05-Layer 3—IP Routing Configuration Guide
HomeSupportSwitchesS6530X SeriesConfigure & DeployConfiguration GuidesH3C S6530X Switch Series Configuration Guides-R8108Pxx-6W10005-Layer 3—IP Routing Configuration Guide
14-Dual-stack PBR configuration
14-Dual-stack PBR configuration 145.63 KB
Configuring dual-stack PBR
About dual-stack PBR
Dual-stack policy-based routing (dual-stack PBR) uses user-defined policies to route packets. A policy can specify parameters for IPv4 or IPv6 packets that match specific criteria such as ACLs. The parameters include the next hop, output interface, and default next hop.
Dual-stack policy
A dual-stack PBR policy includes match criteria and actions to be taken on the matching packets. A dual-stack PBR policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
A dual-stack PBR policy compares packets with dual stack PBR policy nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. If the packet does not match any criteria on the node, it goes to the next node for a match. If the packet does not match the criteria on any node, the device performs a routing table lookup.
Relationship between if-match clauses
On a node, you can specify multiple types of if-match clauses. For each type of the if-match clauses, one clause can be specified for a node. If you specify multiple clauses of the same type for a node, the most recently specified clause takes effect.
To match a node, a packet must match all if-match clauses for the node.
Relationship between apply clauses
You can specify multiple apply clauses for a node, but some of them might not be executed. For more information about relationship between apply clauses, see "Configuring actions for a dual-stack policy node."
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
Permit
Deny
Yes.
·     If the node contains apply clauses, dual-stack PBR executes the apply clauses on the node.
¡     If dual-stack PBR-based forwarding succeeds, dual-stack PBR does not compare the packet with the next node.
¡     If dual-stack PBR-based forwarding fails, dual-stack PBR does not compare the packet with the next node.
·     If the node does not contain apply clauses, the device performs a routing table lookup for the packet.
The device performs a routing table lookup for the packet.
No.
Dual-stack PBR compares the packet with the next node.
A node that has no if-match clauses matches any packet.
Packet forwarding process
You can apply a dual-stack PBR policy to an interface or to all interfaces on the device. Once the policy is applied, the device searches the policy for a matching node to forward that packet upon receiving a packet.
·     If a matching node is found and its match mode is permit, the device performs the following operations:
a.     Uses the next hops specified on the node to forward the packet.
b.     Searches the routing table for a route (except the default route) to forward the packet if one of the following conditions exists:
-     No next hops are specified on the node.
-     Forwarding failed based on the next hops.
c.     Uses the default next hops specified on the node to forward the packet if one of the following conditions exists:
-     No matching route was found in the routing table.
-     The routing table-based forwarding failed.
d.     Uses the default route to forward the packet if one of the following conditions exists:
-     No default next hops are specified on the node.
-     The forwarding failed based on the default next hops.
·     The device performs routing table lookup to forward the packet in either of the following conditions:
¡     No matching node is found.
¡     A matching node is found, but its match mode is deny.
Dual-stack PBR and Track
Dual-stack PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked object. The tracked object can be a next hop, output interface, and default next hop.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track and dual-stack PBR collaboration, see High Availability Configuration Guide.
Restrictions and guidelines: Dual-stack PBR configuration
If a packet destined for the local device matches a dual-stack PBR policy, dual-stack PBR will execute the apply clauses in the policy, including the clause for forwarding. When you configure a dual-stack PBR policy, be careful to avoid this situation.
Dual-stack PBR tasks at a glance
To configure dual-stack PBR, perform the following tasks:
1.     Configuring a dual-stack PBR policy
e.     Creating a dual-stack policy node
f.     Setting match criteria for a dual-stack policy node
g.     Configuring actions for a dual-stack policy node
2.     Specifying a policy for dual-stack PBR
¡     Specifying a policy for interface dual-stack PBR
¡     Specifying a policy for global dual-stack PBR
A global dual-stack PBR policy applies to all interfaces on the device.
2.     Create a node for a dual-stack policy, and enter its view.
dual-stack policy-based-route policy-name [ deny | permit ] node node-number
3.     (Optional.) Configure a description for the policy node.
By default, no description is configured for a dual-stack policy node.
2.     Enter dual-stack policy node view.
3.     Set match criteria.
¡     Set an ACL match criterion.
if-match acl { ipv4 | ipv6 | user-defined } { acl-number | name acl-name }
By default, no ACL match criterion is set.
When using the ACL to match packets, dual-stack PBR ignores the action (permit or deny) and time range settings in the ACL.
¡     Set a local QoS ID match criterion.
if-match qos-local-id local-id-value
By default, no local QoS ID match criterion is set.
¡     Set a service chain match criterion.
if-match service-chain { path-id service-path-id [ path-index service-path-index ] }
By default, no service chain match criterion is set.
Do not configure both the if-match service-chain and apply default-next-hop commands for a node in a dual-stack PBR policy applied to a Layer 3 Ethernet interface or Layer 3 Ethernet aggregate interface.
You cannot configure this command for any node in a dual-stack PBR policy applied to a Layer 3 Ethernet subinterface or Layer 3 Ethernet aggregate subinterface.
The apply clauses allow you to specify the actions to be taken on matching packets on a dual-stack policy node.
The following apply clauses determine the packet forwarding paths in a descending order:
·     apply next-hop
·     apply output-interface
·     apply default-next-hop
Dual-stack PBR supports the apply clauses in Table 1.
Table 1 Apply clauses supported in PBR
Clause
Meaning
Remarks
apply precedence
Sets an IP precedence.
This clause is always executed.
apply next-hop and apply output-interface
Sets next hops and sets output interfaces.
If both clauses are configured, only the apply next-hop clause is executed.
apply service-chain
Sets service chain information.
On a VXLAN network, configure this clause only for a policy node that have a reachable next hop.
Sets default next hops and sets default output interfaces.
The clause takes effect only in the following cases:
·     No next hops are set or the next hops are invalid.
·     The packet does not match any route in the routing table.
apply statistics
Counts successful matches and matching bytes on the policy node.
To include the number of successful matches and matching bytes on a policy node in the statistics displayed by a display command, execute this command.
This clause is always executed for matching packets.
If you specify a next hop or default next hop, dual-stack PBR periodically performs FIB table lookup to determine its availability. Temporary service interruption might occur if dual-stack PBR does not update the route immediately after its availability status changes.
Configuring actions to set the IP precedence for packets
3.     Set an IP precedence for packets.
By default, no IP precedence is specified for packets.
Configuring actions to direct packet forwarding
3.     Configure actions.
¡     Set next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { { ipv4-address | ipv6-address } [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] }&<1-4>
By default, no next hops are specified.
On a node, you can specify a maximum of four next hops for backup in one command line or by executing this command multiple times.
If multiple next hops on the same subnet are specified for backup, the device first uses the subnet route for the next hops to forward packets when the primary next hop fails. If the subnet route is not available, the device selects a backup next hop.
¡     Set output interfaces.
apply output-interface null 0 [ track track-entry-number ]
By default, no output interfaces are specified.
¡     Set default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { { ipv4-address | ipv6-address } [ direct ] [ track track-entry-number ] [ service-chain path-id service-path-id [ path-index service-path-index ] ] }&<1-4>
By default, no default next hops are specified.
On a node, you can specify a maximum of four default next hops for backup in one command line or by executing this command multiple times.
¡     Set service chain information.
apply service-chain path-id service-path-id [ path-index service-path-index ]
By default, no service chain information is set.
This command does not apply to software-forwarded packets.
Collecting policy node statistics
3.     Count successful matches and matching bytes on the policy node.
apply statistics
By default, matching counting is disabled on policy nodes.
Perform this task to apply a dual-stack policy to an interface to guide the forwarding of packets received on the interface.
You can apply only one dual-stack policy to an interface and make sure the specified policy already exists. Before you can apply a new dual-stack PBR policy to an interface, you must first remove the current dual-stack policy from the interface.
You can apply a dual-stack policy to multiple interfaces.
2.     Enter interface view.
3.     Specify a dual-stack policy for interface PBR.
By default, no interface dual-stack policy is applied to an interface.
Perform this task to apply a dual-stack policy to all interfaces on the device to guide the forwarding of packets received on the interfaces.
You can apply only one policy for global dual-stack PBR and the specified policy must already exist. Before you can apply a new policy, you must first remove the current policy.
Interface dual-stack PBR takes precedence over global dual-stack PBR on an interface. When they are both configured and packets fail to match the interface dual-stack PBR policy, global dual-stack PBR applies.
2.     Specify a policy for global dual-stack PBR.
dual-stack global policy-based-route policy-name
By default, no policy is specified for global dual-stack PBR.
Display and maintenance commands for dual-stack PBR
Display dual-stack PBR policy information.
display dual-stack policy-based-route [ policy policy-name ]
Display global dual-stack PBR configuration and statistics.
display dual-stack policy-based-route global [ slot slot-number ]
Display interface dual-stack PBR configuration and statistics.
display dual-stack policy-based-route interface interface-type interface-number [ slot slot-number ]
Display dual-stack PBR configuration.
display dual-stack policy-based-route setup
Clear dual-stack PBR statistics.
reset dual-stack policy-based-route statistics [ policy policy-name ]
PBR configuration examples
Example: Configuring packet type-based interface dual-stack PBR
As shown in Figure 1, Switch B and Switch C do not have a route to reach each other.
Configure dual-stack PBR on Switch A to implement the following requirements:
·     Forward all IPv4 TCP packets received on VLAN-interface 11 to next hop 1.1.2.2 (Switch B).
·     Forward all IPv6 TCP packets received on VLAN-interface 11 to next hop 2::2 (Switch C).
Figure 1 Network diagram
1.     Assign IP addresses to the interfaces as shown in Figure 1. (Details not shown.)
2.     Configure static or dynamic routing protocol settings to make sure Host A and B can communicate with Switch B and Switch C, respectively. (Details not shown.)
3.     Configure dual-stack PBR on Switch A:
# Configure ACL 3101 to match IPv4 TCP packets.
[SwitchA] acl advanced 3101
[SwitchA-acl-ipv4-adv-3101] rule permit tcp
[SwitchA-acl-ipv4-adv-3101] quit
# Configure ACL 3102 to match IPv6 TCP packets.
[SwitchA] acl ipv6 advanced 3102
[SwitchA-acl-ipv6-adv-3102] rule permit tcp
[SwitchA-acl-ipv6-adv-3102] quit
# Configure Node 5 for the dual-stack policy aaa to forward IPv4 TCP packets to next hop 1.1.2.2.
[SwitchA] dual-stack policy-based-route aaa permit node 5
[SwitchA-pbrdual-aaa-5] if-match acl 3101
[SwitchA-pbrdual-aaa-5] apply next-hop 1.1.2.2
[SwitchA-pbrdual-aaa-5] quit
# Configure Node 10 for the dual-stack policy aaa to forward IPv6 TCP packets to next hop 2::2.
[SwitchA] dual-stack policy-based-route aaa permit node 10
[SwitchA-pbrdual-aaa-10] if-match acl ipv6 3102
[SwitchA-pbrdual-aaa-10] apply next-hop 2::2
[SwitchA-pbrdual-aaa-10] quit
# Configure interface dual-stack PBR by applying policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] dual-stack policy-based-route aaa
Perform telnet and ping operations to verify that interface dual-stack PBR on Switch A operates as configured to perform packet forwarding as follows:
·     Forwards the matching IPv4 TCP packets to the next hop 1.1.2.2 (Switch B).
·     Forwards the matching IPv6 TCP packets to the next hop 2::2 (Switch C).
# Verify that you can telnet to Switch B (1.1.2.2) from Host A successfully. (Details not shown.)
# Verify that you cannot telnet to Switch C (1.1.3.2) from Host A. (Details not shown.)
# Verify that you can ping Switch C (1.1.3.2) from Host A successfully. (Details not shown.)
# Verify that you can telnet to Switch C (2::2) from Host B successfully. (Details not shown.)
# Verify that you cannot telnet to Switch B (1::2) from Host B. (Details not shown.)
# Verify that you can ping Switch B (1::2) from Host B successfully. (Details not shown.)
Example: Configuring packet type-based global dual-stack PBR
As shown in Figure 2, Switch E and Switch F do not have a route to reach each other.
Configure global dual-stack PBR on Switch D to implement the following requirements:
·     Forward IPv4 TCP packets to next hop 1.1.4.2 (Switch E).
·     Forward IPv6 TCP packets to next hop 5::2 (Switch F).
Figure 2 Network diagram
1.     Assign IP addresses to the interfaces, as shown in Figure 2. (Details not shown.)
2.     Configure static or dynamic routing protocol settings to make sure Switch A, B and C can communicate with Switch E and Switch F, respectively. (Details not shown.)
3.     Configure dual-stack PBR on Switch D:
# Configure ACL 3101 to match IPv4 TCP packets sourced from networks 1.1.1.0/24, 1.1.2.0/24, and 1.1.3.0/24.
<SwitchD> system-view
[SwitchD] acl advanced 3101
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.1.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.2.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] rule permit tcp source 1.1.3.0 0.0.0.0.255
[SwitchD-acl-ipv4-adv-3101] quit
# Configure ACL 3102 to match IPv6 TCP packets sourced from networks 1::0/64, 2::0/64, and 3::0/64.
<RouterD> system-view
[RouterD] acl ipv6 advanced 3102
[RouterD-acl-ipv6-adv-3102] rule permit tcp source 1::0 64
[RouterD-acl-ipv6-adv-3102] rule permit tcp source 2::0 64
[RouterD-acl-ipv6-adv-3102] rule permit tcp source 3::0 64
[RouterD-acl-ipv6-adv-3102] quit
# Configure node 5 in dual-stack PBR policy aaa to forward IPv4 TCP packets that match ACL 3101 to next hop 1.1.4.2.
[SwitchD] dual-stack policy-based-route aaa permit node 5
[SwitchD-pbrdual-aaa-5] if-match acl ipv4 3101
[SwitchD-pbrdual-aaa-5] apply next-hop 1.1.4.2
[SwitchD-pbrdual-aaa-5] quit
# Configure node 10 in dual-stack PBR policy aaa to forward IPv6 TCP packets that match ACL 3102 to next hop 5::2.
[SwitchD] dual-stack policy-based-route aaa permit node 10
[SwitchD-pbrdual-aaa-10] if-match acl ipv6 3102
[SwitchD-pbrdual-aaa-10] apply next-hop 5::2
[SwitchD-pbrdual-aaa-10] quit
# Specify dual-stack PBR policy aaa as the global PBR policy.
[SwitchD] dual-stack global policy-based-route aaa
Perform telnet and ping operations to verify that global dual-stack PBR on Switch D operates as configured to perform packet forwarding as follows:
·     Forwards the matching IPv4 TCP packets to the next hop 1.1.4.2 (Switch E).
·     Forwards the matching IPv6 TCP packets to the next hop 5::2 (Switch F).
# Verify that you can telnet to Switch E (1.1.4.2) successfully and cannot telnet to Switch F (1.1.5.2), from Switch A, B, and C. (Details not shown.)
# Verify that you can ping Switch F (1.1.5.2) from Switch A, B and C successfully. (Details not shown.)
# Verify that you can telnet to Switch F (5::2) successfully and cannot telnet to Switch E (4::2/64), from Switch A, B, and C. (Details not shown.)
# Verify that you can ping Switch F (4::2) from Switch A, B and C successfully. (Details not shown.)
