H3C DP52-52 Power Adapter User Guide-5W100
HomeSupportSwitchesIE4300-12P-AC & IE4300-12P-PWR Industrial SwitchesInstall & UpgradePower Supply ManualsH3C DP52-52 Power Adapter User Guide-5W100
Table of Contents
Related Documents
01-Text
01-Text 128.04 KB
1 About the H3C DP52-52 power adapter
The H3C DP52-52 power adapter is a 12V-input and 52V-output non-isolated regulated DC power supply. It provides protections against overcurrent output, undervoltage input, and overtemperature conditions. It is suitable for supplying power to industrial switches for being waterproof, dustproof, anti-shock, small in size, easy to install, and stable in performance.
Device view
Figure1-1 View
(1) Screw hole
(2) Positive DC input wire
(3) Negative DC input wire
(4) Negative DC output wire
(5) Positive DC output wire
Technical specifications
Table1-1 Technical specifications
Item
Specifications
Dimensions (H × W × D)
57 × 64 × 22 mm (2.24 × 2.52 × 0.87 in)
Net weight
300 g (10.58 oz)
Input voltage range
11 VDC to 15 VDC
Rated input voltage
12 VDC
Rated output voltage
52 VDC
Output voltage range
50.44 VDC to 53.56 VDC
Rated output current
1.0 A
Rated output power
52 W
Protection rating
IP68
2 Safety guidelines and warnings
To avoid possible device damage or bodily injury, read the following safety guidelines and warnings carefully before using the power adapter.
Safety guidelines
·     Keep good ventilation and heat dissipation during the operating process of the power adapter to ensure long-term reliability.
·     Use the power adapter in an environment that meets the specified requirements in Table3-1.
·     The potentiometer in the power adapter can be adjusted only by qualified personnel as required and they must be aware of the impact of the adjustment.
·     Do not operate the power adapter in an environment with volatile gases or flammable materials.
·     Do not remove the cover from the power adapter. Do not touch, repair, or replace the components inside the power adapter.
·     Cut off power immediately if smoke or unpleasant smell is emitted during the startup or operating process of the power adapter.
Safety warnings
·     Once the power adapter enters the protection mode, stop the power adapter immediately and handle the power adapter according to the relevant maintenance guidelines.
·     Only qualified personnel can connect the power adapter to a power source equipment.
·     Power might be still present on the adapter after it is just shut down. Shut down the adapter and wait for five minutes before working on the power adapter.
·     Pay attention to the safety signs. To avoid electric shocks and burns, do not touch the location with your hands directly where there are safety warning signs and high-voltage signs.
3 Installing the power adapter
Examining the installation environment
Table3-1 Requirements for the installation environment
Item
Specifications
Operating temperature
–30°C to +60°C (–22°F to +140°F)
Storage temperature
–40°C to +85°C (–40°F to +185°F)
Relative humidity (noncondensing)
5% to 95%
Altitude
≤ 5000 m (16404.20 ft)
The operating temperature decreases by 1°C (33.8°F) for every increase of 200 m (656.17 ft) above 3000 m (9842.52 ft) in altitude.
Cooling method
Natural cooling
The following installs the power adapter on a DIN rail:
1.     Wear an ESD wrist strap and make sure the wrist strap has good skin contact and is reliably grounded.
2.     Determine the power adapter installation position on the DIN rail according to the location of power source equipment and the input and output cable lengths of the power adapter.
3.     Thread two cable ties through the power adapter screw holes and through the DIN rail installation holes, and fasten the cable tie to secure the power adapter to the DIN rail.
4 Connecting the power wires
CAUTION
CAUTION:
·     To protect the power adapter from damages caused by incorrect power cord connections, identify the input, output, positive (+), and negative (-) marks on the power adapter before connecting the power wires.
·     Before connecting the power wires, turn off the circuit breaker at the power input end. You can use a 10 A circuit breaker.
The DC power source equipment in Figure4-2 is for illustration only. Prepare a DC power source equipment that meets the voltage requirements yourself.
To connect the power wires:
2.     Connect the positive (yellow) and negative (black) DC output wires of the adapter to the positive and negative input terminals of the device to which the adapter will supply power, respectively. Then fasten the wires.
3.     Connect the positive (red) and negative (black) DC input wires of the adapter to the positive and negative poles of the power source equipment, respectively. Then fasten the wires.
4.     Verify that the power wires are connected correctly and then turn on the circuit breaker at the power input end.
Figure4-2 Connecting the power wires
