08-ACL and QoS Configuration Examples
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-XS Switch Series Configuration Examples-R7178-6W10008-ACL and QoS Configuration Examples
03-H3C_S7500E-XS_Control_Plane-Based_QoS_Policy_Configuration_Examples
H3C S7500E-XS Control Plane-Based QoS Policy Configuration Examples
H3C_彩色.emf
Introduction
This chapter provides examples for configuring control plane-based QoS policies.
This document assumes that you have basic knowledge of QoS policies.
Example: Rate limiting ICMP packets
Network requirements
As shown in Figure 1, the switch receives a large number of ICMP packets from the Internet. As a result, CPU usage is high, and switch performance degrades.
Configure a control plane-based QoS policy to meet the following requirements:
·     Rate limit ICMP packets sent to the control plane to 320 kbps.
·     Drop excess ICMP packets.
Figure 1 Network diagram
Requirements analysis
To meet the network requirements, you must perform the following tasks:
·     Use the if-match command to classify ICMP packets into a class.
·     Use the car command to configure the rate limit value for ICMP packets and drop excess packets.
Software version used
This configuration example was created and verified on S7500EXS-CMW710-R7178.
When you configure a control plane-based QoS policy to rate limit ICMP packets, follow these restrictions and guidelines:
·     By default, the predefined QoS policy is applied to the control plane. The predefined QoS policy identifies packet types by system index and uses a default rate limit value for each packet type. To display the predefined QoS policy, use the display qos policy control-plane pre-defined command.
·     You can use the if-match control-plane protocol or if-match control-plane protocol-group command to classify protocol packets.
·     You can only configure the car command or a combination of the car and accounting packet commands in the behavior associated with the class. Only the CIR value in the car command takes effect.
Configuration procedures
# Create a class named ICMP, and use the ICMP protocol as the match criterion.
<Switch> system-view
[Switch] traffic classifier ICMP
[Switch-classifier-ICMP] if-match control-plane protocol icmp
[Switch-classifier-ICMP] quit
# Create a behavior named ICMP, and configure a CAR action for ICMP packets.
[Switch] traffic behavior ICMP
[Switch-behavior-ICMP] car cir 320
[Switch-behavior-ICMP] quit
# Create a QoS policy named ICMP, and associate class ICMP with behavior ICMP in QoS policy ICMP.
[Switch] qos policy ICMP
[Switch-qospolicy-ICMP] classifier ICMP behavior ICMP
[Switch-qospolicy-ICMP] quit
# Apply QoS policy ICMP to the inbound direction of the control plane of the card in slot 1.
[Switch] control-plane slot 1
[Switch-cp-slot1] qos apply policy ICMP inbound
[Switch-cp-slot1] quit
Verify the configuration
# Verify that the QoS policy is correctly applied to the control plane.
[Switch] display qos policy control-plane slot 1
Control plane slot 1
  Direction: Inbound
  Policy: ICMP
   Classifier: ICMP
     Operator: AND
     Rule(s) :
      If-match control-plane protocol icmp
     Behavior: ICMP
      Committed Access Rate:
        CIR 320 (kbps), CBS 20480 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
        Green packets : 0 (Packets)
        Red packets   : 0 (Packets)
Configuration files
traffic classifier ICMP operator and
 car cir 320 cbs 20480 ebs 0 green pass red discard yellow pass
qos policy ICMP
Related documentation
·     H3C S7500E-XS Switch Series ACL and QoS Configuration Guide-Release 7178
·     H3C S7500E-XS Switch Series ACL and QoS Command Reference-Release 7178
