00-Preface | 21.42 KB |
Preface
This user guide describes the installation, hardware replacement, cabling, software configuration, and maintenance of the UIS-Cell 3000 G3, as well as UIS Manager login and license registration.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the server series.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Documentation feedback
We appreciate your comments.
