04 Layer 3 - IP Services Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10004 Layer 3 - IP Services Command Reference
05-IP forwarding basics commands
05-IP forwarding basics commands 77.24 KB
display fib
Use display fib to display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
vpn-instance vpn-instance-name: Displays the FIB table for the specified VPN. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN, this command displays the FIB entries of the public network.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address, the number of consecutive ones in the mask. The value range is 0 to 32.
Each FIB entry contains a destination IP address/mask, next hop, and output interface.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Destination count: 9 FIB entry count: 9
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
127.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
192.168.0.0/24     192.168.0.63    U        M-GE0/0/0                Null
192.168.0.0/32     192.168.0.63    UBH      M-GE0/0/0                Null
192.168.0.2/32     192.168.0.2     UH       M-GE0/0/0                Null
192.168.0.3/32     192.168.0.3     UH       M-GE0/0/0                Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Destination count: 8 FIB entry count: 8
Flag:
  R:Relay     F:FRR
20.20.20.0/24      20.20.20.25     U        FGE1/1/2                 Null
20.20.20.0/32      20.20.20.25     UBH      FGE1/1/2                 Null
20.20.20.25/32     127.0.0.1       UH       InLoop0                  Null
20.20.20.25/32     20.20.20.25     H        FGE1/1/2                 Null
20.20.20.255/32    20.20.20.25     UBH      FGE1/1/2                 Null
30.30.30.0/24      30.30.30.30     U        FGE1/1/2                 Null
30.30.30.0/32      30.30.30.30     UBH      FGE1/1/8                 Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
  R:Relay     F:FRR
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
Destination count
Total number of destination addresses.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address/mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
display ip load-sharing path
Use display ip load-sharing path to display the load sharing path selected for a flow.
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] } [ dest-port port-id | src-port port-id | ip-pro protocol-id | vpn-instance vpn-instance-name ] *
ingress-port interface-type interface-number: Specify an ingress port by its type and number.
packet-format: Specifies the packet encapsulation format.
ipv4oe: Specifies the format of IPv4 over Ethernet.
dest-ip ip-address: Specifies the destination IPv4 address in dotted decimal notation.
src-ip ip-address: Specifies the source IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
ipv6oe: Specifies the format of IPv6 over Ethernet.
dest-ipv6 ipv6-address: Specifies the destination IPv6 address.
src-ipv6 ipv6-address: Specifies the source IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0.
dest-port port-id: Specifies a destination port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
source-port port-id: Specifies a source port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
ip-pro protocol-id: Specifies an IP protocol by its number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the path on the public network, do not specify this option.
When you configure this command, make sure the options are the same as those in the ip load-sharing mode per-flow command. If the options are not consistent, the path displayed by this command might be different from the real path for load sharing.
# Display the load sharing path selected for the flow with the following attributes: ingress interface FortyGigE 1/1/3, destination IP address 10.110.0.2, source IP address 10.100.0.2, IP protocol number 153, destination port number 2000, source port number 2000, VPN instance vpn10.
<Sysname> display ip load-sharing path ingress-port FortyGigE 1/1/3 packet-format ipv4oe destination-ip 10.110.0.2 source-ip 10.100.0.2 ip-pro 153 dest-port 2000 src-port 2000 vpn-instance vpn10
Load-sharing algorithm: 0
Load-sharing options: ingress-port | dest-ip | src-ip | ip-pro | dest-port | src-port
Load-sharing parameters:
  Missing configured are set to 0.
  ingress-port: FortyGigE1/1/3
  packet-format: IPv4oE
  dest-ip: 10.110.0.2
  src-ip: 10.100.0.2
  ip-pro: 153
  dest-port: 2000
  src-port: 2000
  vpn-instance: VPN10
Path selected: 20.0.0.2(interface FortyGigE1/1/3)
Load sharing algorithm ID.
Load sharing options specified by the ip load-sharing mode per-flow command.
Load sharing parameters that you specify for the display ip load-sharing path command.
Values of the unconfigured parameters are set to 0.
ingress-port
Ingress port of the packet.
packet-format
Packet encapsulation format.
dest-ip
Destination IP address of the packet.
src-ip
Source IP address of the packet.
ip-pro
IP protocol number.
dest-port
Destination port number.
src-port:
Source port number.
vpn-instance
Name of the MPLS L3VPN instance.
Path selected
Selected path information, including the IPv4 or IPv6 address of the next hop and the egress port.
ip load-sharing local-first enable
Use ip load-sharing local-first enable to enable local-first load sharing.
Use undo ip load-sharing local-first enable to disable local-first load sharing.
Local-first load sharing is enabled.
Local-first load sharing takes effect only in an IRF fabric.
# Disable local-first load sharing.
[Sysname] undo ip load-sharing local-first enable
Use ip load-sharing mode per-flow to configure per-flow load sharing.
Use undo ip load-sharing mode per-flow to restore the default.
ip load-sharing mode per-flow [ tunnel { inner | outer } | algorithm algorithm-number | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * ] [ slot slot-number ]
undo ip load-sharing mode [ slot slot-number ]
The device performs per-flow load sharing based on the source IP address, destination IP address, source port, destination port, IP protocol number, ingress port, and VLAN.
per-flow: Implements per-flow load sharing.
algorithm algorithm-number: Enables flow-based load sharing algorithm switching. The algorithm-number argument specifies the algorithm to be switched, and is in the range of 0 to 8. Value 0 indicates the default algorithm.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
ingress-port: Identifies flows by ingress port.
ip-pro: Identifies flows by protocol ID.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
tunnel: Performs load sharing for IP tunnel packets.
·     inner: Identifies flows by inner IP header information.
·     outer: Identifies flows by outer IP header information.
slot slot-number: Specifies an IRF member device by its member ID.
# Configure per-flow load sharing on IRF member device 2.
[Sysname] ip load-sharing mode per-flow slot 2
ip load-sharing symmetric enable
Use ip load-sharing symmetric enable to enable symmetric load sharing.
Use undo ip load-sharing symmetric enable to restore the default.
Symmetric load sharing is disabled.
This feature enables the device to load share a flow and its return traffic on the same path.
# Enable symmetric load sharing.
[Sysname] ip load-sharing symmetric enable
