- 11-NAT Configuration
- 01-ER G3 Routers Port Mapping Configuration Examples (Web)
- 02-MSR Routers Port Mapping Configuration Examples (Web)
- 03-MSR Routers Configure Internal Users to Access Internal Servers by Using Public Addresses
- 04-MSR Routers Configure Internal and External Users to Access Internal Servers
| 03-MSR Routers Configure Internal Users to Access Internal Servers by Using Public Addresses | 76.28 KB |
MSR Routers |
Introduction
The following information provides examples for configuring internal users to access internal servers by using public addresses on MSR routers.
This document applies to Comware 7-based MSR router series. Procedures and information in the examples might be slightly different depending on the software or hardware version of the router.
This document assumes that you have basic knowledge of NAT.
Example: Configuring internal users to access internal servers by using public addresses
As shown in Figure 1, Host A and the FTP server reside in the same LAN and the router acts as the gateway in the LAN. Configure NAT hairpin to meet the following requirements:
· External hosts can access the internal FTP server through the router.
· Host A accesses the FTP server by using a public address to protect the server from internal network attacks.
Analysis
· Configure an ACL rule and associate it with NAT configuration. Only packets from subnet 192.168.1.0/24 that match the ACL rule are processed by NAT.
· To allow external hosts to access the internal FTP server by using a public IP address, configure NAT Server on the interface connected to the external network.
· To allow Host A to access the internal FTP server by using a public IP address, enable NAT hairpin on the interface connected to the internal network.
Software versions used
This configuration example was created and verified on R6749P14 of the H3C MSR3610-X1 router.
Procedures
# Specify IP addresses for GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
<Router> system-view
[Router] interface gigabitethernet 1/0/1
[Router-GigabitEthernet1/0/1] ip address 192.168.1.1 24
[Router-GigabitEthernet1/0/1] quit
[Router] interface gigabitethernet 1/0/2
[Router-GigabitEthernet1/0/2] ip address 10.0.0.1 24
[Router-GigabitEthernet1/0/2] quit
# Configure ACL 2000 to identify packets from subnet 192.168.1.0/24.
[Router] acl number 2000
[Router-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Router-acl-ipv4-basic-2000] quit
# Configure a NAT server mapping on GigabitEthernet 1/0/2 to map the IP address of the FTP server to a public address, allowing external users to access the internal FTP server.
[Router-GigabitEthernet1/0/2] nat server protocol tcp global 10.0.0.1 inside 192.168.1.5 ftp
# Enable outbound NAT with Easy IP on GigabitEthernet 1/0/2 so that NAT translates the source addresses of the packets from Host A into the IP address of GigabitEthernet 1/0/2.
[Router-GigabitEthernet1/0/2] nat outbound 2000
# Enable NAT hairpin on GigabitEthernet 1/0/1.
[Router-GigabitEthernet1/0/1] nat hairpin enable
# Execute the display nat all command to display all NAT configuration and statistics and verify that GigabitEthernet 1/0/1 is enabled with NAT hairpin.
[Router] display nat all
NAT outbound information:
Totally 1 NAT outbound rules.
ACL: 2000
Address group ID: ---
Port-preserved: N NO-PAT: N Reversible: N
NAT counting: 0
Config status: Active
NAT internal server information:
Totally 1 internal servers.
Protocol: 6(TCP)
Global IP/port: 10.0.0.1/21
Local IP/port: 192.168.1.5/21
NAT counting : 0
Config status : Active
NAT logging:
Log enable : Disabled
Flow-begin : Disabled
Flow-end : Disabled
Flow-active : Disabled
Port-block-assign : Disabled
Port-block-withdraw : Disabled
Alarm : Disabled
NO-PAT IP usage : Disabled
NAT hairpinning:
Totally 1 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
Mapping mode: Address and Port-Dependent
ACL : ---
NAT ALG:
DNS : Enabled
FTP : Enabled
H323 : Enabled
ICMP-ERROR : Enabled
ILS : Enabled
MGCP : Enabled
NBT : Enabled
PPTP : Enabled
RTSP : Enabled
RSH : Enabled
SCCP : Enabled
SCTP : Enabled
SIP : Enabled
SQLNET : Enabled
TFTP : Enabled
XDMCP : Enabled
Static NAT load balancing: Disabled
NAT link-switch recreate-session: Disabled
NAT configuration-for-new-connection: Disabled
NAT global-policy compatible-previous-version rule-type ipv4-snat-and-dnat trans
late-before-secp : Disabled
# Execute the display nat session verbose command to display NAT sessions that are generated when Host A accesses the FTP server.
[Router] display nat session verbose
Slot 1:
Initiator:
Source IP/port: 192.168.1.2/1694
Destination IP/port: 10.0.0.1/21
DS-Lite tunnel peer: -
VPN instance/VLAN ID/VLL ID: -/-/-
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/1
Responder:
Source IP/port: 192.168.1.5/21
Destination IP/port: 10.0.0.1/1025
Protocol: TCP(6)
State: TCP_ESTABLISHED
Application: HTTP
Rule ID: -/-/-
Rule name:
Start time: 2013-08-15 14:53:29 TTL: 3597s
Initiator->Responder: 7 packets 308 bytes
Responder->Initiator: 5 packets 312 bytes
Total sessions found: 1
Configuration files
port link-mode route
nat hairpin enable
ip address 10.0.0.1 255.255.255.0
nat outbound 2000
nat server protocol tcp global 10.0.0.1 21 inside 192.168.1.5 21
acl number 2000
rule 0 permit source 192.168.1.0 0.0.0.255
Related documentation
· Layer 3—IP Services Configuration Guide in H3C MSR Router Series Comware 7 Configuration Guides
· Layer 3—IP Services Command Reference in H3C MSR Router Series Comware 7 Command References
