- 05-Network Connectivity Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-L2TP commands
- 10-ARP commands
- 11-IP addressing commands
- 12-DHCP commands
- 13-DHCP snooping commands
- 14-DHCPv6 commands
- 15-DHCPv6 snooping commands
- 16-DNS commands
- 17-HTTP commands
- 18-HTTP redirect commands
- 19-IP forwarding basics commands
- 20-Fast forwarding commands
- 21-Adjacency table commands
- 22-IP performance optimization commands
- 23-IPv6 basics commands
- 24-IPv6 neighbor discovery commands
- 25-IPv6 fast forwarding commands
- 26-NAT commands
- 27-GRE commands
- 28-Basic IP routing commands
- 29-Static routing commands
- 30-OSPF commands
- 31-Policy-based routing commands
- 32-IPv6 static routing commands
- 33-IPv6 policy-based routing commands
- 34-IGMP snooping commands
- 35-MLD snooping commands
27-GRE commands | 49.44 KB |
GRE commands
gre checksum
Use gre checksum to enable GRE checksum.
Use undo gre checksum to disable GRE checksum.
gre checksum
undo gre checksum
GRE checksum is disabled.
Tunnel interface view
GRE checksum verifies packet integrity.
You can enable or disable GRE checksum at each end of a tunnel as needed. After GRE checksum is enabled, the sender does the following:
· Calculates the checksum for the GRE header and the payload.
· Sends the packet containing the checksum information to the peer.
The receiver calculates the checksum for the received packet and compares it with that carried in the packet. If the checksums are the same, the receiver processes the packet. If the checksums are different, the receiver discards the packet.
If a packet carries a GRE checksum, the receiver checks the checksum whether or not the receiver is enabled with GRE checksum.
# Enable GRE checksum.
[Sysname] interface tunnel 2 mode gre
[Sysname-Tunnel2] gre checksum
gre key
Use gre key to configure a key for a GRE tunnel interface.
Use undo gre key to restore the default.
gre key key
undo gre key
No key is configured for a GRE tunnel interface.
key: Specifies the key for the GRE tunnel interface, in the range of 0 to 4294967295.
Both ends of a GRE tunnel must have the same key or no key.
# Configure the GRE key as 123 for the GRE tunnel interface Tunnel 2.
[Sysname-Tunnel2] gre key 123
keepalive
Use keepalive to enable GRE keepalive and set the keepalive interval and the keepalive number.
Use undo keepalive to disable GRE keepalive.
keepalive [ interval [ times ] ]
undo keepalive
GRE keepalive is disabled.
interval: Specifies the keepalive interval, in the range of 1 to 32767 seconds. The default value is 10.
times: Specifies the keepalive number, in the range of 1 to 255. The default value is 3.
This command enables the tunnel interface to send keepalive packets at the specified interval. If the device receives no response from the peer within the timeout time, it shuts down the local tunnel interface. The device brings the local tunnel interface up if it receives a keepalive acknowledgment packet from the peer. The timeout time is the result of multiplying the keepalive interval by the keepalive number.
The device always acknowledges the keepalive packets it receives whether or not GRE keepalive is enabled.
GRE/IPv6 mode tunnel interfaces do not support this command.
# Enable GRE keepalive, set the keepalive interval to 20 seconds, and set the keepalive number to 5.
[Sysname-Tunnel2] keepalive 20 5
