| 01-Enable Multiple Networks on a Switch to Access the Public Network Through the Router (Web) | 369.25 KB |
Copyright © 2024 New H3C Technologies Co., Ltd. All rights reserved
Introduction
The following information describes how to enable multiple networks on a switch to access the public network through the router.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of VLAN and static routing.
Example: Configuring multiple networks on a switch to access the public network through the router
As shown in Figure 1, Host A and Host B are connected to the switch. Host A belongs to VLAN 2, and Host B belongs to VLAN 3. The IP addresses for interfaces VLAN-interface 1, VLAN-interface 2, and VLAN-interface 3 on the switch are 192.168.1.254/24, 192.168.2.1/24, and 192.168.3.1/24, respectively. The IP address for interface VLAN-interface 1 on the device is 192.168.1.1/24. Configure network settings for Host A and Host B to access the Internet.
Software version used
This document applies to Comware 7-based MER router series. This configuration example was created and verified on R6749P14 of the MER8300 router.
Procedures
1. Configuring Host A and Host B
Set the IP address of the Host A to 192.168.2.2/24, and set its gateway address to 192.168.2.1/24. Set the IP address of the Host B to 192.168.3.2/24, and set its gateway address to 192.168.3.1/24.
2. Configuring the switch
# Create VLAN 2 and VLAN 3.
<Switch> system-view
[Switch] vlan 2 to 3
# Assign interface GigabitEthernet 1/0/2 to VLAN 2.
[Switch-GigabitEthernet1/0/2] port access vlan 2
# Assign interface GigabitEthernet 1/0/3 to VLAN 3.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port access vlan 3
[Switch-GigabitEthernet1/0/3] quit
# Set the IP address of VLAN-interface 1 to 192.168.1.254/24.
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ip address 192.168.1.254 255.255.255.0
[Switch-Vlan-interface1] quit
# Set the IP address of VLAN-interface 2 to 192.168.2.1/24.
[Switch-Vlan-interface2] ip address 192.168.2.1 255.255.255.0
[Switch-Vlan-interface2] quit
# Set the IP address of VLAN-interface 3 to 192.168.3.1/24.
[Switch-Vlan-interface3] ip address 192.168.3.1 255.255.255.0
[Switch-Vlan-interface3] quit
# Configure a default route.
[Switch] ip route-static 0.0.0.0 0.0.0.0 192.168.1.1
3. Configuring the device
# Log in to the web management interface of the router. From the left navigation pane, select Network > LAN Settings. Edit interface VLAN-interface 1.
# Set the IP address of VLAN-interface 1 to 192.168.1.1, set its subnet mask to 255.255.255.0, and then click Apply.
# The system displays a prompt message after the configuration is completed.
# From the left navigation pane, select Advanced Settings > Static Routing. Click Add.
# Set the destination IP address to 192.168.2.0, set the mask length to 24, and then click Apply.
# Set the destination IP address to 192.168.3.0, set the mask length to 24, and then click Apply.
Verify that both Host A and Host B can access the Internet. (Details not shown.)
.files/x_Img_x_png_0.png)
.files/x_Img_x_png_1.png)
.files/x_Img_x_png_2.png)
.files/x_Img_x_png_3.png)
.files/x_Img_x_png_4.png)
.files/x_Img_x_png_5.png)
.files/x_Img_x_png_6.png)
.files/x_Img_x_png_7.png)
