H3C SR6600&SR6600-X Routers Configuration Examples-6W100
HomeSupportRoutersConfigure & DeployConfiguration ExamplesH3C SR6600&SR6600-X Routers Configuration Examples-6W100
01-H3C SR6600&SR6600-X Routers Basic MPLS Configuration Examples
SR6600 Router Series
SR6600-X Router Series
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved.
Introduction· 1
Prerequisites· 1
Example: Configuring static LSPs· 1
Network requirements· 1
Requirements analysis· 2
Software version used· 2
Configuration restrictions and guidelines· 2
Configuration procedures· 2
Verifying the configuration· 4
Configuration files· 4
Example: Configuring LDP LSPs· 6
Network requirements· 6
Requirements analysis· 6
Software version used· 7
Configuration procedures· 7
Verifying the configuration· 12
Configuration files· 13
Related documentation· 17
Introduction
This document provides static LSP and LDP LSP configuration examples.
The following table shows the differences between a static LSP and an LDP LSP:
LSP type
Establishment
Feature
Application scenario
Static LSP
You establish a static LSP by specifying the incoming and outgoing labels on ingress, transit, and egress nodes of the forwarding path.
·     Consumes fewer resources.
·     Cannot automatically adapt to network topology changes.
Small and stable networks with simple topologies.
LDP LSP
You establish an LDP LSP by configuring MPLS LDP.
LDP classifies FECs, distributes FEC-label mappings, and establishes and maintains LSPs.
·     Consumes more resources.
·     Automatically adapts to network topology changes.
Large and unstable networks with complicated topologies.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of MPLS and LDP.
As shown in Figure 1, establish static LSPs between Router A and Router C to allow communication between subnets 172.20.2.0/24 and 172.16.2.0/24 over the MPLS network.
Figure 1 Network diagram
To meet the network requirements, you must perform the following tasks:
·     LSPs are unidirectional. To ensure that data can be bidirectionally forwarded, configure an LSP for each direction of the data forwarding path, and specify the ingress, transit, and egress nodes for each LSP.
·     To direct traffic to an LSP for MPLS forwarding, make sure the ingress node has a route to the FEC destination of the LSP. This example uses a static route. Route configuration is not needed on the transit and egress nodes.
This configuration example was created and verified on R7607.
When you configure a static LSP, follow these restrictions and guidelines:
·     Make sure the outgoing label specified on an LSR is the same as the incoming label specified on the directly connected downstream LSR.
·     If you configure a static IP route for the LSP, specify the same next hop or outgoing interface for the static route and the static LSP.
·     On the ingress or transit node of the static LSP, do not specify the public address of a local interface as the next hop address of the static LSP.
·     MPLS adds a label or multiple labels to packets. After MPLS is enabled on an interface, configure jumboframe support on the interface to avoid MPLS packet dropping when the packet size exceeds the interface MPU.
1.     Configure IP addresses and masks for interfaces, including the loopback interfaces, as shown in Figure 1. (Details not shown.)
2.     Configure a static route to the destination address of each LSP:
# Configure a static route to the FEC destination of the LSP from Router A to Router C.
[RouterA] ip route-static 172.16.2.1 24 10.1.1.2
# Configure a static route to the FEC destination of the LSP from Router C to Router A.
<RouterC> system-view
[RouterC] ip route-static 172.20.2.1 24 20.1.1.1
# Verify that the static route has been created on the ingress nodes, for example, on Router A.
Destinations : 18        Routes : 18
0.0.0.0/32         Direct  0   0           127.0.0.1       InLoop0
1.1.1.9/32         Direct  0   0           127.0.0.1       InLoop0
10.1.1.0/24        Direct  0   0           10.1.1.1        GE2/1/2
10.1.1.0/32        Direct  0   0           10.1.1.1        GE2/1/2
10.1.1.1/32        Direct  0   0           127.0.0.1       InLoop0
10.1.1.255/32      Direct  0   0           10.1.1.1        GE2/1/2
127.0.0.0/8        Direct  0   0           127.0.0.1       InLoop0
127.0.0.0/32       Direct  0   0           127.0.0.1       InLoop0
172.16.2.0/24      Static  60  0           10.1.1.2        GE2/1/2
172.20.2.0/24      Direct  0   0           172.20.2.1      GE2/1/1
172.20.2.0/32      Direct  0   0           172.20.2.1      GE2/1/1
172.20.2.1/32      Direct  0   0           127.0.0.1       InLoop0
172.20.2.255/32    Direct  0   0           172.20.2.1      GE2/1/1
224.0.0.0/4        Direct  0   0           0.0.0.0         NULL0
224.0.0.0/24       Direct  0   0           0.0.0.0         NULL0
255.255.255.255/32 Direct  0   0           127.0.0.1       InLoop0
3.     Configure basic MPLS on the routers:
# Configure Router A.
[RouterA] mpls lsr-id 1.1.1.9
[RouterA] interface gigabitethernet 2/1/2
[RouterA-GigabitEthernet2/1/2] mpls enable
[RouterA-GigabitEthernet2/1/2] quit
# Configure Router B.
[RouterB] mpls lsr-id 2.2.2.9
[RouterB] interface gigabitethernet 2/1/1
[RouterB-GigabitEthernet2/1/1] mpls enable
[RouterB-GigabitEthernet2/1/1] quit
[RouterB] interface gigabitethernet 2/1/2
[RouterB-GigabitEthernet2/1/2] mpls enable
[RouterB-GigabitEthernet2/1/2] quit
# Configure Router C.
[RouterC] mpls lsr-id 3.3.3.9
[RouterC] interface gigabitethernet 2/1/1
[RouterC-GigabitEthernet2/1/1] mpls enable
[RouterC-GigabitEthernet2/1/1] quit
4.     Configure a static LSP from Router A to Router C:
# Configure the ingress node Router A. Specify the LSP name as AtoC, destination address as 172.16.2.1/24, next hop as 10.1.1.2, and outgoing label as 30.
[RouterA] static-lsp ingress AtoC destination 172.16.2.1 24 nexthop 10.1.1.2 out-label 30
# Configure the transit node Router B. Specify the LSP name as AtoC, incoming label as 30, next hop as 20.1.1.2, and outgoing label as 50.
[RouterB] static-lsp transit AtoC in-label 30 nexthop 20.1.1.2 out-label 50
# Configure the egress node Router C. Specify the LSP name as AtoC and incoming label as 50.
[RouterC] static-lsp egress AtoC in-label 50
5.     Configure a static LSP from Router C to Router A:
# Configure the ingress node Router C. Specify the LSP name as CtoA, destination address as 172.20.2.1/24, next hop as 20.1.1.1, and outgoing label as 40.
[RouterC] static-lsp ingress CtoA destination 172.20.2.1 24 nexthop 20.1.1.1 out-label 40
# Configure the transit node Router B. Specify the LSP name as CtoA, incoming label as 40, next hop as 10.1.1.1, and outgoing label as 70.
[RouterB] static-lsp transit CtoA in-label 40 nexthop 10.1.1.1 out-label 70
# Configure the egress node Router A. Specify the LSP name as CtoA and incoming label as 70.
[RouterA] static-lsp egress CtoA in-label 70
# Display static LSP information on routers, for example, on Router A.
[RouterA] display mpls static-lsp
Total: 2
Name            FEC                In/Out Label Nexthop/Out Interface    State
AtoC            172.16.2.0/24      NULL/30      10.1.1.2                 Up
CtoA            -/-                70/NULL      -                        Up
# Test the connectivity of the LSP from Router A to Router C.
[RouterA] ping mpls -a 172.20.2.1 ipv4 172.16.2.0 24
MPLS ping FEC 172.16.2.0/24 with 100 bytes of data:
100 bytes from 20.1.1.2: Sequence=1 time=3 ms
100 bytes from 20.1.1.2: Sequence=2 time=2 ms
100 bytes from 20.1.1.2: Sequence=3 time=2 ms
100 bytes from 20.1.1.2: Sequence=4 time=2 ms
100 bytes from 20.1.1.2: Sequence=5 time=27 ms
--- Ping statistics for FEC 172.16.2.0/24 ---
Round-trip min/avg/max = 2/7/27 ms
# Test the connectivity of the LSP from Router C to Router A.
[RouterC] ping mpls -a 172.16.2.1 ipv4 172.20.2.0 24
MPLS ping FEC 172.20.2.0/24 with 100 bytes of data:
100 bytes from 10.1.1.1: Sequence=1 time=3 ms
100 bytes from 10.1.1.1: Sequence=2 time=2 ms
100 bytes from 10.1.1.1: Sequence=3 time=2 ms
100 bytes from 10.1.1.1: Sequence=4 time=2 ms
100 bytes from 10.1.1.1: Sequence=5 time=27 ms
--- Ping statistics for FEC 172.20.2.0/24 ---
Configuration files
·     Router A:
 mpls lsr-id 1.1.1.9
interface LoopBack0
 ip address 1.1.1.9 255.255.255.255
interface GigabitEthernet2/1/1
 port link-mode route
ip address 172.20.2.1 255.255.255.0
interface GigabitEthernet2/1/2
 mpls enable
 ip route-static 172.16.2.0 24 10.1.1.2
 static-lsp ingress AtoC destination 172.16.2.0 24 nexthop 10.1.1.2 out-label 30
·     Router B:
 mpls lsr-id 2.2.2.9
interface LoopBack0
 ip address 2.2.2.9 255.255.255.255
 mpls enable
ip address 20.1.1.1 255.255.255.0
 mpls enable
·     Router C:
 mpls lsr-id 3.3.3.9
interface LoopBack0
 ip address 3.3.3.9 255.255.255.255
ip address 20.1.1.2 255.255.255.0
 mpls enable
ip address 172.16.2.1 255.255.255.0
 ip route-static 172.20.2.1 255.255.255.0 20.1.1.1
 static-lsp ingress CtoA destination 172.20.2.0 24 nexthop 20.1.1.1 out-label 40
As shown in Figure 2, two paths are available for PE 1 and PE 2 to communicate with each other.
·     Configure LDP to establish LSPs between PE 1 and PE 2 to allow communication between subnets 192.168.10.0/24 and 192.168.20.0/24 over the MPLS network.
¡     Use LSP 1 as the primary path.
¡     Use LSP 2 as the backup path, which takes over LSP 1 when LSP 1 fails.
·     Configure LDP to establish LSPs only for destinations 1.1.1.1/32, 2.2.2.2/32, 3.3.3.3/32, 4.4.4.4/32, 5.5.5.5/32, 192.168.10.0/24, and 192.168.20.0/24.
Figure 2 Network diagram
·     To establish LDP LSPs, configure a routing protocol to ensure IP connectivity among the devices. This example uses OSPF.
·     To use LSP 1 as the primary path and LSP 2 as the backup, configure the routes for LSP 1 and LSP 2 as the primary and backup routes, respectively. This example uses OSPF. The OSPF cost of the route for LSP 1 is smaller than that for LSP 2. Therefore, LSP 1 is used when it is available.
·     To control LSP establishment, configure LSP generation policies on each LSR.
1.     Configure IP addresses and masks for interfaces, including the loopback interfaces, as shown in Figure 2. (Details not shown.)
2.     Configure OSPF on each router to ensure IP connectivity:
# Configure PE 1.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 192.168.10.0 0.0.0.255
[PE1-ospf-1] quit
# Configure P 1.
[P1] ospf
[P1-ospf-1] area 0
[P1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 12.12.12.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] quit
[P1-ospf-1] quit
# Configure P 2.
[P2] ospf
[P2-ospf-1] area 0
[P2-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 14.14.14.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] network 45.45.45.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] quit
[P2-ospf-1] quit
# Configure P 3.
[P3] ospf
[P3-ospf-1] area 0
[P3-ospf-1-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[P3-ospf-1-area-0.0.0.0] network 45.45.45.0 0.0.0.255
[P3-ospf-1-area-0.0.0.0] network 35.35.35.0 0.0.0.255
[P3-ospf-1-area-0.0.0.0] quit
[P3-ospf-1] quit
# Configure PE 2.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 23.23.23.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 35.35.35.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 192.168.20.0 0.0.0.255
[PE2-ospf-1] quit
# On each router, for example, on PE 1, verify that the routers have learned the routes to each other.
[PE1] display ospf routing
                   Routing Table
 Routing for network
 45.45.45.0/24      2        Transit 14.14.14.4      5.5.5.5         0.0.0.0
 35.35.35.0/24      3        Transit 14.14.14.4      5.5.5.5         0.0.0.0
 35.35.35.0/24      3        Transit 12.12.12.2      5.5.5.5         0.0.0.0
 192.168.10.0/24    1        Stub    192.168.10.1    1.1.1.1         0.0.0.0
 5.5.5.5/32         2        Stub    14.14.14.4      5.5.5.5         0.0.0.0
 14.14.14.0/24      1        Transit 14.14.14.1      4.4.4.4         0.0.0.0
 23.23.23.0/24      2        Transit 12.12.12.2      3.3.3.3         0.0.0.0
 4.4.4.4/32         1        Stub    14.14.14.4      4.4.4.4         0.0.0.0
 3.3.3.3/32         2        Stub    12.12.12.2      3.3.3.3         0.0.0.0
 12.12.12.0/24      1        Transit 12.12.12.1      2.2.2.2         0.0.0.0
 2.2.2.2/32         1        Stub    12.12.12.2      2.2.2.2         0.0.0.0
 1.1.1.1/32         0        Stub    1.1.1.1         1.1.1.1         0.0.0.0
 192.168.20.0/24    3        Stub    12.12.12.2      3.3.3.3         0.0.0.0
# On each router, for example, on PE 1, verify that OSPF neighbor relationships in Full state have been established between PE 1, P devices, and PE 2.
[PE1] display ospf peer verbose
                  Neighbors
 Area 0.0.0.0 interface 14.14.14.1(GigabitEthernet2/1/2)'s neighbors
 Router ID: 4.4.4.4          Address: 14.14.14.4       GR state: Normal
   DR: 14.14.14.4  BDR: 14.14.14.1  MTU: 0
   Options is 0x42 (-|O|-|-|-|-|E|-)
   Dead timer due in 40  sec
   Neighbor is up for 00:03:30
   BFD status: Disabled
                  Neighbors
 Area 0.0.0.0 interface 12.12.12.1(GigabitEthernet2/1/1)'s neighbors
 Router ID: 2.2.2.2          Address: 12.12.12.2       GR state: Normal
   DR: 12.12.12.2  BDR: 12.12.12.1  MTU: 0
   Dead timer due in 36  sec
   Neighbor is up for 00:03:24
 Last Neighbor Down Event:
 Router ID: 4.4.4.4
 Local Address: 14.14.14.1
 Remote Address: 14.14.14.4
 Time: May 14 09:07:19 2017
 Reason: Reset ospf command was performed
3.     Configure basic MPLS and MPLS LDP:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] interface gigabitethernet 2/1/1
[PE1-GigabitEthernet2/1/1] mpls enable
[PE1-GigabitEthernet2/1/1] mpls ldp enable
[PE1-GigabitEthernet2/1/1] quit
[PE1] interface gigabitethernet 2/1/2
[PE1-GigabitEthernet2/1/2] mpls enable
[PE1-GigabitEthernet2/1/2] mpls ldp enable
[PE1-GigabitEthernet2/1/2] quit
# Configure P 1.
[P1] mpls lsr-id 2.2.2.2
[P1] mpls ldp
[P1-ldp] quit
[P1] interface gigabitethernet 2/1/1
[P1-GigabitEthernet2/1/1] mpls enable
[P1-GigabitEthernet2/1/1] mpls ldp enable
[P1-GigabitEthernet2/1/1] quit
[P1] interface gigabitethernet 2/1/2
[P1-GigabitEthernet2/1/2] mpls enable
[P1-GigabitEthernet2/1/2] mpls ldp enable
[P1-GigabitEthernet2/1/2] quit
# Configure P 2.
[P2] mpls lsr-id 4.4.4.4
[P2] mpls ldp
[P2-ldp] quit
[P2] interface gigabitethernet 2/1/1
[P2-GigabitEthernet2/1/1] mpls enable
[P2-GigabitEthernet2/1/1] mpls ldp enable
[P2-GigabitEthernet2/1/1] quit
[P2] interface gigabitethernet 2/1/2
[P2-GigabitEthernet2/1/2] mpls enable
[P2-GigabitEthernet2/1/2] mpls ldp enable
[P2-GigabitEthernet2/1/2] quit
# Configure P 3.
[P3] mpls lsr-id 5.5.5.5
[P3] mpls ldp
[P3-ldp] quit
[P3] interface gigabitethernet 2/1/1
[P3-GigabitEthernet2/1/1] mpls enable
[P3-GigabitEthernet2/1/1] mpls ldp enable
[P3-GigabitEthernet2/1/1] quit
[P3] interface gigabitethernet 2/1/2
[P3-GigabitEthernet2/1/2] mpls enable
[P3-GigabitEthernet2/1/2] mpls ldp enable
[P3-GigabitEthernet2/1/2] quit
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface gigabitethernet 2/1/1
[PE2-GigabitEthernet2/1/1] mpls enable
[PE2-GigabitEthernet2/1/1] mpls ldp enable
[PE2-GigabitEthernet2/1/1] quit
[PE2] interface gigabitethernet 2/1/2
[PE2-GigabitEthernet2/1/2] mpls enable
[PE2-GigabitEthernet2/1/2] mpls ldp enable
[PE2-GigabitEthernet2/1/2] quit
# On each router, for example, on PE 1, verify that LDP sessions in Operational state have been established between PE 1, P devices, and PE 2.
[PE1] display mpls ldp peer
Total number of peers: 2
Peer LDP ID             State         Role     GR   MD5  KA Sent/Rcvd
2.2.2.2:0               Operational   Passive  Off  Off  55/55
4.4.4.4:0               Operational   Passive  Off  Off  6/6
4.     Configure LSP generation policies:
# On PE 1, create IP prefix list PE1, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[PE1] ip prefix-list PE1 index 10 permit 1.1.1.1 32
[PE1] ip prefix-list PE1 index 20 permit 2.2.2.2 32
[PE1] ip prefix-list PE1 index 30 permit 3.3.3.3 32
[PE1] ip prefix-list PE1 index 40 permit 4.4.4.4 32
[PE1] ip prefix-list PE1 index 50 permit 5.5.5.5 32
[PE1] ip prefix-list PE1 index 60 permit 192.168.10.0 24
[PE1] ip prefix-list PE1 index 70 permit 192.168.20.0 24
[PE1] mpls ldp
[PE1-ldp] lsp-trigger prefix-list PE1
[PE1-ldp] quit
# On P 1, create IP prefix list P1, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[P1] ip prefix-list P1 index 10 permit 1.1.1.1 32
[P1] ip prefix-list P1 index 20 permit 2.2.2.2 32
[P1] ip prefix-list P1 index 30 permit 3.3.3.3 32
[P1] ip prefix-list P1 index 40 permit 4.4.4.4 32
[P1] ip prefix-list P1 index 50 permit 5.5.5.5 32
[P1] ip prefix-list P1 index 60 permit 192.168.10.0 24
[P1] ip prefix-list P1 index 70 permit 192.168.20.0 24
[P1] mpls ldp
[P1-ldp] lsp-trigger prefix-list P1
[P1-ldp] quit
# On P 2, create IP prefix list P2, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[P2] ip prefix-list P2 index 10 permit 1.1.1.1 32
[P2] ip prefix-list P2 index 20 permit 2.2.2.2 32
[P2] ip prefix-list P2 index 30 permit 3.3.3.3 32
[P2] ip prefix-list P2 index 40 permit 4.4.4.4 32
[P2] ip prefix-list P2 index 50 permit 5.5.5.5 32
[P2] ip prefix-list P2 index 60 permit 192.168.10.0 24
[P2] ip prefix-list P2 index 70 permit 192.168.20.0 24
[P2] mpls ldp
[P2-ldp] lsp-trigger prefix-list P2
[P2-ldp] quit
# On P 3, create IP prefix list P3, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[P3] ip prefix-list P3 index 10 permit 1.1.1.1 32
[P3] ip prefix-list P3 index 20 permit 2.2.2.2 32
[P3] ip prefix-list P3 index 30 permit 3.3.3.3 32
[P3] ip prefix-list P3 index 40 permit 4.4.4.4 32
[P3] ip prefix-list P3 index 50 permit 5.5.5.5 32
[P3] ip prefix-list P3 index 60 permit 192.168.10.0 24
[P3] ip prefix-list P3 index 70 permit 192.168.20.0 24
[P3] mpls ldp
[P3-ldp] lsp-trigger prefix-list P3
[P3-ldp] quit
# On PE 2, create IP prefix list PE2, and configure LDP to use only the routes permitted by the prefix list to establish LSPs.
[PE2] ip prefix-list PE2 index 10 permit 1.1.1.1 32
[PE2] ip prefix-list PE2 index 20 permit 2.2.2.2 32
[PE2] ip prefix-list PE2 index 30 permit 3.3.3.3 32
[PE2] ip prefix-list PE2 index 40 permit 4.4.4.4 32
[PE2] ip prefix-list PE2 index 50 permit 5.5.5.5 32
[PE2] ip prefix-list PE2 index 60 permit 192.168.10.0 24
[PE2] ip prefix-list PE2 index 70 permit 192.168.20.0 24
[PE2] mpls ldp
[PE2-ldp] lsp-trigger prefix-list PE2
[PE2-ldp] quit
# Display LDP LSP information on PE 1. The output shows that the next hop is P 1 for the LSP associated with FEC 192.168.20.0/24.
[PE1] display mpls ldp lsp
Status Flags: * - stale, L - liberal
Statistics:
  FECs: 7      Ingress LSPs: 5     Transit LSPs: 5     Egress LSPs: 2
FEC                In/Out Label    Nexthop         OutInterface
1.1.1.1/32         3/-
                   -/1151(L)
                   -/1151(L)
2.2.2.2/32         -/3             12.12.12.2      GE2/1/1
                   1151/3          12.12.12.2      GE2/1/1
                   -/1150(L)
3.3.3.3/32         -/1150          12.12.12.2      GE2/1/1
                   1150/1150       12.12.12.2      GE2/1/1
                   -/1148(L)
4.4.4.4/32         -/1149(L)
                   -/3             14.14.14.4      GE2/1/2
                   1149/3          14.14.14.4      GE2/1/2
5.5.5.5/32         -/1148(L)
                   -/1149          14.14.14.4      GE2/1/2
                   1148/1149       14.14.14.4      GE2/1/2
192.168.10.0/24    1147/-
192.168.20.0/24    -/1147          12.12.12.2      GE2/1/1
                   1146/1147       12.12.12.2      GE2/1/1
                   -/1147(L)
# Power down P 1 and execute the display mpls ldp lsp command on PE 1. The output shows that the next hop becomes P 2 for the LSP associated with FEC 192.168.20.0/24.
Statistics:
1.1.1.1/32         3/-
                   -/1150(L)
2.2.2.2/32         -/1149          14.14.14.4      GE2/1/2
                   1150/1149       14.14.14.4      GE2/1/2
3.3.3.3/32         -/1148          14.14.14.4      GE2/1/2
                   1147/1148       14.14.14.4      GE2/1/2
4.4.4.4/32         -/3             14.14.14.4      GE2/1/2
5.5.5.5/32         -/1151          14.14.14.4      GE2/1/2
                   1148/1151       14.14.14.4      GE2/1/2
192.168.10.0/24    1151/-
                   -/1146(L)
192.168.20.0/24    -/1147          14.14.14.4      GE2/1/2
                   1146/1147       14.14.14.4      GE2/1/2
# Use the following command on PE 1 to verify its connectivity to PE 2.
[PE1] ping mpls -a 192.168.10.1 ipv4 192.168.20.0 24
MPLS ping FEC 192.168.20.0/24 with 100 bytes of data:
100 bytes from 23.23.23.3: Sequence=1 time=2 ms
100 bytes from 23.23.23.3: Sequence=2 time=2 ms
100 bytes from 23.23.23.3: Sequence=3 time=2 ms
100 bytes from 23.23.23.3: Sequence=4 time=2 ms
100 bytes from 23.23.23.3: Sequence=5 time=2 ms
--- Ping statistics for FEC 192.168.20.0/24 ---
Round-trip min/avg/max = 2/2/2 ms
Configuration files
·     PE 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 1.1.1.1
mpls ldp
interface LoopBack0
 ip address 1.1.1.1 255.255.255.255
ip address 12.12.12.1 255.255.255.0
 mpls enable
 mpls ldp enable
ip address 14.14.14.1 255.255.255.0
 mpls enable
 mpls ldp enable
interface GigabitEthernet2/1/3
ip address 192.168.10.1 255.255.255.0
·     P 1:
ospf 1
 area 0.0.0.0
 mpls lsr-id 2.2.2.2
mpls ldp
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
ip address 12.12.12.2 255.255.255.0
 mpls enable
 mpls ldp enable
ip address 23.23.23.2 255.255.255.0
 mpls enable
 mpls ldp enable
·     P 2:
ospf 1
 area 0.0.0.0
 mpls lsr-id 4.4.4.4
mpls ldp
interface LoopBack0
 ip address 4.4.4.4 255.255.255.255
ip address 45.45.45.4 255.255.255.0
 mpls enable
 mpls ldp enable
 ip address 14.14.14.4 255.255.255.0
 mpls enable
 mpls ldp enable
·     P 3:
ospf 1
 area 0.0.0.0
 mpls lsr-id 5.5.5.5
mpls ldp
interface LoopBack0
ip address 35.35.35.5 255.255.255.0
 mpls enable
 mpls ldp enable
ip address 45.45.45.5 255.255.255.0
 mpls enable
 mpls ldp enable
·     PE 2:
ospf 1
 area 0.0.0.0
  network 33.0.0.0 0.0.0.255
 mpls lsr-id 3.3.3.3
mpls ldp
interface LoopBack0
 ip address 3.3.3.3 255.255.255.255
ip address 35.35.35.3 255.255.255.0
 mpls enable
 mpls ldp enable
ip address 23.23.23.3 255.255.255.0
 mpls enable
 mpls ldp enable
ip address 192.168.20.1 255.255.255.0
·     H3C SR6600 SR6600-X Routers MPLS Command Reference-Release 7607
·     H3C SR6600 SR6600-X Routers MPLS Configuration Guide-Release 7607
