04-Layer 2 - LAN Switching Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-Release795x-6W10004-Layer 2 - LAN Switching Configuration Guide
07-VLAN mapping configuration
07-VLAN mapping configuration 115.77 KB
Configuring VLAN mapping
About VLAN mapping
VLAN mapping re-marks VLAN traffic with new VLAN IDs.
VLAN mapping application scenario
As shown in Figure 1, one-to-one mapping is used to replace the CVLAN of user packets with an SVLAN. With one-to-one VLAN mapping, packets from the customer network can be transmitted over the service provider network.
Figure 1 Application scenario of one-to-one VLAN mapping
VLAN mapping implementations
Figure 2 shows a simplified network that illustrates basic VLAN mapping terms.
Basic VLAN mapping terms include the following:
·          Uplink traffic—Traffic transmitted from the customer network to the service provider network.
·          Downlink traffic—Traffic transmitted from the service provider network to the customer network.
·          Network-side port—A port connected to or closer to the service provider network.
·          Customer-side port—A port connected to or closer to the customer network.
Figure 2 Basic VLAN mapping terms
As shown in Figure 3, one-to-one VLAN mapping is implemented on the customer-side port and replaces VLAN tags as follows:
·          Replaces the CVLAN with the SVLAN for the uplink traffic.
·          Replaces the SVLAN with the CVLAN for the downlink traffic.
Figure 3 One-to-one VLAN mapping implementation
Restrictions and guidelines: VLAN mapping configuration
Restriction: Hardware compatibility
VLAN mapping is supported only on the CSPC cards (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E) and CMPE-1104 cards.
Restriction: Feature compatibility
To add or replace VLAN tags for packets, you can configure both VLAN mapping and a QoS policy. The QoS policy takes effect if a configuration conflict occurs. For information about QoS policies, see ACL and QoS Configuration Guide.
Before you configure VLAN mapping, create original and translated VLANs.
Configuring one-to-one VLAN mapping
About one-to-one VLAN mapping
Configure one-to-one VLAN mapping on the PE (see Figure 1) to isolate traffic of the same service type from different homes.
1.        Enter system view.
2.        Enter interface view.
¡  Enter Layer 2 Ethernet interface view.
¡  Enter Layer 2 aggregate interface view.
3.        Set the link type of the port.
port link-type { hybrid | trunk }
By default, the link type of a port is access.
4.        Assign the port to the original VLAN and the translated VLAN.
¡  Assign the trunk port to the original VLAN and the translated VLAN.
port trunk permit vlan vlan-id-list
By default, a trunk port is assigned to VLAN 1.
¡  Assign the hybrid port to the original VLAN and the translated VLAN as a tagged member.
port hybrid vlan vlan-id-list tagged
By default, a hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
5.        Configure a one-to-one VLAN mapping.
vlan mapping vlan-id translated-vlan vlan-id
By default, no VLAN mapping is configured on an interface.
Display and maintenance commands for VLAN mapping
Display VLAN mapping information.
display vlan mapping [ interface interface-type interface-number ]
VLAN mapping configuration examples
Example: Configuring one-to-one VLAN mapping
As shown in Figure 4, configure one-to-one VLAN mapping on the PE to map VLAN 10 to VLAN 100, so user packets can be transmitted over the service provider network.
Figure 4 Network diagram
1.        Configure PE:
# Create the original VLAN and the translated VLAN.
<PE> system-view
[PE] vlan 10
[PE-vlan10] quit
[PE] vlan 100
[PE-vlan100] quit
# Configure customer-side port Ten-GigabitEthernet 1/0/1 as a trunk port.
[PE] interface ten-gigabitethernet 1/0/1
[PE-Ten-GigabitEthernet1/0/1] port link-type trunk
# Assign Ten-GigabitEthernet 1/0/1 to the original VLAN and the translated VLAN.
[PE-Ten-GigabitEthernet1/0/1] port trunk permit vlan 10 100
# Configure one-to-one VLAN mapping on Ten-GigabitEthernet 1/0/1 to map VLAN 10 to VLAN 100.
[PE-Ten-GigabitEthernet1/0/1] vlan mapping 10 translated-vlan 100
[PE-Ten-GigabitEthernet1/0/1] quit
# Configure network-side port Ten-GigabitEthernet 1/0/2 as a trunk port.
[PE] interface ten-gigabitethernet 1/0/2
[PE-Ten-GigabitEthernet1/0/2] port link-type trunk
# Assign Ten-GigabitEthernet 1/0/2 to VLAN 100.
[PE-Ten-GigabitEthernet1/0/2] port trunk permit vlan 100
[PE-Ten-GigabitEthernet1/0/2] quit
# Verify VLAN mapping information on the PE.
[PE] display vlan mapping
Interface Ten-GigabitEthernet1/0/1:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  10            N/A           100                      N/A
