H3C Access Controllers RADIUS Attributes(V7)-6W100
HomeSupportConfigure & DeployRADIUS Attributes ReferenceH3C Access Controllers RADIUS Attributes(V7)-6W100
Download Book
  • Released At: 03-06-2024
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
RADIUS attributes
·     This manual only provides a general introduction to RADIUS attributes. Some information may not apply to the product you have purchased.
·     Due to different device models and version upgrades, the supported RADIUS attribute usage scenarios may vary. If any discrepancies with the actual product exist during use, please refer to the actual situation of the device.
Standard RADIUS attributes
User-Name (1)
Attribute name
User-Name
Attribute number
1
Attribute type
string
Protocol
RFC2865
Attribute description
Name of the user to be authenticated.
In wireless 802.1X access and IPoE access scenarios, after a user passes authentication with a username, the RADIUS server can assign a different username to the user by using the Access-Accept packet. When the access device receives the packet and the username-authorization apply command is executed, the access device uses the assigned username for subsequent AAA processing (such as accounting, user information query and display) for the user.
User-Password (2)
Attribute name
User-Password
Attribute number
2
Attribute type
string
Protocol
RFC2865
User password for PAP authentication, which takes effect only for PAP authentication and is typically present in Access-Request packets.
Used for issuing the encrypted ISP account password to the agency gateway in the PPPoE agency scenario, which is present in COA request packets.
CHAP-Password (3)
Attribute name
CHAP-Password
Attribute number
3
Attribute type
Octets
Protocol
RFC2865
Digest of the user password for CHAP authentication, only present in Access-Request packets when CHAP authentication is used.
NAS-IP-Address (4)
Attribute name
NAS-IP-Address
Attribute number
4
Attribute type
Address
Protocol
RFC2865
IP address of the NAS device.
An authentication request must carry the NAS-IP-Address or NAS-identifier attribute. The NAS-IP-Address carried in the request might be different from the source IP address in the packets received by the RADIUS server in some cases, for example, after a NAT traversal.
The NAS-IP-Address attribute value can be set by a command on the NAS device. For more information, see the AAA configuration guide for the NAS device.
NAS-Port (5)
Attribute name
NAS-Port
Attribute number
5
Attribute type
integer
Protocol
RFC2865
Physical port of the NAS that the user accesses.
H3C defines the attribute format as follows:
·     For Ethernet access users: slot number (8 bits) + subslot number (4 bits) + port number (8 bits) + VLAN ID (12 bits)
·     For ADSL access users: slot number (4 bits) + subslot number (2 bits) + port number (2 bits) + VPI (8 bits) + VCI (166 bits)
Service-Type (6)
Attribute name
Service-Type
Attribute number
6
Attribute type
integer
Protocol
RFC2865
Type of service that the user has requested or type of service to be provided. Values include:
·     1: Login service, for device management users.
·     2: Framed service, for network access users.
·     4: Callback Framed service.
·     10: Call Check service, for MAC authentication users.
·     25:Obtain ACL rules for dynamic ACL
At present, the attribute value is 10 for MAC authentication users, 1 for device management users, and 2 for other types of users. For IPoE users, you can use the attribute 6 value outbound user-type ipoe command to set the value of the attribute to 5.
Framed-Protocol (7)
Attribute name
Framed-Protocol
Attribute number
7
Attribute type
integer
Protocol
RFC2865
Encapsulation protocol for framed access. Values include:
·     1: PPP
·     2: SLIP
·     3: AppleTalk Remote Access Protocol (ARAP)
·     4: Gandalf proprietary SingleLink/MultiLink protocol
·     5: Xylogics proprietary IPX/SLIP
·     6: X.75 Synchronous
·     255: Portal
At present, the attribute value is 255 for portal access and 1 for all other access types.
Framed-IP-Address (8)
Attribute name
Framed-IP-Address
Attribute number
8
Attribute type
Address
Protocol
RFC2865
IP address assigned to the user.
·     Carries the IP address of the user in an authentication request to the server.
·     Carries the IP address assigned by the server to the user in an authentication reply.
Filter-ID (11)
Attribute name
Filter-ID
Attribute number
11
Attribute type
String
Protocol
RFC2865
Name of the filter list.
This attribute is parsed as follows:
·     If the name is a string of all digits, it indicates an ACL number.
·     If the name is not a string of all digits and contains no equal signs (=):
·     If the next attribute is H3C-ACL-Version, it indicates an ACL name.
·     if the next attribute not H3C-ACL-Version, it indicates a user profile name.
·     If the name is not a string of all digits and contains equal signs (=), further parsing is required. At present, the server is supported to send several SSL VPN user groups in the format of user-group=name1;name2;...;namex.
The H3C proprietary attribute user-group (140) can also be used to deploy SSL VPN user groups. This proprietary attribute only supports deploying SSL VPN user groups during authentication and authorization (carried in Access-Accept packets). It does not support the deployment in dynamic authorization (carried in SessionControl and CoA packets). If the Filter-ID attribute is carried in the Access-Accept packet and the user-group (140) attribute is carried in the SessionControl or CoA packet, the device uses the attribute that comes first.
Framed-MTU (12)
Attribute name
Framed-MTU
Attribute number
12
Attribute type
integer
Protocol
RFC2865
MTU of the data link, only for port security users.
The size of an EAPoL frame is limited by the Ethernet frame. If an EAP frame is too long, it cannot be carried in an EAPoL frame.
The NAS device uses the Framed-MTU attribute to indicate the maximum length of an EAP frame sent by the RADIUS server, so as to avoid loss of EAP frames caused by EAP frames exceeding the data link MTU. The default value of this attribute is 1450.
Login-IP-Host (14)
Attribute name
Login-IP-Host
Attribute number
14
Attribute type
Address
Protocol
RFC2865
IP address of the NAS interface that the user accesses.
Login-Service (15)
Attribute name
Login-Service
Attribute number
15
Attribute type
Integer
Protocol
RFC2865
Type of service that the user uses for login. The server is supported to deploy multiple Login-Service attributes at a time.
The device checks the consistency of the service type used by the user to log in to the device and the service type indicated by the Login-Service attribute assigned by the server.
H3C defines the following extended values for the Login-Service attribute:
·     50: SSH
·     51: FTP
·     52: Terminal
·     53: HTTP
·     54: HTTPS
Support for values 53 and 54 depends on the device model.
You can configure the check method for RADIUS 15 on the NAS device to determine whether to use the extended Login-Service attribute values to check the service type consistency for users.
·     Strict method: The devices uses standard and extended Login-Service attribute values to check user service types. SSH, FTP, and terminal users can pass authentication only when the RADIUS server assigns the corresponding extended Login-Service attribute values to them.
·     Loose method: The devices uses standard Login-Service attribute values to check user service types. SSH, FTP, and terminal users can pass authentication only when the RADIUS server assigns the Login-Service attribute value of 0 (representing the Telnet service).
Framed-Route (22)
Attribute name
Framed-Route
Attribute number
22
Attribute type
string
Protocol
RFC2865
Authorization routing information for the user. This attribute applies only to PPP and SMF users. Other access types ignore this attribute. This attribute can be used multiple times in a packet.
State (24)
Attribute name
Attribute number
24
Attribute type
Octets
Protocol
RFC2865
If a reply packet from the server contains this attribute, the access device carries this attribute in all subsequent authentication request packets it sends, and the attribute value maintains the same.
Class (25)
Attribute name
Class
Attribute number
25
Attribute type
Octets
Protocol
RFC2865
If a reply packet from the server contains this attribute, the access device carries this attribute in all subsequent packets it sends, and the attribute value maintains the same.
To communicate with a specific server, you must use the attribute 25 car command to configure the device to interpret the Class attribute (attribute 25) as CAR parameters. The device will parse the first 32 bytes of the Class attribute value as INPUT_PEAK_RATE, INPUT_AVG_RATE, OUTPUT_PEAK_RATE, and OUTPUT_AVG_RAT. Other bytes of the Class attribute value are ignored.
Vendor-Specific (26)
Attribute name
Vendor-Specific
Attribute number
26
Attribute type
Octets
Protocol
RFC2865
Vendor-specific proprietary attribute. A packet can contain one or more proprietary attributes, each of which can contain one or more subattributes.
Session-Timeout (27)
Attribute name
Session-Timeout
Attribute number
27
Attribute type
Integer
Protocol
RFC2865
Maximum service duration (in seconds) for the user before termination of the session. This attribute can present in authentication reply and accounting reply packets.
When the user online duration reaches the session timeout time, the device does not log out the user immediately but initiates an accounting update process for the user. If the accounting reply packet carries a non-zero session-timeout attribute, the device updates the remaining online time for the user. If the accounting reply packet does not provide the session-timeout attribute or the carried session-timeout attribute value is 0, the device logs out the user.
Idle-TimeOut (28)
Attribute name
Idle-TimeOut
Attribute number
28
Attribute type
Integer
Protocol
RFC2865
Maximum idle time permitted for the user before termination of the session.
The device supports setting user idle timeout in ISP domain view. The idle timeout set in ISP domain view has a higher priority than that assigned by the server. By default, a user is timed out if the user generates less than 10240 bytes of traffic within the idle timeout time.
Termination-Action (29)
Attribute name
Termination-Action
Attribute number
29
Attribute type
Integer
Protocol
RFC2865
The specified mode for terminating the NAS service, such as re-authentication or forcing a user to log out. The value for this attribute can be the following:
·     0: Default. The value 0 indicates to force the user to log out. However, if the device is enabled with periodic re-authentication and the re-authentication timer value is smaller than the user session-timeout value, the port does not force users to log out but initiate re-authentication on the online 802.1X users on the port at intervals set by the re-authentication timer.
·     1: RADIUS-Request. The value 1 indicates to perform re-authentication on the user when the session-timeout time for the user is reached. At present, only 802.1X and MAC authentication users support re-authentication.
Called-Station-Id (30)
Attribute name
Called-Station-Id
Attribute number
30
Attribute type
String
Protocol
RFC2865
RFC3580
·     For PPP users, this attribute is the called number.
·     For wired access (portal/port security) users, this attribute is the MAC address of the user access interface (default format: XX-XX-XX-XX-XX-XX).On the NAS, you can use the attribute 30 mac-format command to configure the MAC address format.
·     For wireless access (portal/port security) users, this attribute is the MAC address of the user access AP and the SSID (format: XX-XX-XX-XX-XX-XX:SSID).On the NAS, you can use the attribute 30 format command to configure the attribute format and use the attribute 31 mac-format command to configure the MAC address format.
Calling-Station-Id (31)
Attribute name
Calling-Station-Id
Attribute number
31
Attribute type
String
Protocol
RFC2865
RFC3580
·     For 802.1X, portal, PPPoE, IPOE, L2TP LAC and Login users, this attribute is the MAC address of the user, in the format of H-H-H-H-H-H. On the NAS, you can use the attribute 31 mac-format command to configure the MAC address format, including setting the separator, lowercase, uppercase, six-section format, or three-section format.
·     For L2TP LNS users, this attribute use the information received from LAC.
·     For PPP and VoIP users, this attribute is the caller number.
·     For reverse telnet users, this attribute is the user IP address.
·     For PPPoE agency users, this attribute is a user MAC address in the format of HH:HH:HH:HH:HH:HH, which is present in COA request packets.
NAS-Identifier (32)
Attribute name
NAS-Identifier
Attribute number
32
Attribute type
String
Protocol
RFC2865
RFC3580
Device name of the NAS. Values in descending order of priority are:
·     NAS-ID obtained by the wireless module.
·     NAS-ID in VSRP instance view.
·     NAS-ID bound with the user access VLANs.
·     NAS-ID in access interface view.
·     NAS-ID in ISP domain view.
·     System name set by the sysname command.
Acct-Status-Type (40)
Attribute name
Acct-Status-Type
Attribute number
40
Attribute type
Integer
Protocol
RFC2866
Type of the Accounting-Request packet. Possible values include:
·     1: Accounting start.
·     2: Accounting stop.
·     3: Interim-Update.
Acct-Delay-Time (41)
Attribute name
Acct-Delay-Time
Attribute number
41
Attribute type
Integer
Protocol
RFC2866
Time spent to send an Accounting Request packet, in seconds.
Acct-Delay-Time = Time when an Accounting Request packet was sent - Time when the packet was created.
Acct-Input-Octets (42)
Attribute name
Acct-Input-Octets
Attribute number
42
Attribute type
Integer
Protocol
RFC2866
(Accounting) Number of upstream bytes. The unit is specified by the data-flow-format command on the NAS, which can be byte (default), KB, MB, or GB.
This attribute is used together with attribute 52 (Acct-Input-Gigawords).
Acct-Output-Octets (43)
Attribute name
Acct-Output-Octets
Attribute number
43
Attribute type
Integer
Protocol
RFC2866
(Accounting) Number of downstream bytes. The unit is specified by the data-flow-format command on the NAS, which can be byte (default), KB, MB, or GB.
This attribute is used together with attribute 53 (Acct-Output-Gigawords).
Acct-Session-Id (44)
Attribute name
Acct-Session-Id
Attribute number
44
Attribute type
String
Protocol
RFC2866
A unique accounting identifier, a string of 1 to 64 characters. Accounting packets must carry this attribute. Authentication packets carry this attribute as required by the server. If this attribute is carried in an authentication packet, the attribute value must be the same as that carried in accounting packets.
Acct-Authentic (45)
Attribute name
Acct-Authentic
Attribute number
45
Attribute type
Integer
Protocol
RFC2866
User authentication method carried in accounting packets. Possible values include:
·     0—None (extended value of H3C).
·     1—RADIUS.
·     2—Local.
·     3—Remote.
Acct-Session-Time (46)
Attribute name
Acct-Session-Time
Attribute number
46
Attribute type
Integer
Protocol
RFC2866
(Accounting) Session duration of the user, in seconds.
Acct-Input-Packets (47)
Attribute name
Acct-Input-Packets
Attribute number
47
Attribute type
Integer
Protocol
RFC2866
(Accounting) Number of upstream packets. The unit is specified by the data-flow-format command on the NAS, which can be packet (default), kilo-packet, mega-packet, or giga-packet.
Acct-Output-Packets (48)
Attribute name
Acct-Output-Packets
Attribute number
48
Attribute type
Integer
Protocol
RFC2866
(Accounting) Number of downstream packets. The unit is specified by the data-flow-format command on the NAS, which can be packet (default), kilo-packet, mega-packet, or giga-packet.
Acct-Terminate-Cause (49)
Attribute name
Attribute number
49
Attribute type
Integer
Protocol
RFC2866
Reason for the termination of the accounting session. Possible values include:
·     1: User Request
·     2: Lost Carrier
·     3: Lost Service
·     4: Idle Timeout
·     5: Session Timeout
·     6: Admin Reset
·     7: Admin Reboot
·     8: Port Error
·     9: NAS Error
·     10: NAS Request
·     11: NAS Reboot
·     12: Port Unneeded
·     13: Port Preempted
·     14: Port Suspended
·     15: Service Unavailable
·     16: Callback
·     17: User Error
·     18: Host Request
Acct-Multi-Session-Id (50)
Attribute name
Attribute number
50
Attribute type
String
Protocol
RFC2866
(Accounting) A unique accounting identifier used to link multiple related sessions of a user.
In ITA service, the primary user's attribute 44 (Acct-Session-Id) is the same as attribute 50 for all levels of traffic of the user.
Acct-Input-Gigawords (52)
Attribute name
Attribute number
52
Attribute type
Integer
Protocol
RFC2869
Number of times the Acct-Input-Octets counter has wrapped around 2^32. The unit for this attribute is specified by the data-flow-format command on the NAS, which can be byte (default), KB, MB, or GB.
This attribute is used together with attribute 42 (Acct-Input-Octets).
Acct-Output-Gigawords (53)
Attribute name
Attribute number
53
Attribute type
Integer
Protocol
RFC2869
Number of times the Acct-Output-Octets counter has wrapped around 2^32. The unit for this attribute is specified by the data-flow-format command on the NAS, which can be byte (default), KB, MB, or GB.
This attribute is used together with attribute 43 (Acct-Output-Octets).
Event-Timestamp (55)
Attribute name
Event-Timestamp
Attribute number
55
Attribute type
Date
Protocol
RFC2869
Time that this event occurred on the NAS, in seconds, since January 1, 1970 00:00 UTC.
Egress-VLANID (56)
Attribute name
Egress-VLANID
Attribute number
56
Attribute type
Integer
Protocol
RFC4675
Four-byte VLAN ID assigned by the server. The first byte 0x31 indicates to carry the tag. The first byte 0x32 indicates to not carry the tag. The subsequent 12 bits represent the VLAN ID. In any other cases, this attribute is invalid.
Egress-VLAN-Name (58)
Attribute name
Egress-VLAN-Name
Attribute number
58
Attribute type
String
Protocol
RFC4675
VLAN ID assigned by the server. The first byte 0x31 indicates to carry the tag. The first byte 0x32 indicates to not carry the tag. The subsequent bytes represent the VLAN name.
CHAP-Challenge (60)
Attribute name
CHAP-Challenge
Attribute number
60
Attribute type
Octets
Protocol
RFC2865
CHAP challenge generated by the NAS for MD5 calculation during CHAP authentication.
 NAS-Port-Type (61)
Attribute name
 NAS-Port-Type
Attribute number
61
Attribute type
Integer
Protocol
RFC2865
Type of the physical port of the NAS that is authenticating the user. Possible values include:
·     0: Async
·     1: Sync
·     2: ISDN Sync
·     3: ISDN Async V.120
·     4: ISDN Async V.110
·     5: Virtual
·     6: PIAFS
·     7: HDLC Clear Channel
·     8: X.25
·     9: X.75
·     10: G.3 Fax
·     11: SDSL - Symmetric DSL
·     12: ADSL-CAP - Asymmetric DSL, Carrierless Amplitude Phase Modulation
·     13: ADSL-DMT - Asymmetric DSL, Discrete Multi-Tone
·     14: IDSL - ISDN Digital Subscriber Line
·     15: Ethernet
·     16: xDSL - Digital Subscriber Line of unknown type (any type of ADSL)
·     17: Cable (for cable TV)
·     18: Wireless - Other
·     19: Wireless - IEEE 802.11
·     201: VLAN
·     202: ATM interface
To configure the value for this attribute, use the nas-port-type command on the port.
For portal users, if the NAS communicates with a MAC binding server from a specific vendor, you can use the nas-port-type command in MAC binding server view to configure the value of this attribute.
Tunnel-Type (64)
Attribute name
Tunnel-Type
Attribute number
64
Attribute type
Integer
Protocol
RFC2868
Tunneling protocol. Possible values include:
·     1: Point-to-Point Tunneling Protocol (PPTP) [1]
·     2: Layer Two Forwarding (L2F) [2]
·     3: Layer Two Tunneling Protocol (L2TP) [3]
·     4: Ascend Tunnel Management Protocol (ATMP) [4]
·     5: Virtual Tunneling Protocol (VTP)
·     6: IP Authentication Header in the Tunnel-mode (AH) [5]
·     7: IP-in-IP Encapsulation (IP-IP) [6]
·     8: Minimal IP-in-IP Encapsulation (MIN-IP-IP) [7]
·     9: IP Encapsulating Security Payload in the Tunnel-mode (ESP) [8]
·     10: Generic Route Encapsulation (GRE) [9]
·     11: Bay Dial Virtual Services (DVS)
·     12: IP-in-IP Tunneling [10]
·     13: VLAN
This attribute supports carrying the Tag field.
Tunnel-Medium-Type (65)
Attribute name
Tunnel-Medium-Type
Attribute number
65
Attribute type
Integer
Protocol
RFC2868
Transport medium type to use for creating a tunnel. Possible values include:
·     1: IPv4 (IP version 4)
·     2: IPv6 (IP version 6)
·     3: NSAP
·     4: HDLC (8-bit multidrop)
·     5: BBN 1822
·     6: 802 (includes all 802 media plus Ethernet "canonical format")
·     7: E.163 (POTS)
·     8: E.164 (SMDS, Frame Relay, ATM)
·     9: F.69 (Telex)
·     10: X.121 (X.25, Frame Relay)
·     11: IPX
·     12: Appletalk
·     13: Decnet IV
·     14: Banyan Vines
·     15: E.164 with NSAP format subaddress
For VLAN assignment, the value must be 6.
Tunnel-Client-Endpoint (66)
Attribute name
Attribute number
66
Attribute type
String
Protocol
RFC2868
IP address of the initiator end of the tunnel, in dotted decimal notation.
This attribute is applicable only to L2TP users, and it cannot be used to send multiple addresses to the server at a time.
Tunnel-Server-Endpoint (67)
Attribute name
Attribute number
67
Attribute type
String
Protocol
RFC2868
IP address of the server end of the tunnel, in dotted decimal notation.
Tunnel-Password (69)
Attribute name
Tunnel-Password
Attribute number
69
Attribute type
String
Protocol
RFC2868
Authentication password of the tunnel. The first two bytes are the SALT. The last 16 bytes are the password after encryption. You can configure a plaintext or ciphertext tunnel password by using the tunnel password command on the NAS.
This attribute is applicable only to L2TP users, and it supports carrying the Tag field.
EAP-Message (79)
Attribute name
EAP-Message
Attribute number
79
Attribute type
Octets
Protocol
RFC3579
Encapsulates EAP packet to implement RADIUS support for the EAP authentication. An EAP packet will be fragmented when it exceeds 253 bytes. The fragments are encapsulated in multiple EAP-Message attributes in order. One RADIUS packet can carry multiple EAP-Message attributes.
This attribute is applicable to 802.1X EAP or portal EAP authentication.
In COA packets of the PPPoE proxy scenario, this attribute is the password of the operator account.
Message-Authenticator (80)
Attribute name
Attribute number
80
Attribute type
Octets
Protocol
RFC3579
Message authenticator used to check the integrity of the RADIUS packet that carries the EAP-Message attributes during the EAP authentication.
This attribute is used in the RADIUS support for EAP authentication mode.
Tunnel-Private-Group-id (81)
Attribute name
Attribute number
81
Attribute type
String
Protocol
RFC2868
Group ID for a tunnel session. It can be an integer in the range of 1 to 4094 or a value in other forms.
This attribute is used together with attribute 64 and attribute 65:
·     When attribute 64 is 13 and attribute 65 is 6, this attribute represents a VLAN name.
·     When attribute 64 is 3, this attribute represents a tunnel group ID.
Tunnel-Assignment-id (82)
Attribute name
Attribute number
82
Attribute type
String
Protocol
RFC2868
ID of the tunnel that carries the session.
This attribute is applicable only to L2TP users, and supports carrying the Tag field.
·     If the device already has an L2TP tunnel with this ID, the user uses this L2TP tunnel.
·     If no L2TP tunnel exists on the device with this ID, the device creates an L2TP tunnel with this ID.
Acct-Interim-Interval (85)
Attribute name
Attribute number
85
Attribute type
Integer
Protocol
RFC2869
Real-time accounting interval, in seconds.
NAS-Port-Id (87)
Attribute name
NAS-Port-Id
Attribute number
87
Attribute type
String
Protocol
RFC2869
String for describing the port of the NAS that is authenticating the user. The format of this attribute can be configured by a command on the NAS.
The following formats are supported:
·     Format for ADSL users:
slot=XX;subslot=X;port=X;VPI=XXX;VCI=XXXXX.
Value ranges for the parameters:
slot=0 to 15; subslot=0 to 9; port=0 to 9; VPI=0 to 255; VCI=0 to 65535.
·     Format for Ethernet access users:
¡     VLAN: slot=XX;subslot=XX;port=XXX;VLANID=0;
¡     Single tag: slot=XX;subslot=XX;port=XXX;VLANID=XXXX;
¡     Dual tags: slot=XX;subslot=XX;port=XXX;VLANID=inner VLAN;VLANID2=outer VLAN;
slot=0 to 15; subslot=0 to 15; port=0 to 255; VLANID=0 to 4095.
·     Format for portal users:
¡     {atm|eth|trunk}NAS_slot/NAS_subslot/NAS_port:XPI.XCI AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port[:ANI_XPI.ANI_XCI]
¡     SlotID00IfNOVlanID
¡     SlotID00IfNOVlanID+DHCPoption82 or DHCPoption18
¡     slot=XX;subslot=XX;port=XXX;vlanid=inner VLAN;vlanid2=outer VLAN
·     Standard format in communication industry (YDT 2275-2011)
{eth|trunk} NAS_slo1/NAS_subslot/NAS_port:SVLAN.CVLAN AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port/LSW_ID
·     Format in UP and CP separation scenario:
{eth|trunk} NAS_UpIdentifier/NAS_slo1/NAS_subslot/NAS_port:CVLAN.SVLAN AccessNodeIdentifier/ANI_rack/ANI_frame/ANI_slot/ANI_subslot/ANI_port/LSW_ID
Framed-Pool (88)
Attribute name
Framed-Pool
Attribute number
88
Attribute type
String
Protocol
RFC2869
Name of the IPv4 address pool assigned by the server to the user.
The attribute is valid only when the server allocates IP addresses to users from the local address pool. The designated IPv4 address pool must have been configured on the device.
In COA packets in PPPoE proxy scenario, this attribute represents the dialup group.
Tunnel-Client-Auth-id (90)
Attribute name
Attribute number
90
Attribute type
String
Protocol
RFC2868
Name used by the tunnel client end.
NAS-IPv6-Address (95)
Attribute name
NAS-IPv6-Address
Attribute number
95
Attribute type
Ipv6addr
Protocol
RFC3162
IPv6 address of the NAS.
The NAS-IPv6-Address to be carried in RADIUS packets can be configured in interface view, RADIUS scheme view, and system view. The settings take effect as follows:
·     The NAS IP address configured in interface view (by using the aaa nas-ip command) takes effect only on the users on the interface.
·     The NAS IP address configured in RADIUS scheme view (by using the nas-ip command) takes effect only on this RADIUS scheme.
·     The NAS IP address configured in system view (by using the radius nas-ip command) takes effect only on all RADIUS schemes.
The NAS IP settings in these views have descending order of priority as follows: interface view > RADIUS view > system view.
In VSRP scenarios, if a NAS-IP is configured in the VSRP instance associated with the access service (by using the nas ip command), this configured NAS-IP is carried in sent RADIUS packets.
In CPDR scenarios, if the access service associated CPDR group has configured with the source interface for RADIUS packets (by using the radius source-interface command), the NAS-IP carried in the sent RADIUS packets is the IP address of the specified source interface.
NOTE: Support for NAS-IP address configuration in interface view depends on the device model.
Framed-Interface-Id (96)
Attribute name
Framed-Interface-Id
Attribute number
96
Attribute type
Binary
Protocol
RFC3162
Interface ID assigned by the server to the IPv6 user. This attribute is eight bytes long.
Framed-IPv6-Prefix (97)
Attribute name
Framed-IPv6-Prefix
Attribute number
97
Attribute type
Binary
Protocol
RFC3162
Address prefix assigned by the server to the IPv6 user. The maximum length of this attribute is 128 bits.
Framed-IPV6-Pool (100)
Attribute name
Framed-IPV6-Pool
Attribute number
100
Attribute type
String
Protocol
RFC3162
Name of the IPv6 address pool assigned by the server to the IPv6 user.
The attribute is valid only when the server allocates IP addresses to users from the local address pool. The designated IPv6 address pool must have been configured on the device.
Error-Cause (101)
Attribute name
Error-Cause
Attribute number
101
Attribute type
Integer
Protocol
RFC3576
Used in COA packets to send user error code to the server. Possible values include:
·     201: Session successfully deleted.
·     401: Unsupported attribute.
·     404: Invalid COA request.
·     503: No matching user.
·     504: Failed to delete the session.
·     506: Internal processing failure.
EAP-Key-Name (102)
Attribute name
EAP-Key-Name
Attribute number
102
Attribute type
String
Protocol
N/A
EAP key name used in MACsec authentication.
Delegated-IPv6-Prefix (123)
Attribute name
Attribute number
123
Attribute type
Binary
Protocol
RFC4818
IPv6 PD prefixes assigned to routed CPEs. A packet can carry multiple Delegated-IPv6-Prefix attributes.
Framed-IPv6-Address (168)
Attribute name
Framed-IPv6-Address
Attribute number
168
Attribute type
Ipv6addr
Protocol
RFC6911
IPv6 address assigned to the user.
·     Carries the IPv6 address of the user in an authentication request to the server.
·     Carries the IPv6 address assigned by the server to the user in an authentication reply.
WLAN-Reason-Code (185)
Attribute name
WLAN-Reason-Code
Attribute number
185
Attribute type
Octets
Protocol
RFC7268
Reason for the failure of the WLAN endpoint authentication. It is a 32-bit string. The first 16 bits are reserved bits and the last 16 bits indicate the reason code.
WLAN-Pairwise-Cipher (186)
Attribute name
Attribute number
186
Attribute type
Octets
Protocol
RFC7268
Cipher suite for WLAN unicast frames, a 32-bit string. The first 24 bits indicate the OUI and the last 8 bits indicate the suite type. This attribute is present only in authentication request packets.
WLAN-Group-Cipherr (187)
Attribute name
WLAN-Group-Cipherr
Attribute number
187
Attribute type
Octets
Protocol
RFC7268
Cipher suite for WLAN multicast frames, a 32-bit string. The first 24 bits indicate the OUI and the last 8 bits indicate the suite type. This attribute is present only in authentication request packets.
WLAN-AKM-Suite (188)
Attribute name
WLAN-AKM-Suite
Attribute number
188
Attribute type
Octets
Protocol
RFC7268
Authentication and Key Management (AKM) suite, a 32-bit string. The first 24 bits indicate the OUI and the last 8 bits indicate the suite type. This attribute is present only in authentication request packets.
WLAN-Group-Mgmt-Cipher (189)
Attribute name
Attribute number
189
Attribute type
Octets
Protocol
RFC7268
Cipher suite for WLAN multicast management frames, a 32-bit string. The first 24 bits indicate the OUI and the last 8 bits indicate the suite type. This attribute is present only in authentication request packets.
H3C attributes
Input-Peak-Rate (1)
Attribute name
Input-Peak-Rate
Attribute number
1
Attribute type
Integer
Input peak rate from a user to the NAS.
The default measurement unit is bps.
Input-Average-Rate (2)
Attribute name
Input-Average-Rate
Attribute number
2
Attribute type
Integer
Input average rate from a user to the NAS.
Input-Basic-Rate (3)
Attribute name
Input-Basic-Rate
Attribute number
3
Attribute type
Integer
Input basic rate from a user to the NAS, in bps.
No service supports this attribute in the current software version.
Output-Peak-Rate (4)
Attribute name
Output-Peak-Rate
Attribute number
4
Attribute type
Integer
Output peak rate from the NAS to a user, in bps.
Output-Average-Rate (5)
Attribute name
Output-Average-Rate
Attribute number
5
Attribute type
Integer
Output average rate from the NAS to a user, in bps.
Output-Basic-Rate (6)
Attribute name
Output-Basic-Rate
Attribute number
6
Attribute type
Integer
Output basic rate from the NAS to a user, in bps.
No access service supports this attribute in the current software version.
Remanent-Volume (15)
Attribute name
Remanent-Volume
Attribute number
15
Attribute type
Integer
Total amount of data available for a user. The measurement unit is configurable by using the attribute remanent-volume unit command. The default measurement unit is kilo-byte.
This attribute can be included in authentication response packets, accounting response packets, and CoA packets sent from a server. When the amount of user traffic reaches the value of this attribute, the NAS does not immediately logs off the user. Instead, the NAS triggers an accounting update. If the accounting response packet contains new data quota, the NAS updates the total amount of data available for the user. If the new data quota is 0 or no new data quota is assigned by the server, the NAS logs off the user. If this attribute is included in a CoA packet, the NAS updates the total amount of data available for the user.
Support for this attribute depends on the access type.
ISP-ID (17)
Attribute name
ISP-ID
Attribute number
17
Attribute type
String
ISP domain name of a user, a string of 1 to 253 characters.
·     In an Access-Request packet, this attribute represents the authentication domain used by the user to come online.
·     In an Access-Accept packet, this attribute represents the authorization domain assigned to the user for assigning authorization attributes to the user.
Command (20)
Attribute name
Attribute number
20
Attribute type
Integer
Operation for a user session, used for session control. Possible values include:
·     1: Trigger-Request. This value is not used in the current software version.
·     2: Terminate-Request. This value means that the server forcibly logs off the user.
·     3: SetPolicy. This value means that the server requests to change user authorization attributes.
·     4: Result. This value is used to respond to the server with the session operation result.
·     5: PortalClear. This value is not used in the current software version.
Acl-Version (21)
Attribute name
Acl-Version
Attribute number
21
Attribute type
Integer
ACL type. This attribute and an ACL name are assigned together to deploy an ACL to a user. Available ACL types:
·     1: IPv4.
·     2: IPv6.
·     3: MAC.
·     4: User.
Priority (22)
Attribute name
Priority
Attribute number
22
Attribute type
Integer
Service priority.
Result-Code (25)
Attribute name
Result-Code
Attribute number
25
Attribute type
Integer
Result of the Trigger-Request or SetPolicy operation, zero for success and any other value for failure.
PADM-URL (27)
Attribute name
PADM-URL
Attribute number
27
Attribute type
String
PADM URL assigned to a PPPoE user.
Ftp-Directory (28)
Attribute name
Ftp-Directory
Attribute number
28
Attribute type
String
FTP, SFTP, or SCP user working directory.
If this attribute is not assigned by a server, the NAS uses the default working directory of the current system as the FTP, SFTP, or SCP working directory.
Exec-Privilege (29)
Attribute name
Exec-Privilege
Attribute number
29
Attribute type
Integer
EXEC user priority, in the range of 0 to 15.
A server uses this attribute to assign the level-0 to level-15 user roles to device management users.
NAT-IP-Address (32)
Attribute name
NAT-IP-Address
Attribute number
32
Attribute type
Address
Public IP address assigned to a user when the source IP address and port are translated.
When an AAA user accesses the external network after NAT, the NAS includes this attribute in accounting request packets to report the public IP address of the user to the server. The server can identify the user by its public IP address.
NAT-Start-Port (33)
Attribute name
NAT-Start-Port
Attribute number
33
Attribute type
Integer
Start port number of the port range assigned to a user when the source IP address and port are translated.
The method for including this attribute in a packet and the attribute purposes are the same as those of attribute 32.
NAT-End-Port (34)
Attribute name
NAT-End-Port
Attribute number
34
Attribute type
Integer
End port number of the port range assigned to a user when the source IP address and port are translated.
NAS-Startup-Timestamp (59)
Attribute name
Attribute number
59
Attribute type
Integer
Startup time of the NAS in seconds, which is represented by the time elapsed after 00:00:00 on Jan. 1, 1970 (UTC).
Ip-Host-Addr (60)
Attribute name
Ip-Host-Addr
Attribute number
60
Attribute type
String
User IP address and MAC address included in authentication and accounting requests. The value is a string of 25 to 33 bytes in the format A.B.C.D hh:hh:hh:hh:hh:hh. A space is required between the IP address and the MAC address.
If the user IP address is invalid when the NAS sends an authentication request, the NAS pads A.B.C.D with all zeros.
An IMC server preferentially obtains MAC or IP addresses from this attribute for user and MAC or IP address bindings. If the value for this attribute is invalid, the server obtains IP or MAC addresses from the Framed-IP or Calling-Station-Id attribute, respectively.
User-Notify (61)
Attribute name
User-Notify
Attribute number
61
Attribute type
String
Information that must be sent from the server to the client transparently. The value is a string of 1 to 247 bytes. This attribute can appear multiple times in a packet to deliver multiple messages.
The NAS directly delivers this attribute to the client without parsing it. In EAD solutions, the server can use this attribute to deliver server information including the server IP address and port number to the client.
User-HeartBeat (62)
Attribute name
User-HeartBeat
Attribute number
62
Attribute type
String
Hash value assigned after an 802.1X user passes authentication, which is a 32-byte string. This attribute is stored in the user list on the NAS and verifies the handshake packets from the 802.1X client.
Multicast-Receive-Group (98)
Attribute name
Attribute number
98
Attribute type
Address
IP address of the multicast group that a user joins as a receiver.
This attribute can appear multiple times in a multicast packet to indicate that the user belongs to multiple multicast groups.
IP6-Multicast-Receive-Group (100)
Attribute name
Attribute number
100
Attribute type
Ipv6addr
IPv6 address of the multicast group that a user joins as a receiver.
MLD-Access-Limit (101)
Attribute name
MLD-Access-Limit
Attribute number
101
Attribute type
Integer
Maximum number of MLD multicast groups that a user can join concurrently.
Local-Name (102)
Attribute name
Local-Name
Attribute number
102
Attribute type
String
L2TP local tunnel name.
IGMP-Access-Limit (103)
Attribute name
IGMP-Access-Limit
Attribute number
103
Attribute type
Integer
Maximum number of IGMP multicast groups that a user can join concurrently.
VPN-Instance (104)
Attribute name
VPN-Instance
Attribute number
104
Attribute type
String
Name of the MPLS L3VPN instance to which a user belongs.
ANCP-Profile (105)
Attribute name
ANCP-Profile
Attribute number
105
Attribute type
String
ANCP profile name.
Longitude-Latitude (111)
Attribute name
Longitude-Latitude
Attribute number
111
Attribute type
String
Longitude and latitude information of the NAS. This attribute can only be included in start-accounting and stop-accounting packets.
The value is a string in the format of longitude,latitude. A longitude or latitude is in the format of DirectionDegree.
·     The default directions are east longitude and north latitude. To mark a west longitude or south latitude, add a minus sign (-) before the degree.
·     The degree is in the format of 3 digits plus 6 decimal places. If the number of decimal places is insufficient, use zero paddings.
For example, 123.230000,40.330000 represents east longitude 123.23 degree and north latitude 40.33 degree.
User-VLAN-ID (133)
Attribute name
User-VLAN-ID
Attribute number
133
Attribute type
Integer
User VLAN ID, a 4-byte integer.
This attribute is included in request packets to upload the active VLAN information of a user.
Client-Primary-DNS (135)
Attribute name
Client-Primary-DNS
Attribute number
135
Attribute type
Address
Address of the primary DNS server.
Client-Secondary-DNS (136)
Attribute name
Attribute number
136
Attribute type
Address
Address of the secondary DNS server.
User-Group (140)
Attribute name
User-Group
Attribute number
140
Attribute type
String
User groups assigned after a user passes authentication. Typically, a user can belong to only one user group. For SSL VPN users, a user can belong to multiple user groups. The user group names are separated by semicolon (;).
If this attribute is included in an authentication response packet, the user is assigned to the specified user groups after it passes authentication.
Acct-IPv6-Input-Octets (144)
Attribute name
Attribute number
144
Attribute type
Integer
Bytes of IPv6 packets in the inbound direction. The measurement unit depends on the configuration of the data-flow-format command on the NAS. Supported units include byte, kilo-byte, mega-byte, and giga-byte. By default, the unit is byte.
Acct-IPv6-Output-Octets (145)
Attribute name
Attribute number
145
Attribute type
Integer
Bytes of IPv6 packets in the outbound direction. The measurement unit depends on the configuration of the data-flow-format command on the NAS. Supported units include byte, kilo-byte, mega-byte, and giga-byte. By default, the unit is byte.
Acct-IPv6-Input-Packets (146)
Attribute name
Attribute number
146
Attribute type
Integer
Number of IPv6 packets in the inbound direction. The measurement unit depends on the configuration of the data-flow-format command on the NAS. Supported units include one-packet, kilo-packet, mega-packet, or giga-packet. By default, the unit is one-packet.
Acct-IPv6-Output-Packets (147)
Attribute name
Attribute number
147
Attribute type
Integer
Number of IPv6 packets in the outbound direction. The measurement unit depends on the configuration of the data-flow-format command on the NAS. Supported units include one-packet, kilo-packet, mega-packet, or giga-packet. By default, the unit is one-packet.
Acct-IPv6-Input-Gigawords (148)
Attribute name
Attribute number
148
Attribute type
Integer
Bytes of IPv6 packets in the inbound direction divided by 4G. The value is the most significant 32 bits of the Acct-ipv6-Input-Octets attribute (No. 144). The measurement unit is configurable by using the data-flow-format command on the NAS. Supported units include byte, kilo-byte, mega-byte, and giga-byte. The default measurement unit is byte.
Acct-IPv6-Output-Gigawords (149)
Attribute name
Attribute number
149
Attribute type
Integer
Bytes of IPv6 packets in the outbound direction divided by 4G. The value is the most significant 32 bits of the Acct-ipv6-Output-Octets attribute (No. 145). The measurement unit is configurable by using the data-flow-format command on the NAS. Supported units include byte, kilo-byte, mega-byte, and giga-byte. The default measurement unit is byte.
MAC-Proxy-Authenticator (150)
Attribute name
Attribute number
150
Attribute type
String
Checksum included in the authentication process. This attribute is used in a wireless roaming environment.
User-Roles (155)
Attribute name
User-Roles
Attribute number
155
Attribute type
String
List of space-separated user roles.
This attribute can appear multiple times in a packet.
Acct-Terminate-Subcause (181)
Attribute name
Attribute number
181
Attribute type
Integer
Subcause code for user going offline.
Input-Interval-Octets (201)
Attribute name
Attribute number
201
Attribute type
Integer
Upstream flow difference, in bytes.
Output-Interval-Octets (202)
Attribute name
Attribute number
202
Attribute type
Integer
Downstream flow difference, in bytes.
Input-Interval-Packets (203)
Attribute name
Attribute number
203
Attribute type
Integer
Upstream flow difference, in packets.
Output-Interval-Packets (204)
Attribute name
Attribute number
204
Attribute type
Integer
Downstream flow difference, in packets.
Input-Interval-Gigawords (205)
Attribute name
Attribute number
205
Attribute type
Integer
Upstream flow difference, in Gigawords.
Output-Interval-Gigawords (206)
Attribute name
Attribute number
206
Attribute type
Integer
Downstream flow difference, in Gigawords.
Dhcp-Option55 (208)
Attribute name
Dhcp-Option55
Attribute number
208
Attribute type
Octets
DHCP Option 55 fingerprint used in BYOD.
AV-Pair (210)
Attribute name
AV-Pair
Attribute number
210
Attribute type
String
Extended attributes assigned in attribute pair form. The format for an extended attribute is attribute-command-keywords=attribute-value.
For more information about the supported extended attributes and their formats, see "H3C AV-Pair (210) subattributes."
Accounting-Level (215)
Attribute name
Accounting-Level
Attribute number
215
Attribute type
Integer
ITA traffic accounting level, in the range of 1 to 8.
ITA-Policy-Name (216)
Attribute name
ITA-Policy-Name
Attribute number
216
Attribute type
Octets
Name of an Intelligent Target Accounting (ITA) policy.
DHCP-Option (218)
Attribute name
DHCP-Option
Attribute number
218
Attribute type
Octets
DHCP option information for the DHCP client. This attribute includes the following fields:
·     Type: Type of the option attribute. By default, the length of this field is 1 byte. You can use the include-attribute h3c-dhcp-option format format2 command to change the length of this field to 2 bytes to meet the requirement of HUAWEI servers.
·     Length: Length of the Value field.
·     Value: Value of the option attribute.
This attribute can be included in authentication request packets, start-accounting packets, and real-time accounting packets.
This attribute can appear multiple times in a packet to deliver multiple DHCP options.
Term-Framed-IPv6-Addres (219)
Attribute name
Attribute number
219
Attribute type
String
IPv6 addresses currently used by a user, in the format of IPv6Addr1IPv6Addr2IPv6Addr3. No separator is allowed between each two IPv6 addresses.
This attribute can appear multiple times in a packet. A maximum of 25 IPv6 addresses can be included in one packet.
This attribute is included in accounting request packets.
IP-Source-Mod (221)
Attribute name
IP-Source-Mod
Attribute number
221
Attribute type
Integer
IPv4 address source of a user. Supported values:
·     0: ARP snooping.
·     1: DHCP snooping.
Authen-Detail-Result (246)
Attribute name
Attribute number
246
Attribute type
Integer
Authentication result details. This attribute is used in conjunction with the Web-URL attribute (No.250). Supported values:
·     0: Cancel redirection. This value can be assigned only through CoA packets.
·     1: Continue redirection until redirection is canceled.
·     2: Perform redirection for a number of times. The maximum number of redirection times is configurable by using the authorization-attribute redirect-times command in ISP domain view on the NAS. By default, the maximum number of redirection times is 2.
Input-Committed-Burst-Size (247)
Attribute name
Attribute number
247
Attribute type
Integer
Committed burst size from a user to the NAS, in bits. The total length cannot exceed 4 bytes for this field.
This attribute must be assigned in conjunction with the Input-Average-Rate attribute (No. 2).
Output-Committed-Burst-Size (248)
Attribute name
Attribute number
248
Attribute type
Integer
Committed burst size from the NAS to a user, in bits. The total length cannot exceed 4 bytes for this field.
This attribute must be assigned in conjunction with the Output-Average-Rate attribute (No. 5).
Web-URL (250)
Attribute name
Web-URL
Attribute number
250
Attribute type
String
Web redirect URL for a user.
·     In single-stack scenarios, use this attribute to assign an IPv4 or IPv6 URL.
·     In dual-stack scenarios, use this attribute to assign an IPv4 URL and use user-defined attribute pair urlipv6-redirect to assign an IPv6 URL.
Subscriber-ID (251)
Attribute name
Subscriber-ID
Attribute number
251
Attribute type
String
Family plan ID, a string of digits.
Subscriber-Profile (252)
Attribute name
Subscriber-Profile
Attribute number
252
Attribute type
String
QoS policy name for the family plan of a subscriber.
Product-ID (255)
Attribute name
Product-ID
Attribute number
255
Attribute type
String
Product name.
Attribute format
device-traffic-class=voice
Server-assigned voice VLAN.
shell:roles="xxx yyy zzz"
shell:allowed-roles="xxx" applicable only to users who require temporary user role authorization
Space-separated list of user roles. xxx, yyy, and zzz are examples of role names.
url-redirect=xxx
Redirect URL.
url-redirect-acl=xxx
Redirect ACL.
urlipv6-redirect=xxx
Redirect ACL for IPv6 users.
subscriber:command=bounce-host-port
Server-assigned command to reboot a port.
subscriber:command=disable-host-port
Server-assigned command to shut down a port.
subscriber:command=reauthenticate
Deployed user reauthentication command:
station:radiation=xxx
User-uploaded signal strength between mobile devices and wireless APs.
Huawei attributs
HW-Input-Peak-Rate(1.0)/HW-Input-Committed-Burst-Size(1.1) (1)
Attribute name
Attribute number
1
Attribute type
Integer
(Huawei RADIUS1.0 protocol) Peak uplink rate of user access to an NAS device, in bps.
(Huawei RADIUS1.1 protocol) Uplink committed burst size for user access to an NAS device, in bit.The value length is 4 bytes. To deploy this attribute, you must also deploy the HW-Input-Committed-Info-Rate attribute.
HW-Input-Average-Rate(1.0)/HW-Input-Committed-Info-Rate(1.1) (2)
Attribute name
Attribute number
2
Attribute type
Integer
(Huawei RADIUS1.0 protocol) Average uplink rate of user access to an NAS device, in bps.
(Huawei RADIUS1.1 protocol) Committed uplink rate of user access to an NAS device, in bps. To deploy this attribute, you must also deploy the HW-Input-Committed-Burst-Size attribute.
HW-Input-Basic-Rate(1.0)/HW-Input-Peak-Info-Rate(1.1) (3)
Attribute name
Attribute number
3
Attribute type
Integer
(Huawei RADIUS1.0 protocol) Basic uplink rate of user access to an NAS device, in bps.
(Huawei RADIUS1.1 protocol) Peak uplink rate of user access to an NAS device, in bps. The value length is 4 bytes. Use this attribute for dual leaky bucket. To deploy this attribute, you must also deploy the HW-Input-Committed-Info-Rate attribute.
HW-Output-Peak-Rate(1.0)/HW-Output-Committed-Burst-Size(1.1) (4)
Attribute name
Attribute number
4
Attribute type
Integer
(Huawei RADIUS1.0 protocol) Peak downlink rate from an NAS device to a user, in bps.
(Huawei RADIUS1.1 protocol) Committed burst size for downlink from an NAS device to a user, in bit. The value length is 4 bytes. To deploy this attribute, you must also deploy the HW-Output-Committed-Info-Rate attribute.
HW-Output-Average-Rate(1.0)/HW-Output-Committed-Info-Rate(1.1) (5)
Attribute name
Attribute number
5
Attribute type
Integer
(Huawei RADIUS1.0 protocol) Average downlink rate from an NAS device to a user, in bps.
(Huawei RADIUS1.1 protocol) Committed downlink rate from an NAS device to a user, in bps. To deploy this attribute, you must also deploy the HW-Output-Committed-Burst-Rate attribute.
HW-Output-Basic-Rate(1.0)/HW-Output-Peak-Info-Rate(1.1) (6)
Attribute name
Attribute number
6
Attribute type
Integer
(Huawei RADIUS1.0 protocol) Basic downlink rate from an NAS device to a user, in bps.
(Huawei RADIUS1.1 protocol) Peak downlink rate from an NAS device to a user, in bps. The value length is 4 bytes. Use this attribute for dual leaky bucket. To deploy this attribute, you must also deploy the HW-Output-Committed-Info-Rate attribute.
HW-Command (20)
Attribute name
HW-Command
Attribute number
20
Attribute type
Integer
Action to take on user sessions. Options include:
·     1: Trigger-Request. This option is reserved for future use.
·     2: Terminate-Request. This action indicates forced user logoff.
·     3: SetPolicy. This action indicates that the server requires user authorization attribute modification.
·     4: Result. This action is used to send the session operation result to the server.
·     5: PortalClear. This option is reserved for future use.
HW-Result-Code (25)
Attribute name
HW-Result-Code
Attribute number
25
Attribute type
Integer
Indicates the Trigger-Request or SetPolicy result. 0 indicates success and a non-zero value indicates failure.
HW-PADM-URL (27)
Attribute name
HW-PADM-URL
Attribute number
27
Attribute type
String
PADM URL deployed to PPPoE.
HW-FTP-Directory (28)
Attribute name
HW-FTP-Directory
Attribute number
28
Attribute type
String
Working directory of an FTP/SFTP/SCP user.
If this attribute is not deployed, a NAS device obtains the default directory of the system as the FTP/SFTP/SCP working directory.
HW-Exec-Privilege (29)
Attribute name
HW-Exec-Privilege
Attribute number
29
Attribute type
Integer
EXEC user priority in the range of 0 to 15.
This attribute is used by the server to assign user role level 0 through level 15 to device management users.
HW-Server-String (61)
Attribute name
HW-Server-String
Attribute number
61
Attribute type
String
Message sent by the server to a client, a string of 1 to 247 bytes. The attribute can appear multiple times in a packet to deploy multiple messages.
NAS devices pass the attribute directly to clients without parsing the attribute.
HW-VPN-Instance (94)
Attribute name
HW-VPN-Instance
Attribute number
94
Attribute type
String
Name of the VPN to which a user can join.
HW-Multicast-Receive-Group (98)
Attribute name
Attribute number
98
Attribute type
Address
Address of the multicast group to which a user belongs as a multicast receiver.
If the attribute appears multiple times in a packet, it indicates that the user belongs to multiple multicast groups.
HW-Primary-DNS (135)
Attribute name
HW-Primary-DNS
Attribute number
135
Attribute type
Address
Primary DNS server address.
HW-Secondary-DNS (136)
Attribute name
HW-Secondary-DNS
Attribute number
136
Attribute type
Address
Secondary DNS server address.
HW-Domain-Name (138)
Attribute name
HW-Domain-Name
Attribute number
138
Attribute type
String
ISP domain name, a string of 1 to 253 characters.
·     The attribute in an Access-Request packet indicates the authentication domain used by user association.
·     The attribute in an Access-Accept packet indicates the authorized domain to a user.
HW-ANCP-Profile (139)
Attribute name
HW-ANCP-Profile
Attribute number
139
Attribute type
String
ANCP policy name.
HW-Max-List-Num (143)
Attribute name
HW-Max-List-Num
Attribute number
143
Attribute type
Integer
Maximum number of IPv4 multicast groups that a user can join.
HW-Web-URL (253)
Attribute name
HW-Web-URL
Attribute number
253
Attribute type
String
User Web-redirection URL.
Microsoft attributes
MS-CHAP-Response (1)
Attribute name
MS-CHAP-Response
Attribute number
1
Attribute type
Binary
Response to the MS-CHAP authentication challenge, a string of 50 bytes.
In the current software version, only PPP users support this attribute.
MS-CHAP-Error (2)
Attribute name
MS-CHAP-Error
Attribute number
2
Attribute type
Binary
Error information carried in an MS-CHAP Access-Reject packet, a string of 80 bytes.
MS-CHAP-NT-Enc-PW (6)
Attribute name
MS-CHAP-NT-Enc-PW
Attribute number
6
Attribute type
Binary
New CHAP password obtained by encrypting the old password. The new password contains 516 bytes, which exceeds the maximum length of a RADIUS attribute. The password will be fragmented and carried in multiple attributes for transmission. The attribute contains a 2-byte serial number for fragment reassembly.
MS-CHAP-Challenge (11)
Attribute name
MS-CHAP-Challenge
Attribute number
11
Attribute type
Binary
CHAP challenge. For MS-CHAP authentication, the value length is 8 bytes. For MS-CHAP2 authentication, the value length is 16 bytes. For MS-CHAP2 password change, the value length is 32 bytes.
MS-MPPE-Send-Key (16)
Attribute name
MS-MPPE-Send-Key
Attribute number
16
Attribute type
Binary
MPPE key generated for TLS or PEAP authentication. This attribute is used for 802.1X authentication.
MS-MPPE-Recv-Key (17)
Attribute name
MS-MPPE-Recv-Key
Attribute number
17
Attribute type
Binary
MS-CHAP2-Response (25)
Attribute name
MS-CHAP2-Response
Attribute number
25
Attribute type
Binary
Response to the CHAP2 authentication challenge. The value length is 50 bytes.
MS-CHAP2-Success (26)
Attribute name
MS-CHAP2-Success
Attribute number
26
Attribute type
Binary
Authentication success code. The value length is 42 bytes.
MS-CHAP2-ChangePW (27)
Attribute name
MS-CHAP2-ChangePW
Attribute number
27
Attribute type
Binary
MS-CHAP2 password change information.
If the password of a user has expired, the user can change the password.
MS-Primary-DNS (28)
Attribute name
MS-Primary-DNS
Attribute number
28
Attribute type
Binary
MS-Secondary-DNS (29)
Attribute name
MS-Secondary-DNS
Attribute number
29
Attribute type
Binary
3Com attributes
user_access_level (1)
Attribute name
user_access_level
Attribute number
1
Attribute type
Integer
Cisco attributes
CISCO-AV-Pair (1)
Attribute name
CISCO-AV-Pair
Attribute number
1
Attribute type
String
Extended attribute deployed in AV pair format, which is Attribute Name=Attribute Value.
For more information about supported extended attributes and formats, see the table blow.
CISCO-AV-Pair (1)
Attribute name
CISCO-AV-Pair
Attribute number
1
Attribute type
String
Deployed voice VLAN:
CISCO-AV-Pair (1)
Attribute name
CISCO-AV-Pair
Attribute number
1
Attribute type
String
Deployed user role list.
shell:allowed-roles="xxx" (Only for super users)
Use a space to separate two role names.
CISCO-AV-Pair (1)
Attribute name
CISCO-AV-Pair
Attribute number
1
Attribute type
String
Deployed user redirection URL:
url-redirect=xxx
Deployed user redirection ACL:
CISCO-AV-Pair (1)
Attribute name
CISCO-AV-Pair
Attribute number
1
Attribute type
Integer
Deployed port restart command:
Deployed port shutdown command:
Deployed port restart duration in seconds:
bounce:seconds=xxx
CISCO-AV-Pair (1)
Attribute name
CISCO-AV-Pair
Attribute number
1
Attribute type
String
Deployed dynamic ACL:
CiscoSecure-Defined-ACL=#ACSACL#-IP-Name-Number
For example, CiscoSecure-Defined-ACL=#ACSACL#-IP-UACL-0
CISCO-AV-Pair (1)
Attribute name
CISCO-AV-Pair
Attribute number
1
Attribute type
String
Deployed dynamic ACL rule:
ip:inacl#number=xxx
For example, ip:inacl#1=permit udp any any eq 21862
The device supports decoding only dynamic ACL rules of the following format:
{ deny | permit } protocol [ destination { dest-address dest-wildcard | any } | destination-port operator port1 [ port2 ] | source { source-address source-wildcard | any } | source-port operator port1 [ port2 ] ]
Available operator options include lt, gt, eq, and neq, which represent smaller than, greater than, equal, and not equal, respectively.
China Telecom attributes
User-Address-Type (120)
Attribute name
User-Address-Type
Attribute number
120
Attribute type
Integer
User access address type. Options include:
·     0: Public network IPv4 user
·     1: Private network IPv4 user
·     2: Public network dual-stack user
·     3: Private network dual-stack user
·     4: DS-Lite user
·     5: Pure IPv6 user
·     6: NAT64 user
User-Address-Log (121)
Attribute name
User-Address-Log
Attribute number
121
Attribute type
String
CGN address translation log information, including end port number and user address. The value is a string and is carried in accounting request packets.
In this attribute, colons (:) are used to separate different fields. For example, mapping time (YY/MM/DD/HH/MM/SS):Public address(IPv4 address):Start port number:End port number:User address(IPv4 or IPv6).
DSL forum attributes
Agent-Circuit-Id (1)
Attribute name
Agent-Circuit-Id
Attribute number
1
Attribute type
String
User access link ID. It corresponds to the logic port of the access node (DSLA for example) requested by the initiator user. The ID is a string of 1 to 32 characters.
Agent-Remote-Id (2)
Attribute name
Agent-Remote-Id
Attribute number
2
Attribute type
String
Identifier of a user link, which is used to uniquely identify the user. The identifier is a string of 1 to 32 characters.
Actual-Data-Rate-Upstream (129)
Attribute name
Attribute number
129
Attribute type
Integer
Actual uplink rate of a user link. The value length is 4 bytes.
Actual-Data-Rate-Downstream (130)
Attribute name
Attribute number
130
Attribute type
Integer
Actual downlink rate of a user. The value length is 4 bytes.
Minimum-Data-Rate-Upstream (131)
Attribute name
Attribute number
131
Attribute type
Integer
Minimum uplink rate configured for a user. The value length is 4 bytes.
Minimum-Data-Rate-Downstream (132)
Attribute name
Attribute number
132
Attribute type
Integer
Minimum downlink rate configured for a user. The value length is 4 bytes.
Attainable-Data-Rate-Upstream (133)
Attribute name
Attribute number
133
Attribute type
Integer
Uplink rate that can be reached by a user. The value length is 4 bytes.
Attainable-Data-Rate-Downstream (134)
Attribute name
Attribute number
134
Attribute type
Integer
Downlink rate that can be reached by a user. The value length is 4 bytes.
Maximum-Data-Rate-Upstream (135)
Attribute name
Attribute number
135
Attribute type
Integer
Maximum uplink rate configured for a user. The value length is 4 bytes.
Maximum-Data-Rate-Downstream (136)
Attribute name
Attribute number
136
Attribute type
Integer
Maximum downlink rate configured for a user. The value length is 4 bytes.
Minimum-Data-Rate-Upstream-Low-Power (137)
Attribute name
Attribute number
137
Attribute type
Integer
Minimum uplink rate configured for a user in low-power state (L1/L2). The value range is 4 bytes.
Minimum-Data-Rate-Downstream-Low-Power (138)
Attribute name
Attribute number
138
Attribute type
Integer
Attribute description
Minimum downlink rate configured for a user in low-power state (L1/L2). The value range is 4 bytes.
Maximum-Interleaving-Delay-Upstream (139)
Attribute name
Attribute number
139
Attribute type
Integer
Maximum interleaving delay per uplink flow configured for a user. The value length is 4 bytes.
Actual-Interleaving-Delay-Upstream (140)
Attribute name
Attribute number
140
Attribute type
Integer
Actual interleaving delay per uplink flow configured for a user. The value length is 4 bytes.
Maximum-Interleaving-Delay-Downstream (141)
Attribute name
Attribute number
141
Attribute type
Integer
Maximum interleaving delay per downlink flow configured for a user. The value length is 4 bytes.
Actual-Interleaving-Delay-Downstream (142)
Attribute name
Attribute number
142
Attribute type
Integer
Actual interleaving delay per downlink flow configured for a user. The value length is 4 bytes.
Access-Loop-Encapsulation (144)
Attribute name
Attribute number
144
Attribute type
Binary
Encapsulation type of the user access link, a string of 1 to 24 characters.
IWF-Session (254)
Attribute name
IWF-Session
Attribute number
254
Attribute type
Binary
InterWorking Function (IWF) flag, data excluded. This attribute indicates that transmission of PPPoA traffic through PPPoE is allowed.
No service supports this attribute.
WFA attributes
WFA-Remediation-Indication (1)
Attribute name
Attribute number
1
Attribute type
String
Downlink authentication response attribute dedicated for wireless users.
For detailed attribute description, refer to WFA definitions.
WFA-DeAuthentication-Imminent (4)
Attribute name
Attribute number
4
Attribute type
String
WFA-HS2-0-Session-Information-URL (5)
Attribute name
Attribute number
5
Attribute type
String
