04-Layer 2 - LAN Switching Configuration Guide
HomeSupportRoutersCR16000-F SeriesConfigure & DeployConfiguration GuidesH3C CR16000-F Routers Configuration Guides-Release795x-6W10004-Layer 2 - LAN Switching Configuration Guide
06-QinQ configuration
06-QinQ configuration 156.64 KB
Configuring QinQ
This document uses the following terms:
·          CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
·          SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
About QinQ
802.1Q-in-802.1Q (QinQ) adds an 802.1Q tag to 802.1Q tagged customer traffic. It enables a service provider to extend Layer 2 connections across an Ethernet network between customer sites.
QinQ benefits
QinQ provides the following benefits:
·          Enables a service provider to use a single SVLAN to convey multiple CVLANs for a customer.
·          Enables customers to plan CVLANs without conflicting with SVLANs.
·          Enables customers to keep their VLAN assignment schemes unchanged when the service provider changes its VLAN assignment scheme.
·          Allows different customers to use overlapping CVLAN IDs. Devices in the service provider network make forwarding decisions based on SVLAN IDs instead of CVLAN IDs.
How QinQ works
As shown in Figure 1, a QinQ frame transmitted over the service provider network carries the following tags:
·          CVLAN tag—Identifies the VLAN to which the frame belongs when it is transmitted in the customer network.
·          SVLAN tag—Identifies the VLAN to which the QinQ frame belongs when it is transmitted in the service provider network. The service provider allocates the SVLAN tag to the customer.
The devices in the service provider network forward a tagged frame according to its SVLAN tag only. The CVLAN tag is transmitted as part of the frame's payload.
Figure 1 Single-tagged Ethernet frame header and double-tagged Ethernet frame header
As shown in Figure 2, customer A has remote sites CE 1 and CE 4. Customer B has remote sites CE 2 and CE 3. The CVLANs of the two customers overlap. The service provider assigns SVLANs 3 and 4 to customers A and B, respectively.
When a tagged Ethernet frame from CE 1 arrives at PE 1, the PE tags the frame with SVLAN 3. The double-tagged Ethernet frame travels over the service provider network until it arrives at PE 2. PE 2 removes the SVLAN tag of the frame, and then sends the frame to CE 4.
Figure 2 Typical QinQ application scenario
QinQ implementations
QinQ is enabled on a per-port basis. The link type of a QinQ-enabled port can be access, hybrid, or trunk. The QinQ tagging behaviors are the same across these types of ports.
A QinQ-enabled port tags all incoming frames (tagged or untagged) with the PVID tag.
·          If an incoming frame already has one tag, it becomes a double-tagged frame.
·          If the frame does not have any 802.1Q tags, it becomes a frame tagged with the PVID.
QinQ provides the most basic VLAN manipulation method to tag all incoming frames (tagged or untagged) with the PVID tag. To perform advanced VLAN manipulations, use VLAN mappings or QoS policies as follows:
·          To use criteria other than the CVLAN ID to match packets for SVLAN tagging, use the QoS nest action. The QoS nest action can also be used with other actions in the same traffic behavior.
·          To set the 802.1p priority in SVLAN tags, use the priority marking action as described in "Setting the 802.1p priority in SVLAN tags."
For more information about VLAN mappings, see "Configuring VLAN mapping." For more information about QoS, see ACL and QoS Configuration Guide.
Protocols and standards
·          IEEE 802.1Q, IEEE Standard for Local and Metropolitan Area Networks-Virtual Bridged Local Area Networks
·          IEEE 802.1ad, IEEE Standard for Local and Metropolitan Area Networks-Virtual Bridged Local Area Networks-Amendment 4: Provider Bridges
Restrictions and guidelines: QinQ configuration
When you configure QinQ, follow these restrictions and guidelines:
·          The inner 802.1Q tag of QinQ frames is treated as part of the payload. As a best practice to ensure correct transmission of QinQ frames, set the MTU to a minimum of 1504 bytes for each port on their forwarding path. This value is the sum of the default Ethernet interface MTU (1500 bytes) and the length (4 bytes) of a VLAN tag.
·          You can use a QoS policy, a VLAN mapping, and QinQ on a port for VLAN tag manipulation. If their settings conflict, the settings take effect in the following descending order:
a.    QoS policy.
b.    VLAN mapping.
c.    QinQ.
Enabling QinQ
About enabling QinQ
Enable QinQ on customer-side ports of PEs. A QinQ-enabled port tags an incoming frame with its PVID.
Before you enable or disable QinQ on a port, you must remove any VLAN mappings on the port. For more information about VLAN mapping, see Layer 2—LAN Switching Configuration Guide.
1.        Enter system view.
2.        Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
3.        Set the port link type.
By default, the link type of a port is access.
4.        Configure the port to allow packets from its PVID and the CVLANs to pass through.
¡  Assign the access port to the specified VLAN.
port access vlan vlan-id
By default, all access ports belong to VLAN 1.
The PVID and CVLAN of an access port are the VLAN to which the port belongs. The port sends packets from the VLAN untagged.
¡  Configure the hybrid port to send packets from its PVID untagged and send packets from the CVLANs tagged.
By default, the hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
¡  Configure trunk port to allow packets from its PVID and the CVLANs to pass through.
By default, a trunk port allows packets only from VLAN 1 to pass through.
5.        Enable QinQ on the port.
qinq enable
By default, QinQ is disabled on the port.
Configuring the TPID for VLAN tags
About TPID
TPID identifies a frame as an 802.1Q tagged frame. The TPID value varies by vendor. On an H3C device, the TPID in the 802.1Q tag added on a QinQ-enabled port is 0x8100 by default, in compliance with IEEE 802.1Q. In a multi-vendor network, make sure the TPID setting is the same between directly connected devices so 802.1Q tagged frames can be identified correctly.
TPID settings include CVLAN TPID and SVLAN TPID.
A QinQ-enabled port uses the CVLAN TPID to match incoming tagged frames. An incoming frame is handled as untagged if its TPID is different from the CVLAN TPID.
SVLAN TPIDs are configurable on a per-port basis. A service provider-side port uses the SVLAN TPID to replace the TPID in outgoing frames' SVLAN tags and match incoming tagged frames. An incoming frame is handled as untagged if the TPID in its outer VLAN tag is different from the SVLAN TPID.
For example, a PE device is connected to a customer device that uses the TPID 0x8200 and to a provider device that uses the TPID 0x9100. For correct packet processing, you must set the CVLAN TPID and SVLAN TPID to 0x8200 and 0x9100 on the PE, respectively.
The TPID field is at the same position as the EtherType field in an untagged Ethernet frame. To ensure correct packet type identification, do not set the TPID value to any of the values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86dd
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88cc
802.1X
0x888e
802.1ag
0x8902
Cluster
0x88a7
Reserved
0xfffd/0xfffe/0xffff
You can configure the TPID value in VLAN tags by using one of the following methods:
·          In system view—The TPID value configuration made in system view takes effect on all ports of the device.
·          In interface view—The TPID value configuration made in interface view takes effect only on the current interface. The TPID value in VLAN tags is typically configured on the service provider-side ports of PEs.
Configuring the global TPID value
2.        Set the global CVLAN TPID.
qinq ethernet-type customer-tag hex-value
The default setting is 0x8100.
The customer-tag keyword does not take effect on the CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E cards, CSPEX cards, and CEPC cards.
Configuring an interface-specific TPID value
3.        Set the interface-specific SVLAN TPID.
qinq ethernet-type service-tag hex-value
About the 802.1p priority in SVLAN tags
To modify the 802.1p priority in the SVLAN tag added by a QinQ-enabled port, you can use QoS policies to copy the 802.1p priority in the CVLAN tag to the SVLAN tag.
For more information about QoS policies, see ACL and QoS Configuration Guide.
Tasks at a glance
To use QoS policies to set the 802.1p priority in SVLAN tags, perform the following tasks:
1.        Creating a traffic class and configuring CVLAN match criteria
2.        Creating a traffic behavior and configuring a priority marking action for SVLAN tags
3.        Creating a QoS policy
4.        Applying the QoS policy
2.        Create a traffic class and enter its view.
3.        Configure CVLAN match criteria.
Choose one option as needed:
¡  Match CVLAN IDs.
if-match customer-vlan-id vlan-id-list
¡  Match 802.1p priority.
if-match customer-dot1p dot1p-value&<1-8>
2.        Create a traffic behavior and enter its view.
3.        Copy the 802.1p priority in the CVLAN tag to the SVLAN tag.
By default, the port copies the 802.1p priority in the CVLAN tag to the SVLAN tag.
2.        Create a QoS policy and enter its view.
qos policy policy-name
3.        Specify the traffic behavior for the traffic class in the QoS policy.
classifier classifier-name behavior behavior-name
2.        Enter Layer 2 Ethernet interface view.
3.        Apply the QoS policy to the inbound direction of the port.
Display and maintenance commands for QinQ
Display QinQ-enabled ports.
display qinq [ interface interface-type interface-number ]
QinQ configuration examples
Example: Configuring basic QinQ
As shown in Figure 3:
·          The service provider assigns VLAN 100 to Company A's VLANs 10 through 70.
·          The service provider assigns VLAN 200 to Company B's VLANs 30 through 90.
·          The devices between PE 1 and PE 2 in the service provider network use a TPID value of 0x8200.
Configure QinQ on PE 1 and PE 2 to transmit traffic in VLANs 100 and 200 for Company A and Company B, respectively.
For the QinQ frames to be identified correctly, set the SVLAN TPID to 0x8200 on the service provider-side ports of PE 1 and PE 2.
Figure 3 Network diagram
1.        Configure PE 1:
# Configure GigabitEthernet 3/1/1 as a trunk port, and assign it to VLAN 100.
<PE1> system-view
[PE1] interface gigabitethernet 3/1/1
[PE1-GigabitEthernet3/1/1] port link-type trunk
[PE1-GigabitEthernet3/1/1] port trunk permit vlan 100
# Set the PVID of GigabitEthernet 3/1/1 to VLAN 100.
[PE1-GigabitEthernet3/1/1] port trunk pvid vlan 100
# Enable QinQ on GigabitEthernet 3/1/1.
[PE1-GigabitEthernet3/1/1] qinq enable
[PE1-GigabitEthernet3/1/1] quit
# Configure GigabitEthernet 3/1/2 as a trunk port, and assign it to VLANs 100 and 200.
[PE1] interface gigabitethernet 3/1/2
[PE1-GigabitEthernet3/1/2] port link-type trunk
[PE1-GigabitEthernet3/1/2] port trunk permit vlan 100 200
# Set the TPID value in the SVLAN tags to 0x8200 on GigabitEthernet 3/1/2.
[PE1-GigabitEthernet3/1/2] qinq ethernet-type service-tag 8200
[PE1-GigabitEthernet3/1/2] quit
# Configure GigabitEthernet 3/1/3 as a trunk port, and assign it to VLAN 200.
[PE1] interface gigabitethernet 3/1/3
[PE1-GigabitEthernet3/1/3] port link-type trunk
[PE1-GigabitEthernet3/1/3] port trunk permit vlan 200
# Set the PVID of GigabitEthernet 3/1/3 to VLAN 200.
[PE1-GigabitEthernet3/1/3] port trunk pvid vlan 200
# Enable QinQ on GigabitEthernet 3/1/3.
[PE1-GigabitEthernet3/1/3] qinq enable
[PE1-GigabitEthernet3/1/3] quit
2.        Configure PE 2:
# Configure GigabitEthernet 3/1/1 as a trunk port, and assign it to VLAN 200.
<PE2> system-view
[PE2] interface gigabitethernet 3/1/1
[PE2-GigabitEthernet3/1/1] port link-type trunk
[PE2-GigabitEthernet3/1/1] port trunk permit vlan 200
# Set the PVID of GigabitEthernet 3/1/1 to VLAN 200.
[PE2-GigabitEthernet3/1/1] port trunk pvid vlan 200
[PE2-GigabitEthernet3/1/1] qinq enable
[PE2-GigabitEthernet3/1/1] quit
[PE2] interface gigabitethernet 3/1/2
[PE2-GigabitEthernet3/1/2] port link-type trunk
[PE2-GigabitEthernet3/1/2] port trunk permit vlan 100 200
[PE2-GigabitEthernet3/1/2] qinq ethernet-type service-tag 8200
[PE2-GigabitEthernet3/1/2] quit
# Configure GigabitEthernet 3/1/3 as a trunk port, and assign it to VLAN 100.
[PE2] interface gigabitethernet 3/1/3
[PE2-GigabitEthernet3/1/3] port link-type trunk
[PE2-GigabitEthernet3/1/3] port trunk permit vlan 100
# Set the PVID of GigabitEthernet 3/1/3 to VLAN 100.
[PE2-GigabitEthernet3/1/3] port trunk pvid vlan 100
[PE2-GigabitEthernet3/1/3] qinq enable
[PE2-GigabitEthernet3/1/3] quit
3.        Configure the devices between PE 1 and PE 2:
# Set the MTU to a minimum of 1504 bytes for each port on the path of QinQ frames. (Details not shown.)
# Configure all ports on the forwarding path to allow frames from VLANs 100 and 200 to pass through without removing the VLAN tag. (Details not shown.)
