11-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS6860 SeriesConfigure & DeployConfiguration GuidesH3C S6860 Switch Series Configuration Guide-Release 26xx-6W10311-Network Management and Monitoring Configuration Guide
06-Event MIB configuration
06-Event MIB configuration 143.42 KB
Configuring the Event MIB
Overview
The Event Management Information Base (Event MIB) provides the ability to monitor MIB objects on a local or remote system by using SNMP.  It takes the notification or set action whenever a trigger condition is met.
The Event MIB is an enhancement to remote network monitoring (RMON):
·           In addition to threshold tests, the Event MIB provides Boolean and existence tests for event triggers.
·           When a trigger condition is met, the Event MIB sends a notification to the NMS, sets the value of a MIB object, or performs both operations.
Monitored objects
In the Event MIB, you can monitor the following MIB objects:
·           Table node.
·           Conceptual row node.
·           Table column node.
·           Simple leaf node.
·           Parent node of a leaf node.
The monitored objects can be fully specified or wildcarded:
·           To monitor a specific instance, for example, the description node for the interface with index 2 ifDescr.2, specify the monitored object ifDescr.2.
·           To monitor multiple instances, for example, all instances of the interface description node ifDescr, configure the monitored objects to be wildcarded by using ifDescr.
Object owner
An object owner can only be an SNMPv3 user. You can assign the object owner the rights to access the monitored objects. For more information about SNMPv3 user access rights, see "Configuring SNMP."
Trigger test
Existence test
An existence test monitors and manages the absence, presence, and change of a MIB object, for example, interface status. When a monitored object is specified, the system reads the value of the monitored object regularly.
·           If the test type is Absent, the system triggers an alarm event and takes the specified action when the state of the monitored object changes to absent.
·           If the test type is Present, the system triggers an alarm event and takes the specified action when the state of the monitored object changes to present.
·           If the test type is Changed, the system triggers an alarm event and takes the specified action when the value of the monitored object changes.
Boolean test
A Boolean test compares the value of the monitored object with the reference value and takes action according to the comparison result. The comparison types include unequal, equal, less, lessorequal, greater, and greaterorequal. For example, if the comparison type is equal, an event is triggered when the value of the monitored object equals the reference value. The event will not be triggered again until the value becomes unequal and comes back to equal.
Threshold test
A threshold test regularly compares the value of the monitored object with the threshold values.
·           A rising alarm event is triggered if the value of the monitored object is greater than or equal to the rising threshold.
·           A falling alarm event is triggered if the value of the monitored object is smaller than or equal to the falling threshold.
·           A rising alarm event is triggered if the difference between the current sampled value and the previous sampled value is greater than or equal to the delta rising threshold.
·           A falling alarm event is triggered if the difference between the current sampled value and the previous sampled value is smaller than or equal to the delta falling threshold.
·           A falling alarm event is triggered if the values of the monitored object, the rising threshold, and the falling threshold are the same.
·           A falling alarm event is triggered if the delta rising threshold, the delta falling threshold, and the difference between the current sampled value and the previous sampled value is the same.
The alarm management module defines the set or notification action to take on alarm events.
If the value of the monitored object crosses a threshold multiple times in succession, the managed device triggers an alarm event only for the first crossing. For example, if the value of a sampled object crosses the rising threshold multiple times before it crosses the falling threshold, only the first crossing triggers a rising alarm event, as shown in Figure 1.
Figure 1 Rising and falling alarm events
Event actions
The Event MIB triggers one or both of the following actions when the trigger condition is met:
·           Set action—Uses SNMP to set the value of the monitored object.
·           Notification action—Uses SNMP to send a notification to the NMS. If an object list is specified for the notification action, the notification will carry the specified objects in the object list.
Before you configure the Event MIB, make sure the SNMP agent and NMS are configured correctly.
Event MIB configuration task list
To configure the Event MIB:
Tasks at a glance
Configuring Event MIB sampling
(Required.) Configuring Event MIB object lists
(Required.) Configuring an event
(Required.) Configuring a trigger
·           (Optional.) Configuring a Boolean trigger test
·           (Optional.) Configuring an existence trigger test
·           (Optional.) Configuring a threshold trigger test
(Required.) Enabling SNMP notifications for Event MIB
Step
Remarks
1.      Enter system view.
N/A
2.      (Optional.) Set the minimum sampling interval.
snmp mib event sample minimum min-number
By default, the minimum sampling interval is 1 second.
The sampling intervals of triggers must be greater than or equal to the minimum sampling interval.
Changing the minimum sampling interval does not affect the exiting instances.
3.      (Optional.) Configure the maximum number of object instances that can concurrently sampled.
snmp mib event sample instance maximum max-number
By default, the maximum number of object instances that can be concurrently sampled is limited by the available resources. The value is 0.
Changing the maximum number of object instances that can be concurrently sampled does not affect the existing instances.
You can specify an Event MIB object list by using the object list owner command in trigger view, trigger-test view (including trigger-Boolean view, trigger existence view, and trigger threshold view), and action-notification view. The objects in the list will be added to the triggered notifications.
If you specify an object list respectively in any two of the views or all the three views, the object lists are added to the triggered notification in this sequence: trigger view, trigger-test view, and action-notification view.
To configure an object list:
Step
Remarks
N/A
2.      Configure an Event MIB object list.
snmp mib event object list owner group-owner name group-name object-index oid object-identifier [ wildcard ]
By default, no Event MIB object lists exist.
Use the current username as the object list owner.
Creating an event
Step
Remarks
N/A
2.      Create an event.
snmp mib event owner event-owner name event-name
By default, no event exists.
The owner must be an SNMPv3 user.
3.      (Optional.) Configure a description for the event.
By default, an event does not have a description.
4.      Specify an action for the event.
action { notification | set }
By default, no action is specified for an event.
5.      Enable the event.
event enable
By default, an event is disabled.
To enable the event action for the Boolean, existence, or threshold trigger test, you must enable the event.
Configuring a set action for an event
When you enable a set action, a set entry is created automatically. All fields in the entry have default values.
To configure a set action:
Step
Remarks
N/A
2.      Enter event view.
N/A
3.      Enable the set action and enter set action view.
action set
N/A
4.      Specify an object by its OID for the set action.
By default, no object is specified for the set action.
5.      Enable wildcard search for OIDs.
wildcard oid
By default, the set-action object is fully specified.
This command must be used in conjunction with the oid object-identifier command.
6.      Set the value for the object.
value integer-value
The default value for the object is 0.
7.      (Optional.) Specify a context for the object.
context context-name
By default, no context is specified for an object.
8.      (Optional.) Enable wildcard search for contexts.
wildcard context
By default, the context for an object is fully specified.
This command must be used in conjunction with the context context-name command.
Configuring a notification action for an event
When you enable a notification action, a notification entry is created automatically. All fields in the entry have default values.
To configure a notification action:
Step
Remarks
N/A
2.      Enter event view
N/A
3.      Enable the notification action and enter notification action view.
action notification
N/A
4.      Specify a notification OID.
By default, no notification OID is specified.
5.      Specify an object list to be added to the notification triggered by the event.
By default, no object list is specified for the notification action.
You can specify a Boolean test, an existence test, or a threshold test for a trigger. For more information, see "Configuring a Boolean trigger test," "Configuring an existence trigger test," and "Configuring a threshold trigger test."
To configure a trigger:
Step
Remarks
N/A
2.      Create a trigger and enter its view, or enter the view of an existing trigger.
snmp mib event trigger owner trigger-owner name trigger-name
By default, no triggers exist.
3.      (Optional.) Configure a description for the trigger.
By default, a trigger does not have a description.
4.      Set the sampling interval.
frequency interval
By default, the sampling interval is 600 seconds.
Make sure the sampling interval is greater than or equal to the Event MIB minimum sampling interval.
5.      Specify the sampling method.
sample { absolute | delta }
The default sampling method is absolute.
6.      Specify the object to be sampled by its OID.
By default, the OID is 0.0. No object is specified for a trigger.
The mteTriggerEnabled and mteTriggerTargetTag objects are read-only and cannot be sampled.
7.      Enable wildcard search for OIDs.
wildcard oid
By default, the object to be monitored is fully specified.
8.      (Optional.) Configure a context for the monitored object.
By default, no context is configured for a monitored object.
9.      (Optional.) Enable wildcard search for contexts.
wildcard context
By default, the context for a monitored object is fully specified.
10.   (Optional.) Specify the object list to be added to the notification triggered by the event.
By default, no object list is specified for a trigger.
11.   Specify a test type for the trigger.
test { boolean | existence | threshold }
By default, no test type is specified for a trigger.
12.   Enable the trigger.
trigger enable
By default, a trigger is disabled.
When you enable a Boolean trigger test, a Boolean entry is created automatically. All fields in the entry have default values.
To configure a Boolean trigger test:
Step
Remarks
N/A
2.      Enter trigger view.
N/A
3.      Enter trigger-Boolean view.
test boolean
N/A
4.      Specify a Boolean comparison type.
comparison { equal | greater | greaterorequal | less | lessorequal | unequal }
The default Boolean comparison type is unequal.
5.      Set the reference value for the Boolean trigger test.
value integer-value
The default reference value for a Boolean trigger test is 0.
6.      Configure the event for the Boolean trigger test.
By default, no event is configured for a Boolean trigger test.
7.      (Optional.) Specify the object list to be added to the notification triggered by the event.
By default, no object list is specified for a Boolean trigger test.
8.      (Optional.) Enable the event to be triggered when the trigger condition is met at the first sampling.
startup enable
By default, the event is triggered when the trigger condition is met at the first sampling.
When you enable an existence trigger test, an existence entry is created automatically. All fields in the entry have default values.
To configure an existence trigger test:
Step
Remarks
N/A
N/A
3.      Enter trigger-existence view.
test existence
N/A
4.      Specify the event for the existence trigger test.
By default, no event is specified for an existence trigger test.
5.      (Optional.) Specify the object list to be added to the notification triggered by the event.
By default, no object list is specified for an existence trigger test.
6.      Specify an existence trigger test type.
type { absent | changed | present }
The default existence trigger test types are present and absent.
7.      Specify an existence trigger test type for the first sampling.
startup { absent | present }
For the first sampling, you must execute the startup { absent | present } command to enable the event trigger.
By default, both the present and absent existence trigger test types are allowed for the first sampling.
When you enable a threshold trigger test, a threshold entry is created automatically. All fields in the entry have default values.
To configure a threshold trigger test:
Step
Remarks
N/A
You can only specify an existing SNMPv3 user as the trigger owner.
3.      Enter trigger-threshold view.
test boolean
N/A
4.      Specify the object list to be added to the notification triggered by the event.
By default, no object list is specified for a threshold trigger test.
5.      (Optional.) Specify the type of the threshold trigger test for the first sampling.
startup { falling | rising | rising-or-falling }
For the first sampling, you must execute the startup { falling | rising | rising-or-falling } command to enable the event trigger.
The default threshold trigger test type for the first sampling is rising-or-falling.
6.      Specify the delta falling threshold and the falling alarm event triggered when the sampled value is smaller than or equal to the threshold.
delta falling { event owner event-owner name event-name | value integer-value }
By default, the delta falling threshold is 0, and no falling alarm event is specified.
7.      Specify the delta rising threshold and the rising alarm event triggered when the sampled value is greater than or equal to the threshold.
delta rising { event owner event-owner name event-name | value integer-value }
By default, the delta rising threshold is 0, and no rising alarm event is specified.
8.      Specify the falling threshold and the falling alarm event triggered when the sampled value is smaller than or equal to the threshold.
By default, the falling threshold is 0, and no falling alarm event is specified.
9.      Specify the rising threshold and the ring alarm event triggered when the sampled value is greater than or equal to the threshold.
By default, the rising threshold is 0, and no rising alarm event is specified.
To report critical Event MIB events to an NMS, enable SNMP notifications for Event MIB. For Event MIB event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
To configure SNMP notifications for Event MIB:
Step
Remarks
N/A
2.      Enable snmp notifications for Event MIB.
snmp-agent trap enable event-mib
By default, SNMP notifications are enabled for Event MIB.
Displaying and maintaining the Event MIB
Display global Event MIB configuration and statistics.
display snmp mib event summary
Display trigger information.
display snmp mib event trigger [ owner trigger-owner name trigger-name ]
Display event information.
display snmp mib event event [ owner event-owner name event-name ]
Display object list information.
display snmp mib event object list [ owner group-owner name group-name ]
Display Event MIB configuration and statistics.
Event MIB configuration examples
Existence trigger test configuration example
Network requirements
As shown in Figure 2, the device acts as the agent. Use Event MIB to monitor the device. When interface hot-swap or virtual interface creation or deletion occurs on the device, the agent sends an mteTriggerFired notification to the NMS.
Figure 2 Network diagram
Configuration procedure
1.      Configure the device:
# Add the user owner1 to the SNMPv3 group g3. Assign g3 the right to access the MIB view a.
[Sysname] snmp-agent usm-user v3 owner1 g3
[Sysname] snmp-agent group v3 g3 read-view a write-view a notify-view a
[Sysname] snmp-agent mib-view included a iso
# Set the SNMP context to contextnameA.
[Sysname] snmp-agent context contextnameA
# Configure the device to use the username owner1 to send SNMPv3 notifications to the NMS at 192.168.1.26.
[Sysname] snmp-agent target-host trap address udp-domain 192.168.1.26 params securityname owner1 v3
[Sysname] snmp-agent trap enable event-mib
2.      Set the Event MIB minimum sampling interval to 50 seconds and set the maximum number to 100 for object instances that can be concurrently sampled.
[Sysname] snmp mib event sample minimum 50
[Sysname] snmp mib event sample instance maximum 100
3.      Configure a trigger:
# Create a trigger. Specify its owner as owner1 and its name as triggerA.
[Sysname] snmp mib event trigger owner owner1 name triggerA
# Set the sampling interval to 60 seconds. Make sure the sampling interval is greater than or equal to the Event MIB minimum sampling interval.
[Sysname-trigger-owner1-triggerA] frequency 60
# Specify the object IfIndex OID 1.3.6.1.2.1.2.2.1.1 as the monitored object. Enable wildcard search for OIDs.
[Sysname-trigger-owner1-triggerA] oid 1.3.6.1.2.1.2.2.1.1
[Sysname-trigger-owner1-triggerA] wildcard oid
# Configure the context contextnameA for the monitored object and enable wildcard search for contexts.
[Sysname-trigger-owner1-triggerA] context contextnameA
[Sysname-trigger-owner1-triggerA] wildcard context
# Specify the existence trigger test for the trigger.
[Sysname-trigger-owner1-triggerA] test existence
[Sysname-trigger-owner1-triggerA-existence] quit
# Enable the trigger.
[Sysname-trigger-owner1-triggerA] trigger enable
[Sysname-trigger-owner1-triggerA] quit
# Display Event MIB brief information.
[Sysname] display snmp mib event summary
TriggerFailures               : 0
EventFailures                 : 0
SampleMinimum                 : 50
SampleInstanceMaximum         : 100
SampleInstance                : 20
SampleInstancesHigh           : 20
SampleInstanceLacks           : 0
# Display information about the trigger with the owner owner1 and the name trigger A.
[Sysname] display snmp mib event trigger owner owner1 name triggerA
Trigger entry triggerA owned by owner1:
  TriggerComment              : N/A
  TriggerTest                 : existence
  TriggerSampleType           : absoluteValue
  TriggerValueID              : 1.3.6.1.2.1.2.2.1.1<ifIndex>
  TriggerValueIDWildcard      : true
  TriggerTargetTag            : N/A
  TriggerContextName          : contextnameA
  TriggerContextNameWildcard  : true
  TriggerFrequency(in seconds): 60
  TriggerObjOwner             : N/A
  TriggerObjName              : N/A
  TriggerEnabled              : true
  Existence entry:
   ExiTest                    : present | absent
   ExiStartUp                 : present | absent
   ExiObjOwner                : N/A
   ExiObjName                 : N/A
   ExiEvtOwner                : N/A
   ExiEvtName                 : N/A
# Create VLAN-interface 2 on the device.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname] interface vlan 2
The NMS receives an mteTriggerFired notification from the device.
Boolean trigger test configuration example
As shown in Figure 2, the device acts as the agent. The NMS uses SNMPv3 to monitor and manage the device. Configure a trigger and configure a Boolean trigger test for the trigger. When the trigger condition is met, the device sends an mteTriggerFired notification to the NMS.
Figure 3 Network diagram
# Enable SNMP notifications for Event MIB.
3.      Configure the Event MIB object lists. When a notification action is triggered, the system adds the objects in the specified object list to the notification.
[Sysname] snmp mib event object list owner owner1 name objectA 1 oid 1.3.6.1.4.1.25506.2.6.1.1.1.1.6.11
[Sysname] snmp mib event object list owner owner1 name objectB 1 oid 1.3.6.1.4.1.25506.2.6.1.1.1.1.7.11
[Sysname] snmp mib event object list owner owner1 name objectC 1 oid 1.3.6.1.4.1.25506.2.6.1.1.1.1.8.11
4.      Configure an event:
# Create an event. Specify its owner as owner1 and its name as EventA.
[Sysname] snmp mib event owner owner1 name EventA
# Specify the notification action for the event.
[Sysname-event-owner1-EventA] action notification
# Specify the notification object hh3cEntityExtMemUsageThresholdNotification by its OID 1.3.6.1.4.1.25506.2.6.2.0.5 for the notification.
[Sysname-event-owner1-EventA-notification] oid 1.3.6.1.4.1.25506.2.6.2.0.5
# Specify the object list to be added to the notification when the notification action is triggered
[Sysname-event-owner1-EventA-notification] object list owner owner1 name objectC
[Sysname-event-owner1-EventA-notification] quit
# Enable the event.
[Sysname-event-owner1-EventA] event enable
[Sysname-event-owner1-EventA] quit
5.      Configure a trigger:
# Set the sampling interval to 60 seconds. Make sure the interval is greater than or equal to the global minimum sampling interval.
# Specify the monitored object by its OID.
[Sysname-trigger-owner1-triggerA] oid 1.3.6.1.4.1.25506.2.6.1.1.1.1.9.11
# Specify the object list to be added to the notification when the notification action is triggered.
[Sysname-trigger-owner1-triggerA] object list owner owner1 name objectA
# Enable the Boolean trigger test. Specify the comparison type, reference value, event, and object list for the test.
[Sysname-trigger-owner1-triggerA-boolean] comparison greater
[Sysname-trigger-owner1-triggerA-boolean] value 10
[Sysname-trigger-owner1-triggerA-boolean] event owner owner1 name EventA
[Sysname-trigger-owner1-triggerA-boolean] object list owner owner1 name objectB
[Sysname-trigger-owner1-triggerA-boolean] quit
# Display Event MIB configuration and statistics
TriggerFailures               : 0
EventFailures                 : 0
SampleMinimum                 : 50
SampleInstance                : 1
SampleInstancesHigh           : 1
# Display information about the Event MIB object lists.
[Sysname] display snmp mib event object list
Object list objectA owned by owner1:
  ObjIndex                    : 1
  ObjID                       : 1.3.6.1.4.1.25506.2.6.1.1.1.1.6.11<hh3cEntityExt
CpuUsage.11>
  ObjIDWildcard               : false
Object list objectB owned by owner1:
  ObjIndex                    : 1
  ObjID                       : 1.3.6.1.4.1.25506.2.6.1.1.1.1.7.11<hh3cEntityExt
CpuUsageThreshold.11>
Object list objectC owned by owner1:
  ObjIndex                    : 1
  ObjID                       : 1.3.6.1.4.1.25506.2.6.1.1.1.1.8.11<hh3cEntityExt
MemUsage.11>
# Display information about the event.
[Sysname]display snmp mib event event owner owner1 name EventA
Event entry EventA owned by owner1:
EvtComment                  : N/A
EvtAction                   : notification
EvtEnabled                  : true
Notification entry:
NotifyOID                  : 1.3.6.1.4.1.25506.2.6.2.0.5<hh3cEntityExtMemUsag
eThresholdNotification>
NotifyObjOwner             : owner1
NotifyObjName              : objectC
# Display information about the trigger.
  TriggerTest                 : boolean
  TriggerValueID              : 1.3.6.1.4.1.25506.2.6.1.1.1.1.9.11<hh3cEntityExt
MemUsageThreshold.11>
  TriggerValueIDWildcard      : false
  TriggerContextName          : N/A
  TriggerContextNameWildcard  : false
  TriggerObjOwner             : owner1
  TriggerObjName              : objectA
  Boolean entry:
   BoolCmp                    : greater
   BoolValue                  : 10
   BoolStartUp                : true
   BoolObjOwner               : owner1
   BoolObjName                : objectB
   BoolEvtOwner               : owner1
   BoolEvtName                : EventA
# When the value of the monitored object 1.3.6.1.4.1.25506.2.6.1.1.1.1.9.11 is greater than 10, the NMS receives an mteTriggerFired notification.
Threshold trigger test configuration example
As shown in Figure 2, the device acts as the agent. The NMS uses SNMPv3 to monitor and manage the device. Configure a trigger and configure a threshold trigger test for the trigger. When the trigger conditions are met, the agent sent an mteTriggerFired notification to the NMS.
Figure 4 Network diagram
# Add the user named owner1 to the SNMPv3 group g3. Assign g3 the right to access the MIB view a.
# Configure the agent to use the username owner1 to send SNMPv3 notifications to the NMS at 192.168.1.26.
2.      Set the Event MIB minimum sampling interval to 50 seconds and set the maximum number to 10 for object instances that can be concurrently sampled.
# Set the sampling interval to 60 seconds. Make sure the interval is greater than or equal to the Event MIB minimum sampling interval.
# Specify the monitored object.
[Sysname-trigger-owner1-triggerA] oid 1.3.6.1.4.1.25506.2.6.1.1.1.1.7.11
# Enable the threshold trigger test. Specify the rising threshold, falling threshold, delta rising threshold, and delta falling threshold for the test.
[Sysname-trigger-owner1-triggerA] test threshold
[Sysname-trigger-owner1-triggerA-threshold] rising value 3
[Sysname-trigger-owner1-triggerA-threshold] falling value 1
[Sysname-trigger-owner1-triggerA-threshold] delta rising value 80
[Sysname-trigger-owner1-triggerA-threshold] delta falling value 10
[Sysname-trigger-owner1-triggerA-threshold] quit
# Display Event MIB configuration and statistics.
TriggerFailures               : 0
EventFailures                 : 0
SampleMinimum                 : 50
SampleInstance                : 1
  TriggerTest                 : threshold
  TriggerValueID              : 1.3.6.1.4.1.25506.2.6.1.1.1.1.7.11<hh3cEntityExt
  TriggercontextNameWildcard  : false
Threshold entry:
   ThresStartUp               : risingOrFalling
   ThresRising                : 80
   ThresFalling               : 10
   ThresDeltaRising           : 0
   ThresDeltaFalling          : 0
   ThresObjOwner              : N/A
   ThresObjName               : N/A
   ThresRisEvtOwner           : N/A
   ThresRisEvtName            : N/A
   ThresFalEvtOwner           : N/A
   ThresFalEvtName            : N/A
   ThresDeltaRisEvtOwner      : N/A
   ThresDeltaRisEvtName       : N/A
   ThresDeltaFalEvtOwner      : N/A
   ThresDeltaFalEvtName       : N/A
# When the rising threshold of the monitored object 1.3.6.1.4.1.25506.2.6.1.1.1.1.7.11 is greater than 80, the NMS receives an mteTriggerFired notification.
