- H3C S12500X-AF Switch Series Configuration Examples(R320x)-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-Puppet Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-S-MLAG Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-PTP Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-VCF Fabric Configuration Examples
- 72-VXLAN Configuration Examples
- 73-NetStream Configuration Examples
- 74-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 75-DRNI Configuration Examples
- 76-DRNI and EVPN Configuration Examples
34-Control Plane-Based QoS Policy Configuration Examples | 61.71 KB |
H3C S12500X-AF |
Control Plane-Based QoS Policy |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This chapter provides examples for configuring control plane-based QoS policies.
This document assumes that you have basic knowledge of QoS policies.
Example: Rate limiting ICMP packets
As shown in Figure 1, the device receives a large number of ICMP packets from the Internet. As a result, CPU usage is high, and device performance degrades.
Configure a control plane-based QoS policy to meet the following requirements:
· Rate limit ICMP packets sent to the control plane to 320 kbps.
· Drop excess ICMP packets.
Analysis
To meet the network requirements, you must perform the following tasks:
· Use the if-match command to classify ICMP packets into a class.
· Use the car command to configure the rate limit value for ICMP packets and drop excess packets.
Software versions used
This configuration example was created and verified on R3203.
When you configure a control plane-based QoS policy to rate limit ICMP packets, follow these restrictions and guidelines:
· By default, the predefined QoS policy is applied to the control plane. The predefined QoS policy identifies packet types by system index and uses a default rate limit value for each packet type. To display the predefined QoS policy, use the display qos policy control-plane pre-defined command.
· You can use the if-match control-plane protocol or if-match control-plane protocol-group command to classify protocol packets.
· You can only configure the car command or a combination of the car and accounting packet commands in the behavior associated with the class.
· By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
# Create a class named ICMP, and use the ICMP protocol as the match criterion.
[Device] traffic classifier ICMP
[Device-classifier-ICMP] if-match control-plane protocol icmp
[Device-classifier-ICMP] quit
# Create a behavior named ICMP, and configure a CAR action for ICMP packets.
[Device] traffic behavior ICMP
[Device-behavior-ICMP] car cir 320
[Device-behavior-ICMP] quit
# Create a QoS policy named ICMP, and associate the class ICMP with the behavior ICMP in the QoS policy.
[Device] qos policy ICMP
[Device-qospolicy-ICMP] classifier ICMP behavior ICMP
[Device-qospolicy-ICMP] quit
# Apply the QoS policy ICMP to the inbound direction of the control plane.
[Device] control-plane slot 1
[Device-cp-slot1] qos apply policy ICMP inbound
[Device-cp-slot1] quit
Verify the configuration
# Verify that the QoS policy is correctly applied to the control plane.
[Device] display qos policy control-plane slot 1
Control plane slot 1
Direction: Inbound
Policy: ICMP
Classifier: ICMP
Operator: AND
Rule(s) :
If-match control-plane protocol icmp
Behavior: ICMP
Committed Access Rate:
CIR 320 (kbps), CBS 20480 (Bytes), EBS 0 (Bytes)
Green action : pass
Yellow action : pass
Red action : discard
Green packets : 0 (Packets)
Red packets : 0 (Packets)
Configuration files
traffic classifier ICMP operator and
car cir 320 cbs 20480 ebs 0 green pass red discard yellow pass
qos policy ICMP
Related documentation
· H3C S12500X-AF Switch Series ACL and QoS Configuration Guide-R320x
· H3C S12500X-AF Switch Series ACL and QoS Command Reference-R320x
