- 09-MPLS
- 01-HH3C-MPLSRSVP-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLS-LDP-MIB
- 05-HH3C-MPLSCRLSP-MIB
- 06-HH3C-MPLSEXT-MIB
- 07-HH3C-MPLSLSPV-MIB
- 08-HH3C-VSI-MIB
- 09-HH3C-MPLSTE-MIB
- 10-HH3C-MPLSSLSP-MIB
- 11-HH3C-MPLSPCE-MIB
- 12-MPLS-FRR-FACILITY-STD-MIB
- 13-MPLS-L3VPN-STD-MIB
- 14-MPLS-LDP-STD-MIB
- 15-MPLS-LSR-STD-MIB
- 16-PW-STD-MIB
- 17-TE-MIB
02-HH3C-L2VPN-MIB | 100.21 KB |
HH3C-L2VPN-MIB
About this MIB
Use this MIB to obtain L2VPN configuration information. This MIB also contains notifications about PW state changes.
MIB file name
hh3c-l2vpn.mib
Notifications
hh3cL2vpnPwSwitchPtoB
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.162.0.1 |
Traffic is switched from the primary PW to the backup PW. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.2 (hh3cL2vpnPwSwitchBtoP) |
OFF |
Notification triggers
A notification sent when the traffic is switched from the primary PW to the backup PW.
System impact
Millisecond-level packet loss will occur when the traffic is switched from the primary PW to the backup PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-switch command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-switch command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.3.4.1.1 (hh3cL2vpnXcgPwIndex) |
PW index associated with the cross-connect. |
hh3cL2vpnXcgPwIndex hh3cL2vpnXcgName hh3cL2vpnXcgConnName |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.5 (hh3cL2vpnXcgPwPeerIp) |
IP address of the PW associated with the cross-connect. |
IpAddress |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.6 (hh3cL2vpnXcgPwPwID) |
ID of the PW associated with the cross-connect. |
Unsigned32 |
As per the MIB. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.2 |
Traffic is switched from the backup PW to the primary PW. |
Recovery |
Warning |
OFF |
A notification sent when the traffic is switched from the backup PW to the primary PW.
System impact
Millisecond-level packet loss will occur when the traffic is switched from the backup PW to the primary PW.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Unsigned32 |
As per the MIB. |
IpAddress |
As per the MIB. |
Unsigned32 |
As per the MIB. |
Recommended action
hh3cL2vpnMacLimitMaxPw
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.5 |
The number of MAC addresses learned on a PW reached the upper threshold value. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.6 (hh3cL2vpnMacLimitMaxPw_Clear) |
OFF |
This notification is generated when the number of MAC addresses learned on a PW exceeds the limit.
System impact
No new MAC addresses can be learned on the PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn maclimit-pw command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn maclimit-pw command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.2.3.1.1 (hh3cL2vpnMacLimitPwVsiIndex) |
VSI index. |
hh3cL2vpnMacLimitPwVsiIndex hh3cL2vpnMacLimitPwLinkID |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.3.1.2 (hh3cL2vpnMacLimitPwLinkID) |
PW index. |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.3.1.3 (hh3cL2vpnMacLimitPwVsiName) (1.3.6.1.4.1.25506.2.162.2.3.1.3 (hh3cL2vpnMacLimitPwVsiName)) |
VSI name. |
DisplayString |
As per the MIB. |
Recommended action
To resolve this issue:
1.Use the display l2vpn mac-address vsi vsi-name pw command to display information about MAC address entries learned on the PW.
2.From the command output, identify the unneeded static MAC address entries and then delete them. Alternatively, wait for dynamic MAC address entries to age out.
hh3cL2vpnMacLimitMaxPwClear
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.6 |
The number of MAC addresses learned on a PW dropped below the lower threshold value. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of MAC addresses learned on a PW drops below the lower threshold value.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
VSI index. |
Unsigned32 |
As per the MIB. |
PW index. |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.3.1.3 (hh3cL2vpnMacLimitPwVsiName) |
VSI name. |
DisplayString |
As per the MIB. |
Recommended action
hh3cL2vpnMacLimitMaxAc
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.3 |
The number of MAC addresses learned on an AC reached the maximum. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.4 (hh3cL2vpnMacLimitMaxAcClear) |
OFF |
This notification is generated when the number of MAC addresses learned on an AC exceeds the maximum.
System impact
The AC has learned the maximum number of MAC addresses. It cannot learn new MAC addresses.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn maclimit-ac command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn maclimit-ac command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.4.1.1.3 (hh3cL2vpnAcIfName) |
Name of the interface (AC). |
hh3cL2vpnAcIfIndex hh3cL2vpnAcSrvId |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.4.1.1.4 (hh3cL2vpnAcVsiName) |
Name of the VSI bound to the AC. |
DisplayString |
As per the MIB. |
Recommended action
1.Use the display l2vpn mac-address vsi vsi-name ac command to display information about MAC address entries learned on the AC.
2.From the command output, identify the unneeded static MAC address entries and then delete them. Or, wait for dynamic MAC address entries to age out.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.4 |
The number of MAC addresses learned on an AC dropped below the lower threshold value. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the number of MAC addresses learned on an AC drops below the lower threshold value.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
DisplayString |
As per the MIB. |
DisplayString |
As per the MIB. |
Recommended action
hh3cL2vpnPwParaMisMatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.7 |
PW parameter settings do not match. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.8 (hh3cL2vpnPwParaMatch) |
OFF |
This notification is generated when the PW negotiation parameter settings are inconsistent on the two ends of the PW.
System impact
The PW cannot be established or cannot forward service packets correctly.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn pw-parameter command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn pw-parameter command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.5.1.1.6 (hh3cL2vpnPwVsiName) |
Name of the VSI to which the PW is bound. |
hh3cL2vpnPwPeerIp hh3cL2vpnPwId |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.5.1.1.7 (hh3cL2vpnPwXcgName) |
Name of the cross-connect group to which the PW is bound. |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.5.1.1.8 (hh3cL2vpnPwXcgConnName) |
Name of the cross-connect to which the PW is bound. |
DisplayString |
As per the MIB. |
Recommended action
1.On the two peers of the PW, use the display l2vpn ldp verbose command to display detailed information about PW labels advertised by LDP.
2.From the command output, check the values for the PW Type, Control Word, and MTU fields.
3.If the values of those fields are inconsistent on the two peers of the PW, edit the settings of the corresponding parameters to make sure the two peers use the same settings.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.8 |
PW parameter settings are consistent. |
Recovery |
Warning |
N/A (N/A) |
OFF |
This notification is generated when the PW negotiation parameter settings are consistent on the two ends of the PW.
System impact
This event has impact on the PW setup status and service forwarding status.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
DisplayString |
As per the MIB. |
DisplayString |
As per the MIB. |
DisplayString |
As per the MIB. |
Recommended action
