11-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS6860 SeriesConfigure & DeployConfiguration GuidesH3C S6860 Switch Series Configuration Guide-Release 26xx-6W10311-Network Management and Monitoring Configuration Guide
13-Information center configuration
13-Information center configuration 178.66 KB
Configuring the information center
The information center on a device classifies and manages logs for all modules so that network administrators can monitor network performance and troubleshoot network problems.
Overview
The information center receives logs generated by source modules and outputs logs to different destinations according to user-defined output rules. You can classify, filter, and output logs based on source modules. To view the supported source modules, use info-center source ?.
Figure 1 Information center diagram
By default, the information center is enabled. It affects system performance to some degree while processing large amounts of information. If the system resources are insufficient, disable the information center to save resources.
Log types
Logs are classified into the following types:
·           Common logs—Record common system information. Unless otherwise specified, the term "logs" in this document refers to common logs.
·           Diagnostic logs—Record debug messages.
·           Security logs—Record security information, such as authentication and authorization information.
·           Hidden logs—Record log information not displayed on the terminal, such as input commands.
·           Trace logs—Record system tracing and debug messages, which can be viewed only after the devkit package is installed.
Log levels
Logs are classified into eight severity levels from 0 through 7 in descending order. The information center outputs logs with a severity level that is higher than or equal to the specified level. For example, if you specify a severity level of 6 (informational), logs that have a severity level from 0 to 6 are output.
Table 1 Log levels
Severity value
Level
0
Emergency
The system is unusable. For example, the system authorization has expired.
1
Alert
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit.
2
Critical
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails.
3
Error
Error condition. For example, the link state changes.
4
Warning
Warning condition. For example, an interface is disconnected, or the memory resources are used up.
5
Notification
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
6
Informational
Informational message. For example, a command or a ping operation is executed.
7
Debugging
Debug message.
Log destinations
The system outputs logs to the following destinations: console, monitor terminal, log buffer, log host, and log file. Log output destinations are independent and you can configure them after enabling the information center. One log can be output to multiple destinations.
Default output rules for logs
A log output rule specifies the source modules and severity level of logs that can be output to a destination. Logs matching the output rule are output to the destination. Table 2 shows the default log output rules.
Table 2 Default output rules for logs
Destination
Log source modules
Output switch
Severity
Console
All supported modules
Enabled
Debugging
Monitor terminal
Disabled
Debugging
Log host
Enabled
Informational
Log buffer
Enabled
Informational
Log file
Enabled
Informational
Default output rules for diagnostic logs
Diagnostic logs can only be output to the diagnostic log file, and cannot be filtered by source modules and severity levels. Table 3 shows the default output rule for diagnostic logs.
Table 3 Default output rule for diagnostic logs
Destination
Log source modules
Output switch
Severity
Diagnostic log file
Enabled
Debugging
Default output rules for security logs
Security logs can only be output to the security log file, and cannot be filtered by source modules and severity levels. Table 4 shows the default output rule for security logs.
Table 4 Default output rule for security logs
Destination
Log source modules
Output switch
Severity
Security log file
Disabled
Debugging
Default output rules for hidden logs
Hidden logs can be output to the log host, the log buffer, and the log file. Table 5 shows the default output rules for hidden logs.
Table 5 Default output rules for hidden logs
Destination
Log source modules
Output switch
Severity
Log host
Enabled
Informational
Log buffer
Enabled
Informational
Log file
Enabled
Informational
Default output rules for trace logs
Trace logs can only be output to the trace log file, and cannot be filtered by source modules and severity levels. Table 6 shows the default output rules for trace logs.
Table 6 Default output rules for trace logs
Destination
Log source modules
Output switch
Severity
Trace log file
Enabled
Debugging
Log formats
The format of logs varies by output destinations. Table 7 shows the original format of log information, which might be different from what you see. The actual format varies by the log resolution tool used.
Table 7 Log formats
Output destination
Format
Example
Console, monitor terminal, log buffer, or log file
Prefix Timestamp Sysname Module/Level/Mnemonic: Content
%Nov 24 14:21:43:502 2010 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.26
Log host
·           Standard format:
<PRI>Timestamp Sysname %%vvModule/Level/Mnemonic: Source; Content
·           unicom format:
<PRI>Timestamp Hostip vvModule/Level/Serial_number: Content
·           cmcc format:
<PRI>Timestamp Sysname %vvModule/Level/Mnemonic: Source Content
·           Standard format:
<190>Nov 24 16:22:21 2010 Sysname %%10 SHELL/5/SHELL_LOGIN: -DevIP=1.1.1.1; VTY logged in from 192.168.1.26
·           unicom format:
<189>Oct 13 16:48:08 2000 10.1.1.1 10IFNET/2/210231a64jx073000020: VTY logged in from 192.168.1.21
·           cmcc format:
<189>Oct 9 14:59:04 2009 Sysname %10SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.21
Table 8 describes the fields in a log message.
Table 8 Log field description
Prefix (information type)
A log to a destination other than the log host has an identifier in front of the timestamp:
·           An identifier of percent sign (%) indicates a log with a level equal to or higher than informational.
·           An identifier of asterisk (*) indicates a debug log or a trace log.
·           An identifier of caret (^) indicates a diagnostic log.
PRI (priority)
A log destined to the log host has a priority identifier in front of the timestamp. The priority is calculated by using this formula: facility*8+level, where:
·           facility is the facility name. Facility names local0 through local7 correspond to values 16 through 23. The facility name can be configured using the info-center loghost command. It is used to identify log sources on the log host, and to query and filter the logs from specific log sources.
·           level is in the range of 0 to 7. See Table 1 for more information about severity levels.
Timestamp
Records the time when the log was generated.
Logs sent to the log host and those sent to the other destinations have different timestamp precisions, and their timestamp formats are configured with different commands. For more information, see Table 9 and Table 10.
Hostip
Source IP address of the log. If the info-center loghost source command is configured, this field displays the IP address of the specified source interface. Otherwise, this field displays the sysname.
This field exists only in logs in unicom format that are sent to the log host.
Serial number
Serial number of the device that generated the log.
Sysname (host name or host IP address)
The sysname is the host name or IP address of the device that generated the log. You can use the sysname command to modify the name of the device.
%% (vendor ID)
Identifies the vendor of the device that generated the log.
This field exists only in logs sent to the log host.
vv (version information)
Identifies the version of the log. Its value is 10.
This field exists only in logs that are sent to the log host.
Module
Specifies the name of the module that generated the log. You can enter the info-center source ? command in system view to view the module list.
Level
Identifies the level of the log. See Table 1 for more information about severity levels.
Mnemonic
Describes the content of the log. It contains a string of up to 32 characters.
Source
Optional field that identifies the source of the log. The value contains an IRF member device ID and the IP address of the log sender.
Content
Provides the content of the log.
Table 9 Timestamp precisions and configuration commands
Item
Destined to the log host
Destined to the console, monitor terminal, log buffer, and log file
Precision
Seconds
Milliseconds
Command used to set the timestamp format
info-center timestamp loghost
Table 10 Description of the timestamp parameters
Timestamp parameters
Example
boot
Time that has elapsed since system startup, in the format of xxx.yyy. xxx represents the higher 32 bits, and yyy represents the lower 32 bits, of milliseconds elapsed.
Logs that are sent to all destinations other than a log host support this parameter.
%0.109391473 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
0.109391473 is a timestamp in the boot format.
date
Current date and time, in the format of mmm dd hh:mm:ss yyy for logs that are output to a log host, or MMM DD hh:mm:ss:xxx YYYY for logs that are output to other destinations.
All logs support this parameter.
%May 30 05:36:29:579 2003 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
May 30 05:36:29:579 2003 is a timestamp in the date format.
iso
Timestamp format stipulated in ISO 8601.
Only logs that are sent to a log host support this parameter.
<189>2003-05-30T06:42:44 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully.
2003-05-30T06:42:44 is a timestamp in the iso format.
none
No timestamp is included.
% Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
no-year-date
Current date and time without year information, in the format of MMM DD hh:mm:ss:xxx.
<189>May 30 06:44:22 Sysname %%10FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully.
May 30 06:44:22 is a timestamp in the no-year-date format.
FIPS compliance
Information center configuration task list
Tasks at a glance
Perform at least one of the following tasks:
·           Outputting logs to the console
·           Outputting logs to the monitor terminal
·           Outputting logs to log hosts
·           Outputting logs to the log buffer
·           Saving logs to the log file
(Optional.) Managing security logs
(Optional.) Saving diagnostic logs to the diagnostic log file
(Optional.) Configuring the maximum size of the trace log file
(Optional.) Setting the minimum storage period for logs
(Optional.) Enabling synchronous information output
(Optional.) Enabling duplicate log suppression
(Optional.) Configuring log suppression for a module
(Optional.) Disabling an interface from generating link up or link down logs
(Optional.) Enabling SNMP notifications for system logs
Step
Remarks
1.      Enter system view.
N/A
2.      Enable the information center.
info-center enable
3.      Configure an output rule for the console.
info-center source { module-name | default } { console | monitor | logbuffer | logfile | loghost } { deny | level severity }
For information about default output rules, see "Default output rules for logs."
4.      (Optional.) Configure the timestamp format.
By default, the timestamp format is date.
5.      Return to user view.
N/A
6.      (Optional.) Enable log output to the console.
terminal monitor
The default setting is enabled.
7.      Enable the display of debug information on the current terminal.
terminal debugging
By default, the display of debug information is disabled on the current terminal.
8.      (Optional.) Set the lowest severity level of logs that can be output to the console.
The default setting is 6 (informational).
Monitor terminals refer to terminals that log in to the device through the AUX, VTY, or TTY line.
To output logs to the monitor terminal:
Step
Remarks
N/A
info-center enable
3.      Configure an output rule for the monitor terminal.
The default timestamp format is date.
N/A
6.      Enable log output to the monitor terminal.
terminal monitor
By default, log output to the monitor terminal is enabled.
terminal debugging
8.      (Optional.) Set the lowest level of logs that can be output to the monitor terminal.
Step
Remarks
N/A
info-center enable
3.      Configure an output rule for log hosts.
4.      (Optional.) Specify the source IP address for output logs.
By default, the source IP address of output logs is the primary IP address of the outgoing interface.
5.      (Optional.) Specify the format in which logs are output to log hosts.
info-center format { unicom | cmcc }
By default, logs are output to log hosts in standard format.
6.      (Optional.) Configure the timestamp format.
info-center timestamp loghost { date | iso [ with-timezone ] | no-year-date | none }
7.      Specify a log host and configure related parameters.
info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ dscp dscp-value ] [ facility local-number ]
By default, no log hosts or related parameters are specified.
The value for the port-number argument must be the same as the value configured on the log host. Otherwise, the log host cannot receive logs.
You can specify a maximum of 20 log hosts.
Step
Remarks
N/A
info-center enable
3.      Enable log output to the log buffer.
info-center logbuffer
By default, log output to the log buffer is enabled.
4.      (Optional.) Set the maximum number of logs that can be stored in the log buffer.
By default, the log buffer can store 512 logs.
5.      Configure an output rule for the log buffer.
By default, the log file feature saves logs from the log file buffer to the log file every 24 hours. You can adjust the saving interval or manually save logs to the log file. After saving logs to the log file, the system clears the log file buffer.
The log file has a maximum capacity. When the log file is full, the system will replace the oldest logs with new logs.
You can enable log file overwrite-protection to stop the device from saving new logs when the log file is full or the storage device runs out of space.
To save logs to the log file:
Step
Remarks
N/A
info-center enable
3.      Enable the log file feature.
info-center logfile enable
By default, the log file feature is enabled.
4.      (Optional.) Enable log file overwrite-protection.
info-center logfile overwrite-protection [ all-port-powerdown ]
By default, log file overwrite-protection is disabled.
This feature is supported only in FIPS mode.
5.      (Optional.) Set the maximum size for the log file.
The default setting is 10 MB.
To ensure normal operation, set the size argument to a value between 1 MB and 10 MB.
6.      (Optional.) Specify the directory to save the log file.
The default log file directory is flash:/logfile.
This command cannot survive an IRF reboot or a master/subordinate switchover.
7.      Save the logs in the log file buffer to the log file.
·           Configure the interval to perform the save operation:
info-center logfile frequency
freq-sec
·           Manually save the logs in the log file buffer to the log file:
logfile save
The default log file saving interval is 86400 seconds.
The logfile save command is available in any view.
Security logs are very important for locating and troubleshooting network problems. Generally, security logs are output together with other logs. It is difficult to identify security logs among all logs.
To solve this problem, you can save security logs to the security log file without affecting the current log output rules.
Saving security logs to the security log file
After you enable the saving of the security logs to the security log file:
·           The system first outputs security logs to the security log file buffer.
·           The system saves logs from the security log file buffer to the security log file at the specified interval. If you have the security-audit role, you can manually save security logs to the security log file.
·           After the security logs are saved, the buffer is cleared immediately.
The device supports only one security log file. To avoid security log loss, you can set an alarm threshold for the security log file usage. When the alarm threshold is reached, the system outputs a message to inform the administrator. The administrator can log in to the device with the security-audit user role and back up the security log file to prevent the loss of important data.
To save security logs to the security log file:
Step
Remarks
N/A
info-center enable
3.      Enable the saving of the security logs to the security log file.
info-center security-logfile enable
By default, saving security logs to the security log file is disabled.
4.      Set the interval at which the system saves security logs.
The default security log file saving interval is 86400 seconds.
5.      (Optional.) Set the maximum size for the security log file.
6.      (Optional.) Set the alarm threshold of the security log file usage.
By default, the alarm threshold of the security log file usage is 80. When the usage of the security log file reaches 80%, the system will inform the user.
Managing the security log file
To use the security log file management commands in this section, a local user must have the security-audit user role. For information about configuring the security-audit user role, see Security Command Reference.
To manage the security log file:
Remarks
Display a summary of the security log file.
display security-logfile summary
Available in user view.
Change the directory of the security log file.
a       system-view
b       info-center security-logfile directory dir-name
The default security log file directory is flash:/seclog.
Manually save all the contents in the security log file buffer to the security log file.
security-logfile save
Available in any view.
By default, the device saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file every 24 hours. You can adjust the saving interval or manually save diagnostic logs to the diagnostic log file. After saving diagnostic logs to the diagnostic log file, the system clears the diagnostic log file buffer.
The device supports only one diagnostic log file. The diagnostic log file has a maximum capacity. When the capacity is reached, the system replaces the oldest diagnostic logs with new logs.
To enable saving diagnostic logs to the diagnostic log file:
Step
Remarks
N/A
info-center enable
3.      Enable saving diagnostic logs to the diagnostic log file.
info-center diagnostic-logfile enable
By default, saving diagnostic logs to the diagnostic log file is enabled.
4.      (Optional.) Set the maximum size for the diagnostic log file.
5.      (Optional.) Specify the directory to save the diagnostic log file.
The default diagnostic log file directory is flash:/diagfile.
6.      Save diagnostic logs in the diagnostic log file buffer to the diagnostic log file.
·           Configure the interval to perform the saving operation:
info-center diagnostic-logfile frequency
freq-sec
·           Manually save diagnostic logs in the buffer to the diagnostic log file:
diagnostic-logfile save
The default saving interval is 86400 seconds.
The diagnostic-logfile save command is available in any view.
The device has only one trace log file. When the trace log file is full, the device overwrites the oldest trace logs with new ones.
To set the maximum size for the trace log file:
Step
Remarks
N/A
2.      Set the maximum size for the trace log file.
By default, the maximum size of the trace log file is 1 MB.
Use this feature to set the minimum storage period for logs in the log buffer and log file. This feature ensures that logs will not be overwritten by new logs during a set period of time.
By default, when the log buffer or log file is full, new logs will automatically overwrite the oldest logs. After the minimum storage period is set, the system identifies the storage period of a log to determine whether to delete the log. The system current time minus a log's generation time is the log's storage period.
·           If the storage period of a log is shorter than or equal to the minimum storage period, the system does not delete the log. The new log will not be saved.
·           If the storage period of a log is longer than the minimum storage period, the system deletes the log to save the new log.
To set the log minimum storage period:
Step
Remarks
N/A
2.      Set the log minimum storage period.
info-center syslog min-age min-age
By default, the log minimum storage period is not set.
System log output interrupts ongoing configuration operations, obscuring previously entered commands. Synchronous information output shows the obscured commands. It also provides a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
To enable synchronous information output:
Step
Remarks
N/A
2.      Enable synchronous information output.
info-center synchronous
By default, synchronous information output is disabled.
The output of consecutive duplicate logs at an interval of less than 30 seconds wastes system and network resources.
With this feature enabled, the system starts a suppression period upon outputting a log:
·           During the suppression period, the system does not output logs that have the same module name, level, mnemonic, location, and text as the previous log.
·           After the suppression period expires, if the same log continues to appear, the system outputs the suppressed logs and the log number and starts another suppression period. The suppression period is 30 seconds for the first time, 2 minutes for the second time, and 10 minutes for subsequent times.
·           If a different log is generated during the suppression period, the system aborts the current suppression period, outputs suppressed logs and the log number and then the different log, and starts another suppression period.
To enable duplicate log suppression:
Step
Remarks
N/A
2.      Enable duplicate log suppression.
info-center logging suppress duplicates
By default, duplicate log suppression is disabled.
Perform this task to configure a log suppression rule to suppress output of all logs or logs with a specific mnemonic value for a module.
To configure a log suppression rule for a module:
Step
Remarks
N/A
2.      Configure a log suppression rule for a module.
info-center logging suppress module module-name mnemonic { all | mnemonic-content }
By default, the device does not suppress output of any logs from any modules.
By default, all interfaces generate link up or link down log information when the interface state changes. In some cases, you might want to disable certain interfaces from generating this information. For example:
·           You are concerned only about the states of some interfaces. In this case, you can use this function to disable other interfaces from generating link up and link down log information.
·           An interface is unstable and continuously outputs log information. In this case, you can disable the interface from generating link up and link down log information.
Use the default setting in normal cases to avoid affecting interface status monitoring.
To disable an interface from generating link up or link down logs:
Step
Remarks
N/A
2.      Enter interface view.
N/A
3.      Disable the interface from generating link up or link down logs.
undo enable log updown
By default, all interfaces generate link up and link down logs when the interface state changes.
This feature enables the device to send an SNMP notification for each log message it outputs. The device encapsulates the logs in SNMP notifications and then sends them to the SNMP module and the log trap buffer.
You can configure the SNMP module to send received SNMP notifications in SNMP traps or informs to remote hosts. For more information, see "Configuring SNMP."
To view the traps in the log trap buffer, access the MIB corresponding to the log trap buffer.
To enable SNMP notifications for system logs:
Step
Remarks
N/A
2.      Enable SNMP notifications for system logs.
snmp-agent trap enable syslog
N/A
3.      Set the maximum number of traps that can be stored in the log trap buffer.
By default, the log trap buffer can store a maximum of 1024 traps.
Displaying and maintaining information center
Display the information of each output destination.
display info-center
Display the state and the log information of the log buffer.
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number ]*
Display a summary of the log buffer.
display logbuffer summary [ level severity | slot slot-number ] *
Display the log file configuration.
display logfile summary
Display the diagnostic log file configuration.
display diagnostic-logfile summary
Clear the log buffer.
reset logbuffer
Information center configuration examples
Configuration example for outputting logs to the console
Network requirements
Configure the device to output to the console FTP logs that have a severity level of at least warning.
Figure 2 Network diagram
Configuration procedure
# Enable the information center.
[Device] info-center enable
# Disable log output to the console.
[Device] info-center source default console deny
To avoid output of unnecessary information, disable all modules from outputting log information to the specified destination (console in this example) before you configure the output rule.
# Configure an output rule to output to the console FTP logs that have a severity level of at least warning.
[Device] info-center source ftp console level warning
[Device] quit
# Enable the display of logs on the console. (This function is enabled by default.)
<Device> terminal logging level 6
<Device> terminal monitor
Now, if the FTP module generates logs, the information center automatically sends the logs to the console, and the console displays the logs.
Configuration example for outputting logs to a UNIX log host
Configure the device to output to the UNIX log host FTP logs that have a severity level of at least informational.
Figure 3 Network diagram
Before the configuration, make sure the device and the log host can reach each other. (Details not shown.)
1.      Configure the device:
# Specify the log host 1.2.0.1/16 and specify local4 as the logging facility.
[Device] info-center loghost 1.2.0.1 facility local4
# Disable log output to the log host.
To avoid output of unnecessary information, disable all modules from outputting logs to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to output to the log host FTP logs that have a severity level of at least informational.
[Device] info-center source ftp loghost level informational
2.      Configure the log host:
The following configurations were performed on Solaris. Other UNIX operating systems have similar configurations.
a.    Log in to the log host as a root user.
b.    Create a subdirectory named Device in directory /var/log/, and then create file info.log in the Device directory to save logs from Device.
# mkdir /var/log/Device
c.    Edit the file syslog.conf in directory /etc/ and add the following contents.
In this configuration, local4 is the name of the logging facility that the log host uses to receive logs. info is the informational level. The UNIX system records the log information that has a severity level of at least informational to the file /var/log/Device/info.log.
Follow these guidelines while editing the file /etc/syslog.conf:
·       Comments must be on a separate line and must begin with a pound sign (#).
·       No redundant spaces are allowed after the file name.
·       The logging facility name and the severity level specified in the /etc/syslog.conf file must be identical to those configured on the device by using the info-center loghost and info-center source commands. Otherwise, the log information might not be output to the log host correctly.
d.    Display the process ID of syslogd, kill the syslogd process, and then restart syslogd using the –r option to make the new configuration take effect.
# ps -ae | grep syslogd
147
# kill -HUP 147
# syslogd -r &
Now, the device can output FTP logs to the log host, which stores the logs to the specified file.
Configuration example for outputting logs to a Linux log host
Configure the device to output to the Linux log host 1.2.0.1/16 FTP logs that have a severity level of at least informational.
Figure 4 Network diagram
# Specify the log host 1.2.0.1/16, and specify local5 as the logging facility.
[Device] info-center loghost 1.2.0.1 facility local5
To avoid outputting unnecessary information, disable all modules from outputting log information to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to enable output to the log host FTP logs that have a severity level of at least informational.
b.    Create a subdirectory named Device in the directory /var/log/, and create file info.log in the Device directory to save logs of Device.
local5.info /var/log/Device/info.log
In the above configuration, local5 is the name of the logging facility used by the log host to receive logs. info is the informational level. The Linux system will store the log information with a severity level equal to or higher than informational to the file /var/log/Device/info.log.
d.    Display the process ID of syslogd, kill the syslogd process, and then restart syslogd by using the -r option to apply the new configuration.
Make sure the syslogd process is started with the -r option on a Linux log host.
147
# kill -9 147
# syslogd -r &
Now, the system can record log information to the specified file.
