- H3C S12500X-AF Switch Series Configuration Examples(R320x)-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-Puppet Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-S-MLAG Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-PTP Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-VCF Fabric Configuration Examples
- 72-VXLAN Configuration Examples
- 73-NetStream Configuration Examples
- 74-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 75-DRNI Configuration Examples
- 76-DRNI and EVPN Configuration Examples
57-MAC Address Table Configuration Examples | 82.16 KB |
H3C S12500X-AF |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring static MAC address entries
Example: Configuring MAC address move suppression
Configuring Device B and Device C
Introduction
This document provides MAC address table configuration examples.
This document assumes that you have basic knowledge of the MAC address table.
As shown in Figure 1, for secure communication between users in VLAN 100 and the server, perform the following tasks:
· Assign HundredGigE 1/0/2 and HundredGigE 1/0/3 to VLAN 100.
· Add a static MAC address entry on Device to bind the server MAC address to HundredGigE 1/0/2.
Software versions used
This configuration example was created and verified on R3203.
Procedures
# Create VLAN 100, and assign HundredGigE 1/0/2 to VLAN 100.
[Device] vlan 100
[Device-vlan100] quit
[Device] interface hundredgige 1/0/2
[Device-HundredGigE1/0/2] port link-mode bridge
[Device-HundredGigE1/0/2] port access vlan 100
[Device-HundredGigE1/0/2] undo shutdown
[Device-HundredGigE1/0/2] quit
# Configure HundredGigE 1/0/3 (port connected to the LAN switch) as a trunk port, and assign the port to VLAN 100.
[Device] interface hundredgige 1/0/3
[Device-HundredGigE1/0/3] port link-mode bridge
[Device-HundredGigE1/0/3] port link-type trunk
[Device-HundredGigE1/0/3] port trunk permit vlan 100
[Device-HundredGigE1/0/3] quit
# Add a static entry for MAC address 0000-fc00-a249 on HundredGigE 1/0/2 that belongs to VLAN 100.
[Device] mac-address static 0000-fc00-a249 interface hundredgige 1/0/2 vlan 100
# Verify that any 10.0.0.0/24 host in VLAN 100 can communicate with the server. (Details not shown.)
# Verify that the static MAC address entry has been added.
[Device] display mac-address
MAC Address VLAN ID State Port/NickName Aging
0000-fc00-a249 100 Static HGE1/0/2 N
7425-8a02-4d00 100 Learned HGE1/0/3 Y
Configuration files
sysname Device
vlan 1
vlan 100
interface HundredGigE1/0/2
mac-address static 0000-fc00-a249 vlan 100
interface HundredGigE1/0/3
port trunk permit vlan 1 100
As shown in Figure 2, Devices A, B, and C form a loop because of cable misconnection, and spanning tree protocols are not enabled on the devices. As a result, MAC addresses are frequently moves among Devices A, B, and C. To deal with loop-triggered MAC flapping, perform the following tasks:
· Display MAC address move records to locate the Layer 2 loop.
· Configure MAC address move suppression on Device A to eliminate the Layer 2 loop.
Analysis
To meet the network requirements, you must perform the following tasks:
· For Devices A, B, and C to communicate with each other, assign all inter-connected ports to VLAN 100.
· Configure MAC address move suppression on one or more ports of Device A.
· To monitor the port status change of Device A, enable the log monitoring of the current terminal feature.
· For loop detection, create VLAN-interface 100 and assign an IP address to the interface on each device.
· To display MAC address move records, ping Device B from Device A.
Procedures
Configuring Device A
# Enable the monitoring of logs on the current terminal.
<DeviceA> terminal monitor
<DeviceA> terminal debugging
# Create VLAN 100.
[DeviceA] vlan 100
[DeviceA-vlan100] quit
# Configure HundredGigE 1/0/1 and HundredGigE 1/0/2 as trunk ports, and assign the ports to VLAN 100.
[DeviceA] interface range hundredgige 1/0/1 hundredgige 1/0/2
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] port link-type trunk
[DeviceA-if-range] port trunk permit vlan 100
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] quit
# Set the suppression interval to 300 seconds. A suppressed port will automatically come up after 300 seconds.
[DeviceA] mac-address notification mac-move suppression interval 300
# Set the suppression threshold to 0. A port will be shut down when the system detects a MAC address move on the port within a MAC move detection interval (1 minute by default).
[DeviceA] mac-address notification mac-move suppression threshold 0
# Enable MAC address move suppression on HundredGigE 1/0/1.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] mac-address notification mac-move suppression
[DeviceA-HundredGigE1/0/1] quit
# Create VLAN-interface 100, and assign an IP address to the interface.
[DeviceA] interface vlan-interface 100
[DeviceA-Vlan-interface100] ip address 10.0.0.1 24
[DeviceA-Vlan-interface100] quit
1. Configure Device B:
# Create VLAN 100.
[DeviceB] vlan 100
[DeviceB-vlan100] quit
[DeviceB] interface range hundredgige 1/0/1 hundredgige 1/0/2
[DeviceB-if-range] port link-mode bridge
[DeviceB-if-range] port link-type trunk
[DeviceB-if-range] port trunk permit vlan 100
[DeviceB-if-range] undo shutdown
[DeviceB-if-range] quit
[DeviceB] interface vlan-interface 100
[DeviceB-Vlan-interface100] ip address 10.0.0.2 24
[DeviceB-Vlan-interface100] quit
2. Configure Device C in the same way Device B was configured. (Details not shown.)
# Ping Device B from Device A. (Details not shown.)
# Verify that HundredGigE 1/0/1 on Device A is shut down.
[DeviceA] %Dec 11 09:51:06:309 2016 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the HundredGigE1/0/1 changed to down.
%Dec 11 09:51:06:323 2016 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on
the interface HundredGigE1/0/1 changed to down.
# Verify that HundredGigE 1/0/1 is shut down because a MAC address move is detected.
[DeviceA] display interface hundredgige 1/0/1
HundredGigE1/0/1
Current state: mac-address moving down
Line protocol state: DOWN
# Verify that HundredGigE 1/0/1 comes up automatically after 300 seconds.
[DeviceA] %Dec 11 09:56:07:002 2016 DeviceA IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the HundredGigE1/0/1 changed to up.
%Dec 11 09:56:07:004 2016 DeviceA IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on
the interface HundredGigE1/0/1 changed to up.
# Verify that the MAC address of Device B's VLAN-interface 100 moves between HundredGigE 1/0/1 and HundredGigE 1/0/2. You can manually shut down either port to eliminate the loop.
[DeviceA] display mac-address mac-move
MAC address VLAN Current port Source port Last time Times
0000-fc00-6506 100 HGE1/0/2 HGE1/0/1 2014-12-11 09:29:48 3
0000-fc00-6506 100 HGE1/0/1 HGE1/0/2 2014-12-11 09:51:03 4
--- 2 MAC address moving records found ---
Configuration files
· Device A:
sysname DeviceA
vlan 1
vlan 100
interface Vlan-interface100
ip address 10.0.0.1 255.255.255.0
· Device B:
sysname DeviceB
vlan 1
vlan 100
ip address 10.0.0.2 255.255.255.0
· Device C:
sysname DeviceC
vlan 1
vlan 100
ip address 10.0.0.3 255.255.255.0
Related documentation
· H3C S12500X-AF Switch Series Layer 2—LAN Switching Configuration Guide-R320x
· H3C S12500X-AF Switch Series Layer 2—LAN Switching Command Reference-R320x
