H3C UIS 3000 G5 Hyper-Converged Infrastructure Ecodesign Manual-5PW101
HomeSupportCloud ComputingUIS 3000 G5 SeriesInstall & UpgradeCompliance and Safety InformationH3C UIS 3000 G5 Hyper-Converged Infrastructure Ecodesign Manual-5PW101
Download Book
H3C UIS Series Product Information for Ecodesign Requirements of (EU) 2019/424
Regulatory Reference: COMMISSION REGULATION (EU) 2019/424, implementing Directive 2009/125/EC of the European Parliament and of the Council with regard to Ecodesign requirements for servers and online data storage products.
Product Type
Sever
Manufacturer
New H3C Technologies Co., Ltd
Trade
H3C
Address
466 Changhe Road, Binjiang, 310052 Hangzhou, PEOPLE'S REPUBLIC OF CHINA
Product Model
H3C UIS 3000 G5
Year of Manufacture
2019
PSU Efficiency
PSU model
DPS-850AB-4
Rated Output
+12V/70.8A,+12VSB/2.1A
Rated Load
10%
20%
50%
100%
PSU Efficiency
91.36%
93.52%
94.59%
92.10%
Power Factor
0.984
PSU model
DPS-550AB-22 G
Rated Output
+12V/45.8A,+12VSB/2.1A
Rated Load
10%
20%
50%
100%
PSU Efficiency
91.72%
94.22%
95.44%
93.90%
Power Factor
0.996
PSU model
DPS-1300AB-6 R
Rated Output
+12V/108A,+12VSB/2.1A
Rated Load
10%
20%
50%
100%
PSU Efficiency
90.90%
93.57%
94.38%
92.94%
Power Factor
0.995
PSU model
DPS-1600AB-13 R
Rated Output
12V/132A,12VSB/2.1A
Rated Load
10%
20%
50%
100%
PSU Efficiency
91.91%
94.03%
94.34%
92.40%
Power Factor
0.994
PSU model
DPS-2400EB
Rated Output
12V/84A,12VSB/3A
Rated Load
10%
20%
50%
100%
PSU Efficiency
89.74%
93.45%
94.22%
91.50%
Power Factor
0.9995
Note1: DC-DC internal power supplies don’t need to fill in the form.
Note2: External Power Supplies (EPS) are regulated as a separate component in the European Union and a separate compliance document is required for EPSs. Leave Internal Power Supply test data fields blank for products that use an EPS (and that do not use an internal power supply).
Idle State Power (W) and Active state efficiency
The test for Idle State power and Active State Efficiency is based on ETSI EN 303 470 V1.1.1 (2019-03)- Environmental Engineering (EE); Energy Efficiency measurement methodology and metrics for servers.
Configuration
Low-end performance configuration
519.52
302.6
High-end performance configuration
532.32
312.1
Note: SERT Active State Efficiency must be higher to pass to table 5 of the Regulation. SERT Idle State Power must be lower than the calculated limit to pass- described in Annex II 2.1 of the Regulation.
Components List for additional idle power allowances
System characteristics
Quantity
Additional Idle Power Allowances
CPU Performance
2
15.4
Additional PSU
0
0
HDD or SSD
3
15
Additional Memory (GB)
2044
367.92
Additional buffered DDR Channel
24
96
Additional I/O devices
0
0
Total additional idle power allowances
494.32
Maximum Power (W)
Configuration
Maximum Power
519.52
532.32
Operating Condition Class
Dry bulb temp °C
Humidity range, non-condensing
Allowable Range
Recommended Range
Allowable Range
Recommended Range
Max Dew Point (°C)
Maximum rate of Change (°C/hr)
A4
5-45
18-27
-12 °C DP and 8 % RH to 24 °C DP and 90 % RH
-9 °C DP to 15 °C DP and 60 % RH
24
5/20
Idle State Power at the higher boundary temperature of the declared operating condition class
Configuration
Idle State Power
519.52
532.32
List of all model configurations
Computing
2×3rd generation  Intel® Xeon® Scalable processors
(Up to 40 cores and maximum 270 W power consumption)
Memory
32 × DDR4 DIMMs, 12.0 TB (maximum)
(Up to 3200 MT/s data transfer rate and support for both RDIMM and LRDIMM)
(Up to 16 Intel ® Optane™ DC Persistent Memory Module PMem 200 series .( Barlow Pass)
Storage
Support up to Front 12LFF bays, Internal 4LFF bays , Rear 4LFF+4SFF bays
Support up to Front 25SFF bays, Internal 8SFF bays , Rear 4LFF+4SFF bays
Support Front/Internal  SAS/SATA HDD/SSD/NVMe Drives
Maximum 28 x U.2 NVMe Drives
PCIe NVMe storage accelerator, SATA/PCIe M.2 SSDs, 2 × SD Internal slots (Optional)
GPU
14 × single-slot wide or 4 × double-slot GPU modules
Note: The configurations of server product family are end-user configurable / selectable, the detail can be found at http://www.h3c.com
The Concentration of Cobalt and Neodymium
Item
Cobalt in battery
Less than 5g
Neodymium in HDD
between 5 g and 25 g
Disassembly Operations
Operation Type
Data Storage Device
Release buckle
Memory
Release buckle
CPU
Remove Screw
Motherboard
Release buckle
Expansion/Graphic Card
Release buckle
PSU
Release buckle
Chassis
Release buckle
Batteries
Release buckle
Fastening technique type
Quantity
Required Tool
Trox Screw
24
Trox Screw Driver T15
Trox Screw
8
Trox Screw Driver T10
Trox Screw
4
Trox Screw Driver T30
Philps Screw
2
Philps Screw Driver #2
Buckle
76
