- 10-MPLS Configuration Guide
- 01-MPLS L3VPN configuration
- 02-IPv6 MPLS L3VPN configuration
- 03-MPLS L2VPN configuration
- 04-VPLS configuration
- 05-MPLS OAM configuration
- 06-LDP configuration
- 07-MCE configuration
- 08-MPLS TE configuration
- 09-Basic MPLS configuration
- 10-RSVP configuration
- 11-Tunnel policy configuration
- 12-Static CRLSP configuration
- 13-Static LSP configuration
00-Preface | 109.37 KB |
Preface
This configuration guide describes fundamentals and configuration of MPLS and its extended functions.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
