- 05-Layer 2—LAN Switching Command Reference
- 01-Hardware compatibility with Layer 2 and Layer 3 Ethernet interfaces
- 02-MAC address table commands
- 03-Ethernet link aggregation commands
- 04-Port isolation commands
- 05-VLAN commands
- 06-VLAN termination commands
- 07-Loop detection commands
- 08-Spanning tree commands
- 09-LLDP commands
- 10-Layer 2 forwarding commands
| 00-Preface | 109.42 KB |
Preface
This command reference covers the commands for configuring Layer 2 technologies and features in a LAN switched network.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
