03-HH3C-HTTP-MIB | 47.93 KB |
HH3C-HTTP-MIB
About this MIB
Use this MIB to obtain and manage HTTP settings.
MIB file name
hh3c-http.mib
Notifications
hh3cHttpUserLogin
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.255.2.0.1 |
Successful login of an HTTP user. |
Informational |
Warning |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when an HTTP user successfully logs in.
System impact
No negative impact on services
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.255.1.1.1 (hh3cHttpUserName) |
Username of an HTTP user. |
N/A |
DisplayString |
SIZE(1..80) |
1.3.6.1.4.1.25506.2.255.1.1.2 (hh3cHttpUserIPAddressType) |
IP address type of the HTTP user. |
N/A |
InetAddressType |
Standard MIB values. |
1.3.6.1.4.1.25506.2.255.1.1.3 (hh3cHttpUserIPAddress) |
IP address of the HTTP user. |
N/A |
DisplayString |
SIZE(1..80) |
1.3.6.1.4.1.25506.2.255.1.1.4 (hh3cHttpUserService) |
Service type used by the HTTP user. |
N/A |
DisplayString |
SIZE(1..80) |
Recommended action
No action is required.
hh3cHttpUserLoginFail
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.255.2.0.2 |
Login failure of an HTTP user. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when an HTTP user fails to log in.
System impact
No negative impact on the system.
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
DisplayString |
SIZE(1..80) |
N/A |
InetAddressType |
N/A |
DisplayString |
SIZE(1..80) |
N/A |
DisplayString |
SIZE(1..80) |
Recommended action
This notification is only available for Web login currently. Check whether HTTP service is enabled, the username and password are correct, the verification code is correct and not timed out, and the number of Web users does not reach the upper limit.
If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cHttpUserLogout
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.255.2.0.3 |
Successful logout of an HTTP user. |
Informational |
Warning |
N/A (N/A) |
ON |
This notification is generated when an HTTP user successfully logs out.
System impact
Status control
Object
OID (object name) |
Index |
Type |
Value range |
N/A |
DisplayString |
SIZE(1..80) |
N/A |
InetAddressType |
N/A |
DisplayString |
SIZE(1..80) |
N/A |
DisplayString |
SIZE(1..80) |
Recommended action
