09-MPLS
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10009-MPLS
08-HH3C-VSI-MIB
08-HH3C-VSI-MIB 71.98 KB
HH3C-VSI-MIB
About this MIB
Use this MIB to configure VSI.
MIB file name
hh3c-vsi.mib
Notifications
hh3cVsiChangeToUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.105.0.1
A VSI came up.
Recovery
Warning
OFF
Notification triggers
This notification is generated when a VSI comes up.
System impact
Services in the VSI will recover.
This notification is generated if a VSI comes up.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn vsi-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn vsi-state-change command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.105.1.2.1.2 (hh3cVsiName)
VSI name.
hh3cVsiIndex
OCTET STRING
As per the MIB.
Recommended action
No action is required.
hh3cVsiChangeToDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.2
A VSI went down.
Failure
Warning
OFF
This notification is generated when a VSI goes down.
Possible reasons for this event include:
The state of the physical link for the AC or PW in the VSI changed.
The VPLS configuration changed.
System impact
Services in the VSI will be interrupted and traffic will be blocked.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VSI name.
hh3cVsiIndex
OCTET STRING
As per the MIB.
Recommended action
To resolve this issue:
1.Execute the display l2vpn vsi command to display the status and number of the ACs and PWs associated with a VSI.
<Sysname> display l2vpn vsi verbose
VSI Name: vpls1
VSI Index               : 0
VSI Description         : vsi for vpls1
VSI State               : Up
MTU                     : 1500
Bandwidth               : -
Broadcast Restrain      : -
Multicast Restrain      : -
Unknown Unicast Restrain: -
MAC Table Limit         : -
MAC Learning rate       : -
Drop Unknown            : -
PW Redundancy           : Master
Statistics              : Disabled
VXLAN ID                : -
LDP PWs:
Peer            PW ID            Link ID    State
192.3.3.3       1                8          Down
ACs:
AC                               Link ID    State       Type
GE1/0/3 srv1                     1          Up          Manual
2.If the state of an AC is Down, edit the AC configuration and troubleshoot the AC interface to make sure the AC configuration is correct and the AC interface is up.
3.If the state of a PW is Down, use the display l2vpn pw verbose command to display the down reasons for the PW.
<Sysname> display l2vpn pw verbose
VSI Name: aaa
Peer: 2.2.2.9          Remote Site: 2
Signaling Protocol  : BGP
Link ID             : 9          PW State : Down
In Label            : 1420       Out Label: 1419
MTU                 : 1500
PW Attributes       : Main
VCCV CC             : -
VCCV BFD            : -
Flow Label          : Send
Control Word        : Disabled
Tunnel Group ID     : 0x800000960000000
Tunnel NHLFE IDs    : 1038
Admin PW            : -
E-Tree Mode         : -
E-Tree Role         : root
Root VLAN           : -
Leaf VLAN           : -
Down Reasons        : Control word not match
Common fault causes and solutions are as follows:
BFD session for PW down—The BFD session for PW detection is down. In this case, use the display bfd session command to view the reasons for the BFD session down, and then correct the BFD configuration or troubleshoot the physical link and link quality issues accordingly.
BGP RD was deleted—The BGP RD has been deleted. In this case, execute the route-distinguisher route-distinguisher command in auto-discovery cross-connect group view.
BGP RD was empty—No BGP RD is configured. In this case, execute the route-distinguisher route-distinguisher command in auto-discovery cross-connect group view.
Control word not match—The control word configuration on the two ends of the PW is inconsistent. In this case, configure the same control word setting on the two ends of the PW by using the control-word enable command in the PW class specified for the PW.
Encapsulation not match—The encapsulation types on the two ends of the PW are inconsistent. In this case, configure the same PW data encapsulation type on the two ends of the PW by using the pw-type command in the PW class specified for the PW.
LDP interface parameter not match—The LDP negotiation parameters on the two ends of the PW are inconsistent. In this case, configure the same VCCV CC type on the two ends of the PW by using the vccv cc command in the PW class specified for the PW. Or, configure the same CEM class settings for the CEM interfaces used by the two ends of the PW.
Non-existent remote LDP PW—The remote device has deleted the LDP PW. In this case, reconfigure the PW on the remote device.
Local AC Down—The local AC is down. In this case, verify that the configuration of the AC interface is correct and the state of the AC interface is up on the local device.
Local AC was non-existent—No local AC is configured. In this case, configure a local AC and associate it with the VSI.
MTU not match—The MTU configuration on the two ends of the PW is inconsistent. In this case, configure the same MTU on the two ends of the PW or use the mtu-negotiate disable command to disable PW MTU negotiation.
Remote AC Down—The remote AC is down. In this case, verify that the configuration of the AC interface is correct and the state of the AC interface is up on the remote device.
4.If the AC and PW are both up, use the display l2vpn forwarding pw verbose command to display whether the PW has forwarding information (Tunnel NHLFE IDs—NHLFE IDs of the public tunnels that carry the PW).
<Sysname> display l2vpn forwarding pw verbose
VSI Name: aaa
Link ID: 8
PW Type         : VLAN                  PW State : Up
In Label        : 1272                  Out Label: 1275
MTU             : 1500
VCCV CC         : Router-Alert
VCCV BFD        : Fault Detection with BFD
Flow Label      : Send
Tunnel Group ID : 0x960000000
Tunnel NHLFE IDs: 1034
MAC limit       : maximum=2000   alarm=enabled   action=discard
If a Tunnel NHLFE ID is displayed, go to step 6.
If no Tunnel NHLFE ID is displayed, go to step 5.
5.Use the display mpls lsp command to verify whether there is an LSP whose FEC is the remote IP address of the PW. This LSP is the tunnel that carries the PW. If the LSP tunnel does not exist, establish the tunnel first.
<Sysname> display mpls lsp
FEC                         Proto    In/Out Label    Out Inter/NHLFE/LSINDEX
100.100.100.100/24          LDP      -/1049          GE1/0/1
6.If the issue persists, collect the following information, and then contact Technical Support for help.
Execution results for the previous steps.
Configuration file, log messages, and alarm information of the device.
7.Use the display diagnostic-information command to collect diagnostic information.
hh3cVsiMacLimitMax
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.3
The number of MAC address entries learned by the VSI reached the maximum.
Failure
Warning
OFF
This notification is generated when the number of MAC address entries learned by a VSI reaches the maximum.
System impact
The VSI has learned the maximum number of MAC addresses, and it cannot learn new MAC addresses.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn maclimit-vsi command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn maclimit-vsi command.
Object
OID (object name)
Index
Value range
VSI name.
hh3cVsiIndex
OCTET STRING
As per the MIB.
Recommended action
Use the display l2vpn mac-address vsi vsi-name command to display information about the MAC address entries learned by the VSI. From the command output, identify the unneeded static MAC address entries and then delete them. Or, wait for dynamic MAC address entries to age out.
hh3cVsiMacLimitMaxClear
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.4
The number of MAC address entries learned by the VSI dropped below the lower threshold value.
Recovery
Warning
OFF
This notification is generated when the number of MAC addresses learned on a PW drops below the lower threshold value.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VSI name.
hh3cVsiIndex
OCTET STRING
As per the MIB.
Recommended action
hh3cVsiLabelResourceNotEnough
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.5
The label resources are insufficient.
Failure
Major
1.3.6.1.4.1.25506.2.105.0.6 (hh3cVsiLabelResourceRestore)
OFF
This notification is generated when a PW failed to request a label because of label resources used by existing PWs have reached the maximum.
System impact
Available label resources for PWs are not enough. New PWs cannot be established.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn label-resource
OFF
CLI: Use the undo snmp-agent trap enable l2vpn label-resource
Object
OID (object name)
Index
Value range
VSI name.
hh3cVsiIndex
OCTET STRING
As per the MIB.
Recommended action
Use the display l2vpn pw command to display PW information. From the command output, identify the unneeded PWs and then delete them to release label resources.
Basic information
OID
Event
Severity
Default status
Label resources became sufficient.
Recovery
Major
OFF
This notification is generated if label resources become sufficient.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn label-resource command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn label-resource command.
Object
OID (object name)
Index
Value range
VSI name.
hh3cVsiIndex
OCTET STRING
As per the MIB.
Recommended action
hh3cVsiPwNumberMaxExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.105.0.7
The PW limit was reached.
Failure
Major
OFF
This notification is generated if the number of PWs reaches the upper limit.
System impact
No new PWs can be created in the VSI.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-limitnum command.
OFF
CLI: Use the undo snmp-agent trap enable pw-limitnum command.
Object
OID (object name)
Index
Value range
VSI name.
hh3cVsiIndex
OCTET STRING
As per the MIB.
Recommended action
Use the display l2vpn pw command to display PW information. From the command output, identify the unneeded PWs and then delete them.
