- 17-User Access and Authentication
- 01-HH3C-8021X-EXT2-MIB
- 02-HH3C-AAA-MIB
- 03-HH3C-DOMAIN-MIB
- 04-HH3C-LOCAL-AAA-SERVER-MIB
- 05-HH3C-PORT-SECURITY-MIB
- 06-HH3C-PORTAL-MIB
- 07-HH3C-RADIUS-MIB
- 08-HH3C-USER-MIB
- 09-IEEE8021-PAE-MIB
- 10-IEEE8021-SECY-MIB
- 11-IEEE8021X-PAE-MIB
- 12-RADIUS-ACC-CLIENT-MIB
- 13-RADIUS-AUTH-CLIENT-MIB
02-HH3C-AAA-MIB | 109.81 KB |
hh3cAAAUserChassis (1.3.6.1.4.1.25506.2.181.1.1.1.1)
hh3cAAAUserSlot (1.3.6.1.4.1.25506.2.181.1.1.1.2)
hh3cAAAUserSlotMaxNumThreshold (1.3.6.1.4.1.25506.2.181.1.1.1.3)
hh3cAAAUserCpu(1.3.6.1.4.1.25506.2.181.1.1.1.4)
hh3cAAAUserCpuMaxNumThreshold (1.3.6.1.4.1.25506.2.181.1.1.1.5)
hh3cAAALoginFailedTimes (1.3.6.1.4.1.25506.2.181.1.1.1.6)
hh3cAAAStatisticPeriod (1.3.6.1.4.1.25506.2.181.1.1.1.7)
HH3C-AAA-MIB
About this MIB
Use this MIB to manage AAA.
MIB file name
hh3c-aaa.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cAAA(181)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAAAUserChassis (1.3.6.1.4.1.25506.2.181.1.1.1.1) |
accessible-for-notify |
Integer32 |
Standard MIB values. |
Number of the chassis through which users come online. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAAAUserSlot (1.3.6.1.4.1.25506.2.181.1.1.1.2) |
Integer32 |
Number of the slot through which users come online. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAAAUserSlotMaxNumThreshold (1.3.6.1.4.1.25506.2.181.1.1.1.3) |
Integer32 |
Maximum number of online users on a slot. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAAAUserCpu(1.3.6.1.4.1.25506.2.181.1.1.1.4) |
Integer32 |
CPU from which users come online. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAAAUserCpuMaxNumThreshold (1.3.6.1.4.1.25506.2.181.1.1.1.5) |
Integer32 |
Maximum number of online users on a CPU. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAAALoginFailedTimes (1.3.6.1.4.1.25506.2.181.1.1.1.6) |
Integer32 |
Number of login failures. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAAAStatisticPeriod (1.3.6.1.4.1.25506.2.181.1.1.1.7) |
Integer32 |
Collection period for failure statistics. |
As per the MIB. |
Tabular objects
hh3cAAASlotStatTable
About this table
This table contains AAA statistics for a slot.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is hh3cDomainName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAAAChassisId (1.3.6.1.4.1.25506.2.181.2.1.1.1) |
not-accessible |
Integer32 |
0..65535 |
Chassis number. |
As per the MIB. |
hh3cAAASlotId (1.3.6.1.4.1.25506.2.181.2.1.1.2) |
not-accessible |
Integer32 |
Slot number. |
As per the MIB. |
hh3cAAASlotSessionResourceNum (1.3.6.1.4.1.25506.2.181.2.1.1.3) |
read-only |
Integer32 |
Number of used session resources on the slot. |
As per the MIB. |
hh3cAAASlotDualStackUserNum (1.3.6.1.4.1.25506.2.181.2.1.1.4) |
read-only |
Integer32 |
Number of dual-stack users on the slot. |
As per the MIB. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.181.1.2.0.1 |
Maximum number of online users on a slot reached. |
Fault |
Major |
1.3.6.1.4.1.25506.2.181.1.2.0.2 (hh3cAAAUserSlotMaxNumResume) |
OFF |
Notification triggers
Possible reason 1: This notification is generated when the number of online users on a slot reaches the maximum number of online users on the slot.
Possible reason 2: The configured alarm threshold for access users per module is too low.
System impact
The number of users on the module has reached the threshold, which may result in new users failing to come online from the module.
Status control
ON
CLI: Use the snmp-agent trap enable slot-user-warning-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable slot-user-warning-threshold command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.181.1.1.1.1 (hh3cAAAUserChassis) |
Chassis number. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.181.1.1.1.2 (hh3cAAAUserSlot) |
Slot number. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.181.1.1.1.3 (hh3cAAAUserSlotMaxNumThreshold) |
Maximum number of online users on the slot. |
N/A |
Integer32 |
Recommended action
For an integrated device:
1.Use the display this command in system view to view the configured user resource alarm threshold (slot-user-warning-threshold) and verify if the threshold is too low.
- If the threshold is too low, set a higher threshold.
- If the threshold is proper, proceed to step 2.
2.Use the display access-user command in system view to view the number of online users. If the number is close to the maximum supported user quantity, replace the module with one that supports more users or configure new users to come online from a relatively idle module. If the issue persists, proceed to step 3.
3.Collect alarm, log, and configuration information, and contact Technical Support.
For a vBRAS-CP device, if a UP-VM sends this notification:
4.Use the display this command in system view or UP-manage view to view the configured user resource alarm threshold (slot-user-warning-threshold) and verify if the threshold is too low.
5.Use the display access-user command in system view to view the number of online users. If the number is close to the maximum supported user quantity, replace the module with one that supports more users or configure new users to come online from a relatively idle module. If the issue persists, proceed to step 3.
6.Collect alarm, log, and configuration information, and contact Technical Support.
For a vBRAS-CP device, if a BRAS-VM sends this notification:
7.Use the display this command in system view to view the configured user resource alarm threshold (access-user bras-vm user-warning-threshold) and verify if the threshold is too low.
8.Use the display access-user command in system view to view the number of online users. If the number is close to the maximum supported user quantity, replace the module with one that supports more users or configure new users to come online from a relatively idle module. If the issue persists, proceed to step 3.
9.Collect alarm, log, and configuration information, and contact Technical Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.181.1.2.0.2 |
The alarm that the maximum number of online users on a slot reached was cleared. |
Recovery |
Major |
N/A (N/A) |
OFF |
This notification is generated when the number of online users on a slot drops below 90 percent of the maximum number of online users on the slot.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number. |
N/A |
Integer32 |
Slot number. |
N/A |
Integer32 |
N/A |
Integer32 |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.181.1.2.0.3 |
Maximum number of online users on a CPU reached. |
Fault |
Major |
1.3.6.1.4.1.25506.2.181.1.2.0.4 (hh3cAAAUserCpuMaxNumResume) |
OFF |
Possible reason 1: This notification is generated when the number of online users on a CPU reaches the maximum number. The number of CPU users represents the maximum number of users supported by the device driver chip.
Possible reason 2: The configured upper alarm threshold for access users per module is too low.
System impact
When the number of CPU users reaches the threshold, it may cause failures for subsequent users to come online.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number. |
N/A |
Integer32 |
Slot number. |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.181.1.1.1.4 (hh3cAAAUserCpu) |
CPU number |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.181.1.1.1.5 (hh3cAAAUserCpuMaxNumThreshold) |
Maximum number of online users supported by the CPU. |
N/A |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.181.1.2.0.4 |
Number of online users on a CPU drops to 90% of the maximum number. |
Recovery |
Major |
OFF |
This notification is generated when the number of online users on a CPU drops to 90% of the maximum number.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Chassis number. |
N/A |
Integer32 |
Slot number. |
N/A |
Integer32 |
CPU number. |
N/A |
Integer32 |
N/A |
Integer32 |
Recommended action
hh3cAAAAdminLoginFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.181.1.2.0.5 |
Number of login failures of an admin user reaches the alarm threshold within a specific period. |
Fault |
Major |
1.3.6.1.4.1.25506.2.181.1.2.0.6 (hh3cAAAAdminLoginFailedClear) |
OFF |
This notification is sent when the number of login failures of a management user reaches the upper alarm threshold for the first time, or increases from a value lower than the recovery threshold to a value higher than the upper threshold during a statistics collection period. You can use the aaa login-failed alarm-threshold command to configure the threshold and the statistics collection period.
System impact
The system may be under login attacks.
Status control
ON
CLI: Use the snmp-agent trap enable aaa login-failed-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable aaa login-failed-threshold command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.181.1.1.1.6 (hh3cAAALoginFailedTimes) |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.181.1.1.1.7 (hh3cAAAStatisticPeriod) |
Alarm period. |
N/A |
Integer32 |
Recommended action
The system might be under attack. Contact the network administrator.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.181.1.2.0.6 |
Number of login failures of an admin user drops below the alarm clearing threshold within a specific period. |
Recovery |
Major |
OFF |
This notification is sent when the number of login failures of a management user drops from a value higher than or equal to the upper alarm threshold to a value lower than the recovery threshold. You can use the aaa login-failed alarm-threshold command to configure the threshold and the statistics collection period.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
Integer32 |
Alarm threshold. |
N/A |
Integer32 |
Recommended action
