H3C SR6608-M Router Hardware Information and Specifications-6W102
HomeSupportRoutersSR6600-M SeriesProduct LiteratureHardware Information & SpecificationsH3C SR6608-M Router Hardware Information and Specifications-6W102
01-About the Router
01-About the Router 2.08 MB
1 About the router
Unless otherwise stated, routing and forwarding units (RFUs), FIP modules, HMIC-F interface modules, HMIC interface modules, and SSD modules are collectively referred to as "modules" in this document.
Chassis views
The figures in this section are for illustration only.
SR6608-M
Figure1-1 SR6608-M front panel
(1) Interface module slot 2
(2) Interface module slot 4
(3) Interface module slot 3
(4) Interface module slot 5
(5) RFU slot 0
(6) RFU slot 1
(7) Power supply slot PWR3
(8) Power supply slot PWR2
(9) Power supply slot PWR1
(10) Power supply slot PWR0
(11) Interface module slot 7
(12) Interface module slot 9
(13) Interface module slot 6
(14) Interface module slot 8
Figure1-2 SR6608-M rear panel
(1) Fan tray slot 0
(2) Fan tray slot 1
(3) Grounding screw
SR6608-F
Figure1-3 SR6608-F front panel
(1) FIP module slot 2
(2) FIP module slot 3
(3) RFU slot 0
(4) RFU slot 1
(5) Power supply slot PWR3
(6) Power supply slot PWR2
(7) Power supply slot PWR1
(8) Power supply slot PWR0
(9) FIP module slot 5
(10) FIP module slot 4
Figure1-4 SR6608-F rear panel
(1) Fan tray slot 0
(2) Fan tray slot 1
(3) Grounding screw
Slot arrangement and interface numbering
Slot arrangement
Table1-1 Slot arrangement on the router
Model
Slot arrangement
SR6608-M
SR6608-F
FIP-60-G
: RFU slot
: HMIC interface module or SSD module slot
: FIP module slot
: HMIC-F interface module slot
Interface numbering
Conventions
The interfaces (except the management Ethernet interface) on the router are numbered in the interface-type X/Y/Z format. The management Ethernet interface number is M-GigabitEthernet 0/0/0.
·     interface-typeType of the interface such as GigabitEthernet and Ten-GigabitEthernet.
·     X—Number of the slot where the module resides on the router, as shown in Table1-1.
·     Y—Subslot number. For SR6608-M, the slot number is fixed at 0. For SR6608-F, Y represents the slot number for the HMIC-F interface module on the FIP module, which is fixed to 1 or 2.
·     Z—Number of the interface on the module, starting from 0.
For the SR6608-M device, an HMIC-XP4 interface module is installed in slot 6 of the router. Fixed SFP+ fiber ports on the interface module are numbered Ten-GigabitEthernet 6/0/0 through Ten-GigabitEthernet 6/0/3, respectively.
For the SR6608-M device, an RFU-560-G is installed in slot 0 of the router. The fixed SFP+ fiber port on the RFU-560-G is numbered Ten-GigabitEthernet 0/0/0.
For the SR6608-F device, a FIP-60-G module is installed in slot 2 of the device and an HMIC-XP2-F interface module is installed in slot 1 of the FIP-60-G module. Fixed SFP+ fiber ports on the interface module are numbered Ten-GigabitEthernet 2/1/0 through Ten-GigabitEthernet 2/1/1, respectively.
Technical specifications
Table1-2 SR6608-M[F] technical specifications
Item
SR6608-M
SR6608-F
Dimensions (H × W × D) (excluding rubber feet and mounting brackets)
175 × 440 × 330 mm (6.89 × 17.32 × 12.99 in)
Chassis weight (including mounting brackets and filler panels)
11.5 kg (25.35 lb)
11.42 kg (25.18 lb)
Device weight
Weights of the chassis (including mounting brackets and filler panels), modules, power supplies, fan trays, and other removable components
System power consumption
Total power consumption of all modules and fan trays
Heat dissipation
Heat dissipation of the router per hour is 0.9 × (total power consumption of all modules and fan trays)/0.9 × 3.4121
RFU slots
2
2
FIP module slots
N/A
4
HMIC interface module/SSD module slots
8
N/A
Fan tray slots
2
2
Power supply slots
4
4
Operating temperature
0°C to 45°C (32°F to 113°F)
Operating humidity
5% RH to 95% RH, noncondensing
Heat dissipation is measured in BTU/h. 1 W equals 3.4121 BTU/h.
