- 05-Network Connectivity Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-L2TP commands
- 10-ARP commands
- 11-IP addressing commands
- 12-DHCP commands
- 13-DHCP snooping commands
- 14-DHCPv6 commands
- 15-DHCPv6 snooping commands
- 16-DNS commands
- 17-HTTP commands
- 18-HTTP redirect commands
- 19-IP forwarding basics commands
- 20-Fast forwarding commands
- 21-Adjacency table commands
- 22-IP performance optimization commands
- 23-IPv6 basics commands
- 24-IPv6 neighbor discovery commands
- 25-IPv6 fast forwarding commands
- 26-NAT commands
- 27-GRE commands
- 28-Basic IP routing commands
- 29-Static routing commands
- 30-OSPF commands
- 31-Policy-based routing commands
- 32-IPv6 static routing commands
- 33-IPv6 policy-based routing commands
- 34-IGMP snooping commands
- 35-MLD snooping commands
15-DHCPv6 snooping commands | 176.51 KB |
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping pd binding
display ipv6 dhcp snooping trust
ipv6 dhcp snooping alarm enable
ipv6 dhcp snooping alarm threshold
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check relay-forward
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping client-detect
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 dhcp snooping pd binding record
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping packet statistics
reset ipv6 dhcp snooping pd binding
DHCPv6 snooping works between the DHCPv6 client and the DHCPv6 server or between the DHCPv6 client and DHCPv6 the relay agent. DHCPv6 snooping does not work between the DHCPv6 server and the DHCPv6 relay agent.
Use display ipv6 dhcp snooping binding to display DHCPv6 snooping address entries.
display ipv6 dhcp snooping binding [ address ipv6-address [ vlan vlan-id ] ]
address ipv6-address: Displays the DHCPv6 snooping entry for the specified IPv6 address.
vlan vlan-id: Specifies the ID of the VLAN where the IPv6 address resides.
If you do not specify any parameters, this command displays all DHCPv6 snooping address entries.
# Display all DHCPv6 snooping address entries.
<Sysname> display ipv6 dhcp snooping binding
1 DHCPv6 snooping entries found.
IPv6 address MAC address Lease VLAN SVLAN Interface
2::1 00e0-fc00-0006 54 2 N/A GigabitEthernet1/0/1
IPv6 Address |
IPv6 address assigned to the DHCPv6 client. |
MAC Address |
MAC address of the DHCPv6 client. |
Lease |
Remaining lease duration in seconds. |
VLAN |
When the DHCPv6 packet contains two VLAN tags, this field identifies the outer VLAN tag. Otherwise, it identifies the VLAN where the port connecting the DHCPv6 client resides. |
SVLAN |
When the DHCPv6 packet contains two VLAN tags, this field identifies the inner VLAN tag. Otherwise, it displays N/A. |
Port connecting to the DHCPv6 client. |
Use display ipv6 dhcp snooping binding database to display information about DHCPv6 snooping entry auto backup.
# Display information about DHCPv6 snooping entry auto backup.
<Sysname> display ipv6 dhcp snooping binding database
File name : database.dhcp
Username :
Password :
Update interval : 600 seconds
Latest write time : Feb 27 18:48:04 2012
Status : Last write succeeded.
File name |
Name of the DHCPv6 snooping entry backup file. |
Username |
Username for accessing the URL of the remote backup file. |
Password |
Password for accessing the URL of the remote backup file. This field displays ****** if a password is configured. |
Update interval |
Waiting time in seconds after a DHCPv6 snooping entry change for the DHCPv6 snooping device to update the backup file. |
Latest write time |
Time of the latest update. |
Status |
Status of the update: · Writing—The backup file is being updated. · Last write succeeded—The backup file was successfully updated. · Last write failed—The backup file failed to be updated. |
Use display ipv6 dhcp snooping packet statistics to display DHCPv6 packet statistics for DHCPv6 snooping.
display ipv6 dhcp snooping packet statistics [ slot slot-number ]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command displays DHCPv6 packet statistics for the master device.
# Display DHCPv6 packet statistics for DHCPv6 snooping.
<Sysname> display ipv6 dhcp snooping packet statistics
DHCPv6 packets received : 100
DHCPv6 packets sent : 200
Invalid DHCPv6 packets dropped : 0
Use display ipv6 dhcp snooping pd binding to display DHCPv6 snooping prefix entries.
display ipv6 dhcp snooping pd binding [ prefix prefix/prefix-length [ vlan vlan-id ] ]
prefix prefix/prefix-length: Specifies an IPv6 prefix with its length. The value range for the prefix-length argument is 1 to 128.
vlan vlan-id: Specifies the ID of the VLAN where the IPv6 prefix resides. The value range for the vlan-id argument is 1 to 4094.
This command takes effect only after you execute the ipv6 dhcp snooping pd binding record command on the port directly connecting to the clients.
If you do not specify any parameters, this command displays all DHCPv6 snooping prefix entries.
# Display all DHCPv6 snooping prefix entries.
<Sysname> display ipv6 dhcp snooping pd binding
1 DHCPv6 snooping PD entries found.
IPv6 prefix Lease VLAN SVLAN Interface
1:2::/64 54 2 N/A GigabitEthernet1/0/1
n DHCPv6 snooping PD entries found. |
Total number of DHCPv6 snooping prefix entries. |
IPv6 prefix |
IPv6 prefix assigned to the DHCPv6 client. |
Lease |
VLAN |
When both DHCPv6 snooping and QinQ are enabled or the DHCPv6 packet contains two VLAN tags, this field identifies the outer VLAN tag. Otherwise, it identifies the VLAN where the port connecting the DHCPv6 client resides. |
SVLAN |
When both DHCPv6 snooping and QinQ are enabled or the DHCPv6 packet contains two VLAN tags, this field identifies the inner VLAN tag. Otherwise, it displays N/A. |
Use display ipv6 dhcp snooping trust to display information about trusted ports.
# Display information about trusted ports.
<Sysname> display ipv6 dhcp snooping trust
DHCPv6 snooping is enabled.
Interface Trusted
GigabitEthernet1/0/1 Trusted
VSI(Trust tunnel) Trusted
Interface SrvID Trusted
GE1/0/1 1 Trusted
Interface name. |
VSI(Trust tunnel) |
This field is not supported in the current software version. VSI name. This field is available when you configure the VXLAN tunnel interfaces assigned to the VSI as a DHCP snooping trusted interface by using the ipv6 dhcp snooping trust tunnel command. |
SrvID |
ID of the Ethernet service instance on which the mapped AC is configured as a DHCP snooping trusted interface. |
Trusted |
DHCP snooping trusted interface. This field displays Trusted if the interface is configured as trusted after the DHCPv6 snooping is enabled. |
Use ipv6 dhcp snooping alarm enable to enable the packet drop alarm.
Use undo ipv6 dhcp snooping alarm enable to disable the packet drop alarm.
ipv6 dhcp snooping alarm { relay-forward | request-message } enable
undo ipv6 dhcp snooping alarm { relay-forward | request-message } enable
The packet drop alarm is disabled.
relay-forward: Specifies Relay-Forward check.
request-message: Specifies DHCPv6-REQUEST check.
After you enable the packet drop alarm for a feature, the device generates an alarm log when the number of packets dropped by this feature reaches or exceeds the threshold. The alarm log is sent to the information center. You can set log message filtering and output rules by configuring the information center. For information about the information center, see System Management Configuration Guide.
To set the alarm threshold, use the ipv6 dhcp snooping alarm threshold command.
For this command to take effect, you must first execute the ipv6 dhcp snooping log enable command to enable DHCPv6 snooping logging.
# Enable the packet drop alarm for Relay-Forward check.
[Sysname] ipv6 dhcp snooping alarm relay-forward enable
Use ipv6 dhcp snooping alarm threshold to set a packet drop alarm threshold.
Use undo ipv6 dhcp snooping alarm threshold to restore the default.
ipv6 dhcp snooping alarm { relay-forward | request-message } threshold threshold
undo ipv6 dhcp snooping alarm { relay-forward | request-message } threshold
The packet drop alarm threshold is 100.
threshold: Specifies the number of dropped packets that triggers a packet drop alarm. The value range is 1 to 1000.
The device generates an alarm log when the number of packets dropped due to the check failure reaches or exceeds the alarm threshold.
# Set the packet drop alarm threshold to 2 for Relay-Forward check.
[Sysname] ipv6 dhcp snooping alarm relay-forward threshold 2
Use ipv6 dhcp snooping binding database filename to configure the DHCPv6 snooping device to back up DHCPv6 snooping entries to a file.
Use undo ipv6 dhcp snooping binding database filename to disable the auto backup and remove the backup file.
ipv6 dhcp snooping binding database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
The DHCPv6 snooping device does not back up DHCPv6 snooping entries.
filename: Specifies the local backup file name, a case-insensitive string of 1 to 255 characters. For information about the filename argument, see Fundamentals Configuration Guide.
url url: Specifies the URL of a remote backup file. The URL is a case-sensitive string of 1 to 255 characters. Do not include a username or password in the URL. The supported path format type varies by server.
username username: Specifies the username for accessing the URL of the remote backup file. The username is a case-sensitive string of 1 to 32 characters. Do not specify this option if a username is not required for accessing the URL.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters. Do not specify this argument if a password is not required for accessing the URL of the remote backup file.
This command automatically creates the file if you specify a nonexistent file.
With this command executed, the DHCPv6 snooping device backs up its snooping entries immediately and runs auto backup. The snooping device, by default, waits 300 seconds after a DHCPv6 snooping entry change to update the backup file. You can use the ipv6 dhcp snooping binding database update interval command to change the waiting time. If no DHCPv6 snooping entry changes, the backup file is not updated.
As a best practice, back up the DHCPv6 snooping entries to a remote file. If you use the local storage medium, the frequent erasing and writing might damage the medium and then cause the DHCPv6 snooping device malfunction.
When the file is on a remote device, follow these restrictions and guidelines to specify the URL, username, and password:
· If the file is on an FTP server, enter URL in the format of ftp://server address:port/file path, where the port number is optional.
· If the file is on a TFTP server, enter URL in the format of tftp://server address:port/file path, where the port number is optional.
· The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
· If the IP address of the server is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[1::1]/database.dhcp.
· You can also specify the DNS domain name for the server address field, for example, ftp://company/database.dhcp.
# Configure the DHCPv6 snooping device to back up DHCPv6 snooping entries to the file database.dhcp.
[Sysname] ipv6 dhcp snooping binding database filename database.dhcp
# Configure the DHCPv6 snooping device to back up DHCPv6 snooping entries to the file database.dhcp in the working directory of the FTP server at 1::1.
[Sysname] ipv6 dhcp snooping binding database filename url ftp://[1::1]/database.dhcp username 1 password simple 1
# Configure the DHCPv6 snooping device to back up DHCPv6 snooping entries to the file database.dhcp in the working directory of the TFTP server at 2::1.
[Sysname] ipv6 dhcp snooping binding database filename url tftp://[2::1]/database.dhcp
Use ipv6 dhcp snooping binding database update interval to set the waiting time for the DHCPv6 snooping device to update the backup file after a DHCPv6 snooping entry change.
Use undo ipv6 dhcp snooping binding database update interval to restore the default.
ipv6 dhcp snooping binding database update interval interval
The DHCPv6 snooping device waits 300 seconds to update the backup file after a DHCPv6 snooping entry change. If no DHCPv6 snooping entry changes, the backup file is not updated.
interval: Sets the waiting time in seconds, in the range of 60 to 864000.
When a DHCPv6 snooping entry is learned, updated, or removed, the waiting period starts. The DHCPv6 snooping device updates the backup file when the waiting period is reached. All snooping entries changed during the period will be saved to the backup file.
The waiting time takes effect only after you configure the DHCPv6 snooping entry auto backup by using the ipv6 dhcp snooping binding database filename command.
# Set the waiting time to 600 seconds for the DHCPv6 snooping device to update the backup file.
[Sysname] ipv6 dhcp snooping binding database update interval 600
Use ipv6 dhcp snooping binding database update now to manually save DHCPv6 snooping entries to the backup file.
Each time this command is executed, the DHCPv6 snooping entries are saved to the backup file.
This command takes effect only after you configure the DHCPv6 snooping entry auto backup by using the ipv6 dhcp snooping binding database filename command.
# Manually save DHCPv6 snooping entries to the backup file.
[Sysname] ipv6 dhcp snooping binding database update now
Use ipv6 dhcp snooping binding record to enable recording DHCPv6 snooping address entries.
Use undo ipv6 dhcp snooping binding record to disable recording DHCPv6 snooping address entries.
Recording of DHCPv6 snooping address entries is disabled.
Layer 2 Ethernet interface/Layer 2 aggregate interface view
You can configure this command on the ports that are directly connected to the DHCPv6 clients.
This command enables DHCPv6 snooping to record IP-to-MAC information of the DHCPv6 clients (called DHCPv6 snooping address entries).
# Enable recording DHCPv6 snooping address entries on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping binding record
Use ipv6 dhcp snooping check relay-forward to enable the Relay-Forward packet check.
Use undo ipv6 dhcp snooping check relay-forward to disable the Relay-Forward packet check.
The Relay-Forward packet check is disabled.
A DHCPv6 snooping device functions between DHCPv6 clients and a DHCPv6 server, or between DHCPv6 clients and a DHCPv6 relay agent. When a DHCPv6 relay agent receives a DHCPv6 request, it generates a Relay-Forward packet, adds client information to Option 79, and then forwards the packet to the DHCPv6 server. If the DHCPv6 snooping device receives a Relay-Forward packet, it indicates that the DHCPv6 snooping device location is not correct. In this case, the DHCPv6 snooping device cannot function correctly.
This feature enables the DHCPv6 snooping device to drop Relay-Forward packets. When the number of dropped Relay-Forward packets reaches or exceeds the threshold, the device generates a log for administrators to adjust locations of the DHCPv6 devices.
# Enable the Relay-Forward packet check on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping check relay-forward
Use ipv6 dhcp snooping check request-message to enable the DHCPv6-REQUEST check feature.
Use undo ipv6 dhcp snooping check request-message to disable the DHCPv6-REQUEST check feature.
The DHCPv6-REQUEST check feature is disabled.
Use the DHCPv6-REQUEST check feature to protect the DHCPv6 server against DHCPv6 client spoofing attacks. The feature enables the DHCPv6 snooping device to check every received DHCPv6-RENEW, DHCPv6-DECLINE, or DHCPv6-RELEASE message against DHCPv6 snooping entries.
· If any criterion in an entry is matched, the device compares the entry with the message information.
¡ If they are consistent, the device considers the message valid and forwards it to the DHCPv6 server.
¡ If they are different, the device considers the message forged and discards it.
· If no matching entry is found, the device forwards the message to the DHCPv6 server.
# Enable DHCPv6-REQUEST check.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping check request-message
Use ipv6 dhcp snooping client-detect to enable client offline detection.
Use undo ipv6 dhcp snooping client-detect to disable client offline detection.
Client offline detection is disabled.
When a DHCPv6 client goes offline abnormally, it does not send a message to the DHCPv6 server to release its IPv6 address. As a result, the DHCPv6 server is not aware of the offline event and cannot release the address lease of the client timely.
With this feature enabled, the DHCPv6 snooping device performs the following operations when the ND entry of a client ages out:
1. Deletes the DHCPv6 snooping entry for the client.
2. Sends a release message to the DHCPv6 server to inform the server to release the address lease of the client.
# Enable client offline detection.
[Sysname] ipv6 dhcp snooping client-detect
ipv6 dhcp snooping enable
Use ipv6 dhcp snooping enable to enable DHCPv6 snooping.
Use undo ipv6 dhcp snooping enable to disable DHCPv6 snooping.
DHCPv6 snooping is disabled.
Use the DHCPv6 snooping feature together with trusted port configuration. Trusted ports forward responses from DHCPv6 servers and untrusted ports discard responses from DHCPv6 servers. This mechanism ensures that DHCPv6 clients obtain IPv6 addresses or prefixes from authorized DHCPv6 servers.
When DHCPv6 snooping is disabled, all ports on the device forward responses from DHCPv6 servers.
# Enable DHCPv6 snooping.
[Sysname] ipv6 dhcp snooping enable
Use ipv6 dhcp snooping log enable to enable DHCPv6 snooping logging.
Use undo ipv6 dhcp snooping log enable to disable DHCPv6 snooping logging.
DHCPv6 snooping logging is disabled.
This command enables the DHCPv6 snooping device to generate DHCPv6 snooping logs and send them to the information center. The log information helps administrators locate and solve problems. For information about the log destination and output rule configuration in the information center, see System Management Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance.
# Enable DHCPv6 snooping logging.
[Sysname] ipv6 dhcp snooping log enable
Use ipv6 dhcp snooping max-learning-num to set the maximum number of DHCPv6 snooping entries for an interface to learn.
Use undo ipv6 dhcp snooping max-learning-num to restore the default.
ipv6 dhcp snooping max-learning-num max-number
The number of DHCPv6 snooping entries for an interface to learn is not limited.
max-number: Sets the maximum number of DHCPv6 snooping entries for an interface to learn. The value range varies by device model.
The following compatibility matrixes show the value ranges for this argument on different platforms:
Series |
Models |
Product codes |
Value ranges |
WX3500X series |
· WX3510X · WX3520X · WX3540X |
· EWP-WX3510X · EWP-WX3520X · EWP-WX3540X |
· EWP-WX3510X: 1 to 11520 · EWP-WX3520X: 1 to 23040 · EWP-WX3540X: 1 to 46080 |
WX3500X-E series |
WX3508X-E |
· EWP-WX3508X-E |
· EWP-WX3508X-E: 1 to 15000 |
Series |
Models |
Product codes |
Value ranges |
WX3800X series |
· WX3820X · WX3840X |
· EWP-WX3820X · EWP-WX3840X |
· EWP-WX3820X: 1 to 23040 · EWP-WX3840X: 1 to 46080 |
When an interface learns the maximum number of DHCPv6 snooping entries, the interface stops learning DHCPv6 snooping entries. This does not affect the operation of the DHCPv6 snooping feature.
# Configure the Layer 2 Ethernet interface GigabitEthernet 1/0/1 to learn a maximum of 10 DHCPv6 snooping entries.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping max-learning-num 10
Use ipv6 dhcp snooping option interface-id enable to enable support for the interface-ID option (also called Option 18).
Use undo ipv6 dhcp snooping option interface-id enable to disable support for the interface-ID option.
Option 18 is not supported.
This command takes effect only when DHCPv6 snooping is globally enabled.
# Enable support for Option 18.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping option interface-id enable
Use ipv6 dhcp snooping option interface-id string to specify the content as the interface ID for Option 18.
Use undo ipv6 dhcp snooping option interface-id to restore the default.
ipv6 dhcp snooping option interface-id [ vlan vlan-id ] string interface-id
undo ipv6 dhcp snooping option interface-id [ vlan vlan-id ]
The DHCPv6 snooping device uses its DUID as the content for Option 18.
vlan vlan-id: Pads the interface ID for packets received from the specified VLAN. If you do not specify a VLAN, the device pads the interface ID for packets received from the default VLAN.
interface-id: Specifies a string of 1 to 128 characters as the interface ID.
# Specify company001 as the interface ID.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping option interface-id string company001
Use ipv6 dhcp snooping option remote-id enable to enable support for the remote-ID option (also called Option 37).
Use undo ipv6 dhcp snooping option remote-id enable to disable support for the remote-ID option.
Option 37 is not supported.
# Enable support for Option 37.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping option remote-id enable
Use ipv6 dhcp snooping option remote-id string to specify the content as the remote ID for Option 37.
Use undo ipv6 dhcp snooping option remote-id to restore the default.
ipv6 dhcp snooping option remote-id [ vlan vlan-id ] string remote-id
undo ipv6 dhcp snooping option remote-id [ vlan vlan-id ]
The DHCPv6 snooping device uses its DUID as the content for Option 37.
vlan vlan-id: Pads the remote ID for packets received from the specified VLAN. If you do not specify a VLAN, the device pads the remote ID for packets received from the default VLAN.
remote-id: Specifies a string of 1 to 128 characters as the remote ID.
# Specify device001 as the remote ID.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping option remote-id string device001
Use ipv6 dhcp snooping pd binding record to enable recording DHCPv6 snooping prefix entries.
Use undo ipv6 dhcp snooping pd binding record to disable recording DHCPv6 snooping prefix entries.
Recording of DHCPv6 snooping prefix entries is disabled.
This command enables DHCPv6 snooping to record IPv6 prefix-to-port information of the DHCPv6 clients (called DHCPv6 snooping prefix entries). When IP source guard (IPSG) is configured on the DHCP snooping device, IPSG can generate dynamic bindings based on the DHCP snooping prefix entries to filter out illegitimate packets.
# Enable DHCPv6 snooping prefix entries on GigabitEthernet 1/0/1.
[Sysname]interface gigabitethernet 1/0/1
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping pd binding record
ipv6 dhcp snooping rate-limit
Use ipv6 dhcp snooping rate-limit to enable DHCPv6 snooping packet rate limit on an interface and set the limit value.
Use undo ipv6 dhcp snooping rate-limit to disable DHCPv6 snooping packet rate limit.
ipv6 dhcp snooping rate-limit rate
The DHCPv6 snooping packet rate limit is disabled on an interface.
rate: Specifies the maximum rate in Kbps. The value range is 64 to 512.
This command takes effect only when DHCPv6 snooping is enabled.
The DHCPv6 packet rate limit feature enables the interface to discard DHCPv6 packets that exceed the maximum rate.
The rate configured on a Layer 2 aggregate interface applies to all members of the aggregate interface. If a member interface leaves the aggregation group, it uses the rate configured in its Ethernet interface view.
The chip-supported maximum rate is an integer multiple of eight. If you set the maximum rate to 67, the value 64 or 72 takes effect.
# Configure GigabitEthernet 1/0/1 to receive DHCPv6 packets at a maximum rate of 64 Kbps.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping rate-limit 64
Use ipv6 dhcp snooping trust to configure a port as a trusted port.
Use undo ipv6 dhcp snooping trust to restore the default state of a port.
After you enable DHCPv6 snooping, all ports are untrusted.
Specify the port facing the DHCP server as trusted and specify the other ports as untrusted so DHCP clients can obtain valid IP addresses.
# Specify GigabitEthernet 1/0/1 as a trusted port.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping trust
Use reset ipv6 dhcp snooping binding to clear DHCPv6 snooping address entries.
reset ipv6 dhcp snooping binding { all | address ipv6-address [ vlan vlan-id ] }
address ipv6-address: Clears the DHCPv6 snooping entry for the specified IPv6 address.
vlan vlan-id: Clears DHCPv6 snooping address entries for the specified VLAN. If you do not specify a VLAN, this command clears DHCPv6 snooping address entries for the default VLAN.
all: Clears all DHCPv6 snooping address entries.
# Clear all DHCPv6 snooping address entries.
<Sysname> reset ipv6 dhcp snooping binding all
Use reset ipv6 dhcp snooping packet statistics to clear DHCPv6 packet statistics for DHCPv6 snooping.
reset ipv6 dhcp snooping packet statistics [ slot slot-number ]
slot slot-number: Specifies a cloud cluster member device by its member ID. If you do not specify a member device, this command clears DHCPv6 packet statistics for the master device.
# Clear DHCPv6 packet statistics for DHCPv6 snooping.
<Sysname> reset ipv6 dhcp snooping packet statistics
Use reset ipv6 dhcp snooping pd binding to clear DHCPv6 snooping prefix entries.
reset ipv6 dhcp snooping pd binding { all | prefix prefix/prefix-length [ vlan vlan-id ] }
all: Clears all DHCPv6 snooping prefix entries.
prefix prefix/prefix-length: Clears DHCPv6 snooping entries for the specified IPv6 prefix. The value range for the prefix-length argument is 1 to 128.
vlan vlan-id: Clears DHCPv6 snooping prefix entries for the specified VLAN. The value range for the vlan-id argument is 1 to 4094.
If you do not specify any parameters, this command clears all DHCPv6 snooping prefix entries.
# Clear DHCPv6 snooping prefix entries for 1:2::/64.
<Sysname> reset ipv6 dhcp snooping pd binding prefix 1:2::/64
