10-IP Multicast
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10010-IP Multicast
08-IPMCAST-MIB
08-IPMCAST-MIB 99.75 KB
IPMCAST-MIB
About this MIB
The multicast technique effectively addresses the issue of point-to-multipoint data transmission. By enabling high-efficiency point-to-multipoint data transmission over a network, multicast greatly saves network bandwidth and reduces network load.
By using multicast technology, a network operator can easily provide bandwidth-critical and time-critical information services. These services include live webcasting, Web TV, distance learning, telemedicine, Web radio, and real-time video conferencing.
Use the MIB to manage IP multicast settings, including multicast routes.
MIB file name
rfc5132-ipmcast.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ipMcastMIB(168)
Scalar objects
ipMcastEnabled (1.3.6.1.2.1.168.1.1)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Enabling status of IP multicast.
As per the MIB.
ipMcastRouteEntryCount (1.3.6.1.2.1.168.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
INTEGER(0..4294967295)
Number of entries in the MRIB routing table.
As per the MIB.
ipMcastDeviceConfigStorageType (1.3.6.1.2.1.168.1.11)
Object (OID)
Access
Value range
Implementation
read-write
StorageType
INTEGER {
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type used for the global IP multicast configuration.
Supports only the read operation.
The value of this object is always nonVolatile(3).
Tabular objects
ipMcastInterfaceTable
About this table
This table contains an interface configured with IP multicast.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipMcastInterfaceIPVersion and ipMcastInterfaceIfIndex.
Object (OID)
Access
Value range
Implementation
ipMcastInterfaceIPVersion (1.3.6.1.2.1.168.1.3.1.1)
not-accessible
InetVersion
INTEGER {
unknown(0),
ipv4(1),
ipv6(2)
IP version.
As per the MIB.
ipMcastInterfaceIfIndex (1.3.6.1.2.1.168.1.3.1.2)
not-accessible
InterfaceIndex
Integer32(1..2147483647)
Index of a multicast interface.
As per the MIB.
ipMcastInterfaceTtl (1.3.6.1.2.1.168.1.3.1.3)
read-write
Unsigned32
Unsigned32(0..256)
TTL of the interface.
The value of this object is always 0.
ipMcastInterfaceRateLimit (1.3.6.1.2.1.168.1.3.1.4)
read-write
Unsigned32
Standard MIB values.
Limited rate of multicast traffic on the interface, in kbps.
ipMcastInterfaceStorageType(1.3.6.1.2.1.168.1.3.1.5)
read-write
StorageType
INTEGER {
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Row storage type.
The value of this object is always readOnly(5).
ipMcastSsmRangeTable
About this table
This table contains multicast group range settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are McastSsmRangeAddressType, ipMcastSsmRangeAddress, and ipMcastSsmRangePrefixLength.
Object (OID)
Access
Value range
Implementation
ipMcastSsmRangeAddressType (1.3.6.1.2.1.168.1.4.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of a multicast group prefix.
As per the MIB.
ipMcastSsmRangeAddress (1.3.6.1.2.1.168.1.4.1.2)
not-accessible
InetAddress
OCTET STRING (0..255)
Multicast group address gives the group prefix for this SSM range.
As per the MIB.
ipMcastSsmRangePrefixLength (1.3.6.1.2.1.168.1.4.1.3)
not-accessible
InetAddressPrefixLength
Unsigned32(0..2040)
Length of the mask which gives the group prefix for this SSM range.
As per the MIB.
ipMcastSsmRangeRowStatus (1.3.6.1.2.1.168.1.4.1.4)
read-create
RowStatus
active(1)
Row status.
The value of this object is always active(1).
ipMcastSsmRangeStorageType (1.3.6.1.2.1.168.1.4.1.5)
read-create
StorageType
INTEGER {
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Row storage type.
ipMcastRouteTable
About this table
This table contains multicast routing entry information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipMcastRouteGroupAddressType, ipMcastRouteGroup, ipMcastRouteGroupPrefixLength, ipMcastRouteSourceAddressType, ipMcastRouteSource, and ipMcastRouteSourcePrefixLength.
Object (OID)
Access
Value range
Implementation
ipMcastRouteGroupAddressType (1.3.6.1.2.1.168.1.5.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address family of multicast group address in a multicast routing entry.
As per the MIB.
ipMcastRouteGroup (1.3.6.1.2.1.168.1.5.1.2)
not-accessible
InetAddress
Multicast group address in the entry.
As per the MIB.
ipMcastRouteGroupPrefixLength (1.3.6.1.2.1.168.1.5.1.3)
not-accessible
Unsigned32(0..2040)
Length of the mask which identifies the groups for which this entry contains multicast routing information.
As per the MIB.
ipMcastRouteSourceAddressType (1.3.6.1.2.1.168.1.5.1.4)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the multicast source address in the entry.
As per the MIB.
ipMcastRouteSource (1.3.6.1.2.1.168.1.5.1.5)
not-accessible
InetAddress
Multicast source address in the entry.
As per the MIB.
ipMcastRouteSourcePrefixLength (1.3.6.1.2.1.168.1.5.1.6)
not-accessible
Unsigned32(0..2040)
Length of the mask which identifies the sources for which this entry contains multicast routing information.
As per the MIB.
ipMcastRouteUpstreamNeighborType (1.3.6.1.2.1.168.1.5.1.7)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Type of the upstream neighbor.
As per the MIB.
ipMcastRouteUpstreamNeighbor (1.3.6.1.2.1.168.1.5.1.8)
read-only
InetAddress
Address of the upstream neighbor.
As per the MIB.
ipMcastRouteInIfIndex (1.3.6.1.2.1.168.1.5.1.9)
read-only
InterfaceIndexOrZero
Integer32(0..2147483647)
Index of the incoming interface in the entry.
As per the MIB.
ipMcastRouteTimeStamp (1.3.6.1.2.1.168.1.5.1.10)
read-only
TimeStamp
TimeTicks
Time when the entry was learned.
As per the MIB.
ipMcastRouteExpiryTime (1.3.6.1.2.1.168.1.5.1.11)
read-only
TimeTicks
Time before the entry ages out.
As per the MIB.
ipMcastRouteProtocol (1.3.6.1.2.1.168.1.5.1.12)
read-only
IANAipMRouteProtocol
INTEGER {
other(1),
local(2),
netmgmt(3),
dvmrp(4),
mospf(5),
pimSparseDense(6),
cbt(7),
pimSparseMode(8),
pimDenseMode(9),
igmpOnly(10),
bgmp(11),
msdp(12)
Protocol type of the entry.
As per the MIB.
ipMcastRouteRtProtocol (1.3.6.1.2.1.168.1.5.1.13)
read-only
IANAipRouteProtocol
INTEGER {
other (1),
local (2),
netmgmt (3),
icmp(4),
egp (5),
ggp (6),
hello (7),
rip (8),
isIs (9),
esIs (10),
ciscoIgrp (11),
bbnSpfIgp (12),
ospf (13),
bgp (14),
idpr (15),
ciscoEigrp (16),
dvmrp (17)
Protocol type of the RPF route.
As per the MIB.
ipMcastRouteRtAddressType (1.3.6.1.2.1.168.1.5.1.14)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the RPF route.
As per the MIB.
ipMcastRouteRtAddress (1.3.6.1.2.1.168.1.5.1.15)
read-only
InetAddress
IP address in the RPF route.
As per the MIB.
ipMcastRouteRtPrefixLength (1.3.6.1.2.1.168.1.5.1.16)
read-only
Unsigned32(0..2040)
Mask length for the RPF route.
Value range:
IPv4: 0 to 32.
IPv6: 0 to 128.
ipMcastRouteRtType (1.3.6.1.2.1.168.1.5.1.17)
read-only
INTEGER
unicast (1),
multicast (2)
Reason the RPF route was added. Type of the route on which the RPF route depends.
As per the MIB.
ipMcastRouteOctets (1.3.6.1.2.1.168.1.5.1.18)
read-only
Counter64
INTEGER(0..18446744073709551615)
Number of octets forwarded by using the entry.
As per the MIB.
ipMcastRoutePkts (1.3.6.1.2.1.168.1.5.1.19)
read-only
Counter64
Number of packets forwarded by using the entry.
As per the MIB.
ipMcastRouteTtlDropOctets (1.3.6.1.2.1.168.1.5.1.20)
read-only
Counter64
Number of octets dropped because the TTL was too small.
Not supported
ipMcastRouteTtlDropPackets (1.3.6.1.2.1.168.1.5.1.21)
read-only
Counter64
Number of packets dropped because the TTL was too small.
Not supported
ipMcastRouteDifferentInIfOctets (1.3.6.1.2.1.168.1.5.1.22)
read-only
Counter64
Number of octets dropped because the receiving interface was incorrect.
As per the MIB.
ipMcastRouteDifferentInIfPackets (1.3.6.1.2.1.168.1.5.1.23)
read-only
Counter64
Number of packets dropped because receiving interface was incorrect.
As per the MIB.
ipMcastRouteBps (1.3.6.1.2.1.168.1.5.1.24)
read-only
CounterBasedGauge64
Bits per second forwarded by this router using the entry in the last second.
Not supported
ipMcastRouteNextHopTable
About this table
This table contains information about the next-hop on outgoing interfaces in a multicast routing entry.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipMcastRouteNextHopGroupAddressType, ipMcastRouteNextHopGroup, ipMcastRouteNextHopGroupPrefixLength, ipMcastRouteNextHopSourceAddressType, ipMcastRouteNextHopSource, ipMcastRouteNextHopSourcePrefixLength, ipMcastRouteNextHopIfIndex, ipMcastRouteNextHopAddressType, and ipMcastRouteNextHopAddress.
Object (OID)
Access
Value range
Implementation
ipMcastRouteNextHopGroupAddressType (1.3.6.1.2.1.168.1.6.1.1)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Type of the address in an entry.
As per the MIB.
ipMcastRouteNextHopGroup (1.3.6.1.2.1.168.1.6.1.2)
not-accessible
InetAddress
Address of the multicast source address.
As per the MIB.
ipMcastRouteNextHopGroupPrefixLength (1.3.6.1.2.1.168.1.6.1.3)
not-accessible
Unsigned32(0..2040)
Mask length of the multicast group address.
As per the MIB.
ipMcastRouteNextHopSourceAddressType (1.3.6.1.2.1.168.1.6.1.4)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Type of the multicast source address.
As per the MIB.
ipMcastRouteNextHopSource (1.3.6.1.2.1.168.1.6.1.5)
not-accessible
InetAddress
Multicast source address.
As per the MIB.
ipMcastRouteNextHopSourcePrefixLength (1.3.6.1.2.1.168.1.6.1.6)
not-accessible
Unsigned32(0..2040)
Prefix length of the multicast source.
As per the MIB.
ipMcastRouteNextHopIfIndex (1.3.6.1.2.1.168.1.6.1.7)
not-accessible
InterfaceIndex
Index of the outgoing interface for the next hop.
As per the MIB.
ipMcastRouteNextHopAddressType (1.3.6.1.2.1.168.1.6.1.8)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the next hop.
As per the MIB.
ipMcastRouteNextHopAddress (1.3.6.1.2.1.168.1.6.1.9)
not-accessible
InetAddress
IP address of the next-hop.
As per the MIB.
ipMcastRouteNextHopState (1.3.6.1.2.1.168.1.6.1.10)
read-only
INTEGER
pruned(1),
forwarding(2)
Whether the next hop is currently being used to forward IP datagrams.
The value of this object is always forward(2).
ipMcastRouteNextHopTimeStamp (1.3.6.1.2.1.168.1.6.1.11)
read-only
TimeStamp
TimeTicks
Time when the next hop entry was added.
As per the MIB.
ipMcastRouteNextHopExpiryTime (1.3.6.1.2.1.168.1.6.1.12)
read-only
TimeTicks
Time remaining before the next hop entry ages out.
As per the MIB.
ipMcastRouteNextHopClosestMemberHops (1.3.6.1.2.1.168.1.6.1.13)
read-only
Unsigned32
Unsigned32(0..256)
Minimum number of hops between this router and the nearest group member.
ipMcastRouteNextHopProtocol (1.3.6.1.2.1.168.1.6.1.14)
read-only
INTEGER {
other(1),
local(2),
netmgmt(3),
dvmrp(4),
mospf(5),
pimSparseDense(6),
cbt(7),
pimSparseMode(8),
pimDenseMode(9),
igmpOnly(10),
bgmp(11),
msdp(12)
Protocol through which the next hop entry was learned.
As per the MIB.
ipMcastRouteNextHopOctets (1.3.6.1.2.1.168.1.6.1.15)
read-only
Counter64
Number of octets of multicast packets that have been forwarded using this next hop.
Not supported
ipMcastRouteNextHopPkts (1.3.6.1.2.1.168.1.6.1.16)
read-only
Counter64
Number of packets which have been forwarded using this next hop.
Not supported
ipMcastBoundaryTable
About this table
This table contains multicast boundary settings.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are ipMcastBoundaryIfIndex, ipMcastBoundaryAddressType, ipMcastBoundaryAddress, and ipMcastBoundaryAddressPrefixLength.
Object (OID)
Access
Value range
Implementation
ipMcastBoundaryIfIndex (1.3.6.1.2.1.168.1.7.1.1)
not-accessible
InterfaceIndex
Index of an interface that is configured as the multicast boundary.
As per the MIB.
ipMcastBoundaryAddressType (1.3.6.1.2.1.168.1.7.1.2)
not-accessible
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
Address type of the multicast boundary.
As per the MIB.
ipMcastBoundaryAddress (1.3.6.1.2.1.168.1.7.1.3)
not-accessible
InetAddress
IP address of the multicast boundary.
As per the MIB.
ipMcastBoundaryAddressPrefixLength (1.3.6.1.2.1.168.1.7.1.4)
not-accessible
Unsigned32(0..2040)
Length of the mash which identifies the group range for which the scoped boundary exists.
As per the MIB.
ipMcastBoundaryTimeStamp (1.3.6.1.2.1.168.1.7.1.5)
read-only
TimeStamp
TimeTicks
Time when the multicast boundary entry was learned.
As per the MIB.
ipMcastBoundaryDroppedMcastOctets (1.3.6.1.2.1.168.1.7.1.6)
read-only
Counter64
Number of octets of multicast packets that have been dropped by the multicast boundary.
Not supported
ipMcastBoundaryDroppedMcastPkts (1.3.6.1.2.1.168.1.7.1.7)
read-only
Counter64
Number of multicast packets that have been dropped by the multicast boundary.
Not supported
ipMcastBoundaryStatus (1.3.6.1.2.1.168.1.7.1.8)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
The value of this object is always (1).
ipMcastBoundaryStorageType (1.3.6.1.2.1.168.1.7.1.9)
read-create
StorageType
INTEGER {
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Row storage type.
