03-Layer 2—LAN Switching Configuration Guide
HomeSupportSwitchesS6300 SeriesConfigure & DeployConfiguration GuidesH3C S6300 Switch Series Configuration Guides-Release 243x-6W10003-Layer 2—LAN Switching Configuration Guide
08-Loop detection configuration
08-Loop detection configuration 113.83 KB
Configuring loop detection
Overview
Incorrect network connections or configurations can create Layer 2 loops, which results in repeated transmission of broadcasts, multicasts, or unknown unicasts. The repeated transmission can waste network resources and can sometimes paralyze networks. The loop detection mechanism immediately generates a log when a loop occurs so that you are promptly notified to adjust network connections and configurations. You can configure loop detection to shut down the looped port. Logs are maintained in the information center. For more information, see Network Management and Monitoring Configuration Guide.
Loop detection mechanism
The device detects loops by sending detection frames and then checking whether these frames return to any port on the device. If they do, the device considers that the port is on a looped link.
Loop detection usually works within a VLAN. If a detection frame is returned with a VLAN tag different from the one it was sent out with, an inter-VLAN loop has occurred. To remove the loop, examine the QinQ configuration for incorrect settings. For more information about QinQ, see "Configuring QinQ.".
Figure 1 Ethernet frame header for loop detection
The Ethernet frame header for loop detection contains the following fields:
·           DMACDestination MAC address of the frame, which is the multicast MAC address 010F-E200-0007. When a loop detection-enabled device receives a frame with this destination MAC address, it sends the frame to the CPU and floods the frame in the VLAN from which the frame was originally received.
·           SMACSource MAC address of the frame, which is the bridge MAC address of the sending device.
·           TPIDType of the VLAN tag, with the value of 0x8100.
·           TCIInformation of the VLAN tag, including the priority and VLAN ID.
·           TypeProtocol type, with the value of 0x8918.
Figure 2 Inner frame header for loop detection
The inner frame header for loop detection contains the following fields:
·           CodeProtocol sub-type, which is 0x0001, indicating the loop detection protocol.
·           VersionProtocol version, which is always 0x0000.
·           LengthLength of the frame. The value includes the inner header, but excludes the Ethernet header.
·           ReservedThis field is reserved.
Frames for loop detection are encapsulated as TLV triplets.
Table 1 TLVs supported by loop detection
TLV
Remarks
End of PDU
End of a PDU.
Optional.
Device ID
Bridge MAC address of the sending device.
Required.
Port ID
ID of the PDU sending port.
Optional.
Port Name
Name of the PDU sending port.
Optional.
System Name
Device name.
Optional.
Chassis ID
Chassis ID of the sending port.
Optional.
Slot ID
Slot ID of the sending port.
Optional.
Sub Slot ID
Sub-slot ID of the sending port.
Optional.
Loop detection interval
Loop detection is a continuous process as the network changes. Loop detection frames are sent at a specified interval (called a loop detection interval) to determine whether loops occur on ports and whether loops are removed.
Loop protection actions
When the switch detects a loop on a port, it generates a log but performs no action on the port by default. You can configure the switch to take one of the following actions:
·           Block—Disables the port from learning MAC addresses and blocks inbound traffic to the port.
·           No-learning—Disables the port from learning MAC addresses.
·           Shutdown—Shuts down the port to disable it from receiving and sending any frames.
Port status auto recovery
When the device configured with the block or no-learning loop action detects a loop on a port, it performs the action and waits three loop detection intervals. If the device does not receive a loop detection frame within three loop detection intervals, it performs the following tasks:
·           Automatically sets the port to the forwarding state.
·           Notifies the user of the event.
When the device configured with the shutdown action detects a loop on a port, the following events occur:
1.      The device automatically shuts down the port.
2.      The device automatically sets the port to the forwarding state after the detection timer configured by using the shutdown-interval command expires. For more information about the shutdown-interval command, see Fundamentals Command Reference.
3.      The device shuts down the port again if a loop is still detected on the port when the detection timer expires.
This process is repeated until the loop is removed.
Incorrect recovery can occur when loop detection frames are discarded to reduce the load. To avoid this problem, use the shutdown action or manually remove the loop.
Loop detection configuration task list
Tasks at a glance
(Required.) Enabling loop detection
(Optional.) Configuring the loop protection action
(Optional.) Setting the loop detection interval
The loop protection action on a port can be triggered even if loop detection is disabled on the port when the following requirements are met:
·           Loop detection is enabled globally or on any other port on the device.
·           The port receives a loop detection frame of any VLAN.
As a best practice, do not enable loop detection on TRILL ports, because TRILL networks prevent loops from being generated. For information more about TRILL, see TRILL Configuration Guide.
Enabling loop detection globally
Step
Remarks
1.      Enter system view.
N/A
2.      Globally enable loop detection.
loopback-detection global enable vlan { vlan-list | all }
Disabled by default.
Enabling loop detection on a port
Step
Remarks
N/A
2.      Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
3.      Enable loop detection on the port.
loopback-detection enable vlan { vlan-list | all }
You can configure the loop protection action globally or on a per-port basis. The global configuration applies to all ports. The per-port configuration applies to the individual ports. The per-port configuration takes precedence over the global configuration.
Configuring the global loop protection action
Step
Remarks
N/A
2.      Configure the global loop protection action.
loopback-detection global action shutdown
By default, the switch generates a log but performs no action on the port on which a loop is detected.
Configuring the loop protection action on a Layer 2 Ethernet interface
Step
Remarks
N/A
2.      Enter Layer 2 Ethernet interface view.
N/A
3.      Configure the loop protection action on the interface.
loopback-detection action { block | no-learning | shutdown }
Configuring the loop protection action on a Layer 2 aggregate interface
Step
Remarks
N/A
2.      Enter Layer 2 aggregate interface view.
N/A
loopback-detection action shutdown
With loop detection enabled, the switch sends loop detection frames at a specified interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
To set the loop detection interval:
Step
Remarks
N/A
2.      Set the loop detection interval.
loopback-detection interval-time interval
The default setting is 30 seconds.
Displaying and maintaining loop detection
Display the loop detection configuration and status.
display loopback-detection
Loop detection configuration example
Network requirements
As shown in Figure 3, configure loop detection on Device A, so that Device A generates a log as a notification and automatically shuts down the port on which a loop is detected.
Figure 3 Network diagram
Configuration procedure
1.      Configure Device A:
# Create VLAN 100, and globally enable loop detection for the VLAN.
[DeviceA] vlan 100
[DeviceA-vlan100] quit
[DeviceA] loopback-detection global enable vlan 100
# Configure Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 as trunk ports, and assign them to VLAN 100.
[DeviceA-Ten-GigabitEthernet1/0/1] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceA] interface ten-gigabitethernet 1/0/2
[DeviceA-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/2] port trunk permit vlan 100
[DeviceA-Ten-GigabitEthernet1/0/2] quit
# Configure the global loop protection action as shutdown.
[DeviceA] loopback-detection global action shutdown
# Set the loop detection interval to 35 seconds.
[DeviceA] loopback-detection interval-time 35
2.      Configure Device B:
# Create VLAN 100.
[DeviceB] vlan 100
[DeviceB–vlan100] quit
[DeviceB-Ten-GigabitEthernet1/0/1] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceB] interface ten-gigabitethernet 1/0/2
[DeviceB-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/2] port trunk permit vlan 100
[DeviceB-Ten-GigabitEthernet1/0/2] quit
3.      Configure Device C:
# Create VLAN 100.
<DeviceC> system-view
[DeviceC] vlan 100
[DeviceC–vlan100] quit
[DeviceC] interface ten-gigabitethernet 1/0/1
[DeviceC-Ten-GigabitEthernet1/0/1] port link-type trunk
[DeviceC-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100
[DeviceC-Ten-GigabitEthernet1/0/1] quit
[DeviceC] interface ten-gigabitethernet 1/0/2
[DeviceC-Ten-GigabitEthernet1/0/2] port link-type trunk
[DeviceC-Ten-GigabitEthernet1/0/2] port trunk permit vlan 100
[DeviceC-Ten-GigabitEthernet1/0/2] quit
# View the system logs on devices, for example, Device A.
[DeviceA]
%Feb 24 15:04:29:663 2013 DeviceA LPDT/4/LPDT_LOOPED: Loopback exists on Ten-GigabitEthernet1/0/1.
%Feb 24 15:04:29:667 2013 DeviceA LPDT/4/LPDT_LOOPED: Loopback exists on Ten-GigabitEthernet1/0/2.
%Feb 24 15:04:44:243 2013 DeviceA LPDT/5/LPDT_RECOVERED: Loopback on Ten-GigabitEthernet1/0/1 recovered.
%Feb 24 15:04:44:248 2013 DeviceA LPDT/5/LPDT_RECOVERED: Loopback on Ten-GigabitEthernet1/0/2 recovered.
·           Device A detects loops on ports Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 within a loop detection interval.
·           Device A automatically shuts down the ports and generates log messages.
# Use the display loopback-detection command to display the loop detection configuration and status on devices, for example, Device A.
[DeviceA] display loopback-detection
Loop detection is enabled.
Loop detection interval is 35 second(s).
No loopback is detected.
The output shows that the device has removed the loops from Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 according to the shutdown action.
# Display the status of Ten-GigabitEthernet 1/0/1 on devices, for example, Device A.
[DeviceA] display interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1 current state: DOWN (Loop detection down)
The output shows that Ten-GigabitEthernet 1/0/1 is already shut down by the loop detection module.
# Display the status of Ten-GigabitEthernet 1/0/2 on Device A.
[DeviceA] display interface ten-gigabitethernet 1/0/2
Ten-GigabitEthernet1/0/2 current state: DOWN (Loop detection down)
The output shows that Ten-GigabitEthernet 1/0/2 is already shut down by the loop detection module.
