- H3C S12500X-AF Switch Series Configuration Examples(R320x)-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-Puppet Configuration Examples
- 12-DHCP Snooping Configuration Examples
- 13-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 14-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 15-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 16-GRE Tunnel Configuration Examples
- 17-GRE with OSPF Configuration Examples
- 18-OSPF Configuration Examples
- 19-IS-IS Configuration Examples
- 20-BGP Configuration Examples
- 21-Policy-Based Routing Configuration Examples
- 22-OSPFv3 Configuration Examples
- 23-IPv6 IS-IS Configuration Examples
- 24-Routing Policy Configuration Examples
- 25-IGMP Snooping Configuration Examples
- 26-IGMP Configuration Examples
- 27-BIDIR-PIM Configuration Examples
- 28-S-MLAG Configuration Examples
- 29-MLD Snooping Configuration Examples
- 30-IPv6 Multicast VLAN Configuration Examples
- 31-Basic MPLS Configuration Examples
- 32-MPLS L3VPN Configuration Examples
- 33-ACL Configuration Examples
- 34-Control Plane-Based QoS Policy Configuration Examples
- 35-Traffic Policing Configuration Examples
- 36-GTS and Rate Limiting Configuration Examples
- 37-Priority Mapping and Queue Scheduling Configuration Examples
- 38-Traffic Filtering Configuration Examples
- 39-AAA Configuration Examples
- 40-Port Security Configuration Examples
- 41-Portal Configuration Examples
- 42-SSH Configuration Examples
- 43-IP Source Guard Configuration Examples
- 44-Ethernet OAM Configuration Examples
- 45-CFD Configuration Examples
- 46-DLDP Configuration Examples
- 47-VRRP Configuration Examples
- 48-BFD Configuration Examples
- 49-NTP Configuration Examples
- 50-SNMP Configuration Examples
- 51-NQA Configuration Examples
- 52-Mirroring Configuration Examples
- 53-sFlow Configuration Examples
- 54-FCoE Configuration Examples
- 55-PTP Configuration Examples
- 56-OpenFlow Configuration Examples
- 57-MAC Address Table Configuration Examples
- 58-Static Multicast MAC Address Entry Configuration Examples
- 59-IP Unnumbered Configuration Examples
- 60-MVRP Configuration Examples
- 61-MCE Configuration Examples
- 62-Congestion Avoidance and Queue Scheduling Configuration Examples
- 63-Attack Protection Configuration Examples
- 64-Smart Link Configuration Examples
- 65-RRPP Configuration Examples
- 66-BGP Route Selection Configuration Examples
- 67-IS-IS Route Summarization Configuration Examples
- 68-IRF Configuration Examples
- 69-MPLS OAM Configuration Examples
- 70-MPLS TE Configuration Examples
- 71-VCF Fabric Configuration Examples
- 72-VXLAN Configuration Examples
- 73-NetStream Configuration Examples
- 74-EVPN-DCI over an MPLS L3VPN Network Configuration Examples
- 75-DRNI Configuration Examples
- 76-DRNI and EVPN Configuration Examples
07-Port Isolation Configuration Examples | 63.07 KB |
H3C S12500X-AF |
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides port isolation configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of port isolation.
General restrictions and guidelines
You cannot assign the member ports of a service loopback group to an isolation group. You cannot assign the member ports of an isolation group to a service loopback group.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Example: Configuring port isolation
As shown in Figure 1, the company branches Site 1 and Site 2 transfer service traffic in VLAN 2 and VLAN 3. Device A connects to the Internet through HundredGigE 1/0/1.
Configure port isolation on Device A to meet the following requirements:
· All hosts can access the Internet through Device A.
· Host A and Host B are isolated from each other at Layer 2.
· Host C and Host D are isolated from each other at Layer 2.
Software versions used
This configuration example was created and verified on R3203.
When you configure port isolation on the device, follow these restrictions and guidelines:
· Before assigning a port to an isolation group, make sure the isolation group already exists.
· You can assign a port to only one isolation group.
Procedures
# Create VLAN 2 and assign ports HundredGigE 1/0/2 and HundredGigE 1/0/3 to the VLAN.
[DeviceA] vlan 2
[DeviceA-vlan2] port hundredgige 1/0/2
[DeviceA-vlan2] port hundredgige 1/0/3
[DeviceA-vlan2] quit
# Create VLAN 3 and assign ports HundredGigE 1/0/4 and HundredGigE 1/0/5 to the VLAN.
[DeviceA] vlan 3
[DeviceA-vlan3] port hundredgige 1/0/4
[DeviceA-vlan3] port hundredgige 1/0/5
[DeviceA-vlan3] quit
# Configure port HundredGigE 1/0/1 as a trunk port and assign it to VLAN 2 and VLAN 3.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] port link-type trunk
[DeviceA-HundredGigE1/0/1] port trunk permit vlan 2 3
[DeviceA-HundredGigE1/0/1] quit
# Create isolation groups 1 and 2.
[DeviceA] port-isolate group 1
[DeviceA] port-isolate group 2
# Assign ports HundredGigE 1/0/2 and HundredGigE 1/0/3 to isolation group 1.
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] port-isolate enable group 1
[DeviceA-HundredGigE1/0/2] quit
[DeviceA] interface hundredgige 1/0/3
[DeviceA-HundredGigE1/0/3] port-isolate enable group 1
[DeviceA-HundredGigE1/0/3] quit
# Assign ports HundredGigE 1/0/4 and HundredGigE 1/0/5 to isolation group 2.
[DeviceA] interface hundredgige 1/0/4
[DeviceA-HundredGigE1/0/4] port-isolate enable group 2
[DeviceA-HundredGigE1/0/4] quit
[DeviceA] interface hundredgige 1/0/5
[DeviceA-HundredGigE1/0/5] port-isolate enable group 2
[DeviceA-HundredGigE1/0/5] quit
# Display information about all isolation groups.
[DeviceA] display port-isolate group
Port isolation group information:
Group ID: 1
Group members:
HundredGigE1/0/2
HundredGigE1/0/3
Group ID: 2
Group members:
HundredGigE1/0/4
HundredGigE1/0/5
The output shows that:
· Ports HundredGigE 1/0/2 and HundredGigE 1/0/3 are in isolation group 1. As a result, Host A and Host B are isolated from each other at Layer 2.
· Ports HundredGigE 1/0/4 and HundredGigE 1/0/4 are in isolation group 2. As a result, Host C and Host D are isolated from each other at Layer 2.
Configuration files
vlan 2 to 3
interface HundredGigE1/0/1
port link-mode bridge
port trunk permit vlan 1 to 3
interface HundredGigE1/0/2
port access vlan 2
interface HundredGigE1/0/3
port access vlan 2
interface HundredGigE1/0/4
port access vlan 3
interface HundredGigE1/0/5
port access vlan 3
Related documentation
· H3C S12500X-AF Switch Series Layer 2—LAN Switching Configuration Guide-R320x
· H3C S12500X-AF Switch Series Layer 2—LAN Switching Command Reference-R320x
