H3C SR6600&SR6600-X Routers Configuration Examples-6W100
HomeSupportRoutersConfigure & DeployConfiguration ExamplesH3C SR6600&SR6600-X Routers Configuration Examples-6W100
03-H3C SR6600&SR6600-X Routers Ethernet Link Aggregation Configuration Examples
SR6600 Router Series
SR6600-X Router Series
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved.
Introduction· 1
Prerequisites· 1
Example: Configuring Layer 3 link aggregation· 1
Network requirements· 1
Software version used· 1
Configuration restrictions and guidelines· 1
Configuration procedures· 1
Verifying the configuration· 2
Configuration files· 3
Example: Configuring Layer 3 link aggregation load sharing· 4
Network requirements· 4
Software version used· 4
Configuration restrictions and guidelines· 4
Configuration procedures· 4
Verifying the configuration· 5
Configuration files· 6
Example: Configuring link aggregation between H3C and Cisco devices· 7
Network requirements· 7
Requirements analysis· 7
Software version used· 7
Configuration restrictions and guidelines· 7
Configuration procedures· 8
Verifying the configuration· 8
Configuration files· 10
Related documentation· 11
Introduction
This document provides Ethernet link aggregation configuration examples.
This document assumes that you have basic knowledge of Ethernet link aggregation.
On the network as shown in Figure 1, perform the following tasks:
·     Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
·     Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 1 Network diagram
This configuration example was created and verified on R7607.
An aggregation group can operate in static or dynamic mode. You can choose one mode as required.
·     In a static aggregation group, the aggregation states of the member ports are not affected by the peer ports. Static link aggregation is stable.
·     In a dynamic aggregation group, the local system and the peer system automatically maintain the aggregation states of the member ports. Dynamic link aggregation reduces the administrators' workload.
1.     Configure Device A:
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡     Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
# Assign ports Ten-GigabitEthernet 2/1/1 through Ten-GigabitEthernet 2/1/3 to aggregation group 1.
[DeviceA] interface range gigabitethernet 2/1/1 to gigabitethernet 2/1/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A when you use static aggregation mode.
[DeviceA] display link-aggregation verbose
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Static
  Port             Status  Priority Oper-Key
  GE2/1/1          S       32768    1
  GE2/1/2          S       32768    1
  GE2/1/3          S       32768    1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
# Display detailed information about the link aggregation groups on Device A when you use dynamic aggregation mode.
Aggregation Mode: Dynamic
Local:
  Port             Status  Priority Oper-Key  Flag
  GE2/1/1          S       32768    1         {ACDEF}
  GE2/1/2          S       32768    1         {ACDEF}
  GE2/1/3          S       32768    1         {ACDEF}
Remote:
  Actor            Partner Priority Oper-Key  SystemID               Flag
  GE2/1/1          1       32768    1         0x8000, 000f-e267-57ad {ACDEF}
  GE2/1/2          2       32768    1         0x8000, 000f-e267-57ad {ACDEF}
  GE2/1/3          3       32768    1         0x8000, 000f-e267-57ad {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
·     Device A:
¡     In the static aggregation mode:
interface route-aggregation1
¡     In the dynamic aggregation mode:
interface GigabitEthernet2/1/1
 port link-mode route
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
·     Device B:
The configuration file on Device B is similar as the configuration file on Device A.
On the network as shown in Figure 2, perform the following tasks:
·     Configure Layer 3 static aggregation groups 1 and 2 on Device A and Device B.
·     Configure link aggregation group 1 to load share packets based on source IP addresses.
·     Configure link aggregation group 2 to load share packets based on destination IP addresses.
Figure 2 Network diagram
You can configure global or group-specific link aggregation load sharing mode. A link aggregation group preferentially uses the group-specific load sharing mode. This example uses the group-specific load sharing mode.
# Configure Layer 3 aggregation group 1 to load share packets based on source IP addresses.
[DeviceA-Route-Aggregation1] link-aggregation load-sharing mode source-ip
# Create Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA] interface route-aggregation 2
# Configure Layer 3 aggregation group 2 to load share packets based on destination IP addresses.
[DeviceA-Route-Aggregation2] link-aggregation load-sharing mode destination-ip
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA-Route-Aggregation2] ip address 192.168.2.1 24
[DeviceA-Route-Aggregation2] quit
# Assign Layer 3 Ethernet interfaces GigabitEthernet 2/1/1 and Ten-GigabitEthernet 2/1/2 to aggregation group 1.
[DeviceA] interface range gigabitethernet 2/1/1 gigabitethernet 2/1/2
# Assign Layer 3 Ethernet interfaces GigabitEthernet 2/1/3 and Ten-GigabitEthernet 2/1/4 to aggregation group 2.
[DeviceA] interface range gigabitethernet 2/1/3 gigabitethernet 2/1/4
[DeviceA-if-range] port link-aggregation group 2
# Display detailed information about all aggregation groups on Device A.
  GE2/1/1          S       32768    1
  GE2/1/2          S       32768    1
Aggregate Interface: Route-Aggregation2
  GE2/1/3          S       32768    2
  GE2/1/4          S       32768    2
The output shows that:
·     Link aggregation groups 1 and 2 are both load-shared Layer 3 static aggregation groups.
·     Each aggregation group contains two Selected ports.
# Display the group-specific load sharing modes of all aggregation groups on Device A.
[DeviceA] display link-aggregation load-sharing mode interface
Route-Aggregation1 Load-Sharing Mode:
source-ip address
Route-Aggregation2 Load-Sharing Mode:
destination-ip address
·     Link aggregation group 1 load shares packets based on source IP addresses.
·     Link aggregation group 2 load shares packets based on destination IP addresses.
Configuration files
·     Device A:
interface Route-Aggregation1
interface Route-Aggregation2
 ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet2/1/4
·     Device B:
On the network as shown in Figure 3, perform the following tasks:
·     Configure a Layer 3 dynamic aggregation group on both Device A (H3C device) and Device B (Cisco device).
Figure 3 Network diagram
To meet the network requirements, you must perform the following tasks:
·     To configure a Layer 3 dynamic aggregation group on Device A, assign GigabitEthernet 2/1/1 through GigabitEthernet 2/1/3 to the aggregation group.
·     To configure a Layer 3 dynamic aggregation group on Device B, configure LACP to manage channeling and set the LACP operating mode to active.
In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, H3C recommends using dynamic aggregation.
# Create Layer 3 aggregate interface Route-Aggregation 1, and configure the link aggregation mode as dynamic.
<DeviceA> system
# Configure an IP address and subnet mask for Route-Aggregation 1.
# Assign Layer 3 Ethernet interfaces GigabitEthernet 2/1/1 through GigabitEthernet 2/1/3 to aggregation group 1.
2.     Configure Device B:
# Configure an IP address and subnet mask for interface port-channel 1.
DeviceB>enable
DeviceB#configure terminal
DeviceB(config)#interface port-channel 1
DeviceB(config-if)#ip address 192.168.1.2 255.255.255.0
# Configure LACP to manage channeling. By default, the PAgP is used.
DeviceB(config-if)#channel-protocol lacp
DeviceB(config-if)#exit
# Enter interface range view.
DeviceB(config)#interface range gigabitethernet 1/1 – 3
# Assign GigabitEthernet 1/1 through GigabitEthernet 1/3 to channel group 1 and set the LACP operating mode to active.
DeviceB(config-if-range)#no switchport
DeviceB(config-if-range)#channel-group 1 mode active
DeviceB(config-if-range)#exit
Local:
Remote:
# Display summary information about Ethernet channel group 1 on Device B.
DeviceB#show etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)           LACP   Gi1/1(P) Gi1/2(P) Gi1/3(P)
# Display port-channel information for Ethernet channel group 1 on Device B.
DeviceB#show etherchannel port-channel
                Channel-group listing:
Group: 1
                Port-channels in the group:
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 00d:00h:26m:35s
Logical slot/port   = 2/1       Number of ports = 3
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel
Protocol            =   LACP
Port Security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi1/1    Active             0
  0     00     Gi1/2    Active             0
  0     00     Gi1/3    Active             0
Time since last port bundled:    00d:00h:12m:13s    Gi0/2
Configuration files
·     Device A:
·     Device B:
Building configuration...
Current configuration : 1444 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
no service password-encryption
hostname Switch
interface GigabitEthernet1/1
 no switchport
interface GigabitEthernet1/2
 no switchport
interface GigabitEthernet1/3
 no switchport
interface Port-channel 1
 no switchport
·     H3C SR6600 SR6600-X Routers Layer 2—LAN Switching Command Reference-Release 7607
·     H3C SR6600 SR6600-X Routers Layer 2—LAN Switching Configuration Guide-Release 7607
