Added Data[56:177] to obtain G5 memory information.
Obtain product generation
Use this command to obtain the product generation information for G3, G5, G6, and G7 products and the HDM software.
This command does not have operation log records.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x05 0xa2 0x63 0x00 0x02
Required permission
Information query
Product compatibility
UIS, G3, G5, G6, and G7 products.
# Obtain product generation. In this example, this is a G3 product and the HDM software is used.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x05 0xa2 0x63 0x00 0x02
a2 63 00 34 40 00 5a 04 11 03 01 06 00 00 00 00
00 00 00
# Obtain product generation. In this example, this is a G6 product and the HDM2 software is used.
a2 63 00 68 03 00 5a 08 23 06 01 00 00 02 00 00
00 00 00
# Obtain product generation. In this example, this is a G6 product and the HDM2 software is used (even if the return HDM generation value is 0).
a2 63 00 68 03 00 5a 08 23 06 01 00 00 00 00 00
00 00 00
# Obtain product generation. In this example, this is a G7 product and the HDM3 software is used.
COMMAND>ipmitool -I lanplus -H 192.168.50.166-U admin -P Password@_ raw 0x36 0x05 0xa2 0x63 0x00 0x02
a2 63 00 71 00 00 5a 01 01 07 63 00 00 03 00 00
00 00 00
Table 62 Response field description
Data[1:3]
Data[4:9]
Reserved.
Data[10]
Product generation:
·     1Early UIS product.
·     3—G3.
·     5—G5.
·     6—G6.
·     7—G7.
Data[11:13]
Reserved.
Data[14]
HDM generation information:
·     0—HDM.
·     2—HDM2.
·     3—HDM3.
For G6 products, the generation is HDM2 even if the return value is 0.
Data[15:19]
Reserved.
Change history
Version
Change description
HDM3-1.05
·     Added a value of 7 that represent G7 products for product generation information.
·     Added a value of 3 that represents HDM3 for HDM generation information.
·     Added examples for HDM3.
HDM2-1.61
Use the reserved field Data[14] to represent the HDM software generation information.
Added examples for HDM2.
Obtain expander information
Use this command to obtain expander information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xA2 0x63 0x00 0x8d Exp_Index
Table 63 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code (0x8D).
Data[7]
Expander index.
Required permission
Information query
Not restricted to specific products.
# Obtain expander information.
COMMAND>ipmitool -H 127.0.0.1 -I lanplus -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x8d 0x01
Response values:
a2 63 00 02 01 46 72 6f 6e 74 42 61 63 6b 50 61
6e 65 6c 34 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 30 32 41 32 4e 33 31 32 33 34 35
36 37 38 39 30 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 30 33 30 32 41 32 4e 34 00 00 00
00 00 00 00 00 33 2e 30 30 2e 30 31 00 00 00 00
00 00 00 00 00 33 2e 33 32 2e 30 31 00 00 00 00
00 00 00 00 00
Data[1-3]
Data[4]
Number of expanders.
Data[5]
Expander index.
Data[6-37]
Expander location.
Data[38-69]
Expander serial number.
Data[70-101]
Expander part number.
Data[102-117]
Expander firmware version.
Data[118-133]
Current expander configuration file.
Change history
Version
Change description
HDM-2.25
Added this command.
Obtain server health status
Use this command to obtain the health status of the server and its subsystems.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x05 0xa2 0x63 0x00 0x0a
Required permission
Information query
Table 64 Response field description
Data[1:3]
Manufacturer ID. This field is in the range of 0 to 2.
Data[4]
System health status. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[5]
Health status of the temperature subsystem. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[6]
Health status of the voltage subsystem. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[7]
Health status of the power subsystem. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[8]
Health status of the heat dissipation subsystem. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[9]
Health status of the memory system, including storage controllers, physical drives, and logical drives. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[10]
Health status of the TPM system. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[11]
System power status. Supported options:
·     00hOn.
·     01hOff.
Data[12]
Memory health status. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[13]
CPU health status. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[14]
PCI health status. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[15]
mLOM (G3)/OCP (G5) health status. This field is not supported by G6 products.
Supported options:
·     00hThe mLOM/OCP network adapter is present.
·     01hThe mLOM/OCP network adapter is absent.
·     02hThe mLOM/OCP network adapter is present but failed to be identified.
·     03hThe mLOM/OCP network adapter is absent but the NIC port is present.
Data[16]
Electrical current health status. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[17]
Logical drive health status. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[18]
Health LED status. Supported options:
·     3—Amber.
·     2Red.
·     1Green.
·     0Off.
Data[19]
Reserved.
Data[20]
Server board health status. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Data[21]
Operating system health status. Supported options:
·     00hNormal.
·     01hMinor.
·     02hMajor.
·     03hCritical.
Change history
Version
Change description
HDM2-1.55
Extended Data[8] to include the heat dissipation subsystem, which contains the fan system and the liquid cooling system.
HDM2
MLOM|OCP network adapter health status (not supported by G6 products).
HDM-2.51
Revised errors in the system power-on status output information.
HDM-2.16.00
Added support for G5 OCP health status.
HDM-2.13.00
Data[19] was reserved.
HDM-2.0.07
Added the operating system health status field.
HDM-1.30.14
Added the system module health status field.
HDM-1.30.13
Added the redirected page for the PCIe health LED field.
HDM-1.30.11
Added the health LED status field.
HDM-1.30.10
Added the logical drive status field.
Obtain OCP network adapter status
Use this command to obtain the status of OCP network adapters.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x05 0xa2 0x63 0x00 0x10
Table 65 Request field description
Data[1]
NetFn code.
Data[2]
Cm Command code.
Data[0]
0xa2 ManufactureID0.
Data[1]
0x63 ManufactureID1.
Data[2]
0x00 ManufactureID2.
Data[3]
0x10 Subcommand.
Required permission
Information query
Table 66 Response field description
Data[1:3]
Data[4]
Current number of OCP adapters.
Data[5]
Whether network adapter port information exists:
·     0No.
·     1Yes.
Data[6]
OCP1 status. Supported options:
·     FFh—The device model does not support this OCP.
Data[7]
OCP2 status. Supported options:
Data[8]
OCP3 status. Supported options:
Data[9]
Reserved
Change history
Version
Change description
HDM-2
Added this command.
Host
Obtain security bezel LED configuration
Use this command to obtain security bezel LED configuration.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0a 0xA2 0x63 0x00 0x0c
Table 67 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Information query
G5, G6, and G7 rack servers (servers compatible with security bezels are supported)
# Obtain security bezel LED configuration.
COMMAND>ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0a 0xA2 0x63 0x00 0x0c
a2 63 00 01 01 01 01 01 01 01 01
Table 68 Response field description
Data[1-3]
Data[4]
·     0Absent.
·     1Present.
Data[5]
Logo LED:
·     0—Off.
·     1—On.
Data[6]
LED:
·     0—Off.
·     1—On.
Data[7]
Status sync:
·     0—Off.
·     1—On.
Data[8]
Health status sync:
·     0—Off.
·     1—On.
Data[9]
Energy saving mode:
·     0—Off.
·     1—On.
Data[10]
Decorative LEDs:
·     1—Breathing.
·     2—Flashing.
·     3—Steady on.
Data[11]
Decorative LEDs color:
·     1—White.
·     2—Orange.
·     3—Red.
Change history
Version
Change description
HDM-2.25
Added the health status sync field.
HDM-2.13.00
Added this command.
Set security bezel LEDs
Use this command to set security bezel LEDs.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xA2 0x63 0x00 0x69 0x01 0x01 0x01 0x01 0x01 0x01 0x01
Table 69 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Set the logo LED state:
·     0—Off.
·     1—On.
Data[8]
Set the LED state:
·     0—Off.
·     1—On.
Data[9]
Set the status sync feature:
·     0—Off.
·     1—On.
Data[10]
Set the health status sync feature:
·     0—Off.
·     1—On.
Data[11]
Set the energy saving mode:
·     0—Off.
·     1—On.
X10000 G5 and X10000 G6 servers do not support this field.
Data[12]
Set the flashing mode of decorative LEDs:
·     1—Breathing.
·     2—Flashing.
·     3—Steady on.
Data[13]
Set the color of decorative LEDs:
·     1—White.
·     2—Orange.
·     3—Red.
X10000 G5 and X10000 G6 servers support only the white color.
Required permission
Basic configuration
# Set security bezel LEDs.
COMMAND>ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xA2 0x63 0x00 0x69 0x01 0x01 0x01 0x01 0x01 0x01 0x01
0xa2 0x63 0x00
Table 70 Response field description
Data[1-3]
Change history
Version
Change description
HDM2-1.58
Added description for support of X10000 G6 servers.
HDM-2.25
HDM-2.13.00
Added this command.
Obtain MCA policy information
Use this command to obtain MCA policy and ACD status information.
ipmitool -I connect_type  -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x53 0x00 0x00
Table 71 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Manufacture ID. This field is fixed to a2 63 00.
Data[6]
Subcommand code.
Data[7]
Obtain the enabling status of MCA restart upon error occurrence and ACD (AMD models do not involve ACD).
Data[8]
Reserved.
Required permission
Information query
Intel products and AMD G6 products are supported.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x53 0x00 0x00
a2 63 00 00 01
Table 72 Response field description
Data[1:3]
Data[4]
Enabling status of MCA restart upon error occurrence. Supported options:
·     0x01—Do not restart the server upon error occurrence.
·     0x00—Restart the server upon error occurrence.
Data[5]
ACD enabling status. This field is not applicable to AMD models, and the system returns the default value 0x01. Supported options:
·     0x01Enabled.
·     0x00Disabled.
Change history
Version
Change description
HDM3-1.16
Added this command to HDM3.
HDM2-1.11
ADDC upgrade.
HDM-1.30.15P02
Added the ACD enabling status field.
Configure MCA policy settings
Use this command to configure the MCA policy and ACD.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xa2 0x63 0x00 0x35 0x01/0x00 0x01
Table 73 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Data[8]
ACD enabling status. This field is not supported by AMD models and is thus reserved. For AMD models, the system returns a random value. Supported options:
·     0x01Enable.
·     0x00—Disable. Only G3 servers support the 0x00 option. G5/G6 servers do not support the 0x00 option, and the system will return an error code if you set this field to 0x00.
Required permission
Remote control
All devices that use Intel CPUs support this command. For AMD processors, only G6 products support this command.
# Configure MCA policy settings.
COMMAND>ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xa2 0x63 0x00 0x35 0x01 0x01
a2 63 00 00 00
Table 74 Response field description
Data[1:3]
Data[4:5]
Reserved.
Change history
Version
Change description
HDM3-1.16
HDM2-1.11
ADDC upgrade.
HDM-2.16.00
G5 servers do not support the 0x00 option for the ACD enabling status field.
HDM-1.30.15P02
Storage
Obtain storage controller list information
Use this command to obtain storage controller list information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x01 0x00 0x00 0x00 0x00
Table 75 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length. This field is fixed to 0.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168. 30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x01 0x00 0x00 0x00 0x00
a2 63 00 32 00 00 00 01 00 02 00 08 00 00 02 01
01 52 41 49 44 2d 4c 53 49 2d 39 35 36 30 2d 4c
50 2d 31 36 69 2d 38 47 42 00 00 00 00 00 00 00
Table 76 Response field description
Data[1:3]
Data[4:7]
Length of the remaining response fields.
Data[8:9]
Specify the number of storage controllers.
Data[10:11]
Specify the total number of logical drives managed by storage controllers.
Data[12:13]
Specify the total number of physical drives managed by storage controllers.
Data[14]
Specify the ID of the first storage controller (CtrlID).
Data[15]
Specify the PCIe slot number of the first storage controller.
Data[16]
Specify the status of the first storage controller. Supported options:
·     1—Normal.
·     2—Powered off.
·     3—Not present.
·     4—Faulty.
·     5—The BIOS is being initialized.
Data[17]
Specify the type of the out-of-band management channel used by the first storage controller. Supported options:
·     01I2C.
·     02PCIe.
·     0xFFNot supported.
Data[18:49]
Specify the model of the first storage controller, a string of 0 to 31 characters.
Data[50:57]
Specify the reserved field for the first storage controller.
Data[58:101]
Information about the second storage controller.
Data[102:145]
Information about the third storage controller.
Data[146:189]
Information about the fourth storage controller.
Change history
Version
Change description
HDM2
Added this command.
Obtain information about the specified storage controller
Use this command to obtain information about the specified storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x02 0x00 0x00 0x01 0x00 [#CtrlID]
Table 77 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Specify the data length. This value is fixed to 1.
Data[11]
Specify the ID of a storage controller (CtrlID).
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x02 0x00 0x00 0x00 0x01 0x00
a2 63 00 4c 01 00 00 00 02 04 00 00 e2 10 00 10
00 40 00 10 08 01 01 04 35 30 30 30 36 32 42 32
30 38 36 31 34 36 30 30 00 00 00 00 52 41 49 44
2d 4c 53 49 2d 39 35 36 30 2d 4c 50 2d 31 36 69
2d 38 47 42 00 00 00 00 00 00 00 00 53 4b 42 33
39 38 30 33 32 39 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 35 2e 31 36
30 2e 30 32 2d 33 34 31 35 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 35 32 2e 31
36 2e 30 2d 33 38 30 33 00 00 00 00 00 00 00 00
30 30 2e 30 30 2d 30 33 39 33 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 30 2f 31 2f
35 2f 36 2f 31 30 2f 35 30 2f 36 30 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 4d 69 73 73
00 00 00 00 00 00 00 00 00 00 00 00 28 ff 00 ff
ff 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00
Table 78 Response field description
Data[1:3]
Data[4:7]
Data[8]
ID of the storage controller.
Data[9]
PCIe slot number of the storage controller.
Data[10]
Reserved.
Data[11]
Health status. Supported options:
·     0x0Unknown.
·     0x1OK (Healthy).
·     0x2Warning (Minor alarm).
·     0x3Critical (Major alarm).
Data[12]
Alarm severity. Supported options:
·     0x00Info.
·     0x01Minor.
·     0x02Major.
·     0x03Critical.
·     0xffInvalid.
Data[13:14]
Device ID.
Data[15:16]
Vendor ID.
Data[17:18]
Subsystem device ID.
Data[19:20]
Subsystem vendor ID.
Data[21]
Cache capacity of the storage controller. Supported options:
·     0x011GB.
·     0x022GB.
·     0x044GB.
·     0x088GB.
Data[22]
Mode of the storage controller. Supported options:
·     0x0Not supported.
·     0x1RAID.
·     0x2HBA.
·     0x3Mixed.
·     0x8JBOD.
Data[23]
Controller interface type. Supported options:
·     0x1SAS.
·     0x2SATA.
·     0x3AHCI.
·     0x4NVMe.
·     0x5PCIe.
·     0x6USB.
·     0x7FC.
·     0x8FCoE.
·     0x9iSCSI.
·     0xaSAS/SATA
·     0xbSATA-M.2.
·     0xcNVMe-M.2
Data[24]
Interface speed. Supported options:
·     0x11.5Gbps.
·     0x23.0Gbps.
·     0x36.0Gbps.
·     0x412.0Gbps.
·     0x524.0Gbps.
·     0x62.5GT/s.
·     0x7 5.0GT/s.
Data[25:44]
Adapter WWN number, a string of 20 characters.
Data[45:76]
Name of the storage controller, a string of 0 to 47 characters.
Data[77:124]
Serial number of the storage controller, a string of 0 to 47 characters.
Data[125:156]
Firmware version of the storage controller, a string of 0 to 31 characters.
Data[157:188]
Package version of the storage controller, a string of 0 to 31 characters.
Data[189:220]
Configuration version of the storage controller, a string of 0 to 31 characters.
Data[221:268]
Supported RAID levels, a string of 0 to 47 characters.
For example: 0/1/5/6/10/50/60
Data[269:300]
Powerfail safeguard status, a string of 0 to 31 characters. Supported options:
·     N/A.
·     Learn.
·     LearnFail.
·     Failed.
·     Over_temp
·     Charging.
·     Miss.
·     Fatal.
·     ChargeCompleted.
·     Present.
Data[301]
Storage controller temperature.
Data[302]
Remaining power of the supercapacitor in percent. Supported options:
·     0-100.
·     0xffInvalid.
Data[303]
Supercapacitor presence status. Supported options:
·     0x00Not present.
·     0x01Present.
·     0x02Not supported.
Data[304]
Supercapacitor health status. Supported options:
·     0x00Info.
·     0x01Minor.
·     0x02Major.
·     0x03Critical.
Data[305]
This field is supported only by LSI storage controllers.
Enabling status of JBODState. Supported options:
·     0x00Disabled.
·     0x01Enabled.
·     0xffNot supported.
Data[306]
Enabling status of CopyBackState. Supported options:
·     0x00Disabled.
·     0x01Enabled.
Data[307]
Enabling status of SmarterCopyBackState. Supported options:
·     0x00Disabled.
·     0x01Enabled.
Data[308:339]
Reserved.
Change history
Version
Change description
HDM3-1.09
Added the Present option for powerfail safeguard status in the Data[269:300] field.
HDM2-1.67
HDM2-2.03
Added support for NVMe-M.2 in Data[23].
HDM2-1.17
Changed the capacity unit in Data[21] to GB. Revised the state description of powerfail safeguard module in Data[269:300].
HDM2
Added the command.
Obtain the logical drive list for the specified storage controller
Use this command to obtain the logical drive list for the storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x03 0x00 0x00 0x01 0x00 [#CtrlID]
Table 79 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length. This field is fixed to 1.
Data[11]
Storage controller ID (CtrlID).
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x03 0x00 0x00 0x00 0x01 0x00
a2 63 00 07 00 00 00 00 02 00 ee 00 ef 00
Table 80 Response field description
Data[1:3]
Data[4:7]
Data[8]
ID of the storage controller. The error value is 0xff.
Data[9:10]
Number of logical drives.
Data[11:12]
ID of the first logical drive.
Data[(11+(N-1)*2) : (12+(N-1)*2)]
ID of the Nth logical drive.
Change history
Version
Change description
HDM2
Added this command.
Obtain information about the specified logical drive
Use this command to obtain information about the specified logical drive.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x04 0x00 0x00 0x03 0x00 [#CtrlID] [#LDDeviceID]
Table 81 Request field description
DataLUOJI [1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length. This field is fixed to 3.
Data[11]
ID of a storage controller.
Data[12:13]
ID of a logical drive.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x04 0x00 0x00 0x03 0x00 0x00 0xef 0x00
a2 63 00 c5 00 00 00 00 ef 00 00 00 73 79 73 74
65 6d 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 4f 70 74 69
6d 61 6c 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a8
6f 00 00 00 00 07 00 00 00 00 00 00 00 00 00 01
01 01 ff 01 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 01 00 00 00 5b 00 00 00 00 00 00 00
Table 82 Response field description
Data[1:3]
Data[4:7]
Data[8]
Data[9:10]
ID of the logical drive.
Data[11]
·     0x0Unknown.
·     0x1OK (Healthy).
Data[12]
·     0x00Info.
·     0x01Minor.
·     0x02Major.
·     0x03Critical.
Data[13:44]
Logical drive name, a string of 0 to 31 characters.
Data[45:76]
Logical drive state, a string of 1 to 31 characters.
Data[77:84]
Capacity of the logical drive in Byte.
Data[85]
RAID level. Supported options:
·     0x00RAID0.
·     0x01RAID1.
·     0x02RAID5.
·     0x03RAID6.
·     0x04RAID1E.
·     0x05RAID1E_RLQ0.
·     0x06RAID1E0_RLQ0.
·     0x07RAID00.
·     0x08RAID10.
·     0x09RAID50.
·     0x0aRAID60.
·     0x0bRAID1ADM.
·     0x0cRAID10ADM.
·     0x0fRAID_JBOD.
Data[86]
Strip size of the logical drive. Supported options:
·     0x0Not supported.
·     0x11KB.
·     0x22KB.
·     0x34KB.
·     0x48KB.
·     0x516KB.
·     0x632KB.
·     0x764KB.
·     0x8128KB.
·     0x9256KB.
·     0xa512KB.
·     0xb1MB.
·     OthersReserved.
Data[87]
For LSI storage controllers, this field specifies the default cache policy of the logical drive. Supported options:
·     0x00Direct IO.
·     0x01Cached IO.
For PMC storage controllers, this field specifies the default acceleration policy of the logical drive. Supported options:
·     0x01None. Disable the read and write cache of the storage controller.
·     0x02Controller cache. Enable the read and write cache of the storage controller.
·     0x03IO Bypass. For SSD drives, use the IO Bypass path to improve read and write performance.
·     0x04MaxCache. Use RAID arrays formed by SSD drives as the high-speed cache.
·     0xFFInvalid. No corresponding feature is available.
This field is not available for 3SINC storage controllers.
Data[88]
Default read policy for logical drives. This field is supported only by LSI controllers. Supported options:
·     0x0No Read Ahead.
·     0x1Read Ahead.
Data[89]
Default write policy for logical disks. This field is supported only by LSI controllers. Supported options:
·     0x0Write through.
·     0x1Write back.
·     0x2Always write back.
Data[90]
Default access policy for logical drives. This field is supported only by LSI controllers. Supported options:
·     0x0Read write.
·     0x1Read only.
·     0x2Blocked.
Data[91]
Cache status of physical drives that form the logical drive. This field is supported only by LSI controllers and 3SINC storage controllers. Supported options:
·     0x0Unchanged.
·     0x1Enabled.
·     0x2Disabled.
·     0x3On.
·     0x4Off.
·     0x5Default.
The options available for LSI storage controllers include Unchanged, Enabled, and Disabled.
The options available for 3SINC storage controllers include On, Off, and Default.
Data[92]
Current cache policy of the logical drive. This field is supported only by LSI controllers. Supported options:
·     0x0Direct IO.
·     0x1Cached IO
Data[93]
Current read policy of the logical drive. This field is supported only by LSI and 3SINC storage controllers. Supported options:
Supported options:
·     0x0No Read Ahead.
·     0x1Always Read Ahead.
·     0x2No Ahead.
·     0x3Ahead.
The options available for LSI storage controllers include No Read Ahead and Always Read Ahead.
The options available for 3SINC storage controllers include No Ahead and Ahead.
Data[94]
Current write policy of the logical drive. This field is supported only by LSI and 3SINC storage controllers. Supported options:
·     0x0Write through.
·     0x1Write back.
·     0x3Write Back Enforce.
The options available for LSI storage controllers include Write Through, Write Back, and Always write back.
The options available for 3SINC storage controllers include Write Through, Write Back, and Write Back Enforce.
Data[95]
Current access policy of the logical drive. This field is supported only by LSI controllers. Supported options:
·     0x0Read write.
·     0x1Read only.
·     0x2Blocked.
·     0xeHidden.
Data[96]
Number of drive groups in the logical drive.
Data[97]
Number of member drives in each group in the logical drive.
Data[98]
Whether the logical drive is a boot drive. Supported options:
·     0x0No.
·     0x1Yes.
Data[99]
Progress of the ongoing task performed by the logical drive, in percent. Supported options:
·     0 to 100.
·     0xFFNo background task.
Available tasks LSI logical drives include Background Initialization (BGI).
Available tasks of PMC logical drives include Background Initialization (BGI), which is not supported in the current software version.
SSSRAID logical drives are not supported in the current software version.
Data[100]
BGI state. This field is supported only by LSI controllers. Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
·     0xFF—The field value cannot be obtained.
Data[101]
Progress of the LSI or PMC logical drive rebuild task in percentage:
·     0 to 100.
·     0xFF—No rebuild task.
Data[102:116]
Reserved.
Data[117:120]
Number of contained drives.
Data[121:184]
Device IDs of physical drives. Each ID contains two bytes and the system can display up to 32 physical drive IDs.
Data[185:188]
Number of contained hot spare drives.
Data[189:203]
Device IDs of hot spare drives. Each ID contains two bytes and the system can display up to 8 hot spare drive IDs.
Change history
Version
Change description
HDM3-1.09
Added description about 3SINC storage controllers for Data[87], Data[91], Data[93], Data[94], and Data[99].
HDM3-1.15
·     Added the Data[101] field to indicate the progress of the LSI or PMC logical drive rebuild task.
·     Revised the description for the task performed by the PMC storage controller in the Data[99] field.
HDM2-1.67
HDM2-2.03
Added options for Data[85].
HDM2-1.11
Added this command.
Obtain the physical drive list for a storage controller
Use this command to obtain the list of physical drives for the specified storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x05 0x00 0x00 0x02 0x00 [#CtrlID] [#DeviceNoFormat]
Table 83 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length. This field is fixed to 2.
Data[11]
Data[12]
Display format of drive numbers:
·     0x1—DeviceID format.
·     0x2—Location format.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x05 0x00 0x00 0x02 0x00 0x00 0x02
a2 63 00 09 00 00 00 00 02 00 00 00 0a f0 0c f0
Table 84 Response field description
Data[1:3]
Data[4:7]
Data[8]
Data[9:12]
Number of physical drives.
Data[13:14]
·     If the display format is 0x1, this field displays the logical drive ID in DeviceID format.
·     If the display format is 0x2, this field displays the logical drive ID in Location formation.
In Location format:
Data[13]: Specifies the location and slot information of the drive.
·     0-127: Indicates a front drive slot.
·     ≥128:
Bit[0:3]: Drive slot number.
Bit[4:7]: Drive location:
¡     0x8—Rear (corresponding to rear 0 to 15).
¡     0x9—Rear (corresponding to rear 16 to 31).
¡     0xaRear (corresponding to rear 32 to 47).
¡     0xb—Middle (corresponding to middle 0 to 15).
¡     0xc—RSFF (rear upper SFF drive, reserved).
¡     0xd—RLFF (rear upper LFF drive, reserved).
¡     Others—Reserved.
For example:
·     For drive Front10, Data[13] is 0x0a.
·     For drive Front20, Data[13] is 0x14.
·     For drive Rear10, Data[13] is 0x8a.
·     For drive Rear20, Data[13] is 0x94.
·     For drive Middle10, Data[13] is 0xba.
·     For drive RSFF1, Data[13] is 0xC1.
·     For drive RLFF4, Data[13] is 0xD4.
Data[14]: Specifies the node to which the drive belongs.
·     Bit[0:3]: Node number 0 to 15. If Bit[0:3] is 0xf, it indicates that the physical drive location is assigned to AIC and M.2:
¡     If Data[13] is 0x00 to 0x78, 0xf in Bit[0:3] of Data[14] represents NVMe AIC.
¡     If Data[13] is 0x79 to 0x7B, 0xf in Bit[0:3] of Data[14] represents M2-SSD-F 0 to 2.
¡     If Data[13] is 0x7C to 0x7D, 0xf in Bit[0:3] of Data[14] represents M2-SSD-R 1 to 2.
¡     If Data[13] is 0x7E to 0xFF, 0xf in Bit[0:3] of Data[14] represents reserved.
For example:
¡     For drive PCIeSlot10, the Location is 0x0a 0xff.
¡     For drive M2-SSD-F0, the Location is 0x79 0xff.
¡     For drive M2-SSD-R1, the Location is 0x7c 0xff.
·     Bit[4:7]: Node type.
¡     0x1—Node (for multi-node models, such as G3 6900).
¡     0x2—Bay (for drives in HDDBAY).
¡     0x3—Reserved for bay use.
¡     0x4—JBOD (for drives in JBOD).
¡     0xf—No node information.
¡     Others—Reserved.
Data[(11+N*2):(12+N*2)]
ID of the Nth physical drive. For more information, see the numbering rule for the first physical drive.
Change history
Version
Change description
HDM2-1.57
Extended and revised the description for the Location format of rear drives.
HDM2-1.14
Revised the command example.
HDM2
Added this command.
Obtain information about the specified physical drive for a storage controller
Use this command to obtain information about the specified physical drive for a storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x06 0x00 0x00 0x04 0x00 [#CtrlID] [#DeviceNoFormat] [#DeviceNo]
Table 85 Response field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length value. This field is fixed to 4.
Data[11]
ID of a storage controller. To use the Location format, specify the ID as 0xff.
Data[12]
Display format of the physical drive ID. Supported options:
·     0xff—No specified format. The system uses the DeviceID format by default.
Data[13:14]
ID of the physical drive.
·     If the display format is 0x1, this field displays the drive ID in DeviceID format.
·     If the display format is 0x2, this field displays the drive ID in Location formation.
Data[13]: Specifies the location and slot information of the physical drive.
·     ≥128:
Bit[4:7]: Drive location.
¡     0x8—Rear (corresponding to rear 0 to15).
¡     0xa—Rear (corresponding to rear 32 to 47).
¡     Others—Reserved.
For example:
·     Bit[0:3]: Node number 0 to15. If Bit[0:3] is 0xf, it indicates that the physical drive location is assigned to AIC and M.2:
¡     If Data[13] is0x00 to 0x78, 0xf in Bit[0:3] of Data[14] represents NVMe AIC.
¡     If Data[13] is 0x7E to 0x7F, 0xf in Bit[0:3] of Data[14] represents M2-NVMe-F 1 to 2.
¡     If Data[13] is 0x80 to 0xFF, 0xf in Bit[0:3] of Data[14] represents reserved.
For example:
¡     For drive M2-NVMe-F1, the Location is 0x7e 0xff.
¡     Others—Reserved.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x06 0x00 0x00 0x04 0x00 0xff 0x02 0x01 0xf0
a2 63 00 18 01 00 00 00 1c 00 00 00 55 6e 63 6f
6e 66 69 67 75 72 65 64 47 6f 6f 64 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 60 5f ba
8b 00 00 00 48 47 53 54 00 00 00 00 00 00 00 00
00 00 00 00 48 55 43 31 30 31 38 36 30 43 53 53
32 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 30 42 47 35 30 58 34 46 00 00 00 00
00 00 00 00 41 41 30 31 00 00 00 00 00 00 00 00
00 00 00 00 35 30 30 30 43 43 41 30 37 44 30 39
32 35 30 44 30 30 30 30 30 30 30 30 30 30 30 30
30 30 30 30 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 04
ff ff ff ff ff 00 01 01 34 ff 00 00 01 00 ff ff
ff ff ff ff ff ff 00 00 00 00 00 00 00 00 46 72
6f 6e 74 31 00 00 ff ff ff ff 00 00 00 00 00 00
Table 86 Response field description
Data[1:3]
Data[4:7]
Data[8]
Data[9:10]
Data[11]
·     0x0Unknown.
·     0x1OK (Healthy).
·     0x2Warning (Minor).
·     0x3Critical (Major).
Data[12]
·     0x00Info.
·     0x01Minor.
·     0x02Major.
·     0x03Critical.
Data[13:44]
Physical drive status in the storage controller.
·     For LSI storage controllers, supported options include:
¡     UnconfiguredGood.
¡     UnconfiguredBad.
¡     Ready.
¡     Online.
¡     JBOD.
¡     Hotspare.
¡     Rebuilding.
¡     PFA.
¡     Copyback.
·     For PMC storage controllers, supported options include:
¡     Ready.
¡     Offline.
¡     PFA.
¡     Raw.
¡     Hotspare.
¡     Optimal.
¡     Unsupported.
·     For the self-developed MARVELL controller, supported options include:
¡     PFA.
¡     Unconfigured.
¡     Configured.
·     For the outsourced MARVELL controller, supported options include:
¡     Idle.
¡     Assigned.
¡     PFA.
¡     Failed.
·     For 3SINC storage controllers, supported options include:
¡     Online.
¡     Offline.
¡     Fault.
¡     Ucfggood.
¡     Ucfgfault.
¡     Spare.
¡     Foreign.
¡     Diagnosing.
¡     Reconstructing.
¡     Copybacking.
¡     Cfgincompat.
¡     PFA.
Data[45:52]
Capacity of the physical drive, in Bytes.
Data[53:84]
Manufacturer ID, a string of 0 to 31 characters.
Data[85:116]
Physical drive model, a string of 0 to 31 characters.
Data[117:148]
Serial number of the physical drive, a string of 0 to 31 characters.
Data[149:164]
Firmware version of the physical drive, a string of 16 characters.
Data[165:204]
SAS address of the physical drive, a string of 40 characters.
Data[205:220]
Reserved.
Data[221]
Physical drive interface type. Supported options:
·     0x0Unknown.
·     0x1PCIE.
·     0x2AHCI.
·     0x3UHCI.
·     0x4SAS.
·     0x5SATA.
·     0x6USB.
·     0x7NVME.
·     0x8FC.
·     0x9ISCSI.
·     0xaFCOE.
·     0xbFCP.
Data[222]
Physical drive media type. Supported options:
·     0x0HDD.
·     0x1SSD.
·     0x2SMR.
·     0x3Unknown.
Data[223]
Maximum speed of the physical drive. Supported options:
·     0x1—1.5Gbps.
·     0x2—3.0Gbps.
·     0x3—6.0Gbps.
·     0x4—12.0Gbps.
·     0x5—22.5Gbps.
NVMe drives:
·     0x80—2.5GT/s.
·     0x81—5.0GT/s.
·     0x82—8.0GT/s.
·     0x83—16.0GT/s.
·     0x84—32.0GT/s.
Data[224]
Negotiated speed of the physical drive. Supported options:
·     0x11.5Gbps.
·     0x23.0Gbps.
·     0x36.0Gbps.
·     0x412.0Gbps.
·     0x522.5Gbps.
NVMe drives:
·     0x802.5GT/s.
·     0x815.0GT/s.
·     0x828.0GT/s.
·     0x8316.0GT/s.
·     0x8432.0GT/s.
Data[225:228]
Drive rotation speed in rpm. If this field is not supported, the system displays 0xffffffff.
Data[229]
Drive size. Supported options:
·     0x15.25 inches.
·     0x23.5 inches.
·     0x3 2.5 inches.
·     0x41.8 inches.
·     0x5<1.8 inches.
Data[230]
Port number of the storage controller to which the physical drive belongs.
Data[231]
BOX number of the physical drive.
Data[232]
Bay number of the Physical drive (slot number in the BIOS).
Data[233]
Physical drive temperature.
Data[234]
This field is available only for SSD drives.
Remaining life of the drive in percentage. Supported options:
·     0-100.
Data[235]
Status of the drive UID LED. Supported options:
·     0x00Off.
·     0x01On.
Data[236]
Hot spare drive type. Supported options:
·     0x00None (Non-hot spare).
·     0x01Global (Global hot spare).
·     0x02Dedicated (Dedicated hot spare).
Data[237]
Hard drive task. Supported options:
·     0x00Unknown.
·     0x01Rebuild.
·     0x02Erase.
·     0x03Migration.
Data[238]
Task progress in percentage. Supported options:
·     0-100.
·     0xffNo task or not supported.
Only the rebuild progress can be displayed in the current software version.
Data[239:270]
ID of the logical drive to which the physical drive belongs. This field can display up to 16 IDs. If this field displays 0xffff, it indicates that the physical drive does not belong to any logical drive.
Data[271:278]
Information about the node to which the logical drive belongs, a string of 0 to 7 characters.
Data[279:286]
Location description for the physical drive, a string of 0 to 7 characters.
Data[287:290]
Total power-on time of the physical drive, in hours.
·     0xffffffffInvalid.
Data[291:294]
Predictive Failure Analysis (PFA) count for the physical drive.
·     0xffffffff—Invalid.
Data[295:298]
Media error count for the physical drive.
Data[299:302]
Other error count for the physical drive.
·     0xffffffffInvalid value
Data[303:311]
Reserved.
Change history
Version
Change description
HDM3-1.09
Added description about physical drive status for 3SINC storage controllers in Data[12:44].
HDM2-1.67
HDM2-2.03
Added support for the outsourced MARVELL controller in Data[13:44].
HDM2-1.25
HDM2-1.63
Extended the Location rules for M.2 drives.
HDM2-1.60
Added the Unsupported state option for physical drives managed by a PMC controller to field Data[13:44].
HDM2-1.58
Revised supported options for Data[13:44].
HDM2-1.57
HDM2-1.54
Added options for Data[223-224].
HDM2-1.14
HDM2
Added this command.
Use this command to obtain the list of physical drives and their information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x07 0x00 0x00 0x00 0x00
Table 87 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
This field length is fixed to 0.
Required permission
Information query
COMMAND> ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x07 0x00 0x00 0x00 0x00
a2 63 00 08 00 00 00 02 00 00 00 0a f0 0c f0
Table 88 Response field description
Data[1:3]
Data[4:7]
Data[8:11]
Number of a physical drive.
Data[12]
Location and slot number information of the first hard drive.
·     ≥128:
¡     Others—Reserved.
For example:
Data[13]
Data[13]: Specifies the node to which the first drive belongs.
¡     If Data[12] is0x00 to 0x78, 0xf in Bit[0:3] of Data[13] represents NVMe AIC.
¡     If Data[12] is 0x79 to 0x7B, 0xf in Bit[0:3] of Data[13] represents M2-SSD-F 0 to 2.
¡     If Data[12] is 0x7C to 0x7D, 0xf in Bit[0:3] of Data[13] represents M2-SSD-R 1 to 2.
¡     If Data[12] is 0x7E to 0x7F, 0xf in Bit[0:3] of Data[13] represents M2-NVMe-F 1 to 2.
¡     If Data[12] is 0x80 to 0xFF, 0xf in Bit[0:3] of Data[13] represents reserved.
For example:
¡     Others—Reserved.
Data[(10+N*2):(11+N*2)]
Specify the Nth physical drive location information. See the format of the first hard drive.
Change history
Version
Change description
HDM2-1.25
HDM2-1.63
HDM2-1.57
HDM2-1.14
HDM2
Added this command.
Use this command to obtain information about the physical drive in the specified slot.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x08 0x00 0x00 0x02 0x00 [#Location]
Table 89 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
This field length is fixed to 2.
Data[11]
Data[11]: Specifies the location and slot number information of the drive.
·     ≥128:
¡     Others—Reserved.
For example:
·     For drive Front10, Data[11] is 0x0a.
·     For drive Front20, Data[11] is 0x14.
·     For drive Rear10, Data[11] is 0x8a.
·     For drive Rear20, Data[11] is 0x94.
·     For drive Middle10, Data[11] is 0xba.
·     For drive RSFF1, Data[11] is 0xC1.
·     For drive RLFF4, Data[11] is 0xD4.
Data[12]
Data[12]: Specifies the node to which the drive belongs.
¡     If Data[11] is0x00 to 0x78, 0xf in Bit[0:3] of Data[12] represents NVMe AIC.
¡     If Data[11] is 0x79 to 0x7B, 0xf in Bit[0:3] of Data[12] represents M2-SSD-F 0 to 2.
¡     If Data[11] is 0x7C to 0x7D, 0xf in Bit[0:3] of Data[12] represents M2-SSD-R 1 to 2.
¡     If Data[11] is 0x7E to 0x7F, 0xf in Bit[0:3] of Data[12] represents M2-NVMe-F 1 to 2.
¡     If Data[11] is 0x80 to 0xFF, 0xf in Bit[0:3] of Data[12] represents reserved.
For example:
¡     Others—Reserved.
Required permission
Remote control
COMMAND>ipmitool -I lanplus -H 192.168.30.128 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x08 0x00 0x00 0x02 0x00 0x05 0xf0
a2 63 00 5a 01 00 00 ff ff 01 00 4e 6f 72 6d 61
6c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 eb 08 bf
01 00 00 4b 49 4f 58 49 41 00 00 00 00 00 00 00
00 00 00 4b 43 44 37 31 52 55 47 31 54 39 32 00
00 00 00 38 31 45 30 41 30 30 55 54 51 4d 37 00
00 00 00 30 31 30 34 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 01 01 83 83 ff
ff ff ff ff ff 01 26 24 64 00 00 ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00
00 00 00 00 00 00 00 00 00 46 72 6f 6e 74 20 53
6c 6f 74 20 35 00 00 00 00 ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff 64 00
00
Table 90 Response field description
Data[1:3]
Data[4:7]
Data[8:9]
ID of a physical drive.
0xffffThis feature is not supported.
Data[10]
·     0x0Unknown.
·     0x1OK (Healthy).
Data[11]
·     0x00Info.
·     0x01 Minor.
·     0x02Major.
·     0x03Critical.
Data[12:43]
Physical drive status.
Length of the physical drive status string is 0 to 31.
·     For the LSI controller. Supported options:
¡     UnconfiguredGood.
¡     UnconfiguredBad.
¡     Ready.
¡     Online.
¡     JBOD.
¡     Hotspare.
¡     Rebuilding.
¡     PFA.
·     For the PMC controller. Supported options:
¡     Ready.
¡     Offline.
¡     PFA.
¡     Raw.
¡     Hotspare.
¡     Optimal.
¡     Unsupported.
·     For the NVMe card physical drive status. Supported options:
¡     Normal.
¡     Spare_below.
¡     Temp_Anomaly.
¡     Subsys_Degraded.
¡     Read_only.
¡     Cache_Failed.
¡     Abnormal.
¡     Predict_Fail.
·     For the self-developed MARVELL controller. Supported options:
¡     PFA.
¡     Unconfigured.
¡     Configured.
¡     Idle.
¡     Assigned.
¡     PFA.
¡     Failed.
¡     Online.
¡     Offline.
¡     Fault.
¡     Ucfggood.
¡     Ucfgfault.
¡     Spare.
¡     Foreign.
¡     Diagnosing.
¡     Reconstructing.
¡     Copybacking.
¡     Cfgincompat.
¡     PFA.
Data[44:51]
Specify the capacity of a Physical drive, in Bytes.
Data[52:83]
Manufacturer ID. Length of the field is 0 to 31.
Data[84:131]
Physical drive model. Length of the field is 0 to 47.
Data[132:163]
Physical drive serial number. Length of the field is 0 to 31.
Data[164:179]
Hard drive firmware version ID. Length of the field is 15.
Data[180:219]
SAS address of a physical drive. Length of the field is 0 to 39.
Data[220:235]
Reserved. Length of the field is 0 to 15.
Data[236]
Type of a physical drive interface.
Supported options:
·     0x0Unknown.
·     0x1PCIE.
·     0x2AHCI.
·     0x3UHCI.
·     0x4SAS.
·     0x5SATA.
·     0x6USB.
·     0x7NVME.
·     0x8FC.
·     0x9ISCSI.
·     0xaFCOE.
·     0xbFCP.
Data[237]
Type of a physical drive media.
Supported options:
·     0x0HDD.
·     0x1 SSD.
·     0x2 SMR.
·     0x3unknown.
Data[238]
Maximum speed of a physical drive.
·     SAS/SATA disks:
¡     0x1—1.5Gbps.
¡     0x2—3.0Gbps.
¡     0x3—6.0Gbps.
¡     0x4—12.0Gbps.
¡     0x5—22.5Gbps.
·     NVMe disks:
¡     0x80—2.5GT/s.
¡     0x81—5.0GT/s.
¡     0x82—8.0GT/s.
¡     0x83—16.0GT/s.
¡     0x84—32.0GT/s.
Data[239]
Negotiated speed of a physical drive.
·     SAS/SATA disks:
¡     0x11.5Gbps.
¡     0x23.0Gbps.
¡     0x36.0Gbps.
¡     0x412.0Gbps.
¡     0x522.5Gbps.
·     NVMe disks:
¡     0x802.5GT/s.
¡     0x815.0GT/s.
¡     0x828.0GT/s.
¡     0x8316.0GT/s.
¡     0x8432.0GT/s.
Data[240:243]
Hard drive rotation speed, in rpm.
0xffffffffNot supported for this field.
Data[244]
Hard drive size.
Supported options:
·     0x15.25 inches.
·     0x23.5 inches.
·     0x3 2.5 inches.
·     0x41.8 inches.
·     0x5<1.8 inches.
·     0xffNot supported for this field.
Data[245]
Port number of a physical drives storage controller.
Data[246]
BOX number of a physical drive.
·     SAS/SATA disks:
¡     If the hard drive is installed on an Expander backplane, this value represents the Expander chip.
¡     If the hard drive is installed on a non-Expander backplane, this value represents the card's BOX Number.
·     NVMe disks:
¡     This value represents the aux of the backplane to which the hard drive belongs.
¡     0xffNot supported for this field.
Data[247]
Bay number of a Physical drive (Slot number under BIOS).
0xff—Not supported for this field.
Data[248]
Data[249]
Hard drive remaining life in percentage.
Supported options:
·     0-100Remaining life in percentage.
Data[250]
Physical drive location LED status.
Supported options:
·     0x00Off.
·     0x01On.
·     0xffThis feature is not supported.
Data[251]
Supported options:
Data[252]
Hard drive task.
Supported options:
·     0x00No task.
·     0x01Rebuild.
·     0x02Erase.
·     0x03Migration.
Data[253]
Supported options:
·     0-100Task progress in percentage.
·     0xffNo task or not supported for this feature.
Only the rebuild progress percentage is supported for display.
Data[254:285]
Logical drive ID of a physical drive. Length of the field is 0 to 31.
Two bytes represent one logical drive ID, with a maximum display of 16.
0xffffNot belonging to any logical drive.
Data[286:289]
Reserved. Length of the field is 0 to 3.
Data[290:297]
Physical drive node information. Length of the field is 0 to 7.
Data[298:313]
Physical drive location information. Length of the field is 0 to 15.
Data[314:317]
Physical drive cumulative power-on time (in Hours).
0xffffffff—Not supported.
Data[318:321]
Physical drive Predictive Failure Analysis (PFA) count.
0xffffffffNot supported.
Data[322:325]
Physical drive media error count.
Data[326:329]
Physical drive other error count.
Data[330:333]
NVMe predicted remaining life in days.
0xffffffffUnable to obtain NVMe remaining life days.
Data[334]
NVMe power consumption, in W.
0xff—Not supported.
Data[335]
NVMe remaining space, in percent.
0xff—Not supported.
Data[336]
NVMe critical warning:
·     Bit[0]The remaining space of the NVMe drive is below the threshold.
·     Bit[1]The temperature of the NVMe drive is equal to or has exceeded the overtemperature threshold, or is equal to or below the low-temperature threshold.
·     Bit[2]The reliability of the NVMe drive subsystem has degraded.
·     Bit[3]The NVMe drive is in Read Only mode.
·     Bit[4]The volatile memory backup device failed.
·     Bit[5]The permanent memory region becomes read-only or unreliable.
·     Bit[6:7]—Reserved
Data[337]
NVMe drive usage, in percent.
0xff—Not supported.
Data[338:353]
Reserved.
Change history
Version
Change description
HDM3-1.09
Added description about physical drive status for 3SINC storage controllers in Data[12:43].
HDM2-1.67
HDM2-2.03
Added support for the outsourced MARVELL controller in Data[12:43].
HDM2-1.25
HDM2-1.63
HDM2-1.61
Added the Unsupported state option for physical drives managed by PMC controllers to the Data[12:43] field.
HDM2-1.60
Added NVMe critical warning information to the Data[334:337] field.
HDM2-1.58
HDM2-1.57
HDM2-1.13
Set the invalid value for both NVMe and physical drives to 0xffff.
HDM2
Added this command.
Obtain idle slot list information
Use this command to obtain information about the idle slot list.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x0d 0x00 0x00 0x00 0x00
Table 91 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Manufacturer ID. This field is fixed to a2 63 00.
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x0d 0x00 0x00 0x00 0x00
a2 63 00 14 00 00 00 08 00 00 00 10 f0 11 f0 12
f0 13 f0 14 f0 15 f0 16 f0 17 f0
Table 92 Response field description
Data[1:3]
Data[4:7]
Data[8:11]
Number of idle slots.
Data[12:13]
Idle slot ID.
Location format:
Data[12]: Specifies the location and slot information of the idle slot.
·     0-127: Indicates a front idle slot.
·     ≥128:
Bit[0:3]: Idle slot number.
Bit[4:7]: Idle slot location:
¡     0xc—RSFF (rear upper SFF idle slot, reserved).
¡     0xd—RLFF (rear upper LFF idle slot, reserved).
¡     Others—Reserved.
For example:
·     For idle slot Front10, Data[12] is 0x0a.
·     For idle slot Front20, Data[12] is 0x14.
·     For idle slot Rear10, Data[12] is 0x8a.
·     For idle slot Rear20, Data[12] is 0x94.
·     For idle slot Middle10, Data[12] is 0xba.
·     For idle slot RSFF1, Data[12] is 0xC1.
·     For idle slot RLFF4, Data[12] is 0xD4.
Data[13]: Specifies the node to which the idle slot belongs.
·     Bit[0:3]: Node number 0 to 15. If Bit[0:3] is 0xf, it indicates that the idle slot location is assigned to M.2:
For example:
¡     For idle slot M2-SSD-F0, the Location is 0x79 0xff.
¡     For idle slot M2-SSD-R1, the Location is 0x7c 0xff.
¡     For idle slot M2-NVMe-F1, the Location is 0x7e 0xff.
¡     0x2—Bay (for idle slots in HDDBAY).
¡     0x4—JBOD (for idle slots in JBOD).
¡     Others—Reserved.
ID of the Nth idle slot. For more information, see the location format for the first idle slot.
Change history
Version
Change description
HDM3-2.03
Added the idle slot numbering description for Data[12:13].
HDM3-1.15
Added this command.
Obtain information about an idle slot
Use this command to obtain the information about an idle slot.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x0e 0x00 0x00 0x02 0x00 [#Location]
Table 93 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data[11:12]
Idle slot ID.
Location format:
Data[11]: Specifies the location and slot information of the idle slot.
·     ≥128:
¡     Others—Reserved.
For example:
Data[12]: Specifies the node to which the idle slot belongs.
For example:
¡     Others—Reserved.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x0e 0x00 0x00 0x02 0x00 0x10 0xf0
a2 63 00 53 00 00 00 07 01 00 46 72 6f 6e 74 31
36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 38 55 6e 69 42 61
79 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Table 94 Response field description
Data[1:3]
Data[4:7]
Data[8]
Drive interface types supported by idle slots. Supported options:
·     0x03—SATA/SAS
·     0x07—SATA/SAS/ U.2(NVMe)
·     0x08—M.2(SATA)
·     0x10—M.2(NVMe)
·     0x20—E1.S
·     0x40—E3.S
Data[9]
Drive sizes supported by idle slots. Supported options:
·     0x01—2.5 inch, size of U.2 drives.
·     0x02—3.5 inch, size of U.2 drives.
·     0x04—7.5 mm, size of E3.S drives.
·     0x08— 9.5 mm, size of E1.S drives.
·     0x10—80 mm, size of M.2 drives.
·     0x20—110 mm, size of M.2 drives.
·     0x30—80 mm/110 mm, size of M.2 drives.
Data[10]
LED status for idle slots. Supported options:
·     0x00—Off.
·     0x01—On.
Data[11:42]
Slot number of idle slots, a string of 0 to 31 characters.
Data[43:90]
Name of modules connected to idle slots, a string of 0 to 47 characters.
Change history
Version
Change description
HDM3-2.03
Added the idle slot numbering description for Data[11:12].
HDM3-1.15
Added this command.
Obtain information about idle slots under a storage controller
Use this command to obtain information about the idle slots for a storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x0f 0x00 0x00 0x01 0x00  [#CtrlID]
Table 95 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data[11]
Storage controller ID.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x0f 0x00 0x00 0x01 0x00 0x01
a2 63 00 0b 00 00 00 01 03 00 00 00 15 f0 16 f0
17 f0
Table 96 Response field description
Data[1:3]
Data[4:7]
Data[8]
Data[9:12]
Data[13:14]
ID of the first idle slot.
Location format:
Data[13]: Specifies the location and slot information of the idle slot.
·     ≥128:
¡     Others—Reserved.
For example:
Data[14]: Specifies the node to which the idle slot belongs.
For example:
¡     Others—Reserved.
ID of the Nth idle slot. For more information, see the numbering rules for the first idle slot.
Change history
Version
Change description
HDM3-2.03
Added the idle slot numbering description for Data[13:14].
HDM3-1.15
Added this command.
Obtain information about an idle slot under a storage controller
Use this command to obtain information about an idle slot under a storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x10 0x00 0x00 0x03 0x00  [#CtrlID] [#Location]
Table 97 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data[11]
Data[12:13]
Idle slot ID.
Location format:
·     ≥128:
¡     Others—Reserved.
For example:
For example:
¡     Others—Reserved.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x10 0x00 0x00 0x03 0x00 0x01 0x15 0xf0
a2 63 00 54 00 00 00 01 07 01 00 46 72 6f 6e 74
32 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 38 55 6e 69 42
61 79 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Table 98 Response field description
Data[1:3]
Data[4:7]
Data[8]
Data[9]
·     0x03—SATA/SAS
·     0x08—M.2(SATA)
·     0x10—M.2(NVMe)
·     0x20—E1.S
·     0x40—E3.S
Data[10]
Data[11]
·     0x00—Off.
·     0x01—On.
Data[12:43]
Data[44:91]
Change history
Version
Change description
HDM3-2.03
HDM3-1.15
Added this command.
Set the mode of a storage controller
Use this command to set the mode of a storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x21 0x00 0x00 0x02 0x00  [#CtrlID]  [#Mode]
Table 99 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data[11]
Specify the ID of a storage controller.
Data[12]
Specify the mode of a storage controller.
·     0x1RAID.
·     0x2HBA.
·     0x3Mixed.
·     0x8JBOD.
PMC storage controllers support setting RAID, HBA, and Mixed modes.
LSI storage controllers support setting RAID and JBOD modes.
Required permission
Remote control
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x21 0x00 0x00 0x00 0x02 0x00 0x01
a2 63 00
Table 100 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Set the attributes of the specified storage controller
Use this command to set the attributes of the specified storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x22 0x00 0x00 0x04 0x00 [#CtrlID] [#Reserved4] [#JBODState] [#CopyBackState] [#SmarterCopyBackState]
Table 101 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length.
Data[11]
Specify the ID of the storage controller.
Data[12-15]
Data[16]
Only LSI controllers support controller passthrough (JBODState).
Enabling status of the JBODState feature.
Supported options:
·     0x00Disabled.
·     0x01Enabled.
·     0xFFKeep the current value.
Data[17]
Only LSI controllers support controller copyback (CopyBackState).
Enabling state of the CopyBackState state.
Supported options:
·     0x00Disabled.
·     0x01Enabled.
Data[18]
Only LSI controllers support controller copyback on SMART errors (SmarterCopyBackState).
Enabling state of the SmarterCopyBackState feature.
Supported options:
·     0x00Disabled.
·     0x01Enabled.
Required permission
Remote control
COMMAND>ipmitool - I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x22 0x00 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x01
a2 63 00
Table 102 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Clear configuration of the specified storage controller
Use this command to clear configuration of the specified storage controller.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x23 0x00 0x00 0x01 0x00 [#CtrlID]
Table 103 Request field description
Data[1]
NetFn.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
This field length is fixed to 1.
Data[11]
Required permission
Remote control
COMMAND>ipmitool I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x23 0x00 0x00 0x01 0x00 0x00
a2 63 00
Table 104 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Create a logical drive
Use this command to create a logical drive.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x24 0x00 0x00 0x00 [#Len] [#CtrlID] [#RAIDName] [#RAIDLevel] [#StripeSize] [#Unit] [#Size] [#CachePolicy] [#InitMethod] [#DriveCachePolicy] [#ReadPolicy] [#WritePolicy] [#AccessPolicy] 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 [#SpanNum] [#DriveNum] [#SpanNum] [#DeviceNoFormat] [#DeviceNo] [#SpanNoDeviceIn]
Table 105 Request field description
Data[1]
NetFn.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length.
Data[11]
Data[12:43]
Specify the name of logical drive.
The length of LSI controller is 0 to 15.
The length of PMC controller is 1 to 31.
The length of 3SINC controller is 0 to 15.
Data[44]
Specify the logical drive level.
Supported options:
·     0x00—RAID0.
·     0x01—RAID1.
·     0x02—RAID5.
·     0x03—RAID6.
·     0x08—RAID10.
·     0x09—RAID50.
·     0x0a—RAID60.
·     0x0b—RAID1ADM.
·     0x0c—RAID10ADM.
RAID1ADM and RAID10ADM are only supported by PMC cards.
Data[45]
Specify the stripe size.
Supported options:
·     0x1—1KB.
·     0x2—2KB.
·     0x3—4KB.
·     0x4—8KB.
·     0x5—16KB.
·     0x6—32KB.
·     0x7—64KB.
·     0x8—128KB.
·     0x9—256KB.
·     0xa—512KB.
·     0xb—1MB.
·     Other—Reserved.
·     LSI 9540 only supports 64KB.
·     LSI 9560 supports 64KB, 128KB, 256KB, 512KB, and 1MB.
·     PMC H460 3254 supports 64KB, 128KB, 256KB, 512KB, and 1MB.
·     PMC P460 supports 16KB, 32KB, 64KB, 128KB, 256KB, 512KB, and 1MB.
·     3SINC storage controllers support 32KB, 64KB, 128KB, 256KB, 512KB, and 1MB.
For more information about the supported storage controllers, see the actual specifications and obtain the supported stripe sizes through HDM/BIOS.
Data[46:49]
Specify the capacity, decimals not supported.
·     0—Indicates using all capacity.
When the unit is MiB, you can set the capacity value to 0 or a value larger than 100, except 3SINC storage controllers.
Data[50]
Specify the capacity unit.
Supported options:
·     0x01—MiB.
·     0x02—GiB.
·     0x03—TiB.
Data[51]
For LSI controllers, it indicates the default cache policy for the logical drive.
For PMC controllers, it indicates the default acceleration policy for the logical drive.
·     Cache policy for logical drives supported by LSI controllers:
¡     0x00—Direct IO.
·     Acceleration policies supported by PMC controllers:
¡     0x01—None. Disable read and write cache of the storage controller.
¡     0x02—Controller Cache. Enable read and write cache of the storage controller.
¡     0x03—IO Bypass. For SSD drives, this policy can improve the read and write performance.
Data[52]
Specify the initialization mode.
·     For LSI controllers:
¡     0x00—No Init.
¡     0x01—Quick Init.
¡     0x02—Full Init.
·     For PMC controllers:
¡     0x03—Default.
¡     0x04—RPI (Rapid-Parity-Initialization).
·     For 3SINC storage controllers:
¡     0x01—Quick Init.
¡     0x06—Background.
¡     0x07—Front.
Data[53]
Only LSI controllers support this field.
Default read policy.
·     0x0—No Read Ahead.
·     0x1— Read Ahead.
·     0xFF—This feature is not supported.
Data[54]
Default write policy.
·     0x0—Write through.
·     0x1—Write back.
·     0x2—Always write back.
Data[55]
Default access policy.
·     0x0—Read write.
·     0x1—Read only.
·     0x2—Blocked.
Data[56]
Only LSI controllers and 3SINC storage controllers support this field.
Physical drive cache policy.
·     0x0—Unchanged.
·     0x1—Enabled.
·     0x2—Disabled.
·     0x3On.
·     0x4Off.
·     0x5Default.
Data[57]
Only 3SINC storage controllers support this field.
Read policy. Supported options include:
·     0x2—No Ahead.
·     0x3—Ahead.
Data[58]
Write policy. Supported options include:
·     0x0—Write Through.
·     0x1—Write Back.
·     0x3—Write Back Enforce.
Data[59:66]
Reserved.
Data[67]
Specify the number of drive groups.
¡     When the level is 0/1/5/6/10, RAID1 ADM, or RAID10ADM, the number of groups is 0.
¡     When the level is 50/60, the number of groups must be greater than 1.
¡     When the level is 0/1/5/6, the number of groups is 1.
¡     When the level is 00/10/50/60, the number of groups must be greater than 1.
¡     When the level is 10/50/60, the number of groups must be greater than 1.
Data[68]
Specify the total number of hard disks. You can specify up to 32 drives.
Data[69]
Specify the display format of drive numbers.
·     0xff—No specified format. The default format (DeviceID format) is used.
Data[70:71]
ID of the first hard drive.
·     If the display format is 0x1, this field displays the hard drive ID in DeviceID format.
·     If the display format is 0x2, this field displays the hard drive ID in Location formation.
In Location format:
Data[70]: Specifies the location and slot information of the drive.
·     ≥128:
¡     Others—Reserved.
For example:
·     For drive Front10, Data[70] is 0x0a.
·     For drive Front20, Data[70] is 0x14.
·     For drive Rear10, Data[70] is 0x8a.
·     For drive Rear20, Data[70] is 0x94.
·     For drive Middle10, Data[70] is 0xba.
·     For drive RSFF1, Data[70] is 0xC1.
·     For drive RLFF4, Data[70] is 0xD4.
Data[71]: Specifies the node to which the drive belongs.
¡     If Data[70] is0x00 to 0x78, 0xf in Bit[0:3] of Data[71] represents NVMe AIC.
¡     If Data[70] is 0x79 to 0x7B, 0xf in Bit[0:3] of Data[71] represents M2-SSD-F 0 to 2.
¡     If Data[70] is 0x7C to 0x7D, 0xf in Bit[0:3] of Data[71] represents M2-SSD-R 1 to 2.
¡     If Data[70] is 0x7E to 0xFF, 0xf in Bit[0:3] of Data[71] represents reserved.
For example:
¡     Others—Reserved.
Data[72:73]
ID of the group to which the first drive belongs.
This field displays 0xFF if it is not supported.
Data[(74+N*4):(75+N*4]
ID of the Nth hard drive and ID of the drive group to which the drive belongs.
Required permission
Remote control
Product compatibility
COMMAND> ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x24 0x00 0x00 0x3f 0x00 0x00 0x6c 0x6f 0x67 0x69 0x63 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x07 0x00 0x00 0x01 0x00 0x01 0x03 0x03 0xff 0xff 0xff 0xff 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x01 0x02 0x01 0xf0 0xff 0x00
a2 63 00
Table 106 Response field description
Data[1:3]
Change history
Version
Change description
HDM3-1.09
Added description about 3SINC storage controllers in Data[12:43], Data[45], Data[46:49], Data[51], Data[52], Data[56], and Data[67].
Added description about the write policy in Data[57].
Added description about the write policy in Data[58].
HDM2-1.63
Added the remarks about command execution timeout.
HDM2-1.57
HDM2-1.15
Revised the support description of stripe sizes in Data[45] and the drive group quantity description in Data[67].
HDM2-1.14
HDM2
Added this command.
Remarks
This command is time consuming and may be timed out by IPMItool. To resolve this issue add the -N parameter (timeout value in seconds) to allow the command to be fully processed. Adjust the value of N as needed.
Delete a logical drive
Use this command to delete the specified logical drive.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x25 0x00 0x00 0x01 0x00 [#CtrlID] [#LDDeviceID]
Table 107 Request field description
Data[1]
NetFn.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
This field length is fixed to 3.
Data[11]
Data[12:13]
Specify the ID of the logical drive.
Required permission
Remote control
Not restricted to specific products.
COMMAND> ipmitool I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x25 0x00 0x00 0x03 0x00 0x01  0x01 0x00
a2 63 00
Table 108 Response field description
Data[1:3]
Change history
Version
Change description
HDM2-1.63
HDM2
Added this command.
Remarks
Modify the attributes of the specified logical drive
Use this command to modify the attributes of the specified logical drive.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x26 0x00 0x00 0x02 0x00 [#CtrlID] [#LDDeviceID] [#Reserved12]
Table 109 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved
Data[9:10]
Data length.
Data[11]
Data[12:13]
Specify the ID of logical drive.
Data[14]
Reserved.
Data[15]
Default read policy:
·     0x1—Read Ahead.
·     0xFF—Keep the original value.
Data[16]
Default write policy:
·     0x1—Write back.
Data[17]
Default access policy:
·     0x0—Read write.
·     0x1—Read only.
·     0x2—Blocked.
Data[18]
Only LSI cards support this field:
Physical drive cache policy:
·     0x0—Unchanged.
·     0x1—Enabled.
·     0x2—Disabled.
Data[19:25]
Reserved. Length of the field is 0 to 6.
Required permission
Remote control
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x26 0x00 0x00 0x0f 0x00 0x00 0xee 0x00 0xff 0xff 0xff 0xff 0xff 0x00 0x00 0x00 0x00 0x00 0x00 0x00
a2 63 00
Table 110 Response field description
Data[1:3]
Change history
Version
Change description
HDM2-1.14
HDM2
Added this command.
Add/Remove the specified hot spare drive
Use this command to add or remove the specified hot spare drive.
To add a global hot spare or remove hot spares:
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x27 0x00 0x00 0x05 0x00 [#CtrlID] [#DeviceNoFormat] [#DeviceNo] [#SpareType]
To add a dedicated hot spare:
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x27 0x00 0x00 [#Len] 0x00 [#CtrlID] [#DeviceNoFormat] [#DeviceNo] [#LDNum] [#LDDeviceID]
Table 111 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length.
Data[11]
If the drive number format is Location, specify this field as 0xff.
Data[12]
Specify the physical drive number format.
Supported options:
·     0x1DeviceID format.
·     0x2Location format.
Data[13:14]
ID of the hard drive.
In Location format:
·     ≥128:
¡     Others—Reserved.
For example:
For example:
¡     Others—Reserved.
Data[15]
Specify the action.
Supported options:
·     0x00—Remove a hot spare drive.
·     0x01Add a global hot spare.
·     0x02Add a dedicated hot spare.
Data[16]
Specify the number of logical drives associated with the hot spare drive.
This field is required only when you add a dedicated hot spare drive.
Data[17:18]
Specify the ID of the first logical drive associated with the hot spare drive.
Data[(15+N*2):(16+N*2)]
Specify the ID of the Nth logical drive associated with the hot spare drive.
Required permission
Remote control
# Add a dedicated hot spare.
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x27 0x00 0x00 0x08 0x00 0xff 0x02 0x06 0xf0 0x02 0x01 0x03 0x00
a2 63 00
# Remove a hot spare drive.
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x27 0x00 0x00 0x05 0x00 0xff 0x02 0x00 0xf0 0x00
a2 63 00
Table 112 Response field description
Data[1:3]
Change history
Version
Change description
HDM2-1.57
HDM2-1.14
HDM2
Added this command.
Modify the status of the specified physical drive
Use this command to modify the status of the specified physical drive.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x28 0x00 0x00 0x00  0x00 [#CtrlID] [#DeviceNoFormat] [#DeviceNo] [#PDState]
Table 113 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved
Data[9:10]
Data length.
Data[11]
Data[12]
Supported options:
Data[13:14]
In Location format:
·     ≥128:
¡     Others—Reserved.
For example:
For example:
¡     Others—Reserved.
Data[15]
Physical drive state:
·     0x0—UnconfiguredGood.
·     0x1—UnconfiguredBad.
·     0x2—JBOD.
Data[16]
Reserved.
Required permission
Remote control
COMMAND>ipmitool -I lanplus -H 192.168.30.178 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x28 0x00 0x00 0x06 0x00 0x00 0x01 0x01 0x00 0x01 0x00
a2 63 00
Table 114 Response field description
Data[1:3]
Change history
Version
Change description
HDM2-1.57
HDM2
Added this command.
Locate the specified physical drive
Use this command to locate the specified physical drive.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0x29 0x00 0x00 0x06 0x00 [#DeviceNo] [#PDState]  0x00 0x00 0x00
Table 115 Request field description
Data[1]
NetFun code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Data length.
Data[11:12]
In Location format:
Data[11]: Specifies the location and slot information of the drive.
·     ≥128:
¡     Others—Reserved.
For example:
·     For drive Rear10, Data[113] is 0x8a.
¡     Others—Reserved.
Data[13]
Locate the physical drive.
Supported options:
·     0x00—Start to locate the device.
·     0x01—Stop locating the device.
Data[14:16]
Reserved.
Required permission
Maintenance
# Turn on the UID LED of DiskFront2.
COMMAND>ipmitool -I lanplus -H 192.168.34.201 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0x29 0x00 0x00 0x06 0x00 0x02 0xf0 0x00 0x00 0x00 0x00
Table 116 Response field description
Data[1:3]
Change history
Version
Change description
HDM2-1.57
HDM2-1.14
HDM2
Added this command.
Obtain the drive alarm thresholds
Use this command to obtain the drive alarm thresholds.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0xd0  0x00 0x00 0x00 0x00
Table 117 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved.
Data[9:10]
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.30.158 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0xd0 0x00 0x00 0x00 0x00
a2 63 00 12 00 00 00 01 5f 00 01 0a 00 01 00 5f 01 5f 00 01 00 5f 00 00 00
Table 118 Response field description
Data[1:3]
Data[4:7]
Data[8]
Remaining life alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
·     0xFF—Not supported.
Data[9:10]
Remaining life alarm threshold value. The value range is 0 to 100.
Data[11]
Reserved block alarm enabling state.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[12:13]
Reserved block alarm threshold. The value range is 0 to 100.
Data[14]
Bad sector alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[15:16]
Bad sector alarm threshold. The value range is 0 to 65535.
Data[17]
UNC alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[18:19]
UNC alarm threshold. The value range is 0 to 255.
Data[20]
Media error alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[21:22]
Media error alarm threshold. The value range is 0 to 65535.
Data[23]
Pred fail alarm enabling state.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[24:25]
Pred fail alarm threshold. The value range is 0 to 255.
Change history
Version
Change description
HDM2-1.14
Revised description of the Data[14] and Data[15:16] fields.
HDM2
Added this command.
Set the drive alarm thresholds
Use this command to set the drive alarm thresholds.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x24 0xa2 0x63 0x00 0xd1 0x00 0x00 0x14 0x00 [#left life enable][#left life]{#reserved  block enable][#reserved block][#bad block enable][#bad block][#UNC enable][#UNC][#Media Error enable][#Media Error] [#Pred Fail enable][# Pred Fail] 0x00 0x00
Table 119 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:8]
Reserved
Data[9:10]
Data length.
Data[11]
Specify the remaining life alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[12:13]
Specify the remaining life alarm threshold value. The value range is 0 to 100.
Data[11]
Specify the reserved block alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
·     0xFF—Keep the current value.
Data[12:13]
Specify the remaining life alarm threshold. The value range is 0 to 100.
Data[14]
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[15:16]
Specify the reserved block alarm threshold. The value range is 0 to 100.
Data[17]
Specify the bad sector alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[18:19]
Specify the bad sector alarm threshold. The value range is 0 to 65535.
Data[20]
Specify the UNC alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[21:22]
Specify the UNC alarm threshold. The value range is 0 to 255.
Data[23]
Specify the media error alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[24:25]
Specify the media error alarm threshold. The value range is 0 to 65535.
Data[26]
Specify the pred fail alarm enabling status.
Supported options:
·     0x00—Disabled.
·     0x01—Enabled.
Data[27:28]
Specify the pred fail alarm threshold. The value range is 0 to 255.
Data[29:30]
Reserved. This field length is to 2.
Required permission
Remote control
COMMAND>ipmitool -I lanplus -H 192.168.7.7 -U admin -P Password@_ raw 0x36 0x24 0xa2 0x63 0x00 0xd1 0x00 0x00 0x14 0x00 0x01 0x60 0x00 0xff 0x00 0x00 0xff 0x00 0x00 0xff 0xff 0x00 0xff 0x00 0x00 0x01 0x0c 0x00 0x00 0x00
a2 63 00
Table 120 Response field description
Data[1:3]
Change history
Version
Change description
HDM2-1.14
Revised the description of the Data[17] and Data[18:19] fields.
HDM2
Added this command.
Obtain the total drive usage
Use this command to obtain the total drive usage (drive usage in HDM).
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x56
Table 121 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
To use this command, you must first run FIST SMS.
# Obtain the total drive usage.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x56
a2 63 00 00 00 70 e1 00 40 1e 00 00
Table 122 Response field description
Data[1:3]
Data[4]
Total drive usage.
Data[5-8]
Total drive capacity, in MB.
Data[9-12]
Used drive capacity, in MB.
Change history
Version
Change description
HDM-1.30.14
Added the total drive capacity and used drive capacity fields. The two fields are supported only in FIST SMS D018 and later versions.
HDM-1.11.29
Added this command.
Specify the drive usage
Use this command to specify the drive usage (drive usage in HDM). FIST SMS uses this command to send drive usage statistics to BMC.
This command does not have operation log records.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xa2 0x63 0x00 0x3d 0x00 0x00 0x70 0xe1 0x00 0x40 0x1e 0x00 0x00
Table 123 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Maximum drive usage, in the range of 0 to 100.
Data[8:11]
Total drive capacity.
Data[12:15]
Total used drive capacity.
Required permission
Remote control
# Specify the drive usage.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x09 0xa2 0x63 0x00 0x3d 0x00 0x00 0x70 0xe1 0x00 0x40 0x1e 0x00 0x00
a2 63 00
Table 124 Response field description
Data[1:3]
Change history
Version
Change description
HDM-1.30.14
HDM-1.11.29
Added this command.
BMC and BIOS interaction
Obtain the next boot option
Use this command to obtain the configured next boot option.
ipmitool -I connect_type -H hostname -U username -P password raw 0x00 0x09 0x05 0x00 0x00
Table 125 Request field description
Data[1]
NetFn.
Data[2]
Command code.
Data[3]
Parameter selector.
Data[4]
Set selector.
Data[5]
Block selector.
Required permission
Information query
# Obtain the configured next boot option.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x00 0x09 0x05 0x00 0x00
 01 05 80 08 00 00 00
Table 126 Response field description
Data[1]
Parameter version.
Data[2]
Parameter validity.
Data[3]
Bit[7]: Indicates whether the boot option is valid. Supported options:
·     0—Invalid.
·     1—Valid.
Bit[6]: Indicates the effective time of the boot option. Supported options:
·     0—One-time boot option.
·     1—Permanent boot option.
Bits[0:5]: N/A.
Data[4]
Bits[2:5]: Indicates the boot option. Supported options:
·     0000bNot configured.
·     0001b—PXE.
·     0110bUses BIOS configuration.
·     0010b—HDD.
·     0101b—CDROM.
Bits[0:1]: N/A.
Data[5]
This field is 0 by default.
Data[6]
Data[7]
Set the next boot option
Use this command to set the next boot option.
ipmitool -I connect_type -H hostname -U username -P password raw 0x00 0x08 0x05 0x80 0x18 0x00 0x00 0x00
Table 127 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3]
Parameter selector.
Data[4]
Bit[7]: Specify whether the boot option is valid. Supported options:
·     0—Invalid.
·     1—Valid.
Bit[6]: Specify the effective time of the boot option. Supported options:
Bits[0:4]: Each of these bits is set to 0 by default.
Data[5]
Bits[2:5]: Specify the boot option. Supported options:
·     0001b—PXE.
·     0010b—HDD.
·     0101b—CDROM.
Bit[7]: 1 indicates restoring the BIOS default settings. This configuration takes effect after a BIOS reboot.
Note: Bits[2:5] and Bit[7] cannot be configured at the same time. BIOS restart is required between configuration of the two options. Bit[7] and the Bit[5] or Bit[6] fields of DATA[4] cannot be set to 1 at the same time.
Bits[0:1]: Each of these bits is set to 0 by default.
Note: The BIOS configuration is not available for permanent boot option configuration.
Data[6]
Data[7]
Data[8]
Required permission
Remote control
# Configure the device to use the boot options configured in the BIOS.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x00 0x08 0x05 0x80 0x18 0x00 0x00 0x00
# Configure the device to use the boot options configured in the CDROM.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x00 0x08 0x05 0xc0 0x14 0x00 0x00 0x00
Obtain the next boot mode
Use this command to obtain the next boot mode.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x2e
Table 128 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain the next boot mode.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x2e
a2 63 00 01 01 00 00
Table 129 Response field description
Data[1:3]
Data[4]
Bit[0]: Indicates whether the next boot mode is valid. Supported options:
·     1Valid.
·     0Invalid.
Bits[1:3]: N/A.
Data[5]
Next boot mode. Supported options:
·     0x00—No override.
·     0x01—Legacy.
·     0x02—UEFI.
·     0x03—Auto.
Data[6]
Reserved.
Data[7]
Reserved.
Remarks
The next boot mode of the Phytium platform does not support Legacy mode.
Change history
Version
Change description
HDM3-1.15
Added the remarks to indicate that the Phytium platform does not support Legacy mode.
Set the next boot mode
Use this command to set the next boot mode.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0a 0xa2 0x63 0x00 0x02 0x01 mode 0x00 0x00
Table 130 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Bit[0]: Specify whether the next boot mode is valid. Supported options:
·     1Valid.
·     0Invalid.
Bits[1:3]: N/A.
Data[8]
Specify the next boot mode. Supported options:
·     0x00—No override.
·     0x01—Legacy.
·     0x02—UEFI.
·     0x03—Auto.
Data[9]
Data[10]
Required permission
Remote control
For this configuration to take effect, you must also specify the next boot option.
# Set the next boot mode.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0a 0xa2 0x63 0x00 0x02 0x01 0x01 0x00 0x00
a2 63 00
Table 131 Response field description
Data[1:3]
Remarks
The next boot mode of the Phytium platform does not support setting Data[8] to Legacy mode.
Change history
Version
Change description
HDM3-1.15
Obtain the power-on delay time
Use this command to obtain the power-on delay time.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x3F
Table 132 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain the power-on delay time.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x3f
a2 63 00 01 78 00 00 00 00 00 00
Table 133 Response field description
Data[1:3]
Data[4]
Power-on delay policy. Supported options:
·     0x00—Fixed delay time.
·     0x01—Random delay time.
·     0x02No delay. Not configurable when the AC recovery policy is off.
Data[5:6]
Delay time, in seconds.
When the value of Data[4] is 0x00, the delay time can only be 0, 15, 30, 45, or 60 seconds.
When the value of Data[4] is 0x01, the delay time is in the range of 1 to 120 seconds.
When the value of Data[4] is 0x02, this field is not available.
Data[7:11]
Reserved.
Change history
Version
Change description
HDM2
Removed option 0 for setting the delay time.
HDM-2.16.00
Added support for obtaining the random delay time.
Set the power-on delay time
Use this command to set the power-on delay time.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0a 0xa2 0x63 0x00 0x03 Data[7] Data[8:9] 0x00 0x00 0x00 0x00 0x00
Table 134 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Specify the power-on delay policy. Supported options:
·     0x02No delay.
Data[8:9]
Specify the delay time, in seconds.
When the value of Data[7] is 0x00, the delay time can only be 0, 15, 30, 45, or 60 seconds.
When the value of Data[7] is 0x01, the delay time is in the range of 1 to 120 seconds.
When the value of Data[7] is 0x02, this field is not available.
Data[10:14]
Required permission
Power control
Blade servers do not support this command.
# Set the power-on delay time.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0a 0xa2 0x63 0x00 0x03 0x00 0x0f 0x00 0x00 0x00 0x00 0x00 0x00
a2 63 00
Table 135 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Removed option 0 for setting the delay time when random delay time is specified as the power-on delay policy.
HDM-2.16.00
Added support for setting the random delay time.
Obtain Postcode information
Use this command to obtain Port80 (G5) or Port81 (G60) information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x09
Table 136 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain Port81 information.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x09
a2 63 00 00 01 01 03 ad 00 a2 00 a7 00 a7 00 a7
00 a9 00 a8 00 aa 00 ae 00 e0 00 e0 00 e0 00 e1
00 e4 00 e3 00 e5 00 af 00 af 00 b0 00 bf 00 b5
00 c1
00 70 00 b1 00 b1 00 7e 00 c2 00 7e 00 70 00 7e
00 7e 00 b1 00 b1 00 b1 00 b6 00 7e 00 b4 00 7e
00 b8 00 c5 00 b2 00 c6 00 b3 00 b3 00 b6 00 b6
00 b6 00 b0 00 b7 00 b6 00 b6 00 7e 00 7e 00 7e
00 b7 00 b7 00 b6 00 b6 00 b7 00 b7 00 7e 00 70
00 7e 00 70 00 70 00 b7 00 7e 00 be 00 be 00 7e
00 7e 00 d2 00 7e 00 d2 00 d6 00 70 00 b9 00 b7
00 b7 00 b7 00 b8 00 b8 00 b8 00 b8 00 b8 00 b8
00 b8 00 d7 00 c9 00 da 00 d9 00 db 00 ba 00 b9
00 70 00 70 00 70 00 7e 00 cb 00 bb 00 bb 00 bb
00 bb 00 bb 00 bb 00 bb 00 bb 00 bb 00 bb 00 7e
00 7e 00 d0 00 7e 00 d0 00 7e 00 d0 00 7e 00 d1
00 7e 00 d1 00 7e 00 70 00 7e 00 b7 00 ca 00 ca
00 dc 00 7e 00 cc 00 bc 00 bc 00 bc 00 bc 00 bc
00 ce 00 c6 00 7e 00 bf 00 af 00 af 00 af 00 e6
00 e7 00 e9 00 eb 00 ec 00 ed 00 ee 00 03 00 23
00 02 00 22 00 50 00 00 00 04 00 06 00 0b 00 0d
00 15 00 7f 00 00 00 7f 00 40 00 41 00 42 00 47
00 4f 00 33 00 60 00 61 00 9a 00 68 00 70 00 79
00 90 00 91 00 92 00 94 00 94 00 94 00 94 00 94
00 94 00 94 00 94 00 94 00 94 00 94 00 94 00 95
00 96 00 ef 00 92 00 92 00 92 00 92 00 92 00 92
00 92 00 92 00 92 00 99 00 91 00 92 00 92 00 92
00 92 00 92 00 92 00 92 00 92 00 92 00 92 00 97
00 98 00 9d 00 9a 00 9c 00 b4 00 b4 00 b4 00 b4
00 b4 00 b4 00 98 00 b4 00 b4 00 b4 00 b4 00 92
00 a0 00 a2 00 a2 00 a2 00 a2 00 a2 00 a2 00 a2
00 a2 00 99 00 92 00 92 00 92 00 92 00 92 00 92
00 92 00 92 00 92 00 ad 00
Table 137 Response field description
Data[1:3]
Data[4:5]
Total number of POST codes.
Data[6]
Current host power status. Supported options:
·     1Powered-on.
·     0Powered-off.
Data[7]
Current post status. Supported options:
·     0POST initial state.
·     1—POST start.
·     2—POST to setup.
·     3—POST to boot OS.
·     4—End of IPMI.
Note: G6 products do not support options 0 and 4.
Data[8:9]
Current POST code.
Data[10:521]
Most recent 256 POST codes of the most recent startup.
Change history
Version
Change description
HDM2
Current post status. G6 products do not support options 0 and 4. G6 products obtain Port81 information, with each postcode containing 2 bytes.
Set a BIOS option
Use this command to set a BIOS option.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x19 index data
Table 138 Request field description (for AMD G7)
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Specify the configuration item. Options include:
·     For Genoa:
¡     0x00IOMMU.
¡     0x01GlobalCstateControl.
¡     0x02DeterminismControl.
¡     0x03Determinism Enable.
¡     0x04DFCstates.
¡     0x05NUMAnodespersocket.
¡     0x06Memoryinterleaving.
¡     0x08IPv4PXESupport.
¡     0x09IPv6PXESupport.
¡     0x0aABLConsoleOutControl.
¡     0x14—BootOrder1.
·     For Turin:
¡     0x00GnbNbIOMMU.
¡     0x02DeterminismCtl.
¡     0x03DeterminismEnable.
¡     0x04DFCstates.
¡     0x05DramNUMANodePerSocket.
¡     0x06MemoryInterleaving.
¡     0x0a—SocAblConOut.
¡     0x14—BootOrder1.
Data[8]
Specify the configuration value. Options include:
·     For IOMMU:
¡     0Disabled.
¡     1Enabled.
¡     2Auto.
·     For GlobalCstateControl:
¡     0Disabled.
¡     1Enabled.
¡     2Auto.
·     For DeterminismControl:
¡     0Manual.
¡     1Auto.
·     For Determinism Enable:
¡     0Power.
¡     2Performance.
·     For DFCstates:
¡     0Disabled.
¡     1Enabled.
¡     2Auto.
·     For NUMAnodespersocket:
¡     0NPS0.
¡     1NPS1.
¡     2NPS2.
¡     3NPS3.
¡     4Auto.
·     For Memoryinterleaving:
¡     0Disabled.
¡     1Auto.
¡     2Enabled.
·     For BootOrder1:
¡     0Hard Disk.
¡     1Network.
¡     4CD/DVD.
¡     7Other Device.
¡     36Disabled.
·     For IPv4PXESupport:
¡     1Enabled.
¡     0Disabled.
¡     1Enabled.
¡     0Disabled.
·     For ABLConsoleOutControl:
¡     0Disabled.
¡     1Enabled.
¡     2Auto.
Required permission
Remote control
# Set BIOS option IOMMU to 1.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x19 0x00 0x01
a2 63 00
Table 139 Response field description
Data[1:3]
Change history
Version
Change description
HDM3-2.02
Revised the data[7] value from 0x07 to 0x14 in the BIOS AMD field BootOrder1.
HDM3-2.01
Added support for G7 AMD products and added the option description for G7 AMD products.
Obtain a BIOS option
Use this command to obtain a BIOS option.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x1a 0x09
Table 140 Request field description (for AMD G7)
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
·     For Genoa:
¡     0x00IOMMU.
¡     0x04DFCstates.
¡     0x14—BootOrder1.
·     For Turin:
¡     0x00GnbNbIOMMU.
¡     0x04DFCstates.
¡     0x14—BootOrder1.
Required permission
Information query
# Obtain a BIOS option.
COMMAND> ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x1a 0x00
a2 63 00 01 00 00 00
Table 141 Response field description
Data[1:3]
Data[4:7]
Configuration value. For more information, see "Set a BIOS option."
Change history
Version
Change description
HDM3-2.02
HDM3-2.01
DNS
Obtain host name setting
Use this command to obtain host name setting.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x12
Table 142 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain host name settings.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x12
a2 63 00 01 09 6c 6f 63 61 6c 68 6f 73 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Table 143 Response field description
Data[1:3]
Data[4]
Host name mode. Supported options:
·     0Manual.
·     1Auto.
Data[5]
Length of the host name, 1 to 63.
Data[6-69]
Host name, suffixed with 0x00.
Change history
Version
Change description
HDM3
Added this command.
Security
Obtain the state of weak password dictionary validation
Use this command to query the state of weak password dictionary validation, which is disabled by default.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x21 0xA2 0x63 0x00 0x02
Table 144 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
G6 and G7 products.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x21 0xA2 0x63 0x00 0x02
a2 63 00 00
Table 145 Response field description
Data[1:3]
Data[4]
State of weak password dictionary validation:
·     0x00Disabled (default).
·     0x01Enabled.
Change history
Version
Change description
HDM2
Added this command.
Set the state of weak password dictionary validation
Use this command to enable or disable weak password dictionary validation.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x21 0xA2 0x63 0x00 0x03 0x00/0x01
Table 146 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Specify whether to enable or disable weak password dictionary validation:
·     0x00Disabled.
·     0x01Enabled.
Required permission
User accounts
G6 and G7 products.
COMMAND> ipmitool -I lanplus –H 192.168.30.251 -U admin –P Password@_ raw 0x36 0x21 0xa2 0x63 0x00 0x03 0x00
a2 63 00
Table 147 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Obtain ICMP outbound rules of the firmware
Use this command to obtain ICMP outbound rules of the firmware.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xA2 0x63 0x00 0x06
Table 148 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code. Obtain the state of ICMP outbound rules configured on the firmware.
Required permission
Information query
COMMAND>ipmitool -H 127.0.0.1 -I lanplus -U admin -P Password@_ raw 0x36 0x29 0xA2 0x63 0x00 0x06
a2 63 00 03
Table 149 Response field description
Data[1:3]
Data[4]
ICMP packet outbound rules:
·     BIT0: echo-reply outbound rule.
¡     1Disabled.
¡     0Enabled.
·     BIT1: time-exceeded outbound rule.
¡     1Disabled.
¡     0Enabled.
·     BIT2: destination-unreachable outbound rule.
¡     1Disabled.
¡     0Enabled.
Change history
Version
Change description
HDM2
Added this command.
Configure ICMP outbound rules on the firmware
Use this command to configure ICMP outbound rules on the firmware to fix the Traceroute detection vulnerability.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xA2 0x63 0x00 0x07 0x03
Table 150 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code. Set the network firewall ICMP outbound rule.
Data[7]
ICMP packet outbound rules settings.
¡     1Disabled.
¡     0Enabled.
¡     1Disabled.
¡     0Enabled.
¡     1Disabled.
¡     0Enabled.
As a best practice, to fix the Traceroute detection vulnerability, disable these three rules.
Required permission
Security
COMMAND>ipmitool - H 127.0.0.1 -I lanplus -U admin -P Password@_ raw 0x36 0x29 0xA2 0x63 0x00
0x07 0x03
a2 63 00
Table 151 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Network-related settings
Obtain HDM network service information
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x21 0xa2 0x63 0x00 0x10 Data[0:3]
Table 152 Request field description
0x36
NetFn code.
0x21
Command code.
0xa2 0x63 0x00
Data[0:3]
Specify the service ID. Supported options:
·     0x00000001Web.
·     0x00000002KVM.
·     0x00000004CD-media.
·     0x00000008FD-media.
·     0x00000010HD-media.
·     0x00000020SSH.
·     0x00000080IPMI.
·     0x00000100SNMP.
·     0x00000800VNC.
·     0x00000400—RemoteXDP(ASD).
User role
User
Required permission
Information query
# Obtain SSH service information.
COMMAND> ipmitool -I lanplus  -H 192.168.55.2 -U admin -P Password@_ raw 0x36 0x21 0xa2 0x63 0x00 0x10 0x20 0x00 0x00 0x00
 a2 63 00 20 00 00 00 00 ff ff ff ff 16 00 00 00
 58 02 00 00 83 80 3c 00 00 00 08 07 00 00
Table 153 Response field description
Data[1:3]
Data[4:7]
Service ID. Supported options:
·     0x00000001Web.
·     0x00000002KVM.
·     0x00000020SSH.
·     0x00000080IPMI.
·     0x00000100SNMP.
·     0x00000800VNC.
·     0x00000400RemoteXDP(ASD).
Data[8]
Enabling status of the service.
Data[9:12]
Insecure service port.
The value of all-Fs indicates that the interface is a secure service port.
Data[13:16]
Secure service port.
The value of all-Fs indicates that the interface is an insecure service port.
Data[17:20]
Session timeout time.
Data[21]
Maximum number of sessions. If this field displays 0xFF, the field value is invalid.
Bit[7]: If this bit is 1, the field cannot be modified.
Bits[6:0]: Maximum number of sessions.
Data[22]
Number of active sessions. If this field displays 0xFF, the field value is invalid.
Bits[6:0]: Number of active sessions.
Data[23:26]
Minimum session timeout time, in seconds.
Data[27:30]
Maximum session timeout time, in seconds.
Change history
Version
Change description
HDM3-2.03
Added service ID RemoteXDP(ASD).
HDM3-2.02
Deleted Telnet service information.
HDM3
Added this command.
Remarks
None.
Configure HDM network service settings
ipmitool -I connect_type -H ip_address -U username -P password raw 0x36 0x21 0xa2 0x63 0x00 0x11 Data0_18
Table 154 Request field description
0x36
NetFn code.
0x21
Command code.
0xa2 0x63 0x00
0x11
Subcommand code.
Data[0:3]
Specify a service ID. Supported options:
·     0x00000001Web.
·     0x00000002KVM.
·     0x00000020SSH.
·     0x00000080IPMI.
·     0x00000100SNMP.
·     0x00000800VNC.
Data[4]
Enable or disable the service. Supported options:
·     0—Disable.
·     1—Enable.
Data[5-8]
Specify the interface as an insecure service port.
To use the interface as a secure service port, set the field value to all Fs.
Data[9-12]
Specify the interface as a secure service port.
To use the interface as an insecure service port, set the field value to all Fs.
Data[13-16]
Set the session timeout time, in seconds.
The value of this field must be a multiple of 60.
Data[17]
Set the maximum number of sessions. Refer to the maximum number of sessions field in the obtained HDM network service information to set this field:
·     If the obtained field displays 0xFF, set this field to 0xFF.
·     If the highest bit of the obtained field is 1, set this field to 0.
Data[18]
Set the number of active sessions. Refer to the number of active sessions field in the obtained HDM network service information to set this field:
User role
Administrator
Required permission
Security
# Set the session timeout time to 900 seconds for the SSH service.
COMMAND> ipmitool -I lanplus  -H 192.168.55.2 -U admin -P Password@ raw 0x36 0x21 0xa2 0x63 0x00 0x11 0x20 0x00 0x00 0x00 0x01 0xff 0xff 0xff 0xff 0x16 0x00 0x00 0x00 0x84 0x03 0x00 0x00 0x00 0x00
# Obtain the SSH service information to verify that the session timeout time has been set to 900 seconds.
Table 155 Response field description
Data[1:3]
Change history
Version
Change description
HDM3-2.03
HDM3-2.02
HDM3
Added this command.
Remarks
None.
Obtain permissions of all user roles
Use this command to obtain permissions of all user roles.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x67
Table 156 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain permissions of all user roles.
COMMAND>ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xA2 0x63 0x00 0x67
a2 63 00 ff 01 b7 01 80 01 80 01 80 01 80 01 80 01 80 01
Table 157 Response field description
Data[1-3]
Data[4-5]
Permissions of user role Administrator.
Data[6-7]
Permissions of user role Operator.
Data[8-9]
Permissions of user role User.
Data[10-11]
Permissions of the custom 1 user role.
Data[12-13]
Permissions of the custom 2 user role.
Data[14-15]
Permissions of the custom 3 user role.
Data[16-17]
Permissions of the custom 4 user role.
Data[18-19]
Permissions of the custom 5 user role.
Change history
Version
Change description
HDM-2.0.04
Added this command.
Set permissions for a custom user role
Use this command to set permissions for a custom user role.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xa2 0x63 0x00 0x51 0x01 0xe3 0x00
Table 158 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Custom user role ID:
·     0x01—Custom 1.
·     0x02—Custom 2.
·     0x03—Custom 3.
·     0x04—Custom 4.
·     0x05—Custom 5.
Data[8-9]
Permissions that a user role has:
Data8:
·     0—Remote control
·     1—Remote media.
·     2—Security.
·     3—User accounts
·     4—Basic configuration
·     5—Power control.
·     6—Maintenance
·     7—Information query.
Data9:
·     0—Password modification
·     1—System audit.
·     2 to 7—Reserved.
Required permission
User accounts
# Set permissions for the custom 1 user role.
COMMAND>ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xA2 0x63 0x00 0x51 0x01 0xe3 0x00
0xa2 0x63 0x00
Table 159 Response field description
Data[1-3]
Change history
Version
Change description
HDM2
Added the system audit permission.
HDM-2.0.04
Added this command.
Trigger an immediate network restart
Use this command to trigger an immediate network restart.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x01
Table 160 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Basic configuration
# Trigger a network restart.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x01
a2 63 00
Table 161 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Delete all network firewall rules
Use this command to delete all network firewall rules.
The command execution takes a long time and may cause IPMI timeout. To avoid this issue, add -N to specify the timeout value.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x02
Table 162 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Basic configuration
# Delete all firewall rules and set the timeout value to 20 seconds.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus –N 20 -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x02
a2 63 00
Table 163 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Set NCSI information
Use this command to set NCSI information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x03 0x01 0x00 0x00 0x00 0x00 0x01 0x02
Table 164 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Cardauto
·     0—Disable network card autonegotiation.
·     1—Enable network card autonegotiation.
Data[8]
Failover
·     0—Disable port autonegotiation.
·     1—Enable port autonegotiation.
Data[9]
CardSelect
Data[10]
Port
Data[11-13]
CardautoRules: Network card autonegotiation priority.
Required permission
Basic configuration
Blade servers and X18000 G6 do not supported this command.
# Set NCSI information.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x03 0x01 0x01 0x00 0x00 0x00 0x00 0x01 0x02
a2 63 00
Table 165 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Obtain NCSI information
Use this command to obtain NCSI information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x04
Table 166 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Information query
Blade servers do not supported this command.
# Obtain NCSI information.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x04
a2 63 00 0x01 0x00 0x01 0x03 0x00 0x00 0x01 0x02 0x01 0x04 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Table 167 Response field description
Data[1:3]
Data[4]
Cardauto.
Data[5]
Failover.
Data[6]
Ncsi state.
Data[7]
ModeNumSupported.
Data[8]
CardSelect.
Data [9-11]
CardautoRules: Network card auto-adaptation priority.
Data[12]
Card0 nic present.
Data[13]
Card0 total channel number.
Data[14]
Card0 select channel.
Data[15]
Card1 nic present.
Data[16]
Card1 total channel number.
Data[17]
Card1 select channel.
Data[18]
Card2 nic present.
Data[19]
Card2 total channel number.
Data[20]
Card2 select channel.
Change history
Version
Change description
HDM2
Added this command.
Set the BMC network mode
Use this command to set the BMC network mode.
To avoid IPMI timeout due to long execution time, add -N with timeout timer for this command.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x05 0x01
Table 168 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
SelectMode:
·     0—Normal mode.
·     1—Adaptive mode.
Required permission
Basic configuration
# Set the network mode to adaptive mode.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x05 0x01
a2 63 00
Table 169 Response field description
Data[1:3]
Change history
Version
Change description
HDM2-1.53
Added description for the timeout issue and the corresponding resolution.
HDM2
Added this command.
Obtain the status setting of a network port
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x0e ChannelNumber
Table 170 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Channel:
·     0x01—Channel 1.
·     0x08—Channel 8.
Required permission
Information query
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x0e 0x01
a2 63 00 03
Table 171 Response field description
Data[1:3]
Data[4]
EnableState:
·     0x00Both IPv4 and IPv6 disabled.
·     0x01Only IPv4 enabled.
·     0x02Only IPv6 enabled.
·     0x03Both IPv4 and IPv6 enabled.
Change history
Version
Change description
HDM2
Added this command.
Set the network port status
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x0f ChannelNumber EnableState
Table 172 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Channel:
·     0x01Channel 1.
·     0x08Channel 8.
Data[8]
EnableState:
·     0x00Disable both IPv4 and IPv6.
·     0x01Enable only IPv4.
·     0x02Enable only IPv6.
·     0x03Enable both IPv4 and IPv6.
Required permission
Basic configuration
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x0f 0x01 0x03
a2 63 00
Table 173 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Obtain network port in use in active/standby mode
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x26
Table 174 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Information query
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x26
a2 63 00 00
Table 175 Response field description
Data[1:3]
Data[4]
Network port in use:
·     0x00—Dedicated network port.
·     0x01—Shared network port.
Change history
Version
Change description
HDM2-1.57
Added this command.
Obtain the name of a network port
Use this command to obtain the name of a network port.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x29 0xa2 0x63 0x00 0x10 ChannelNumber
Table 176 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
ChannelNumber. Options include:
·     0x01Channel 1.
·     0x08Channel 8.
Required permission
Information query
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x29 0xa2 0x63 0x00 0x10 0x01
a2 63 00 65 74 68 30 00 00 00 00 00 00 00 00 00 00 00 00
65 74 68 30 -> “eth0”
Table 177 Response field description
Data[1:3]
Manufacturer ID. This field is fixed to a2 63 00.
Data[4-20]
Name of a network port.
Obtain the link status of dedicated and shared network ports
Use this command to obtain the link status of dedicated and shared network ports.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x6a
Table 178 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain the link status of dedicated and shared network ports.
COMMAND> ipmitool -H 127.0.0.1 -U admin –P Password@_ -I lanplus raw 0x36 0x0b 0xa2 0x63 0x00 0x6a
a2 63 00 01 04 00 01 00 00 00 00 00 00 00 00 00
00 00 00 00 00
Table 179 Response field description
Data[1:3]
Data[4]
Link status of the dedicated port. Supported options:
·     0x01Up.
·     0x00Down.
Data[5]
Number of shared ports.
Data[6]
Ports selected as the shared ports.
Data[7:21]
Link status of the shared ports. Supported options:
·     0x01—Up.
·     0x00—Down.
Change history
Version
Change description
HDM-1.30.12
Added this command.
SNMP
Obtain SNMP version information
Use this command to obtain basic SNMP settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x14
Table 180 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain SNMP version information.
COMMAND> > ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x28 0xa2 0x63 0x00 0x14
Response:
00 00 01 72 6f 63 6f 6d 6d 73 74 72 00 00 00 00
00 00 00 00 00 00
Table 181 Response field description
Data[1]
Enabling status of SNMPv1. Supported options:
·     0x00Enabled.
·     0x01Disabled.
Data[2]
Enabling status of SNMPv2c. Supported options:
·     0x00Enabled.
·     0x01Disabled.
Data[3]
Enabling status of SNMPv3. Supported options:
·     0x00Enabled.
·     0x01Disabled.
Data[4-36]
SNMP read community.
Data[37-69]
SNMP write community.
Data[70]
Enabling status of long password. Supported options:
·     0x00Enabled.
·     0x01Disabled.
Configure SNMP version settings
Use this command to configure SNMP version settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x15  Data7-76
Table 182 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6:]
Subcommand code.
Data[7:]
Enable or disable SNMPv1. Supported options:
·     0x00Disable.
·     0x01Enable.
Data[8:]
Enable or disable SNMPv2c. Supported options:
·     0x00Disable.
·     0x01Enable.
Data[9:]
Enable or disable SNMPv3. Supported options:
·     0x00Disable.
·     0x01Enable.
Data[10-42]
SNMP read community with a maximum length of 32 bits, which supports only letters, digits, spaces, and the following special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
Data[43:75]
SNMP write community with a maximum length of 32 bits, which supports only letters, digits, spaces, and the following special characters: `~!@#$%^&*()_+-=[]\{}|;':",./<>?
Data[76]
Enable or disable long password.
·     0x00Disable.
·     0x01Enable.
Required permission
Basic configuration
# Configure SNMP version settings.
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x28 0xa2 0x63 0x00 0x15 0x00 0x00 0x01 0x72 0x6f 0x63 0x6f 0x6d 0x6d 0x73 0x74 0x72 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Change history
Version
Change description
HDM3
Added this command.
Set the enabling status of SNMP traps
Use this command to set the enabling status of SNMP traps.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x01 SnmpTrapEnable
Table 183 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Enable or disable SNMP traps. Supported options:
·     1Enable.
·     0Disable.
Required permission
Basic configuration
# Disable SNMP traps.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x01 0x00
Change history
Version
Change description
HDM-1.30.08
Added this command.
Set the SNMP trap version
Use this command to set the SNMP trap version.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x02 SnmpTrapVersion
Table 184 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Set the SNMP trap version for a user.
Bits[0:1]: Specify an SNMP version. Supported options:
·     0SNMPv1.
·     1SNMPv2c.
·     2—SNMPv3.
Bits[2:7]: Specify a user ID.
Required permission
Basic configuration
To set the SNMP trap version to SNMPv3, you must specify an existing user that has the SNMP extended privilege.
# Set the SNMP trap version to SNMPv1.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x02 0x00
Change history
Version
Change description
HDM-1.30.08
Added this command.
Set the location of an SNMP trap node
Use this command to set the location of an SNMP trap node.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x05 0x65 0x65 0x65 0x00
Table 185 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:N]
Location of the SNMP trap node.
This field is a string of up to to 31 bytes and ended with \0.
Required permission
Basic configuration
# Set the location of an SNMP trap node.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x05 0x61 0x62 0x63 0x64 0x65 0x66 0x67 0x68 0x69 0x6a 0x6b 0x6c 0x6d 0x6e 0x6f 0x70 0x71 0x72 0x73 0x74 0x75 0x76 0x77 0x78 0x79 0x7a 0x35 0x36 0x37 0x38 0x39 0x00
a2 63 00
Table 186 Response field description
Data[1:3]
Change history
Version
Change description
HDM3-1.14
Changed the maximum length of the node location to 31 bytes.
HDM-1.30.08
Added this command.
Set the SNMP trap contact information
Use this command to set the SNMP trap contact information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x06 0x65 0x65 0x65 0x00
Table 187 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:N]
Set the contact information.
This field is a string of up to 31 bytes and ended with \0.
Required permission
Basic configuration
# Set the SNMP trap contact.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x06 0x61 0x62 0x63 0x64 0x65 0x66 0x67 0x68 0x69 0x6a 0x6b 0x6c 0x6d 0x6e 0x6f 0x70 0x71 0x72 0x73 0x74 0x75 0x76 0x77 0x78 0x79 0x7a 0x41 0x42 0x43 0x44 0x45 0x00
a2 63 00
Table 188 Response field description
Data[1:3]
Change history
Version
Change description
HDM3-1.14
Changed the maximum length of the contact information to 31 bytes.
HDM-1.30.08
Added this command.
Configure an SNMP community
Use this command to configure an SNMP community.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x07 0x65 0x65 0x65 0x00
Table 189 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:N]
Specify the name of the SNMP community.
Required permission
Basic configuration
# Configure an SNMP community.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x07 0x61 0x62 0x63 0x64 0x65 0x66 0x67 0x68 0x69 0x6a 0x6b 0x6c 0x6d 0x6e 0x6f 0x70 0x71 0x72 0x73 0x74 0x75 0x76 0x77 0x78 0x79 0x7a 0x31 0x32 0x33 0x34 0x35 0x00
a2 63 00
Table 190 Response field description
Data[1:3]
Change history
Version
Change description
HDM3-1.14
Changed the maximum length of the community name to 31 bytes.
HDM-1.30.08
Added this command.
Specify the severity levels of SNMP traps to be reported
Use this command to specify the severity levels of SNMP traps to be reported.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x08 Data[7]
Table 191 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand node.
Data[7]
Specify the severity levels. Supported options:
·     0—Minor + major + critical.
·     1Major + critical.
·     2Information +minor + major + critical.
·     3—Critical.
Required permission
Basic configuration
# Specify the severity levels of SNMP traps to be reported.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x08 0x00
Change history
Version
Change description
HDM2-1.09
Modified the severity levels of SNMP traps to be reported and added option 3, which represents the critical level.
HDM-1.30.12
Modified the severity level of "major + critical" to "minor + major + critical".
HDM-1.30.08
Added this command.
Configure an SNMP trap server
Use this command to configure an SNMP trap server.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x09 Data[7] Data[8] Data[9:10] Date[11] Date[12:N]
Table 192 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Specify the ID of an SNMP trap server. Supported options:
·     1.
·     2.
·     3.
·     4.
·     5.
·     6.
·     7.
·     8.
Data[8]
Enable or disable the SNMP trap server. Supported options:
·     1Enable.
·     0Disable.
Data[9:10]
Specify the port number of the SNMP trap server.
Data[11]
Specify the mode of the SNMP trap server. Supported options:
·     0—IPv4.
·     1—IPv6 or domain name.
Data[12:15]
Hexadecimal data of IPv4.
Data[12:76]
Specify the ASCII code for the IPv6 address or domain name of the SNMP trap server, up to 64 characters. If the string does not reach the maximum length, 0x00 must be added at the end of the last valid character as an end tag.
Required permission
Basic configuration
# Configure IPv4 address 192.168.1.2 for the SNMP trap server.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x09 0x02 0x01 0xA3 0x00 0x00 0xc0 0xa8 0x01 0x02
# Configure domain name www.12345.com for the SNMP trap server.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x09 0x02 0x01 0xA3 0x00 0x02 0x77 0x77 0x77 0x2E 0x31 0x32 0x33 0x34 0x35 0x2E 0x63 0x6F 0x6D 0x00 0x00 0x00 0x00
# Configure IPv6 address 2323::2220:2220:2220:2220:1348 for the SNMP trap server.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x09 0x03 0x01 0xA3 0x00 0x01 0x32 0x33 0x32 0x33 0x3A 0x3A 0x32 0x32 0x32 0x30 0x3A 0x32 0x32 0x32 0x30 0x3A 0x32 0x32 0x32 0x30 0x3A 0x32 0x32 0x32 0x30 0x3A 0x31 0x33 0x34 0x38 0x00
Change history
Version
Change description
HDM2-1.53
Added restrictions and guidelines for specifying an IPv6 address or domain name for Data[12].
HDM-2.33
Added the support for the number of SNMP trap servers from 4 to 8.
HDM-1.30.08
Added this command.
Set the SNMP trap mode
Use this command to set the SNMP trap mode.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x0a 0x00
Table 193 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Trap mode:
·     0—Module OID mode.
·     1—Event OID mode.
·     2—Event code OID mode.
Required permission
Basic configuration
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x0a 0x00
Change history
Version
Change description
HDM-1.30.11
Added this command.
Obtain SNMP trap general settings
Use this command to obtain the SNMP trap general settings, including: trap enabling status, trap alarm mode, trap version number, trap v3 user ID, trap v3 username, node location, contact information, community name, and severity levels of traps to be reported.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x06
Table 194 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain SNMP trap settings. In this example, the settings are: trap enabled, OID alarm mode, trap v2c version, trap v3 user ID 0, and all alarm levels for trap reporting. The trap v3 username, node location, contact info, and community name are empty.
COMMAND>ipmitool - U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x28 0x06
a2 63 00 01 00 01 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 02
Table 195 Response field description
Data[1:3]
Date[4]
Trap enablement:
·     0Disabled.
·     1Enabled.
Data[5]
Trap mode:
·     1—Event OID mode.
Data[6]
Trap version number:
·     0—v1.
·     1—v2c.
·     2—v3.
Data[7]
Trap v3 user ID.
Data[8:40]
Trap v3 username.
Data[41:72]
Node location.
Data[73:104]
Contact information.
Data[105:136]
Community name.
Data[137]
Specify the severity levels of traps to be reported. Supported options:
·     3—Critical.
Change history
Version
Change description
HDM3-1.16
Changed the response fields to the same as HDM3.
HDM2-1.09
HDM2
Added this command.
Send a SNMP trap test command
Use this command to send a test command to the specified SNMP trap server.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x07 Index
Table 196 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Specify the ID of a trap server, 1 to 8.
Required permission
Basic configuration
# Send a trap alarm test command to server 1.
COMMAND>ipmitool - U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x28 0x07 0x01
0xa2 0x63 0x00
Table 197 Response field description
Data[0]
Command sending result. Supported options:
·     0x00Test command sent successfully.
·     0xce—Failed to send the test command.
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Set user SNMP v3 information
Use this command to set user SNMP v3 information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0d 0xa2 0x63 0x00 0x0b 0x02 0x01 0x01 0x01 0x01 0x36 0x36 0x36 0x36 0x36 0x36 0x36 0x36
Table 198 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Specify the user ID of a local user, the value range is 2 to 16.
Data[8]
Enabling status of SNMP v3 extended permissions. Supported options:
·     0—Disabled.
·     1—Enabled.
Data[9]
Enabling status of SNMP v3 read-write permissions.
Supported options:
·     1—Read-only.
·     2—Read-write.
Data[10]
SNMP v3 authentication algorithm.
Supported options:
·     1—SHA.
·     2—MD5.
·     4—SHA256.
·     5—SHA384.
·     6—SHA512.
Data[11]
SNMP v3 encryption algorithm.
Supported options:
·     1—DES.
·     2—AES.
·     4—AES192.
·     5—AES256.
Encryption algorithms AES192 and AES256 can only be used in combination with authentication algorithm SHA256, SHA384, or SHA512.
Data[12-51]
SNMPv3 independent password.
The password can contain 8 to 40 characters, and must meet the advanced password policy requirements for local user passwords.
Required permission
User accounts
Product compatibility
# Set user SNMP v3 information.
COMMAND>ipmitool - H 192.168.7.23 -I lanplus -U admin -P Password@_ raw 0x36 0x0d 0xa2 0x63 0x00 0x0b 0x02 0x01 0x01 0x01 0x01 0x36 0x36 0x36 0x36 0x36 0x36 0x36 0x36
Change history
Version
Change description
HDM2-1.19
Changed the password requirements for Data[12-51] by adding support for spaces and slashes (\).
HDM2
Added this command.
NTP
HDM3 supports the interfaces for obtaining NTP configuration and configuring all NTP settings. The interfaces in the subsequent sections might overlap with the above two interfaces. However, to maintain continuity in the use of these interfaces, these interfaces are still retained.
Obtain the NTP configuration information
Use this command to obtain the NTP configuration information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x22 0xa2 0x63 0x00 0x08 Data7
Table 199 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Parameter selector (See Table 200.)
Table 200 Parameter selector description
0x01
NTP server synchronization function switch.
0x02
NTP primary server.
0x03
NTP secondary server.
0x04
NTP tertiary server.
0x05
NTP time zone.
0x06
NTP synchronization rate.
Required permission
Information query
Not restricted to specific products.
# Obtain NTP configuration information and obtain the NTP main server address.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x22 0xa2 0x63 0x00 0x08 0x02
a2 63 00 31 2e 63 6e 2e 70 6f 6f 6c 2e 6e 74 70
2e 6f 72 67 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00
Table 201 Response field description
Data[1:3]
Data[4:N]
See Table 202.
Table 202 Data description
Value/Description
NTP server synchronization ffunction switch.
0x01
Data[4]:
·     0Indicates that NTP is disabled.
·     1Indicates that NTP is enabled and the synchronization is successful.
·     2—Indicates that NTP is enabled but the synchronization failed.
NTP primary server.
0x02
Data[4-131]: The maximum length of the NTP primary server address is 128 bytes. Convert to ASCII code for reading.
0x03
Data[4-131]: The maximum length of the NTP secondary server address is 128 bytes. Convert to ASCII code for reading.
0x04
Data[4-131]: The maximum length of the NTP tertiary server address is 128 bytes. Convert to ASCII code for reading.
NTP time zone.
0x05
Data[4-67]: The maximum length of NTP time zone is 64 bytes. Convert to ASCII code for reading.
0x06
Data[4-7]: NTP synchronization interval in seconds. This field is displayed in little-endian format using 4 bytes.
Change history
Version
Change description
HDM2-2.03
Edited the description for the NTP server synchronization function switch.
HDM2-1.64
HDM2-2.02
Added this command.
Configure NTP settings
Use this command to configure NTP settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x22 0xa2 0x63 0x00 0x09 Data7 Data8
Table 203 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Parameter selector (See Table 204.)
Data[8-N]
Configuration parameter data.
Table 204 Parameter selector description
Value/Description
NTP synchronization enabling status
0x01
Data[8]:
·     0x00Disable the NTP service.
·     0x01Enable the NTP service.
Primary NTP server address
0x02
Data[8-135]: Address of the primary NTP server, a hexadecimal value of up to 127 bytes. It is required to pad with zeros if the length is less than 127 bytes. Supported address types:
·     IPv4 address.
·     IPv6 address.
·     FQDN address.
To obtain the hexadecimal value:
·     Enter the NTP server address as a string in the Notepad++ tool, such as ntp.abc.com.
·     Use the Converter plug-in to convert the ASCII address to a hexadecimal address.
Secondary NTP server address
0x03
Same as the primary NTP server address.
Tertiary NTP server address
0x04
NTP time zone configuration
0x05
Data[8-71]:
NTP time zone in UTC format.
Use the same method as the primary server to convert the time zone string to a hexadecimal value.
The maximum length of the time zone string is 64 bytes.
0x06
Data[8-11]:
NTP synchronization interval in seconds, in the range of 600 to 2592000.
This field is displayed in little-endian format.
Required permission
Basic configuration
Data[1:3]
# Set the NTP refresh interval to 600s.
COMMAND> ipmitool -I lanplus -H 192.168.88.89 -U admin -P Password@_ raw 0x36 0x22 0xa2 0x63 0x00 0x09 0x06 0x58 0x02 0x00 0x00
a2 63 00
# Specify the host at ntp.abc.com as the primary NTP server.
COMMAND> ipmitool -I lanplus -H 192.168.88.89 -U admin -P Password@_ raw 0x36 0x22 0xa2 0x63 0x00 0x09 0x02 0x6e 0x74 0x70 0x2e 0x61 0x62 0x63 0x2e 0x63 0x6f 0x6d
a2 63 00
Change history
Version
Change description
HDM3-1.13
Revised the description of the Data[4] field for parameter selectors.
HDM3-1.08
Revised the description of the Data[7] and Data[8-N] fields.
HDM3
Added this command.
Set the time zone
Use this command to set the time zone.
ipmitool -I connect_type -H hostname -U username -P password raw 0x0A 0x5D Data[1:2]
Table 205 Request field description
Data[1:2]
Specify the UTC offset, in minutes. The value range is -720 to 840. Only hours and half hours are supported. The value must be in hexadecimal format.
Required permission
Basic configuration
To correctly set the time zone, you must correctly calculate the UTC offset, and then convert the offset to a value in hexadecimal and little endian format. For example, to set the time zone to UTC-8:00, perform the following steps:
1.     Calculate the UTC offset: -8*60=-480.
2.     Convert the offset to a value in hexadecimal notation 0xfe 0x20.
3.     Adjust the endianness of the value to little endian: 0x20 0xfe.
# Set the time zone to UTC-8:00.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x0A 0x5D 0x20 0xfe
Use this command to set the NTP refresh interval (the frequency at which the server synchronizes the time with NTP servers.)
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0a 0xa2 0x63 0x00 0x05 Data[7:10]
Table 206 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7:10]
Set the NTP refresh interval, in seconds.
Value range: 600 to 2592000.
Required permission
Basic configuration
Data[1:3]
# Set the NTP refresh interval to 600 seconds.
COMMAND> ipmitool -H 127.0.0.1 -U jdroot -P JCss%6!8 -I lanplus raw 0x36 0x0a 0xa2 0x63 0x00 0x05 0x58 0x02 0x00 0x00
a2 63 00
Obtain the IP address of the tertiary NTP server
Use this command to obtain the IP address of the tertiary NTP server.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x70
Required permission
Information query
# Obtain the IP address of the tertiary NTP server.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x70
a2 63 00 33 2e 63 6e 2e 70 6f 6f 6c 2e 6e 74 70
 2e 6f 72 67 00 31 30 30 52 30 30 31 42 30 32 44
 30 32 37 53 50 30 34 5f 44 45 42 55 47 00 00 00
 00 00 00
Table 207 Response field description
Data[1:3]
Data[4:131]
IP address of the tertiary NTP server, which is shorter than 128 bytes.
Change history
Version
Change description
HDM-1.11.36, HDM-1.30.12
Added this command.
Obtain the NTP synchronization interval
Use this command to obtain the NTP synchronization interval.
ipmitool -I connect_type -H hostname -U username -P password raw  0x36 0x0a 0xa2 0x63 0x00 0x0b
Table 208 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain the NTP synchronization interval.
COMMAND> ipmitool -H 127.0.0.1 -U jdroot -P JCss%6!8 -I lanplus raw 0x36 0x0a 0xa2 0x63 0x00 0x0b
a2 63 00 58 02 00 00
Table 209 Response field description
Data[1:3]
Data[4:7]
Synchronization interval in seconds.
Change history
Version
Change description
HDM-2.13.00
Added this command.
HDM maintenance
Obtain HDM firmware information
Use this command to obtain HDM firmware information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x25 0xa2 0x63 0x00 0x0a 0x01
Table 210 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Subsubcommand code.
Required permission
Information query
# Obtain HDM firmware information.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x25 0xa2 0x63 0x00 0x0a 0x01
 01 00 00 42 4d 43 00 00 00 00 00 01 34 00 00 00
 00 00 00 00 56 31 30 30 52 30 30 31 42 30 31 44
 30 35 32 00 00 00 00 00 00 00 00 00 00 00 00 00
 00 00 00 00
Table 211 Response field description
Data[1]
Number of HDM firmware versions.
Information about the first HDM firmware version
Data[2]
ID.
Data[3]
Instance.
Data[4:11]
Device name. This field is a string fixed to BMC.
Data[12]
Major version, in decimal notation.
Data[13]
Minor version.
Data[14:19]
Aux version.
Data[14]: Small version.
Data[15]: SP version.
Data[16]: HP version
Data[17:19]: Reserved.
Major, minor, and aux versions together define a firmware version. The following are examples:
·     Major=0x01, Minor=0x00, Aux=0x080000000000 represent version 1.00.08.
·     Major=0x01, Minor=0x00, Aux=0x080100000000 represent version 1.00.08P01.
·     Major=0x01, Minor=0x00, Aux=0x080102000000 represent version 1.00.08P01H02.
Data[20]
Device.
Data[21:148]
Internal version. This field is a string, V500R001B01D002, for example.
Information about the Nth HDM firmware version (if any). N represents the number of an HDM firmware version.
Change history
Version
Change description
HDM3
Added this command.
Obtain BIOS firmware information
Use this command to obtain BIOS firmware information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x25 0xa2 0x63 0x00 0x0a 0x02
Table 212 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Subsubcommand code.
Required permission
Information query
# Obtain BIOS firmware information.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x25 0xa2 0x63 0x00 0x0a 0x02
 01 00 00 42 49 4f 53 00 00 00 00 06 00 14 00 00
 00 00 00 01 56 31 30 30 52 30 30 31 42 30 31 44
 30 32 30 53 50 30 31 5f 44 45 42 55 47 00 00 00
 00 00 00 00
Table 213 Response field description
Data[1]
Number of BIOS firmware versions.
Information about the first BIOS firmware version
Data[2]
Version ID.
Data[3]
Instance.
Data[4:11]
Device name. This field is a string fixed to BIOS.
Data[12]
Data[13]
Minor version.
Data[14:19]
Aux version.
Data[16]: HP version.
Data[20]
Device.
Data[21:148]
Information about the Nth BIOS firmware version (if any). N represents the number of an HDM firmware version.
Change history
Version
Change description
HDM3
Added this command.
Restore factory HDM settings
Use this command to restore factory HDM settings, which is edited based on the default settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x22 0xa2 0x63 0x00 0x0b 0x01
Table 214 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Subsubcommand code.
Required permission
Maintenance
Data[1:3]
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x22 0xa2 0x63 0x00 0x0b 0x01
a2 63 00
Change history
Version
Change description
HDM3
Added this command.
Obtain CPLD firmware information
Use this command to obtain CPLD firmware information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x25 0xa2 0x63 0x00 0x0a 0x04
Table 215 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Subsubcommand code.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x25 0xa2 0x63 0x00 0x0a 0x04
01 00 00 43 50 4c 44 00 00 00 00 00 01 00 00 00
00 00 00 00 56 30 30 31 00 00 00 00 00 00 00 00
00 00 00 00
Data[1]
Number of CPLD versions.
Information about the first CPLD version
Data[2]
ID.
Data[3]
Instance.
Data[4:11]
Device name. This field is a string fixed to CPLD.
Data[12]
Major version, in decimal notation. The default is 0.
Data[13]
Minor version, release version.
Data[14:19]
Aux version.
Data[14]: Debug version.
Data[15-19]: Reserved.
Data[20]
Device.
Data[21:148]
Internal version, for example, V001AA. This field is a string.
Information about the Nth CPLD version (if any). N represents the number of a CPLD version.
Change history
Version
Change description
HDM3
Added this command.
Obtain FPCPLD firmware information
Use this command to obtain FPCPLD firmware information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x25 0xa2 0x63 0x00 0x0a 0x00 0x01
Required permission
Information query
Data[1]
Number of FPCPLD versions.
Information about the first FPCPLD version
Data[2]
ID.
Data[3]
Instance.
Data[4:11]
Device name. This field is a string fixed to FPCPLD.
Data[12]
Data[13]
Data[14:19]
Aux version.
Data[20]
Device.
Data[21:148]
Internal version. This field is a string.
Information about the Nth FPCPLD version (if any). N represents the number of a FPCPLD version.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x25 0xa2 0x63 0x00 0x0a 0x00 0X01
01 00 00 50 46 52 43 50 4C 44 00 00 00 00 00 00
00 00 00 00 4e 2f 41 00 00 00 00 00 00 00 00 00
00 00 00 00
Change history
Version
Change description
HDM3
Added this command.
Obtain service USB device configuration
Use this command to obtain service USB device configuration.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xA2 0x63 0x00 0x89
Table 216 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Information query
Only G5, G6, and G7 servers that support the dedicated management interface support this command.
COMMAND>ipmitool –I lanplus –H 127.0.0.1 –U admin –P Password@_raw 0x36 0x0b 0xA2 0x63 0x00 0x89
a2 63 00 00 00 00
Table 217 Response field description
Data[1-3]
Data[4]
Service USB device status:
·     0—Off.
·     1—On.
Data[5]
Presence status:
·     0—Absent.
·     1—Present.
·     2Operating.
Data[6]
Auto SDS log downloading:
·     0—Off.
·     1—On.
Change history
Version
Change description
HDM-2.25
Added this command.
Set service USB device configuration
Use this command to set service USB device configuration.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xA2 0x63 0x00 0x71 0x01 0x01
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Set the service USB device status:
·     0—Off.
·     1—On.
Data[8]
Set the auto SDS log downloading status:
·     0—Off.
·     1—On.
Required permission
Maintenance
Data[1-3]
# Set service USB device configuration.
COMMAND>ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xA2 0x63 0x00 0x71 0x01 0x01
0xa2 0x63 0x00
Change history
Version
Change description
HDM-2.25
Added this command.
Obtain Wi-Fi service enabling status
Use this command to obtain Wi-Fi service enabling status. HDM3 does not support this command in the current software version.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0xa2
Table 218 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# View Wi-Fi service enabling status.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x0b 0xA2 0x63 0x00 0xa2
00
Table 219 Response field description
Data[1:3]
Data[4]
Wi-Fi service enabling status:
·     0x00Disable.
·     0x01Enable.
Change history
Version
Change description
HDM-3.18
Added this command.
Set Wi-Fi service enabling status
Use this command to set Wi-Fi service enabling status. HDM3 does not support this command in the current software version.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xA2 0x63 0x00 0xa0 0x00
Table 220 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Set Wi-Fi service status:
·     0x00Disable.
·     0x01Enable.
Required permission
Basic configuration
# Set Wi-Fi service enabling status.
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x09 0xA2 0x63 0x00 0xa0 0x00
a2 63 00
Table 221 Response field description
Data[1:3]
Change history
Version
Change description
HDM-3.18
Added this command.
Obtain the number of taskservice tasks and the current task ID
Use this command to obtain the number of taskservice tasks and the current task ID.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x27 0xa2 0x63 0x00 0x01
Table 222 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 00x27 0xa2 0x63 0x00 0x01
a2 63 00 02 00 01 00 00 00 00 00 00 00 01 02
Table 223 Response field description
Data[1:3]
Data[4:5]
Number of current tasks.
Data[6:7]
Number of successful tasks.
Data[8:9]
Number of failed tasks.
Data[10:11]
Number of canceled tasks.
Data[12:13]
Number of deleted tasks.
Data[14-]
Current task ID.
Change history
Version
Change description
HDM2
Added this command.
Obtain taskservice task details
Use this command to obtain detailed information about taskservice tasks.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x27 0xa2 0x63 0x00 0x02 TaskID
Table 224 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Task ID.
Required permission
Information query
COMMAND> ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 00x27 0xa2 0x63 0x00 0x02 0x01
Table 225 Response field description
Data[1:3]
Data[4]
Task status:
·     0x00In progress.
·     0x01Pending.
·     0x02Succeeded.
·     0x03Canceled.
·     0x04Abnormal.
Data[5]
Task progress.
Data[6:126]
Task description in ASCII code.
Data[127:175]
Task type in ASCII code.
Data[176:208]
Task stage in ASCII code.
Change history
Version
Change description
HDM2
Added this command.
Set the enabling status of the dedicated management interface
Use this command to set the enabling status of the BMC dedicated management interface (USB interface).
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x26 0xa2 0x63 0x00 0x01 0x01
Table 226 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Enabling status of the dedicated management interface:
·     0—Disable.
·     1—Enable.
Required permission
Basic configuration and maintenance
Servers that support the dedicated management interface support this command.
Table 227 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
View the enabling status of the dedicated management interface
Use this command to view the enabling status of the BMC dedicated management interface (USB interface).
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x26 0xa2 0x63 0x00 0x02
Table 228 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
Table 229 Response field description
Data[1:3]
Data[4]
·     0—Disabled.
·     1—Enabled.
Change history
Version
Change description
HDM2
Added this command.
System maintenance
Obtain the SEL storage mode
Use this command to obtain the SEL storage mode. This mode defines the way how SEL processes new events when the maximum number (1500) of SEL logs is already reached.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x22 0xa2 0x63 0x00 0x06
Table 230 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
The SEL storage mode is circular.
Required permission
Information query
Data[1:3]
Data[4]
SEL storage mode. Supported options:
·     00Linear mode. In this mode, no new logs will be generated and old logs will not be cleared.
·     01Circular mode. In this mode, a new log is generated and overrides the oldest log.
# Obtain the SEL storage mode.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x22 0xa2 0x63 0x00 0x06
a2 63 00 01
Change history
Version
Change description
HDM3-1.16
Revised the response fields.
HDM3
Added this command.
Set the SEL storage mode
Use this command to set the SEL storage mode.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x22 0xa2 0x63 0x00 0x07 0x01
Table 231 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Set the SEL storage mode. Supported options:
Required permission
Basic configuration
# Set the SEL storage mode.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x22 0xa2 0x63 0x00 0x07 0x01
a2 63 00
Table 232 Response field description
Data[1-3]
Change history
Version
Change description
HDM3
Changed the required permission to basic configuration.
Obtain overall information about SEL logs
Use this command to obtain overall information about SEL logs.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x12 0xA2 0x63 0x00 0x1c Data[7] Data[8:9]
Table 233 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Overall information about SEL logs.
Data[8:9]
Reserved.
Required permission
System audit
COMMAND>ipmitool -H 127.0.0.1 -I lanplus -U admin -P Password@_ raw 0x36 0x12 0xA2 0x63 0x00 0x1c 0x20 0x00 0x00
a2 63 00 20 00 18 00 18 00 01 00 dc 05
Table 234 Response field description
Data[1:3]
Data[4]
Used for error checking. It must be consistent with data [7] in the command.
Data[5]
Error code. Supported options:
·     0x00The request was returned successfully.
·     0xe1The request format is invalid.
·     0xe2No SEL logs exist. This code might be returned if SEL logs have been cleared.
·     0xe3—The number of SEL logs exceeded the maximum storage limit. Due to Web page alignment, excessive logs may not be displayed.
·     0xe4The SEL log with the specified record ID does not exist.
·     0xe5The specified packet of the specified SEL log does not exist.
·     0xe6The requested SEL log has been overwritten.
·     0xe7—Failed to open the log file.
·     0xe8—Failed to verify the event log. The record ID and log entry quantity do not match.
·     0xe9—SEL log overview was not obtained.
Data[6:7]
Number of SEL logs.
Data[8-9]
Record ID of the most recent SEL log.
Data[10:11]
Record ID of the first SEL log.
If SEL logs might be generated in circular mode, the record ID of the first SEL log can be greater than the record ID of the most recent log.
Data[12-13]
Maximum number of SEL entries.
Change history
Version
Change description
HDM2
Added field for displaying the maximum number of SEL entries and changed the required permission to system audit.
Obtain information about an SEL log
Use this command to obtain information about an SEL log, including the log length and the number of packets transmitted for the log.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x12 0xA2 0x63 0x00 0x1c 0x21 Data[8] Data[9:10]
Table 235 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code. SEL-specific.
Data[7]
Information about an SEL log.
Data[8]
Reserved.
Data[9:10]
Specify the record ID of the SEL log.
Required permission
System audit
# Obtain information about an SEL log.
COMMAND>ipmitool -H 127.0.0.1 -I lanplus -U admin -P Password@_ raw 0x36 0x12 0xA2 0x63 0x00 0x1c 0x21 0x00 0x18 0x00
a2 63 00 21 00 01 00 3d 00
Table 236 Response field description
Data[1:3]
Data[4]
Data[5]
·     0xe3The number of SEL logs exceeded the maximum storage limit. Due to Web page alignment, excessive logs may not be displayed.
·     0xe5—The specified packet of the specified SEL log does not exist.
Data[6]
Number of packets for the SEL log.
Data[7]
Reserved.
Data[8:9]
Length of the SEL log.
Change history
Version
Change description
HDM2
Changed the required permission to system audit.
Obtain information about a packet transmitted for an SEL entry
Use this command to obtain information about a packet transmitted for an SEL entry.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x12 0xA2 0x63 0x00 0x1c 0x22 Data[8] Data[9:10]
Table 237 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Information about a packet transmitted for an SEL log.
Data[8]
Request of the packet transmitted for the SEL log.
Data[9:10]
Required permission
System audit
COMMAND>ipmitool -H 127.0.0.1 -I lanplus -U admin -P Password@_ raw 0x36 0x12 0xA2 0x63 0x00 0x1c 0x22 0x01 0x18 0x00
a2 63 00 22 00 3d 01 18 00 01 01 b4 dd d7 5e 43
50 55 31 5f 53 74 61 74 75 73 00 00 00 00 00 70
72 6f 63 65 73 73 6f 72 07 50 72 6f 63 65 73 73
6f 72 20 70 72 65 73 65 6e 63 65 20 64 65 74 65
63 74 65 64
Table 238 Response field description
Data[1:3]
Data[4]
Data[5]
·     0xe3The number of SEL logs exceeded the maximum storage limit. Due to Web page alignment, excessive logs may not be displayed..
Data[6]
Length of the packet, in bytes.
Value range: 1 to 100.
Data[7]
Information about the packet for error checking.
Data[8]
Content of the packet. The maximum value of N is 100.
The content includes the following fields:
·     Record IDTwo bytes. Value range: 0x0001 to 0x5DC (in LSB). The maximum storage limit for SEL entries is 1500 by default in HDM2.
·     Trigger typeOne byte. Supported options:
¡     0x00—Deasserted.
¡     0x01—Asserted.
·     Severity levelFour bytes. Supported options:
¡     1Information.
¡     2Minor.
¡     3Major.
¡     4Critical.
·     TimestampFour bytes, in LSB.
·     Sensor nameVariable length. The maximum length is 16 bytes.
·     Sensor typeVariable length.
·     Time descriptionVariable length.
Change history
Version
Change description
HDM2
Obtain information about the serial port connected to the SOL
Use this command to obtain information about the serial port connected to the SOL.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x57
Table 239 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
X18000 G6 products do not support this command.
# Obtain information about the serial port connected to the SOL.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x57 0xa2 0x63 0x00 0x00
Table 240 Response field description
Data[1:3]
Data[4]
Type of the serial port connected to the SOL. Supported options:
·     0x00BIOS serial port.
·     0x01BMC serial port (Not supported by G6 products).
·     0x02—Serial port of an H3C-proprietary RAID controller (Not supported by G6 products).
·     0x03Serial port of the smart Ethernet adapter.
Change history
Version
Change description
HDM2-1.62
Added G6 support descriptions. Limited by AST2600 and the currently delivered components, some options are not supported by G6 products.
HDM-1.11.31P03
Added this command.
Obtain information about the serial port connected to a panel
Use this command to obtain information about the serial port connected to a panel.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xa2 0x63 0x00 0x58
Table 241 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
# Obtain information about the serial port connected to a panel.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x0b 0xa2 0x63 0x00 0x58 0xa2 0x63 0x00 0x01
Table 242 Response field description
Data[1:3]
Data[4]
·     0x01Serial port of an Ethernet adapter.
·     0x02Serial port of an H3C-proprietary RAID controller.
Change history
Version
Change description
HDM-1.11.31P03
Added this command.
Obtain SMTP configuration information
Use this command to obtain SMTP configuration information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x1a Data[7]
Required permission
Information query
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Parameter selector. (See Table 243.)
Data[5]
Set selector.
Data[6]
Block selector.
Data[7]
Set the severity levels. Supported options:
·     0x00Critical.
·     0x01—Minor + major + critical.
·     0x02Informational +minor + major + critical.
·     0x03Major + critical.
Table 243 Parameter selector description
0x00
Enabling status of SMTP.
0x01
Server address.
0x02
Port number.
0x03
Anonymous or not.
0x04
Sender username.
0x05
Sender password.
0x06
Sender email address.
0x07
Severity level for sending alarms.
0x08
TLS encryption.
0x09
Email subject.
Data[1:3]
Data[4-N]
See Table 244.
Table 244 Data[4] description
Value/Description
0x00
Data[4]:
·     0x00—SMTP is disabled.
·     0x01—SMTP is enabled.
Server address
0x01
Data[4-131]:
The maximum length of the server address is 127 bytes.
Port number
0x02
Data[4-5]:
Port number in the hexadecimal notation in little-endian mode.
The port number range is 1 to 65535.
Anonymous or not
0x03
Data[4]:
·     0x00Anonymous feature is disabled.
·     0x01Anonymous feature is enabled.
Sender username
0x04
Data[4-67]:
The maximum length of the sender username is 64 bytes.
Sender password
0x05
Data[4-67]:
The maximum length of the sender password is 64 bytes.
0x06
Data[4-67]:
The maximum length of the sender email address is 64 bytes.
Severity levels for alarm sending
0x07
Data[4]:
·     0x00Critical and above.
·     0x01—Minor and above.
·     0x02Informational and above.
·     0x03—Major and above.
TLS encryption
0x08
Data[4]:
·     0x00—TLS encryption is disabled.
·     0x01—TLS encryption is enabled.
Email subject
0x09
Data[4]:
·     1bProduct name.
·     2b—Host name.
·     3b—Asset label.
·     4bSystem board serial number.
An email subject can have multiple options.
# Configure SMTP settings.
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x28 0xa2 0x63 0x00 0x1a 0x00 a2 63 00 00
Change history
Version
Change description
HDM3
Added this command.
Use this command to configure SMTP settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x1b Data7 Data8
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Parameter selector. (See Table 245.)
Data[8-N]
Table 245 Parameter selector description
Value/Description
SMTP enabling status
0x00
Data[8]:
Server address
0x01
Data[8-134]:
Server address (No padding with zeros required if less than 127 bytes).
Data type: ASCII code corresponding to the string.
Port number
0x02
Data[8-9]:
Port number
Data type: Hexadecimal format, little-endian mode.
Anonymous
0x03
Data[8]:
·     0x00—Disable.
·     0x01—Enable.
Before disabling the anonymous mode, you must first set the sender username and password.
Sender username
0x04
Data[8-71]:
Sender username (No padding with zeros required if less than 64 bytes).
Only letters, digits, dots (.), hyphens (-), underscores (_), and at signs (@) are allowed.
Sender password
0x05
Data[8-71]:
Sender password (No padding with zeros required if less than 64 bytes).
0x06
Data[8-71]:
Sender email address (No padding with zeros required if less than 64 bytes).
The maximum length of the email address is 64 bytes.
Severity levels for sending SMTP alert emails
0x07
Data[8]:
·     0x00—Critical and above.
·     0x02—Info and above.
TLS encryption
0x08
Data[8]:
Email subject
0x09
Data[8]:
·     1bProduct name.
·     2bHost name.
·     3bAsset label.
Multiple subjects can be set at the same time.
Required permission
Basic configuration
Data[1:3]
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x28 0xa2 0x63 0x00 0x1b 0x00 0x00
a2 63 00
Change history
Version
Change description
HDM3–2.04
Added a restriction remark for the SMTP anonymous field.
HDM3
Added this command.
Obtain SMTP alert email configuration
Use this command to obtain SMTP alert email configuration.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x1c Data7 Data8
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand.
Data[7]
Email ID (in the range of 0x01 to 0x0F).
Data[8]
See Table 246.
Table 246 Parameter selector description
0x00
Email address.
0x01
(Optional.) Email subject.
Required permission
Information query
Data[1:3]
Data[4-N]
See Table 247.
Table 247 Data[4] description
Value/Description
Email address
0x00
Data[4-67]:
The maximum length of an email address is 64 bytes.
Subject
0x01
Data[4-35]:
The maximum length of the subject is 32 bytes.
# Obtain SMTP alert email configuration.
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x28 0xa2 0x63 0x00 0x1c 0x01 0x01
a2 63 00 61 61 61
Change history
Version
Change description
HDM3-1.16
Revised the email ID parameter for Data[7].
HDM3
Added this command.
Configure SMTP alert email settings
Use this command to configure SMTP alert email settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x1d Data7 Data8 Data9
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Email ID (in the range of 0x01 to 0x05).
Data[8]
Parameter selector (see Table 248).
Data[9-N]
Table 248 Parameter selector description
Value/Description
Email address
0x00
Data[9-72]:
Email address (No padding with zeros required if less than 64 bytes).
Subject (optional)
0x01
Data[9-40]:
Subject (No padding with zeros required if less than 32 bytes).
The maximum length of the email address is 32 bytes.
Required permission
Basic configuration
Data[1:3]
# Configure SMTP alert email settings.
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x28 0xa2 0x63 0x00 0x1d 0x01 0x00 0x61 0x61 0x61 0x40 0x31 0x32 0x33 0x2e 0x63 0x6f 0x6d
a2 63 00
Change history
Version
Change description
HDM3
Added this command.
Obtain rsyslog configuration information
Use this command to obtain rsyslog configuration information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x01
Table 249 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain rsyslog configuration information.
COMMAND>ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x28 0xa2 0x63 0x01
a2 63 00 00 01 01 00 2c 01 00 00 00 03
Data[1:3]
Data[4]
Enabling status of syslog. Supported options:
·     0x00Disabled.
·     0x01Enabled.
Data[5]
Transmission type. Supported options:
·     0x01UDP.
·     0x02TCP.
·     0x03TLS (one-way authentication).
·     0x04TLS (two-way authentication).
Data[6]
Host identifier. Supported options:
·     0x01Host name.
·     0x02System board serial number.
·     0x03Asset tag.
·     0x04Product SN.
Data[7]
Reserved.
Data[8-11]
SDR time in seconds. The value range is 10 to 2592000. For example, 0x2c 0x01 0x00 0x00 represents a sending interval of 300 seconds.
Data[12]
Log format for event logs, operation logs, and security logs. Supported options:
·     0x00—Simplified format.
·     0x01—RFC3164 format.
·     0x02—RFC5424 format.
Data[13]
Custom content, which is only available for the simplified log format.
Supported options:
·     0x00—Message only.
·     0x01—Timestamp + message.
·     0x02—Host name + message.
·     0x03—Timestamp + host name + message.
Change history
Version
Change description
HDM2
Added this command.
Obtain information about rsyslog single-channel server configuration
Use this command to obtain information about rsyslog single-channel server configuration.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x02 0x01
Table 250 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Specify the channel number, in the range of 1 to 8.
Required permission
Information query
The command is not supported or the excess part of the command will be truncated under the BT channel when the returned content exceeds 250 bytes (excluding Completion Code). Be careful about data validity.
# Obtain information about rsyslog channel 1 server configuration.
COMMAND>ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x28 0xa2 0x63 0x02 0x01
a2 63 00 01 07 00 00 02 02 00 00 31 39 32 2e 31
36 38 2e 32 34 38 2e 35 31 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Table 251 Response field description
Data[1:3]
Data[4]
Channel enabling status.
Supported options:
·     0x0Disabled.
·     0x01Enabled.
Data[5]
Types of logs that can be sent .
Supported options:
·     0x00Send no logs.
·     0x01Operation log.
·     0x02Event log.
·     0x03—Event log + operation log.
·     0x04Security log.
·     0x05—Security log + operation log.
·     0x06—Security log + event log.
·     0x07—Security log + event log + operation log.
·     0x08—SDR log.
·     0x09—SDR log + operation log.
·     0x0a—SDR log + event log.
·     0x0b—SDR log + event log + operation log.
·     0x0c—SDR log + security log.
·     0x0d—SDR log + security log + operation log.
·     0x0e—SDR log + security log + event log.
·     0x0f—SDR log + security log + event log + operation log.
·     0x10Host serial port log.
·     0x11Host serial port log + operation log.
·     0x12Host serial port log + event log.
·     0x13Host serial port log + event log + operation log.
·     0x14Host serial port log + security log.
·     0x15Host serial port log + security log + operation log.
·     0x16Host serial port log + security log + event log.
·     0x17Host serial port log + security log + event log + operation log.
·     0x18Host serial port log + SDR log.
·     0x19Host serial port log + SDR log + operation log.
·     0x1aHost serial port log + SDR log + event log.
·     0x1bHost serial port log + SDR log + event log + operation log.
·     0x1cHost serial port log + SDR log + security log
·     0x1dHost serial port log + SDR log + security log + operation log.
·     0x1eHost serial port log + SDR log + security log + event log.
·     0x1f—All types of logs.
Data[6]
Level of event logs that can be sent.
Supported options:
·     0x00All levels.
·     0x01Minor and above.
·     0x02Major and above.
·     0x03Critical.
Data[7]
Reserved.
Data[8-11]
Port number.
The value range is 1 to 65535.
For example: 0x02 0x02 0x00 0x00, which represents port 514.
Data[12-N]
IP address.
For example: 0x31 0x19 0x32 0x2e 0x31 0x36 0x38 0x2e 0x32 0x34 0x38 0x2e 0x35 0x31, which represents 192.168.248.51 in ASCII code format.
IPv4 and IPv6 addresses and domain names (in ASCII code format) are supported with a maximum length of 256 bits.
(In some cases, the length of an IPMI reply command is up to 255 bits)
Change history
Version
Change description
HDM2-2.02
Added the restriction that the returned content will be truncated under the BT channel if the returned content exceeds 250 bytes.
HDM2-1.61
Added the restriction that the command is not supported under the BT channel when the returned content exceeds 250 bytes (excluding Completion Code).
HDM2
Added this command.
Set rsyslog message configuration
Use this command to set the rsyslog message configuration.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x03 0x00 0x01 0x01 0x00 0x2c 0x01 0x00 0x00 0x00 0x03
Table 252 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
·     0x00Disable.
·     0x01Enable.
Data[8]
·     0x01UDP.
·     0x02TCP.
·     0x04—TLS (two-way authentication).
Data[9]
·     0x01Host name.
·     0x03Asset tag.
·     0x04—Product serial number.
Data[10]
Reserved.
Data[11-14]
Specify the SDR interval in seconds. The value range is 10 to 2592000. For example, 0x2c 0x01 0x00 0x00 represents a sending interval of 300 seconds.
Data[15]
Specify the log format for event logs, operation logs, and security logs. Supported options:
Data[16]
Specify the custom content, which is available only for the simplified log format.
Supported options:
Required permission
Basic configuration
# Obtain syslog message settings.
COMMAND>ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x28 0xa2 0x63 0x00 0x03 0x00 0x01 0x01 0x00 0x2c 0x01 0x00 0x00 0x00 0x03
a2 63 00
Table 253 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Configure rsyslog single-channel server settings
Use this command to configure the rsyslog single-channel server settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x04 0x1a 0x01 0x01 0x1f 0x00 0x00 0x02 0x02 0x00 0x00 0x31 0x39 0x32 0x2e 0x31 0x36 0x38 0x2e 0x31 0x2e 0x31
Table 254 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Specify the valid data field length.
Data[8]
Specify the channel number in the range of 1 to 8.
Data[9]
Enable or disable the channel. Supported options:
·     0x00Disable.
·     0x01—Enable.
Data[10]
Specify the types of logs to be sent. Supported options:
·     0x00Send no logs.
·     0x02Event log.
·     0x03Event log + operation log.
·     0x04Security log.
·     0x05Security log + operation log.
·     0x06Security log + event log.
·     0x08—SDR log.
Data[11]
Specify the level of event logs.
Supported options:
·     0x00—Send information of all levels.
·     0x01—Send minor and above level information.
·     0x02—Send critical and above level information.
·     0x03—Send emergency level information.
Data[12]
Reserved.
Data[13-16]
Specify the port number.
For example, 0x02 0x02 0x00 0x00, which represents port 514.
Data[17-N]
Specify the IP address of the channel. Supported address types:
·     IPv4 address.
·     IPv6 address.
For example, 0x31 0x32 0x37 0x2e 0x30 0x2e 0x30 0x2e 0x31, which represents IPv4 address 192.168.1.1 (in ASCII code format).
Required permission
Basic configuration
# Configure rsyslog channel 1 server settings.
COMMAND>ipmitool - U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x28 0xa2 0x63 0x00 0x04 0x1a 0x01 0x01 0x1f 0x00 0x00 0x02 0x02 0x00 0x00 0x31 0x39 0x32 0x2e 0x31 0x36 0x38 0x2e 0x31 0x2e 0x31
a2 63 00
Table 255 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Test rsyslog single-channel server settings
Use this command to test rsyslog single-channel server settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x05 0x01
Table 256 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Manufacturer ID. This field is fixed to a2 63 00.
Data[6]
Subcommand code.
Data[7]
Required permission
Basic configuration
# Test channel 1 server settings.
COMMAND>ipmitool -U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x28 0xa2 0x63 0x00 0x05 0x01
a2 63 00
Table 257 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Configure event log association with the health center
Use this command to configure event log association with the health center..
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x28 0xa2 0x63 0x00 0x08 0x02 0x6f 0x0c 0x01 0x00 0x00 0x00 0x01
Table 258 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
SystemType. For more information, see the IPMI V2.0 manual.
Data[8]
EventDirType . For r more information, see the IPMI V2.0 manual.
Data[9]
SensorType. For more information, see the IPMI V2.0 manual.
Data[10]
EvtOffset. For more information, see the IPMI V2.0 manual.
Data[11]
Data1. For more information, see the IPMI V2.0 manual.
Data[12]
Data2. For more information, see the IPMI V2.0 manual.
Data[13]
Data3. For more information, see the IPMI V2.0 manual.
Data[14]
Whether to associate event logs with the health center.
Supported options:
·     0x00—Not associate.
·     0x01—Associate.
·     0x02Not permanently associate.
·     0x03—Permanently associate.
Required permission
Maintenance
# Associate memory UCE logs with the health center.
COMMAND>ipmitool - U admin -P Password@_ -I lanplus -H 192.168.10.18 raw 0x36 0x28 0xa2 0x63 0x00 0x08  0x02 0x6f 0x0c 0x01 0x00 0x00 0x00 0x01
a2 63 00
Table 259 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
Added this command.
Fans
Set the fan speed mode
Use this command to set the fan speed mode to optimize its cooling, noise control, and energy efficiency performance.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x03 0xa2 0x63 0x00 0x60 speed_mode span_mode
Table 260 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Set the fan speed.
Value range: 0x0 to 0x13, where 0 represents the first speed in HDM.
Data[8]
Set the fan speed mode. Supported options:
·     0Silent mode. To specify this mode, make sure the fan speed is 0x00.
·     1Balanced mode. To specify this mode, make sure the fan speed is 0x03.
·     2Powerful mode. To specify this mode, make sure the fan speed is 0x13.
·     3Custom cooling mode.
Required permission
Power control
Blade servers do not support this command.
For this command, 0x00 represents the first speed mode, while in the HDM interface, 1 represents the first speed mode. Be mindful of the conversion.
# Set the fan speed to 0x12.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x03 0xa2 0x63 0x00 0x60 0x12 0x03
a2 63 00 12
Table 261 Response field description
Data[1:3]
Data[4]
Fan speed.
Value range: 0x0 to 0x13.
Change history
Version
Change description
HDM-1.30.11
Added the fan speed mode field.
Obtain the fan speed mode
Use this command to obtain the current fan speed and fan speed mode.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x03 0xa2 0x63 0x00 0x61
Table 262 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Information query
# Obtain the fan speed mode, which is customized as 6.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x03 0xa2 0x63 0x00 0x61
a2 63 00 05 03
Table 263 Response field description
Data[1:3]
Data[4]
Fan speed 0x00 to 0x13, corresponding to 1 to 20 on HDM.
Data[5]
Fan speed mode. Supported options:
·     0Silent mode.
·     1Balanced mode.
·     2Powerful mode.
·     3—Custom cooling mode.
Reload the configuration file for fans
Use this command to reload the configuration file for fans.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x03 0xa2 0x63 0x00 0x22
Table 264 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Power control
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x03 0xa2 0x63 0x00 0x22
a2 63 00
Power supplies
Obtain the maximum number of supported power supplies
Use this command to obtain the maximum number of supported power supplies.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x00
Table 265 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Power control
Blade servers and the X18000 G6 do not support this command.
# Obtain the maximum number of power supplies.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x00
a2 63 00 04
Table 266 Response field description
Data[1:3]
Data[4]
Maximum number of power supplies supported by the system.
Check whether the installed power supply are as required
Use this command to identify whether the currently installed power supply are as required, that is, whether the power supplies are H3C power supplies and whether they have the same model.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x01
Required permission
Power control
# Verify that the currently installed power supply are as required. In this example, the power supply models meet the installation requirements.
a2 63 00 00
Table 267 Response field description
Data[1:3]
Data[4]
Whether the power supply models meet the requirements. Supported options:
·     00hYes.
·     01hNo.
Obtain the presence, AC input, and DC input status of a power supply
Use this command to obtain the presence, AC input, and DC input status of a power supply.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x02 UcDev
Table 268 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Specify the ID of a power supply, starting from 0.
Required permission
Power control
# Obtain the presence, AC input, and DC input status of a power supply.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x02 0x01
a2 63 00 01 01 01
Table 269 Response field description
Data[1:3]
Data[4]
Presence status of the power supply. Supported options:
·     1Present.
·     0Absent.
Data[5]
AC input status. Supported options:
·     1Normal.
·     0Abnormal.
Data[6]
DC input status. Supported options:
·     1Normal.
·     0Abnormal or no DC input.
Obtain the cold backup state of a power supply
Use this command to obtain the cold backup state of a power supply.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x03 UcDev
Table 270 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Required permission
Power control
# Obtain the cold backup state of a power supply.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x03 0x01
a2 63 00 00
Table 271 Response field description
Data[1:3]
Data[4]
Cold backup state. Supported options:
·     0The active power supplies supply power to the server together in a balanced way. (Enable load balancing for all power supplies, causing all redundant power supplies to switch to the main power source. If a specific PSU is specified in the request, the system ignores the specified PSU number)
·     1The power supply is the active power supply in cold backup. (Switch the specified backup power supply to the main power supply and restore normal operation)
·     2The power supply is standby power supply 1 in cold backup. (Put the specified power supply into cold standby mode, which is power supply standby mode 1)
·     3The power supply is standby power supply 2 in cold backup. (Put the specified power supply into cold standby mode, which is power supply standby mode 2)
·     4The power supply is standby power supply 3 in cold backup. (Put the specified power supply into cold standby mode, which is power supply standby mode 4)
Configure a power supply to enter in cold backup
Use this command to configure a power supply to enter in cold backup.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x04 UcDev ucColdVal
Table 272 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Data[8]
Specify a cold backup state. Supported options:
Required permission
Power control
# Configure a power supply to enter in cold backup.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x04 0x01 0x03
a2 63 00 03
Table 273 Response field description
Data[1:3]
Data[4]
·     0x2The power supply is standby power supply 1 in cold backup.
·     0x3The power supply is standby power supply 2 in cold backup.
·     0x4The power supply is standby power supply 3 in cold backup.
Configure a power supply to exit from cold backup
Use this command to configure a power supply to exit from cold backup.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x05 UcDev ucColdVal
Table 274 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Data[8]
Specify the cold backup value, 0x00, or 0x01:
·     0x00All power supplies are in the 0x01 state.
·     0x01The active power supplies supply power to the server together with in a balanced way.
Setting 0x00 causes some power supply to enter 0x00 state.
For a G5 server, all power supplies enter 0x00 state.
Required permission
Power control
# Configure a power supply to exit from cold backup.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x05 0x01 0x01
a2 63 00 01
Table 275 Response field description
Data[1:3]
Data[4]
Cold backup value, 0x00, or 0x01:
Obtain the manufacturer information of a power supply
Use this command to obtain the manufacturer information of a power supply.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x06 power_id
Table 276 Request field description
power_id
Specify the ID of a power supply, starting from 0. The value range varies by device model.
Required permission
Power control
# Obtain the manufacturer information of a power module. In this example, the manufacturer is FSP-GROUP.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x06 0x01
a2 63 00 46 53 50 2d 47 52 4f 55 50
Table 277 Response field description
Data[1:3]
Data[4:N]
Manufacturer of the power supply, a hexadecimal value of 1 to 16 bytes. For better understanding, convert the string format to ASCII.
Obtain the model of a power supply
Use this command to obtain the model of a power supply.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x07 power_id
Table 278 Request field description
power_id
Required permission
Power control
# Obtain the model of a power supply.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x07 0x01
a2 63 00 50 53 52 35 35 30 2d 31 32 41
Table 279 Response field description
Data[1:3]
Data[4:N]
Model of the power supply.
The maximum length of this field is 16 bytes.
This string is in hexadecimal format. For better understanding, convert the string format to ASCII.
Obtain the maximum output power of a power supply
Use this command to obtain the maximum output power of a power supply.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x08 UcDev
Table 280 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Required permission
Power control
# Obtain the maximum output power of a power supply.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x08 0x01
a2 63 00 26 02
Table 281 Response field description
Data[1:3]
Data[4:5]
Maximum output power of the power supply, in W. This field is in litter endian.
Obtain power supply information displayed on the Web interface
Use this command to obtain power supply information displayed on the Web interface.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x0d power_id
Table 282 Request field description
power_id
Required permission
Power control
COMMAND>ipmitool.exe -I lanplus -H 10.99.205.177 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x0d 0x01
 a2 63 00 01 00 00 50 53 52 35 35 30 2d 31 32 41
 00 00 00 00 00 00 32 31 30 32 33 31 41 38 4b 58
 48 31 37 43 30 30 30 30 31 32 00 00 00 00 00 00
00 00 00 00 00 00 26 02 01 01
Data[1:3]
Data[4]
Presence status. 1 represents present.
Data[5]
Health status:
·     0—Healthy.
·     1—Unhealthy.
Data[6]
Cold backup state:
·     0x00The power supply is the active power supply in cold backup.
·     0x01The power supply is the standby power supply in cold backup.
·     0xff—Invalid state.
Data[7:22]
Power supply model in ASCII format.
Data[23:70]
Power supply serial number in ASCII format.
Data[71:72]
Data[73]
Power input mode:
·     0—No power input.
·     1—AC input.
·     2—High-voltage DC input.
·     3—Low-voltage DC input.
Data[74]
Whether active/standby switchover is supported by the power supply:
·     0Not supported.
·     1Supported.
Obtain the current output power of a power supply
Use this command to obtain the current output power of a power supply.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x0e UcDev
Table 283 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Required permission
Power control
# Obtain the current output power of a power supply.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x0e 0x01
a2 63 00 0a 01
Table 284 Response field description
Data[1:3]
Data[4:5]
Current output power of the power supply, in W. This field is in litter endian.
Obtain the range of the power cap value
Use this command to obtain the range of the power cap value.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x10
Table 285 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Power control
# Obtain the range of the power cap value.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x10
a2 63 00 26 02 96 00
Table 286 Response field description
Data[1:3]
Data[4:5]
Maximum power cap value, in W. This field is in litter endian.
Data[6:7]
Minimum power cap value, in W. This field is in litter endian.
Remarks
For R5500 G6 servers, the command obtains the power cap range only for CPU nodes and does not support obtaining the power cap range for GPU nodes.
Obtain the power information of a power supply
Use this command to obtain the power information (including the input power, output power, input current, input voltage, and output voltage) of a power supply.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x12 UcDev
Table 287 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Specify the number of a power supply, starting from 0.
Supported options:
·     0x00PSU1.
·     0x01PSU2.
Required permission
Power control
Product compatibility
# Obtain the power information (including the input power, output power, input current, input voltage, and output voltage) of a power supply.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x12 0x01
a2 63 00 52 00 5d 00 b5 01 e8 00 57 2f
Table 288 Response field description
Data[1:3]
Data[4:5]
Output power, in W and in little endian format.
Data[6:7]
Input power, in W and in little endian format.
Data[8:9]
Input current, in mA and in little endian format.
Data[10:11]
Input voltage, in V and in little endian format.
Data[12:13]
Output voltage, in mV and in little endian format.
Obtain the firmware revision of a power supply
Use this command to obtain the firmware revision of a power supply.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x14 UcDev
Table 289 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Supported options:
·     0x00PSU1.
·     0x01PSU2.
Required permission
Power control
# Obtain the firmware revision of a power supply.
COMMAND>ipmitool -I lanplus -H 192.168.50.166 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x14 0x01
a2 63 00 31 4d 2e 30 30 30 39 2e 30 30 32 34 2e 30 30 32
Table 290 Response field description
Data[1:3]
Data[4:19]
Firmware information of the power supply, a string.
Obtain GPU power capping information
Use this command to obtain GPU power capping information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x21
Table 291 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Required permission
Power control
R5500G6 AMD and Intel servers
# Obtain GPU power capping information.
COMMAND>ipmitool -I lanplus -H 192.168.181.20 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x21
a2 63 00 01 d0 07 00 a0 0f e8 03
Table 292 Response field description
Data[1:3]
Data[4]
GPU power capping enabling status. Supported options:
·     1—Enabled.
·     0—Disabled.
Data[5-6]
GPU power cap value, in the range of 1000 W to 4000 W for the NVIDIA Delta module and in little endian format.
For example, 0xd0 0x07 represents 2000 W.
This option is not available for other GPUs.
Data[7]
Policy upon power capping failure. Supported options:
·     0x01—Shutdown upon power capping failure. This option is not supported by G6.
·     0x00—No shutdown upon power capping failure.
Data[8-9]
Maximum power cap value, in little endian format.
Data[10-11]
Minimum power cap value, in little endian format.
Change history
Version
Change description
HDM2
Added description of G6 support for setting the policy upon power capping failure. G6 products do not support setting the policy upon power capping failure.
HDM-2.33
Added this command.
Remarks
For R5500 G6 servers, the command displays only the power cap value of GPU nodes and does not support displaying the power cap value of CPU nodes.
Configure GPU power capping
Use this command to configure GPU power capping.
ipmitool -I connect_type -H hostname -U username -P password  raw 0x36 0x06 0xa2 0x63 0x00 0x22 0x00 0x01 0xd0 0x07 0x00
Table 293 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
Power supply ID (PSUID, reserved).
Data[8]
Configure GPU power capping enabling status. Supported options:
·     1—Enable.
·     0—Disable.
When you disable GPU power capping, the power cap value and policy upon power capping failure remain most-recent-configured values.
Data[9-10]
GPU power cap value, in the range of 1600 W to 10000 W for the NVIDIA Delta module and in little endian format.
Data[11]
Configure policy upon power capping failure. Supported options:
·     0x01—Shut down upon power capping failure. This option is not supported by G6.
·     0x00Not shut down upon power capping failure.
Required permission
Power control
# Configure GPU power capping.
COMMAND>ipmitool -I lanplus -H 192.168.181.20 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x22 0x00 0x01 0xd0 0x07 0x00
a2 63 0x00
Table 294 Response field description
Data[1:3]
Change history
Version
Change description
HDM2
HDM-2.33
Added this command.
Remarks
For R5500 G6 servers, the command sets only the power cap value of GPU nodes and does not support setting the power cap value of CPU nodes.
Obtain power information of the past day or week
Use this command to obtain power information of the past day or week.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x06 0xa2 0x63 0x00 0x23 0x00 0x00/0x01
Table 295 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3:5]
Data[6]
Subcommand code.
Data[7]
PSUID is 0x00 by default. The information obtaining does not depend on the presence of the power supply.
Data[8]
Time during which the power information is obtained. Supported options:
·     0x00—Past one day.
·     0x01—Past one week.
Required permission
Power control
Not restricted to specific products.
# Obtain power information of the past one day or one week.
COMMAND>ipmitool -I lanplus -H 192.168.31.32 -U admin -P Password@_ raw 0x36 0x06 0xa2 0x63 0x00 0x23 0x00 0x00
a2 63 00 3d 03 02 00 53 00
Table 296 Response field description
Data[1:3]
Data[4-5]
Maximum power value, in little endian format.
For example, 0xc5 0x03 represents 965 W.
Data[6-7]
Minimum power value, in little endian format.
For example, 0x01 0x00 represents 1 W.
Data[8-9]
Average power value, in little endian format.
For example, 0x40 0x02 represents 576 W.
Change history
Version
Change description
HDM-2.55
Added this command.
KVM and virtual media
Obtain KVM modes
Use this command to obtain KVM modes.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x0b 0xA2 0x63 0x00 0x8c
Table 297 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Required permission
Information query
COMMAND>ipmitool -I lanplus -H 192.168.181.20 -U admin -P Password@_ raw 0x36 0x0b 0xA2 0x63 0x00 0x8c
a2 63 0x00 0x00 0x00 0x00 0x00
Table 298 Response field description
Data[1-3]
Data[4]
KVM sharing mode. Supported options:
·     0x00—Shared.
·     0x01Dedicated.
Data[5]
KVM encryption mode. Supported options:
·     0x00Not encrypted.
·     0x01Encrypted.
This field is not supported.
Data[6]
H5 KVM sharing mode. Supported options:
·     0x00—Shared.
·     0x01Dedicated.
Data[7]
H5 KVM encryption mode. Supported options:
·     0x01Encrypted.
Change history
Version
Change description
HDM3-1.18
Revised the description for Data[5] and Data[7].
HDM-2.25
Added this command.
Set KVM modes
Use this command to set KVM modes.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x09 0xA2 0x63 0x00 0x82 <KvmShareMode> <KvmSecureMode> <H5KvmShareMode> <H5KvmSecureMode>
Table 299 Request field description
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Set the KVM sharing mode. Supported options:
·     0x00—Shared.
·     0x01Dedicated.
Data[8]
Set the KVM encryption mode. Supported options:
·     0x01Encrypted.
The KVM encryption mode must be consistent with the H5 KVM encryption mode.
Data[9]
Set the H5 KVM sharing mode. Supported options:
·     0x00—Shared.
·     0x01Dedicated.
Data[10]
Set the H5 KVM encryption mode. Supported options:
·     0x00—Not encrypted.
·     0x01—Encrypted.
The H5 KVM encryption mode must be consistent with the KVM encryption mode.
Required permission
Remote control
# Configure KVM and H5 KVM to use the shared encryption mode.
COMMAND>ipmitool -I lanplus -H 192.168.181.20 -U admin -P Password@_ raw 0x36 0x09 0xA2 0x63 0x00 0x82 0x00 0x01 0x00 0x01
a2 63 00
Table 300 Response field description
Data[1-3]
Change history
Version
Change description
HDM3-1.18
Revised the description for Data[8] and Data[10].
HDM-2.25
Added this command.
Obtain remote virtual media (VM)
Use this command to obtain remote virtual media configuration.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x20 0xA2 0x63 0x00 0x01 <Service Type> <Parameter Selector>
Data[1]
Netfun code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Service type:
·     0x01—CD.
·     0x02—FD.
·     0x04—HD.
·     0x08—RIS.
Data[8]
Select parameters, including:
·     0x00—Image name (not supported).
·     0x01—Source path.
·     0x02—IP address of the server.
·     0x03—Username.
·     0x04—Password.
·     0x05—Share type.
·     0x06—Domain name.
·     0x07—Whether to deploy the configuration.
·     0x08—Mounting status.
·     0x09—Error code (not supported).
·     0x0A—Enable remote media.
Required permission
Information query
Data[1-3]
Data[4]
Service type:
·     0x01—CD.
·     0x02—FD.
·     0x04—HD.
·     0X08—Configuration deployment. This option does not provide actual meaning and is used with deployed parameters.
Data[5]
·     0x01—Source path.
·     0x03—Username.
·     0x04—Password.
·     0x05—Share type.
·     0x06—Domain name.
Data[6-N]
Parameter data. For more information, see Table 301.
Table 301 Obtaining remote media configuration
Source path
Bytes [6–263]—Path where the image resides.
Bytes [6-71]—IP address of the server, in big-endian format.
Make sure the IP address is specified in dotted decimal notation.
Username
Bytes [6–263]—Username.
The maximum length of the username is 256 bytes.
If you set the type of virtual media sharing to CIFS, the username cannot be empty. Only letters, digits, underscores (_), and chinese characters are allowed.
Password
Bytes [6-39]—Password
Share type
Bytes [6-13]—Share type. Supported options include nfs and cifs.
Domain Name
Bytes [6–263]—Domain name.
The maximum length of the domain name is 256 bytes.
Bytes [6]:
·     0h—The configuration is not deployed.
·     1h—The configuration has been deployed.
Mounting status
Bytes [6]:
·     0h—The mounting succeeded.
·     1h—No mounting is performed.
·     100h—The mounting is in progress.
·     ffh—The mounting failed.
Enabling status of remote media.
Bytes [6]:
·     0h—Remote media is disabled.
·     1h—Remote media is enabled.
·     This field can only be used together with the 0x08 option for Data[4].
# Obtain the source path (/Share1).
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x20 0xA2 0x63 0x00 0x01 0x01 0x01
a2 63 00 01 01 2f 53 68 61 72 65 31
Change history
Version
Change description
HDM3-1.18
Added this command.
Deploy remote virtual media (VM) settings
Use this command to deploy remote virtual media settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x20 0xA2 0x63 0x00 0x02 0x01 0x01 0x01 0x2f 0x53 0x68 0x61 0x72 0x65 0x32
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Service type:
·     0x01—CD.
·     0x02—FD.
·     0x04—HD.
Data[8]
Select parameters.
·     0x01—Source path.
·     0x03—Username.
·     0x04—Password.
·     0x05—Share type.
·     0x06—Domain name.
·     0xB—Perform mounting again.
Data[9:N]
Parameter data. For more information, see Table 302.
Table 302 Remote media configuration
Bytes [9–72]—Image name.
The maximum length of the image name is 256 bytes.
If support for remote media multi-image redirection is enabled, this field will be blocked. In this case, IPMI will return response code 0x80.
Required permission
Remote media
Data[1-3]
# Disable remote media.
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x20 0xA2 0x63 0x00 0x02 0x08 0x0a 0x00 0x00
a2 63 00
Change history
Version
Change description
HDM3-1.18
Added this command.
Start or stop image mounting (VM)
Use this command to start or stop image mounting.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x20 0xA2 0x63 0x00 0x03 0x00 0x01 0x01 0x02 0x01 0x01
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
·     0x00—Subscript method.
·     0x01—Image name method.
Data[8:N]
For more information about configuration parameters, see Table 303.
Table 303 Configuration parameters
By Index
·     Data[1]—Media type:
¡     0x00— Local media (not supported).
¡     0x01— Remote media
·     Data[2]—Image type:
¡     0x01—CD.
¡     0x02—FD.
¡     0x04—HD.
·     Data[3]—File type:
¡     0x00—NORMFILE/*Normal file*/
¡     0x01— DIRFILE/*Directory file*/
¡     0x02—IMGFILE/*Image file*/
·     Data[4]—Redirection status:
¡     0x00—Stops redirection.
¡     0x01—Starts redirection.
·     Data[5:6]—Image subscript.
By Image Name
¡     0x01—CD.
¡     0x02—FD.
¡     0x04—HD.
·     Data[3]—Image type:
·     Data[5-134]—Image name. Zero padding is required for the image name. The maximum space that the image name can occupy is Data[5-133].
Required permission
Remote media
Data[1-3]
# Mount a CD image file by index.
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x20 0xA2 0x63 0x00 0x03 0x00 0x01 0x01 0x02 0x01 0x01
a2 63 00
Change history
Version
Change description
HDM3-1.19
Added the field for specifying a file type.
HDM3-1.18
Added this command.
Obtain image information (VM)
Use this command to obtain image information.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x20 0xA2 0x63 0x00 0x04 0x00 0x01
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Parameters:
·     0x00—Total number of available images.
·     0x01—Maximum number of CD images that can be mounted.
·     0x02—Maximum number of FD images that can be mounted.
·     0x03—Maximum number of HD images that can be mounted.
·     0x04—Maximum number of images that can be redirected.
·     0x05—Image information about the corresponding image type (not supported).
·     0x06—Information about redirected images.
·     0x07—Information about available images.
Data[8:N]
For more information about configuration parameters, see Table 304.
Table 304 Configuration parameters
Data[1]—Media type:
·     0x00— Local media (not supported).
·     0x01— Remote media
Data[1]—Media type:
·     0x01— Remote media.
Data[1]—Media type:
Data[1]—Media type:
Data[1]—Media type:
¡     0x01—CD.
¡     0x02—FD.
¡     0x04—HD.
¡     0x01—CD.
¡     0x02—FD.
¡     0x04—HD.
·     Data[3]: Image subscript.
·     Data[2]—Image name format:
¡     0x00—Abbreviated image name, a string of up to 20 characters.
¡     0x01—Full image name.
·     Data[3]—Image subscript.
·     Data[4]—Image type:
¡     0x01—CD.
¡     0x02—FD.
¡     0x04—HD.
Required permission
Information query
Data[1-3]
Data[4:N]
For more information about configuration parameters, see Table 305.
Table 305 Configuration parameters
Byte 1: Returns the total number of available images in the SD or SPI card.
The available images include CD images, FD images, and HD images.
Byte 1: Returns the maximum number of CD images that can be mounted.
Byte 1: Returns the maximum number of FD images that can be mounted.
Byte 1: Returns the maximum number of HD images that can be mounted.
Byte 1: Returns the total maximum number of CD images, FD images, and HD images that can be mounted.
·     Bytes[4-260]: Image name.
·     Byte 263: Image type.
·     Byte 264: Whether redirection is enabled.
¡     0x00—Redirection is disabled.
¡     0x01—Redirection is enabled.
·     Byte 261: Image subscript.
·     Byte 262: Session subscript.
Total response bytes = The specified total number of CD images, FD images, and HD images × 260 + Returned error code.
For other (interfaces) sessions: -
·     Byte [4-262]: Image name.
Total response bytes = 256 + Returned error code.
For the UDS session: -
Byte 1: Image subscript.
For abbreviated image names:
Byte[4-23]: Image name. In this format, if the available image name exceeds 20 characters, it will return the first 16 characters and the last 4 characters that represent the image type.
For full image names:
Byte[4-261]: Image name.
For other sessions (interfaces): -
Byte[1-20]: Abbreviated image names.
Byte[1-256]: Full image names.
# Obtain the number of the available images.
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x20 0xA2 0x63 0x00 0x04 0x00 0x01
a2 63 00 00 0
Change history
Version
Change description
HDM3-1.18
Added this command.
Configure image settings (VM)
Use this command to configure image settings.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x20 0xA2 0x63 0x00 0x05 0x02 0x01 0x01
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code.
Data[7]
Parameters:
·     0x00—Add images (not supported).
·     0x01—Delete images (not supported).
·     0x02—Update the available image list.
·     0x03—Cancel abnormal redirections.
Data[8:N]
For more information about configuration parameters, see Table 306.
Table 306 Configuration parameters
N/A
Delete media images (not support)
¡     0x01— Remote media.
·     Data[2]—Image index.
·     Data[3-13]—Image name.
Update media image list
¡     0x01— CD
¡     0x02— FD
¡     0x04— HD
Clear Media Image Info
·     Data[2]—Image type.
¡     0x01— CD
¡     0x02— FD
¡     0x04— HD
The image redirection task for the redirected image must be terminated.
Required permission
Remote media
Data[1-3]
# Update the CD image list.
COMMAND> ipmitool -I lanplus -H 192.168.30.148 -U admin -P Password@_ raw 0x36 0x20 0xA2 0x63 0x00 0x05 0x02 0x01 0x01
a2 63 00
Change history
Version
Change description
HDM3-1.18
Added this command.
Manually take snapshots
Use this command to manually take snapshots.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x20 0xA2 0x63 0x00 0x06
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code (0x06).
Required permission
Remote control
Data[1-3]
# Manually take snapshots.
COMMAND>ipmitool -I lanplus -H 192.168.181.20 -U admin -P Password@_ raw 0x36 0x20 0xA2 0x63 0x00 0x06
a2 63 00
Change history
Version
Change description
HDM3-1.18
Added this command.
Delete snapshots
Use this command to delete all snapshots. Due to the IPMI command not being suitable for using the filename as a parameter, deleting a single snapshot is temporarily not supported. The snapshot deletion feature will be adjusted in the future as needed.
ipmitool -I connect_type -H hostname -U username -P password raw 0x36 0x20 0xA2 0x63 0x00 0x07
Data[1]
NetFn code.
Data[2]
Command code.
Data[3-5]
Data[6]
Subcommand code (0x07).
Required permission
Remote control
Data[1-3]
# Manually delete snapshots.
COMMAND>ipmitool -I lanplus -H 192.168.181.20 -U admin -P Password@_ raw 0x36 0x20 0xA2 0x63 0x00 0x07
a2 63 00
Change history
Version
Change description
HDM3-1.18
Added this command.
Using IPMItool to obtain chassis status
As shown in Figure 2, the HDM of the R4900 G3 server is connected to the PC through the dedicated network port. Make sure the HDM IP address can communicate with the PC IP address.
·     HDM management software information:
¡     IP address: 172.16.18.69
¡     Administrator account: admin
¡     Administrator password: Password@_
·     PC IP address : 172.16.18.1
Figure 2 Network diagram
Using IPMItool software
1.     Download the IPMItool tool that is compatible with Windows OS such as IPMItool v1.8.18 on the client. As a best practice, use IPMItool v1.8.18 or later versions.
2.     Access Windows cmd.
Figure 3 Windows cmd
Using IPMItool to obtain chassis information
Execute the ipmitool -I lanplus -H 172.16.18.69 -U admin -P Password@_ chassis status command to obtain chassis status information.
Figure 4 Obtaining chassis status information
