03-Typical Configuration Example
HomeSupportRoutersCR16000-M SeriesConfigure & DeployConfiguration ExamplesH3C CR16000-M Routers Configuration Examples All-In-One-R838x-6W10103-Typical Configuration Example
Table of Contents
Related Documents
30-H3C_Software_Upgrade_Examples
30-H3C_Software_Upgrade_Examples 199.80 KB
Introduction
This document provides software upgrade examples. In this document, examples of upgrading software from the CLI use the non-ISSU method.
The following information is provided based on the assumption that you have basic knowledge of software upgrade, FTP, and TFTP.
Upgrading software from the CLI
Example: Using the device as a TFTP client to upgrade software
As shown in Figure 1, use TFTP to download a software upgrade file from a TFTP server to upgrade the device.
Figure 1 Network diagram
When you upgrade software, follow these restrictions and guidelines:
·     Make sure the device has sufficient storage space for the upgrade file. If the device does not have sufficient storage space, delete unused files by using the delete /unreserved file-url command.
·     Save the running configuration before the upgrade for the configuration to survive a reboot.
·     If the device has two MPUs, you must upgrade both MPUs for the device to operate correctly.
Procedures
1.     Configure the TFTP server:
# Assign the IP address 192.168.100.14/24 to the TFTP server. (Details not shown.)
# Start the TFTP server and specify a working directory. (Details not shown.)
2.     Upgrade the device:
# Assign an IP address to Ten-GigabitEthernet 3/1/0. Make sure the device can reach the TFTP server.
[Device] interface Ten-GigabitEthernet3/1/0
[Device-Ten-GigabitEthernet3/1/0] ip address 192.168.100.66 255.255.255.0
[Device-Ten-GigabitEthernet3/1/0] quit
[Device] quit
# Verify that the device can ping the TFTP server.
<Device> ping 192.168.100.14
Ping 192.168.100.14 (192.168.100.14): 56 data bytes, press CTRL_C to break
56 bytes from 192.168.100.14: icmp_seq=0 ttl=64 time=10.701 ms
56 bytes from 192.168.100.14: icmp_seq=1 ttl=64 time=2.678 ms
56 bytes from 192.168.100.14: icmp_seq=2 ttl=64 time=2.282 ms
56 bytes from 192.168.100.14: icmp_seq=3 ttl=64 time=1.617 ms
56 bytes from 192.168.100.14: icmp_seq=4 ttl=64 time=1.701 ms
--- Ping statistics for 192.168.100.14 ---
round-trip min/avg/max/std-dev = 1.617/3.796/10.701/3.474 ms
# Save the running configuration.
<Device> save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
# Identify MPUs on the device.
<Device> display device
The output shows that the device has two MPUs: one active MPU in slot 0 and one standby MPU in slot 1. You must upgrade both MPUs.
# Use TFTP to download the upgrade file from the TFTP server to the root directory of the storage medium on the active MPU.
<Device> tftp 192.168.100.14 get new.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 70.7M  100 70.7M    0     0  1193k      0  0:00:50  0:00:50 --:--:-- 1127k
# Specify the upgrade file as the main startup image file for both MPUs.
<Device> boot-loader file boot cfa0:/new.ipe slot 0 main
Verifying the IPE file and the images............Done.
Images in IPE:
  BOOT-test.bin
  SYSTEM-test.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to target slot.
File cfa0:/BOOT-test.bin already exists on slot 0.
File cfa0:/SYSTEM-test.bin exists on slot 0.
Overwrite the existing files? [Y/N]:Y
Decompressing file boot.bin to cfa0:/BOOT-test.bin........................Done.
Decompressing file system.bin to cfa0:/SYSTEM-test.bin........................Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 0.
<Device> boot-loader file boot cfa0:/BOOT-test.bin system cfa0:/SYSTEM-test.bin slot 1 main
This command will set the main software images. Continue? [Y/N]:y
Copying file cfa0:/BOOT-test.bin to slot1#cfa0:/BOOT-test.bin...........................
.........................................................Done.
Copying file cfa0:/SYSTEM-test.bin to slot1#cfa0:/SYSTEM-test.bin.....................
ftware images at the next reboot on slot 1.
# Specify the current startup image file as the backup startup image file for both MPUs. This setting ensures that the device can start up if the upgrade file is corrupt or not correct.
<Device> boot-loader file boot cfa0:/BOOT-old.bin system cfa0:/SYSTEM-old.bin slot 0 backup
This command will set the backup startup software images. Continue? [Y/N]:y
Verifying the file cfa0:/BOOT-old.bin on slot 0............Done.
Verifying the file cfa0:/SYSTEM-old.bin on slot 0.....................................
The images that have passed all examinations will be used as the backup startup software images at the next reboot on slot 0.
<Device> boot-loader file boot cfa0:/BOOT-old.bin system cfa0:/SYSTEM-old.bin slot 1 backup
Copying file cfa0:/BOOT-old.bin to slot1#cfa0:/BOOT-old.bin............................
Copying file cfa0:/SYSTEM-old.bin to slot1#cfa0:/SYSTEM-old.bin.........................
The images that have passed all examinations will be used as the backup startup software images at the next reboot on slot 1.
# Reboot the device.
<Device> reboot
Start to check configuration with next startup configuration file, please wait..
.......DONE!
1.     Verify that the software has been upgraded.
<Device> display version
H3C Comware Software, Version 7.1.075, R8385P09
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C CR16000-M16 uptime is 0 weeks, 5 days, 17 hours, 14 minutes
Last reboot reason : USER reboot
Boot image: cfa0:/BOOT-test.bin
Boot image version: 7.1.075, Release R8385P09
  Compiled Sep 05 2022 16:00:00
System image: cfa0:/SYSTEM-test.bin
System image version: 7.1.075, Release R8385P09
---- More ----
2.     Verify that the software images on the MPUs are the same:
# Display the current software images and startup software images on the active MPU.
<Device> display boot-loader slot 0
Software images on slot 0:
Current software images:
  cfa0:/BOOT-test.bin
Main startup software images:
  cfa0:/BOOT-test.bin
Backup startup software images:
  cfa0:/BOOT-old.bin
# Display the current software images and startup software images on the standby MPU.
<Device> display boot-loader slot 1
Software images on slot 1:
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-old.bin
Configuration files
 port link-mode route
Example: Using the device as an FTP client to upgrade software
As shown in Figure 2, use FTP to download a software upgrade file from an FTP server to upgrade the device.
Figure 2 Network diagram
·     The FTP username, password, and file name settings must be the same between the FTP server and the device.
Procedures
1.     Configure the FTP server:
# Assign the IP address 192.168.100.14/24 to the FTP server. (Details not shown.)
# Start the FTP server and specify a working directory. (Details not shown.)
# Add a local user account. (Details not shown.)
# Set the username to 123456 and the password to 123456 for the user account. (Details not shown.)
# Assign an IP address to Ten-GigabitEthernet 3/1/0. Make sure the device can reach the FTP server.
[Device] interface ten-gigabitethernet3/1/0
[Device] quit
# Verify that the device can ping the FTP server.
<Device> save
# Use the username 123456 and the password 123456 to log in to the FTP server.
<Device> ftp 192.168.100.14
User (192.168.100.14:(none)): 123456
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
# Use FTP to download the upgrade file from the FTP server to the root directory of the storage medium on the active MPU.
ftp> get new.ipe
227 Entering passive mode (192,168,100,14,8,86)
125 Using existing data connection
226 Closing data connection; File transfer successful.
70445056 bytes received in 53.6 seconds (1.25 Mbyte/s)
ftp> quit
The output shows that the switch has two MPUs: one active MPU in slot 0 and one standby MPU in slot 1.
Images in IPE:
  BOOT-test.bin
  SYSTEM-test.bin
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
<Device> reboot
.......DONE!
---- More ----
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-old.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-old.bin
Configuration files
Example: Using the device as an FTP server to upgrade software
As shown in Figure 3, enable the FTP server and configure a local user account on the device to provide FTP service. Use FTP to upload a software upgrade file from an FTP client to upgrade the device.
Figure 3 Network diagram
·     You must set the file transfer mode to binary.
Procedures
# Add a local user account. Set the username to abc and the password to 123456.
[Device] local-user abc
[Device-luser-abc] password simple 123456
# Assign the network-admin user role to the user account.
[Device-luser-abc] authorization-attribute user-role network-admin
# Remove the default network-operator user role.
[Device-luser-abc] undo authorization-attribute user-role network-operator
# Assign FTP service to the user account.
[Device-luser-abc] service-type ftp
[Device-luser-abc] quit
# Enable the FTP server.
[Device] ftp server enable
[Device] quit
<Device> save
2.     Configure the FTP client:
# Assign the IP address 192.168.100.14/24 to the FTP client. Make sure the FTP client can reach the device. (Details not shown.)
# Use the username abc and the password 123456 to log in to the FTP server.
C:\Documents and Settings\Administrator> ftp 192.168.100.66
Connected to 192.168.100.66.
220 FTP service ready.
User (192.168.100.66:(none)): abc
331 Password required for abc.
Password:
230 User logged in.
# Access the directory that contains the upgrade file.
ftp> lcd E:\
Local directory now E:\
# Set the file transfer mode to binary.
ftp> binary
200 TYPE is now 8-bit binary
# Transfer the upgrade file to the root directory of the storage medium on the FTP server.
ftp> put new.ipe
200 PORT command successful
150 Connecting to port 2903
226 File successfully transferred
ftp: 70445056 sent in 1.05Seconds 67282.77Kbytes/sec.
# Verify that the image file is saved on the FTP server.
ftp> ls new.ipe
150 Connecting to port 3391
new.ipe
226 1 matches total
ftp: 24 bytes received in 0.00Seconds 24000.00Kbytes/sec.
# Close the FTP connection.
ftp> bye
3.     Upgrade the device:
Images in IPE:
  BOOT-test.bin
  SYSTEM-test.bin
<Device> reboot
.......DONE!
---- More ----
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-old.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-old.bin
Configuration files
local-user abc class manage
 password hash $h$6$YMVbbwFL/vviWcQu$+CuTbYCehNZtZo5RCXiadpYbXYWa2omt5TUtEh3UPCg3fZjxYCp5WzbuE2GoowVi2YA/BK+mnSZJZqi5jRDuCg==
 service-type ftp
 ftp server enable
Upgrading software from the BootWare menu
As shown in Figure 4, the device cannot start up.
Use TFTP to upgrade the device from the BootWare menu.
Figure 4 Network diagram
When you upgrade software, make sure the device has sufficient storage space for the upgrade file. If the device does not have sufficient storage space, delete unused files by using the delete /unreserved file-url command.
Procedures
1.     Configure the host:
# Use a console cable to connect the console port on the standby MPU to the configuration terminal, and use a network cable to connect the management port on the active MPU to the TFTP server. (Details not shown.)
# To access the device through the console port, you must run a terminal emulator program (HyperTerminal, PuTTY, or Tera Term) on the host. For information about using a terminal emulator program, see the program's user guide.
The following are the required terminal settings:
¡     Baud rate—9600.
¡     Data bits—8.
¡     Stop bits—1.
¡     Paritynone.
¡     Flow controlnone.
2.     Configure the TFTP server:
a.     Upgrade the standby MPU:
# Use a straight-through Ethernet cable to connect the management Ethernet interface (Ten-GigabitEthernet 3/1/0) on the standby MPU to the TFTP server.
# Disable startup software version check for the standby MPU at startup.
[Device] version check ignore
[Device] save
# Reboot the standby MPU.
<Device> reboot slot 1
.......DONE!
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start memory test
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing.........Done.
*                       H3C BootWare, Version 1.44                         *
Compiled Date         : Aug 24 2017
CPU Type              : XLP316
CPU Clock Speed       : 1200MHz
Memory Type           : DDR3 SDRAM
Memory Size           : 8192MB
Memory Speed          : 667MHz
BootWare Size         : 1536KB
Cfa0 Size            : 500MB
cfa0 Size             : 4002MB
BASIC CPLD Version    : 1.0
EXTENDED CPLD Version : 1.0
PCB Version           : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
# Press Ctrl+B at prompt to access the EXTEND-BOOTWARE menu.
Password recovery capability is enabled.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>=========================
|<1> Boot System        |
|<2> Enter Serial SubMenu                                                            |
|<3> Enter Ethernet SubMenu                                                          |
|<4> File Control        |
|<5> Restore to Factory Default Configuration                                    |
|<6> Skip Current System Configuration                                             |
|<7> BootWare Operation Menu                                                         |
|<8> Skip Authentication for Console Login                                        |
|<9> Storage Device Operation                                                        |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
# Enter 3 in the EXTEND-BOOTWARE menu to access the Ethernet submenu.
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is cfa0                                                 |
|<1> Download Image Program To SDRAM And Run                                      |
|<2> Update Main Image File                                                          |
|<3> Update Backup Image File                                                        |
|<4> Download Files(*.*)                                                              |
|<5> Modify Ethernet Parameter                                                       |
|<0> Exit To Main Menu        |
|<Ensure The Parameter Be Modified Before Downloading!>                         |
# Enter 5 in the Ethernet submenu to configure the network settings.
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                                       |
|            '-' = Go to previous field.                                             |
|         Ctrl+D = Quit.        |
Protocol (FTP or TFTP) :tftp             //Use TFTP to download software images.
Load File Name         : new.ipe     //Load the image file new.ipe.
                          : new.ipe
Target File Name       : new.ipe
                          : new.ipe
Server IP Address      :192.168.1.100 192.168.100.14  //Enter the TFTP server IP address.
Local IP Address       :192.168.1.1 192.168.100.66    //Enter the management IP address of the device.
Subnet Mask             :255.255.255.0      // Enter the subnet mask.
Gateway IP Address     :0.0.0.0
Table 1 Network parameter fields
'.' = Clear field
Press the dot (.), and then press Enter to clear the setting for a field.
Press the hyphen (-), and then press Enter to return to the previous field.
Ctrl+D = Quit
Press Ctrl+D to exit the Ethernet parameter settings menu.
Load File Name
Set the name of the file to be downloaded.
Target File Name
Set a file name for saving the file on the device. By default, the target file name is the same as the source file name.
Server IP Address
Set the IP address of the TFTP server.
Local IP Address
Set the IP address of the Ethernet interface that connects to the TFTP server.
Subnet Mask
Set the IP address mask.
Gateway IP Address
Set a gateway IP address if the device is on a different network from the server.
# Press Enter in the ETHERNET PARAMETER SET menu to access the Ethernet submenu.
# Enter 2 in the Ethernet submenu to upgrade the main startup images.
Enter your choice(0-5): 2
Loading...................................................................
47979456 bytes downloaded!
Image file BOOT-test.bin is self-decompressing...
Saving file cfa0:/BOOT-test.bin ..........................
Image file SYSTEM-test.bin is self-decompressing...
Saving file cfa0:/SYSTEM-test.bin..........................................
............Done.
# Enter 0 in the Ethernet submenu to return to the EXTEND-BOOTWARE menu.
Enter your choice(0-5): 0
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System        |
|<4> File Control        |
|<0> Reboot        |
# Enter 1 in the EXTEND-BOOTWARE menu to boot the standby MPU.
Enter your choice(0-9): 1
Loading the main image files...
Loading file cfa0:/SYSTEM-test.bin..........................................
Loading file cfa0:/BOOT-test.bin..............................Done.
Image file cfa0:/BOOT-test.bin is self-decompressing........................
System image is starting...
Finished running batch file.
Line con0 is available.
Press ENTER to get started.
b.     Upgrade software on the active MPU:
# Use a console cable to connect console port 0 on the active MPU to the TFTP server. (Details not shown.)
# Upgrade the active MPU in the same way you upgrade the standby MPU. (Details not shown.)
---- More ----
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-old.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-test.bin
  cfa0:/BOOT-old.bin
Configuration files
The system does not save the commands used in this procedure to a configuration file.
Related documentation
·     H3C CR16000-M Routers Fundamentals Configuration Guide-R8385P09
·     H3C CR16000-M Routers Fundamentals Command Reference-R8385P09
