03-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10003-Layer 2—LAN Switching Configuration Guide
04-MAC address table configuration
04-MAC address table configuration 248.91 KB
Configuring the MAC address table· 2
Overview· 2
How a MAC address entry is created· 2
Types of MAC address entries· 2
MAC address table configuration task list 3
Configuring MAC address entries· 4
Configuration guidelines· 4
Adding or modifying a static or dynamic MAC address entry globally· 4
Adding or modifying a static or dynamic MAC address entry on an interface· 4
Adding or modifying a blackhole MAC address entry· 5
Adding or modifying a multiport unicast MAC address entry· 5
Disabling MAC address learning· 7
Disabling global MAC address learning· 7
Disabling MAC address learning on an interface· 7
Disabling MAC address learning on a VLAN· 8
Setting the aging timer for dynamic MAC address entries· 8
Setting the MAC learning limit on an interface· 8
Configuring the device to forward unknown frames after the MAC learning limit on an interface is reached  9
Assigning MAC learning priority to an interface· 9
Enabling MAC address synchronization· 10
Enable MAC address move notifications· 11
Enabling ARP fast update for MAC address moves· 12
Disabling static source check· 13
Enabling SNMP notifications for the MAC address table· 14
Displaying and maintaining the MAC address table· 14
MAC address table configuration example· 15
Network requirements· 15
Configuration procedure· 15
Verifying the configuration· 15
Configuring MAC Information· 17
Enabling MAC Information· 17
Configuring the MAC Information mode· 17
Configuring the MAC change notification interval 18
Configuring the MAC Information queue length· 18
MAC Information configuration example· 18
Network requirements· 18
Configuration restrictions and guidelines· 19
Configuration procedure· 19
Overview
An Ethernet device uses a MAC address table to forward frames. A MAC address entry includes a destination MAC address, an outgoing interface, and a VLAN ID. When the device receives a frame, it uses the destination MAC address of the frame to look for a match in the MAC address table.
·           The device forwards the frame out of the outgoing interface in the matching entry if a match is found.
·           The device floods the frame in the VLAN of the frame if no match is found.
The entries in the MAC address table include entries automatically learned by the device and entries manually added.
The device can automatically populate its MAC address table by learning the source MAC addresses of incoming frames on each interface.
When a frame arrives at an interface (for example, port A), the device performs the following operations:
1.      Checks the source MAC address (for example, MAC-SOURCE) of the frame.
2.      Looks up the source MAC address in the MAC address table.
¡  The device updates the entry if an entry is found.
¡  The device adds an entry for MAC-SOURCE and port A if no entry is found.
3.      When the device receives a frame destined for MAC-SOURCE after learning this source MAC address, the device performs the following operations:
a.    Finds the MAC-SOURCE entry in the MAC address table.
b.    Forwards the frame out of port A.
The device performs the learning process each time it receives a frame with an unknown source MAC address until the table is fully populated.
Manually configuring MAC address entries
Dynamic MAC address learning does not distinguish between illegitimate and legitimate frames, which can invite security hazards. When Host A is connected to port A, a MAC address entry will be learned for the MAC address of Host A (for example, MAC A). When an illegal user sends frames with MAC A as the source MAC address to port B, the device performs the following operations:
1.      Learns a new MAC address entry with port B as the outgoing interface and overwrites the old entry for MAC A.
2.      Forwards frames destined for MAC A out of port B to the illegal user.
As a result, the illegal user obtains the data of Host A. To improve the security for Host A, manually configure a static entry to bind Host A to port A. Then, the frames destined for Host A are always sent out of port A. Other hosts using the forged MAC address of Host A cannot obtain the frames destined for Host A.
A MAC address table can contain the following types of entries:
·           Static entries—A static entry is manually added to forward frames with a specific destination MAC address out of the associated interface, and it never ages out. A static entry has higher priority than a dynamically learned one.
·           Dynamic entries—A dynamic entry can be manually configured or dynamically learned to forward frames with a specific destination MAC address out of the associated interface. A dynamic entry might age out. A manually configured dynamic entry has the same priority as a dynamically learned one.
·           Blackhole entries—A blackhole entry is manually configured and never ages out. A blackhole entry is configured for filtering out frames with a specific source or destination MAC address. For example, for security purposes, to block all frames destined for or sourced from a user, you can configure the user's MAC address as a blackhole MAC address entry.
·           Multiport unicast entriesA multiport unicast entry is manually added to send frames with a specific unicast destination MAC address out of multiple ports, and it never ages out. A multiport unicast entry has higher priority than a dynamically learned one.
A static, blackhole, or multiport unicast MAC address entry can overwrite a dynamic MAC address entry, but not vice versa.
The configuration tasks discussed in the following sections can be performed in any order.
This document covers only the configuration of unicast MAC address entries, including static, dynamic, blackhole, and multiport unicast MAC address entries. For information about configuring static multicast MAC address entries, see IP Multicast Configuration Guide.
To configure the MAC address table, perform the following tasks:
Tasks at a glance
(Optional.) Configuring MAC address entries
·          Adding or modifying a static or dynamic MAC address entry globally
·          Adding or modifying a static or dynamic MAC address entry on an interface
·          Adding or modifying a blackhole MAC address entry
·          Adding or modifying a multiport unicast MAC address entry
(Optional.) Disabling MAC address learning
(Optional.) Setting the aging timer for dynamic MAC address entries
(Optional.) Setting the MAC learning limit on an interface
(Optional.) Configuring the device to forward unknown frames after the MAC learning limit on an interface is reached
(Optional.) Assigning MAC learning priority to an interface
(Optional.) Enabling MAC address synchronization
(Optional.) Enable MAC address move notifications
(Optional.) Enabling ARP fast update for MAC address moves
(Optional.) Disabling static source check
(Optional.) Enabling SNMP notifications for the MAC address table
·           You cannot add a dynamic MAC address entry if a learned entry already exists with a different outgoing interface for the MAC address.
·           The manually configured static, blackhole, and multiport unicast MAC address entries cannot survive a reboot if you do not save the configuration. The manually configured dynamic MAC address entries are lost upon reboot whether or not you save the configuration.
A frame whose source MAC address matches different types of MAC address entries is processed differently.
Static MAC address entry
·          Discards the frame received on a different interface from that in the entry.
·          Forwards the frame received on the same interface with that in the entry.
Multiport unicast MAC address entry
Learns the MAC address (for example, MAC A) of the frame, generates a dynamic MAC address entry for MAC A, and forwards the frame. However, the generated dynamic MAC address entry does not take effect. Frames destined for MAC A are forwarded based on the multiport unicast MAC address entry.
Dynamic MAC address entry
·          Learns the MAC address of the frames received on a different interface from that in the entry and overwrites the original entry.
·          Forwards the frame received on the same interface as that in the entry and updates the aging timer for the entry.
Step
Remarks
1.      Enter system view.
N/A
2.      Add or modify a static or dynamic MAC address entry.
By default, no MAC address entry is configured globally.
Make sure you have created the VLAN and assigned the interface to the VLAN.
Step
Remarks
N/A
2.      Enter interface view.
·          Enter Layer 2 Ethernet interface view:
·          Enter Layer 2 aggregate interface view:
·          Enter S-channel interface view:
interface s-channel interface-number.channel-id
·          Enter S-channel aggregate interface view:
interface schannel-aggregation interface-number:channel-id
N/A
3.      Add or modify a static or dynamic MAC address entry.
mac-address { dynamic | static } mac-address vlan vlan-id
By default, no MAC address entry is configured on an interface.
Step
Remarks
N/A
2.      Add or modify a blackhole MAC address entry.
By default, no blackhole MAC address entry is configured.
Make sure you have created the VLAN.
You can configure a multiport unicast MAC address entry to associate a unicast destination MAC address with multiple ports. The frame with a destination MAC address matching the entry is sent out of multiple ports.
For example, in NLB unicast mode:
·           All servers within the cluster uses the cluster's MAC address as their own address.
·           Frames destined for the cluster are forwarded to every server in the group.
In this case, you can configure a multiport unicast MAC address entry on the device connected to the server group. Then, the device forwards the frame destined for the server group through all ports connected to the servers within the cluster.
Figure 1 NLB cluster
Do not configure an interface as the output interface of a multiport unicast MAC address entry if the interface receives frames destined for the multiport unicast MAC address. Otherwise, the frames are flooded on the VLAN to which they belong.
You can configure a multiport unicast MAC address entry globally or on an interface.
Configuring a multiport unicast MAC address entry globally
Step
Remarks
N/A
2.      Add or modify a multiport unicast MAC address entry.
By default, no multiport unicast MAC address entry is configured globally.
Configuring a multiport unicast MAC address entry on an interface
Step
Remarks
N/A
N/A
3.      Add the interface to a multiport unicast MAC address entry.
mac-address multiport mac-address vlan vlan-id
By default, no multiport unicast MAC address entry is configured on an interface.
MAC address learning is enabled by default. To prevent the MAC address table from being saturated when the device is experiencing attacks, disable MAC address learning. For example, you can disable MAC address learning to prevent the device from being attacked by a large amount of frames with different source MAC addresses.
When MAC address learning is disabled, the device immediately deletes the existing dynamic MAC address entries.
Step
Remarks
N/A
2.      Disable global MAC address learning.
undo mac-address mac-learning enable
By default, global MAC address learning is enabled.
Disabling global MAC address learning disables MAC address learning on all interfaces.
The global MAC address learning configuration does not take effect in a TRILL network or for an S-channel. For information about TRILL, see TRILL Configuration Guide. For information about S-channels, see EVB Configuration Guide.
When global MAC address learning is enabled, you can disable MAC address learning on a single interface.
To disable MAC address learning on an interface:
Step
Remarks
N/A
N/A
3.      Disable MAC address learning on the interface.
By default, MAC address learning on the interface is enabled.
When global MAC address learning is enabled, you can disable MAC address learning on a per-VLAN basis.
To disable MAC address learning on a VLAN:
Step
Remarks
N/A
2.      Enable global MAC address learning.
3.      Enter VLAN view.
vlan vlan-id
N/A
4.      Disable MAC address learning on the VLAN.
By default, MAC address learning on the VLAN is enabled.
For security and efficient use of table space, the MAC address table uses an aging timer for each dynamic MAC address entry. If a dynamic MAC address entry is not updated before the aging timer expires, the device deletes the entry. This aging mechanism ensures that the MAC address table can promptly update to accommodate latest network topology changes.
A stable network requires a longer aging interval, and an unstable network requires a shorter aging interval.
An aging interval that is too long might cause the MAC address table to retain outdated entries. As a result, the MAC address table resources might be exhausted, and the MAC address table might fail to update to accommodate the latest network changes.
An interval that is too short might result in removal of valid entries, which would cause unnecessary floods and possibly affect the device performance.
To reduce floods on a stable network, set a long aging timer or disable the timer to prevent dynamic entries from unnecessarily aging out. Reducing floods improves the network performance. Reducing flooding also improves the security because it reduces the chances for a data frame to reach unintended destinations.
To set the aging timer for dynamic MAC address entries:
Step
Remarks
N/A
2.      Set the aging timer for dynamic MAC address entries.
By default, the aging timer is 300 seconds for dynamic MAC address entries.
The no-aging keyword disables the aging timer.
This feature limits the MAC address table size. A large MAC address table will degrade forwarding performance.
To set the MAC learning limit on an interface:
Step
Remarks
N/A
2.      Enter Layer 2 Ethernet interface view.
N/A
3.      Set the MAC learning limit on the interface.
By default, the maximum number of MAC addresses that can be learned on an interface is not set.
In this document, unknown frames refer to frames whose source MAC addresses are not in the MAC address table.
You can enable or disable forwarding of unknown frames after the MAC learning limit is reached.
To enable the interface to forward unknown frames after the MAC learning limit is reached:
Step
Remarks
N/A
·          Enter Layer 2 Ethernet interface view.
·          Enter Layer 2 aggregate interface view.
N/A
3.      Configure the device to forward unknown frames received on the interface after the MAC learning limit on the interface is reached.
mac-address max-mac-count enable-forwarding
By default, the device can forward unknown frames received on an interface after the MAC learning limit on the interface is reached.
IMPORTANT
IMPORTANT:
To make this feature take effect in an IRF fabric, you must also enable MAC address synchronization by using the mac-address mac-roaming enable command.
The MAC learning priority mechanism assigns either low priority or high priority to an interface. An interface with high priority can learn MAC addresses as usual. However, an interface with low priority is not allowed to learn MAC addresses already learned on a high-priority interface.
The MAC learning priority mechanism can help defend your network against MAC address spoofing attacks. In a network that performs MAC-based forwarding, an upper layer device MAC address might be learned by a downlink interface because of a loop or attack to the downlink interface. To avoid this issue, perform the following tasks:
·           Assign high MAC learning priority to an uplink interface.
·           Assign low MAC learning priority to a downlink interface.
To assign MAC learning priority to an interface:
Step
Remarks
N/A
N/A
3.      Assign MAC learning priority to the interface.
mac-address mac-learning priority { high | low }
By default, low MAC learning priority is used.
To avoid unnecessary floods and improve forwarding speed, make sure all member devices have the same MAC address table. After you enable MAC address synchronization, each member device advertises learned MAC address entries to other member devices.
As shown in Figure 2,
·           Device A and Device B form an IRF fabric enabled with MAC address synchronization.
·           Device A and Device B connect to AP C and AP D, respectively.
When Client A associates with AP C, Device A learns a MAC address entry for Client A and advertises it to Device B.
Figure 2 MAC address tables of devices when Client A accesses AP C
When Client A roams to AP D, Device B learns a MAC address entry for Client A. Device B advertises it to Device A to ensure service continuity for Client A, as shown in Figure 3.
Figure 3 MAC address tables of devices when Client A roams to AP D
To enable MAC address synchronization:
Step
Remarks
N/A
2.      Enable MAC address synchronization.
By default, MAC address synchronization is disabled.
The outgoing interface for a MAC address entry learned on interface A is changed to interface B when the following conditions exist:
·           Interface B receives a packet with the MAC address as the source MAC address.
·           Interface B belongs to the same VLAN as interface A.
In this case, the MAC address is moved from interface A to interface B, and a MAC address move occurs.
If a MAC address is continuously moved between the two interfaces, Layer 2 loops might occur. To detect and locate loops, you can view the MAC address move information.
When the system detects that a MAC address frequently moves from an interface, you can configure MAC address move suppression on the interface to bring it down. The interface can automatically come up after waiting for the specified suppression interval. Or, you can manually bring up the interface. To make MAC address move suppression take effect, you must use this feature together with ARP fast update. For more information about ARP fast update, see "Enabling ARP fast update for MAC address moves."
To display the MAC address move records after the device is started, use the display mac-address mac-move command.
To enable MAC address move notifications:
Step
Remarks
N/A
2.      Enable MAC address move notifications and optionally specify a detection interval.
mac-address notification mac-move [ interval interval-value ]
By default, MAC address move notifications are disabled.
If you do not specify a detection interval, the default setting of 1 minute is used.
After you execute this command:
·          If the device is configured with the snmp-agent trap enable mac-address command, the system sends SNMP notifications to the SNMP module.
·          If the device is not configured with the snmp-agent trap enable mac-address command, the system sends log messages to the information center module.
3.      Set a threshold for MAC address moves sourced from an interface within a detection interval.
mac-address notification mac-move suppression threshold threshold-value
The default setting is 3.
4.      Set a MAC address move suppression interval.
mac-address notification mac-move suppression interval interval-value
The default setting is 30 seconds.
5.      Enter interface view.
N/A
6.      Enable MAC address move suppression.
By default, MAC address move suppression is disabled.
7.      Return to system view.
N/A
8.      Enable ARP fast update for MAC address moves.
mac-address mac-move fast-update
This task is required when you enable MAC address move suppression.
By default, ARP fast update for MAC address moves is disabled.
ARP fast update for MAC address moves allows the device to update an ARP entry immediately after the outgoing interface for a MAC address changes. This feature ensures data connection without interruption.
As shown in Figure 4, a mobile user Laptop accesses the network by connecting to AP 1 or AP 2. When the AP to which the user connects changes, the switch updates the ARP entry for the user immediately after it detects a MAC address move.
Figure 4 ARP fast update application scenario
To enable ARP fast update for MAC address moves:
Step
Remarks
N/A
2.      Enable ARP fast update for MAC address moves.
By default, the static source check feature is enabled on an interface. The check identifies whether a received frame meets the following conditions:
·           The source MAC address of the frame matches a static MAC address entry.
·           The incoming interface of the frame is different from the outgoing interface in the entry.
If the frame meets both conditions, the switch drops the frame.
When this feature is disabled, the switch does not perform the check for a received frame. It can forward the frame whether or not the frame meets the conditions.
To disable the static source check feature:
Step
Remarks
N/A
N/A
3.      Disable the static source check feature.
undo mac-address static source-check enable
By default, the static source check feature is enabled.
After you enable SNMP notifications for the MAC address table, the device will send SNMP notifications to the SNMP module to notify the NMS of important events. You can set the notification sending parameters in SNMP to determine the attributes of sending notifications.
After you disable SNMP notifications for the MAC address table, the device will send log messages to the information center module. You can set the output rules and destinations to examine the log messages of the MAC address table module.
For more information about SNMP notifications and information center, see Network Management and Monitoring Configuration Guide.
To enable SNMP notifications for the MAC address table:
Step
Remarks
N/A
2.      Enable SNMP notifications for the MAC address table.
snmp-agent trap enable mac-address [ mac-move ]
By default, SNMP notifications are disabled for the MAC address table.
Display MAC address table information.
Display the MAC address information of the egress RB specified by its nickname (see Figure 5).
display mac-address nickname nickname
Display the aging timer for dynamic MAC address entries.
display mac-address aging-time
Display the system or interface MAC address learning state.
Display MAC address statistics.
display mac-address statistics
Display the MAC address move records.
display mac-address mac-move [ slot slot-number ]
Figure 5 An example for the display mac-address nickname command
Host A at MAC address 000f-e235-dc71 is connected to interface Ten-GigabitEthernet 1/0/1 of Device and belongs to VLAN 1.
Host B at MAC address 000f-e235-abcd, which behaved suspiciously on the network, also belongs to VLAN 1.
Configure the MAC address as follows:
·           To prevent MAC address spoofing, add a static entry for Host A in the MAC address table of Device.
·           To drop all frames destined for Host B, add a blackhole MAC address entry for the host.
·           Set the aging timer to 500 seconds for dynamic MAC address entries.
# Add a static MAC address entry for MAC address 000f-e235-dc71 on Ten-GigabitEthernet 1/0/1 that belongs to VLAN 1.
[Device] mac-address static 000f-e235-dc71 interface ten-gigabitethernet 1/0/1 vlan 1
# Add a blackhole MAC address entry for MAC address 000f-e235-abcd that belongs to VLAN 1.
[Device] mac-address blackhole 000f-e235-abcd vlan 1
# Set the aging timer to 500 seconds for dynamic MAC address entries.
[Device] mac-address timer aging 500
# Display the static MAC address entries for interface Ten-GigabitEthernet 1/0/1.
[Device] display mac-address static interface ten-gigabitethernet 1/0/1
MAC Address      VLAN ID    State            Port/NickName            Aging
000f-e235-dc71   1          Static           XGE1/0/1                 N
# Display the blackhole MAC address entries.
[Device] display mac-address blackhole
000f-e235-abcd   1          Blackhole        N/A                      N
# Display the aging time of dynamic MAC address entries.
[Device] display mac-address aging-time
MAC address aging time: 500s.
The MAC Information feature can generate syslog messages or SNMP notifications when MAC address entries are learned or deleted. You can use these messages to monitor users leaving or joining the network and analyze network traffic.
The MAC Information feature buffers the MAC change syslog messages or SNMP notifications in a queue. The device overwrites the oldest MAC address change written into the queue with the most recent MAC address change when the following conditions exist:
·           The MAC change notification interval does not expire.
·           The queue has been exhausted.
To send a syslog message or SNMP notification immediately after it is created, set the queue length to zero.
The device writes information and sends messages only for the following MAC addresses:
·           Dynamic MAC addresses.
·           MAC addresses that pass MAC authentication.
·           MAC addresses that pass 802.1X authentication.
·           Secure MAC addresses.
The device does not write information or send messages for blackhole MAC addresses, static MAC addresses, multiport unicast MAC addresses, multicast MAC addresses, and local MAC addresses.
For more information about MAC authentication, 802.1X, and secure MAC addresses, see Security Configuration Guide.
Step
Remarks
N/A
2.      Enable MAC Information globally.
mac-address information enable
By default, MAC Information is globally disabled.
3.      Enter Layer 2 Ethernet interface view.
N/A
4.      Enable MAC Information on the interface.
By default, MAC Information is disabled on an interface.
Make sure you have enabled MAC Information globally before you enable it on the interface.
The following MAC Information modes are available for sending MAC address changes:
·           Syslog—The device sends syslog messages to notify MAC address changes. The device sends syslog messages to the information center, which then outputs them to the monitoring terminal. For more information about information center, see Network Management and Monitoring Configuration Guide.
·           Trap—The device sends SNMP notifications to notify MAC address changes. The device sends SNMP notifications to the NMS. For more information about SNMP, see Network Management and Monitoring Configuration Guide.
To configure the MAC Information mode:
Step
Remarks
N/A
2.      Configure the MAC Information mode.
The default setting is trap.
To prevent syslog messages or SNMP notifications from being sent too frequently, you can set the MAC change notification interval to a larger value.
To set the MAC change notification interval:
Step
Remarks
N/A
2.      Set the MAC change notification interval.
mac-address information interval interval-time
The default setting is 1 second.
Step
Remarks
N/A
2.      Configure the MAC Information queue length.
The default setting is 50.
Enable MAC Information on interface Ten-GigabitEthernet 1/0/1 on Device in Figure 6 to send MAC address changes in syslog messages to the log host, Host B, through interface Ten-GigabitEthernet 1/0/2.
Figure 6 Network diagram
When you edit the file /etc/syslog.conf, follow these restrictions and guidelines:
·           Comments must be on a separate line and must begin with a pound sign (#).
·           No redundant spaces are allowed after the file name.
·           The logging facility name and the severity level specified in the /etc/syslog.conf file must be the same as those configured on the device. Otherwise, the log information might not be output correctly to the log host. The logging facility name and the severity level are configured by using the info-center loghost and info-center source commands, respectively.
1.      Configure Device to send syslog messages to Host B:
# Enable the information center.
[Device] info-center enable
# Specify the log host 192.168.1.2/24 and specify local4 as the logging facility.
[Device] info-center loghost 192.168.1.2 facility local4
# Disable log output to the log host.
To avoid output of unnecessary information, disable all modules from outputting logs to the specified destination (loghost, in this example) before you configure an output rule.
# Configure an output rule to output to the log host MAC address logs that have a severity level of at least informational.
[Device] info-center source mac loghost level informational
2.      Configure the log host, Host B:
Configure Solaris as follows. Configure other UNIX operating systems in the same way Solaris is configured.
a.    Log in to the log host as a root user.
b.    Create a subdirectory named Device in directory /var/log/.
# mkdir /var/log/Device
c.    Create file info.log in the Device directory to save logs from Device.
d.    Edit the file syslog.conf in directory /etc/ and add the following contents:
In this configuration, local4 is the name of the logging facility that the log host uses to receive logs, and info is the informational level. The UNIX system records the log information that has a severity level of at least informational to the file /var/log/Device/info.log.
e.    Display the process ID of syslogd, end the syslogd process, and then restart syslogd using the –r option to make the new configuration take effect.
# ps -ae | grep syslogd
147
# kill -HUP 147
# syslogd -r &
The device can output MAC address logs to the log host, which stores the logs to the specified file.
3.      Enable MAC Information on Device:
# Enable MAC Information globally.
[Device] mac-address information enable
# Configure the MAC Information mode as syslog.
[Device] mac-address information mode syslog
# Enable MAC Information on interface Ten-GigabitEthernet 1/0/1 to enable Ten-GigabitEthernet 1/0/1 to record MAC address change information when the interface performs either of the following operations:
¡  Learns a new MAC address.
¡  Deletes an existing MAC address.
[Device-Ten-GigabitEthernet1/0/1] mac-address information enable added
[Device-Ten-GigabitEthernet1/0/1] mac-address information enable deleted
# Set the MAC Information queue length to 100.
[Device] mac-address information queue-length 100
# Set the MAC change notification interval to 20 seconds.
[Device] mac-address information interval 20
