H3C DP52-52 Power Adapter User Guide-5W100
HomeSupportSwitchesIE4300-12P-AC & IE4300-12P-PWR Industrial SwitchesInstall & UpgradePower Supply ManualsH3C DP52-52 Power Adapter User Guide-5W100
Table of Contents
Related Documents
00-Preface
00-Preface 100.20 KB
Preface
This document provides a user guide for installing the DP52-52 Power Adapter. It also covers the power supply views, technical specifications, and installation environment and guidelines.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the H3C DG-240-55 industrial power supply.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
