| 02-Removable Components | 5.97 MB |
2 Removable components
RFUs
RFU-360-G
View
Figure2-1 RFU-360-G view
(1) Captive screw |
(2) Management Ethernet port |
(3) Cloud cluster management SFP+ fiber port |
(4) USB port |
(5) Reset button (RESET) |
(6) Locking clip |
(7) Ejector lever |
(8) Console port |
(9) DIAG button |
LEDs
Figure2-2 RFU-360-G LEDs
(1) Management Ethernet copper port LED |
(2) Cloud cluster management SFP+ fiber port LED |
(3) System status LED (SYS) |
(4) RFU active/standby status LED (ACT) |
(5) Fan tray status LED (FAN) |
Table2-1 LED description
LED |
Status |
System LED (SYS) |
Flashing green (eight times per second) |
The router is in BootWare stage. |
Steady green |
The router is in Kernel stage, including Eshell stage. |
Flashing green (once per second) |
The Comware system is starting up or is operating correctly. |
Flashing yellow (once per second) |
Memory test failed in BootWare stage. |
Flashing yellow (eight times per second) |
The extended BootWare segment does not exist. |
Steady yellow |
The boot.bin file does not exist. |
Off |
No power input, or an exception has occurred. |
Steady green |
The RFU is in active mode. |
The router is performing an active/standby RFU switchover. |
Off |
The RFU is in standby mode. |
Steady green |
Both fan trays are operating correctly. |
One fan tray is operating correctly and the other one is not present. |
Steady yellow |
A minimum of one fan try is faulty. |
Off |
Both fan trays are not present. |
Steady green |
A 10 Gbps link is present on the port. |
Flashing green |
The port is sending or receiving data at 10 Gbps. |
Steady yellow |
A 1000 Mbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 1000 Mbps. |
Off |
No link is present on the port. |
Steady green |
Flashing green |
Steady yellow |
A 10 or 100 Mbps link is present on the port. |
Flashing yellow |
The port is sending or receiving data at 10 or 100 Mbps. |
Off |
Ports
Table2-2 Port specifications
Port type |
Specification |
Console port |
1 |
GE management port |
1 |
1 |
USB port |
1 |
DIAG button |
1 |
Technical specifications
Table2-3 Technical specifications
Item |
Specification |
Net weight |
1.9 kg (4.19 lb) |
Dimensions (H × W × D) |
42.6 × 375 × 227 mm (1.68 × 14.76 × 8.94 in) |
Max power consumption |
103.10 W |
Memory |
8 GB DDR4 |
Flash |
4 GB |
RFU-560-G
View
Figure2-3 RFU-560-G view
(1) Captive screw |
(4) USB port |
(6) Locking clip |
(7) Ejector lever |
(8) Console port |
(9) DIAG button |
LEDs
Figure2-4 RFU-560-G LEDs
Table2-4 LED description
LED |
Status |
System LED (SYS) |
Steady green |
Steady yellow |
Off |
Steady green |
Off |
Steady green |
Steady yellow |
Off |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Steady green |
Flashing green |
Steady yellow |
Flashing yellow |
Off |
Ports
Table2-5 Port specifications
Port type |
Specification |
Console port |
1 |
1 |
1 |
USB port |
1 |
DIAG button |
1 |
Table2-6 Technical specifications
Item |
Specification |
Net weight |
1.95 kg (4.30 lb) |
146.80 W |
Memory |
16 GB DDR4 |
Flash |
4 GB |
FIP modules
FIP-60-G
View
Figure2-5 FIP-60-G view
(1) Captive screw |
(2) HMIC-F interface module slot 1 |
(3) HMIC-F interface module slot 2 |
(4) Ejector lever |
LEDs
Figure2-6 FIP-60-G LEDs
(1) RUN LED |
Table2-7 LED description
LED |
Status |
RUN LED |
The module is being initialized. |
Steady green |
The module is operating correctly. |
Steady red |
The module failed to be initialized. |
Off |
The module is not identified or has been removed. |
Ports
Port type |
Specification |
HMIC-F interface module slot |
2 |
Table2-9 Technical specifications
Item |
Specification |
Net weight |
0.88 kg (1.94 lb) |
19.8 × 375 × 228 mm (0.78 × 14.76 × 8.98 in) |
0.59 W |
Compatibility
Table2-10 shows the compatibility between FIP modules and routers, where × indicates that the FIP module is not compatible with the router model and √ indicates that the FIP module is compatible with the router model.
Table2-10 Compatibility between the FIP module and routers
FIP model |
SR6608-M |
SR6608-F |
FIP-60-G |
Interface modules
Weights, dimensions, and power consumptions
Table2-11 Weights, dimensions, and power consumptions
Module model |
Net weight |
RT-HMIC-CQ1F |
0.75 kg (1.65 lb) |
35 W |
19.8 × 186 × 228 mm (0.78 × 7.32 × 8.98 in) |
RT-HMIC-XP10 |
0.75 kg (1.65 lb) |
28 W |
RT-HMIC-XP4 |
0.60 kg (1.32 lb) |
8.50 W |
RT-HMIC-GP20 |
0.75 kg (1.65 lb) |
30 W |
RT-HMIC-GP10 |
0.65 kg (1.43 lb) |
18.50 W |
RT-HMIC-GT8 |
0.64 kg (1.41 lb) |
10.00 W |
RT-HMIC-SP4 |
0.66 kg (1.46 lb) |
16.50 W |
RT-HMIC-CLP2 |
0.66 kg (1.46 lb) |
18 W |
RT-HMIC-ET16 |
0.65 kg (1.43 lb) |
8 W |
RT-HMIC-CNDE-SJK |
0.75 kg (1.65 lb) |
16 W |
RT-HMIC-ESPA |
0.75 kg (1.65 lb) |
24 W |
RT-HMIC-GT8-F |
0.32 kg (0.71 lb) |
10.15 W |
19.8 × 159 × 176 mm (0.78 × 6.26 × 6.93 in) |
RT-HMIC-GP8-F |
0.32 kg (0.71 lb) |
12.03 W |
RT-HMIC-XP2-F |
0.30 kg (0.71 lb) |
9.64 W |
RT-HMIC-SP2-F |
0.30 kg (0.71 lb) |
8.93 W |
RT-SSD-960G |
0.50 kg (1.10 lb) |
11.00 W |
Interface modules
The SR6608-M router supports HMIC interface modules and SSD modules. The SR6608-F router supports only HMIC-F interface modules. For more information about the views, LEDs, specifications, and compatibility of the interface modules, see H3C SR6608-M[F] Router Interface Module Guide.
Power supplies
The router supports AC power supplies, DC power supplies, and mix of AC and DC power supplies. You can install a maximum of four power supplies on the router. The power supplies can be hot swapped and configured in redundancy. You can install only one power supply or multiple power supplies for 1+1, 1+2, 2+1, 3+1, or 2+2 power supply redundancy. Only the 1+1 and 2+2 redundancy modes support dual power supply circuits.
The router supports only mix of 450 W AC and DC power supplies.
PSR250-12A
View
Figure2-7 PSR250-12A power supply view
(1) Latch |
(2) Handle |
(3) Power receptacle |
LEDs
Figure2-8 PSR250-12A power supply LEDs
(1) Status LED |
Table2-12 LED description
LED |
Status |
Status LED |
Steady green |
The power supply is operating correctly. |
Flashing green |
The power supply has normal power input but has not been turned on. |
Steady red |
The power supply is faulty. |
Flashing red/green |
An alarm is present on the power supply. |
Flashing red |
This power supply does not have power input but the other power supply has power input. |
Off |
No power is present. |
Table2-13 Technical specifications
Item |
Specification |
Net weight |
0.64 kg (1.41 lb) |
40 × 51 × 221 mm (1.57 × 2.01 × 8.70 in) |
Rated input voltage |
· 100 to 240 VAC @ 50 or 60 Hz · 240 VDC |
Max input current |
· 4 A (AC input) · 2 A (DC input) |
Max power |
250 W |
PSR450-12A
View
Figure2-9 PSR450-12A power supply view
(1) Latch |
(2) Handle |
LEDs
Figure2-10 PSR450-12A power supply LEDs
(1) Status LED |
Table2-14 LED description
LED |
Status |
Status LED |
Steady green |
Flashing green |
Steady red |
Flashing red |
Off |
Table2-15 Technical specifications
Item |
Specification |
Net weight |
0.65 kg (1.43 lb) |
Max input current |
· 6 A (AC input) · 3 A (DC input) |
Max power |
450 W |
PSR450-12D-F
View
Figure2-11 PSR450-12D-F power supply view
(1) Latch |
(2) Handle |
LEDs
Figure2-12 PSR450-12D-F power supply LEDs
(1) Status LED |
Table2-16 LED description
LED |
Status |
Status LED |
Steady green |
Flashing green |
Steady red |
Flashing red |
Off |
Table2-17 Technical specifications
Item |
Specification |
Net weight |
0.68 kg (1.50 lb) |
–48 to –60 VDC |
Max input current |
12 to 10 A |
Max power |
450 W |
Compatibility
Table2-8 shows the compatibility between power supplies and routers, where × indicates that the power supply is not compatible with the router model and √ indicates that the power supply is compatible with the router model.
Table2-18 Compatibility between the FIP module and routers
Power supply model |
SR6608-M |
SR6608-F |
PSR250-12A |
PSR450-12A |
PSR450-12D-F |
Fan trays
FAN-80B-2-C
View
Figure2-13 FAN-80B-2-C fan tray view
(1) Handle |
LEDs
Figure2-14 FAN-80B-2-C fan tray LEDs
(1) Status LED |
Table2-19 LED description
LED |
LED status |
RUN |
Steady green |
The fan tray is operating correctly. |
Steady yellow |
The fan tray is faulty. |
Off |
No fan tray is present or no power is present on the fan tray. |
Table2-20 Technical specifications
Item |
Specification |
Net weight |
1.06 kg (2.34 lb) |
171 × 136 × 93 mm (6.73 × 5.35 × 3.66 in) |
90 W |
Number of fans |
2 |
Automatic speed adjustment |
Supported |
Anti-misinsertion |
Supported |
Hot swapping |
Supported |
