- 03-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Bulk interface configuration
- 03-Ethernet interface configuration
- 04-Ethernet link aggregation configuration
- 05-DRNI configuration
- 06-Port isolation configuration
- 07-VLAN configuration
- 08-MVRP configuration
- 09-Loopback, null, and inloopback interface configuration
- 10-QinQ configuration
- 11-VLAN mapping configuration
- 12-PBB configuration
- 13-Loop detection configuration
- 14-Spanning tree configuration
- 15-LLDP configuration
- 16-L2PT configuration
- 17-Service loopback group configuration
- 18-Cut-through Layer 2 forwarding configuration
| 17-Service loopback group configuration | 51.11 KB |
Configuring service loopback groups
Restrictions and guidelines: Service loopback group configuration
Configuring a service loopback group
Display and maintenance commands for service loopback groups
Service loopback group configuration examples
Example: Configuring a service loopback group
About service loopback groups
A service loopback group provides one of the following services:
· Tunnel—Supports unicast tunnel traffic.
· Multicast tunnel—Supports multicast tunnel traffic.
· Multiport—Supports multiport ARP traffic.
· VSI gateway—Supports VSI gateway traffic.
When you add member ports to a service loopback group, follow these restrictions and guidelines:
· Make sure the ports support the service type of the service loopback group and are not members of any other service loopback group.
· The configuration on a port is removed when it is assigned to the service loopback group.
· To avoid IRF split, do not assign a physical interface to the service loopback group if that interface is the only member interface of an IRF port.
· In an IRF 3.1 system, ports on PEXs cannot be assigned to service loopback groups.
· For correct traffic processing, make sure the service loopback group has a minimum of one member port when it is being used by a feature.
· On an S6820-56HF switch, do not assign any of the 48 SFP28 ports to a service loopback group. Assigning the SFP28 ports to a service loopback group reduces the traffic transmission rate of the switch.
When you apply service loopback groups to features, follow these restrictions and guidelines:
· One service loopback group can be used by multiple features.
· You cannot change the service type of a service loopback group.
· Do not delete a service loopback group that is being used by a feature.
1. Enter system view.
2. Create a service loopback group and specify its service type.
service-loopback group group-id type { { multicast-tunnel | tunnel } * | multiport | vsi-gateway }
You can configure only one service loopback group for a service type.
3. Enter Layer 2 Ethernet interface view.
4. Assign the port to the service loopback group.
port service-loopback group group-id
By default, a port does not belong to a service loopback group.
You can assign a maximum of 32 ports to a service loopback group.
Task |
Command |
Display information about service loopback groups. |
display service-loopback group [ group-id ] |
All Ethernet ports on the device support the tunnel service. Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to a service loopback group to loop GRE packets sent out by the device back to the device.
# Create service loopback group 1, and specify its service type as tunnel.
[Sysname] service-loopback group 1 type tunnel
# Assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to service loopback group 1.
[Sysname-Ten-GigabitEthernet1/0/1] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-Ten-GigabitEthernet1/0/1] quit
[Sysname-Ten-GigabitEthernet1/0/2] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-Ten-GigabitEthernet1/0/2] quit
[Sysname] interface ten-gigabitethernet 1/0/3
[Sysname-Ten-GigabitEthernet1/0/3] port service-loopback group 1
All configurations on the interface will be lost. Continue?[Y/N]:y [Sysname-Ten-GigabitEthernet1/0/3] quit
# Create the interface Tunnel 1 and set it to GRE mode. The interface will automatically use service loopback group 1.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
