00-Preface | 100.46 KB |
Preface
This document describes the modules (such as HIM, MIM, MIC, MIC-X and SAP) supported by the H3C SR6600/SR6600-X routers, the interface cables, and the compatibility matrices among the modules, flexible interface platforms (FIPs), main processing units (MPUs), and the routers.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
