- H3C S12500X-AF Switch Series Configuration Examples(R320x)-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-Puppet Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-S-MLAG Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-PTP Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-VCF Fabric Configuration Examples
- 72-VXLAN Configuration Examples
- 73-NetStream Configuration Examples
- 74-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 75-DRNI Configuration Examples
- 76-DRNI and EVPN Configuration Examples
62-Congestion Avoidance and Queue Scheduling Configuration Examples | 85.17 KB |
H3C S12500X-AF |
Congestion Avoidance and Queue Scheduling |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
Example: Configuring congestion avoidance and queue scheduling
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
· Voice traffic—Transmitted in VLAN 6 and carries 802.1p priority 6.
· Video traffic—Transmitted in VLAN 4 and carries 802.1p priority 4.
· Data traffic—Transmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
· The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
· WRED drop is used when serious congestion occurs.
Analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
· To assign different types of traffic to different queues, configure the inbound interface HGE 3/0/1 to trust the 802.1p priority in packets.
· To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
· To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
Traffic type |
Packet color |
Lower limit |
Upper limit |
Drop probability |
Voice |
Yellow |
1000 |
1500 |
3% |
Red |
500 |
1000 |
30% |
Video |
Yellow |
1000 |
1500 |
2% |
Red |
500 |
1000 |
20% |
Data |
Yellow |
1000 |
1500 |
1% |
Red |
500 |
1000 |
10% |
Software versions used
This configuration example was created and verified on R3203.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
1. Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface hundredgige 3/0/1
[Device-HundredGigE3/0/1] port link-type trunk
[Device-HundredGigE3/0/1] port trunk permit vlan 2 4 6
[Device-HundredGigE3/0/1] quit
[Device] interface fortygige 3/0/3
[Device-FortyGigE3/0/3] port link-type trunk
[Device-FortyGigE3/0/3] port trunk permit vlan 2 4 6
[Device-FortyGigE3/0/3] quit
[Device] interface fortygige 3/0/4
[Device-FortyGigE3/0/4] port link-type trunk
[Device-FortyGigE3/0/4] port trunk permit vlan 2 4 6
[Device-FortyGigE3/0/4] quit
2. Configure interface HundredGigE 3/0/1 to trust the 802.1p priority in packets.
[Device-HundredGigE3/0/1] qos trust dot1p
3. Configure WRR on FortyGigE 3/0/3 and FortyGigE 3/0/4:
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device] display qos map-table inbound dot1p-lp
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
# Enable weight-based WRR on FortyGigE 3/0/3.
[Device-FortyGigE3/0/3] qos wrr weight
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-FortyGigE3/0/3] qos wrr 1 group 1 weight 2
[Device-FortyGigE3/0/3] qos wrr 4 group 1 weight 2
[Device-FortyGigE3/0/3] qos wrr 6 group 1 weight 1
# Enable weight-based WRR on FortyGigE 3/0/4.
[Device-FortyGigE3/0/4] qos wrr weight
[Device-FortyGigE3/0/4] qos wrr 1 group 1 weight 2
[Device-FortyGigE3/0/4] qos wrr 4 group 1 weight 2
[Device-FortyGigE3/0/4] qos wrr 6 group 1 weight 1
4. Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces FortyGigE 3/0/3 and FortyGigE 3/0/4.
[Device-FortyGigE3/0/3] qos wred apply droppolicy
[Device-FortyGigE3/0/4] qos wred apply droppolicy
# Verify the WRR configuration on interfaces FortyGigE 3/0/3 and FortyGigE 3/0/4.
[Device] display qos queue wrr interface
Interface: FortyGigE3/0/3
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Weight
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 2
5 ef 1 6
6 cs6 1 1
7 cs7 1 8
Interface: FortyGigE3/0/4
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 2
5 ef 1 6
6 cs6 1 1
7 cs7 1 8
# Display the WRED table configuration.
Table name: droppolicy
Table type: Queue based WRED
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 1000 1500 1 500 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 1000 1500 2 500 1000 20 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 1000 1500 3 500 1000 30 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
interface FortyGigE3/0/3
port link-mode bridge
port trunk permit vlan 1 to 2 4 6
qos wrr weight
qos wrr af1 group 1 weight 2
qos wrr af4 group 1 weight 2
qos wrr cs6 group 1 weight 1
interface FortyGigE3/0/4
qos wrr weight
interface HundredGigE3/0/1
return
Related documentation
· H3C S12500X-AF Switch Series ACL and QoS Configuration Guide-R320x
· H3C S12500X-AF Switch Series ACL and QoS Command Reference-R320x
