- H3C S12500X-AF Switch Series Configuration Examples(R320x)-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-Puppet Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-S-MLAG Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-PTP Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-VCF Fabric Configuration Examples
- 72-VXLAN Configuration Examples
- 73-NetStream Configuration Examples
- 74-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 75-DRNI Configuration Examples
- 76-DRNI and EVPN Configuration Examples
14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples | 81.16 KB |
H3C S12500X-AF |
IPv6 over IPv4 Manual Tunneling with |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring IPv6 over IPv4 manual tunneling with OSPFv3
Configuring IPv6 over IPv4 manual tunnels
Introduction
This document provides IPv6 over IPv4 manual tunneling with OSPFv3 configuration examples.
This document assumes that you have basic knowledge of HP IPv6 over IPv4 manual tunneling and OSPFv3.
As shown in Figure 1, in IPv6 networks, Device A, Device B, and Device C act as the gateways of the headquarters, Branch 1, and Branch 2, respectively.
Configure IPv6 over IPv4 manual tunnels to ensure that the headquarters can communicate with the two branches over IPv4 networks.
Configure OSPFv3 on the gateways to ensure the following:
· The gateways have routes to destination IPv6 addresses through tunnel interfaces.
· Branch 1 and Branch 2 can communicate with each other through the headquarters.
Device |
IP address |
Device A |
Vlan-int10 |
20.1.1.1/24 |
Vlan-int20 |
2001::1/64 |
Tunnel1 |
3001::1/64 |
Tunnel2 |
4001::1/64 |
Device B |
Vlan-int10 |
30.1.1.1/24 |
Vlan-int20 |
5001::1/64 |
Tunnel1 |
3001::2/64 |
Device C |
Vlan-int10 |
40.1.1.1/24 |
Vlan-int20 |
6001::1/64 |
Tunnel2 |
4001::2/64 |
Software versions used
This configuration example was created and verified on R3203.
When you configure IPv6 over IPv4 manual tunneling with OSPFv3, follow these restrictions and guidelines:
· For tunnel interfaces to send and receive packets, you must configure a tunnel-type service loopback group.
· On the device, a tunneled packet cannot be directly routed based on its destination address. It is sent to a tunnel-type service loopback group, which then delivers the packet to the forwarding module for Layer 3 forwarding.
· By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Make sure the gateways can reach each other at IPv4.
· Configure Device A:
# Configure an IP address for VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port HundredGigE 1/0/1
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 20.1.1.1 24
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Create service loopback group 1, and specify its service type as tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Assign HundredGigE 1/0/3 to service loopback group 1.
[DeviceA] interface HundredGigE 1/0/3
[DeviceA-HundredGigE1/0/3] port service-loopback group 1
[DeviceA-HundredGigE1/0/3] quit
# Configure an IPv6 over IPv4 manual tunnel interface Tunnel 1.
[DeviceA] interface tunnel 1 mode ipv6-ipv4
# Configure an IPv6 address for Tunnel 1.
[DeviceA-Tunnel1] ipv6 address 3001::1/64
# Specify VLAN-interface 10 as the source interface of Tunnel 1.
[DeviceA-Tunnel1] source vlan-interface 10
# Specify the destination address for Tunnel 1.
[DeviceA-Tunnel1] destination 30.1.1.1
[DeviceA-Tunnel1] quit
# Configure an IPv6 over IPv4 manual tunnel interface Tunnel 2.
[DeviceA] interface tunnel 2 mode ipv6-ipv4
# Configure an IPv6 address for Tunnel 2.
[DeviceA-Tunnel2] ipv6 address 4001::1/64
# Specify VLAN-interface 10 as the source interface of Tunnel 2.
[DeviceA-Tunnel2] source Vlan-interface 10
# Specify the destination address for Tunnel 2.
[DeviceA-Tunnel2] destination 40.1.1.1
[DeviceA-Tunnel2] quit
· Configure Device B:
[DeviceB] vlan 10
[DeviceB-vlan10] port HundredGigE 1/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-Vlan-interface10] ip address 30.1.1.1 24
[DeviceB-Vlan-interface10] quit
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface HundredGigE 1/0/3
[DeviceB-HundredGigE1/0/3] port service-loopback group 1
[DeviceB-HundredGigE1/0/3] quit
[DeviceB] interface tunnel 1 mode ipv6-ipv4
[DeviceB-Tunnel1] ipv6 address 3001::2/64
[DeviceB-Tunnel1] source vlan-interface 10
[DeviceB-Tunnel1] destination 20.1.1.1
[DeviceB-Tunnel1] quit
· Configure Device C:
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] port HundredGigE 1/0/1
[DeviceC-vlan10] quit
[DeviceC] interface vlan-interface 10
[DeviceC-Vlan-interface10] ip address 40.1.1.1 24
[DeviceC-Vlan-interface10] quit
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface HundredGigE 1/0/3
[DeviceC-HundredGigE1/0/3] port service-loopback group 1
[DeviceC-HundredGigE1/0/3] quit
[DeviceC] interface tunnel 2 mode ipv6-ipv4
[DeviceC-Tunnel2] ipv6 address 4001::2/64
[DeviceC-Tunnel2] source vlan-interface 10
[DeviceC-Tunnel2] destination 20.1.1.1
[DeviceC-Tunnel2] quit
Configuring OSPFv3
# Specify the router ID as 1.1.1.1.
[DeviceA] ospfv3
[DeviceA-ospfv3-1] router-id 1.1.1.1
[DeviceA-ospfv3-1] quit
# Enable OSPFv3 on Tunnel 1.
[DeviceA] interface Tunnel 1
[DeviceA-Tunnel1] ospfv3 1 area 0
# Enable OSPFv3 on Tunnel 2.
[DeviceA] interface Tunnel 2
[DeviceA-Tunnel2] ospfv3 1 area 0
# Enable OSPFv3 on VLAN-interface 20.
[DeviceA] interface vlan-interface 20
[DeviceA-Vlan-interface20] ospfv3 1 area 0
[DeviceA-Vlan-interface20] quit
# Specify the router ID as 2.2.2.2.
[DeviceB] ospfv3
[DeviceB-ospfv3-1] router-id 2.2.2.2
[DeviceB-ospfv3-1] quit
[DeviceB] interface Tunnel 1
[DeviceB-Tunnel1] ospfv3 1 area 0
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ospfv3 1 area 0
[DeviceB-Vlan-interface20] quit
# Specify the router ID as 3.3.3.3.
[DeviceC] ospfv3
[DeviceC-ospfv3-1] router-id 3.3.3.3
[DeviceC-ospfv3-1] quit
[DeviceC] interface Tunnel 2
[DeviceC-Tunnel2] ospfv3 1 area 0
[DeviceC] interface vlan-interface 20
[DeviceC-Vlan-interface20] ospfv3 1 area 0
[DeviceC-Vlan-interface20] quit
# Ping PC 1 from PC 2.
Pinging 2001::3
from 5001::3 with 32 bytes of data:
Reply from 2001::3: bytes=32 time=13ms
Reply from 2001::3: bytes=32 time=1ms
Reply from 2001::3: bytes=32 time<1ms
Ping statistics for 2001::3:
Minimum = 0ms, Maximum = 13ms, Average = 3ms
The output shows that the ping operation succeeds.
# Ping PC 3 from PC 2.
D:\>ping6 -s 5001::3 6001::3
Pinging 6001::3
from 6001::3 with 32 bytes of data:
Reply from 6001::3: bytes=32 time=13ms
Reply from 6001::3: bytes=32 time=1ms
Reply from 6001::3: bytes=32 time<1ms
Ping statistics for 6001::3:
Configuration files
· Device A:
ospfv3 1
router-id 1.1.1.1
area 0.0.0.0
vlan 10
vlan 20
interface Vlan-interface10
ip address 20.1.1.1 255.255.255.0
interface Vlan-interface20
ospfv3 1 area 0.0.0.0
ipv6 address 2001::1/64
interface HundredGigE1/0/1
port link-mode bridge
port access vlan 10
interface HundredGigE1/0/2
port access vlan 20
interface HundredGigE1/0/3
interface Tunnel1 mode ipv6-ipv4
source Vlan-interface10
interface Tunnel2 mode ipv6-ipv4
· Device B:
ospfv3 1
router-id 2.2.2.2
area 0.0.0.0
vlan 10
vlan 20
ip address 30.1.1.1 255.255.255.0
ipv6 address 5001::1/64
port access vlan 10
port access vlan 20
· Device C:
ospfv3 1
router-id 3.3.3.3
area 0.0.0.0
vlan 10
vlan 20
ip address 40.1.1.1 255.255.255.0
ipv6 address 6001::1/64
port access vlan 10
port access vlan 20
Related documentation
· H3C S12500X-AF Switch Series Layer 3—IP Routing Command Reference-R320x
· H3C S12500X-AF Switch Series Layer 3—IP Routing Configuration Guide-R320x
· H3C S12500X-AF Switch Series Layer 3—IP Services Command Reference-R320x
· H3C S12500X-AF Switch Series Layer 3—IP Services Configuration Guide-R320x
