03-HH3C-SRV6POLICY-MIB | 151.75 KB |
HH3C-SRV6POLICY-MIB
About this MIB
Use this MIB to configure SRv6-TE policy settings.
MIB file name
hh3c-srv6policy.mib
Notifications
hh3cSrv6PolicyBsidConflict
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.189.0.2 |
BSID assignment failure. |
Informational |
Informational |
1.3.6.1.4.1.25506.2.189.0.3 (hh3cSrv6PolicyBsidConflictClear) |
OFF |
Notification triggers
This notification is generated when the device failed to allocate the BSID for an SRv6-TE policy. Possible reasons are as follows:
The statically configured BSID for the SRv6-TE policy conflicted with the BSID dynamically assigned to another SRv6-TE policy.
BGP has dynamically allocated the same BSID to different SRv6-TE policies.
System impact
The SRv6-TE policy cannot be used for forwarding because of the BSID allocation failure.
Status control
ON
CLI: Use the snmp-agent trap enable srv6-policy command.
OFF
CLI: Use the undo snmp-agent trap enable srv6-policy command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.189.1.2.1.1 (hh3cSrv6PolicyColor) |
Color value of the SRv6-TE policy. |
hh3cSrv6PolicyColor hh3cSrv6PolicyEndPoint |
Unsigned32 |
Unsigned32 (0..4294967295) |
1.3.6.1.4.1.25506.2.189.1.2.1.2 (hh3cSrv6PolicyEndPoint) |
Destination address of the SRv6-TE policy. |
InetAddressIPv6 |
OCTET STRING (16) |
1.3.6.1.4.1.25506.2.189.1.2.1.4 (hh3cSrv6PolicyBsid) |
BSID of the SRv6-TE policy. |
InetAddressIPv6 |
OCTET STRING (16) |
1.3.6.1.4.1.25506.2.189.1.2.1.7 (hh3cSrv6PolicyBsidFailReason) |
Cause for the BSID assignment failure. |
OCTET STRING |
OCTET STRING (SIZE (0..255)) |
1.3.6.1.4.1.25506.2.189.1.2.1.8 (hh3cSrv6PolicyBsidConflictState) |
BSID state |
INTEGER |
inConflict(1),, conflictResolved(2) |
Recommended action
To resolve the issue:
1.On the device that generated this notification, execute the display segment-routing ipv6 te policy command to view the BSID values of all SRv6-TE policies.
2.If there is an SRv6-TE policy using the same BSID as the alarming SRv6-TE policy, use the display segment-routing ipv6 locator command to view the valid BSID value range and then use the binding-sid command to edit the BSID for the SRv6-TE policy.
3.After the SRv6-TE policy is bound to a new BSID, execute the display segment-routing ipv6 te policy command to view the value of Request state field. If the value is Succeeded, the BSID request has succeeded. If the value is not Succeeded, go to the next step.
4.Collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.189.0.3 |
BSID assignment failure issue is fixed. |
Informational |
Informational |
N/A (N/A) |
OFF |
This notification is generated when the BSID allocation failure alarm for an SRv6-TE policy is cleared.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
InetAddressIPv6 |
OCTET STRING (16) |
InetAddressIPv6 |
OCTET STRING (16) |
OCTET STRING |
BSID state |
INTEGER |
Recommended action
No action is required.
hh3cSrv6PolicyDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.189.0.4 |
The SRv6-TE policy state goes down. |
Informational |
Informational |
1.3.6.1.4.1.25506.2.189.0.5 (hh3cSrv6PolicyDownClear) |
OFF |
This notification is generated when the state of an SRv6-TE policy changes from Up to Down.
The SRv6-TE policy has been shut down.
The candidate path of the SRv6-TE policy became invalid.
System impact
The SRv6-TE policy cannot forward traffic.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
InetAddressIPv6 |
OCTET STRING (16) |
1.3.6.1.4.1.25506.2.189.1.2.1.6 (hh3cSrv6PolicyDownReason) |
Cause of the SRv6-TE policy down event. |
OCTET STRING |
OCTET STRING (SIZE (0..51)) |
Recommended action
1.Execute the display segment-routing ipv6 te policy command to display SRv6-TE policy information.
- Check the value of the Request state field. If it is not Succeeded, it indicates that the BSID request failed or is conflicted. In this case, delete the current BSID and re-execute the binding-sid command to configure a new BSID or obtain a dynamic BSID.
- Check the value of the AdminStatus field. If it is Down, it indicates that the shutdown command has been executed for the SRv6-TE policy. You need to execute the undo shutdown command to bring up the SRv6-TE policy.
- Check the value of the BFD trigger path-down field. If it is Enabled, it indicates that the function of BFD down triggering the SRv6-TE policy down is enabled. Disable this function by using the bfd trigger path-down disable command or ensure that the BFD session is normal.
- If the values of the previous fields are all correct, go to the next step.
2.Execute the display segment-routing ipv6 te policy last-down-reason command to display the reason for the last down event of the SRv6-TE policy. Check the value of the Down reason field.
- Admin down—The SRv6-TE policy has been shut down by using the shutdown command. Please execute the undo shutdown command to bring up the SRv6-TE policy.
- No Endpoint—The destination IP address of the SRv6-TE policy does not exist. Please execute the color end-point command to reconfigure a valid destination address. Make sure the destination address is reachable.
- No candidate path—The candidate path does not exist. Please create the candidate path.
- No valid candidate path—The candidate path does not have a SID list. Please specify a SID list for the SRv6-TE policy.
- Candidate path invalid segment list—All SID lists in the candidate path are down. Please check the forwarding path, repair the physical link, or reconfigure a valid SID list.
- Policy unconfigured—The SRv6-TE policy is being deleted. Please collect log messages and alarm information, and then contact Technical Support.
- Unknown error—The SRv6-TE policy has an unknown error. Please collect log messages and alarm information, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.189.0.5 |
The SRv6-TE policy down event is cleared. |
Informational |
Informational |
N/A (N/A) |
OFF |
This notification is generated when the state down alarm for an SRv6-TE policy is cleared.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
InetAddressIPv6 |
OCTET STRING (16) |
Recommended action
hh3cSrv6PolicyResExdUppLimit
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.189.0.6 |
Resource usage exceeds the upper limit. |
Informational |
Informational |
1.3.6.1.4.1.25506.2.189.0.7 (hh3cSrv6PolicyResExceedClear) |
OFF |
This notification is generated when the resource usage of the SRv6-TE policy exceeds the upper limit, for example, the number of SRv6-TE policies or the number of segment lists exceeds the limit.
System impact
SRv6-TE policies might not be able to forward traffic correctly if new SRv6-TE policies or segment lists are created.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.189.1.1.1.1 (hh3cSrv6PolicyResourceType) |
Resource type |
INTEGER |
unknown(1), , srv6Policy(2),, srv6PolicySegmentList(3),, srv6PolicyGroup(4), , srv6PolicyFwdPath(5) |
1.3.6.1.4.1.25506.2.189.1.1.1.2 (hh3cSrv6PolicyResCurrentCnt) |
Number of resources. |
Unsigned32 |
Unsigned32 |
1.3.6.1.4.1.25506.2.189.1.1.1.3 (hh3cSrv6PolicyResUpperLimit) |
Upper threshold of resources. |
Unsigned32 |
Unsigned32 (1..100) |
1.3.6.1.4.1.25506.2.189.1.1.1.4 (hh3cSrv6PolicyResLowerLimit) |
Lower threshold of resources. |
Unsigned32 |
1.3.6.1.4.1.25506.2.189.1.1.1.5 (hh3cSrv6PolicyResourceTotalCnt) |
Maximum number of available resources. |
Unsigned32 |
Unsigned32 |
Recommended action
1.On the device that generated this notification, execute the display segment-routing ipv6 te policy statistics command to display SRv6 TE policy statistics.
- If the value of the Used resources field in the SRv6-TE policy resource information is the same as the value of the Max resources field, the number of SRv6-TE policies might have exceeded the limit. In this case, delete the SRv6-TE policies not needed.
- If the value of the Used resources field in the SID list resource information is the same as the value of the Max resources field, the number of segment lists might have exceeded the limit. In this case, delete the segment lists not needed.
- If none of the values of the previous fields exceeds the limit, go to the next step.
2.On the device that generated this notification, execute the display system internal segment-routing ipv6 te policy status command in probe view and the display segment-routing ipv6 te segment-list command.
- If the number of SID nodes exceeds the value of the MaxSIDs field in the output from the display system internal segment-routing ipv6 te policy status command, delete the SIDs not needed from the segment list.
- If the number of SIDs exceeds the value of the Nodes field in the output from the display segment-routing ipv6 te segment-list command, delete the SIDs not needed in the segment list.
- If the alarm is not removed, go to the next step.
3.Collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.189.0.7 |
Resource usage drops below the lower limit. |
Informational |
Informational |
N/A (N/A) |
OFF |
This notification is generated when the resource usage of the SRv6-TE policy drops below the lower limit, for example, the number of SRv6-TE policies or the number of segment lists drops below the lower limit.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Resource type |
INTEGER |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Unsigned32 |
Recommended action
hh3cSrv6PathDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.189.0.8 |
Candidate path down. |
Informational |
Informational |
N/A (N/A) |
OFF |
This notification is generated when the state of the primary or backup candidate path of an SRv6-TE policy changes.
System impact
Traffic will be switched from the primary candidate path to a backup candidate path. If no valid backup candidate path is available, traffic forwarding will fail.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.189.1.3.1.1 (hh3cSrv6PolicyPathColor) |
Value of the color that associates an SRv6-TE policy with certain intent. The color is used to distinguish SRv6-TE policies that have the same source and destination nodes. |
hh3cSrv6PolicyColor hh3cSrv6PolicyEndPoint hh3cSrv6PolicyPathProto hh3cSrv6PolicyPathInst hh3cSrv6PolicyPathOri hh3cSrv6PolicyPathDis |
Unsigned32 |
1.3.6.1.4.1.25506.2.189.1.3.1.2 (hh3cSrv6PolicyPathEndPoint) |
The endpoint (destination) of the SRv6-TE policy. |
InetAddressIPv6 |
OCTET STRING (16) |
1.3.6.1.4.1.25506.2.189.1.3.1.3 (hh3cSrv6PolicyPathProto) |
Protocol that originates or signals the candidate path. |
INTEGER |
pcep(10),, bgp(20),, cli(30) |
1.3.6.1.4.1.25506.2.189.1.3.1.4 (hh3cSrv6PolicyPathInst) |
BGP instance number when the candidate path is originated by BGP. |
Integer32 |
Integer32(0..65535) |
1.3.6.1.4.1.25506.2.189.1.3.1.5 (hh3cSrv6PolicyPathOri) |
Originator, the identifier of the node that instantiated or signaled the candidate path on the headend. |
OCTET STRING |
OCTET STRING(1-63) |
1.3.6.1.4.1.25506.2.189.1.3.1.6 (hh3cSrv6PolicyPathDis) |
Discriminator, which uniquely identifies a candidate path from a specific protocol. |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.189.1.3.1.7 (hh3cSrv6PolicyPathPref) |
Preference of the candidate path. |
Unsigned32 |
Unsigned32(1..65535) |
1.3.6.1.4.1.25506.2.189.1.3.1.8 (hh3cSrv6PolicyPathPreviousRole) |
Role of the candidate path: primary or backup. |
OCTET STRING |
OCTET STRING (SIZE (0..31)) |
1.3.6.1.4.1.25506.2.189.1.3.1.9 (hh3cSrv6PolicyPathDownReason) |
The cause for the candidate path down event. |
OCTET STRING |
Recommended action
hh3cSrv6PolicySeglistDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.189.0.9 |
Segment list down. |
Informational |
Informational |
1.3.6.1.4.1.25506.2.189.0.10 (hh3cSrv6SeglistDownclear) |
OFF |
This notification is generated when the state of a SID list used by the candidate path of an SRv6-TE policy becomes down.
System impact
Traffic will be switched to another SID list in the candidate path. If no other SID list exists in the candidate path, the traffic will be switched to a backup candidate path. If no valid backup candidate path is available, traffic forwarding will fail.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.189.1.4.1.1 (hh3cSrv6PolicySeglistColor) |
hh3cSrv6PolicyColor hh3cSrv6PolicyEndPoint hh3cSrv6PolicyPathProto hh3cSrv6PolicyPathInst hh3cSrv6PolicyPathOri hh3cSrv6PolicyPathDis hh3cSrv6PolicySeglistId |
Unsigned32 |
1.3.6.1.4.1.25506.2.189.1.4.1.2 (hh3cSrv6PolicySeglistEndPoint) |
InetAddressIPv6 |
OCTET STRING (16) |
1.3.6.1.4.1.25506.2.189.1.4.1.3 (hh3cSrv6PolicySeglistPathProto) |
INTEGER |
1.3.6.1.4.1.25506.2.189.1.4.1.4 (hh3cSrv6PolicySeglistPathInst) |
Integer32 |
1.3.6.1.4.1.25506.2.189.1.4.1.5 (hh3cSrv6PolicySeglistPathOri) |
OCTET STRING |
1.3.6.1.4.1.25506.2.189.1.4.1.6 (hh3cSrv6PolicySeglistPathDis) |
Unsigned32 |
1.3.6.1.4.1.25506.2.189.1.4.1.7 (hh3cSrv6PolicySeglistId) |
ID of the segment list. |
Unsigned32 |
Unsigned32 (1..4294967295) |
1.3.6.1.4.1.25506.2.189.1.4.1.9 (hh3cSrv6PolicySeglistStatus) |
Status of the segment list. |
OCTET STRING |
1.3.6.1.4.1.25506.2.189.1.4.1.10 (hh3cSrv6PolicySeglistDownReason) |
The cause for the segment list down event. |
OCTET STRING |
Recommended action
hh3cSrv6SeglistDownClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.189.0.10 |
Segment list down notification was cleared. |
Informational |
Informational |
N/A (N/A) |
OFF |
This notification is generated when the SID list down alarm for an SRv6-TE policy is cleared.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
InetAddressIPv6 |
OCTET STRING (16) |
INTEGER |
Integer32 |
OCTET STRING |
Unsigned32 |
Unsigned32 |
OCTET STRING |
Recommended action
