- 17-User Access and Authentication
- 01-HH3C-8021X-EXT2-MIB
- 02-HH3C-AAA-MIB
- 03-HH3C-DOMAIN-MIB
- 04-HH3C-LOCAL-AAA-SERVER-MIB
- 05-HH3C-PORT-SECURITY-MIB
- 06-HH3C-PORTAL-MIB
- 07-HH3C-RADIUS-MIB
- 08-HH3C-USER-MIB
- 09-IEEE8021-PAE-MIB
- 10-IEEE8021-SECY-MIB
- 11-IEEE8021X-PAE-MIB
- 12-RADIUS-ACC-CLIENT-MIB
- 13-RADIUS-AUTH-CLIENT-MIB
01-HH3C-8021X-EXT2-MIB | 80.10 KB |
hh3c8021XExt2AuthQuietPeriod (1.3.6.1.4.1.25506.2.153.1.1.1)
(1.3.6.1.4.1.25506.2.153.1.1.2)
(1.3.6.1.4.1.25506.2.153.1.1.3)
hh3c8021XExt2AuthServerTimeout
(1.3.6.1.4.1.25506.2.153.1.1.4)
(1.3.6.1.4.1.25506.2.153.1.1.5)
(1.3.6.1.4.1.25506.2.153.1.1.6)
(1.3.6.1.4.1.25506.2.153.1.1.7)
hh3c8021XExt2UserNumThreshold (1.3.6.1.4.1.25506.2.153.2.1.1)
hh3c8021XExt2AuthConfigExtTable
HH3C-8021X-EXT2-MIB
About this MIB
Use this MIB to configure 802.1X parameters and obtain 802.1X trap notifications.
MIB file name
hh3c-8021x-ext2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3c8021XExt2(153)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2AuthQuietPeriod (1.3.6.1.4.1.25506.2.153.1.1.1) |
read-write |
Unsigned32 |
Unsigned32 (10..120) |
Quiet time after authentication failure. |
As per the MIB. |
hh3c8021XExt2AuthTxPeriod
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2AuthTxPeriod (1.3.6.1.4.1.25506.2.153.1.1.2) |
read-write |
Unsigned32 |
Unsigned32 (1..120) |
Username request timeout time. |
As per the MIB. |
hh3c8021XExt2AuthSuppTimeout
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2AuthSuppTimeout (1.3.6.1.4.1.25506.2.153.1.1.3) |
read-write |
Unsigned32 |
Client response timeout time. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2AuthServerTimeout (1.3.6.1.4.1.25506.2.153.1.1.4) |
read-write |
Unsigned32 |
Unsigned32 (100..300) |
Server response timeout time. |
As per the MIB. |
hh3c8021XExt2AuthMaxReq
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2AuthMaxReq (1.3.6.1.4.1.25506.2.153.1.1.5) |
read-write |
Unsigned32 |
Unsigned32 (1..10) |
Maximum number of attempts to send an authentication request to the same client. |
As per the MIB. |
hh3c8021XExt2AuthReAuthPeriod
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2AuthReAuthPeriod (1.3.6.1.4.1.25506.2.153.1.1.6) |
read-write |
Unsigned32 |
Unsigned32 (60..7200) |
Periodic reauthentication interval on the access device. |
As per the MIB. |
hh3c8021XExt2AuthMethod
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2AuthMethod (1.3.6.1.4.1.25506.2.153.1.1.7) |
read-write |
INTEGER |
chap(1), pap(2), eap(3) |
EAP message handling method used by the access device. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2UserNumThreshold (1.3.6.1.4.1.25506.2.153.2.1.1) |
accessible-for-notify |
Integer32 |
Integer32 (0..100) |
Threshold for the number of 802.1X users. |
As per the MIB. |
Tabular objects
About this table
Use this table to configure port-specific extended 802.1X features.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
The table index is dot1xPaePortNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3c8021XExt2PaePortAuthAdminStatus (1.3.6.1.4.1.25506.2.153.1.2.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Whether 802.1X is enabled on a port. |
As per the MIB. |
hh3c8021XExt2PaePortControlledType (1.3.6.1.4.1.25506.2.153.1.2.1.1.2) |
read-write |
INTEGER |
portbased(1), macbased(2) |
Port access control method. |
As per the MIB. |
hh3c8021XExt2PaePortMaxUserNum (1.3.6.1.4.1.25506.2.153.1.2.1.1.3) |
read-write |
Unsigned32 |
Unsigned32 (1..4294967295) |
Maximum number of concurrent users on the port. |
As per the MIB. |
hh3c8021XExt2PaePortUserNumNow (1.3.6.1.4.1.25506.2.153.1.2.1.1.4) |
read-only |
Unsigned32 |
Standard MIB values |
Number of current online users on the port. |
As per the MIB. |
hh3c8021XExt2PaePortClearStatistics (1.3.6.1.4.1.25506.2.153.1.2.1.1.5) |
read-write |
INTEGER |
noClear(0), clear(1) |
Clears 802.1X statistics. |
You can set the value only to clear(1). |
hh3c8021XExt2PaePortMcastTrigStatus (1.3.6.1.4.1.25506.2.153.1.2.1.1.6) |
read-write |
TruthValue |
true(1), false(2) |
Whether to enable the multicast trigger. |
As per the MIB. |
hh3c8021XExt2PaePortHandshakeStatus (1.3.6.1.4.1.25506.2.153.1.2.1.1.7) |
read-write |
TruthValue |
true(1), false(2) |
Whether to send handshake packets. |
As per the MIB. |
