10-IP Multicast
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10010-IP Multicast
01-HH3C-IPMCAST-MIB
01-HH3C-IPMCAST-MIB 49.64 KB
HH3C-IPMCAST-MIB
About this MIB
The multicast technique effectively addresses the issue of point-to-multipoint data transmission. By enabling high-efficiency point-to-multipoint data transmission over a network, multicast greatly saves network bandwidth and reduces network load.
By using multicast technology, a network operator can easily provide bandwidth-critical and time-critical information services. These services include live webcasting, Web TV, distance learning, telemedicine, Web radio, and real-time video conferencing.
Use the MIB to manage IP multicast settings, including multicast routes.
MIB file name
hh3c-ipmcast.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506). hh3cCommon(2).hh3cIpMcast(212)
Scalar objects
hh3cIpMcastEntryLimitType
(1.3.6.1.4.1.25506.2.212.2.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
INTEGER
star-group(1),
source-group(2)
Multicast entry limit type.
As per the MIB.
hh3cIpMcastAddressFamily
(1.3.6.1.4.1.25506.2.212.2.2)
Object (OID)
Access
Value range
Implementation
InetAddressType
unknown(0),
ipv4(1),
ipv6(2)
Multicast address type.
As per the MIB.
hh3cIpMcastEntryLimitCount
(1.3.6.1.4.1.25506.2.212.2.3)
Object (OID)
Access
Value range
Implementation
Unsigned32
Unsigned32(0..4294967295)
Multicast entry limit.
As per the MIB.
hh3cIpMcastEntryLimitReasonType (1.3.6.1.4.1.25506.2.212.2.4)
Object (OID)
Access
Value range
Implementation
INTEGER
entryDeleted(1),
configurationChanged(2),
Reason when a multicast entry restored.
As per the MIB.
Notifications
hh3cIpMcastEntryExceedClear
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.212.0.2
The number of multicast route entries has dropped below the upper limit allowed by the device.
Recovery
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the number of multicast route entries drops below the upper limit allowed by the device.
System impact
No impact on services.
Status control
ON
CLI: Use the snmp-agent trap enable mrib entry-exceed-clear command.
CLI: Use the snmp-agent trap enable mrib6 entry-exceed-clear command.
OFF
CLI: Use the undo snmp-agent trap enable mrib entry-exceed-clear command.
CLI: Use the undo snmp-agent trap enable mrib6 entry-exceed-clear command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.212.2.1 (hh3cIpMcastEntryLimitType)
Multicast routing entry type.
N/A
INTEGER
star-group(1),, source-group(2)
1.3.6.1.4.1.25506.2.212.2.2 (hh3cIpMcastAddressFamily)
N/A
InetAddressType
unknown(0),, ipv4(1), , ipv6(2)
1.3.6.1.4.1.25506.2.212.2.3 (hh3cIpMcastEntryLimitCount)
Limit value.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.212.2.4 (hh3cIpMcastEntryLimitReasonType)
Reason why the number of multicast routing entries fell below the limit.
N/A
INTEGER
entryDeleted(1),, configurationChanged(2),
Recommended action
No action is required.
