- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IRDP commands
- 12-IP performance optimization commands
- 13-UDP helper commands
- 14-IPv6 basics commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
- 17-AFT commands
- 18-Tunneling commands
- 19-GRE commands
- 20-ADVPN commands
- 21-WAAS commands
- 22-Lighttpd service commands
- 23-Web caching commands
16-IPv6 fast forwarding commands | 58.48 KB |
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
ipv6 fast-forwarding load-sharing
reset ipv6 fast-forwarding cache
Use display ipv6 fast-forwarding aging-time to display the aging time of IPv6 fast forwarding entries.
# Display the aging time of IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding aging-time
Aging time: 30s
Aging time |
Aging time of IPv6 fast forwarding entries, in seconds. |
Use display ipv6 fast-forwarding cache to display IPv6 fast forwarding entries.
In standalone mode:
display ipv6 fast-forwarding cache [ ipv6-address ]
In IRF mode:
display ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ]
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 fast forwarding entries for all member devices. (In IRF mode.)
# Display all IPv6 fast forwarding entries.
<Sysname> display ipv6 fast-forwarding cache
Total number of IPv6 fast-forwarding items: 2
Src IP: 2002::1 Src port: 129
Dst IP: 2001::1 Dst port: 65535
Protocol: 58
VPN instance: N/A
Input interface: GE1/0/2
Output interface: GE1/0/1
Src IP: 2001::1 Src port: 128
Dst IP: 2002::1 Dst port: 0
Protocol: 58
VPN instance: N/A
Input interface: GE1/0/1
Output interface: GE1/0/2
Total number of IPv6 fast-forwarding items |
Number of IPv6 fast forwarding entries. |
Src IP |
Source IPv6 address. |
Src port |
Source port number. |
Dst IP |
Destination IPv6 address. |
Dst Port |
Destination port number. |
Protocol |
Protocol number. |
VPN instance |
VPN instance. If the entry does not belong to any VPN instance, this field displays N/A. |
Input interface |
Input interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the input interface does not exist, this field displays a hyphen (-). |
Output interface |
Output interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the output interface does not exist, this field displays a hyphen (-). |
Use ipv6 fast-forwarding aging-time to set the aging time for IPv6 fast forwarding entries.
Use undo ipv6 fast-forwarding aging-time to restore the default.
ipv6 fast-forwarding aging-time aging-time
The aging time is 30 seconds.
aging-time: Sets the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for IPv6 fast forwarding entries.
[Sysname] ipv6 fast-forwarding aging-time 20
ipv6 fast-forwarding enable
Use ipv6 fast-forwarding enable to enable IPv6 fast forwarding.
Use undo ipv6 fast-forwarding enable to disable IPv6 fast forwarding.
IPv6 fast forwarding is enabled.
The IPv6 fast forwarding feature will create fast forwarding entries for the device to speed up packet forwarding. When the traffic volume is high, the device will generate a large number of fast forwarding entries. These entries will cause high memory usage, which eventually leads to memory allocation failure for other services. In this case, you can disable this feature temporarily to free up device memory.
Do not disable IPv6 fast forwarding if the device runs services that are based on sessions. Disabling fast forwarding will make these services become ineffective:
· NAT.
· ASPF.
· Attack detection and prevention.
# Disable IPv6 fast forwarding.
[Sysname] undo ipv6 fast-forwarding enable
Use ipv6 fast-forwarding load-sharing to enable IPv6 fast forwarding load sharing.
Use undo ipv6 fast-forwarding load-sharing to disable IPv6 fast forwarding load sharing.
IPv6 fast forwarding load sharing is enabled.
IPv6 fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If IPv6 fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable IPv6 fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ipv6 fast-forwarding load-sharing
Use reset ipv6 fast-forwarding cache to clear the IPv6 fast forwarding table.
In standalone mode:
In IRF mode:
reset ipv6 fast-forwarding cache [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears the IPv6 fast forwarding table for all member devices. (In IRF mode.)
# Clear the IPv6 fast forwarding table.
<Sysname> reset ipv6 fast-forwarding cache
