03-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10003-Layer 2—LAN Switching Configuration Guide
09-VLAN configuration
09-VLAN configuration 558.86 KB
Configuring VLANs· 1
Overview· 1
VLAN frame encapsulation· 1
Protocols and standards· 2
Configuring basic VLAN settings· 2
Configuring basic settings of a VLAN interface· 3
Configuring port-based VLANs· 4
Introduction· 4
Assigning an access port to a VLAN· 5
Assigning a trunk port to a VLAN· 6
Assigning a hybrid port to a VLAN· 7
Configuring MAC-based VLANs· 8
Introduction· 8
Configuration restrictions and guidelines· 11
Configuring static MAC-based VLAN assignment 11
Configuring dynamic MAC-based VLAN assignment 12
Configuring server-assigned MAC-based VLAN· 12
Configuring IP subnet-based VLANs· 13
Configuring protocol-based VLANs· 14
Configuring a VLAN group· 15
Displaying and maintaining VLANs· 16
VLAN configuration examples· 16
Port-based VLAN configuration example· 16
MAC-based VLAN configuration example· 18
IP subnet-based VLAN configuration example· 20
Protocol-based VLAN configuration example· 21
Configuring the private VLAN·· 25
Configuration task list 25
Configuration restrictions and guidelines· 26
Configuration procedure· 26
Displaying and maintaining the private VLAN· 28
Private VLAN configuration examples· 28
Promiscuous port configuration example· 28
Trunk promiscuous port configuration example· 31
Trunk promiscuous and trunk secondary port configuration example· 34
Secondary VLAN Layer 3 communication configuration example· 39
Configuring voice VLANs· 42
Overview· 42
Methods of identifying IP phones· 42
Identifying IP phones through OUI addresses· 42
Automatically identifying IP phones through LLDP· 43
Advertising the voice VLAN information to IP phones· 43
IP phone access methods· 44
Connecting the host and the IP phone in series· 44
Connecting the IP phone to the device· 44
Configuring a voice VLAN on a port 44
Voice VLAN assignment modes· 44
Security mode and normal mode of voice VLANs· 46
Configuration prerequisites· 47
Configuring the QoS priority settings for voice traffic· 47
Configuring a port to operate in automatic voice VLAN assignment mode· 48
Configuring a port to operate in manual voice VLAN assignment mode· 49
Configuration restrictions and guidelines· 49
Enabling LLDP for automatic IP phone discovery· 50
Configuration prerequisites· 50
Configuration restrictions and guidelines· 50
Configuration procedure· 50
Configuring LLDP or CDP to advertise a voice VLAN· 50
Dynamically advertising an authorization VLAN through LLDP or CDP· 51
Displaying and maintaining voice VLANs· 51
Voice VLAN configuration examples· 52
Automatic voice VLAN assignment mode configuration example· 52
Manual voice VLAN assignment mode configuration example· 54
Configuring VLANs
Overview
Ethernet is a family of shared-media LAN technologies based on the CSMA/CD mechanism. An Ethernet LAN is both a collision domain and a broadcast domain. Because the medium is shared, collisions and broadcasts are common in an Ethernet LAN. Typically, bridges and Layer 2 switches can reduce collisions in an Ethernet LAN. To confine broadcasts, a Layer 2 switch must use the Virtual Local Area Network (VLAN) technology.
VLANs enable a Layer 2 switch to break a LAN down into smaller broadcast domains, as shown in Figure 1.
Figure 1 A VLAN diagram
A VLAN is logically divided on an organizational basis rather than on a physical basis. For example, you can assign all workstations and servers used by a particular workgroup to the same VLAN, regardless of their physical locations. Hosts in the same VLAN can directly communicate with one another. You need a router or a Layer 3 switch for hosts in different VLANs to communicate with one another.
All these VLAN features reduce bandwidth waste, improve LAN security, and enable flexible virtual group creation.
To identify Ethernet frames from different VLANs, IEEE 802.1Q inserts a four-byte VLAN tag between the destination and source MAC address (DA&SA) field and Type field.
Figure 2 VLAN tag placement and format
A VLAN tag includes the following fields:
·           TPID—16-bit tag protocol identifier that indicates whether a frame is VLAN-tagged. By default, the TPID value 0x8100 identifies a VLAN-tagged frame. A device vendor can set TPID to different values. For compatibility with a neighbor device, configure the TPID value on the device to be the same as the neighbor device.
·           Priority—3-bit long, identifies the 802.1p priority of the frame. For more information, see ACL and QoS Configuration Guide.
·           CFI—1-bit long canonical format indicator that indicates whether the MAC addresses are encapsulated in the standard format when packets are transmitted across different media. Available values include:
¡  0 (default)—The MAC addresses are encapsulated in the standard format.
¡  1The MAC addresses are encapsulated in a nonstandard format.
This field is always set to 0 for Ethernet.
·           VLAN ID—12-bit long, identifies the VLAN to which the frame belongs. The VLAN ID range is 0 to 4095. VLAN IDs 0 and 4095 are reserved, and VLAN IDs 1 to 4094 are user configurable.
The way a network device handles an incoming frame depends on whether the frame has a VLAN-tag and the value of the VLAN tag (if any). For more information, see "Introduction."
Ethernet supports encapsulation formats Ethernet II, 802.3/802.2 LLC, 802.3/802.2 SNAP, and 802.3 raw. The Ethernet II encapsulation format is used here. For information about the VLAN tag fields in other frame encapsulation formats, see related protocols and standards.
For a frame with multiple VLAN tags, the device handles it according to its outer-most VLAN tag and transmits its inner VLAN tags as the payload.
IEEE 802.1Q, IEEE Standard for Local and Metropolitan Area Networks: Virtual Bridged Local Area Networks
Step
Remarks
1.      Enter system view.
N/A
2.      (Optional.) Create a VLAN and enter its view, or create a list of VLANs.
vlan { vlan-id1 [ to vlan-id2 ] | all }
By default, only the system default VLAN (VLAN 1) exists.
3.      Enter VLAN view.
vlan vlan-id
To configure a VLAN after you create a list of VLANs, you must perform this step.
4.      Configure a name for the VLAN.
name text
By default, VLAN names are in the format VLAN vlan-id. For example, the name of VLAN 100 is VLAN 0100 by default.
5.      Configure the description of the VLAN.
The default setting is VLAN vlan-id, which is the ID of the VLAN. For example, the description of VLAN 100 is VLAN 0100 by default.
·       As the system default VLAN, VLAN 1 cannot be created or deleted.
·       Before you delete a dynamic VLAN, a VLAN configured with the QoS policy, or a VLAN locked by an application, you must first remove the configuration from the VLAN.
For hosts of different VLANs to communicate at Layer 3, you can use VLAN interfaces. VLAN interfaces are virtual interfaces used for Layer 3 communication between different VLANs. They do not exist as physical entities on devices. For each VLAN, you can create one VLAN interface and assign an IP address to it. The VLAN interface acts as the gateway of the VLAN to forward packets destined for another IP subnet.
When you configure a VLAN interface, follow these restrictions and guidelines:
·           Before you create a VLAN interface for a VLAN, create the VLAN first.
·           You cannot create VLAN interfaces for secondary VLANs that have the following characteristics:
¡  Associated with the same primary VLAN.
¡  Enabled with Layer 3 communication in VLAN interface view of the primary VLAN interface.
For more information about secondary VLANs, see "Configuring the private VLAN."
To configure basic settings of a VLAN interface:
Step
Remarks
N/A
2.      Create a VLAN interface and enter VLAN interface view.
interface vlan-interface vlan-interface-id
If the VLAN interface already exists, you enter its view directly.
By default, no VLAN interface is created.
3.      Assign an IP address to the VLAN interface.
By default, no IP address is assigned to any VLAN interface.
4.      Configure the description of the VLAN interface.
The default setting is the VLAN interface name. For example, Vlan-interface1 Interface.
5.      (Optional.) Specify a member device for forwarding the traffic on the current VLAN interface.
service slot slot-number
By default, no member devices are specified.
6.      Configure the MTU for the VLAN interface.
mtu size
The default setting is 1500 bytes.
7.      Configure the expected bandwidth of the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
8.      (Optional.) Restore the default settings for the VLAN interface.
default
N/A
9.      (Optional.) Bring up the VLAN interface.
By default, a VLAN interface is not manually shut down. The VLAN interface is up if one or more ports in the VLAN is up, and goes down if all ports in the VLAN go down.
Introduction
Port-based VLANs group VLAN members by port. A port forwards packets from a VLAN only after it is assigned to the VLAN.
Port link type
You can configure the link type of a port as access, trunk, or hybrid. The link types use the following VLAN tag handling methods:
·           Access—An access port can forward packets from only one VLAN and send these packets untagged. An access port can connect a terminal device that does not support VLAN packets or is used in scenarios that do not distinguish VLANs.
·           Trunk—A trunk port can forward packets from multiple VLANs. Except packets from the port VLAN ID (PVID), packets sent out of a trunk port are VLAN-tagged. Ports connecting network devices are typically configured as trunk ports.
·           Hybrid—A hybrid port can forward packets from multiple VLANs. The tagging status of the packets forwarded by a hybrid port depends on the port configuration. Hybrid ports are typically used in one-to-two VLAN mapping to remove SVLAN tags for downlink traffic. For more information about one-to-two VLAN mapping, see "Configuring VLAN mapping."
PVID
The PVID identifies the default VLAN of a port.
When configuring the PVID on a port, follow these restrictions and guidelines:
·           An access port can join only one VLAN. The VLAN to which the access port belongs is the PVID of the port.
·           A trunk or hybrid port supports multiple VLANs and the PVID configuration.
·           When you use the undo vlan command to delete the PVID of a port, either of the following events occurs depending on the port link type:
¡  For an access port, the PVID of the port changes to VLAN 1.
¡  For a hybrid or trunk port, the PVID setting on the port does not change.
You can use a nonexistent VLAN as the PVID for a hybrid or trunk port, but not for an access port.
·           As a best practice, set the same PVID for a local port and its peer.
·           To prevent a port from dropping packets from its PVID and untagged packets, assign the port to its PVID.
How ports of different link types handle frames
Actions
Access
Trunk
Hybrid
In the inbound direction for an untagged frame
Tags the frame with the PVID tag.
·          If the PVID is permitted on the port, tags the frame with the PVID tag.
·          If not, drops the frame.
In the inbound direction for a tagged frame
·          Receives the frame if its VLAN ID is the same as the PVID.
·          Drops the frame if its VLAN ID is different from the PVID.
·          Receives the frame if its VLAN is permitted on the port.
·          Drops the frame if its VLAN is not permitted on the port.
In the outbound direction
Removes the VLAN tag and sends the frame.
·          Removes the tag and sends the frame if the frame carries the PVID tag and the port belongs to the PVID.
·          Sends the frame without removing the tag if its VLAN is carried on the port but is different from the PVID.
Sends the frame if its VLAN is permitted on the port. The tagging status of the frame depends on the port hybrid vlan command configuration.
In a VLAN-aware network, the default processing order for untagged packets is as follows, in descending order of priority:
·           MAC-based VLANs.
·           IP subnet-based VLANs.
·           Protocol-based VLANs.
·           Port-based VLANs.
You can assign an access port to a VLAN in VLAN view or interface view.
Make sure the VLAN has been created.
Assigning one or multiple access ports to a VLAN in VLAN view
Step
Remarks
N/A
2.      Enter VLAN view.
vlan vlan-id
N/A
3.      Assign one or a group of access ports to the VLAN.
port interface-list
By default, all ports belong to VLAN 1.
Assigning an access port to a VLAN in interface view
Step
Remarks
N/A
2.      Enter interface view.
·          Enter Layer 2 Ethernet interface view:
interface
interface-type interface-number
·          Enter Layer 2 aggregate interface view:
interface bridge-aggregation
interface-number
·          Enter S-channel interface view:
interface s-channel
interface-number.channel-id
·          Enter S-channel aggregate interface view:
interface
schannel-aggregation interface-number:channel-id
·          The configuration made in Layer 2 Ethernet interface view applies only to the port.
·          The configuration made in Layer 2 aggregate interface view applies to the aggregate interface and its aggregation member ports. If the system fails to apply the configuration to an aggregation member port, it skips the port and moves to the next member port. If the system fails to apply the configuration to the aggregate interface, it stops applying the configuration to aggregation member ports.
·          The configuration made in S-channel interface view or S-channel aggregate interface view applies only to the interface. For more information about S-channel interfaces and S-channel aggregate interfaces, see EVB Configuration Guide.
3.      Configure the link type of the port as access.
port link-type access
By default, all ports are access ports.
4.      (Optional.) Assign the access port to a VLAN.
port access vlan vlan-id
By default, all access ports belong to VLAN 1.
A trunk port supports multiple VLANs. You can assign it to a VLAN in interface view.
When you assign a trunk port to a VLAN, follow these restrictions and guidelines:
·           To change the link type of a port from trunk to hybrid or vice versa, set the link type to access first.
·           To enable a trunk port to transmit packets from its PVID, you must assign the trunk port to the PVID by using the port trunk permit vlan command.
To assign a trunk port to one or multiple VLANs:
Step
Remarks
N/A
interface
interface-number
interface s-channel
interface
3.      Configure the link type of the port as trunk.
port link-type trunk
4.      Assign the trunk port to the specified VLANs.
By default, a trunk port permits only VLAN 1.
5.      (Optional.) Configure the PVID of the trunk port.
port trunk pvid vlan vlan-id
The default setting is VLAN 1.
A hybrid port supports multiple VLANs. You can assign it to the specified VLANs in interface view. Make sure the VLANs have been created.
When you assign a hybrid port to a VLAN, follow these restrictions and guidelines:
·           To enable a hybrid port to transmit packets from its PVID, you must assign the hybrid port to the PVID by using the port hybrid vlan command.
To assign a hybrid port to one or multiple VLANs:
Step
Remarks
N/A
interface
interface-number
interface s-channel
interface
3.      Configure the link type of the port as hybrid.
port link-type hybrid
4.      Assign the hybrid port to the specified VLANs.
By default, a hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
5.      (Optional.) Configure the PVID of the hybrid port.
port hybrid pvid vlan vlan-id
By default, the PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
Introduction
This feature is available only on hybrid ports.
The MAC-based VLAN feature assigns hosts to a VLAN based on their MAC addresses. This feature is usually used with security technologies such as 802.1X to provide secure and flexible network access for terminal devices.
Static MAC-based VLAN assignment
Use static MAC-based VLAN assignment in networks that have a small number of VLAN users. To configure static MAC-based VLAN assignment on a port, perform the following tasks:
1.      Create MAC-to-VLAN entries.
2.      Enable the MAC-based VLAN feature on the port.
3.      Assign the port to the MAC-based VLAN.
A port configured with static MAC-based VLAN assignment processes a received frame as follows before sending the frame out:
·           For an untagged frame, the port determines its VLAN ID in the following workflow:
a.    The port first performs a fuzzy match as follows:
-       Searches for the MAC-to-VLAN entries whose masks are not all-Fs.
-       Performs a logical AND operation on the source MAC address and each of these masks.
If the result of an AND operation matches the MAC address in a MAC-to-VLAN entry, the port tags the frame with the VLAN ID specific to this entry.
b.    If the fuzzy match fails, the port performs an exact match. It searches for MAC-to-VLAN entries whose masks are all-Fs. If the source MAC address of the frame matches the MAC address of a MAC-to-VLAN entry, the port tags the frame with the VLAN ID specific to this entry.
c.    If no matching VLAN ID is found, other criteria, such as IP subnet or protocol, are used for VLAN assignment.
d.    If no VLAN is available, the port tags the frame with its PVID.
·           For a tagged frame, the port determines whether the VLAN ID of the frame is permitted on the port.
¡  If the VLAN ID of the frame is permitted on the port, the port forwards the frame.
¡  If the VLAN ID of the frame is not permitted on the port, the port drops the frame.
Dynamic MAC-based VLAN assignment
When you cannot determine the target MAC-based VLANs of a port, you can use dynamic MAC-based VLAN assignment on the port. To use dynamic MAC-based VLAN assignment, perform the following tasks:
3.      Enable dynamic MAC-based VLAN assignment on the port.
Dynamic MAC-based VLAN assignment uses the following workflow, as shown in Figure 3:
1.      When a port receives a frame, it first determines whether the frame is tagged.
¡  If the frame is tagged, the port reports the source MAC address of the frame.
¡  If the frame is untagged, the port selects a VLAN for the frame by using the following matching order:
-       MAC-based VLAN.
-       IP subnet-based VLAN.
-       Protocol-based VLAN.
-       Port-based VLAN.
After tagging the frame with the selected VLAN, the port reports the source MAC address of the frame.
2.      The port uses the source address and VLAN of the frame to match the MAC-to VLAN entries.
¡  If the source MAC address of the frame exactly matches the MAC address in a MAC-to-VLAN entry, the port checks whether the VLAN ID of the frame matches the VLAN in the entry.
-       If the two VLAN IDs match, the port joins the VLAN and forwards the frame.
-       If the two VLAN IDs do not match, the port drops the frame.
¡  If the source MAC address of the frame does not match any MAC addresses in MAC-to-VLAN entries exactly, the port checks whether the VLAN ID of the frame is its PVID.
-       If the VLAN ID of the frame is the PVID of the port, the port determines whether it allows the PVID. If the PVID is allowed, the port forwards the frame within the PVID. If the PVID is not allowed, the port drops the frame.
-       If the VLAN ID of the frame is not the PVID of the port, the port matches the VLAN ID of the frame by using other criteria, such as IP subnet or protocol, and forwards the frame. If no VLAN is available, the port drops the frame.
Figure 3 Flowchart for processing a frame in dynamic MAC-based VLAN assignment
When you configure dynamic MAC-based VLAN assignment, follow these guidelines:
·           When a port joins a VLAN specified in the MAC-to-VLAN entry, one of the following events occurs depending on the port configuration:
¡  If the port has not been configured to allow packets from the VLAN to pass through, the port joins the VLAN as an untagged member.
¡  If the port has been configured to allow packets from the VLAN to pass through, the port configuration remains the same.
·           If you configure both static and dynamic MAC-based VLAN assignments on a port, dynamic MAC-based VLAN assignment takes effect.
·           When a packet matches a MAC-to-VLAN entry, the device determines a forwarding policy for the packet according to the 802.1p priority of the VLAN in the MAC-to-VLAN entry.
Server-assigned MAC-based VLAN
Use the server-assigned MAC-based VLAN feature with access authentication, such as MAC-based 802.1X authentication, to implement secure and flexible terminal access. In addition to configuring the server-assigned MAC-based VLAN feature on the device, you must configure the username-to-VLAN entries on the access authentication server.
When a user passes authentication of the access authentication server, the server issues the VLAN ID for the user to the device. The device then performs the following operations:
1.      Generates a MAC-to-VLAN entry by using the source MAC address of the user packet and the received VLAN ID. The VLAN is a MAC-based VLAN.
2.      Assigns the port that connects the user to the MAC-based VLAN.
When the user goes offline, the device automatically deletes the MAC-to-VLAN entry and removes the port from the MAC-based VLAN. For more information about 802.1X and MAC authentication, see Security Configuration Guide.
When you configure MAC-based VLANs, follow these restrictions and guideline:
·           As a best practice, do not both configure dynamic MAC-based VLAN assignment and disable MAC address learning on a port. If the two features are configured together on a port, the port forwards only packets exactly matching the MAC-to-VLAN entry and drops inexactly matching packets.
·           Do not use dynamic MAC-based VLAN assignment together with 802.1X or MAC authentication.
·           For successful dynamic MAC-based VLAN assignment, use static VLANs when you create MAC-to-VLAN entries.
·           The MAC-based VLAN feature is mainly configured on downlink ports of user access devices. Do not enable this function with link aggregation.
·           As a best practice, do not use dynamic MAC-based VLAN assignment together with MSTP. In MSTP mode, if a port is blocked in the MSTI of the target VLAN, the port drops the received packets instead of delivering them to the CPU. As a result, the receiving port will not be dynamically assigned to the VLAN.
·           As a best practice, do not use dynamic MAC-based VLAN assignment together with PVST. In PVST mode, if the target VLAN is not permitted on a port, the port is placed in blocked state. The received packets are dropped instead of being delivered to the CPU. As a result, the receiving port will not be dynamically assigned to the VLAN.
·           As a best practice, do not configure both dynamic MAC-based VLAN assignment and automatic voice VLAN assignment mode on a port. If you have to configure both of them on a port, configure dynamic MAC-based VLAN assignment first. If you configure them in a reverse order, conflict will occur. When you remove one of the configurations, the operation of the other is affected.
Step
Remarks
N/A
2.      Create a MAC-to-VLAN entry.
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ dot1q priority ]
N/A
3.      Enter Layer 2 Ethernet interface view.
N/A
4.      Configure the link type of the port as hybrid.
5.      Configure the hybrid port to forward packets from the MAC-based VLANs.
6.      Enable the MAC-based VLAN feature.
mac-vlan enable
7.      (Optional.) Configure VLAN matching order.
vlan precedence { mac-vlan | ip-subnet-vlan }
By default, the system assigns VLANs based on the MAC address preferentially.
Step
Remarks
N/A
mac-vlan mac-address mac-address vlan vlan-id [ dot1q priority ]
The VLAN assignment for a port is triggered only when the source MAC address of its receiving packet exactly matches the MAC address in the MAC-to-VLAN entry.
N/A
5.      Enable the MAC-based VLAN feature.
mac-vlan enable
By default, MAC-based VLAN is disabled.
6.      Enable dynamic MAC-based VLAN assignment.
mac-vlan trigger enable
By default, dynamic MAC-based VLAN assignment is disabled.
By default, the system assigns VLANs based on the MAC address preferentially..
As a best practice to ensure the priority of MAC-based VLAN matching, configure the vlan precedence mac-vlan command when you enable dynamic MAC-based VLAN assignment. If you execute the  vlan precedence ip-subnet-vlan command, the command will not take effect.
8.      (Optional.) Disable the port from forwarding packets that fail the exact MAC address match in its PVID.
port pvid forbidden
By default, when a port receives packets whose source MAC addresses fail the exact match, the port forwards them in its PVID.
Step
Remarks
N/A
2.      Enter Layer 2 Ethernet interface view.
N/A
3.      Configure the link type of the ports as hybrid.
4.      Configure the hybrid port to forward packets from the MAC-based VLANs.
mac-vlan enable
6.      Configure 802.1X or MAC authentication.
For more information, see Security Command Reference.
N/A
In this method, packets are assigned to VLANs based on their source IP addresses and subnet masks. A port configured with IP subnet-based VLANs assigns a received untagged packet to a VLAN based on the source address of the packet.
Use this feature when packets from an IP subnet or IP address must be transmitted in a VLAN.
This feature is available only on hybrid ports, and it processes only untagged packets.
An IP subnet-based VLAN has one or multiple subnets to match inbound packets. Each subnet has a unique index in the IP subnet-based VLAN. All subnets in an IP subnet-based VLAN have the same VLAN ID.
To configure a IP subnet-based VLAN:
Remarks
N/A
2.      Enter VLAN view.
vlan vlan-id
N/A
3.      Associate an IP subnet or IP address with the VLAN.
ip-subnet-vlan [ ip-subnet-index ] ip ip-address [ mask ]
By default, a VLAN is not associated with any IP subnets or IP addresses.
A multicast subnet or a multicast address cannot be associated with a VLAN.
4.      Return to system view.
N/A
5.      Enter interface view.
·          The configurations made in Layer 2 Ethernet interface view apply only to the port.
·          The configurations made in Layer 2 aggregate interface view apply to the aggregate interface and its aggregation member ports. If the system fails to apply the configurations to the aggregate interface, it stops applying the configurations to the aggregation member ports. If the system fails to apply the configurations to an aggregation member port, it skips the port and moves to the next member port.
6.      Configure the port link type as hybrid.
7.      Assign the hybrid port to the specified IP subnet-based VLANs.
8.      Associate the hybrid port with the specified IP subnet-based VLAN.
port hybrid ip-subnet-vlan vlan vlan-id
By default, no IP subnet-based VLAN is associated with a hybrid port.
The protocol-based VLAN feature assigns inbound packets to different VLANs based on their protocol types and encapsulation formats. The protocols available for VLAN assignment include IP, IPX, and AT. The encapsulation formats include Ethernet II, 802.3 raw, 802.2 LLC, and 802.2 SNAP.
A protocol template defines a protocol type and an encapsulation format. A combination of a protocol-based VLAN ID and a protocol index uniquely identify a protocol template. You can assign multiple protocol templates to a protocol-based VLAN.
This feature is available only on hybrid ports, and it processes only untagged packets. It associates the available network service types with VLANs and facilitates network management and maintenance.
A protocol-based VLAN has one or multiple protocol templates. A protocol template defines a protocol type and an encapsulation format as the match criteria to match inbound packets. Each protocol template has a unique index in the protocol-based VLAN. All protocol templates in a protocol-based VLAN have the same VLAN ID.
For a port to assign inbound packets to protocol-based VLANs, perform the following tasks:
·           Assign the port to the protocol-based VLANs.
·           Associate the port with the protocol templates of the protocol-based VLANs.
When an untagged packet arrives at the port, the port processes the packet as follows:
·           If the protocol type and encapsulation format in the packet match a protocol template, the port tags the packet with the VLAN tag specific to the protocol template.
·           If no protocol templates are matched, the port tags the packet with its PVID.
The voice VLAN in automatic mode processes only tagged voice traffic. Do not configure a VLAN as both a protocol-based VLAN and a voice VLAN.
To configure a protocol-based VLAN:
Step
Remarks
N/A
2.      Enter VLAN view.
vlan vlan-id
If the specified VLAN does not exist, this command first creates the VLAN and enters VLAN view of this VLAN.
3.      Create a protocol template for the VLAN.
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
By default, no protocol template is configured for a VLAN.
4.      Exit VLAN view.
N/A
·          The configurations made in Layer 2 aggregate interface view apply to the aggregate interface and its aggregation member ports. If the system fails to apply the configurations to the aggregate interface, it stops applying the configurations to aggregation member ports. If the system fails to apply the configurations to an aggregation member port, it skips the port and moves to the next member port.
7.      Assign the hybrid port to the specified protocol-based VLANs.
8.      Associate the hybrid port with the specified protocol-based VLAN.
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
By default, a port is not associated with any protocol-based VLANs.
After you configure a VLAN group on the device, the authentication sever can assign the VLAN group name to the 802.1X user that passes authentication. The VLAN group name identifies this group of VLANs. For more information about 802.1X authentication, see Security Configuration Guide.
To configure a VLAN group:
Step
Remarks
N/A
2.      Create a VLAN group and enter VLAN group view.
vlan-group group-name
By default, no VLAN group exists.
3.      Add VLANs to the VLAN group.
vlan-list vlan-id-list
By default, no VLAN exists in a VLAN group.
Display VLAN interface information.
display interface vlan-interface [ brief [ description | down ] ]
display interface vlan-interface interface-number [ brief [ description ] ]
Display MAC-to-VLAN entries.
display mac-vlan { all | dynamic | mac-address mac-address [ mask mac-mask ] | static | vlan vlan-id }
Display all ports that are enabled with the MAC-based VLAN feature.
display mac-vlan interface
Display information about IP subnet-based VLANs that are associated with the specified ports.
display ip-subnet-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
Display information about IP subnet-based VLANs.
display ip-subnet-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
Display information about protocol-based VLANs that are associated with the specified ports.
display protocol-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
Display information about protocol-based VLANs.
display protocol-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
Display VLAN information.
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
Display brief VLAN information.
display vlan brief
Display VLAN group information.
display vlan-group [ group-name ]
Display hybrid ports or trunk ports on the device.
Network requirements
As shown in Figure 4:
·           Host A and Host C belong to Department A. VLAN 100 is assigned to Department A.
·           Host B and Host D belong to Department B. VLAN 200 is assigned to Department B.
Configure port-based VLANs so that only hosts in the same department can communicate with each other.
Figure 4 Network diagram
1.      Configure Device A:
# Create VLAN 100, and assign Ten-GigabitEthernet 1/0/1 to VLAN 100.
[DeviceA] vlan 100
[DeviceA-vlan100] port ten-gigabitethernet 1/0/1
[DeviceA-vlan100] quit
# Create VLAN 200, and assign Ten-GigabitEthernet 1/0/2 to VLAN 200.
[DeviceA] vlan 200
[DeviceA-vlan200] port ten-gigabitethernet 1/0/2
[DeviceA-vlan200] quit
# Configure Ten-GigabitEthernet 1/0/3 as a trunk port to forward packets from VLANs 100 and 200 to Device B.
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/3] port trunk permit vlan 100 200
Please wait... Done.
2.      Configure Device B in the same way Device A is configured. (Details not shown.)
3.      Configure hosts:
¡  Configure Host A and Host C to be on the same IP subnet. For example, 192.168.100.0/24.
¡  Configure Host B and Host D to be on the same IP subnet. For example, 192.168.200.0/24.
# Verify that Host A and Host C can ping each other, but they both fail to ping Host B. (Details not shown.)
# Verify that Host B and Host D can ping each other, but they both fail to ping Host A. (Details not shown.)
# Verify that VLANs 100 and 200 are correctly configured on devices, for example, on Device A.
[DeviceA-Ten-GigabitEthernet1/0/3] display vlan 100
 VLAN ID: 100
 VLAN type: Static
 Description: VLAN 0100
 Tagged ports:
 Untagged ports:
    Ten-GigabitEthernet1/0/1
[DeviceA-Ten-GigabitEthernet1/0/3] display vlan 200
 VLAN ID: 200
 VLAN type: Static
 Description: VLAN 0200
 Tagged ports:
 Untagged ports:
    Ten-GigabitEthernet1/0/2
As shown in Figure 5:
·           Ten-GigabitEthernet 1/0/1 of Device A and Device C are each connected to a meeting room. Laptop 1 and Laptop 2 are used for meetings and might be used in either of the two meeting rooms.
·           Different departments own Laptop 1 and Laptop 2. The two departments use VLANs 100 and 200, respectively.
Configure MAC-based VLANs, so that each laptop is able to access only its own department server, no matter which meeting room they are used in.
Figure 5 Network diagram
# Create VLANs 100 and 200.
[DeviceA] vlan 100
[DeviceA] vlan 200
# Associate the MAC addresses of Laptop 1 and Laptop 2 with VLANs 100 and 200, respectively.
[DeviceA] mac-vlan mac-address 000d-88f8-4e71 vlan 100
[DeviceA] mac-vlan mac-address 0014-222c-aa69 vlan 200
# Configure Ten-GigabitEthernet 1/0/1 as a hybrid port to forward packets from VLANs 100 and 200 without VLAN tags.
[DeviceA-Ten-GigabitEthernet1/0/1] port link-type hybrid
[DeviceA-Ten-GigabitEthernet1/0/1] port hybrid vlan 100 200 untagged
# Enable the MAC-based VLAN feature on Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] mac-vlan enable
# Configure the uplink port Ten-GigabitEthernet 1/0/2 as a trunk port, and assign it to VLANs 100 and 200.
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/2] port trunk permit vlan 100 200
[DeviceA-Ten-GigabitEthernet1/0/2] quit
2.      Configure Device B:
# Create VLAN 100 and assign Ten-GigabitEthernet 1/0/13 to VLAN 100.
[DeviceB] vlan 100
[DeviceB-vlan100] port ten-gigabitethernet 1/0/13
[DeviceB-vlan100] quit
# Create VLAN 200 and assign Ten-GigabitEthernet 1/0/14 to VLAN 200.
[DeviceB] vlan 200
[DeviceB-vlan200] port ten-gigabitethernet 1/0/14
[DeviceB-vlan200] quit
# Configure Ten-GigabitEthernet 1/0/3 as a trunk port, and assign the port to VLANs 100 and 200.
[DeviceB] interface ten-gigabitethernet 1/0/3
[DeviceB-Ten-GigabitEthernet1/0/3] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/3] port trunk permit vlan 100 200
[DeviceB-Ten-GigabitEthernet1/0/3] quit
# Configure Ten-GigabitEthernet 1/0/4 as a trunk port, and assign the port to VLANs 100 and 200.
[DeviceB] interface ten-gigabitethernet 1/0/4
[DeviceB-Ten-GigabitEthernet1/0/4] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/4] port trunk permit vlan 100 200
[DeviceB-Ten-GigabitEthernet1/0/4] quit
3.      Configure Device C in the same way as the Device A is configured. (Details not shown.)
# Verify that Laptop 1 can access only Server 1, and Laptop 2 can access only Server 2. (Details not shown.)
# Verify the MAC-to-VLAN entries on Device A and Device C, for example, Device A.
[DeviceA] display mac-vlan all
  The following MAC VLAN addresses exist:
  S:Static  D:Dynamic
  MAC address      Mask             VLAN ID  Dot1q      State
  000d-88f8-4e71   ffff-ffff-ffff   100       0          S
  0014-222c-aa69   ffff-ffff-ffff   200       0          S
  Total MAC VLAN address count: 2
As shown in Figure 6, the hosts in the office belong to different IP subnets.
Configure Device C to transmit packets from 192.168.5.0/24 and 192.168.50.0/24 in VLANs 100 and 200, respectively.
Figure 6 Network diagram
1.      Configure Device C:
# Associate IP subnet 192.168.5.0/24 with VLAN 100.
<DeviceC> system-view
[DeviceC] vlan 100
[DeviceC-vlan100] ip-subnet-vlan ip 192.168.5.0 255.255.255.0
[DeviceC-vlan100] quit
# Associate IP subnet 192.168.50.0/24 with VLAN 200.
[DeviceC] vlan 200
[DeviceC-vlan200] ip-subnet-vlan ip 192.168.50.0 255.255.255.0
[DeviceC-vlan200] quit
# Configure Ten-GigabitEthernet 1/0/11 as a hybrid port, and assign it to VLAN 100 as a tagged VLAN member.
[DeviceC] interface ten-gigabitethernet 1/0/11
[DeviceC-Ten-GigabitEthernet1/0/11] port link-type hybrid
[DeviceC-Ten-GigabitEthernet1/0/11] port hybrid vlan 100 tagged
[DeviceC-Ten-GigabitEthernet1/0/11] quit
# Configure Ten-GigabitEthernet1/0/12 as a hybrid port, and assign it to VLAN 200 as a tagged VLAN member.
[DeviceC] interface ten-gigabitethernet 1/0/12
[DeviceC-Ten-GigabitEthernet1/0/12] port link-type hybrid
[DeviceC-Ten-GigabitEthernet1/0/12] port hybrid vlan 200 tagged
[DeviceC-Ten-GigabitEthernet1/0/12] quit
# Configure Ten-GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLANs 100 and 200 as an untagged VLAN member.
[DeviceC-Ten-GigabitEthernet1/0/1] port link-type hybrid
[DeviceC-Ten-GigabitEthernet1/0/1] port hybrid vlan 100 200 untagged
# Associate Ten-GigabitEthernet 1/0/1 with IP subnet-based VLANs 100 and 200.
[DeviceC-Ten-GigabitEthernet1/0/1] port hybrid ip-subnet-vlan vlan 100
[DeviceC-Ten-GigabitEthernet1/0/1] port hybrid ip-subnet-vlan vlan 200
[DeviceC-Ten-GigabitEthernet1/0/1] quit
2.      Configure Device A and Device B to forward packets from VLANs 100 and 200, respectively. (Details not shown.)
# Display information about all IP subnet-based VLANs.
[DeviceC] display ip-subnet-vlan vlan all
 VLAN ID: 100
  Subnet index      IP address      Subnet mask
  0                 192.168.5.0     255.255.255.0
 VLAN ID: 200
  0                 192.168.50.0    255.255.255.0
# Display IP subnet-based VLANs on Ten-GigabitEthernet 1/0/1.
[DeviceC] display ip-subnet-vlan interface ten-gigabitethernet 1/0/1
  VLAN ID   Subnet index    IP address       Subnet mask       Status
  100       0               192.168.5.0      255.255.255.0     Active
  200       0               192.168.50.0     255.255.255.0     Active
As shown in Figure 7:
·           The majority of hosts in a lab environment run the IPv4 protocol.
·           The other hosts run the IPv6 protocol for teaching purposes.
To isolate IPv4 and IPv6 traffic at Layer 2, configure protocol-based VLANs to associate the IPv4 and ARP protocols with VLAN 100, and associate the IPv6 protocol with VLAN 200.
Figure 7 Network diagram
In this example, L2 Switch A and L2 Switch B use the factory configuration.
1.      Configure Device:
# Create VLAN 100, and configure the description for VLAN 100 as protocol VLAN for IPv4.
[Device] vlan 100
[Device-vlan100] description protocol VLAN for IPv4
# Assign Ten-GigabitEthernet 1/0/11 to VLAN 100.
[Device-vlan100] port ten-gigabitethernet 1/0/11
[Device-vlan100] quit
# Create VLAN 200, and configure the description for VLAN 200 as protocol VLAN for IPv6.
[Device] vlan 200
[Device-vlan200] description protocol VLAN for IPv6
# Assign Ten-GigabitEthernet 1/0/12 to VLAN 200.
[Device-vlan200] port ten-gigabitethernet 1/0/12
# Configure VLAN 200 as a protocol-based VLAN, and create an IPv6 protocol template with the index 1 for VLAN 200.
[Device-vlan200] protocol-vlan 1 ipv6
[Device-vlan200] quit
# Configure VLAN 100 as a protocol-based VLAN, and create an IPv4 protocol template with the index 1 for VLAN 100.
[Device] vlan 100
[Device-vlan100] protocol-vlan 1 ipv4
# Create an ARP protocol template with the index 2 for VLAN 100. (In Ethernet II encapsulation, the protocol type ID for ARP is 0x0806.)
[Device-vlan100] protocol-vlan 2 mode ethernetii etype 0806
[Device-Ten-GigabitEthernet1/0/1] port link-type hybrid
[Device-Ten-GigabitEthernet1/0/1] port hybrid vlan 100 200 untagged
# Associate Ten-GigabitEthernet 1/0/1 with the IPv4 and ARP protocol templates of VLAN 100 and the IPv6 protocol template of VLAN 200.
[Device-Ten-GigabitEthernet1/0/1] port hybrid protocol-vlan vlan 100 1 to 2
[Device-Ten-GigabitEthernet1/0/1] port hybrid protocol-vlan vlan 200 1
# Configure Ten-GigabitEthernet 1/0/2 as a hybrid port, and assign it to VLANs 100 and 200 as an untagged VLAN member.
[Device] interface ten-gigabitethernet 1/0/2
[Device-Ten-GigabitEthernet1/0/2] port link-type hybrid
[Device-Ten-GigabitEthernet1/0/2] port hybrid vlan 100 200 untagged
# Associate Ten-GigabitEthernet 1/0/2 with the IPv4 and ARP protocol templates of VLAN 100 and the IPv6 protocol template of VLAN 200.
[Device-Ten-GigabitEthernet1/0/2] port hybrid protocol-vlan vlan 100 1 to 2
[Device-Ten-GigabitEthernet1/0/2] port hybrid protocol-vlan vlan 200 1
[Device-Ten-GigabitEthernet1/0/2] quit
2.      Configure hosts and servers:
a.    Configure IPv4 Host A, IPv4 Host B, and IPv4 server to be on the same network segment (192.168.100.0/24, for example). (Details not shown.)
b.    Configure IPv6 Host A, IPv6 Host B, and IPv6 server to be on the same network segment (2001::1/64, for example). (Details not shown.)
1.      Verify the following:
¡  The hosts and the server in VLAN 100 can successfully ping one another. (Details not shown.)
¡  The hosts and the server in VLAN 200 can successfully ping one another. (Details not shown.)
¡  The hosts or the server in VLAN 100 cannot ping the hosts or server in VLAN 200. (Details not shown.)
2.      Verify the protocol-based VLAN configuration:
# Display protocol-based VLANs on Device.
[Device] display protocol-vlan vlan all
 VLAN ID: 100
  Protocol index  Protocol type
  1               IPv4
  2               Ethernet II Etype 0x0806
 VLAN ID: 200
  1               IPv6
# Display protocol-based VLANs on the ports of Device.
[Device] display protocol-vlan interface all
  VLAN ID  Protocol index  Protocol type             Status
  100      1               IPv4                      Active
  100      2               Ethernet II Etype 0x0806  Active
  200      1               IPv6                      Active
 Interface: Ten-GigabitEthernet 1/0/2
  100      1               IPv4                      Active
  200      1               IPv6                      Active
The private VLAN feature uses a two-tier VLAN structure, including a primary VLAN and secondary VLANs. This feature simplifies the network configuration and saves VLAN resources.
A primary VLAN is used for upstream data exchange. A primary VLAN can be associated with multiple secondary VLANs. Because the upstream device identifies only the primary VLAN and not the secondary VLANs, network configuration is simplified and VLAN resources are saved.
Secondary VLANs are isolated at Layer 2. To enable Layer 3 communication between secondary VLANs associated with the same primary VLAN, you can enable local proxy ARP or ND on the upstream device (for example, Device A in Figure 8).
As shown in Figure 8, the private VLAN feature is enabled on Device B. VLAN 10 is the primary VLAN. VLAN 2, VLAN 5, and VLAN 8 are secondary VLANs associated with VLAN 10 and are invisible to Device A.
Figure 8 Private VLAN example
To configure the private VLAN feature, perform the following tasks:
1.      Configure the primary VLAN.
2.      Configure the secondary VLANs.
3.      Configure the uplink and downlink ports:
¡  Configure the uplink port (for example, the port connecting Device B to Device A in Figure 8):
-       When the port allows only one primary VLAN, configure the port as a promiscuous port of the primary VLAN. The promiscuous port can be automatically assigned to the primary VLAN and its associated secondary VLANs.
-       When the port allows multiple primary VLANs, configure the port as a trunk promiscuous port of the primary VLANs. The trunk promiscuous port can be automatically assigned to these primary VLANs and their associated secondary VLANs.
¡  Configure a downlink port (for example, the port connecting Device B to a host in Figure 8) as a host port. The host port can be automatically assigned to the secondary VLAN and its associated primary VLAN.
¡  If a downlink port allows multiple secondary VLANs, configure the port as a trunk secondary port. The trunk secondary port can be automatically assigned to the secondary VLANs and their associated primary VLANs.
For more information about promiscuous, trunk promiscuous, host, and trunk secondary ports, see Layer 2—LAN Switching Command Reference.
4.      Associate the secondary VLANs with the primary VLAN.
5.      (Optional.) Configure Layer 3 communication between the specified secondary VLANs that are associated with the primary VLAN.
When you configure the private VLAN feature, follow these restrictions and guidelines:
·           After you complete the private VLAN configurations, perform the following tasks:
¡  For a promiscuous port, make sure the following requirements are met:
-       The primary VLAN is the PVID of the port.
-       The port is an untagged member of the primary VLAN and secondary VLANs.
¡  For a host port, make sure the following requirements are met:
-       The PVID of the port is a secondary VLAN.
-       The port is an untagged member of the primary VLAN and the secondary VLAN.
¡  For a trunk promiscuous or trunk secondary port, make sure the port is a tagged member of the primary VLANs and the secondary VLANs.
·           VLAN 1 (system default VLAN) does not support the private VLAN configuration.
To configure the private VLAN feature:
Step
Remarks
N/A
2.      Create a VLAN and enter VLAN view.
vlan vlan-id
N/A
3.      Configure the VLAN as a primary VLAN.
private-vlan primary
By default, a VLAN is not a primary VLAN.
N/A
5.      Create one or multiple secondary VLANs.
N/A
6.      Enable Layer 2 communication for ports in the same secondary VLAN.
·          undo private-vlan isolated
·          private-vlan community
Use either command.
By default, ports in the same secondary VLAN can communicate with each other at Layer 2.
This configuration takes effect when the following conditions exist:
·          The ports in the secondary VLAN are configured as host ports.
·          The secondary VLAN is associated with a primary VLAN.
7.      Return to system view.
N/A
8.      Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
9.      Configure the uplink port as a promiscuous or trunk promiscuous port of the specified VLANs.
·          Configure the uplink port as a promiscuous port of the specified VLAN:
port private-vlan vlan-id promiscuous
·          Configure the uplink port as a trunk promiscuous port of the specified VLANs:
port private-vlan vlan-id-list trunk promiscuous
By default, a port is not a promiscuous or trunk promiscuous port of any VLAN.
10.   Return to system view.
N/A
11.   Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
12.   Assign the downlink port to secondary VLANs.
a.   Set the link type of the port:
b.   Assign the access port to the specified VLAN:
c.   Assign the trunk port to the specified VLANs:
d.   Assign the hybrid port to the specified VLANs:
Select substep b, c, or d depending on the port link type.
13.   Return to system view.
N/A
14.   Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
15.   Configure the downlink port as a host or trunk secondary port.
·          Configure the downlink port as a host port:
port private-vlan host
·          Configure the downlink port as a trunk secondary port:
port private-vlan vlan-id-list trunk secondary
By default, a port is not a host or trunk secondary port.
16.   Enter primary VLAN view.
vlan vlan-id
N/A
17.   Associate the primary VLAN with the specified secondary VLANs.
private-vlan secondary vlan-id-list
By default, a primary VLAN is not associated with any secondary VLAN.
18.   Return to system view.
N/A
19.   (Optional.) Configure Layer 3 communication between the specified secondary VLANs.
a.   Enter VLAN interface view of the primary VLAN interface:
interface vlan-interface vlan-id
b.   Enable Layer 3 communication between secondary VLANs that are associated with the primary VLAN:
c.   Assign an IPv4 address to the primary VLAN interface:
d.   Assign an IPv6 address to the primary VLAN interface:
e.   Enable local proxy ARP:
local-proxy-arp enable
f.    Enable local proxy ND:
local-proxy-nd enable
Use substeps a, b, c, and e for devices that run IPv4 protocols.
Use substeps a, b, d, and f for devices that run IPv6 protocols.
By default:
·          Secondary VLANs cannot communicate with each other at Layer 3.
·          No IP address is configured for a VLAN interface.
·          Local proxy ARP and local proxy ND are disabled.
Display information about primary VLANs and the secondary VLANs associated with each primary VLAN.
display private-vlan [ primary-vlan-id ]
As shown in Figure 9, configure the private VLAN feature to meet the following requirements:
·           On Device B, VLAN 5 is a primary VLAN that is associated with secondary VLANs 2 and 3. Ten-GigabitEthernet 1/0/5 is in VLAN 5. Ten-GigabitEthernet 1/0/2 is in VLAN 2. Ten-GigabitEthernet 1/0/1 is in VLAN 3.
·           On Device C, VLAN 6 is a primary VLAN that is associated with secondary VLANs 3 and 4. Ten-GigabitEthernet 1/0/5 is in VLAN 6. Ten-GigabitEthernet 1/0/3 is in VLAN 3. Ten-GigabitEthernet 1/0/4 is in VLAN 4.
·           Device A is aware of only VLAN 5 on Device B and VLAN 6 on Device C.
Figure 9 Network diagram
This example describes the configurations on Device B and Device C.
1.      Configure Device B:
# Configure VLAN 5 as a primary VLAN.
[DeviceB] vlan 5
[DeviceB-vlan5] private-vlan primary
[DeviceB-vlan5] quit
# Create VLANs 2 and 3.
[DeviceB] vlan 2 to 3
# Configure the uplink port Ten-GigabitEthernet 1/0/5 as a promiscuous port of VLAN 5.
[DeviceB] interface ten-gigabitethernet 1/0/5
[DeviceB-Ten-GigabitEthernet1/0/5] port private-vlan 5 promiscuous
[DeviceB-Ten-GigabitEthernet1/0/5] quit
# Assign the downlink port Ten-GigabitEthernet 1/0/1 to VLAN 3, and configure the port as a host port.
[DeviceB-Ten-GigabitEthernet1/0/1] port access vlan 3
[DeviceB-Ten-GigabitEthernet1/0/1] port private-vlan host
# Assign the downlink port Ten-GigabitEthernet 1/0/2 to VLAN 2, and configure the port as a host port.
[DeviceB] interface ten-gigabitethernet 1/0/2
[DeviceB-Ten-GigabitEthernet1/0/2] port access vlan 2
[DeviceB-Ten-GigabitEthernet1/0/2] port private-vlan host
[DeviceB-Ten-GigabitEthernet1/0/2] quit
# Associate the secondary VLANs 2 and 3 with the primary VLAN 5.
[DeviceB] vlan 5
[DeviceB-vlan5] private-vlan secondary 2 to 3
2.      Configure Device C:
# Configure VLAN 6 as a primary VLAN.
[DeviceC] vlan 6
[DeviceC–vlan6] private-vlan primary
[DeviceC–vlan6] quit
# Create VLANs 3 and 4.
[DeviceC] vlan 3 to 4
# Configure the uplink port Ten-GigabitEthernet 1/0/5 as a promiscuous port of VLAN 6.
[DeviceC] interface ten-gigabitethernet 1/0/5
[DeviceC-Ten-GigabitEthernet1/0/5] port private-vlan 6 promiscuous
[DeviceC-Ten-GigabitEthernet1/0/5] quit
# Assign the downlink port Ten-GigabitEthernet 1/0/3 to VLAN 3, and configure the port as a host port.
[DeviceC] interface ten-gigabitethernet 1/0/3
[DeviceC-Ten-GigabitEthernet1/0/3] port access vlan 3
[DeviceC-Ten-GigabitEthernet1/0/3] port private-vlan host
[DeviceC-Ten-GigabitEthernet1/0/3] quit
# Assign the downlink port Ten-GigabitEthernet 1/0/4 to VLAN 4, and configure the port as a host port.
[DeviceC] interface ten-gigabitethernet 1/0/4
[DeviceC-Ten-GigabitEthernet1/0/4] port access vlan 4
[DeviceC-Ten-GigabitEthernet1/0/4] port private-vlan host
[DeviceC-Ten-GigabitEthernet1/0/4] quit
# Associate the secondary VLANs 3 and 4 with the primary VLAN 6.
[DeviceC] vlan 6
[DeviceC-vlan6] private-vlan secondary 3 to 4
[DeviceC-vlan6] quit
# Display the private VLAN configuration on the devices, for example, on Device B.
[DeviceB] display private-vlan
 Primary VLAN ID: 5
 Secondary VLAN ID: 2-3
 VLAN ID: 5
 VLAN type: Static
 Private VLAN type: Primary
 Description: VLAN 0005
 Tagged   ports: None
 Untagged ports:
    Ten-GigabitEthernet1/0/1            Ten-GigabitEthernet1/0/2            Ten-GigabitEthernet1/0/5
 VLAN ID: 2
 VLAN type: Static
 Private VLAN type: Secondary
 Description: VLAN 0002
 Tagged   ports: None
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 Description: VLAN 0003
 Tagged   Ports: None
 Untagged Ports:
    Ten-GigabitEthernet1/0/1            Ten-GigabitEthernet1/0/5
The output shows that:
·           The promiscuous port Ten-GigabitEthernet 1/0/5 is an untagged member of primary VLAN 5 and secondary VLANs 2 and 3.
·           The host port Ten-GigabitEthernet 1/0/2 is an untagged member of primary VLAN 5 and secondary VLAN 2.
·           The host port Ten-GigabitEthernet 1/0/1 is an untagged member of primary VLAN 5 and secondary VLAN 3.
As shown in Figure 10, configure the private VLAN feature to meet the following requirements:
·           VLANs 5 and 10 are primary VLANs on Device B. The uplink port Ten-GigabitEthernet 1/0/1 on Device B permits the packets from VLANs 5 and 10 to pass through tagged.
·           On Device B, the downlink port Ten-GigabitEthernet 1/0/2 permits secondary VLAN 2. The downlink port Ten-GigabitEthernet 1/0/3 permits secondary VLAN 3. Secondary VLANs 2 and 3 are associated with primary VLAN 5.
·           On Device B, the downlink port Ten-GigabitEthernet 1/0/6 permits secondary VLAN 6. The downlink port Ten-GigabitEthernet 1/0/8 permits secondary VLAN 8. Secondary VLANs 6 and 8 are associated with primary VLAN 10.
·           Device A is aware of only VLANs 5 and 10 on Device B.
Figure 10 Network diagram
# Configure VLANs 5 and 10 as primary VLANs.
[DeviceB] vlan 5
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan primary
[DeviceB-vlan10] quit
# Create VLANs 2, 3, 6, and 8.
[DeviceB] vlan 6
[DeviceB-vlan6] quit
[DeviceB] vlan 8
[DeviceB-vlan8] quit
# Configure the uplink port Ten-GigabitEthernet 1/0/1 as a trunk promiscuous port of VLANs 5 and 10.
[DeviceB-Ten-GigabitEthernet1/0/1] port private-vlan 5 10 trunk promiscuous
[DeviceB-Ten-GigabitEthernet1/0/3] port access vlan 3
[DeviceB-Ten-GigabitEthernet1/0/3] port private-vlan host
[DeviceB] vlan 5
# Assign the downlink port Ten-GigabitEthernet 1/0/6 to VLAN 6, and configure the port as a host port.
[DeviceB] interface ten-gigabitethernet 1/0/6
[DeviceB-Ten-GigabitEthernet1/0/6] port access vlan 6
[DeviceB-Ten-GigabitEthernet1/0/6] port private-vlan host
[DeviceB-Ten-GigabitEthernet1/0/6] quit
# Assign the downlink port Ten-GigabitEthernet 1/0/8 to VLAN 8, and configure the port as a host port.
[DeviceB] interface ten-gigabitethernet 1/0/8
[DeviceB-Ten-GigabitEthernet1/0/8] port access vlan 8
[DeviceB-Ten-GigabitEthernet1/0/8] port private-vlan host
[DeviceB-Ten-GigabitEthernet1/0/8] quit
# Associate the secondary VLANs 6 and 8 with the primary VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan secondary 6 8
2.      Configure Device A:
# Create VLANs 5 and 10.
[DeviceA] vlan 5
[DeviceA-vlan5] quit
[DeviceA] vlan 10
[DeviceA-vlan10] quit
# Configure Ten-GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLANs 5 and 10 as a tagged VLAN member.
[DeviceA-Ten-GigabitEthernet1/0/1] port hybrid vlan 5 10 tagged
# Display primary VLAN configurations on Device B. The following output uses primary VLAN 5 as an example.
[DeviceB] display private-vlan 5
 Primary VLAN ID: 5
 VLAN ID: 5
 VLAN type: Static
 Tagged   ports:
 Untagged ports:
    Ten-GigabitEthernet1/0/2          Ten-GigabitEthernet1/0/3
 VLAN ID: 2
 VLAN type: Static
 Tagged   ports:
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 Tagged   ports:
 Untagged ports:
·           The trunk promiscuous port Ten-GigabitEthernet 1/0/1 is a tagged member of primary VLAN 5 and secondary VLANs 2 and 3.
·           The host port Ten-GigabitEthernet 1/0/3 is an untagged member of primary VLAN 5 and secondary VLAN 3.
As shown in Figure 11, configure the private VLAN feature to meet the following requirements:
·           VLANs 10 and 20 are primary VLANs on Device A. The uplink port Ten-GigabitEthernet 1/0/5 on Device A permits the packets from VLANs 10 and 20 to pass through tagged.
·           VLAN 11, VLAN 12, VLAN 21, and VLAN 22 are secondary VLANs on Device A.
¡  The downlink port Ten-GigabitEthernet 1/0/2 permits the packets from VLAN 11 and VLAN 21 to pass through tagged.
¡  The downlink port Ten-GigabitEthernet 1/0/1 permits VLAN 22.
¡  The downlink port Ten-GigabitEthernet 1/0/3 permits VLAN 12.
·           Secondary VLANs 11 and 12 are associated with primary VLAN 10.
·           Secondary VLANs 21 and 22 are associated with primary VLAN 20.
Figure 11 Network diagram
# Configure VLANs 10 and 20 as primary VLANs.
[DeviceA] vlan 10
[DeviceA-vlan10] private-vlan primary
[DeviceA] vlan 20
[DeviceA-vlan20] private-vlan primary
[DeviceA-vlan20] quit
# Create VLANs 11, 12, 21, and 22, which are to be configured as secondary VLANs.
[DeviceA] vlan 11 to 12
[DeviceA] vlan 21 to 22
# Associate the secondary VLANs 11 and 12 with the primary VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] private-vlan secondary 11 12
# Associate the secondary VLANs 21 and 22 with the primary VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] private-vlan secondary 21 22
# Configure the uplink port Ten-GigabitEthernet 1/0/5 as a trunk promiscuous port of VLANs 10 and 20.
[DeviceA] interface ten-gigabitethernet 1/0/5
[DeviceA-Ten-GigabitEthernet1/0/5] port private-vlan 10 20 trunk promiscuous
[DeviceA-Ten-GigabitEthernet1/0/5] quit
# Assign the downlink port Ten-GigabitEthernet 1/0/1 to VLAN 22 and configure the port as a host port.
[DeviceA-Ten-GigabitEthernet1/0/1] port access vlan 22
[DeviceA-Ten-GigabitEthernet1/0/1] port private-vlan host
# Assign the downlink port Ten-GigabitEthernet 1/0/3 to VLAN 12 and configure the port as a host port.
[DeviceA-Ten-GigabitEthernet1/0/3] port access vlan 12
[DeviceA-Ten-GigabitEthernet1/0/3] port private-vlan host
[DeviceA-Ten-GigabitEthernet1/0/3] quit
# Configure the downlink port Ten-GigabitEthernet 1/0/2 as a trunk secondary port in VLANs 11 and 21.
[DeviceA-Ten-GigabitEthernet1/0/2] port private-vlan 11 21 trunk secondary
# Create VLANs 11 and 21.
[DeviceB] vlan 11
[DeviceB-vlan11] quit
[DeviceB] vlan 21
[DeviceB-vlan21] quit
# Configure Ten-GigabitEthernet 1/0/2 as a hybrid port, and assign it to VLANs 11 and 21 as a tagged VLAN member.
[DeviceB-Ten-GigabitEthernet1/0/2] port link-type hybrid
[DeviceB-Ten-GigabitEthernet1/0/2] port hybrid vlan 11 21 tagged
# Assign the port Ten-GigabitEthernet 1/0/4 to VLAN 11.
[DeviceB-Ten-GigabitEthernet1/0/4] port access vlan 11
# Assign the port Ten-GigabitEthernet 1/0/3 to VLAN 21.
[DeviceB-Ten-GigabitEthernet1/0/3] port access vlan 21
3.      Configure Device C:
# Create VLANs 10 and 20.
[DeviceC] vlan 10
[DeviceC-vlan10] quit
[DeviceC] vlan 20
[DeviceC-vlan20] quit
# Configure Ten-GigabitEthernet1/0/5 as a hybrid port, and assign it to VLANs 10 and 20 as a tagged VLAN member.
[DeviceC-Ten-GigabitEthernet1/0/5] port link-type hybrid
[DeviceC-Ten-GigabitEthernet1/0/5] port hybrid vlan 10 20 tagged
# Display the configuration of primary VLAN 10 on Device A.
[DeviceA] display private-vlan 10
 Primary VLAN ID: 10
 Secondary VLAN ID: 11-12
 VLAN ID: 10
 VLAN type: Static
 Private-vlan type: Primary
 Description: VLAN 0010
 Tagged   ports:
 Untagged ports:
 VLAN ID: 11
 VLAN type: Static
 Private-vlan type: Secondary
 Description: VLAN 0011
 Tagged   ports:
 Untagged ports: None
VLAN ID: 12
 VLAN type: Static
 Description: VLAN 0012
 Tagged   ports:
 Untagged ports:
·           The trunk promiscuous port Ten-GigabitEthernet 1/0/5 is a tagged member of primary VLAN 10 and secondary VLANs 11 and 12.
·           The trunk secondary port Ten-GigabitEthernet 1/0/2 is a tagged member of primary VLAN 10 and secondary VLAN 11.
·           The host port Ten-GigabitEthernet 1/0/3 is an untagged member of primary VLAN 10 and secondary VLAN 12.
# Display the configuration of primary VLAN 20 on Device A.
[DeviceA] display private-vlan 20
 Primary VLAN ID: 20
 Secondary VLAN ID: 21-22
 VLAN ID: 20
 VLAN type: Static
 Description: VLAN 0020
 Tagged   ports:
 Untagged ports:
 VLAN ID: 21
 VLAN type: Static
 Description: VLAN 0021
 Tagged   ports:
 VLAN ID: 22
 VLAN type: Static
 Description: VLAN 0022
 Tagged   ports:
 Untagged ports:
·           The trunk promiscuous port Ten-GigabitEthernet 1/0/5 is a tagged member of primary VLAN 20 and secondary VLANs 21 and 22.
·           The trunk secondary port Ten-GigabitEthernet 1/0/2 is a tagged member of primary VLAN 20 and secondary VLAN 21.
·           The host port Ten-GigabitEthernet 1/0/1 is an untagged member of primary VLAN 20 and secondary VLAN 22.
As shown in Figure 12, configure the private VLAN feature to meet the following requirements:
·           Primary VLAN 10 on Device B is associated with secondary VLANs 2 and 3.
·           The uplink port Ten-GigabitEthernet 1/0/1 is in VLAN 10.
·           The IP address of VLAN-interface 10 is 192.168.1.1/24.
·           The ports Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 are in VLAN 2 and VLAN 3, respectively.
·           Secondary VLANs are isolated at Layer 2 but interoperable at Layer 3.
Figure 12 Network diagram
# Create VLAN 2 and VLAN 3.
# Configure VLAN 10 as a primary VLAN, and associate VLAN 2 and VLAN 3 with primary VLAN 10 as secondary VLANs.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan secondary 2 3
# Configure the uplink port Ten-GigabitEthernet 1/0/1 as a promiscuous port of VLAN 10.
[DeviceB-Ten-GigabitEthernet1/0/1] port private-vlan 10 promiscuous
# Enable Layer 3 communication between secondary VLANs 2 and 3 that are associated with primary VLAN 10.
[DeviceB] interface vlan-interface 10
[DeviceB-Vlan-interface10] private-vlan secondary 2 3
# Assign the IP address 192.168.1.1/24 to VLAN-interface 10.
[DeviceB-Vlan-interface10] ip address 192.168.1.1 255.255.255.0
# Enable local proxy ARP on VLAN-interface 10.
[DeviceB-Vlan-interface10] local-proxy-arp enable
[DeviceB-Vlan-interface10] quit
# Display the configuration of primary VLAN 10.
[DeviceB] display private-vlan 10
 Primary VLAN ID: 10
 Secondary-VLAN ID: 2-3
 VLAN ID: 10
 VLAN type: Static
 Route interface: Configured
 IPv4 address: 192.168.1.1
 IPv4 subnet mask: 255.255.255.0
 Tagged   ports: None
 Untagged ports:
 VLAN ID: 2
 VLAN type: Static
 Tagged   ports: None
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 Tagged   ports: None
 Untagged ports:
    Ten-GigabitEthernet1/0/1            Ten-GigabitEthernet1/0/3
The Route interface field in the output is Configured, indicating that secondary VLANs 2 and 3 are interoperable at Layer 3.
Configuring voice VLANs
Overview
A voice VLAN is used for transmitting voice traffic. When ports that connect to voice devices are assigned to a voice VLAN, the system can configure QoS parameters for voice packets to ensure higher transmission priority and sound voice quality.
Common voice devices include IP phones and integrated access devices (IADs). This chapter uses IP phone as an example.
For an IP phone to access a device, the device must perform the following operations:
·           Identify the IP phone in the network and obtain the MAC address of the IP phone.
·           Advertise the voice VLAN information to the IP phone.
After receiving the voice VLAN information, the IP phone can perform automatic configuration, so the voice packets sent from the IP phone can be transmitted within the voice VLAN.
Methods of identifying IP phones
Devices can use the OUI addresses or LLDP to identify IP phones.
Identifying IP phones through OUI addresses
A device determines whether a received packet is a voice packet based on its source MAC address. A packet whose source MAC address complies with any of the Organizationally Unique Identifier (OUI) addresses of the voice devices is regarded as voice traffic.
You can use system default OUI addresses (see Table 1) or configure OUI addresses for the device. You can manually remove or add the system default OUI addresses.
The switch supports 128 OUI addresses, including system default OUI addresses.
Table 1 Default OUI addresses
Number
OUI address
Vendor
1
0001-E300-0000
Siemens phone
2
0003-6B00-0000
Cisco phone
3
0004-0D00-0000
Avaya phone
4
00D0-1E00-0000
Pingtel phone
5
0060-B900-0000
Philips/NEC phone
6
00E0-7500-0000
Polycom phone
7
00E0-BB00-0000
3Com phone
Typically, an OUI address refers to the first 24 bits of a MAC address (in binary notation) and is a globally unique identifier that IEEE assigns to a vendor. However, OUI addresses in this chapter are addresses that the system uses to determine whether a received packet is a voice packet. They are the logical AND results of the mac-address and oui-mask arguments in the voice-vlan mac-address command.
Automatically identifying IP phones through LLDP
When you use OUI addresses to identify IP phones, the number of OUI addresses that can be configured is limited. Additionally, when there are plenty of IP phones in the network, you must configure many OUI addresses. If IP phones support LLDP, configure LLDP on the device for automatic IP phone discovery. For more information, see "Enabling LLDP for automatic IP phone discovery."
Advertising the voice VLAN information to IP phones
Figure 13 shows the workflow of advertising the voice VLAN information to IP phones.
Figure 13 Workflow of advertising the voice VLAN information to IP phones
After receiving the voice VLAN information, the IP phone automatically completes the voice VLAN configuration.
·           If the voice VLAN configuration is based on the received LLDP-MED TLVs or CDP packets, the IP phone will send out packets tagged with the advertised voice VLAN ID. The voice packets will be forwarded in the voice VLAN.
For more information about configuring LLDP or CDP, see "Configuring LLDP or CDP to advertise a voice VLAN." For more information about LLDP and CDP compatibility, see "Configuring LLDP."
·           If the voice VLAN configuration is based on the authorization VLAN information, the IP phone will send out packets tagged with the advertised authorization VLAN ID. The voice packets will be forwarded in the authorization VLAN.
For more information about advertising the authorization VLAN information to IP phones, see "Dynamically advertising an authorization VLAN through LLDP or CDP." For more information about authorization VLANs, see Security Configuration Guide.
·           If the voice VLAN configuration is based on the voice VLAN information of the accessing port, the voice traffic from the IP phone will be forwarded in the voice VLAN of the accessing port. Whether the voice packets are tagged depends on the voice VLAN configuration of the accessing port. For more information about configuring a voice VLAN on a port, see "Configuring a voice VLAN on a port."
IP phone access methods
Connecting the host and the IP phone in series
As shown in Figure 14, the host is connected to the IP phone, and the IP phone is connected to the device. In this scenario, the following requirements must be met:
·           The host and the IP phone use different VLANs.
·           The IP phone is able to send out VLAN-tagged packets, so that the device can differentiate traffic from the host and the IP phone.
·           The port connecting to the IP phone forwards packets from the voice VLAN and the PVID.
Figure 14 Connecting the host and IP phone in series
Connecting the IP phone to the device
As shown in Figure 15, the IP phone is connected to the device without the presence of the host. Use this connection method when the IP phone sends out untagged voice packets. In this scenario, you must configure the voice VLAN as the PVID of the port, and configure the port to forward the packets from the PVID.
Figure 15 Connecting the IP phone to the device
Voice VLAN assignment modes
A port can be assigned to a voice VLAN automatically or manually.
Automatic mode
Use automatic mode when PCs and IP phones are connected in series to access the network through the device, as shown in Figure 14. Ports on the device transmit both voice traffic and data traffic.
When an IP phone is powered on, it sends out protocol packets. After receiving these protocol packets, the device uses the source MAC address of the protocol packets to match its OUI addresses. If the match succeeds, the system performs the following operations:
·           Assigns the receiving port of the protocol packets to the voice VLAN.
·           Issues ACL rules to set the packet precedence.
·           Starts the voice VLAN aging timer.
The system will remove the port from the voice VLAN if no packet is received from the port before the aging timer expires. The aging timer is also configurable.
If the device reboots, the port is reassigned to the voice VLAN to ensure the correct operation of the existing voice connections. The reassignment occurs automatically without being triggered by voice traffic as long as the voice VLAN operates correctly.
Manual mode
Use manual mode when only IP phones access the network through the device, as shown in Figure 15. In this mode, ports are assigned to a voice VLAN that transmits voice traffic exclusively. No data traffic affects the voice traffic transmission.
You must manually assign the receiving port on the device to a voice VLAN. The device uses the source MAC address of the received voice packets to match its OUI addresses. If the match succeeds, the system issues ACL rules to set the packet precedence.
To remove the port from the voice VLAN, you must manually remove it.
Cooperation of voice VLAN assignment modes and IP phones
Some IP phones send out VLAN-tagged packets, and others send out only untagged packets. For correct packet processing, ports of different link types must meet specific configuration requirements in different voice VLAN assignment modes.
Table 2 Configuration requirements for access/trunk/hybrid ports to support tagged voice traffic
Port link type
Support for tagged voice traffic
Access
Automatic
No
N/A
Manual
No
N/A
Trunk
Automatic
Yes
The PVID of the port cannot be the voice VLAN.
Manual
Yes
The PVID of the port cannot be the voice VLAN. Configure the port to forward the packets from the voice VLAN.
Hybrid
Automatic
Yes
Manual
Yes
The PVID of the port cannot be the voice VLAN. Configure the port to forward the packets from the voice VLAN with VLAN tags.
Table 3 Configuration requirements for access/trunk/hybrid ports to support untagged voice traffic
Port link type
Support for untagged voice traffic
Access
Automatic
No
N/A
Manual
Yes
Configure the voice VLAN as the PVID of the port.
Trunk
Automatic
No
N/A
Manual
Yes
Configure the voice VLAN as the PVID of the port. Configure the port to forward the packets from the voice VLAN.
Hybrid
Automatic
No
N/A
Manual
Yes
Configure the voice VLAN as the PVID of the port. Configure the port to forward the packets from the voice VLAN without VLAN tags.
If an IP phone sends out tagged voice traffic, and its accessing port is configured with 802.1X authentication, guest VLAN, Auth-Fail VLAN, or critical VLAN, the VLAN ID must be different for the following VLANs:
·           Voice VLAN.
·           PVID of the accessing port.
·           802.1X guest, Auth-Fail, or critical VLAN.
If an IP phone sends out untagged voice traffic, the PVID of the accessing port must be the voice VLAN. As a result, 802.1X authentication is not supported.
Security mode and normal mode of voice VLANs
Depending on the incoming packet filtering mechanisms, a voice VLAN-enabled port can operate in one of the following modes:
·           Normal modeThe port receives voice-VLAN-tagged packets and forwards them in the voice VLAN without examining their MAC addresses. If the PVID of the port is the voice VLAN and the port operates in manual VLAN assignment mode, the port forwards all the received untagged packets in the voice VLAN.
In this mode, voice VLANs are vulnerable to traffic attacks. Malicious users might send large quantities of forged voice-VLAN-tagged or untagged packets to consume the voice VLAN bandwidth to affect normal voice communication.
·           Security mode—The port uses the source MAC addresses of voice packets to match the OUI addresses of the device. Packets that fail the match will be dropped.
In a safe network, you can configure the voice VLANs to operate in normal mode to reduce the system resource consumption in source MAC address checking.
TIP
TIP:
As a best practice, do not transmit both voice traffic and non-voice traffic in a voice VLAN. If you must transmit different traffic in a voice VLAN, make sure the voice VLAN security mode is disabled.
Table 4 Packet processing on a voice VLAN-enabled port in normal and security mode
Voice VLAN mode
Packet type
Packet processing
Normal
Untagged packets or packets with the voice VLAN tags
The port does not examine the source MAC addresses of incoming packets. Both voice traffic and non-voice traffic can be transmitted in the voice VLAN.
Packets with other VLAN tags
Forwarded or dropped depending on whether the port allows packets from these VLANs to pass through.
Security
·          If the source MAC address of a packet matches an OUI address on the device, the packet is forwarded in the voice VLAN.
·          If the source MAC address of a packet does not match an OUI address on the device, the packet is dropped.
Configuration prerequisites
Before you configure a voice VLAN, complete the following tasks:
·           Create a VLAN.
·           Determine the QoS priority settings for voice VLAN traffic.
·           Determine the voice VLAN assignment mode.
Configuring the QoS priority settings for voice traffic
The QoS priority settings carried in voice traffic include the CoS and DSCP values. You can configure the device to modify the QoS priority settings for voice traffic.
Before you configure the QoS priority settings for voice traffic on a port, make sure the voice VLAN feature is disabled on it.
To configure the QoS priority settings for voice traffic:
Step
Remarks
1.      Enter system view.
N/A
N/A
3.      Configure QoS priority settings for incoming voice VLAN packets.
·          Configure the port to trust and retain the QoS priority settings:
a.   Use the 802.1p priority in incoming packets for priority mapping:
qos trust dot1p
b.   Configure the port to trust and retain the QoS priority settings:
voice-vlan qos trust
·          Configure the port to modify the CoS and DSCP values:
voice-vlan qos cos-value dscp-value
By default, a port modifies the CoS and DSCP values for voice VLAN packets to 6 and 46, respectively.
If you execute the voice-vlan qos and voice-vlan qos trust commands multiple times, the most recent configuration takes effect.
For more information about the qos trust dot1p command, see ACL and QoS Command Reference.
Configuring a port to operate in automatic voice VLAN assignment mode
When you configure a port to operate in automatic voice VLAN assignment mode, follow these restrictions and guidelines:
·           Do not configure a VLAN as both a voice VLAN and a protocol-based VLAN. A voice VLAN in automatic mode on a hybrid port processes only tagged incoming voice traffic. A protocol-based VLAN on a hybrid port processes only untagged incoming packets. For more information about protocol-based VLANs, see "Configuring protocol-based VLANs."
·           As a best practice, do not use the automatic voice VLAN assignment mode together with MSTP. In MSTP mode, if a port is blocked in the MSTI of the target voice VLAN, the port drops the received packets instead of delivering them to the CPU. As a result, the receiving port will not be dynamically assigned to the voice VLAN.
·           As a best practice, do not use the automatic voice VLAN assignment mode together with PVST. In PVST mode, if the target voice VLAN is not permitted on a port, the port is placed in blocked state. The received packets are dropped instead of being delivered to the CPU. As a result, the receiving port will not be dynamically assigned to the voice VLAN.
Configuration procedure
To configure a port to operate in automatic voice VLAN assignment mode:
Step
Remarks
N/A
2.      (Optional.) Set the voice VLAN aging timer.
voice-vlan aging minutes
By default, the aging timer of a voice VLAN is 1440 minutes.
The voice VLAN aging timer takes effect only on ports in automatic voice VLAN assignment mode.
3.      (Optional.) Enable the voice VLAN security mode.
voice-vlan security enable
By default, the voice VLAN security mode is enabled.
4.      (Optional.) Add an OUI address for voice packet identification.
voice-vlan mac-address oui mask oui-mask [ description text ]
By default, system default OUI addresses exist. For more information, see Table 1.
5.      Enter Layer 2 Ethernet interface view.
N/A
6.      Configure the link type of the port.
·          port link-type trunk
·          port link-type hybrid
N/A
7.      (Optional.) Configure the port to operate in automatic voice VLAN assignment mode.
voice-vlan mode auto
By default, the automatic voice VLAN assignment mode is enabled.
8.      Enable the voice VLAN feature on the port.
voice-vlan vlan-id enable
By default, the voice VLAN feature is disabled.
Configuring a port to operate in manual voice VLAN assignment mode
When you configure a port to operate in manual voice VLAN assignment mode, follow these restrictions and guidelines:
·           You can configure different voice VLANs on different ports on the same device. Make sure the following requirements are met:
¡  One port can be configured with only one voice VLAN.
¡  Voice VLANs must be existing static VLANs.
·           Do not enable voice VLAN on the member ports of a link aggregation group. For more information about link aggregation, see "Configuring Ethernet link aggregation."
·           For a port that is enabled with voice VLAN and operating in manual mode, you must manually assign the port to the voice VLAN to make the voice VLAN take effect.
To configure a port to operate in manual voice VLAN assignment mode:
Step
Remarks
N/A
2.      (Optional.) Enable the voice VLAN security mode.
3.      (Optional.) Add an OUI address for voice packet identification.
4.      Enter Layer 2 Ethernet interface view.
N/A
5.      Configure the port to operate in manual voice VLAN assignment mode.
undo voice-vlan mode auto
By default, the manual voice VLAN assignment mode is disabled.
6.      Assign the access, trunk, or hybrid port in manual voice VLAN assignment mode to the voice VLAN.
·          For the access port, see "Assigning an access port to a VLAN."
·          For the trunk port, see "Assigning a trunk port to a VLAN."
·          For the hybrid port, see "Assigning a hybrid port to a VLAN."
After you assign an access port to the voice VLAN, the voice VLAN becomes the PVID of the port.
7.      (Optional.) Configure the voice VLAN as the PVID of the trunk or hybrid port.
This step is required for untagged incoming voice traffic and prohibited for tagged incoming voice traffic.
The device can automatically discover the peer through LLDP, and exchange LLDP TLVs with the peer. If the LLDP System Capabilities TLV received on a port indicates that the peer can act as a telephone, the device sends an LLDP TLV with the voice VLAN configuration to the peer.
When the IP phone discovery process is complete, the port will continue the following voice VLAN configuration:
·           Join the voice VLAN.
·           Increase the transmission priority of the voice traffic sent from the IP phone.
To ensure that the IP phone can pass authentication, the device will add the MAC address of the IP phone to the MAC address table.
Before you enable LLDP for automatic IP phone discovery, complete the following tasks:
·           Enable LLDP globally and on ports.
·           Complete voice VLAN configurations.
When you enable LLDP for automatic IP phone discovery, following these restrictions and guidelines:
·           A maximum of five IP phones can be connected to each port of the device.
·           Use this feature only with the automatic voice VLAN assignment mode.
·           You cannot use this feature together with CDP compatibility.
To enable LLDP for automatic IP phone discovery:
Step
Remarks
N/A
2.      Enable LLDP for automatic IP phone discovery.
voice-vlan track lldp
By default, this function is disabled.
If IP phones support LLDP, the device advertises the voice VLAN information to the IP phones through the LLDP-MED TLVs. If IP phones support only CDP, configure CDP compatibility on the device to enable it to advertise the voice VLAN information through CDP packets.
In either case, the voice VLAN information includes the voice VLAN ID and the tagging status indicator of the voice packets. The LLDP packets sent from the device carry the priority information. The CDP packets sent from the device do not carry the priority information.
After you configure this feature, the device advertises the voice VLAN to the IP phone by following the workflow described in Figure 13.
To configure LLDP or CDP to advertise a voice VLAN:
Step
Remarks
N/A
N/A
3.      Configure LLDP or CDP to advertise a voice VLAN.
·          Configure LLDP to advertise a voice VLAN:
lldp tlv-enable med-tlv network-policy vlan-id
·          Configure CDP to advertise a voice VLAN:
a.   Specify the ID of an advertised VLAN:
cdp voice-vlan vlan-id
b.   Configure CDP compatibility:
For more information, see "Configuring LLDP."
By default, LLDP and CDP advertise the voice VLAN configured on the port.
For more information about the lldp tlv-enable med-tlv network-policy command, see Layer 2—LAN Switching Command Reference.
4.      (Optional.) Display the voice VLAN advertised by LLDP.
display lldp local-information
The advertised voice LAN information is displayed in the MED information fields in the command output.
This function is available only on IP phones that support LLDP or CDP.
Dynamic authorization VLAN advertisement through LLDP or CDP works with 802.1X or MAC authentication. If 802.1X authentication is used, make sure the IP phone support 802.1X authentication.
After the IP phone passes authentication, LLDP advertises the authorization VLAN in the LLDP-MED Network Policy TLV to the IP phone. If the IP phone supports only CDP, CDP advertises the authorization VLAN in CDP packets to the IP phone. The port connected to the IP phone will be added to the authorization VLAN.
To implement this function, perform the following configuration tasks:
1.      Enable LLDP globally and on the port connected to the IP phone.
If the IP phone supports only CDP, configure CDP compatibility on the device.
2.      Configure 802.1X or MAC authentication to ensure that the IP phone can pass security authentication. For more information about 802.1X and MAC authentication, see Security Configuration Guide.
3.      Configure the authorization VLAN for the IP phone on the authentication server. For more information about authorization VLANs, see Security Configuration Guide.
Displaying and maintaining voice VLANs
Display the voice VLAN state.
display voice-vlan state
Display the OUI addresses that the system supports.
display voice-vlan mac-address
Voice VLAN configuration examples
Automatic voice VLAN assignment mode configuration example
As shown in Figure 16, Device A transmits traffic from IP phones and hosts.
For correct voice traffic transmission, perform the following tasks on Device A:
·           Configure voice VLANs 2 and 3 to transmit voice packets from IP phones A and B, respectively.
·           Configure Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to operate in automatic voice VLAN assignment mode.
·           Add MAC addresses of IP phones A and B to the device for voice packet identification. The mask of the two MAC addresses is FFFF-FF00-0000.
Figure 16 Network diagram
1.      Configure voice VLANs:
[DeviceA] vlan 2 to 3
# Set the voice VLAN aging timer to 30 minutes.
[DeviceA] voice-vlan aging 30
# Configure voice VLANs to operate in security mode to transmit only voice packets.
[DeviceA] voice-vlan security enable
# Add MAC addresses of IP phones A and B to the device with the mask FFFF-FF00-0000.
[DeviceA] voice-vlan mac-address 0011-1100-0001 mask ffff-ff00-0000 description IP phone A
[DeviceA] voice-vlan mac-address 0011-2200-0001 mask ffff-ff00-0000 description IP phone B
2.      Configure Ten-GigabitEthernet 1/0/1:
# Configure Ten-GigabitEthernet 1/0/1 as a hybrid port.
# Configure Ten-GigabitEthernet 1/0/1 to operate in automatic voice VLAN assignment mode.
[DeviceA-Ten-GigabitEthernet1/0/1] voice-vlan mode auto
# Enable voice VLAN on Ten-GigabitEthernet 1/0/1 and configure VLAN 2 as the voice VLAN for it.
[DeviceA-Ten-GigabitEthernet1/0/1] voice-vlan 2 enable
3.      Configure Ten-GigabitEthernet 1/0/2:
# Configure Ten-GigabitEthernet 1/0/2 as a hybrid port.
[DeviceA-Ten-GigabitEthernet1/0/2] port link-type hybrid
# Configure Ten-GigabitEthernet 1/0/2 to operate in automatic voice VLAN assignment mode.
[DeviceA-Ten-GigabitEthernet1/0/2] voice-vlan mode auto
# Enable voice VLAN on Ten-GigabitEthernet 1/0/2 and configure VLAN 3 as the voice VLAN for it.
[DeviceA-Ten-GigabitEthernet1/0/2] voice-vlan 3 enable
# Display the OUI addresses and their masks and descriptions.
[DeviceA] display voice-vlan mac-address
OUI Address     Mask            Description
0001-e300-0000  ffff-ff00-0000  Siemens phone
0003-6b00-0000  ffff-ff00-0000  Cisco phone
0004-0d00-0000  ffff-ff00-0000  Avaya phone
000f-e200-0000  ffff-ff00-0000  H3C Aolynk phone
0060-b900-0000  ffff-ff00-0000  Philips/NEC phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3Com phone
# Display the voice VLAN state.
[DeviceA] display voice-vlan state
 Current Voice VLANs: 2
 Voice VLAN security mode: Security
 Voice VLAN aging time: 30 minutes
 Voice VLAN enabled ports and their modes:
 Port                            VLAN        Mode        COS        DSCP
 XGE1/0/1                        2           AUTO        6          46
 XGE1/0/2                        3           AUTO        6          46
Manual voice VLAN assignment mode configuration example
As shown in Figure 17:
·           Device A transmits only voice traffic.
·           IP phone A send untagged voice traffic.
·           Configure a voice VLAN to transmit voice traffic.
·           Configure Ten-GigabitEthernet 1/0/1 to operate in manual voice VLAN assignment mode.
·           Add the MAC address of IP phone A to the device for voice packet identification. The mask is FFFF-FF00-0000.
Figure 17 Network diagram
# Configure the voice VLAN to operate in security mode.
# Add a MAC address 0011-2200-0000 with the mask FFFF-FF00-0000.
[DeviceA] voice-vlan mac-address 0011-2200-0000 mask ffff-ff00-0000 description test
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] quit
# Configure Ten-GigabitEthernet 1/0/1 to operate in manual voice VLAN assignment mode.
[DeviceA-Ten-GigabitEthernet1/0/1] undo voice-vlan mode auto
# Configure VLAN 2 as the PVID of Ten-GigabitEthernet 1/0/1.
[DeviceA-Ten-GigabitEthernet1/0/1] port hybrid pvid vlan 2
# Configure Ten-GigabitEthernet 1/0/1 to forward the voice traffic from VLAN 2 without VLAN tags.
[DeviceA-Ten-GigabitEthernet1/0/1] port hybrid vlan 2 untagged
# Enable voice VLAN and configure VLAN 2 as the voice VLAN on Ten-GigabitEthernet 1/0/1.
 Current Voice VLANs: 1
 Voice VLAN aging time: 1440 minutes
 Port                            VLAN        Mode        CoS        DSCP
 XGE1/0/1                        2           Manual      6          46
