- H3C S12500X-AF Switch Series Configuration Examples(R320x)-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-Puppet Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-S-MLAG Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-PTP Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-VCF Fabric Configuration Examples
- 72-VXLAN Configuration Examples
- 73-NetStream Configuration Examples
- 74-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 75-DRNI Configuration Examples
- 76-DRNI and EVPN Configuration Examples
41-Portal Configuration Examples | 455.47 KB |
H3C S12500X-AF |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Example: Configuring cross-subnet portal authentication
Configuring the RADIUS and portal server
Example: Configuring extended cross-subnet portal authentication
Configuring the RADIUS, portal, and security policy server
Example: Configuring direct portal authentication
Introduction
This document provides examples for configuring the following portal authentications:
· Cross-subnet authentication—Applies to networks where Layer 3 forwarding devices exist between the authentication client and the access device. After a user passes authentication on an interface, the access device generates an ACL for the user based on the user's IP address to permit packets from the user on the interface.
· Direct authentication—Applies to networks where no layer 3 forwarding devices exist between the authentication client and the access device. In such a network, the access device can learn MAC addresses of users. The access device can use both ACLs and MAC addresses to enhance control on user packet forwarding.
This document assumes that you have basic knowledge of portal.
When you configure direct or cross-subnet portal authentication, follow these restrictions and guidelines:
· Only the RADIUS server can perform authentication, authorization, and accounting for portal users.
· On the RADIUS server, configure routes to reach the authentication interfaces and user networks.
· The IMC server uses session control packets to send disconnection requests to the access device. If you use the IMC server as the RADIUS server, execute the radius session-control enable command on the access device. Otherwise, the access device cannot receive portal user logout requests from the RADIUS server.
· When the access device runs Portal 2.0, configure the BAS-IP attribute for portal packets sent to the portal authentication server. Make sure the BAS-IP is the same as the IP Address configured on the portal authentication server. Otherwise, the portal authentication server will drop unsolicited portal packets (such as logout notifications) from the access device.
As shown in Figure 1, Device B supports portal authentication. An IMC server acts as a portal authentication server, a portal Web server, and a RADIUS server. The RADIUS server is used to perform AAA on portal users. In this example, the IMC server runs IMC PLAT 7.0 (E0202) and IMC UAM 7.0 (E0202).
Configure cross-subnet portal authentication. Before passing authentication, a host can access only the portal server. After passing authentication, the host can access resources in the IP network.
Analysis
To enable Device B to perform cross-subnet portal authentication through RADIUS, you must complete the following tasks:
· Configure the portal authentication and Web server, and enable cross-subnet portal authentication.
· Configure the RADIUS scheme. Specify the AAA server for the scheme and apply the scheme to the portal authentication domain.
Software versions used
This configuration example was created and verified on R3203.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Procedures
Configuring Device A
# Configure VLAN-interface 2 and VLAN-interface 11, and assign them IP addresses.
[DeviceA] vlan 2
[DeviceA-vlan2] quit
[DeviceA] vlan 11
[DeviceA-vlan11] quit
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] ip address 192.168.0.1 24
[DeviceA-Vlan-interface2] quit
[DeviceA] interface vlan-interface 11
[DeviceA-Vlan-interface11] ip address 10.0.11.2 24
[DeviceA-Vlan-interface11] quit
# Assign the corresponding physical interfaces to the VLANs. (Details not shown.)
# Configure a static route to the RADIUS server.
[DeviceA] ip route-static 10.0.10.0 255.255.255.0 10.0.11.1
Configuring Device B
# Configure VLAN-interface 10 and VLAN-interface 11, and assign them IP addresses.
[DeviceB] vlan 10
[DeviceB-vlan10] quit
[DeviceB] vlan 11
[DeviceB-vlan11] quit
[DeviceB] interface vlan-interface 11
[DeviceB-Vlan-interface11] ip address 10.0.11.1 24
[DeviceB-Vlan-interface11] quit
[DeviceB] interface vlan-interface 10
[DeviceB-Vlan-interface10] ip address 10.0.10.1 24
[DeviceB-Vlan-interface10] quit
# Configure portal authentication server newpt.
[DeviceB] portal server newpt
[DeviceB-portal-server-newpt] ip 10.0.10.2 key simple portal
[DeviceB-portal-server-newpt] port 50100
[DeviceB-portal-server-newpt] quit
# Configure portal Web server newpt. The URL must be the same as the URL configured for the portal page on the portal Web server.
[DeviceB] portal web-server newpt
[DeviceB-portal-websvr-newpt] url http://10.0.10.2:8080/portal
[DeviceB-portal-websvr-newpt] quit
# Enable cross-subnet authentication on VLAN-interface 11, the interface connected to Device A.
[DeviceB] interface Vlan-interface 11
[DeviceB-Vlan-interface11] portal enable method layer3
# Configure the BAS-IP as 10.0.11.1 for portal packets sent from VLAN-interface 11 to the portal authentication server.
[DeviceB-Vlan-interface11] portal bas-ip 10.0.11.1
# Specify portal Web server newpt on VLAN-interface 11.
[DeviceB-Vlan-interface11] portal apply web-server newpt
# Create a RADIUS scheme named imc and enter its view.
[DeviceB] radius scheme imc
# Specify the primary authentication and accounting server, and configure the keys for communication with the server.
[DeviceB-radius-imc] primary authentication 10.0.10.2
[DeviceB-radius-imc] primary accounting 10.0.10.2
[DeviceB-radius-imc] key authentication simple expert
[DeviceB-radius-imc] key accounting simple expert
# Exclude the ISP domain name from the username sent to the RADIUS server.
[DeviceB-radius-imc] user-name-format without-domain
[DeviceB-radius-imc] quit
# Enable the RADIUS session-control feature.
[DeviceB] radius session-control enable
# Create an ISP domain named portal.com and enter its view.
[DeviceB] domain portal.com
# Configure AAA methods for the ISP domain.
[DeviceB-isp-portal.com] authentication portal radius-scheme imc
[DeviceB-isp-portal.com] authorization portal radius-scheme imc
[DeviceB-isp-portal.com] accounting portal radius-scheme imc
[DeviceB-isp-portal.com] quit
# Configure domain portal.com as the default ISP domain. If a user enters the username without the ISP domain name at login, the AAA methods of the default domain are used for the user.
[DeviceB] domain default enable portal.com
# Configure a static route to Department A.
[DeviceB] ip route-static 192.168.0.0 255.255.255.0 10.0.11.2
Adding an access device
1. Log in to IMC, and click the User tab.
2. From the navigation tree, select User Access Manager > Access Device Management > Access Device.
3. Click Add.
The Add Access Device page appears.
4. In the Access Configuration area, configure the following parameters:
¡ Enter expert in the Shared Key and Confirm Shared Key fields.
¡ Enter 1812 in the Authentication Port field and 1813 in the Accounting Port field.
¡ Select LAN Access Service from the Service Type list.
¡ Select HP(Comware) from the Access Device Type list.
5. In the Device List area, click Add Manually.
6. On the page that appears, enter IP address 10.0.10.1 in the Start IP field, and click OK.
7. Click OK.
Figure 2 Adding an access device
Adding an access policy
1. Click the User tab.
2. From the navigation tree, select User Access Manager > Access Policy.
3. Click Add.
4. On the page that appears, enter portal in the Access Policy Name field. Keep the default values for other parameters.
5. Click OK.
Figure 3 Adding an access policy
Adding an access service
2. From the navigation tree, select User Access Manager > Access Service.
3. Click Add.
4. On the page that appears, configure the following parameters:
¡ Enter Portal-auth in the Service Name field.
¡ Select portal from the Default Access Policy list.
¡ Keep the default values for other parameters.
5. Click OK.
Figure 4 Adding an access service
Configuring an access user
2. From the navigation tree, select Access User> All Access Users.
3. Click Add.
The Add Access User page appears.
4. In the Access Information area, click the Add User button for the User Name field.
5. On the page that appears, configure the following parameters:
¡ Enter hello in the User Name field.
¡ Enter 111111 in the Identity Number field.
¡ Click OK.
Figure 5 Adding a user
6. In the Access Information area, enter portal in the Account Name field and configure the password as 123456 for the account.
7. In the Access Service area, select the access service named Portal-auth.
8. Keep the default values for other parameters.
9. Click OK.
Figure 6 Configuring an access user
Configuring a portal page
2. From the navigation tree, select User Access Policy > Portal Service > Server.
3. Use the default values for all parameters.
4. Click OK.
Figure 7 Configuring a portal page
Adding an IP group for portal authentication
2. From the navigation tree, select User Access Policy > Portal Service > IP Group.
3. Click Add.
¡ Enter Portal_user in the IP Group Name field.
¡ Enter 192.168.0.0 in the Start IP field and 192.168.0.255 in the End IP field.
5. Click OK.
Figure 8 Adding an IP group
Configuring an access device for portal authentication
2. From the navigation tree, select User Access Policy > Portal Service > Device.
3. Click Add.
4. On the Add Device page, configure the following parameters:
¡ Enter NAS in the Device Name field.
¡ Enter 10.0.11.1 in the IP Address field.
¡ Enter portal in the Key and Confirm Key fields.
The key must be the same as that for the portal authentication server configured on Device B.
¡ Select Layer 3 from the Access Method list.
5. Click OK.
Figure 9 Adding an access device
Configuring a port group for portal authentication
1. On the Device page, click the Port Group icon.
Figure 10 Accessing the Device page
2. On the Configure Port Group page, click Add.
3. On the Add Port Group page, configure the following parameters:
¡ Enter portal in the Port Group Name field.
¡ Select Portal_user from the IP Group list.
4. Click OK.
Figure 11 Adding a port group
A user can perform portal authentication by using the iNode client or through a Web page. This example triggers portal authentication by accessing a Web page.
# Access a Web page through a Web browser on a host. You are redirected to the authentication page http://10.0.10.2:8080/portal. Enter the username portal and the password 123456 to log in. After passing the authentication, you are redirected to the authentication success page.
# Execute the display portal user command on Device B to display the portal user information.
[DeviceB] display portal user interface vlan-interface 11
Total portal users: 1
Username: portal
Portal server: newpt
State: Online
VPN instance: N/A
MAC IP Vlan Interface
0015-e9a6-7cfe 192.168.0.2 11 Vlan-interface11
Authorization information:
DHCP IP pool: N/A
User profile: N/A
Session group profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
Configuration files
· Device A:
vlan 2
vlan 11
interface Vlan-interface2
ip address 192.168.0.1 255.255.255.0
interface Vlan-interface11
ip address 10.0.11.2 255.255.255.0
ip route-static 10.0.10.0 24 10.0.11.1
· Device B:
vlan 10 to 11
interface Vlan-interface10
ip address 10.0.10.1 255.255.255.0
ip address 10.0.11.1 255.255.255.0
ip route-static 192.168.0.0 24 10.0.11.2
radius scheme imc
key authentication cipher $c$3$M30nGDQxiOCAxe2AJ9yEZdk8kjoWag==
key accounting cipher $c$3$M23dGDQxiOCAxe2BJ9yEZdk8kjoWag==
domain portal.com
portal server newpt
ip 10.0.10.2 key cipher $c$3$r0VxoIiBrpzju9h2akP4TxyknX8VTuYKfA==
As shown in Figure 12, Device B supports portal authentication. An IMC server acts as a portal authentication server, a portal Web server, a RADIUS server, and a security policy server. The RADIUS server is used to perform AAA on portal users. The security policy server is deployed to perform security check on portal-authenticated users. In this example, the IMC server runs on IMC PLAT 7.0(E0202) and IMC UAM 7.0(E0202).
Configure extended cross-subnet portal authentication. Before passing portal authentication, a host can access only the portal Web server. After the host passes authentication, the security policy server performs a security check on the host. If the host fails the security check, the host is permitted to access only the Patch/Virus definitions update server. After passing the security check, the host can access resources in the IP network.
Analysis
To perform security check on authenticated users, you must complete the following tasks:
· On Device B, create an ACL (ACL 3000 in this example) for users who fail security checks, and an ACL (ACL 3001 in this example) for users who pass security checks.
· On the security policy server, specify ACL 3000 as the isolation ACL and ACL 3001 as the security ACL.
Procedures
[DeviceA] vlan 2
[DeviceA] vlan 11
# Configure a static route to the RADIUS/portal/security policy server.
# Configure a static route to the Patch/Virus definitions update server.
[DeviceA] ip route-static 10.0.12.0 255.255.255.0 10.0.11.1
# Configure VLAN-interface 10, VLAN-interface 11, and VLAN-interface 12, and assign them IP addresses.
[DeviceB] vlan 10
[DeviceB] vlan 11
[DeviceB] vlan 12
[DeviceB-vlan12] quit
[DeviceB] interface vlan-interface 12
[DeviceB-Vlan-interface12] ip address 10.0.12.1 24
[DeviceB-Vlan-interface12] quit
# Configure the portal authentication server newpt.
# Create a static route to Department A.
# Create RADIUS scheme named imc and enter its view.
# Specify the primary authentication server and primary accounting server, and configure the keys for communication with the server.
# Enable RADIUS session control.
# Configure ACL 3000 to permit access only to the Patch/Virus definitions update server. Configure ACL 3001 to permit access to any IP address.
[DeviceB] acl number 3000
[DeviceB-acl-adv-3000] rule permit ip destination 10.0.12.2 0
[DeviceB-acl-adv-3000] rule deny ip
[DeviceB-acl-adv-3000] quit
[DeviceB] acl number 3001
[DeviceB-acl-adv-3001] rule permit ip
[DeviceB-acl-adv-3001] quit
# Configure the RADIUS server and portal server. For more information, see "Configuring the RADIUS and portal server."
# Configure the security policy server. Make sure you specify ACL 3000 as the isolation ACL and ACL 3001 as the security ACL.
A user can perform the extended cross-subnet authentication only by using the HP iNode client.
# Open the iNode client on a host, and create a portal connection. Enter the username and password and click Connect. The user passes the portal authentication.
# On the iNode client, check security check information. The user failed to pass the security check.
# Use the display portal user all command on Device B to display portal users. Verify that ACL 3000 is deployed to the user.
[DeviceB] display portal user all
Username: portal
State: Online
VPN instance: N/A
MAC IP VLAN Interface
DHCP IP pool: N/A
User profile: N/A
ACL number: 3000
Inbound CAR: N/A
Outbound CAR: N/A
# Update the virus database on the host to meet the security requirement.
# On the iNode client, disconnect the portal connection and then log in again. Check security check information. The iNode client displays that the host successfully passed the security check.
# Display portal user information on Device B. Verify that ACL 3001 is deployed to the portal user.
[DeviceB]display portal user all
Username: portal
State: Online
Authorization ACL: 3001
VPN instance: N/A
DHCP IP pool: N/A
User profile: N/A
ACL number: 3001
Inbound CAR: N/A
Outbound CAR: N/A
Configuration files
· Device A:
vlan 2
vlan 11
ip route-static 10.0.12.0 24 10.0.11.1
· Device B:
vlan 10 to 12
interface Vlan-interface12
ip address 10.0.12.1 255.255.255.0
acl number 3000
rule 0 permit ip destination 10.0.12.2 0
rule 5 deny ip
acl number 3001
rule 0 permit ip
radius scheme imc
domain portal.com
portal server newpt
As shown in Figure 13, hosts in Department A are directly connected to the device. An IMC server acts as both a portal authentication server, a portal Web server, and a RADIUS server. The RADIUS server is used to perform AAA on portal users. In this example, the IMC server runs on IMC PLAT 7.0(E0202) and IMC UAM 7.0(E0202).
Configure direct portal authentication. The hosts can access only the portal server before passing authentication and can access other network resources after passing authentication.
Analysis
To enable Device to perform portal authentication through RADIUS, you must complete the following tasks:
· Configure the portal authentication and Web server, and enable direct portal authentication.
Procedures
Configuring Device
[Device] vlan 10
[Device-vlan10] quit
[Device] vlan 11
[Device-vlan11] quit
[Device] interface vlan-interface 11
[Device-Vlan-interface11] ip address 192.168.0.1 24
[Device-Vlan-interface11] quit
[Device] interface vlan-interface 10
[Device-Vlan-interface10] ip address 10.0.10.1 24
[Device-Vlan-interface10] quit
[Device] portal server newpt
[Device-portal-server-newpt] ip 10.0.10.2 key simple portal
[Device-portal-server-newpt] port 50100
[Device-portal-server-newpt] quit
[Device] portal web-server newpt
[Device-portal-websvr-newpt] url http://10.0.10.2:8080/portal
[Device-portal-websvr-newpt] quit
# Enable direct portal authentication on VLAN-interface 11.
[Device] interface Vlan-interface 11
[Device-Vlan-interface11] portal enable method direct
# Configure the BAS-IP as 192.168.0.1 for portal packets sent from VLAN-interface 11 to the portal authentication server.
[Device-Vlan-interface11] portal bas-ip 192.168.0.1
[Device-Vlan-interface11] portal apply web-server newpt
# Create the RADIUS scheme named imc and enter its view.
[Device] radius scheme imc
[Device-radius-imc] primary authentication 10.0.10.2
[Device-radius-imc] primary accounting 10.0.10.2
[Device-radius-imc] key authentication simple expert
[Device-radius-imc] key accounting simple expert
[Device-radius-imc] user-name-format without-domain
[Device-radius-imc] quit
[Device] radius session-control enable
[Device] domain portal.com
[Device-isp-portal.com] authentication portal radius-scheme imc
[Device-isp-portal.com] authorization portal radius-scheme imc
[Device-isp-portal.com] accounting portal radius-scheme imc
[Device-isp-portal.com] quit
# Configure domain portal.com as the default ISP domain. If a user enters the username without the ISP domain name at login, the authentication and accounting methods of the default domain are used for the user.
[Device] domain default enable portal.com
When you configuring an access device for portal authentication (as shown in Figure 13), select Directly Selected from the Access Method list, and enter 192.168.0.1 in the IP Address field.
A user can perform portal authentication by using the HP iNode client or through a Web page. This example uses the Web page.
# Execute the display portal user command to display portal user information on Device.
[Device] display portal user interface vlan-interface 11
Username: portal
State: Online
VPN instance: N/A
DHCP IP pool: N/A
User profile: N/A
ACL number: N/A
Inbound CAR: N/A
Outbound CAR: N/A
Configuration files
vlan 10 to 11
radius scheme imc
domain portal.com
portal server newpt
Related documentation
· H3C S12500X-AF Switch Series Security Configuration Guide-R320x
· H3C S12500X-AF Switch Series Security Command Reference-R320x
