10-IP Multicast
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10010-IP Multicast
03-HH3C-MGMD-STD-MIB
03-HH3C-MGMD-STD-MIB 58.78 KB
HH3C-MGMD-STD-MIB
About this MIB
Use this MIB to manage IGMP and MLD.
MIB file name
hh3c-mgmd-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMgmdStd(223)
Scalar objects
hh3cMgmdStdInterfaceName
(1.3.6.1.4.1.25506.2.223.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
DisplayString (SIZE(1..64))
OCTET STRING (1..64)
Interface name
As per the MIB.
hh3cMgmdStdInterfaceIfIndex
(1.3.6.1.4.1.25506.2.223.1.2)
Object (OID)
Access
Value range
Implementation
InterfaceIndex
Integer32(1..2147483647)
Interface index
As per the MIB.
hh3cMgmdStdGmpJoinVersion (1.3.6.1.4.1.25506.2.223.1.3)
Object (OID)
Access
Value range
Implementation
Unsigned32
Unsigned32 (1..3)
Version of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdAddressType (1.3.6.1.4.1.25506.2.223.1.4)
Object (OID)
Access
Value range
Implementation
InetAddressType
unknown(0),
ipv4(1),
ipv6(2).
Address type of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdGmpJoinSrcAddr (1.3.6.1.4.1.25506.2.223.1.5)
Object (OID)
Access
Value range
Implementation
InetAddress
OCTET STRING (0..255)
Source address of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdGmpJoinGrpAddr (1.3.6.1.4.1.25506.2.223.1.6)
Object (OID)
Access
Value range
Implementation
InetAddress
Group address of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdGmpJoinSenderIp (1.3.6.1.4.1.25506.2.223.1.7)
Object (OID)
Access
Value range
Implementation
InetAddress
Sender IP address of IGMP/MLD join messages.
As per the MIB.
hh3cMgmdStdInstanceName (1.3.6.1.4.1.25506.2.223.1.8)
Object (OID)
Access
Value range
Implementation
DisplayString
VPN instance name.
As per the MIB.
hh3cMgmdStdGmpJoinNotifPeriod (1.3.6.1.4.1.25506.2.223.2.1)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Unsigned32(0..65535)
Interval between hh3cMgmdStdGmpJoin notifications generated.
As per the MIB.
hh3cMgmdStdGmpLeaveNotifPeriod (1.3.6.1.4.1.25506.2.223.2.2)
Object (OID)
Access
Value range
Implementation
read-write
Unsigned32
Interval between hh3cMgmdStdGmpLeave notifications generated.
As per the MIB.
Notifications
hh3cMgmdStdGmpJoin
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.223.0.1
An IGMPv1, IGMPv2, or MLDv1 join message was received.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when an interface receives an IGMPv1, IGMPv2, or MLDv1 leave message or the corresponding multicast group timer times out.
System impact
No negative impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable igmp leave command.
CLI: Use the snmp-agent trap enable mld leave command.
OFF
CLI: Use the undo snmp-agent trap enable igmp leave command.
CLI: Use the undo snmp-agent trap enable mld leave command.
Object
OID (object name)
Index
Value range
 (hh3cMgmdStdInterfaceName)
Interface name.
N/A
 (hh3cMgmdStdInterfaceIfIndex)
Interface index.
N/A
InterfaceIndex
 (hh3cMgmdStdAddressType)
Address type of IGMP/ MLD leave messages.
N/A
InetAddressType
unknown(0),, ipv4(1), , ipv6(2).
 (hh3cMgmdStdGmpJoinSrcAddr)
Source address of IGMP/ MLD leave messages.
N/A
InetAddress
 (hh3cMgmdStdGmpJoinGrpAddr)
Group address of IGMP/ MLD leave messages.
N/A
InetAddress
 (hh3cMgmdStdGmpJoinSenderIp)
Sender IP address of IGMP/ MLD leave messages.
N/A
InetAddress
1.3.6.1.4.1.25506.2.223.1.8 (hh3cMgmdStdInstanceName)
VPN instance name.
N/A
DisplayString
Recommended action
No action is required.
